[U-Boot] ARM / PXA unapplied patches
Dear Jean-Christophe,
I have a couple of unapplied patches in my list which seem to fall into your area of responsibility. Can you please have a look at these:
1 04/24 michael [U-Boot-Users] [PATCH ARM 0/2] Ide support 2 04/24 michael [U-Boot-Users] [PATCH ARM 1/2] Ide support io function 3 04/24 michael [U-Boot-Users] [PATCH ARM 2/2] Ide support. Ide registration 4320 07/18 Adrian Filipi [U-Boot-Users] [PATCH] Set up SD/MMC OCR as comment describes. i.e. 3 4373 07/21 Adrian Filipi Re: [U-Boot-Users] [PATCH] asm-arm/sizes.h clean-up 5943 08/15 Sergey Lapin [U-Boot] [PATCH] Custom AFEB9260 board support 5945 08/15 Sergey Lapin [U-Boot] [PATCH][Re-submit] Hardware watchdog support for AT91SAM9260 5956 08/15 "Gururaja Hebbar [U-Boot] [PATCH] - Correct Invalid Timer Register Field Declaration 6043 08/18 Magnus Lilja [U-Boot] [PATCH v2 0/6] i.MX31: Add NAND support and new PDK board. 6044 08/18 Magnus Lilja [U-Boot] [PATCH v2 1/6] i.MX31: Add NFC_BASE_ADDR definition. 6045 08/18 Magnus Lilja [U-Boot] [PATCH v2 2/6] i.MX31: Add reset_timer() and modify get_time 6046 08/18 Magnus Lilja [U-Boot] [PATCH v2 3/6] i.MX31: Add i.MX31 NAND Flash Controller driv 6047 08/18 Magnus Lilja [U-Boot] [PATCH v2 4/6] i.MX31: Add NAND support in the i.MX31 Liteki 6048 08/18 Magnus Lilja [U-Boot] [PATCH v2 5/6] i.MX31: Make the SPI bus and chip select conf 6049 08/18 Magnus Lilja [U-Boot] [PATCH v2 6/6] i.MX31: Add basic support for Freescale's i.M 6209 08/20 "Gururaja Hebbar Would like to know the status of the Patches 6407 08/23 Dirk Behme [U-Boot] [PATCH] ARM: Update mach-types.h 6423 08/24 "Gururaja Hebbar [U-Boot] [PATCH] ARM OMAP : Correct Invalid Timer Register Field Decl 6472 08/25 Andrew Dyer [U-Boot] [patch] arm920t fix constant error in start.S 6751 08/28 Andrew Dyer Re: [U-Boot] [patch] i.MX use u-boot baud rate and don't assume UART 6583 08/26 Andrew Dyer [U-Boot] [patch] i.mx change get_timer(base) to return time since bas 6633 08/27 Atsuo Igarashi [U-Boot] [PATCH] Add support for KMC KZM-ARM11-01 board 6644 08/27 Claudio Scordino Bug ? at91rm9200dk mach-type 6703 08/28 Markus Kammerstet [U-Boot] PATCH: U-Boot support for Olimex SAM9L-9260 development board 6712 08/28 Claudio Scordino [PATCH] at91rm9200dk mach-type 6717 08/28 Guennadi Liakhove [U-Boot] [PATCH] i.MX31: document timer precision option 6779 08/29 Nobuhiro Iwamatsu [PATCH] pci: Divided pci code of the powerpc 6796 08/29 Magnus Lilja [U-Boot] [PATCH v3 0/6] i.MX31: Add NAND support and new PDK board. 6798 08/29 Magnus Lilja [U-Boot] [PATCH v3 1/6] i.MX31: Add reset_timer() and modify get_time 6797 08/29 Magnus Lilja [U-Boot] [PATCH v3 2/6] i.MX31: Make the SPI bus and chip select conf 6800 08/29 Magnus Lilja [U-Boot] [PATCH v3 3/6] i.MX31: Add basic support for Freescale's i.M 6802 08/29 Magnus Lilja [U-Boot] [PATCH v3 4/6] i.MX31: Add i.MX31 NAND Flash Controller driv 6799 08/29 Magnus Lilja [U-Boot] [PATCH v3 5/6] i.MX31: Add NAND support in the i.MX31 Liteki 6801 08/29 Magnus Lilja [U-Boot] [PATCH v3 6/6] i.MX31: Enable NAND driver for i.MX31 PDK boa 6887 08/31 Shinya Kuribayash [U-Boot] [PATCH] make: Remove redundant __ARM__ addition when cross-c 7064 09/01 Hugo Villeneuve [U-Boot] [PATCH] ARM DaVinci: Remove duplicate code in cpu/arm926ejs/ 7137 09/02 Hugo Villeneuve [U-Boot] [PATCH V2] ARM DaVinci: Remove duplicate code in cpu/arm926e 7174 09/03 Jens Scharsig Re: [U-Boot] [PATCH] at91rm9200: fix errors with CONFIG_CMD_I2C_TREE
