[PATCH] board: amlogic: odroid-n2: fix fdtfile suffix for n2-plus
The N2+ dtb is meson-g12b-odroid-n2-plus.dtb, not n2_plus, so correct the suffix provided in the board file. Also align the board ident string shown during boot to match.
Fixes: 8bc780106c13 ("board: amlogic: odroid: add runtime detection of the N2/N2+/C4/HC4 variants") Signed-off-by: Christian Hewitt christianshewitt@gmail.com --- board/amlogic/odroid-n2/odroid-n2.c | 2 +- configs/odroid-n2_defconfig | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/amlogic/odroid-n2/odroid-n2.c b/board/amlogic/odroid-n2/odroid-n2.c index 88a60f34fe..acfd107fc5 100644 --- a/board/amlogic/odroid-n2/odroid-n2.c +++ b/board/amlogic/odroid-n2/odroid-n2.c @@ -48,7 +48,7 @@ static struct meson_odroid_boards { /* OdroidN2 rev 2019,2,7 */ { MESON_SOC_ID_G12B, 330 * 4, 350 * 4, "n2" }, /* OdroidN2plus rev 2019,11,20 */ - { MESON_SOC_ID_G12B, 410 * 4, 430 * 4, "n2_plus" }, + { MESON_SOC_ID_G12B, 410 * 4, 430 * 4, "n2-plus" }, /* OdroidC4 rev 2020,01,29 */ { MESON_SOC_ID_SM1, 80 * 4, 100 * 4, "c4" }, /* OdroidHC4 rev 2019,12,10 */ diff --git a/configs/odroid-n2_defconfig b/configs/odroid-n2_defconfig index bac44b61ab..1f718a3154 100644 --- a/configs/odroid-n2_defconfig +++ b/configs/odroid-n2_defconfig @@ -9,7 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="meson-g12b-odroid-n2" CONFIG_MESON_G12A=y CONFIG_DEBUG_UART_BASE=0xff803000 CONFIG_DEBUG_UART_CLOCK=24000000 -CONFIG_IDENT_STRING=" odroid-n2/n2_plus" +CONFIG_IDENT_STRING=" odroid-n2/n2-plus" CONFIG_DEBUG_UART=y CONFIG_OF_BOARD_SETUP=y # CONFIG_DISPLAY_CPUINFO is not set
- { MESON_SOC_ID_G12B, 410 * 4, 430 * 4, "n2-plus" }, /* OdroidC4 rev 2020,01,29 */ { MESON_SOC_ID_SM1, 80 * 4, 100 * 4, "c4" }, /* OdroidHC4 rev 2019,12,10 */
Indeed, thx for the fix
Acked-by: Neil Armstrong narmstrong@baylibre.com
If nobody complains I'll push it at the end of the week !
Neil
Christian Hewitt
Neil Armstrong
