[U-Boot] [PATCH v2] cmd: avb: Fix requested partitions list
The requested_partitions[] array should contain only boot partitions. Usually it's only 'boot' partition, as can be seen in [1]. Also, seems like the requested_partitions[] are only used when there is no 'vbmeta' partition [2], which is not a regular use-case.
Make requested_partitions[] contain only 'boot' partition as it was supposed to be, and also make that array to be a local in do_avb_verify_part() function, as nobody else needs that.
[1] https://android.googlesource.com/platform/external/avb/+/5fbb42a189aa/test/a... [2] https://android.googlesource.com/platform/external/avb/+/5fbb42a189aa/libavb...
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- Changes in v2: - fix links in commit message (suggested by Eugeniu Rosca)
cmd/avb.c | 6 +----- 1 file changed, 1 insertion(+), 5 deletions(-)
diff --git a/cmd/avb.c b/cmd/avb.c index a8a95034ca..a4de5c40a2 100644 --- a/cmd/avb.c +++ b/cmd/avb.c @@ -15,11 +15,6 @@ #define AVB_BOOTARGS "avb_bootargs" static struct AvbOps *avb_ops;
-static const char * const requested_partitions[] = {"boot", - "system", - "vendor", - NULL}; - int do_avb_init(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { unsigned long mmc_dev; @@ -232,6 +227,7 @@ int do_avb_get_uuid(cmd_tbl_t *cmdtp, int flag, int do_avb_verify_part(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) { + const char * const requested_partitions[] = {"boot", NULL}; AvbSlotVerifyResult slot_result; AvbSlotVerifyData *out_data; char *cmdline;
Hi Sam,
On Thu, Aug 15, 2019 at 8:49 PM Sam Protsenko semen.protsenko@linaro.org wrote:
Changes in v2:
"system",
"vendor",
NULL};
-- 2.23.0.rc1
Reviewed-by: Igor Opaniuk igor.opaniuk@gmail.com
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org Reviewed-by: Igor Opaniuk igor.opaniuk@gmail.com
Igor Opaniuk
Sam Protsenko
