[U-Boot] [PATCH] mmc: renesas-sdhi: Use priv directly
The dev_get_priv(dev) is used twice in the probe function. Replace the second invocation with priv variable.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Masahiro Yamada yamada.masahiro@socionext.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/mmc/renesas-sdhi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/renesas-sdhi.c b/drivers/mmc/renesas-sdhi.c index ecdb088ac4..f8dc5f57ce 100644 --- a/drivers/mmc/renesas-sdhi.c +++ b/drivers/mmc/renesas-sdhi.c @@ -374,7 +374,7 @@ static int renesas_sdhi_probe(struct udevice *dev) ret = tmio_sd_probe(dev, quirks); #if CONFIG_IS_ENABLED(MMC_HS200_SUPPORT) if (!ret) - renesas_sdhi_reset_tuning(dev_get_priv(dev)); + renesas_sdhi_reset_tuning(priv); #endif return ret; }
