[U-Boot] [PATCH] driver: net: ldpaa_eth: Add PHY-less SGMII support
In case of PHY-less mode, there is no interaction with PHY so auto-neg etc is not required and link will have fixed attributes
Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- drivers/net/ldpaa_eth/ldpaa_eth.c | 9 +++++++-- 1 file changed, 7 insertions(+), 2 deletions(-)
diff --git a/drivers/net/ldpaa_eth/ldpaa_eth.c b/drivers/net/ldpaa_eth/ldpaa_eth.c index 21be79a..85e7faa 100644 --- a/drivers/net/ldpaa_eth/ldpaa_eth.c +++ b/drivers/net/ldpaa_eth/ldpaa_eth.c @@ -440,12 +440,17 @@ static int ldpaa_eth_open(struct eth_device *net_dev, bd_t *bd) bus = wriop_get_mdio(priv->dpmac_id); enet_if = wriop_get_enet_if(priv->dpmac_id); if ((bus == NULL) && - (enet_if == PHY_INTERFACE_MODE_XGMII)) { + ((enet_if == PHY_INTERFACE_MODE_XGMII) || + (enet_if == PHY_INTERFACE_MODE_SGMII))) { priv->phydev = (struct phy_device *) malloc(sizeof(struct phy_device)); memset(priv->phydev, 0, sizeof(struct phy_device));
- priv->phydev->speed = SPEED_10000; + if (enet_if == PHY_INTERFACE_MODE_XGMII) + priv->phydev->speed = SPEED_10000; + else + priv->phydev->speed = SPEED_1000; + priv->phydev->link = 1; priv->phydev->duplex = DUPLEX_FULL; }
priv->phydev = (struct phy_device *) malloc(sizeof(struct phy_device)); memset(priv->phydev, 0, sizeof(struct phy_device));(enet_if == PHY_INTERFACE_MODE_SGMII))) {
else
- priv->phydev->link = 1; priv->phydev->duplex = DUPLEX_FULL; }
How was this patch tested?
A little off-topic. I remember a similar discussion somewhere (maybe internal) for PowerPC-based boards regarding fixed SGMII port. When the port doesn't have a PHY, it fails due to PHY id check. I don't find the change in U-Boot code. Does anyone remember it?
York
-----Original Message----- From: York Sun Sent: Thursday, November 09, 2017 2:07 AM To: Ashish Kumar ashish.kumar@nxp.com; u-boot@lists.denx.de Cc: joe.hershberger@ni.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Subject: Re: [PATCH] driver: net: ldpaa_eth: Add PHY-less SGMII support
else
It can be tested with PHY-less SGMII riser cards after adding patches attached. With the existing Riser card, which are PHY enabled, the test is that PHYs are not configured by adding these to patches.
Do you suggest to add these patches in upstream?
Regards Ashish
York
else
Ashish,
This patch seems OK. But it is only effective with the other two patches you mentioned, isn't it? Please find a proper way to enable SGMII_PHYLIB using Kconfig.
York
-----Original Message----- From: U-Boot [mailto:u-boot-bounces@lists.denx.de] On Behalf Of Ashish Kumar Sent: Thursday, November 09, 2017 10:46 AM To: York Sun york.sun@nxp.com; u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com Cc: joe.hershberger@ni.com Subject: Re: [U-Boot] [PATCH] driver: net: ldpaa_eth: Add PHY-less SGMII support
*net_dev, bd_t *bd)
else
Regards Ashish
Hello York,
Please provide more details of the PowerPC target in which this these changes may be required?
Regards Ashish
York
Ashish Kumar
Ashish Kumar
York Sun
