[U-Boot] [PATCHv2 0/4]enable USB OHCI on sam9x5ek boards
This small patchset is based on current master ( 178d0cc1a4c73c3341afbeb2a93b172de8c96bd1 ) It enables usb on at91sam9x5ek boards. Tested on at91sam9x5ek with a sam9g35 CPU (+ usb key and mouse)
By default the 3 USB 1.1 ports (A, B and C) are enabled. If CONFIG_USB_EHCI is defined, the 2 USB 2.0 ports (A and B) will be enabled.
changes from v1: * VBUS for usb port A is enabled * EHCI configuration is now present * number of OHCI ports corrected (3 instead of 2)
Richard Genoud (4): usb documentation: fix typo ARM: at91sam9x5: enable USB OHCI support for 9x5ek board. at91sam9x5ek: regroup FAT/DOS features at91sam9x5ek: add USB OHCI configuration
arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c | 9 +++++++++ arch/arm/include/asm/arch-at91/at91sam9x5.h | 2 ++ board/atmel/at91sam9x5ek/at91sam9x5ek.c | 3 +++ doc/README.usb | 2 +- drivers/usb/host/ohci-at91.c | 6 ++++-- include/configs/at91sam9x5ek.h | 18 +++++++++++++++++- 6 files changed, 36 insertions(+), 4 deletions(-)
Signed-off-by: Richard Genoud richard.genoud@gmail.com --- doc/README.usb | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/doc/README.usb b/doc/README.usb index ef1d6ba..b4c3ef5 100644 --- a/doc/README.usb +++ b/doc/README.usb @@ -63,7 +63,7 @@ Common USB Commands: Storage USB Commands: - usb scan: scans the USB for storage devices.The USB must be running for this command (usb start) -- usb device [dev]: show or set current USB staorage device +- usb device [dev]: show or set current USB storage device - usb part [dev]: print partition table of one or all USB storage devices - usb read addr blk# cnt:
Signed-off-by: Richard Genoud richard.genoud@gmail.com --- arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c | 10 ++++++++++ arch/arm/include/asm/arch-at91/at91sam9x5.h | 2 ++ board/atmel/at91sam9x5ek/at91sam9x5ek.c | 3 +++ drivers/usb/host/ohci-at91.c | 6 ++++-- 4 files changed, 19 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c index 9348552..f2a05c8 100644 --- a/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c +++ b/arch/arm/cpu/arm926ejs/at91/at91sam9x5_devices.c @@ -193,6 +193,16 @@ void at91_spi1_hw_init(unsigned long cs_mask) } #endif
+#if defined(CONFIG_USB_OHCI_NEW) || defined(CONFIG_USB_EHCI) +void at91_uhp_hw_init(void) +{ + /* Enable VBus on UHP ports */ + at91_set_pio_output(AT91_PIO_PORTD, 18, 0); /* port A */ + at91_set_pio_output(AT91_PIO_PORTD, 19, 0); /* port B */ + at91_set_pio_output(AT91_PIO_PORTD, 20, 0); /* port C */ +} +#endif + #ifdef CONFIG_MACB void at91_macb_hw_init(void) { diff --git a/arch/arm/include/asm/arch-at91/at91sam9x5.h b/arch/arm/include/asm/arch-at91/at91sam9x5.h index 0e728c9..de0f1b1 100644 --- a/arch/arm/include/asm/arch-at91/at91sam9x5.h +++ b/arch/arm/include/asm/arch-at91/at91sam9x5.h @@ -154,6 +154,8 @@ #define ATMEL_PIO_PORTS 4 #define CPU_HAS_PIO3 #define PIO_SCDR_DIV (0x3fff << 0) /* Slow Clock Divider Mask */ +#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP +#define ATMEL_ID_UHP ATMEL_ID_UHPHS
/* * at91sam9x5 specific prototypes diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index edb0886..8773e6f 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -295,6 +295,9 @@ int board_init(void) at91_macb_hw_init(); #endif
+#if defined(CONFIG_USB_OHCI_NEW) || defined(CONFIG_USB_EHCI) + at91_uhp_hw_init(); +#endif #ifdef CONFIG_LCD at91sam9x5ek_lcd_hw_init(); #endif diff --git a/drivers/usb/host/ohci-at91.c b/drivers/usb/host/ohci-at91.c index 9532dd9..efd711d 100644 --- a/drivers/usb/host/ohci-at91.c +++ b/drivers/usb/host/ohci-at91.c @@ -41,7 +41,8 @@ int usb_cpu_init(void) writel(get_pllb_init(), &pmc->pllbr); while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != AT91_PMC_LOCKB) ; -#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) +#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) || \ + defined(CONFIG_AT91SAM9X5) /* Enable UPLL */ writel(readl(&pmc->uckr) | AT91_PMC_UPLLEN | AT91_PMC_BIASEN, &pmc->uckr); @@ -81,7 +82,8 @@ int usb_cpu_stop(void) writel(0, &pmc->pllbr); while ((readl(&pmc->sr) & AT91_PMC_LOCKB) != 0) ; -#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) +#elif defined(CONFIG_AT91SAM9G45) || defined(CONFIG_AT91SAM9M10G45) || \ + defined(CONFIG_AT91SAM9X5) /* Disable UPLL */ writel(readl(&pmc->uckr) & (~AT91_PMC_UPLLEN), &pmc->uckr); while ((readl(&pmc->sr) & AT91_PMC_LOCKU) == AT91_PMC_LOCKU)
Hi Richard,
- /* Enable VBus on UHP ports */
- at91_set_pio_output(AT91_PIO_PORTD, 18, 0); /* port A */
- at91_set_pio_output(AT91_PIO_PORTD, 19, 0); /* port B */
- at91_set_pio_output(AT91_PIO_PORTD, 20, 0); /* port C */
+} +#endif
As port C doesn't support EHCI, so, I think we should deal with this carefully. ---<8--- #if OHCI #else EHCI #endif --->8--- I think this will be better.
Best Regards Bo Shen
2012/11/29 Bo Shen voice.shen@atmel.com: Hi !
yes, you're right, I'll change that
Signed-off-by: Richard Genoud richard.genoud@gmail.com --- include/configs/at91sam9x5ek.h | 6 +++++- 1 files changed, 5 insertions(+), 1 deletions(-)
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 71f765b..5e5f9c1 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -90,6 +90,7 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_SF #define CONFIG_CMD_MMC +#define CONFIG_CMD_FAT
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 @@ -142,9 +143,12 @@ /* MMC */ #ifdef CONFIG_CMD_MMC #define CONFIG_MMC -#define CONFIG_CMD_FAT #define CONFIG_GENERIC_MMC #define CONFIG_GENERIC_ATMEL_MCI +#endif + +/* FAT */ +#ifdef CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION #endif
Signed-off-by: Richard Genoud richard.genoud@gmail.com --- include/configs/at91sam9x5ek.h | 24 ++++++++++++++++++++++++ 1 files changed, 24 insertions(+), 0 deletions(-)
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index 5e5f9c1..fd2586d 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -91,6 +91,14 @@ #define CONFIG_CMD_SF #define CONFIG_CMD_MMC #define CONFIG_CMD_FAT +#define CONFIG_CMD_USB + +/* + * define CONFIG_USB_EHCI to enable USB Hi-Speed (aka 2.0) + * NB: in this case, USB 1.1 devices won't be recognized. + */ +#undef CONFIG_USB_EHCI +
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 @@ -158,6 +166,22 @@ #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_MACB_SEARCH_PHY
+/* USB */ +#ifdef CONFIG_CMD_USB +#ifdef CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_ATMEL +#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 +#else +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_CPU_INIT +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00600000 /* ATMEL_BASE_OHCI */ +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9x5" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 +#endif +#define CONFIG_USB_ATMEL +#define CONFIG_USB_STORAGE +#endif + #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE
- define CONFIG_USB_EHCI to enable USB Hi-Speed (aka 2.0)
- NB: in this case, USB 1.1 devices won't be recognized.
Nowhere defined it, so no need undefined it.
This has defined in arch/arm/include/asm/arch-at91/at91sam9x5.h. You can use it directly.
Bo Shen
Richard Genoud
