[U-Boot] [PATCH] common: cmd_sata: Fix usage text for 'sata init'
Currently sata usage text prints a double 'sata' for the init command.
MX53LOCO U-Boot > sata sata - SATA sub system
Usage: sata sata init - init SATA sub system sata info - show available SATA devices sata device [dev] - show or set current device sata part [dev] - print partition table sata read addr blk# cnt sata write addr blk# cnt
Remove the extra 'sata' from the 'sata init' line.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- common/cmd_sata.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/cmd_sata.c b/common/cmd_sata.c index b401bd1..8d57285 100644 --- a/common/cmd_sata.c +++ b/common/cmd_sata.c @@ -196,7 +196,7 @@ static int do_sata(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) U_BOOT_CMD( sata, 5, 1, do_sata, "SATA sub system", - "sata init - init SATA sub system\n" + "init - init SATA sub system\n" "sata info - show available SATA devices\n" "sata device [dev] - show or set current device\n" "sata part [dev] - print partition table\n"
Hi Fabio,
- "init - init SATA sub system\n" "sata info - show available SATA devices\n" "sata device [dev] - show or set current device\n" "sata part [dev] - print partition table\n"
I think we do not need to talk a lot about it. Applied to u-boot-imx, thanks !
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
