[PATCH] eth: Fixed-phy support in r-car
From 87bdd605d79f3c492cfc2634a51b17de161b87b5 Mon Sep 17 00:00:00 2001
From: Mikhail Lappo miklelappo@gmail.com Date: Fri, 7 Feb 2020 12:37:53 +0100 Subject: [PATCH] eth: Fixed-phy support in r-car
Calling old Uboot API doesn't allow to use fixed phy. Searching by mask is the part of new function, after scanning FDT for a fixed-phy definition
Signed-off-by: Mikhail Lappo miklelappo@gmail.com CC: Marek Vasut marek.vasut+renesas@gmail.com --- drivers/net/ravb.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/net/ravb.c b/drivers/net/ravb.c index 46e02ed14c..92b9a0767c 100644 --- a/drivers/net/ravb.c +++ b/drivers/net/ravb.c @@ -304,7 +304,7 @@ static int ravb_phy_config(struct udevice *dev) struct ravb_priv *eth = dev_get_priv(dev); struct eth_pdata *pdata = dev_get_platdata(dev); struct phy_device *phydev; - int mask = 0xffffffff, reg; + int reg;
if (dm_gpio_is_valid(ð->reset_gpio)) { dm_gpio_set_value(ð->reset_gpio, 1); @@ -313,7 +313,7 @@ static int ravb_phy_config(struct udevice *dev) mdelay(1); }
- phydev = phy_find_by_mask(eth->bus, mask, pdata->phy_interface); + phydev = phy_connect(eth->bus, 0, dev, pdata->phy_interface); if (!phydev) return -ENODEV;
Mikle Lappo
