[PATCH v2] serial: zynq: Add support for serial parameters
This adds serial parameters that include stop bit mode, parity mode, and character length. Mark parity and space parity modes are not supported.
At the moment, the only path to call setconfig directly is DM testing, however, this affects the size of SPL for DM testing, so it doesn't apply to SPL.
Signed-off-by: Kunihiko Hayashi hayashi.kunihiko@socionext.com --- drivers/serial/serial_zynq.c | 68 ++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 68 insertions(+)
diff --git a/drivers/serial/serial_zynq.c b/drivers/serial/serial_zynq.c index 799d524..2f49f59 100644 --- a/drivers/serial/serial_zynq.c +++ b/drivers/serial/serial_zynq.c @@ -28,7 +28,17 @@ #define ZYNQ_UART_CR_TXRST BIT(1) /* TX logic reset */ #define ZYNQ_UART_CR_RXRST BIT(0) /* RX logic reset */
+#define ZYNQ_UART_MR_STOPMODE_2_BIT 0x00000080 /* 2 stop bits */ +#define ZYNQ_UART_MR_STOPMODE_1_5_BIT 0x00000040 /* 1.5 stop bits */ +#define ZYNQ_UART_MR_STOPMODE_1_BIT 0x00000000 /* 1 stop bit */ + #define ZYNQ_UART_MR_PARITY_NONE 0x00000020 /* No parity mode */ +#define ZYNQ_UART_MR_PARITY_ODD 0x00000008 /* Odd parity mode */ +#define ZYNQ_UART_MR_PARITY_EVEN 0x00000000 /* Even parity mode */ + +#define ZYNQ_UART_MR_CHARLEN_6_BIT 0x00000006 /* 6 bits data */ +#define ZYNQ_UART_MR_CHARLEN_7_BIT 0x00000004 /* 7 bits data */ +#define ZYNQ_UART_MR_CHARLEN_8_BIT 0x00000000 /* 8 bits data */
struct uart_zynq { u32 control; /* 0x0 - Control Register [8:0] */ @@ -137,6 +147,63 @@ static int zynq_serial_setbrg(struct udevice *dev, int baudrate) return 0; }
+#if !defined(CONFIG_SPL_BUILD) +static int zynq_serial_setconfig(struct udevice *dev, uint serial_config) +{ + struct zynq_uart_plat *plat = dev_get_plat(dev); + struct uart_zynq *regs = plat->regs; + u32 val = 0; + + switch (SERIAL_GET_BITS(serial_config)) { + case SERIAL_6_BITS: + val |= ZYNQ_UART_MR_CHARLEN_6_BIT; + break; + case SERIAL_7_BITS: + val |= ZYNQ_UART_MR_CHARLEN_7_BIT; + break; + case SERIAL_8_BITS: + val |= ZYNQ_UART_MR_CHARLEN_8_BIT; + break; + default: + return -ENOTSUPP; /* not supported in driver */ + } + + switch (SERIAL_GET_STOP(serial_config)) { + case SERIAL_ONE_STOP: + val |= ZYNQ_UART_MR_STOPMODE_1_BIT; + break; + case SERIAL_ONE_HALF_STOP: + val |= ZYNQ_UART_MR_STOPMODE_1_5_BIT; + break; + case SERIAL_TWO_STOP: + val |= ZYNQ_UART_MR_STOPMODE_2_BIT; + break; + default: + return -ENOTSUPP; /* not supported in driver */ + } + + switch (SERIAL_GET_PARITY(serial_config)) { + case SERIAL_PAR_NONE: + val |= ZYNQ_UART_MR_PARITY_NONE; + break; + case SERIAL_PAR_ODD: + val |= ZYNQ_UART_MR_PARITY_ODD; + break; + case SERIAL_PAR_EVEN: + val |= ZYNQ_UART_MR_PARITY_EVEN; + break; + default: + return -ENOTSUPP; /* not supported in driver */ + } + + writel(val, ®s->mode); + + return 0; +} +#else +#define zynq_serial_setconfig NULL +#endif + static int zynq_serial_probe(struct udevice *dev) { struct zynq_uart_plat *plat = dev_get_plat(dev); @@ -198,6 +265,7 @@ static const struct dm_serial_ops zynq_serial_ops = { .pending = zynq_serial_pending, .getc = zynq_serial_getc, .setbrg = zynq_serial_setbrg, + .setconfig = zynq_serial_setconfig, };
static const struct udevice_id zynq_serial_ids[] = {
- struct zynq_uart_plat *plat = dev_get_plat(dev);
- struct uart_zynq *regs = plat->regs;
- u32 val = 0;
- switch (SERIAL_GET_BITS(serial_config)) {
- case SERIAL_6_BITS:
break;
- case SERIAL_7_BITS:
break;
- case SERIAL_8_BITS:
break;
- default:
- switch (SERIAL_GET_STOP(serial_config)) {
- case SERIAL_ONE_STOP:
break;
- case SERIAL_ONE_HALF_STOP:
break;
- case SERIAL_TWO_STOP:
break;
- default:
- switch (SERIAL_GET_PARITY(serial_config)) {
- case SERIAL_PAR_NONE:
break;
- case SERIAL_PAR_ODD:
break;
- case SERIAL_PAR_EVEN:
break;
- default:
- writel(val, ®s->mode);
- .setconfig = zynq_serial_setconfig,
Applied. M
Kunihiko Hayashi
Michal Simek
