[U-Boot] [PATCH] efi_loader: Disable env_save() call on boot
With the introduction of EFI variable support, we also wanted to persist these EFI variables. However, the way it was implemented we ended up persisting all U-Boot environment variables on every EFI boot.
That could potentially lead to unexpected side effects because variables that were not supposed to be written to persisted env get written. It also means we may end up writing the environment more often than we should.
For this release, let's just disable EFI variable persistence and instead implement it properly for the next one.
Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de Fixes: ad644e7c182 ("efi_loader: efi variable support") Signed-off-by: Alexander Graf agraf@suse.de --- lib/efi_loader/efi_boottime.c | 5 +---- 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index f627340de4..743b84864f 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1439,10 +1439,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(void *image_handle, /* Make sure that notification functions are not called anymore */ efi_tpl = TPL_HIGH_LEVEL;
-#if defined(CONFIG_CMD_SAVEENV) && !defined(CONFIG_ENV_IS_NOWHERE) - /* save any EFI variables that have been written: */ - env_save(); -#endif + /* XXX Should persist EFI variables here */
board_quiesce_devices();
Acked-by: Rob Clark robdclark@gmail.com
env_save();
-#endif
/* XXX Should persist EFI variables here */ board_quiesce_devices();
-- 2.12.3
- env_save();
-#endif
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Reported-by: Heinrich Schuchardt xypron.glpk@gmx.de Fixes: ad644e7c182 ("efi_loader: efi variable support") Signed-off-by: Alexander Graf agraf@suse.de Acked-by: Rob Clark robdclark@gmail.com Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de
Alexander Graf
Rob Clark
