[U-Boot] [PATCH] sun7i: Add support for Olimex A20-OLinuXino-LIME
This patch adds support for Olimex A20-OLinuXino-LIME board.
Signed-off-by: FUKAUMI Naoki naobsd@gmail.com --- board/sunxi/Makefile | 1 + board/sunxi/dram_a20_olinuxino_l.c | 31 +++++++++++++++++++++++++++++++ configs/A20-OLinuXino-Lime_defconfig | 5 +++++ 3 files changed, 37 insertions(+) create mode 100644 board/sunxi/dram_a20_olinuxino_l.c create mode 100644 configs/A20-OLinuXino-Lime_defconfig
diff --git a/board/sunxi/Makefile b/board/sunxi/Makefile index cf001e7..56073a0 100644 --- a/board/sunxi/Makefile +++ b/board/sunxi/Makefile @@ -15,6 +15,7 @@ obj-$(CONFIG_A10_OLINUXINO_L) += dram_a10_olinuxino_l.o obj-$(CONFIG_A10S_OLINUXINO_M) += dram_a10s_olinuxino_m.o obj-$(CONFIG_A13_OLINUXINO) += dram_a13_olinuxino.o obj-$(CONFIG_A13_OLINUXINOM) += dram_a13_oli_micro.o +obj-$(CONFIG_A20_OLINUXINO_L) += dram_a20_olinuxino_l.o obj-$(CONFIG_A20_OLINUXINO_M) += dram_sun7i_384_1024_iow16.o # This is not a typo, uses the same mem settings as the a10s-olinuxino-m obj-$(CONFIG_AUXTEK_T004) += dram_a10s_olinuxino_m.o diff --git a/board/sunxi/dram_a20_olinuxino_l.c b/board/sunxi/dram_a20_olinuxino_l.c new file mode 100644 index 0000000..2c74999 --- /dev/null +++ b/board/sunxi/dram_a20_olinuxino_l.c @@ -0,0 +1,31 @@ +/* this file is generated, don't edit it yourself */ + +#include "common.h" +#include <asm/arch/dram.h> + +static struct dram_para dram_para = { + .clock = 480, + .type = 3, + .rank_num = 1, + .density = 4096, + .io_width = 16, + .bus_width = 16, + .cas = 9, + .zq = 0x7f, + .odt_en = 0, + .size = 512, + .tpr0 = 0x42d899b7, + .tpr1 = 0xa090, + .tpr2 = 0x22a00, + .tpr3 = 0, + .tpr4 = 0, + .tpr5 = 0, + .emr1 = 0x4, + .emr2 = 0x10, + .emr3 = 0, +}; + +unsigned long sunxi_dram_init(void) +{ + return dramc_init(&dram_para); +} diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig new file mode 100644 index 0000000..b06377a --- /dev/null +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -0,0 +1,5 @@ +CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="A20_OLINUXINO_L,SPL,AXP209_POWER,SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3),USB_EHCI" +CONFIG_FTDFILE="sun7i-a20-olinuxino-lime.dtb" ++S:CONFIG_ARM=y ++S:CONFIG_TARGET_SUN7I=y
I think this looks like a pretty straight import from the linux-sunxi u-boot fork, massaged for changes from upstream, is that right?
Looks good but please also add an entry to board/sunxi/MAINTAINERS. You'll most likely want to base it on u-boot-sunxi.git next or master to avoid conflicts.
Ian.
hi
yes. dram_a20_olinuxino_l.c is copied from linux-sunxi/u-boot-sunxi.
I see, but sorry, who should maintain this board?
yes, I used u-boot-sunxi/master as a base.
Regards,
You, I hope! I'm not sure what u-boot policy generally is here, but personally I would much prefer to have a named person who owns the hardware listed so that I can ask for testing when I think something might affect that board.
Ian.
hi
I see. I'll make new patch.
The A20-OLinuXino-LIME is already supported by the u-boot-arm tree: http://git.denx.de/?p=u-boot/u-boot-arm.git;a=summary
We're waiting for the u-boot arm maintainer to send a pull-req for things to get added to u-boot master.
Regards,
Hans
- .clock = 480,
- .type = 3,
- .rank_num = 1,
- .density = 4096,
- .io_width = 16,
- .bus_width = 16,
- .cas = 9,
- .zq = 0x7f,
- .odt_en = 0,
- .size = 512,
- .tpr0 = 0x42d899b7,
- .tpr1 = 0xa090,
- .tpr2 = 0x22a00,
- .tpr3 = 0,
- .tpr4 = 0,
- .tpr5 = 0,
- .emr1 = 0x4,
- .emr2 = 0x10,
- .emr3 = 0,
- return dramc_init(&dram_para);
hi
I cannot find any file for A20-OLinuXino-LIME under configs/* and board/sunxi/* in u-boot-arm/master.
(btw, I tested my patch with u-boot-sunxi/master)
Regards,
On Sun, 2014-08-24 at 22:05 +0900, Naoki FUKAUMI wrote:
hi
FWIW I see ./configs/A10-OLinuXino-Lime_defconfig but not the A20 variant, perhaps Hans had confused the two.
There's some additional stuff in /next. Nothing looks like it should interfere with your patch but testing the new dram stuff which is in there on one more platform surely couldn't hurt.
Ian.
hi
Ah right, my bad I did not even know there was an A20 based lime out, interesting!
Regards,
Hans
FUKAUMI Naoki
Hans de Goede
Ian Campbell
Naoki FUKAUMI
