[U-Boot] [PATCH] powerpc: Replace CONFIG_SYS_INIT_RAM_END with CONFIG_SYS_INIT_RAM_SIZE
CONFIG_SYS_INIT_RAM_SIZE may be used out of the board header file. Some boards use CONFIG_SYS_INIT_RAM_END for the same purpose. To unify the macros, use CONFIG_SYS_INIT_RAM_SIZE for all.
Signed-off-by: York Sun york.sun@nxp.com CC: Mario Six mario.six@gdsys.cc
include/configs/BSC9131RDB.h | 4 ++-- include/configs/BSC9132QDS.h | 4 ++-- include/configs/C29XPCIE.h | 4 ++-- include/configs/P1010RDB.h | 4 ++-- include/configs/a3m071.h | 4 ++-- include/configs/ac14xx.h | 4 ++-- include/configs/dlvision-10g.h | 4 ++-- include/configs/io.h | 4 ++-- include/configs/iocon.h | 4 ++-- include/configs/o2dnt-common.h | 6 +++--- 10 files changed, 21 insertions(+), 21 deletions(-)
diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 9c32a01..e870ffe 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -215,9 +215,9 @@ extern unsigned long get_sdram_size(void);
#define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ -#define CONFIG_SYS_INIT_RAM_END 0x00004000/* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000/* End of used area in RAM */
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE \ - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 9f7ceb8..108e924 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -396,9 +396,9 @@ combinations. this should be removed later
#define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ -#define CONFIG_SYS_INIT_RAM_END 0x00004000 /* End of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* End of used area in RAM */
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 4cbc9ad..a7a5e8e 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -329,9 +329,9 @@
#define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 -#define CONFIG_SYS_INIT_RAM_END 0x00004000 +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 81af871..249e11b 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -555,9 +555,9 @@ extern unsigned long get_sdram_size(void);
diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index cf931a6..31348da 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -141,9 +141,9 @@
/* Use SRAM until RAM will be available */ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - \ +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index 750d8ff..57421c6 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -289,9 +289,9 @@
/* Use SRAM for initial stack */ #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_SRAM_BASE -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_SRAM_SIZE
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index 9f9bcb8..bbeed76 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -238,10 +238,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE
#define CONFIG_SYS_GBL_DATA_OFFSET \ - (CONFIG_SYS_INIT_RAM_END - GENERATED_GBL_DATA_SIZE) + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* diff --git a/include/configs/io.h b/include/configs/io.h index 1213fe2..f05eb0a 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -196,10 +196,10 @@ #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE
/* diff --git a/include/configs/iocon.h b/include/configs/iocon.h index 8bc89a0..f75ca76 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -249,10 +249,10 @@ int fpga_gpio_get(unsigned int bus, int pin); #define CONFIG_SYS_OCM_DATA_ADDR 0xF8000000 #define CONFIG_SYS_OCM_DATA_SIZE 0x1000 #define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_OCM_DATA_ADDR /* in SDRAM */ -#define CONFIG_SYS_INIT_RAM_END CONFIG_SYS_OCM_DATA_SIZE /* End of used area */ +#define CONFIG_SYS_INIT_RAM_SIZE CONFIG_SYS_OCM_DATA_SIZE
/* diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 73a44a7..4ffab8a 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -253,13 +253,13 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #ifdef CONFIG_POST /* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_POST_SIZE #else /* End of used area in DPRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE +#define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
Stefan, Anatolij, Dirk,
Do you have any objection/comment on the proposed changes? I plan to merge it soon.
York
Looks good to me (not tested on real hardware), so:
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Hi York,
Acked-by: Anatolij Gustschin agust@denx.de
-- Anatolij
Applied to u-boot-mpc85xx master. Awaiting upstream.
York
Anatolij Gustschin
Stefan Roese
York Sun
