[U-Boot] [PATCH] rockchip: rk322x: fix pd_bus hclk/pclk
The pd_bus hclk/pclk source is pd_bus aclk, not the PLL.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
drivers/clk/rockchip/clk_rk322x.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/clk/rockchip/clk_rk322x.c b/drivers/clk/rockchip/clk_rk322x.c index 6bbfde4..9e7e047 100644 --- a/drivers/clk/rockchip/clk_rk322x.c +++ b/drivers/clk/rockchip/clk_rk322x.c @@ -117,16 +117,16 @@ static void rkclk_init(struct rk322x_cru *cru) pclk_div << CORE_PERI_DIV_SHIFT);
/* - * select apll as pd_bus bus clock source and + * select gpll as pd_bus bus clock source and * set up dependent divisors for PCLK/HCLK and ACLK clocks. */ aclk_div = GPLL_HZ / BUS_ACLK_HZ - 1; assert((aclk_div + 1) * BUS_ACLK_HZ == GPLL_HZ && aclk_div <= 0x1f);
- pclk_div = GPLL_HZ / BUS_PCLK_HZ - 1; + pclk_div = BUS_ACLK_HZ / BUS_PCLK_HZ - 1; assert((pclk_div + 1) * BUS_PCLK_HZ == GPLL_HZ && pclk_div <= 0x7);
- hclk_div = GPLL_HZ / BUS_HCLK_HZ - 1; + hclk_div = BUS_ACLK_HZ / BUS_HCLK_HZ - 1; assert((hclk_div + 1) * BUS_HCLK_HZ == GPLL_HZ && hclk_div <= 0x3);
rk_clrsetreg(&cru->cru_clksel_con[0],
Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Signed-off-by: Kever Yang kever.yang@rock-chips.com Acked-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com Reviewed-by: Philipp Tomsich philipp.tomsich@theobroma-systems.com
Applied to u-boot-rockchip, thanks!
Kever Yang
Philipp Tomsich
