[U-Boot] [PATCH] TQM8xx: adjust linker script to grown code size
Some of the previous changes caused the code to grow, which causes errors like
u-boot.lds:76 cannot move location counter backwards (from 4000828c to 40008000)
when building with some older tool chains (like ELDK 4.2). Adjust the linker script to make fit again.
Signed-off-by: Wolfgang Denk wd@denx.de --- board/tqc/tqm8xx/u-boot.lds | 2 -- 1 file changed, 2 deletions(-)
This fixes the autobuilder errors for TQM855L, TQM860L and TQM862L.
diff --git a/board/tqc/tqm8xx/u-boot.lds b/board/tqc/tqm8xx/u-boot.lds index 4f08be6..e905c26 100644 --- a/board/tqc/tqm8xx/u-boot.lds +++ b/board/tqc/tqm8xx/u-boot.lds @@ -43,8 +43,6 @@ SECTIONS drivers/pcmcia/libpcmcia.o (.text.pcmcia_hardware_enable) drivers/rtc/librtc.o (.text*) drivers/misc/libmisc.o (.text*) - *(.text.print_buffer) - *(.text.print_size)
. = DEFINED(env_offset) ? env_offset : .; common/env_embedded.o (.ppcenv*)
Dear Wolfgang Denk,
I ain't no expert, but didn't this happen on TQM85xx ?
Best regards, Marek Vasut
Dear Marek Vasut,
In message 201209271520.33571.marex@denx.de you wrote:
Dear Wolfgang Denk,
No.
TQM85xx is a different issue (here the image size has grown, which would require to change the whole memory map). I'll rather remove these boards.
Dear Wolfgang Denk,
Dear Marek Vasut,
Dear Wolfgang Denk,
No.
But these are important powerpc boards, no ?
