[U-Boot] ppc4xx: u-boot sees PCIe endpoint, linux does not.
Hello,
AMCC PPC460EX canyonlands board with an FPGA PCIe end point:
u-boot sees the end point, but Linux does not:
U-Boot 1.3.3-00249-ga524e11 (Jun 30 2008 - 16:05:51) CPU: AMCC PowerPC 460EX Rev. A at 800 MHz (PLB=200, OPB=100, EBC=100 MHz) <...> Board: Canyonlands - AMCC PPC460EX Evaluation Board, 2*PCIe, Rev. 16 <...> PCIE1: successfully set as root-complex 02 00 2071 2071 00ff 00
Now, if I re-program the end-point FPGA during the u-boot boot time-out, Linux will recognize the end-point.
Any takers on what I should start looking for?
Regards,
On Fri, 2008-11-28 at 13:50 +0100, Leon Woestenberg wrote:
Hello,
It's possible that either the reset in between goes bonkers or something else causes your FPGA to stop responding. It looks like a programming problem with the FPGA to me.
Ben.
Hello all,
On Mon, Dec 1, 2008 at 9:12 AM, Benjamin Herrenschmidt benh@kernel.crashing.org wrote:
I have verified that the end point does not receive any kind of reset.
Also, this problem only happens on the Canyonlands board; on x86 and powerpc MPC8315E it remains properly working after soft/hard resets, u-boot init etc.
Could it be u-boot overwrites a too large payload into the config space or something similar, which makes subsequent accesses fail?
Regards,
This could be because only the 4xx Linux PCI(e) driver really resets the endpoint (PHY reset). But you seem to have analyzed this already.
Not sure. I suggest that you disable the PCI(e) support in U-Boot to see if Linux behaves differently on a non-pre-initialized endpoint.
Best regards, Stefan
Hello Stefan,
Some progress:
Using au-boot GIT checkout of 9-2-2009 (one month old) I now have different behaviour: u-boot does report a link, but no longer the PCIe vendor id:
CPU: AMCC PowerPC 460EX Rev. A at 800 MHz (PLB=200, OPB=100, EBC=100 MHz) Security/Kasumi support Bootstrap Option H - Boot ROM Location I2C (Addr 0x52) Internal PCI arbiter disabled 32 kB I-Cache 32 kB D-Cache Board: Canyonlands - AMCC PPC460EX Evaluation Board, 2*PCIe, Rev. 16 I2C: ready DTT: 1 is 44 C DRAM: 512 MB (ECC not enabled, 400 MHz, CL3) FLASH: 64 MB NAND: 128 MiB PCI: Bus Dev VenId DevId Class Int PCIE0: link is not up. PCIE0: initialization as root-complex failed PCIE1: successfully set as root-complex
Linux now correctly recognizes the device. The FPGA with PCIe end point now also survives both a hard reset (reset button) and soft reset (shutdown -r now in Linux).
Regards,
Leon Woestenberg
Stefan Roese
