[U-Boot] [PATCH] board: axs10x switch serial port and Ethernet to driver model
With this change Synopsys DesignWare SDP board is switched to driver model for both serial port (serial_dw) and Ethernet (Designware GMAC).
This simplifies include/configs/axs101.h and allows for reuse of Linux's Device Tree description.
For simplicity Linux's .dts files are not blindly copied but only very few extracts of them are really used (those that are supported in U-Boot at the moment).
Signed-off-by: Alexey Brodkin abrodkin@synopsys.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Simon Glass sjg@chromium.org --- arch/arc/dts/Makefile | 1 + arch/arc/dts/axs10x.dts | 45 ++++++++++++++++++++++++++++++++++++++++++ board/synopsys/axs101/axs101.c | 12 ----------- configs/axs101_defconfig | 11 ++++++++++- configs/axs103_defconfig | 11 ++++++++++- include/configs/axs101.h | 31 ++++++----------------------- 6 files changed, 72 insertions(+), 39 deletions(-) create mode 100644 arch/arc/dts/axs10x.dts
diff --git a/arch/arc/dts/Makefile b/arch/arc/dts/Makefile index d481fcd..d4772ec 100644 --- a/arch/arc/dts/Makefile +++ b/arch/arc/dts/Makefile @@ -2,6 +2,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
+dtb-$(CONFIG_TARGET_AXS101) += axs10x.dtb dtb-$(CONFIG_TARGET_ARCANGEL4) += arcangel4.dtb dtb-$(CONFIG_TARGET_TB100) += abilis_tb100.dtb
diff --git a/arch/arc/dts/axs10x.dts b/arch/arc/dts/axs10x.dts new file mode 100644 index 0000000..8fe1837 --- /dev/null +++ b/arch/arc/dts/axs10x.dts @@ -0,0 +1,45 @@ +/* + * Copyright (C) 2015 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/dts-v1/; + +#include "skeleton.dtsi" + +/ { + #address-cells = <1>; + #size-cells = <1>; + + aliases { + console = &uart0; + }; + + clocks { + apbclk: apbclk { + compatible = "fixed-clock"; + clock-frequency = <50000000>; + #clock-cells = <0>; + }; + }; + + uart0: serial0@e0022000 { + compatible = "snps,dw-apb-uart"; + reg = <0xe0022000 0x1000>; + reg-shift = <2>; + reg-io-width = <4>; + }; + + ethernet@e0018000 { + #interrupt-cells = <1>; + compatible = "altr,socfpga-stmmac"; + reg = < 0xe0018000 0x2000 >; + interrupts = < 25 >; + interrupt-names = "macirq"; + phy-mode = "gmii"; + snps,pbl = < 32 >; + clocks = <&apbclk>; + clock-names = "stmmaceth"; + max-speed = <100>; + }; +}; diff --git a/board/synopsys/axs101/axs101.c b/board/synopsys/axs101/axs101.c index aa446b9..84ee2bf 100644 --- a/board/synopsys/axs101/axs101.c +++ b/board/synopsys/axs101/axs101.c @@ -7,8 +7,6 @@ #include <common.h> #include <dwmmc.h> #include <malloc.h> -#include <netdev.h> -#include <phy.h> #include "axs10x.h"
DECLARE_GLOBAL_DATA_PTR; @@ -35,16 +33,6 @@ int board_mmc_init(bd_t *bis) return 0; }
-int board_eth_init(bd_t *bis) -{ - if (designware_initialize(ARC_DWGMAC_BASE, - PHY_INTERFACE_MODE_RGMII) >= 0) - return 1; - - return 0; -} - - #define AXS_MB_CREG 0xE0011000
int board_early_init_f(void) diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index fdb3149..8e5d2e5 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -1,12 +1,21 @@ CONFIG_ARC=y CONFIG_SYS_DCACHE_OFF=y CONFIG_ARC_CACHE_LINE_SHIFT=5 +CONFIG_DM_SERIAL=y CONFIG_SYS_CLK_FREQ=750000000 CONFIG_SYS_TEXT_BASE=0x81000000 +CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_SYS_PROMPT="AXS# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_NETDEVICES=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index b3dbb8d..cbd63fe 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -1,11 +1,20 @@ CONFIG_ARC=y CONFIG_ISA_ARCV2=y +CONFIG_DM_SERIAL=y CONFIG_SYS_CLK_FREQ=50000000 CONFIG_SYS_TEXT_BASE=0x81000000 +CONFIG_DEFAULT_DEVICE_TREE="axs10x" CONFIG_SYS_PROMPT="AXS# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set -CONFIG_NETDEVICES=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_OF_CONTROL=y +CONFIG_OF_EMBED=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/include/configs/axs101.h b/include/configs/axs101.h index 450291c..9a7e0dc 100644 --- a/include/configs/axs101.h +++ b/include/configs/axs101.h @@ -39,6 +39,8 @@ #define CONFIG_BOARD_TYPES #define CONFIG_BOARD_EARLY_INIT_F
+#define CONFIG_OF_LIBFDT + /* * NAND Flash configuration */ @@ -48,28 +50,14 @@
/* * UART configuration - * - * CONFIG_CONS_INDEX = 1 - Debug UART - * CONFIG_CONS_INDEX = 4 - FPGA UART connected to FTDI/USB */ -#define CONFIG_CONS_INDEX 4 +#define CONFIG_DW_SERIAL #define CONFIG_SYS_NS16550 #define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE -4 -#if (CONFIG_CONS_INDEX == 1) - /* Debug UART */ -# define CONFIG_SYS_NS16550_CLK 33333000 -#else - /* FPGA UARTs use different clock */ -# define CONFIG_SYS_NS16550_CLK 33333333 -#endif -#define CONFIG_SYS_NS16550_COM1 (ARC_APB_PERIPHERAL_BASE + 0x5000) -#define CONFIG_SYS_NS16550_COM2 (ARC_FPGA_PERIPHERAL_BASE + 0x20000) -#define CONFIG_SYS_NS16550_COM3 (ARC_FPGA_PERIPHERAL_BASE + 0x21000) -#define CONFIG_SYS_NS16550_COM4 (ARC_FPGA_PERIPHERAL_BASE + 0x22000) +#define CONFIG_SYS_NS16550_CLK 33333333 #define CONFIG_SYS_NS16550_MEM32 - #define CONFIG_BAUDRATE 115200 + /* * I2C configuration */ @@ -119,18 +107,11 @@ #define CONFIG_DW_AUTONEG
/* - * Command line configuration + * Commands still not supported in Kconfig */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_EEPROM #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_MMC #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_RARP - -#define CONFIG_OF_LIBFDT
#define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_MAXARGS 16
On 13 November 2015 at 11:26, Alexey Brodkin Alexey.Brodkin@synopsys.com wrote:
Applied, thanks!
-Alexey
Alexey Brodkin
