[PATCH V4 00/12] AM68: Add support for AM68 Starter Kit
Hi All, This series of patch add initial support for AM68 starter kit. Design files can be referrred from https://www.ti.com/lit/zip/SPRR463
Refer below link to J721S2/AM68 Technical Reference Manual for further details: http://www.ti.com/lit/pdf/spruj28
Link to kerenl patches: https://lore.kernel.org/linux-arm-kernel/20221115154832.19759-4-sinthu.raja@...
Changes in V4: ============= Address review comments: - In align wih the macro conditional statement which missed it in the previous version
Changes in V3: ============= Address review comments: - Rework on DTB selection API clarity about mini-U-Boot vs EVM and family support as suggested. * board: ti: j721s2: Add board_init and support for selecting DT based on EEPROM
Changes in V2: ============= Address review comments: - Remove support for detecting multiple device trees using different DTB - Remove board specific API from K3 generic file (arch/arm/mach-k3/j721s2_init.c) and moved to board specific file (board/ti/j721s2/evm.c). * arch: mach-k3: Update board specific API name to K3 generic API name * board: ti: j721s2: Add board_init and support for selecting DT based on EEPROM - Move board_is_xxx within CONFIG_TI_I2C_BOARD_DETECT block to maintain the "mini" U-Boot concept for this SoC.
V1: https://patchwork.ozlabs.org/project/uboot/cover/20221027104846.11820-1-sint... V2: https://patchwork.ozlabs.org/project/uboot/cover/20221221135219.24702-1-sint... v3: https://patchwork.ozlabs.org/project/uboot/cover/20221227121543.22306-1-sint...
Sinthu Raja (12): configs: j721s2_evm_r5: Enable support for building multiple dtbs into FIT configs: j721s2_evm_a72: Enable support for building multiple dtbs into FIT configs: j721s2_evm: Enable configs to store env in MMC FAT partition board: ti: j721s2: Add support to update board_name for am68-sk board: ti: j721s2: Enable support for reading EEPROM at next alternate address board: ti: j721s2: Add support for detecting multiple device trees arch: mach-k3: Update board specific API name to K3 generic API name board: ti: j721s2: Add board_init and support for selecting DT based on EEPROM arm: dts: Add initial support for AM68 Starter Kit System on Module arm: dts: Add support for A72 specific AM68 Starter Kit Base Board arm: dts: k3-am68-sk: Add r5 specific dt support include: configs: Update env for selecting right dtb
arch/arm/dts/Makefile | 4 +- .../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 150 ++++++++ arch/arm/dts/k3-am68-sk-base-board.dts | 353 ++++++++++++++++++ arch/arm/dts/k3-am68-sk-r5-base-board.dts | 194 ++++++++++ arch/arm/dts/k3-am68-sk-som.dtsi | 127 +++++++ arch/arm/mach-k3/include/mach/sys_proto.h | 3 + arch/arm/mach-k3/j721s2_init.c | 13 +- board/ti/j721s2/evm.c | 118 +++++- configs/j721s2_evm_a72_defconfig | 4 +- configs/j721s2_evm_r5_defconfig | 4 + include/configs/j721s2_evm.h | 4 + 11 files changed, 956 insertions(+), 18 deletions(-) create mode 100644 arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am68-sk-base-board.dts create mode 100644 arch/arm/dts/k3-am68-sk-r5-base-board.dts create mode 100644 arch/arm/dts/k3-am68-sk-som.dtsi
Enable configs for building multiple dtbs into a single fit image and load the right dtb for next stage. This will help to use same defconfig for both EVM and SK.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- configs/j721s2_evm_r5_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 2de5d87bdb..7418dc2900 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -84,6 +84,9 @@ CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_SPL_OF_LIST="k3-j721s2-r5-common-proc-board k3-am68-sk-r5-base-board" +CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y
Enable configs for building multiple dtbs into a single fit image and load the right dtb for next stage. Add k3-am68-sk-base-board dtb along with evm dtb inside DTB FIT image. This helps to use same defconfig for both EVM and SK
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- configs/j721s2_evm_a72_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 2b2f80c4aa..75b4e52238 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -89,6 +89,7 @@ CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_MULTI_DTB_FIT=y +CONFIG_OF_LIST="k3-j721s2-common-proc-board k3-am68-sk-base-board" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y
J721S2 EVM used to store env on eMMC, since EVM and SK uses same defconfig and there is no eMMC on SK, we need to keep env in an interface which available on both EVM and SK. So, save env in FAT partition of MMC SD Card.
Enable defconfigs relevant for storing env on FAT partition of MMC.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- configs/j721s2_evm_a72_defconfig | 3 ++- configs/j721s2_evm_r5_defconfig | 1 + 2 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/j721s2_evm_a72_defconfig b/configs/j721s2_evm_a72_defconfig index 75b4e52238..1db5b47a24 100644 --- a/configs/j721s2_evm_a72_defconfig +++ b/configs/j721s2_evm_a72_defconfig @@ -92,7 +92,8 @@ CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_OF_LIST="k3-j721s2-common-proc-board k3-am68-sk-base-board" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y +CONFIG_ENV_IS_IN_FAT=y +CONFIG_ENV_FAT_DEVICE_AND_PART="1:1" CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/j721s2_evm_r5_defconfig b/configs/j721s2_evm_r5_defconfig index 7418dc2900..f7805e83e0 100644 --- a/configs/j721s2_evm_r5_defconfig +++ b/configs/j721s2_evm_r5_defconfig @@ -88,6 +88,7 @@ CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_OF_LIST="k3-j721s2-r5-common-proc-board k3-am68-sk-r5-base-board" CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ENV_OVERWRITE=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_REGMAP=y
Update setup_board_eeprom_env() to choose the right board name for am68-sk.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- board/ti/j721s2/evm.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index e09adc8ad3..f223ccf2c6 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -26,8 +26,6 @@
#include "../common/board_detect.h"
-#define board_is_j721s2_som() board_ti_k3_is("J721S2X-PM1-SOM") - DECLARE_GLOBAL_DATA_PTR;
int board_init(void) @@ -101,6 +99,14 @@ int ft_board_setup(void *blob, struct bd_info *bd) #endif
#ifdef CONFIG_TI_I2C_BOARD_DETECT +/* + * Functions specific to EVM and SK designs of J721S2/AM68 family. + */ + +#define board_is_j721s2_som() board_ti_k3_is("J721S2X-PM1-SOM") + +#define board_is_am68_sk_som() board_ti_k3_is("AM68-SK-SOM") + int do_board_detect(void) { int ret; @@ -136,6 +142,8 @@ static void setup_board_eeprom_env(void)
if (board_is_j721s2_som()) name = "j721s2"; + else if (board_is_am68_sk_som()) + name = "am68-sk"; else printf("Unidentified board claims %s in eeprom header\n", board_ti_get_name());
J721S2 EVM has EEPROM populated at 0x50. AM68 SK has EEPROM populated at next address 0x51 in order to be compatible with RPi. So start looking for TI specific EEPROM at 0x50, if not found look for EEPROM at 0x51.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- board/ti/j721s2/evm.c | 12 +++++++++--- 1 file changed, 9 insertions(+), 3 deletions(-)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index f223ccf2c6..a3adb8704e 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -113,9 +113,15 @@ int do_board_detect(void)
ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS); - if (ret) - pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", - CONFIG_EEPROM_CHIP_ADDRESS, ret); + if (ret) { + printf("EEPROM not available at 0x%02x, trying to read at 0x%02x\n", + CONFIG_EEPROM_CHIP_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS + 1); + ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, + CONFIG_EEPROM_CHIP_ADDRESS + 1); + if (ret) + pr_err("Reading on-board EEPROM at 0x%02x failed %d\n", + CONFIG_EEPROM_CHIP_ADDRESS + 1, ret); + }
return ret; }
Update the board_fit_config_name_match() to choose the right dtb based on the board name read from EEPROM.
Also restrict multpile EEPROM reads by verifying if EEPROM is already read
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- board/ti/j721s2/evm.c | 30 ++++++++++++++++++++---------- 1 file changed, 20 insertions(+), 10 deletions(-)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index a3adb8704e..a7c4082a7a 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -72,16 +72,6 @@ int dram_init_banksize(void) return 0; }
-#ifdef CONFIG_SPL_LOAD_FIT -int board_fit_config_name_match(const char *name) -{ - if (!strcmp(name, "k3-j721s2-common-proc-board")) - return 0; - - return -1; -} -#endif - #if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) int ft_board_setup(void *blob, struct bd_info *bd) { @@ -111,6 +101,9 @@ int do_board_detect(void) { int ret;
+ if (board_ti_was_eeprom_read()) + return 0; + ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS); if (ret) { @@ -179,6 +172,23 @@ static void setup_serial(void) } #endif
+#ifdef CONFIG_SPL_LOAD_FIT +int board_fit_config_name_match(const char *name) +{ + bool eeprom_read = board_ti_was_eeprom_read(); + + if (!eeprom_read || board_is_j721s2_som()) { + if (!strcmp(name, "k3-j721s2-common-proc-board")) + return 0; + } else if (!eeprom_read || board_is_am68_sk_som()) { + if (!strcmp(name, "k3-am68-sk-base-board")) + return 0; + } + + return -1; +} +#endif + int board_late_init(void) { if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) {
Hi Sinthu
- return -1;
-} -#endif
Any reason why the modifications to board_fit_config_name_match was not made here itself and instead shifted, would make patch more readable.
- if (board_ti_was_eeprom_read())
- ret = ti_i2c_eeprom_am6_get_base(CONFIG_EEPROM_BUS_ADDRESS, CONFIG_EEPROM_CHIP_ADDRESS); if (ret) {
- bool eeprom_read = board_ti_was_eeprom_read();
- if (!eeprom_read || board_is_j721s2_som()) {
- } else if (!eeprom_read || board_is_am68_sk_som()) {
This second eeprom_read check is unnecessary.
- return -1;
+} +#endif
- int board_late_init(void) { if (IS_ENABLED(CONFIG_TI_I2C_BOARD_DETECT)) {
Neha,
On Wed, Jan 4, 2023 at 5:37 PM Neha Malcom Francis n-francis@ti.com wrote:
Hi Sinthu
return -1;
-} -#endif
If you please check patch number 4, we are bringing the Macro board_is_xxxx under CONFIG_TI_I2C_BOARD_DETECT macro to make it as functions specific to EVM and SK designs of J721S2/AM68 family. This modification is suggested by Tom earlier. As we moved board_is_xxxx we have to move board_fit_config_name_match() API also. Without this change we will get an implicit declaration error.
This is to check what board is loaded and to identify if the corresponding DTB file is present in the image. If not this will work only for EVM and not SK.
return -1;
+} +#endif
-- Thanking You Neha Malcom Francis
On Wed, Jan 04, 2023 at 03:13:44PM +0530, Sinthu Raja wrote:
[snip]
What I'd like to see is a comment above this part noting that this is the safe default for the SoC.
Although the board_init_f API initialises the SoC, the API name is incorrectly specified and misleads the functionality. This file should only include k3-specific functionality. Change the API's name to something more K3-specific and separate the function to make it more modular.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- arch/arm/mach-k3/include/mach/sys_proto.h | 3 +++ arch/arm/mach-k3/j721s2_init.c | 13 ++++++++++++- 2 files changed, 15 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-k3/include/mach/sys_proto.h b/arch/arm/mach-k3/include/mach/sys_proto.h index 60287b261c..3d3d90d02d 100644 --- a/arch/arm/mach-k3/include/mach/sys_proto.h +++ b/arch/arm/mach-k3/include/mach/sys_proto.h @@ -19,4 +19,7 @@ int fdt_disable_node(void *blob, char *node_path); bool soc_is_j721e(void); bool soc_is_j7200(void);
+void k3_spl_init(void); +void k3_mem_init(void); +bool check_rom_loaded_sysfw(void); #endif diff --git a/arch/arm/mach-k3/j721s2_init.c b/arch/arm/mach-k3/j721s2_init.c index 0206b01d9e..09e55ed456 100644 --- a/arch/arm/mach-k3/j721s2_init.c +++ b/arch/arm/mach-k3/j721s2_init.c @@ -93,7 +93,7 @@ static void store_boot_info_from_rom(void) sizeof(struct rom_extended_boot_data)); }
-void board_init_f(ulong dummy) +void k3_spl_init(void) { struct udevice *dev; int ret; @@ -154,6 +154,17 @@ void board_init_f(ulong dummy)
/* Output System Firmware version info */ k3_sysfw_print_ver(); +} + +bool check_rom_loaded_sysfw(void) +{ + return is_rom_loaded_sysfw(&bootdata); +} + +void k3_mem_init(void) +{ + struct udevice *dev; + int ret;
if (IS_ENABLED(CONFIG_TARGET_J721S2_R5_EVM)) { ret = uclass_get_device_by_name(UCLASS_MISC, "msmc", &dev);
Add the board_init_f API for SPL and run the platform-required SoC initialization.
Add the functionality for board name-based DTB selection from FIT within SPL. This will make it easier to utilise one defconfig for both the EVM and the SK.
V3: https://patchwork.ozlabs.org/project/uboot/patch/20221227121543.22306-9-sint...
board/ti/j721s2/evm.c | 64 +++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 64 insertions(+)
diff --git a/board/ti/j721s2/evm.c b/board/ti/j721s2/evm.c index a7c4082a7a..941b4bd8ae 100644 --- a/board/ti/j721s2/evm.c +++ b/board/ti/j721s2/evm.c @@ -23,6 +23,7 @@ #include <asm/arch/sys_proto.h> #include <dm.h> #include <dm/uclass-internal.h> +#include <dm/root.h>
@@ -202,3 +203,66 @@ int board_late_init(void) void spl_board_init(void) { } + +/* Support for the various EVM / SK families */ +#if defined(CONFIG_SPL_OF_LIST) && defined(CONFIG_TI_I2C_BOARD_DETECT) +void do_dt_magic(void) +{ + int ret, rescan, mmc_dev = -1; + static struct mmc *mmc; + + do_board_detect(); + + /* + * Board detection has been done. + * Let us see if another dtb wouldn't be a better match + * for our board + */ + if (IS_ENABLED(CONFIG_CPU_V7R)) { + ret = fdtdec_resetup(&rescan); + if (!ret && rescan) { + dm_uninit(); + dm_init_and_scan(true); + } + } + + /* + * Because of multi DTB configuration, the MMC device has + * to be re-initialized after reconfiguring FDT inorder to + * boot from MMC. Do this when boot mode is MMC and ROM has + * not loaded SYSFW. + */ + switch (spl_boot_device()) { + case BOOT_DEVICE_MMC1: + mmc_dev = 0; + break; + case BOOT_DEVICE_MMC2: + case BOOT_DEVICE_MMC2_2: + mmc_dev = 1; + break; + } + + if (mmc_dev > 0 && !check_rom_loaded_sysfw()) { + ret = mmc_init_device(mmc_dev); + if (!ret) { + mmc = find_mmc_device(mmc_dev); + if (mmc) { + ret = mmc_init(mmc); + if (ret) + printf("mmc init failed with error: %d\n", ret); + } + } + } +} +#endif + +#ifdef CONFIG_SPL_BUILD +void board_init_f(ulong dummy) +{ + k3_spl_init(); +#if defined(CONFIG_SPL_OF_LIST) && defined(CONFIG_TI_I2C_BOARD_DETECT) + do_dt_magic(); +#endif + k3_mem_init(); +} +#endif
AM68 Starter Kit (SK) is a low cost, small form factor board designed for TI’s AM68 SoC. TI’s AM68 SoC comprises of dual core A72, high performance vision accelerators, hardware accelerators, latest C71x DSP, high bandwidth real-time IPs for capture and display. The SoC is power optimized to provide best in class performance for industrial applications.
AM68 SK supports the following interfaces: * 16 GB LPDDR4 RAM * x1 Gigabit Ethernet interface * x1 USB 3.1 Type-C port * x2 USB 3.1 Type-A ports * x1 PCIe M.2 M Key * 512 Mbit OSPI flash * x2 CSI2 Camera interface (RPi and TI Camera connector) * 40-pin Raspberry Pi GPIO header
SK's System on Module (SoM) contains the SoC, PMIC, DDR and OSPI flash. Therefore, add support for the components present on the SoM.
Schematics: https://www.ti.com/lit/zip/SPRR463 TRM: http://www.ti.com/lit/pdf/spruj28
Hi All, The Kernel DTSI is under review and waiting to get merged. Kernel Link: https://lore.kernel.org/linux-arm-kernel/20221115154832.19759-4-sinthu.raja@...
arch/arm/dts/k3-am68-sk-som.dtsi | 127 +++++++++++++++++++++++++++++++ 1 file changed, 127 insertions(+) create mode 100644 arch/arm/dts/k3-am68-sk-som.dtsi
diff --git a/arch/arm/dts/k3-am68-sk-som.dtsi b/arch/arm/dts/k3-am68-sk-som.dtsi new file mode 100644 index 0000000000..cb1c58fcd1 --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-som.dtsi @@ -0,0 +1,127 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-j721s2.dtsi" +#include <dt-bindings/gpio/gpio.h> + +/ { + memory@80000000 { + device_type = "memory"; + /* 16 GB RAM */ + reg = <0x00 0x80000000 0x00 0x80000000>, + <0x08 0x80000000 0x03 0x80000000>; + }; + + /* Reserving memory regions still pending */ + reserved_memory: reserved-memory { + #address-cells = <2>; + #size-cells = <2>; + ranges; + + secure_ddr: optee@9e800000 { + reg = <0x00 0x9e800000 0x00 0x01800000>; + alignment = <0x1000>; + no-map; + }; + }; +}; + +&mailbox0_cluster0 { + status = "disabled"; +}; + +&mailbox0_cluster1 { + status = "disabled"; +}; + +&mailbox0_cluster2 { + status = "disabled"; +}; + +&mailbox0_cluster3 { + status = "disabled"; +}; + +&mailbox0_cluster4 { + status = "disabled"; +}; + +&mailbox0_cluster5 { + status = "disabled"; +}; + +&mailbox0_cluster6 { + status = "disabled"; +}; + +&mailbox0_cluster7 { + status = "disabled"; +}; + +&mailbox0_cluster8 { + status = "disabled"; +}; + +&mailbox0_cluster9 { + status = "disabled"; +}; + +&mailbox0_cluster10 { + status = "disabled"; +}; + +&mailbox0_cluster11 { + status = "disabled"; +}; + +&mailbox1_cluster0 { + status = "disabled"; +}; + +&mailbox1_cluster1 { + status = "disabled"; +}; + +&mailbox1_cluster2 { + status = "disabled"; +}; + +&mailbox1_cluster3 { + status = "disabled"; +}; + +&mailbox1_cluster4 { + status = "disabled"; +}; + +&mailbox1_cluster5 { + status = "disabled"; +}; + +&mailbox1_cluster6 { + status = "disabled"; +}; + +&mailbox1_cluster7 { + status = "disabled"; +}; + +&mailbox1_cluster8 { + status = "disabled"; +}; + +&mailbox1_cluster9 { + status = "disabled"; +}; + +&mailbox1_cluster10 { + status = "disabled"; +}; + +&mailbox1_cluster11 { + status = "disabled"; +};
The SK architecture comprises of baseboard and a SOM board. The AM68 Starter Kit's baseboard contains most of the actual connectors, power supply etc. The System on Module (SoM) is plugged on to the base board. Therefore, add support for peripherals brought out in the base board.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- arch/arm/dts/Makefile | 3 +- .../arm/dts/k3-am68-sk-base-board-u-boot.dtsi | 150 ++++++++ arch/arm/dts/k3-am68-sk-base-board.dts | 353 ++++++++++++++++++ 3 files changed, 505 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi create mode 100644 arch/arm/dts/k3-am68-sk-base-board.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 43951a7731..6d49baaaa7 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1249,7 +1249,8 @@ dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j7200-r5-common-proc-board.dtb \ k3-j721e-sk.dtb \ k3-j721e-r5-sk.dtb -dtb-$(CONFIG_SOC_K3_J721S2) += k3-j721s2-common-proc-board.dtb\ +dtb-$(CONFIG_SOC_K3_J721S2) += k3-am68-sk-base-board.dtb\ + k3-j721s2-common-proc-board.dtb\ k3-j721s2-r5-common-proc-board.dtb dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ k3-am642-r5-evm.dtb \ diff --git a/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi new file mode 100644 index 0000000000..12faaae59b --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-base-board-u-boot.dtsi @@ -0,0 +1,150 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/ { + chosen { + stdout-path = "serial2:115200n8"; + tick-timer = &timer1; + }; + + aliases { + serial0 = &wkup_uart0; + serial1 = &mcu_uart0; + serial2 = &main_uart8; + i2c0 = &wkup_i2c0; + i2c1 = &mcu_i2c0; + i2c2 = &mcu_i2c1; + i2c3 = &main_i2c0; + ethernet0 = &cpsw_port1; + mmc1 = &main_sdhci1; + }; +}; + +&wkup_i2c0 { + u-boot,dm-spl; +}; + +&cbass_main { + u-boot,dm-spl; +}; + +&main_navss { + u-boot,dm-spl; +}; + +&cbass_mcu_wakeup { + u-boot,dm-spl; + + timer1: timer@40400000 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x40400000 0x0 0x80>; + ti,timer-alwon; + clock-frequency = <250000000>; + u-boot,dm-spl; + }; + + chipid@43000014 { + u-boot,dm-spl; + }; +}; + +&mcu_navss { + u-boot,dm-spl; +}; + +&mcu_ringacc { + reg = <0x0 0x2b800000 0x0 0x400000>, + <0x0 0x2b000000 0x0 0x400000>, + <0x0 0x28590000 0x0 0x100>, + <0x0 0x2a500000 0x0 0x40000>, + <0x0 0x28440000 0x0 0x40000>; + reg-names = "rt", "fifos", "proxy_gcfg", "proxy_target", "cfg"; + u-boot,dm-spl; +}; + +&mcu_udmap { + reg = <0x0 0x285c0000 0x0 0x100>, + <0x0 0x284c0000 0x0 0x4000>, + <0x0 0x2a800000 0x0 0x40000>, + <0x0 0x284a0000 0x0 0x4000>, + <0x0 0x2aa00000 0x0 0x40000>, + <0x0 0x28400000 0x0 0x2000>; + reg-names = "gcfg", "rchan", "rchanrt", "tchan", + "tchanrt", "rflow"; + u-boot,dm-spl; +}; + +&secure_proxy_main { + u-boot,dm-spl; +}; + +&sms { + u-boot,dm-spl; + k3_sysreset: sysreset-controller { + compatible = "ti,sci-sysreset"; + u-boot,dm-spl; + }; +}; + +&main_pmx0 { + u-boot,dm-spl; +}; + +&main_uart8_pins_default { + u-boot,dm-spl; +}; + +&main_mmc1_pins_default { + u-boot,dm-spl; +}; + +&wkup_pmx0 { + u-boot,dm-spl; +}; + +&k3_pds { + u-boot,dm-spl; +}; + +&k3_clks { + u-boot,dm-spl; +}; + +&k3_reset { + u-boot,dm-spl; +}; + +&main_uart8 { + u-boot,dm-spl; +}; + +&mcu_uart0 { + u-boot,dm-spl; +}; + +&wkup_uart0 { + u-boot,dm-spl; +}; + +&mcu_cpsw { + reg = <0x0 0x46000000 0x0 0x200000>, + <0x0 0x40f00200 0x0 0x8>; + reg-names = "cpsw_nuss", "mac_efuse"; + /delete-property/ ranges; + + cpsw-phy-sel@40f04040 { + compatible = "ti,am654-cpsw-phy-sel"; + reg= <0x0 0x40f04040 0x0 0x4>; + reg-names = "gmii-sel"; + }; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/k3-am68-sk-base-board.dts b/arch/arm/dts/k3-am68-sk-base-board.dts new file mode 100644 index 0000000000..8fc03324ab --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-base-board.dts @@ -0,0 +1,353 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + * + * Base Board: **Yet to Add** + */ + +/dts-v1/; + +#include "k3-am68-sk-som.dtsi" +#include <dt-bindings/net/ti-dp83867.h> +#include <dt-bindings/phy/phy-cadence.h> +#include <dt-bindings/phy/phy.h> + +/ { + compatible = "ti,am68-sk", "ti,j721s2"; + model = "Texas Instruments AM68 SK"; + + chosen { + stdout-path = "serial2:115200n8"; + bootargs = "console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x2880000"; + }; + + aliases { + serial2 = &main_uart8; + mmc1 = &main_sdhci1; + }; + + vusb_main: fixedregulator-vusb-main5v0 { + /* USB MAIN INPUT 5V DC */ + compatible = "regulator-fixed"; + regulator-name = "vusb-main5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + vsys_3v3: fixedregulator-vsys3v3 { + /* Output of LM5141 */ + compatible = "regulator-fixed"; + regulator-name = "vsys_3v3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vusb_main>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_mmc1: fixedregulator-sd { + /* Output of TPS22918 */ + compatible = "regulator-fixed"; + regulator-name = "vdd_mmc1"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + enable-active-high; + vin-supply = <&vsys_3v3>; + gpio = <&exp1 10 GPIO_ACTIVE_HIGH>; + }; + + vdd_sd_dv: gpio-regulator-TLV71033 { + /* Output of TLV71033 */ + compatible = "regulator-gpio"; + regulator-name = "tlv71033"; + pinctrl-names = "default"; + pinctrl-0 = <&vdd_sd_dv_pins_default>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-boot-on; + vin-supply = <&vsys_3v3>; + gpios = <&main_gpio0 49 GPIO_ACTIVE_HIGH>; + states = <1800000 0x0>, + <3300000 0x1>; + }; +}; + +&main_pmx0 { + main_uart8_pins_default: main-uart8-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x040, PIN_INPUT, 14) /* (AC28) MCASP0_AXR0.UART8_CTSn */ + J721S2_IOPAD(0x044, PIN_OUTPUT, 14) /* (Y26) MCASP0_AXR1.UART8_RTSn */ + J721S2_IOPAD(0x0d0, PIN_INPUT, 11) /* (AF26) SPI0_CS1.UART8_RXD */ + J721S2_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AH27) SPI0_CLK.UART8_TXD */ + >; + }; + + main_i2c0_pins_default: i2c0-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0e0, PIN_INPUT_PULLUP, 0) /* (AH25) I2C0_SCL */ + J721S2_IOPAD(0x0e4, PIN_INPUT_PULLUP, 0) /* (AE24) I2C0_SDA */ + >; + }; + + main_mmc1_pins_default: main-mmc1-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ + J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ + J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */ + J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */ + J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ + J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */ + J721S2_IOPAD(0x0f0, PIN_INPUT, 0) /* (R22) MMC1_DAT3 */ + J721S2_IOPAD(0x0e8, PIN_INPUT, 8) /* (AE25) TIMER_IO0.MMC1_SDCD */ + >; + }; + + vdd_sd_dv_pins_default: vdd-sd-dv-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0c4, PIN_INPUT, 7) /* (AB26) ECAP0_IN_APWM_OUT.GPIO0_49 */ + >; + }; +}; + +&wkup_pmx0 { + mcu_cpsw_pins_default: mcu-cpsw-pins-default { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x094, PIN_INPUT, 0) /* (B22) MCU_RGMII1_RD0 */ + J721S2_WKUP_IOPAD(0x090, PIN_INPUT, 0) /* (B21) MCU_RGMII1_RD1 */ + J721S2_WKUP_IOPAD(0x08c, PIN_INPUT, 0) /* (C22) MCU_RGMII1_RD2 */ + J721S2_WKUP_IOPAD(0x088, PIN_INPUT, 0) /* (D23) MCU_RGMII1_RD3 */ + J721S2_WKUP_IOPAD(0x084, PIN_INPUT, 0) /* (D22) MCU_RGMII1_RXC */ + J721S2_WKUP_IOPAD(0x06c, PIN_INPUT, 0) /* (E23) MCU_RGMII1_RX_CTL */ + J721S2_WKUP_IOPAD(0x07c, PIN_OUTPUT, 0) /* (F23) MCU_RGMII1_TD0 */ + J721S2_WKUP_IOPAD(0x078, PIN_OUTPUT, 0) /* (G22) MCU_RGMII1_TD1 */ + J721S2_WKUP_IOPAD(0x074, PIN_OUTPUT, 0) /* (E21) MCU_RGMII1_TD2 */ + J721S2_WKUP_IOPAD(0x070, PIN_OUTPUT, 0) /* (E22) MCU_RGMII1_TD3 */ + J721S2_WKUP_IOPAD(0x080, PIN_OUTPUT, 0) /* (F21) MCU_RGMII1_TXC */ + J721S2_WKUP_IOPAD(0x068, PIN_OUTPUT, 0) /* (F22) MCU_RGMII1_TX_CTL */ + >; + }; + + mcu_mdio_pins_default: mcu-mdio-pins-default { + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x09c, PIN_OUTPUT, 0) /* (A21) MCU_MDIO0_MDC */ + J721S2_WKUP_IOPAD(0x098, PIN_INPUT, 0) /* (A22) MCU_MDIO0_MDIO */ + >; + }; +}; + +&main_gpio2 { + status = "disabled"; +}; + +&main_gpio4 { + status = "disabled"; +}; + +&main_gpio6 { + status = "disabled"; +}; + +&wkup_gpio1 { + status = "disabled"; +}; + +&wkup_uart0 { + status = "reserved"; +}; + +&main_uart0 { + status = "disabled"; +}; + +&main_uart1 { + status = "disabled"; +}; + +&main_uart2 { + status = "disabled"; +}; + +&main_uart3 { + status = "disabled"; +}; + +&main_uart4 { + status = "disabled"; +}; + +&main_uart5 { + status = "disabled"; +}; + +&main_uart6 { + status = "disabled"; +}; + +&main_uart7 { + status = "disabled"; +}; + +&main_uart8 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart8_pins_default>; + /* Shared with TFA on this platform */ + power-domains = <&k3_pds 357 TI_SCI_PD_SHARED>; +}; + +&main_uart9 { + status = "disabled"; +}; + +&main_i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&main_i2c0_pins_default>; + clock-frequency = <400000>; + + exp1: gpio@21 { + compatible = "ti,tca6416"; + reg = <0x21>; + gpio-controller; + #gpio-cells = <2>; + gpio-line-names = "CSI_VIO_SEL", "CSI_SEL_FPC_EXPN", "HDMI_PDN", + "HDMI_LS_OE", "DP0_3V3_EN", "BOARDID_EEPROM_WP", + "CAN_STB", "","GPIO_uSD_PWR_EN", "EDP_ENABLE", + "IO_EXP_PCIE1_M2_RSTZ", "IO_EXP_MCU_RGMII_RSTZ", + "IO_EXP_CSI1_EXP_RSTZ", "","CSI0_B_GPIO1", + "CSI1_B_GPIO1"; + }; +}; + +&main_i2c1 { + status = "disabled"; +}; + +&main_i2c2 { + status = "disabled"; +}; + +&main_i2c3 { + status = "disabled"; +}; + +&main_i2c4 { + status = "disabled"; +}; + +&main_i2c5 { + status = "disabled"; +}; + +&main_i2c6 { + status = "disabled"; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + /* SD card */ + pinctrl-0 = <&main_mmc1_pins_default>; + pinctrl-names = "default"; + disable-wp; + vmmc-supply = <&vdd_mmc1>; + vqmmc-supply = <&vdd_sd_dv>; +}; + +&mcu_cpsw { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_cpsw_pins_default &mcu_mdio_pins_default>; +}; + +&davinci_mdio { + phy0: ethernet-phy@0 { + reg = <0>; + ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; + ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; + ti,min-output-impedance; + }; +}; + +&cpsw_port1 { + phy-mode = "rgmii-rxid"; + phy-handle = <&phy0>; +}; + +&mcu_mcan0 { + status = "disabled"; +}; + +&mcu_mcan1 { + status = "disabled"; +}; + +&main_mcan0 { + status = "disabled"; +}; + +&main_mcan1 { + status = "disabled"; +}; + +&main_mcan2 { + status = "disabled"; +}; + +&main_mcan3 { + status = "disabled"; +}; + +&main_mcan4 { + status = "disabled"; +}; + +&main_mcan5 { + status = "disabled"; +}; + +&main_mcan6 { + status = "disabled"; +}; + +&main_mcan7 { + status = "disabled"; +}; + +&main_mcan8 { + status = "disabled"; +}; + +&main_mcan9 { + status = "disabled"; +}; + +&main_mcan10 { + status = "disabled"; +}; + +&main_mcan11 { + status = "disabled"; +}; + +&main_mcan12 { + status = "disabled"; +}; + +&main_mcan13 { + status = "disabled"; +}; + +&main_mcan14 { + status = "disabled"; +}; + +&main_mcan15 { + status = "disabled"; +}; + +&main_mcan17 { + status = "disabled"; +};
Add initial support for AM68 SK device tree that runs on R5.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/k3-am68-sk-r5-base-board.dts | 194 ++++++++++++++++++++++ 2 files changed, 195 insertions(+) create mode 100644 arch/arm/dts/k3-am68-sk-r5-base-board.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6d49baaaa7..be6e7b4e79 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1250,6 +1250,7 @@ dtb-$(CONFIG_SOC_K3_J721E) += k3-j721e-common-proc-board.dtb \ k3-j721e-sk.dtb \ k3-j721e-r5-sk.dtb dtb-$(CONFIG_SOC_K3_J721S2) += k3-am68-sk-base-board.dtb\ + k3-am68-sk-r5-base-board.dtb\ k3-j721s2-common-proc-board.dtb\ k3-j721s2-r5-common-proc-board.dtb dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-evm.dtb \ diff --git a/arch/arm/dts/k3-am68-sk-r5-base-board.dts b/arch/arm/dts/k3-am68-sk-r5-base-board.dts new file mode 100644 index 0000000000..46ee6c4422 --- /dev/null +++ b/arch/arm/dts/k3-am68-sk-r5-base-board.dts @@ -0,0 +1,194 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2022 Texas Instruments Incorporated - https://www.ti.com/ + */ + +/dts-v1/; + +#include "k3-am68-sk-som.dtsi" +#include "k3-j721s2-ddr-evm-lp4-4266.dtsi" +#include "k3-j721s2-ddr.dtsi" + +/ { + chosen { + firmware-loader = &fs_loader0; + stdout-path = &main_uart8; + tick-timer = &timer1; + }; + + aliases { + remoteproc0 = &sysctrler; + remoteproc1 = &a72_0; + }; + + fs_loader0: fs_loader@0 { + compatible = "u-boot,fs-loader"; + u-boot,dm-pre-reloc; + }; + + a72_0: a72@0 { + compatible = "ti,am654-rproc"; + reg = <0x0 0x00a90000 0x0 0x10>; + power-domains = <&k3_pds 61 TI_SCI_PD_EXCLUSIVE>, + <&k3_pds 202 TI_SCI_PD_EXCLUSIVE>; + resets = <&k3_reset 202 0>; + clocks = <&k3_clks 61 1>; + assigned-clocks = <&k3_clks 61 1>, <&k3_clks 202 0>; + assigned-clock-parents = <&k3_clks 61 2>; + assigned-clock-rates = <200000000>, <2000000000>; + ti,sci = <&sms>; + ti,sci-proc-id = <32>; + ti,sci-host-id = <10>; + u-boot,dm-spl; + }; + + clk_200mhz: dummy_clock_200mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <200000000>; + u-boot,dm-spl; + }; + + clk_19_2mhz: dummy_clock_19_2mhz { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <19200000>; + u-boot,dm-spl; + }; +}; + +&cbass_mcu_wakeup { + sa3_secproxy: secproxy@44880000 { + u-boot,dm-spl; + compatible = "ti,am654-secure-proxy"; + reg = <0x0 0x44880000 0x0 0x20000>, + <0x0 0x44860000 0x0 0x20000>, + <0x0 0x43600000 0x0 0x10000>; + reg-names = "rt", "scfg", "target_data"; + #mbox-cells = <1>; + }; + + mcu_secproxy: secproxy@2a380000 { + compatible = "ti,am654-secure-proxy"; + reg = <0x0 0x2a380000 0x0 0x80000>, + <0x0 0x2a400000 0x0 0x80000>, + <0x0 0x2a480000 0x0 0x80000>; + reg-names = "rt", "scfg", "target_data"; + #mbox-cells = <1>; + u-boot,dm-spl; + }; + + sysctrler: sysctrler { + compatible = "ti,am654-system-controller"; + mboxes= <&mcu_secproxy 4>, <&mcu_secproxy 5>, <&sa3_secproxy 5>; + mbox-names = "tx", "rx", "boot_notify"; + u-boot,dm-spl; + }; + + dm_tifs: dm-tifs { + compatible = "ti,j721e-dm-sci"; + ti,host-id = <3>; + ti,secure-host; + mbox-names = "rx", "tx"; + mboxes= <&mcu_secproxy 21>, + <&mcu_secproxy 23>; + u-boot,dm-spl; + }; +}; + +&main_pmx0 { + main_uart8_pins_default: main-uart8-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0d0, PIN_INPUT, 11) /* (AF26) SPI0_CS1.UART8_RXD */ + J721S2_IOPAD(0x0d4, PIN_OUTPUT, 11) /* (AH27) SPI0_CLK.UART8_TXD */ + >; + }; + + main_mmc1_pins_default: main-mmc1-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x104, PIN_INPUT, 0) /* (P23) MMC1_CLK */ + J721S2_IOPAD(0x108, PIN_INPUT, 0) /* (N24) MMC1_CMD */ + J721S2_IOPAD(0x100, PIN_INPUT, 0) /* (###) MMC1_CLKLB */ + J721S2_IOPAD(0x0fc, PIN_INPUT, 0) /* (M23) MMC1_DAT0 */ + J721S2_IOPAD(0x0f8, PIN_INPUT, 0) /* (P24) MMC1_DAT1 */ + J721S2_IOPAD(0x0f4, PIN_INPUT, 0) /* (R24) MMC1_DAT2 */ + J721S2_IOPAD(0x0f0, PIN_INPUT, 0) /* (R22) MMC1_DAT3 */ + J721S2_IOPAD(0x0e8, PIN_INPUT, 8) /* (AE25) TIMER_IO0.MMC1_SDCD */ + >; + }; + + main_usbss0_pins_default: main-usbss0-pins-default { + pinctrl-single,pins = < + J721S2_IOPAD(0x0ec, PIN_OUTPUT, 6) /* (AG25) TIMER_IO1.USB0_DRVVBUS */ + >; + }; +}; + +&wkup_pmx0 { + mcu_uart0_pins_default: mcu-uart0-pins-default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x0f4, PIN_INPUT, 0) /*(C24) WKUP_GPIO0_13.MCU_UART0_RXD*/ + J721S2_WKUP_IOPAD(0x0f0, PIN_OUTPUT, 0) /*(C25) WKUP_GPIO0_12.MCU_UART0_TXD*/ + >; + }; + + wkup_uart0_pins_default: wkup-uart0-pins-default { + u-boot,dm-spl; + pinctrl-single,pins = < + J721S2_WKUP_IOPAD(0x0d8, PIN_INPUT, 0) /*(E25) WKUP_GPIO0_6.WKUP_UART0_CTSn*/ + J721S2_WKUP_IOPAD(0x0dc, PIN_OUTPUT, 0) /*(F28) WKUP_GPIO0_7.WKUP_UART0_RTSn*/ + J721S2_WKUP_IOPAD(0x0b0, PIN_INPUT, 0) /* (D28) WKUP_UART0_RXD */ + J721S2_WKUP_IOPAD(0x0b4, PIN_OUTPUT, 0) /* (D27) WKUP_UART0_TXD */ + >; + }; + +}; + +&sms { + mboxes= <&mcu_secproxy 8>, <&mcu_secproxy 6>, <&mcu_secproxy 5>; + mbox-names = "tx", "rx", "notify"; + ti,host-id = <4>; + ti,secure-host; + u-boot,dm-spl; +}; + +&wkup_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&wkup_uart0_pins_default>; +}; + +&mcu_uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&mcu_uart0_pins_default>; +}; + +&main_uart8 { + pinctrl-names = "default"; + pinctrl-0 = <&main_uart8_pins_default>; +}; + +&main_sdhci0 { + status = "disabled"; +}; + +&main_sdhci1 { + /delete-property/ power-domains; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + pinctrl-0 = <&main_mmc1_pins_default>; + pinctrl-names = "default"; + clock-names = "clk_xin"; + clocks = <&clk_200mhz>; + ti,driver-strength-ohm = <50>; +}; + +&mcu_ringacc { + ti,sci = <&dm_tifs>; +}; + +&mcu_udmap { + ti,sci = <&dm_tifs>; +}; + +#include "k3-am68-sk-base-board-u-boot.dtsi"
Now that single defconfig shall be used for booting J721S2 EVM and AM68 SK, the default device tree will not work for selecting dtb for kernel. Update the findfdt env to select right dtb based on board_name env variable.
Signed-off-by: Sinthu Raja sinthu.raja@ti.com --- include/configs/j721s2_evm.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/j721s2_evm.h b/include/configs/j721s2_evm.h index 932d7d3c8c..715f03048a 100644 --- a/include/configs/j721s2_evm.h +++ b/include/configs/j721s2_evm.h @@ -32,6 +32,10 @@ "default_device_tree=" CONFIG_DEFAULT_DEVICE_TREE ".dtb\0" \ "findfdt=" \ "setenv name_fdt ${default_device_tree};" \ + "if test $board_name = j721s2; then " \ + "setenv name_fdt k3-j721s2-common-proc-board.dtb; fi;" \ + "if test $board_name = am68-sk; then " \ + "setenv name_fdt k3-am68-sk-base-board.dtb; fi;"\ "setenv fdtfile ${name_fdt}\0" \ "name_kern=Image\0" \ "console=ttyS2,115200n8\0" \
But please note that the CFG_ENV_EXTRA_SETTINGS logic needs to move to text based environment files, sooner rather than later would be best.
Sure, Tom. We will work on this sooner. Thanks for the review.
-- Tom
On Wed, Jan 4, 2023 at 3:14 PM Sinthu Raja sinthu.raja@mistralsolutions.com wrote:
Tom, Please let me know your comments on this series.
Changes in V4:
- In align with the macro conditional statement which missed it in the previous version
Changes in V3:
- board: ti: j721s2: Add board_init and support for selecting DT based on EEPROM
Changes in V2:
- arch: mach-k3: Update board specific API name to K3 generic API name
-- 2.36.1
Neha Malcom Francis
Sinthu Raja
Sinthu Raja M
