[U-Boot] Adding SPI slave devices To DM
Hello All,
It's quite a long time, since I touched u-boot code, I was working on adding a slave SPI device to DM, can anyone point me to a sample driver.
Cheers, --Prabhakar Lad
On 13 May 2016 at 10:58, Lad, Prabhakar prabhakar.csengg@gmail.com wrote:
Hello All,
I think you mean a device that uses SPI, so you could try cro_ec_spi.c or tpm_tis_st33zp24_spi.c.
There is also a patch to provide a DM interface - if you base your work on u-boot-dm/master then you will get this - dm_spi_xfer(), etc.
Cheers, --Prabhakar Lad _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
Hi Simon,
Hello All,
Thanks for the pointers.
My intention was, to use sspi command, just to power up the LCD, but since there is no slave driver for it in the u-boot source, the device didnt populate as I am using devicetree.
So would it be good to have spidev driver in u-boot as well ?
On 14 May 2016 at 14:26, Lad, Prabhakar prabhakar.csengg@gmail.com wrote:
Hi Simon,
Hello All,
Sounds useful to me.
Lad, Prabhakar
