[U-Boot] [PATCH 1/1] common: fb_nand: won't compile
Somehow this got overlooked when getting rid of nand_info.
Small patch, won't affect anything else, no reason to wait for the next cycle.
Signed-off-by: Sergey Kubushyn ksi@koi8.net --- diff --git a/common/fb_nand.c b/common/fb_nand.c index e55ea38..ae34f48 100644 --- a/common/fb_nand.c +++ b/common/fb_nand.c @@ -34,7 +34,7 @@ __weak int board_fastboot_write_partition_setup(char *name) }
static int fb_nand_lookup(const char *partname, char *response, - struct mtd_info **nand, + struct mtd_info **mtd, struct part_info **part) { struct mtd_device *dev;
--- ****************************************************************** * KSI@home KOI8 Net < > The impossible we do immediately. * * Las Vegas NV, USA < > Miracles require 24-hour notice. * ******************************************************************
"Somehow" would be that there is no board that enables this code in order to get build coverage...
-Scott
Scott Wood
Sergey Kubushyn
