[U-Boot] [PATCH 0/6] DDR intereleaving support
Current new DDR code has included DDR interleaving support but has not been tested out. The following patches fix the bugs for common code, enable run time configuration of memory controller interleaving mode and bank interleaving mode and add board specific parameters table to decides the ddr controller options. The DDR interleaving support was tested on MPC8572DS and MPC8641HPCN with some (not all) of the interleaving modes.
On MPC8572DS board, I tested two kinds of memory modules: * 2 X 512MB single-rank DDR2 DIMM * 2 X 1GB single-rank DDR2 DIMM at 1500/600/800(CPU/CCB/DDR)MHz frequency, by using "bw_mem", the memory bandwith benchmark in LMbench.
The following interleaving combination are tested: +-------------+--------------------+ | | Bank Interleaving| | +--------+-----------+ |Memory | | | |Controller | None | 2x1 lower | |Interleaving | | {CS0+CS1} | +-------------+--------+-----------+ |None | Yes | Yes | +-------------+--------+-----------+ |Cacheline | Yes | Yes | | |CS0 Only| | +-------------+--------+-----------+ |Page | Yes | Yes | | |CS0 Only| | +-------------+--------+-----------+ |Bank | Yes | Yes | | |CS0 Only| | +-------------+--------+-----------+ |Superbank | No | Yes | | | | | +-------------+--------+-----------+
On MPC8641HPCN board, I tested three kinds of memory modules: * 2 X 512MB single-rank DDR2 DIMM * 4 X 512MB single-rank DDR2 DIMM * 2 X 1GB single-rank DDR2 DIMM I also tested CS2+CS3 interleaving mode on MPC8641HPCN board.
Haiying
Haiying Wang
