[PATCH 1/1] efi_selftest: use CRLF as line endings in dtbdump
EFI applications must use CR LF as line endings.
Provide a print() function to reduce code size.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/dtbdump.c | 94 +++++++++++++++++++++----------------- 1 file changed, 52 insertions(+), 42 deletions(-)
diff --git a/lib/efi_selftest/dtbdump.c b/lib/efi_selftest/dtbdump.c index cbc9067b5a..953b264d9d 100644 --- a/lib/efi_selftest/dtbdump.c +++ b/lib/efi_selftest/dtbdump.c @@ -28,6 +28,16 @@ static struct efi_system_table *systable; static const efi_guid_t efi_dt_fixup_protocol_guid = EFI_DT_FIXUP_PROTOCOL_GUID; static const efi_guid_t efi_file_info_guid = EFI_FILE_INFO_GUID;
+/** + * print() - print string + * + * @string: text + */ +static void print(u16 *string) +{ + cout->output_string(cout, string); +} + /** * error() - print error string * @@ -36,7 +46,7 @@ static const efi_guid_t efi_file_info_guid = EFI_FILE_INFO_GUID; static void error(u16 *string) { cout->set_attribute(cout, EFI_LIGHTRED | EFI_BACKGROUND_BLACK); - cout->output_string(cout, string); + print(string); cout->set_attribute(cout, EFI_LIGHTBLUE | EFI_BACKGROUND_BLACK); }
@@ -111,7 +121,7 @@ static efi_status_t efi_input(u16 *buffer, efi_uintn_t buffer_size) continue; switch (key.scan_code) { case 0x17: /* Escape */ - cout->output_string(cout, L"\nAborted\n"); + print(L"\r\nAborted\r\n"); return EFI_ABORTED; default: break; @@ -120,12 +130,12 @@ static efi_status_t efi_input(u16 *buffer, efi_uintn_t buffer_size) case 0x08: /* Backspace */ if (pos) { buffer[pos--] = 0; - cout->output_string(cout, L"\b \b"); + print(L"\b \b"); } break; case 0x0a: /* Linefeed */ case 0x0d: /* Carriage return */ - cout->output_string(cout, L"\n"); + print(L"\r\n"); return EFI_SUCCESS; default: break; @@ -138,7 +148,7 @@ static efi_status_t efi_input(u16 *buffer, efi_uintn_t buffer_size) *outbuf = key.unicode_char; buffer[pos++] = key.unicode_char; buffer[pos] = 0; - cout->output_string(cout, outbuf); + print(outbuf); } } } @@ -215,9 +225,9 @@ bool starts_with(u16 *string, u16 *keyword) */ void do_help(void) { - error(L"load <dtb> - load device-tree from file\n"); - error(L"save <dtb> - save device-tree to file\n"); - error(L"exit - exit the shell\n"); + error(L"load <dtb> - load device-tree from file\r\n"); + error(L"save <dtb> - save device-tree to file\r\n"); + error(L"exit - exit the shell\r\n"); }
/** @@ -242,7 +252,7 @@ efi_status_t do_load(u16 *filename) ret = bs->locate_protocol(&efi_dt_fixup_protocol_guid, NULL, (void **)&dt_fixup_prot); if (ret != EFI_SUCCESS) { - error(L"Device-tree fix-up protocol not found\n"); + error(L"Device-tree fix-up protocol not found\r\n"); return ret; }
@@ -252,7 +262,7 @@ efi_status_t do_load(u16 *filename) (void **)&loaded_image, NULL, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); if (ret != EFI_SUCCESS) { - error(L"Loaded image protocol not found\n"); + error(L"Loaded image protocol not found\r\n"); return ret; } /* Open the simple file system protocol */ @@ -261,57 +271,57 @@ efi_status_t do_load(u16 *filename) (void **)&file_system, NULL, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); if (ret != EFI_SUCCESS) { - error(L"Failed to open simple file system protocol\n"); + error(L"Failed to open simple file system protocol\r\n"); goto out; }
/* Open volume */ ret = file_system->open_volume(file_system, &root); if (ret != EFI_SUCCESS) { - error(L"Failed to open volume\n"); + error(L"Failed to open volume\r\n"); goto out; }
/* Open file */ ret = root->open(root, &file, filename, EFI_FILE_MODE_READ, 0); if (ret != EFI_SUCCESS) { - error(L"File not found\n"); + error(L"File not found\r\n"); goto out; } /* Get file size */ buffer_size = 0; ret = file->getinfo(file, &efi_file_info_guid, &buffer_size, NULL); if (ret != EFI_BUFFER_TOO_SMALL) { - error(L"Can't get file info size\n"); + error(L"Can't get file info size\r\n"); goto out; } ret = bs->allocate_pool(EFI_LOADER_DATA, buffer_size, (void **)&info); if (ret != EFI_SUCCESS) { - error(L"Out of memory\n"); + error(L"Out of memory\r\n"); goto out; } ret = file->getinfo(file, &efi_file_info_guid, &buffer_size, info); if (ret != EFI_SUCCESS) { - error(L"Can't get file info\n"); + error(L"Can't get file info\r\n"); goto out; } buffer_size = info->file_size; pages = efi_size_in_pages(buffer_size); ret = bs->free_pool(info); if (ret != EFI_SUCCESS) - error(L"Can't free memory pool\n"); + error(L"Can't free memory pool\r\n"); /* Read file */ ret = bs->allocate_pages(EFI_ALLOCATE_ANY_PAGES, EFI_ACPI_RECLAIM_MEMORY, pages, &addr); if (ret != EFI_SUCCESS) { - error(L"Out of memory\n"); + error(L"Out of memory\r\n"); goto out; } dtb = (struct fdt_header *)(uintptr_t)addr; ret = file->read(file, &buffer_size, dtb); if (ret != EFI_SUCCESS) { - error(L"Can't read file\n"); + error(L"Can't read file\r\n"); goto out; } /* Fixup file, expecting EFI_BUFFER_TOO_SMALL */ @@ -322,24 +332,24 @@ efi_status_t do_load(u16 *filename) /* Read file into larger buffer */ ret = bs->free_pages(addr, pages); if (ret != EFI_SUCCESS) - error(L"Can't free memory pages\n"); + error(L"Can't free memory pages\r\n"); pages = efi_size_in_pages(buffer_size); ret = bs->allocate_pages(EFI_ALLOCATE_ANY_PAGES, EFI_ACPI_RECLAIM_MEMORY, pages, &addr); if (ret != EFI_SUCCESS) { - error(L"Out of memory\n"); + error(L"Out of memory\r\n"); goto out; } dtb = (struct fdt_header *)(uintptr_t)addr; ret = file->setpos(file, 0); if (ret != EFI_SUCCESS) { - error(L"Can't position file\n"); + error(L"Can't position file\r\n"); goto out; } ret = file->read(file, &buffer_size, dtb); if (ret != EFI_SUCCESS) { - error(L"Can't read file\n"); + error(L"Can't read file\r\n"); goto out; } buffer_size = pages << EFI_PAGE_SHIFT; @@ -349,24 +359,24 @@ efi_status_t do_load(u16 *filename) EFI_DT_INSTALL_TABLE); } if (ret == EFI_SUCCESS) - cout->output_string(cout, L"device-tree installed\n"); + print(L"device-tree installed\r\n"); else - error(L"Device-tree fix-up failed\n"); + error(L"Device-tree fix-up failed\r\n"); out: if (addr) { ret2 = bs->free_pages(addr, pages); if (ret2 != EFI_SUCCESS) - error(L"Can't free memory pages\n"); + error(L"Can't free memory pages\r\n"); } if (file) { ret2 = file->close(file); if (ret2 != EFI_SUCCESS) - error(L"Can't close file\n"); + error(L"Can't close file\r\n"); } if (root) { ret2 = root->close(root); if (ret2 != EFI_SUCCESS) - error(L"Can't close volume\n"); + error(L"Can't close volume\r\n"); } return ret; } @@ -388,11 +398,11 @@ efi_status_t do_save(u16 *filename)
dtb = get_dtb(systable); if (!dtb) { - error(L"DTB not found\n"); + error(L"DTB not found\r\n"); return EFI_NOT_FOUND; } if (f2h(dtb->magic) != FDT_MAGIC) { - error(L"Wrong device tree magic\n"); + error(L"Wrong device tree magic\r\n"); return EFI_NOT_FOUND; } dtb_size = f2h(dtb->totalsize); @@ -403,7 +413,7 @@ efi_status_t do_save(u16 *filename) (void **)&loaded_image, NULL, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); if (ret != EFI_SUCCESS) { - error(L"Loaded image protocol not found\n"); + error(L"Loaded image protocol not found\r\n"); return ret; }
@@ -413,26 +423,26 @@ efi_status_t do_save(u16 *filename) (void **)&file_system, NULL, NULL, EFI_OPEN_PROTOCOL_GET_PROTOCOL); if (ret != EFI_SUCCESS) { - error(L"Failed to open simple file system protocol\n"); + error(L"Failed to open simple file system protocol\r\n"); return ret; }
/* Open volume */ ret = file_system->open_volume(file_system, &root); if (ret != EFI_SUCCESS) { - error(L"Failed to open volume\n"); + error(L"Failed to open volume\r\n"); return ret; } /* Check if file already exists */ ret = root->open(root, &file, filename, EFI_FILE_MODE_READ, 0); if (ret == EFI_SUCCESS) { file->close(file); - cout->output_string(cout, L"Overwrite existing file (y/n)? "); + print(L"Overwrite existing file (y/n)? "); ret = efi_input_yn(); - cout->output_string(cout, L"\n"); + print(L"\r\n"); if (ret != EFI_SUCCESS) { root->close(root); - error(L"Aborted by user\n"); + error(L"Aborted by user\r\n"); return ret; } } @@ -445,16 +455,16 @@ efi_status_t do_save(u16 *filename) /* Write file */ ret = file->write(file, &dtb_size, dtb); if (ret != EFI_SUCCESS) - error(L"Failed to write file\n"); + error(L"Failed to write file\r\n"); file->close(file); } else { - error(L"Failed to open file\n"); + error(L"Failed to open file\r\n"); } root->close(root);
if (ret == EFI_SUCCESS) { - cout->output_string(cout, filename); - cout->output_string(cout, L" written\n"); + print(filename); + print(L" written\r\n"); }
return ret; @@ -480,7 +490,7 @@ efi_status_t EFIAPI efi_main(efi_handle_t image_handle, cout->set_attribute(cout, EFI_LIGHTBLUE | EFI_BACKGROUND_BLACK); cout->clear_screen(cout); cout->set_attribute(cout, EFI_WHITE | EFI_BACKGROUND_BLACK); - cout->output_string(cout, L"DTB Dump\n========\n\n"); + print(L"DTB Dump\r\n========\r\n\r\n"); cout->set_attribute(cout, EFI_LIGHTBLUE | EFI_BACKGROUND_BLACK);
for (;;) { @@ -488,7 +498,7 @@ efi_status_t EFIAPI efi_main(efi_handle_t image_handle, u16 *pos; efi_uintn_t ret;
- cout->output_string(cout, L"=> "); + print(L"=> "); ret = efi_input(command, sizeof(command)); if (ret == EFI_ABORTED) break; -- 2.29.2
