[PATCH v2 1/2] smbios: add parsing API
Add an very simple API to be able to access SMBIOS strings like vendor, model and bios version.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- include/smbios.h | 27 +++++++++++++ lib/Kconfig | 6 +++ lib/Makefile | 1 + lib/smbios-parser.c | 96 +++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 130 insertions(+) create mode 100644 lib/smbios-parser.c
diff --git a/include/smbios.h b/include/smbios.h index 97b9ddce23..ed60c00fae 100644 --- a/include/smbios.h +++ b/include/smbios.h @@ -237,4 +237,31 @@ typedef int (*smbios_write_type)(ulong *addr, int handle); */ ulong write_smbios_table(ulong addr);
+/** + * smbios_entry() - Get a vaild struct smbios_entry pointer + * + * @address: address where smbios tables is located + * @size: size of smbios table + * @return: NULL or a valid pointer to a struct smbios_entry + */ +const struct smbios_entry *smbios_entry(u64 address, u32 size); + +/** + * smbios_header() - Search for SMBIOS header type + * + * @entry: pointer to a struct smbios_entry + * @type: SMBIOS type + * @return: NULL or a valid pointer to a struct smbios_header + */ +const struct smbios_header *smbios_header(const struct smbios_entry *entry, int type); + +/** + * smbios_string() - Return string from SMBIOS + * + * @header: pointer to struct smbios_header + * @index: string index + * @return: NULL or a valid const char pointer + */ +const char *smbios_string(const struct smbios_header *header, int index); + #endif /* _SMBIOS_H_ */ diff --git a/lib/Kconfig b/lib/Kconfig index 8efb154f73..c92131b7bc 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -667,6 +667,12 @@ config OID_REGISTRY help Enable fast lookup object identifier registry.
+config SMBIOS_PARSER + bool "SMBIOS parser" + default n + help + A simple parser for SMBIOS data. + source lib/efi/Kconfig source lib/efi_loader/Kconfig source lib/optee/Kconfig diff --git a/lib/Makefile b/lib/Makefile index 0cd7bea282..0383fddf2c 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -37,6 +37,7 @@ obj-$(CONFIG_FIT) += fdtdec_common.o obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o obj-$(CONFIG_GZIP_COMPRESSED) += gzip.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += smbios.o +obj-$(CONFIG_SMBIOS_PARSER) += smbios-parser.o obj-$(CONFIG_IMAGE_SPARSE) += image-sparse.o obj-y += ldiv.o obj-$(CONFIG_XXHASH) += xxhash.o diff --git a/lib/smbios-parser.c b/lib/smbios-parser.c new file mode 100644 index 0000000000..b89f988ef9 --- /dev/null +++ b/lib/smbios-parser.c @@ -0,0 +1,96 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020, Bachmann electronic GmbH + */ + +#include <common.h> +#include <smbios.h> + +static inline int verify_checksum(const struct smbios_entry *e) +{ + /* + * Checksums for SMBIOS tables are calculated to have a value, so that + * the sum over all bytes yields zero (using unsigned 8 bit arithmetic). + */ + u8 *byte = (u8 *)e; + u8 sum = 0; + + for (int i = 0; i < e->length; i++) + sum += byte[i]; + + return sum; +} + +const struct smbios_entry *smbios_entry(u64 address, u32 size) +{ + const struct smbios_entry *entry = (struct smbios_entry *)(uintptr_t)address; + + if (!address | !size) + return NULL; + + if (memcmp(entry->anchor, "_SM_", 4)) + return NULL; + + if (verify_checksum(entry)) + return NULL; + + return entry; +} + +static const struct smbios_header *next_header(const struct smbios_header *curr) +{ + u8 *pos = ((u8 *)curr) + curr->length; + + /* search for _double_ NULL bytes */ + while (!((*pos == 0) && (*(pos + 1) == 0))) + pos++; + + /* step behind the double NULL bytes */ + pos += 2; + + return (struct smbios_header *)pos; +} + +const struct smbios_header *smbios_header(const struct smbios_entry *entry, int type) +{ + const unsigned int num_header = entry->struct_count; + const struct smbios_header *header = (struct smbios_header *)entry->struct_table_address; + + for (unsigned int i = 0; i < num_header; i++) { + if (header->type == type) + return header; + + header = next_header(header); + } + + return NULL; +} + +static const char *string_from_smbios_table(const struct smbios_header *header, + int idx) +{ + unsigned int i = 1; + u8 *pos; + + if (!header) + return NULL; + + pos = ((u8 *)header) + header->length; + + while (i < idx) { + if (*pos == 0x0) + i++; + + pos++; + } + + return (const char *)pos; +} + +const char *smbios_string(const struct smbios_header *header, int index) +{ + if (!header) + return NULL; + + return string_from_smbios_table(header, index); +}
If u-boot gets used as coreboot payload it might be nice to get vendor, model and bios version from smbios. I am not sure about the output of all the read information.
With qemu target for coreboot this could look this:
CBFS: Found @ offset 14f40 size 3b188 Checking segment from ROM address 0xffc15178 Checking segment from ROM address 0xffc15194 Loading segment from ROM address 0xffc15178 code (compression=1) New segment dstaddr 0x01110000 memsize 0x889ef srcaddr 0xffc151b0 filesize 0x3b150 Loading Segment: addr: 0x01110000 memsz: 0x00000000000889ef filesz: 0x000000000003b150 using LZMA Loading segment from ROM address 0xffc15194 Entry Point 0x01110000 BS: BS_PAYLOAD_LOAD run times (exec / console): 77 / 1 ms Jumping to boot code at 0x01110000(0x07fa7000)
U-Boot 2020.10-00536-g5dcf7cc590-dirty (Oct 07 2020 - 14:21:51 +0200)
CPU: x86_64, vendor AMD, device 663h DRAM: 127.1 MiB MMC: Video: No video mode configured in coreboot! Video: No video mode configured in coreboot! Vendor: QEMU Model: Standard PC (i440FX + PIIX, 1996) Bios Version: 4.12-3152-g326a499f6f-dirty Net: e1000: 52:54:00:12:34:56 eth0: e1000#0 No working controllers found Finalizing coreboot Hit any key to stop autoboot: 0
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- board/coreboot/coreboot/coreboot.c | 45 ++++++++++++++++++++++++++++++ configs/coreboot_defconfig | 1 + 2 files changed, 46 insertions(+)
diff --git a/board/coreboot/coreboot/coreboot.c b/board/coreboot/coreboot/coreboot.c index b791b82ef4..afb457212a 100644 --- a/board/coreboot/coreboot/coreboot.c +++ b/board/coreboot/coreboot/coreboot.c @@ -4,7 +4,9 @@ */
#include <common.h> +#include <asm/arch/sysinfo.h> #include <init.h> +#include <smbios.h>
int board_early_init_r(void) { @@ -16,3 +18,46 @@ int board_early_init_r(void)
return 0; } + +#ifdef CONFIG_SMBIOS_PARSER +int show_board_info(void) +{ + const struct smbios_entry *smbios = smbios_entry(lib_sysinfo.smbios_start, lib_sysinfo.smbios_size); + + if (!smbios) + goto fallback; + + const struct smbios_header *bios = smbios_header(smbios, SMBIOS_BIOS_INFORMATION); + const struct smbios_header *system = smbios_header(smbios, SMBIOS_SYSTEM_INFORMATION); + const struct smbios_type0 *t0 = (struct smbios_type0 *)bios; + const struct smbios_type1 *t1 = (struct smbios_type1 *)system; + + if (!t0 || !t1) + goto fallback; + + const char *bios_ver = smbios_string(bios, t0->bios_ver); + const char *model = smbios_string(system, t1->product_name); + const char *manufacturer = smbios_string(system, t1->manufacturer); + + if (!model || !manufacturer || !bios_ver) + goto fallback; + + printf("Vendor: %s\n", manufacturer); + printf("Model: %s\n", model); + printf("Bios Version: %s\n", bios_ver); + + return 0; + +fallback: +#ifdef CONFIG_OF_CONTROL + DECLARE_GLOBAL_DATA_PTR; + + model = fdt_getprop(gd->fdt_blob, 0, "model", NULL); + + if (model) + printf("Model: %s\n", model); +#endif + + return checkboard(); +} +#endif diff --git a/configs/coreboot_defconfig b/configs/coreboot_defconfig index 3249b2fb2f..501a20e790 100644 --- a/configs/coreboot_defconfig +++ b/configs/coreboot_defconfig @@ -43,3 +43,4 @@ CONFIG_SOUND=y CONFIG_SOUND_I8254=y CONFIG_CONSOLE_SCROLL_LINES=5 # CONFIG_GZIP is not set +CONFIG_SMBIOS_PARSER=y
ping
Am Mi., 7. Okt. 2020 um 14:33 Uhr schrieb Christian Gmeiner christian.gmeiner@gmail.com:
if (!smbios)
goto fallback;
if (!t0 || !t1)
goto fallback;
goto fallback;
if (model)
2.28.0
On Wed, Oct 7, 2020 at 8:33 PM Christian Gmeiner christian.gmeiner@gmail.com wrote:
if (!smbios)
goto fallback;
if (!t0 || !t1)
goto fallback;
goto fallback;
nits: Bios -> BIOS
if (model)
Please make sure the Kconfig option is inserted in a correct order
Otherwise: Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
ping and a short question: would it make more sense to put the parsing code into smbios.c and unconditionally compile it?
- smbios_entry() - Get a vaild struct smbios_entry pointer
- @address: address where smbios tables is located
- @size: size of smbios table
- @return: NULL or a valid pointer to a struct smbios_entry
- smbios_header() - Search for SMBIOS header type
- @entry: pointer to a struct smbios_entry
- @type: SMBIOS type
- @return: NULL or a valid pointer to a struct smbios_header
- smbios_string() - Return string from SMBIOS
- @header: pointer to struct smbios_header
- @index: string index
- @return: NULL or a valid const char pointer
default n
help
- Copyright (C) 2020, Bachmann electronic GmbH
u8 *byte = (u8 *)e;
u8 sum = 0;
sum += byte[i];
return sum;
return NULL;
return NULL;
return NULL;
return entry;
pos++;
pos += 2;
return header;
return NULL;
int idx)
unsigned int i = 1;
u8 *pos;
if (!header)
return NULL;
while (i < idx) {
if (*pos == 0x0)
i++;
pos++;
if (!header)
return NULL;
2.28.0
On Mon, Nov 2, 2020 at 5:21 PM Christian Gmeiner christian.gmeiner@gmail.com wrote:
I think it's fine to leave this as a separte module.
But nits below:
an -> a
typo: valid
default n
nits: remove default n, because it is Kconfig default
help
u8 *byte = (u8 *)e;
u8 sum = 0;
sum += byte[i];
return sum;
return NULL;
return NULL;
return NULL;
return entry;
pos++;
pos += 2;
return header;
return NULL;
int idx)
unsigned int i = 1;
u8 *pos;
if (!header)
return NULL;
while (i < idx) {
if (*pos == 0x0)
i++;
pos++;
if (!header)
return NULL;
2.28.0
Regards, Bin
Bin Meng
Christian Gmeiner
