[U-Boot-Users] Run Linux kernel from within a JFFS2 filesystem
Hi all,
this is my first post in this mailing list. I hope I don't start with a FAQ.
On my board I have installed U-Boot and I'm able to run Linux kernel and rootfs via Flash/Flash (ramdisk/image file) or TFTP/NFS.
Of course, either ramdisk and nfs aren't suitable for my end application (ramdisk losts many RAM space and NFS won't be available).
So I'd like to use a local root filesystem stored in the NOR Flash (a J30 Intel), starting from the small ramdisk I have and adding all software I need.
I could divide my Flash memory in three partitions: - U-Boot bootloader (with the two sectors for its configuration) - Linux kernel image - JFFS2 root filesystem
But I want to go futher and I want to save the linux kernel image file into the root JFFS2 filesystem. So I'll have only two main partitions: - U-Boot bootloader (...) - JFFS2 root filesystem (with linuk kernel image file saved inside)
Is U-Boot able to run a kernel image file that is saved into a JFFS2 filesystem stored in the Flash? I think this is what happens on a desktop computer (where the bootloader is Grub and the root filesystem is on a hard-disk and the kernel is a file saved into it).
I think it isn't so simple for U-Boot that is capable of running the application (linux kernel in my case) only at a specified memory address (it doesn't have any knowledge about JFFS2 filesystem, do it?).
Many thanks for your comments and my compliments for the good work!
Giuseppe
Ciao Pesà,
U-Boot can load an image from a jffs2 fs using the fsload command:
fsload DEST_ADDR imagename
Furthermore, you need to properly define the mtdpart and mtdids environment vars or define the opportune #define, like this:
#define MTDIDS_DEFAULT "nor0=phys_mapped_flash" #define MTDPARTS_DEFAULT "mtdparts=phys_mapped_flash:2M(jffs2),10M(root)ro,2M(u-boot)ro,2M(kernel)ro"
ciao,
luigi
Il giorno sab, 14/06/2008 alle 11.48 +0200, Giuseppe Modugno ha scritto:
Hi all,
Giuseppe
Check out the new SourceForge.net Marketplace. It's the best place to buy or sell services for just about anything Open Source. http://sourceforge.net/services/buy/index.php _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Ing. Luigi Mantellini Industrie Dial Face S.p.A. Via Canzo, 4 20068 Peschiera Borromeo (MI) Tel.: +39 02 5167 2813 Fax: +39 02 5167 2459 E-mail: luigi.mantellini@idf-hit.com
Giuseppe Modugno
Luigi 'Comio' Mantellini
