Re: [U-Boot-Users] U-boot on rattler8248 - does not quite run for me
Dear Pete,
please keep the mailing list on Cc:
In message CC3927BD446D8240AE6041EA3AB77EDF023515C7@ES20SNLNT.srn.sandia.gov you wrote:
When I wrote "console" I was referring to the RS232 port on the Rattler8248 board.
When the board boots it prints the following text to the RS232 port. That kind of introductory boot text is sometimes called a "splash screen".
No. With U-Boot, "splash screen" has another meaning; it's something we output on a graphics display (usually LCD). See the docs.
CPU: MPC8248 (HiP7 Rev 14, Mask 1.0 1K50M) at 400 MHz Board: Rattler Rev. @ DRAM: 32 MB
If the board hangs here, it means that your SDRAM initialization is broken; see the FAQ.
Since the rs232 port is working I am adding puts() calls to the code to figure out where things are stalling. This is very slow because I have
Use a debugger?
to burn the flash every compile-test cycle. I'm still learning to use the bdi2000 and I don't have WORKSPACE variable set in the [TARGET] section so flash programming is very slow.
Why the heck don't you use the BDI200 for it's main purpose - as a DEBUG tool?
I guess I need to find where the processor gets lost. I could do that the brute force way by putting puts() calls in the code or I could use gdb on the relocated code. You provide some instruction on using gdb after relocation.
See the manual.
