[PATCH v2 0/7] arm64: dts: imx8mm: add common -binman.dtsi and further clean-up
With the move to using binman to generate SPL aka u-boot-spl-ddr.bin and U-Boot proper aka u-boot.itb every board now covers such configuration in its own U-Boot specific device tree include. Move the comon part of that configuration to the common imx8mm-u-boot.dtsi include file.
The initial patch fixes an issue with intermediate binary naming for the imx8mm-cl-iot-gate. And subsequent patches further clean up that dtsi.
This series is based on Peng's binman conversion of late [1], my Verdin iMX8M Mini target refresh [2], Fabio's generating a single bootable flash.bin again for imx8mm-evk [3] and Tim's switching imx8mm_venice to using binman to pack images [4].
This series has been run-time tested on Verdin iMX8M Mini. The other targets were only compile tested.
[1] https://marc.info/?l=u-boot&m=163366377832026 [2] https://marc.info/?l=u-boot&m=163365299927718 [3] https://marc.info/?l=u-boot&m=162972343709264 [4] https://marc.info/?l=u-boot&m=162983187605276
Changes in v2: - New patch preparing cl-iot-gate. - Morph common binman dtsi into regular common u-boot dtsi as discussed on mailing list. - Re-based. - Rather than doing that clean-up to the separate binman dtsi now do it to the common u-boot dtsi one.
Changes in v1: - This was suggested by Simon on my earlier patch set upon which we decided to first break this up into a common binman dtsi and then subsequently do such further improvements.
Marcel Ziswiler (7): imx8mm-cl-iot-gate: fix imximage intermediate binary naming arm64: dts: imx8mm-cl-iot-gate-u-boot.dtsi: alphabetically re-order arm64: dts: imx8mm-cl-iot-gate-u-boot.dtsi: use common imx8mm-u-boot.dtsi arm64: dts: imx8mm: use common binman configuration arm64: dts: imx8mm-u-boot.dtsi: alphabetically re-order properties arm64: dts: imx8mm-u-boot.dtsi: explicitly add spl filename arm64: dts: imx8mm-u-boot.dtsi: improve odd blob-ext naming
.../dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi | 209 ++++-------------- arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 188 +++------------- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 123 ----------- arch/arm/dts/imx8mm-u-boot.dtsi | 149 ++++++++++++- arch/arm/dts/imx8mm-venice-u-boot.dtsi | 119 ---------- arch/arm/dts/imx8mm-verdin-u-boot.dtsi | 122 +--------- .../imximage-8mm-lpddr4.cfg | 2 +- 7 files changed, 212 insertions(+), 700 deletions(-)
This fixes the following build time issue:
... BINMAN all binman: Error 1 running 'mkimage -d ./mkimage.spl.mkimage -n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000 ./mkimage-out.spl.mkimage': mkimage.flash.mkimage: Can't open: No such file or directory
make: *** [Makefile:1094: all] Error 1
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
(no changes since v1)
board/compulab/imx8mm-cl-iot-gate/imximage-8mm-lpddr4.cfg | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/compulab/imx8mm-cl-iot-gate/imximage-8mm-lpddr4.cfg b/board/compulab/imx8mm-cl-iot-gate/imximage-8mm-lpddr4.cfg index b89092a5590..4071219fbf4 100644 --- a/board/compulab/imx8mm-cl-iot-gate/imximage-8mm-lpddr4.cfg +++ b/board/compulab/imx8mm-cl-iot-gate/imximage-8mm-lpddr4.cfg @@ -6,4 +6,4 @@ #define __ASSEMBLY__
BOOT_FROM sd -LOADER mkimage.flash.mkimage 0x7E1000 +LOADER u-boot-spl-ddr.bin 0x7e1000
Alphabetically re-order nodes and properties.
.../dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi | 202 +++++++++--------- arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 202 +++++++++--------- 2 files changed, 202 insertions(+), 202 deletions(-)
diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi index 12065935e49..67ce70d0bdf 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi @@ -8,18 +8,18 @@ multiple-images; };
- wdt-reboot { - compatible = "wdt-reboot"; - wdt = <&wdog1>; - u-boot,dm-spl; - }; - firmware { optee { compatible = "linaro,optee-tz"; method = "smc"; }; }; + + wdt-reboot { + compatible = "wdt-reboot"; + u-boot,dm-spl; + wdt = <&wdog1>; + }; };
&{/soc@0} { @@ -27,17 +27,12 @@ u-boot,dm-spl; };
-&clk { +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b} { u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; };
-&osc_24m { +&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b/regulators} { u-boot,dm-spl; - u-boot,dm-pre-reloc; };
&aips1 { @@ -53,94 +48,6 @@ u-boot,dm-spl; };
-&iomuxc { - u-boot,dm-spl; -}; - -&pinctrl_uart3 { - u-boot,dm-spl; -}; - -&pinctrl_usdhc2_gpio { - u-boot,dm-spl; -}; - -&pinctrl_usdhc2 { - u-boot,dm-spl; -}; - -&pinctrl_usdhc3 { - u-boot,dm-spl; -}; - -&gpio1 { - u-boot,dm-spl; -}; - -&gpio2 { - u-boot,dm-spl; -}; - -&gpio3 { - u-boot,dm-spl; -}; - -&gpio4 { - u-boot,dm-spl; -}; - -&gpio5 { - u-boot,dm-spl; -}; - -&uart3 { - u-boot,dm-spl; -}; - -&usdhc1 { - u-boot,dm-spl; -}; - -&usdhc2 { - u-boot,dm-spl; -}; - -&usdhc3 { - u-boot,dm-spl; -}; - -&i2c1 { - u-boot,dm-spl; -}; - -&i2c2 { - u-boot,dm-spl; -}; - -&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b} { - u-boot,dm-spl; -}; - -&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b/regulators} { - u-boot,dm-spl; -}; - -&pinctrl_i2c2 { - u-boot,dm-spl; -}; - -&pinctrl_pmic { - u-boot,dm-spl; -}; - -&fec1 { - phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; -}; - -&wdog1 { - u-boot,dm-spl; -}; - &binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; @@ -253,3 +160,96 @@ }; }; }; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&fec1 { + phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&pinctrl_i2c2 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +}; diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi index 00927c15744..fe45a35d751 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -8,18 +8,18 @@ multiple-images; };
-&iomuxc { - u-boot,dm-spl; -}; - -&pinctrl_uart3 { - u-boot,dm-spl; -}; - -&pinctrl_usdhc2_gpio { - u-boot,dm-spl; -}; - -&pinctrl_usdhc2 { - u-boot,dm-spl; -}; - -&pinctrl_usdhc3 { - u-boot,dm-spl; -}; - -&gpio1 { - u-boot,dm-spl; -}; - -&gpio2 { - u-boot,dm-spl; -}; - -&gpio3 { - u-boot,dm-spl; -}; - -&gpio4 { - u-boot,dm-spl; -}; - -&gpio5 { - u-boot,dm-spl; -}; - -&uart3 { - u-boot,dm-spl; -}; - -&usdhc1 { - u-boot,dm-spl; -}; - -&usdhc2 { - u-boot,dm-spl; -}; - -&usdhc3 { - u-boot,dm-spl; -}; - -&i2c1 { - u-boot,dm-spl; -}; - -&i2c2 { - u-boot,dm-spl; -}; - -&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b} { - u-boot,dm-spl; -}; - -&{/soc@0/bus@30800000/i2c@30a30000/pmic@4b/regulators} { - u-boot,dm-spl; -}; - -&pinctrl_i2c2 { - u-boot,dm-spl; -}; - -&pinctrl_pmic { - u-boot,dm-spl; -}; - -&fec1 { - phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; -}; - -&wdog1 { - u-boot,dm-spl; -}; - &binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; @@ -241,3 +148,96 @@ }; }; }; + +&clk { + u-boot,dm-spl; + u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; +}; + +&fec1 { + phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&gpio2 { + u-boot,dm-spl; +}; + +&gpio3 { + u-boot,dm-spl; +}; + +&gpio4 { + u-boot,dm-spl; +}; + +&gpio5 { + u-boot,dm-spl; +}; + +&i2c1 { + u-boot,dm-spl; +}; + +&i2c2 { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&osc_24m { + u-boot,dm-spl; + u-boot,dm-pre-reloc; +}; + +&pinctrl_i2c2 { + u-boot,dm-spl; +}; + +&pinctrl_pmic { + u-boot,dm-spl; +}; + +&pinctrl_uart3 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2 { + u-boot,dm-spl; +}; + +&pinctrl_usdhc2_gpio { + u-boot,dm-spl; +}; + +&pinctrl_usdhc3 { + u-boot,dm-spl; +}; + +&uart3 { + u-boot,dm-spl; +}; + +&usdhc1 { + u-boot,dm-spl; +}; + +&usdhc2 { + u-boot,dm-spl; +}; + +&usdhc3 { + u-boot,dm-spl; +}; + +&wdog1 { + u-boot,dm-spl; +};
Use common imx8mm-u-boot.dtsi.
.../dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi | 37 +------------------ arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 37 +------------------ 2 files changed, 4 insertions(+), 70 deletions(-)
diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi index 67ce70d0bdf..bc8a138e6c0 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2019 NXP */
+#include "imx8mm-u-boot.dtsi" + / { binman: binman { multiple-images; @@ -22,11 +24,6 @@ }; };
-&{/soc@0} { - u-boot,dm-pre-reloc; - u-boot,dm-spl; -}; - &{/soc@0/bus@30800000/i2c@30a30000/pmic@4b} { u-boot,dm-spl; }; @@ -35,19 +32,6 @@ u-boot,dm-spl; };
-&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - &binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; @@ -161,14 +145,6 @@ }; };
-&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - &fec1 { phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; }; @@ -201,15 +177,6 @@ u-boot,dm-spl; };
-&iomuxc { - u-boot,dm-spl; -}; - -&osc_24m { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - &pinctrl_i2c2 { u-boot,dm-spl; }; diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi index fe45a35d751..cf3cc191d5a 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2019 NXP */
-&aips1 { - u-boot,dm-spl; - u-boot,dm-pre-reloc; -}; - -&aips2 { - u-boot,dm-spl; -}; - -&aips3 { - u-boot,dm-spl; -}; - &binman { u-boot-spl-ddr { filename = "u-boot-spl-ddr.bin"; @@ -149,14 +133,6 @@ }; };
-&clk { - u-boot,dm-spl; - u-boot,dm-pre-reloc; - /delete-property/ assigned-clocks; - /delete-property/ assigned-clock-parents; - /delete-property/ assigned-clock-rates; -}; - &fec1 { phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; }; @@ -189,15 +165,6 @@ u-boot,dm-spl; };
Changes in v2: - Morph common binman dtsi into regular common u-boot dtsi as discussed on mailing list. - Re-based.
.../dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi | 124 ++-------------- arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi | 105 -------------- arch/arm/dts/imx8mm-evk-u-boot.dtsi | 123 ---------------- arch/arm/dts/imx8mm-u-boot.dtsi | 133 ++++++++++++++++++ arch/arm/dts/imx8mm-venice-u-boot.dtsi | 119 ---------------- arch/arm/dts/imx8mm-verdin-u-boot.dtsi | 122 +--------------- 6 files changed, 147 insertions(+), 579 deletions(-)
diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi index bc8a138e6c0..5cbc70faaaf 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-optee-u-boot.dtsi @@ -6,10 +6,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - binman: binman { - multiple-images; - }; - firmware { optee { compatible = "linaro,optee-tz"; @@ -32,117 +28,21 @@ u-boot,dm-spl; };
-&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - blob_1: blob-ext@1 { - filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; - }; - - blob_2: blob-ext@2 { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; - }; - - blob_3: blob-ext@3 { - filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; - }; +&binman_fip { + arch = "arm64"; + compression = "none"; + description = "Trusted Firmware FIP"; + load = <0x40310000>; + type = "firmware";
- blob_4: blob-ext@4 { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; - }; - }; - - flash { - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; + fip_blob { + filename = "fip.bin"; + type = "blob-ext"; }; +};
- itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SYS_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x920000>; - entry = <0x920000>; - - atf_blob: blob-ext { - filename = "bl2.bin"; - }; - }; - - fip { - description = "Trusted Firmware FIP"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x40310000>; - - fip_blob: blob-ext{ - filename = "fip.bin"; - }; - }; - - fdt { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - - uboot_fdt_blob: blob-ext { - filename = "u-boot.dtb"; - }; - }; - }; - - configurations { - default = "conf"; - - conf { - description = "NAME"; - firmware = "uboot"; - loadables = "atf", "fip"; - fdt = "fdt"; - }; - }; - }; - }; +&binman_configuration { + loadables = "atf", "fip"; };
&fec1 { diff --git a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi index cf3cc191d5a..433b02cceee 100644 --- a/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-cl-iot-gate-u-boot.dtsi @@ -6,10 +6,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - binman: binman { - multiple-images; - }; - firmware { optee { compatible = "linaro,optee-tz"; @@ -32,107 +28,6 @@ u-boot,dm-spl; };
-&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - blob_1: blob-ext@1 { - filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; - }; - - blob_2: blob-ext@2 { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; - }; - - blob_3: blob-ext@3 { - filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; - }; - - blob_4: blob-ext@4 { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; - }; - }; - - flash { - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; - }; - - itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SYS_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x920000>; - entry = <0x920000>; - - atf_blob: blob-ext { - filename = "bl31.bin"; - }; - }; - - fdt { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - - uboot_fdt_blob: blob-ext { - filename = "u-boot.dtb"; - }; - }; - }; - - configurations { - default = "conf"; - - conf { - description = "NAME"; - firmware = "uboot"; - loadables = "atf"; - fdt = "fdt"; - }; - }; - }; - }; -}; - &fec1 { phy-reset-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; }; diff --git a/arch/arm/dts/imx8mm-evk-u-boot.dtsi b/arch/arm/dts/imx8mm-evk-u-boot.dtsi index 3c75415e8fb..6b459831e74 100644 --- a/arch/arm/dts/imx8mm-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-evk-u-boot.dtsi @@ -6,10 +6,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - binman: binman { - multiple-images; - }; - wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>; @@ -116,122 +112,3 @@ &wdog1 { u-boot,dm-spl; }; - -&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - blob_1: blob-ext@1 { - filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; - }; - - blob_2: blob-ext@2 { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; - }; - - blob_3: blob-ext@3 { - filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; - }; - - blob_4: blob-ext@4 { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; - }; - }; - - - spl { - filename = "spl.bin"; - - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; - }; - - itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SYS_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x920000>; - entry = <0x920000>; - - atf_blob: blob-ext { - filename = "bl31.bin"; - }; - }; - - fdt { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - - uboot_fdt_blob: blob-ext { - filename = "u-boot.dtb"; - }; - }; - }; - - configurations { - default = "conf"; - - conf { - description = "NAME"; - firmware = "uboot"; - loadables = "atf"; - fdt = "fdt"; - }; - }; - }; - }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - - spl: blob-ext@1 { - offset = <0x0>; - filename = "spl.bin"; - }; - - uboot: blob-ext@2 { - offset = <0x57c00>; - filename = "u-boot.itb"; - }; - }; -}; diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index f833d9df59b..5020255fa0f 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -3,6 +3,12 @@ * Copyright (C) 2020 Jagan Teki jagan@amarulasolutions.com */
+/ { + binman: binman { + multiple-images; + }; +}; + &{/soc@0} { u-boot,dm-pre-reloc; u-boot,dm-spl; @@ -21,6 +27,133 @@ u-boot,dm-spl; };
+&binman { + u-boot-spl-ddr { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>; + + u-boot-spl { + align-end = <4>; + }; + + blob_1: blob-ext@1 { + filename = "lpddr4_pmu_train_1d_imem.bin"; + size = <0x8000>; + }; + + blob_2: blob-ext@2 { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + size = <0x4000>; + }; + + blob_3: blob-ext@3 { + filename = "lpddr4_pmu_train_2d_imem.bin"; + size = <0x8000>; + }; + + blob_4: blob-ext@4 { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + size = <0x4000>; + }; + }; + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + fit,fdt-list = "of-list"; + + images { + uboot { + description = "U-Boot (64-bit)"; + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SYS_TEXT_BASE>; + + uboot_blob: blob-ext { + filename = "u-boot-nodtb.bin"; + }; + }; + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x920000>; + entry = <0x920000>; + + atf_blob: blob-ext { + filename = "bl31.bin"; + }; + }; + + binman_fip: fip { + description = "Trusted Firmware FIP"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x40310000>; + }; + + @fdt-SEQ { + description = "NAME"; + type = "flat_dt"; + compression = "none"; + + uboot_fdt_blob: blob-ext { + filename = "u-boot.dtb"; + }; + }; + }; + + configurations { + default = "@config-DEFAULT-SEQ"; + + binman_configuration: @config-SEQ { + description = "NAME"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt-SEQ"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "spl.bin"; + }; + + binman_uboot: blob-ext@2 { + offset = <0x57c00>; + filename = "u-boot.itb"; + }; + }; +}; + &clk { u-boot,dm-spl; u-boot,dm-pre-reloc; diff --git a/arch/arm/dts/imx8mm-venice-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-u-boot.dtsi index e0fa9ff4bfc..42b2903f040 100644 --- a/arch/arm/dts/imx8mm-venice-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-u-boot.dtsi @@ -6,10 +6,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - binman: binman { - multiple-images; - }; - wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>; @@ -72,118 +68,3 @@ &wdog1 { u-boot,dm-spl; }; - -&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - blob_1: blob-ext@1 { - filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; - }; - - blob_2: blob-ext@2 { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; - }; - - blob_3: blob-ext@3 { - filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; - }; - - blob_4: blob-ext@4 { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; - }; - }; - - spl { - filename = "spl.bin"; - - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; - }; - - itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - fit,fdt-list = "of-list"; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SYS_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x920000>; - entry = <0x920000>; - - atf_blob: blob-ext { - filename = "bl31.bin"; - }; - }; - - @fdt-SEQ { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - }; - }; - - configurations { - default = "@config-DEFAULT-SEQ"; - - @config-SEQ { - description = "NAME"; - firmware = "uboot"; - loadables = "atf"; - fdt = "fdt-SEQ"; - }; - }; - }; - }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - - spl: blob-ext@1 { - filename = "spl.bin"; - offset = <0x0>; - }; - - uboot: blob-ext@2 { - filename = "u-boot.itb"; - offset = <0x57c00>; - }; - }; -}; diff --git a/arch/arm/dts/imx8mm-verdin-u-boot.dtsi b/arch/arm/dts/imx8mm-verdin-u-boot.dtsi index bf47930c36f..c50f2b01d4e 100644 --- a/arch/arm/dts/imx8mm-verdin-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-verdin-u-boot.dtsi @@ -6,10 +6,6 @@ #include "imx8mm-u-boot.dtsi"
/ { - binman: binman { - multiple-images; - }; - firmware { optee { compatible = "linaro,optee-tz"; @@ -100,120 +96,6 @@ u-boot,dm-spl; };
-&binman { - u-boot-spl-ddr { - filename = "u-boot-spl-ddr.bin"; - pad-byte = <0xff>; - align-size = <4>; - align = <4>; - - u-boot-spl { - align-end = <4>; - }; - - blob_1: blob-ext@1 { - filename = "lpddr4_pmu_train_1d_imem.bin"; - size = <0x8000>; - }; - - blob_2: blob-ext@2 { - filename = "lpddr4_pmu_train_1d_dmem.bin"; - size = <0x4000>; - }; - - blob_3: blob-ext@3 { - filename = "lpddr4_pmu_train_2d_imem.bin"; - size = <0x8000>; - }; - - blob_4: blob-ext@4 { - filename = "lpddr4_pmu_train_2d_dmem.bin"; - size = <0x4000>; - }; - }; - - spl { - filename = "spl.bin"; - - mkimage { - args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x7e1000"; - - blob { - filename = "u-boot-spl-ddr.bin"; - }; - }; - }; - - itb { - filename = "u-boot.itb"; - - fit { - description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; - fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; - - images { - uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; - arch = "arm64"; - compression = "none"; - load = <CONFIG_SYS_TEXT_BASE>; - - uboot_blob: blob-ext { - filename = "u-boot-nodtb.bin"; - }; - }; - - atf { - description = "ARM Trusted Firmware"; - type = "firmware"; - arch = "arm64"; - compression = "none"; - load = <0x920000>; - entry = <0x920000>; - - atf_blob: blob-ext { - filename = "bl31.bin"; - }; - }; - - fdt { - description = "NAME"; - type = "flat_dt"; - compression = "none"; - - uboot_fdt_blob: blob-ext { - filename = "u-boot.dtb"; - }; - }; - }; - - configurations { - default = "conf"; - - conf { - description = "NAME"; - firmware = "uboot"; - loadables = "atf"; - fdt = "fdt"; - }; - }; - }; - }; - - imx-boot { - filename = "flash.bin"; - pad-byte = <0x00>; - - spl: blob-ext@1 { - offset = <0x0>; - filename = "spl.bin"; - }; - - uboot: blob-ext@2 { - offset = <0x5fc00>; - filename = "u-boot.itb"; - }; - }; +&binman_uboot { + offset = <0x5fc00>; };
Alphabetically re-order properties.
Changes in v2: - Rather than doing that clean-up to the separate binman dtsi now do it to the common u-boot dtsi one.
arch/arm/dts/imx8mm-u-boot.dtsi | 34 ++++++++++++++++----------------- 1 file changed, 17 insertions(+), 17 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 5020255fa0f..770282d2b98 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -15,8 +15,8 @@ };
&aips1 { - u-boot,dm-spl; u-boot,dm-pre-reloc; + u-boot,dm-spl; };
&aips2 { @@ -29,10 +29,10 @@
&binman { u-boot-spl-ddr { + align = <4>; + align-size = <4>; filename = "u-boot-spl-ddr.bin"; pad-byte = <0xff>; - align-size = <4>; - align = <4>;
u-boot-spl { align-end = <4>; @@ -76,17 +76,17 @@
fit { description = "Configuration to load ATF before U-Boot"; - #address-cells = <1>; fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; fit,fdt-list = "of-list"; + #address-cells = <1>;
images { uboot { - description = "U-Boot (64-bit)"; - type = "standalone"; arch = "arm64"; compression = "none"; + description = "U-Boot (64-bit)"; load = <CONFIG_SYS_TEXT_BASE>; + type = "standalone";
uboot_blob: blob-ext { filename = "u-boot-nodtb.bin"; @@ -94,12 +94,12 @@ };
atf { - description = "ARM Trusted Firmware"; - type = "firmware"; arch = "arm64"; compression = "none"; - load = <0x920000>; + description = "ARM Trusted Firmware"; entry = <0x920000>; + load = <0x920000>; + type = "firmware";
atf_blob: blob-ext { filename = "bl31.bin"; @@ -107,17 +107,17 @@ };
binman_fip: fip { - description = "Trusted Firmware FIP"; - type = "firmware"; arch = "arm64"; compression = "none"; + description = "Trusted Firmware FIP"; load = <0x40310000>; + type = "firmware"; };
@fdt-SEQ { + compression = "none"; description = "NAME"; type = "flat_dt"; - compression = "none";
uboot_fdt_blob: blob-ext { filename = "u-boot.dtb"; @@ -130,9 +130,9 @@
binman_configuration: @config-SEQ { description = "NAME"; + fdt = "fdt-SEQ"; firmware = "uboot"; loadables = "atf"; - fdt = "fdt-SEQ"; }; }; }; @@ -143,20 +143,20 @@ pad-byte = <0x00>;
spl: blob-ext@1 { - offset = <0x0>; filename = "spl.bin"; + offset = <0x0>; };
binman_uboot: blob-ext@2 { - offset = <0x57c00>; filename = "u-boot.itb"; + offset = <0x57c00>; }; }; };
&clk { - u-boot,dm-spl; u-boot,dm-pre-reloc; + u-boot,dm-spl; /delete-property/ assigned-clocks; /delete-property/ assigned-clock-parents; /delete-property/ assigned-clock-rates; @@ -167,6 +167,6 @@ };
&osc_24m { - u-boot,dm-spl; u-boot,dm-pre-reloc; + u-boot,dm-spl; };
Explicitly add SPL aka u-boot-spl.bin filename.
arch/arm/dts/imx8mm-u-boot.dtsi | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 770282d2b98..8feb0f2592a 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -36,6 +36,7 @@
u-boot-spl { align-end = <4>; + filename = "u-boot-spl.bin"; };
Rather than using odd implicit blob-ext naming, explicitly specify the type to be of blob-ext and therefore also simplify the node naming.
arch/arm/dts/imx8mm-u-boot.dtsi | 27 ++++++++++++++++++--------- 1 file changed, 18 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index 8feb0f2592a..7882fe73167 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -39,24 +39,28 @@ filename = "u-boot-spl.bin"; };
- blob_1: blob-ext@1 { + 1d-imem { filename = "lpddr4_pmu_train_1d_imem.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_2: blob-ext@2 { + 1d_dmem { filename = "lpddr4_pmu_train_1d_dmem.bin"; size = <0x4000>; + type = "blob-ext"; };
- blob_3: blob-ext@3 { + 2d_imem { filename = "lpddr4_pmu_train_2d_imem.bin"; size = <0x8000>; + type = "blob-ext"; };
- blob_4: blob-ext@4 { + 2d_dmem { filename = "lpddr4_pmu_train_2d_dmem.bin"; size = <0x4000>; + type = "blob-ext"; }; };
@@ -89,8 +93,9 @@ load = <CONFIG_SYS_TEXT_BASE>; type = "standalone";
- uboot_blob: blob-ext { + uboot_blob { filename = "u-boot-nodtb.bin"; + type = "blob-ext"; }; };
@@ -102,8 +107,9 @@ load = <0x920000>; type = "firmware";
- atf_blob: blob-ext { + atf_blob { filename = "bl31.bin"; + type = "blob-ext"; }; };
@@ -120,8 +126,9 @@ description = "NAME"; type = "flat_dt";
- uboot_fdt_blob: blob-ext { + uboot_fdt_blob { filename = "u-boot.dtb"; + type = "blob-ext"; }; }; }; @@ -143,14 +150,16 @@ filename = "flash.bin"; pad-byte = <0x00>;
- spl: blob-ext@1 { + spl { filename = "spl.bin"; offset = <0x0>; + type = "blob-ext"; };
- binman_uboot: blob-ext@2 { + binman_uboot: uboot { filename = "u-boot.itb"; offset = <0x57c00>; + type = "blob-ext"; }; }; };
Thanks for the work.
Reviewed-by: Peng Fan peng.fan@nxp.com for the patchset.
[1] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fmarc.info%... [2] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fmarc.info%... [3] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fmarc.info%... [4] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fmarc.info%...
Changes in v2:
- Re-based.
Changes in v1:
Marcel Ziswiler
Peng Fan (OSS)
