[U-Boot] [PATCH] ARM: tegra: add Colibri T30 board support
This adds board support for the Toradex Colibri T30 module.
Working functions: - SD card boot - eMMC environment and boot - USB host/USB client (on the dual role port) - Network (via ASIX USB)
Signed-off-by: Stefan Agner stefan@agner.ch --- arch/arm/Kconfig | 4 + arch/arm/dts/Makefile | 1 + arch/arm/dts/tegra30-colibri.dts | 84 +++++ arch/arm/include/asm/mach-types.h | 13 + board/toradex/colibri_t30/Makefile | 6 + board/toradex/colibri_t30/colibri_t30.c | 52 +++ .../colibri_t30/pinmux-config-colibri_t30.h | 360 +++++++++++++++++++++ include/configs/colibri_t30.h | 73 +++++ 8 files changed, 593 insertions(+) create mode 100644 arch/arm/dts/tegra30-colibri.dts create mode 100644 board/toradex/colibri_t30/Makefile create mode 100644 board/toradex/colibri_t30/colibri_t30.c create mode 100644 board/toradex/colibri_t30/pinmux-config-colibri_t30.h create mode 100644 include/configs/colibri_t30.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index e385eda..dd987cc 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -701,6 +701,9 @@ config TARGET_WHISTLER config TARGET_COLIBRI_T20_IRIS bool "Support colibri_t20_iris"
+config TARGET_COLIBRI_T30 + bool "Support Colibri T30" + config TARGET_TEC_NG bool "Support tec-ng"
@@ -989,6 +992,7 @@ source "board/timll/devkit3250/Kconfig" source "board/timll/devkit8000/Kconfig" source "board/toradex/colibri_pxa270/Kconfig" source "board/toradex/colibri_t20_iris/Kconfig" +source "board/toradex/colibri_t30/Kconfig" source "board/trizepsiv/Kconfig" source "board/ttcontrol/vision2/Kconfig" source "board/udoo/Kconfig" diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6e2e313..c46b7be 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -21,6 +21,7 @@ dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ tegra20-colibri_t20_iris.dtb \ tegra30-beaver.dtb \ tegra30-cardhu.dtb \ + tegra30-colibri.dtb \ tegra30-tec-ng.dtb \ tegra114-dalmore.dtb \ tegra124-jetson-tk1.dtb \ diff --git a/arch/arm/dts/tegra30-colibri.dts b/arch/arm/dts/tegra30-colibri.dts new file mode 100644 index 0000000..21d0311 --- /dev/null +++ b/arch/arm/dts/tegra30-colibri.dts @@ -0,0 +1,84 @@ +/dts-v1/; + +#include "tegra30.dtsi" + +/ { + model = "Toradex Colibri T30"; + compatible = "toradex,colibri_t30", "nvidia,tegra30"; + + aliases { + i2c0 = "/i2c@7000d000"; + i2c1 = "/i2c@7000c000"; + i2c2 = "/i2c@7000c700"; + sdhci0 = "/sdhci@78000600"; + sdhci1 = "/sdhci@78000200"; + usb0 = "/usb@7d000000"; + usb1 = "/usb@7d004000"; /* on module only, for ASIX */ + usb2 = "/usb@7d008000"; + }; + + memory { + device_type = "memory"; + reg = <0x80000000 0x40000000>; + }; + + /* GEN1_I2C: I2C_SDA/SCL on SODIMM pin 194/196 (e.g. RTC on carrier + board) */ + i2c@7000c000 { + status = "okay"; + clock-frequency = <100000>; + }; + + /* GEN2_I2C: unused */ + + /* CAM_I2C: unused */ + + /* DDC_CLOCK/DATA on X3 pin 15/16 (e.g. display EDID) */ + i2c@7000c700 { + status = "okay"; + clock-frequency = <100000>; + }; + + /* PWR_I2C: power I2C to audio codec, PMIC, temperature sensor and + touch screen controller */ + i2c@7000d000 { + status = "okay"; + clock-frequency = <100000>; + }; + + /* SPI1: Colibri SSP */ + spi@7000d400 { + status = "okay"; + spi-max-frequency = <25000000>; + }; + + sdhci@78000200 { + status = "okay"; + bus-width = <4>; + cd-gpios = <&gpio 23 1>; /* PC7, MMCD */ + }; + + sdhci@78000600 { + status = "okay"; + bus-width = <8>; + non-removable; + }; + + /* EHCI instance 0: USB1_DP/N -> USBC_P/N */ + usb@7d000000 { + status = "okay"; + dr_mode = "otg"; + }; + + /* EHCI instance 1: USB2_DP/N -> AX88772B */ + usb@7d004000 { + status = "okay"; + phy_type = "utmi"; + }; + + /* EHCI instance 2: USB3_DP/N -> USBH_P/N */ + usb@7d008000 { + status = "okay"; + nvidia,vbus-gpio = <&gpio 178 1>; /* PW2, USBH_PEN */ + }; +}; diff --git a/arch/arm/include/asm/mach-types.h b/arch/arm/include/asm/mach-types.h index 440b041..560924e 100644 --- a/arch/arm/include/asm/mach-types.h +++ b/arch/arm/include/asm/mach-types.h @@ -1106,6 +1106,7 @@ extern unsigned int __machine_arch_type; #define MACH_TYPE_OMAP5_SEVM 3777 #define MACH_TYPE_ARMADILLO_800EVA 3863 #define MACH_TYPE_KZM9G 4140 +#define MACH_TYPE_COLIBRI_T30 4493
#ifdef CONFIG_ARCH_EBSA110 # ifdef machine_arch_type @@ -14235,6 +14236,18 @@ extern unsigned int __machine_arch_type; # define machine_is_kzm9g() (0) #endif
+#ifdef CONFIG_MACH_COLIBRI_T30 +# ifdef machine_arch_type +# undef machine_arch_type +# define machine_arch_type __machine_arch_type +# else +# define machine_arch_type MACH_TYPE_COLIBRI_T30 +# endif +# define machine_is_colibri_t30() (machine_arch_type == MACH_TYPE_COLIBRI_T30) +#else +# define machine_is_colibri_t30() (0) +#endif + /* * These have not yet been registered */ diff --git a/board/toradex/colibri_t30/Makefile b/board/toradex/colibri_t30/Makefile new file mode 100644 index 0000000..3d58a4b --- /dev/null +++ b/board/toradex/colibri_t30/Makefile @@ -0,0 +1,6 @@ +# Copyright (c) 2013-2014 Stefan Agner +# SPDX-License-Identifier: GPL-2.0+ + +include $(srctree)/board/nvidia/common/common.mk + +obj-y += colibri_t30.o diff --git a/board/toradex/colibri_t30/colibri_t30.c b/board/toradex/colibri_t30/colibri_t30.c new file mode 100644 index 0000000..6c7c62d --- /dev/null +++ b/board/toradex/colibri_t30/colibri_t30.c @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2014 + * Stefan Agner stefan@agner.ch + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/pinmux.h> +#include <asm/arch/gp_padctrl.h> +#include "pinmux-config-colibri_t30.h" +#include <i2c.h> +#include <asm/gpio.h> + +#define PMU_I2C_ADDRESS 0x2D +#define MAX_I2C_RETRY 3 + +/* + * Routine: pinmux_init + * Description: Do individual peripheral pinmux configs + */ +void pinmux_init(void) +{ + pinmux_config_pingrp_table(tegra3_pinmux_common, + ARRAY_SIZE(tegra3_pinmux_common)); + + pinmux_config_pingrp_table(unused_pins_lowpower, + ARRAY_SIZE(unused_pins_lowpower)); + + /* Initialize any non-default pad configs (APB_MISC_GP regs) */ + pinmux_config_drvgrp_table(colibri_t30_padctrl, + ARRAY_SIZE(colibri_t30_padctrl)); +} + +/* + * Enable AX88772B USB to LAN controller + */ +void pin_mux_usb(void) +{ + /* Enable LAN_VBUS */ + gpio_request(GPIO_PDD2, NULL); + gpio_direction_output(GPIO_PDD2, 1); + + /* Reset ASIX using LAN_RESET */ + gpio_request(GPIO_PDD0, NULL); + gpio_direction_output(GPIO_PDD0, 0); + + udelay(5); + + gpio_set_value(GPIO_PDD0, 1); +} + diff --git a/board/toradex/colibri_t30/pinmux-config-colibri_t30.h b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h new file mode 100644 index 0000000..4e73c07 --- /dev/null +++ b/board/toradex/colibri_t30/pinmux-config-colibri_t30.h @@ -0,0 +1,360 @@ +/* + * Copyright (c) 2013-2014, Stefan Agner + * + * This program is free software; you can redistribute it and/or modify it + * under the terms and conditions of the GNU General Public License, + * version 2, as published by the Free Software Foundation. + * + * This program is distributed in the hope it will be useful, but WITHOUT + * ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or + * FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for + * more details. + * + * You should have received a copy of the GNU General Public License + * along with this program. If not, see http://www.gnu.org/licenses/. + */ + +#ifndef _PINMUX_CONFIG_COLIBRI_T30_H_ +#define _PINMUX_CONFIG_COLIBRI_T30_H_ + +#define DEFAULT_PINMUX(_pingrp, _mux, _pull, _tri, _io) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_DEFAULT, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define I2C_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _od) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_##_od, \ + .ioreset = PMUX_PIN_IO_RESET_DEFAULT, \ + } + +#define LV_PINMUX(_pingrp, _mux, _pull, _tri, _io, _lock, _ioreset) \ + { \ + .pingrp = PMUX_PINGRP_##_pingrp, \ + .func = PMUX_FUNC_##_mux, \ + .pull = PMUX_PULL_##_pull, \ + .tristate = PMUX_TRI_##_tri, \ + .io = PMUX_PIN_##_io, \ + .lock = PMUX_PIN_LOCK_##_lock, \ + .od = PMUX_PIN_OD_DEFAULT, \ + .ioreset = PMUX_PIN_IO_RESET_##_ioreset \ + } + +#define DEFAULT_PADCFG(_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) \ + { \ + .drvgrp = PMUX_DRVGRP_##_drvgrp, \ + .slwf = _slwf, \ + .slwr = _slwr, \ + .drvup = _drvup, \ + .drvdn = _drvdn, \ + .lpmd = PMUX_LPMD_##_lpmd, \ + .schmt = PMUX_SCHMT_##_schmt, \ + .hsm = PMUX_HSM_##_hsm, \ + } + +static struct pmux_pingrp_config tegra3_pinmux_common[] = { + /* SDMMC1 disabled */ + DEFAULT_PINMUX(SDMMC1_CLK_PZ0, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_CMD_PZ1, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT3_PY4, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT2_PY5, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT1_PY6, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC1_DAT0_PY7, RSVD1, NORMAL, NORMAL, INPUT), + + /* SDMMC3 pinmux */ + DEFAULT_PINMUX(SDMMC3_CLK_PA6, SDMMC3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_CMD_PA7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT0_PB7, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT1_PB6, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT2_PB5, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT3_PB4, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT6_PD3, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT7_PD4, RSVD1, NORMAL, NORMAL, INPUT), + + /* SDMMC4 pinmux (eMMC) */ + LV_PINMUX(SDMMC4_CLK_PCC4, SDMMC4, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_CMD_PT7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT0_PAA0, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT1_PAA1, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT2_PAA2, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT3_PAA3, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT4_PAA4, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT5_PAA5, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT6_PAA6, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_DAT7_PAA7, SDMMC4, UP, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(SDMMC4_RST_N_PCC3, RSVD1, DOWN, NORMAL, INPUT, DISABLE, DISABLE), + + /* I2C1 pinmux */ + I2C_PINMUX(GEN1_I2C_SCL_PC4, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(GEN1_I2C_SDA_PC5, I2C1, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* I2C2 pinmux */ + DEFAULT_PINMUX(GEN2_I2C_SCL_PT5, I2C2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GEN2_I2C_SDA_PT6, I2C2, NORMAL, NORMAL, INPUT), + + /* I2C3 pinmux, muliplexed with KB_ROW13/KB_ROW14 */ + I2C_PINMUX(CAM_I2C_SCL_PBB1, I2C3, NORMAL, TRISTATE, INPUT, DISABLE, ENABLE), + I2C_PINMUX(CAM_I2C_SDA_PBB2, I2C3, NORMAL, TRISTATE, INPUT, DISABLE, ENABLE), + + /* I2C4 pinmux */ + I2C_PINMUX(DDC_SCL_PV4, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(DDC_SDA_PV5, I2C4, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + /* Power I2C pinmux */ + I2C_PINMUX(PWR_I2C_SCL_PZ6, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + I2C_PINMUX(PWR_I2C_SDA_PZ7, I2CPWR, NORMAL, NORMAL, INPUT, DISABLE, ENABLE), + + DEFAULT_PINMUX(ULPI_DATA0_PO1, UARTA, NORMAL, NORMAL, OUTPUT), + /* UARTA RX, make sure we don't get input form a floating Pin */ + DEFAULT_PINMUX(ULPI_DATA1_PO2, UARTA, UP, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA2_PO3, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA3_PO4, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA4_PO5, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA5_PO6, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA6_PO7, UARTA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DATA7_PO0, UARTA, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(ULPI_CLK_PY0, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_DIR_PY1, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_NXT_PY2, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(ULPI_STP_PY3, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_FS_PP0, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DIN_PP1, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_DOUT_PP2, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP3_SCLK_PP3, I2S2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PV2, OWR, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PV3, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CLK2_OUT_PW5, EXTPERIPH2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK2_REQ_PCC5, DAP, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PWR1_PC1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PWR2_PC6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SDIN_PZ2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SDOUT_PN5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_WR_N_PZ3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS0_N_PN4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DC0_PN6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_SCK_PZ4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PWR0_PB2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_PCLK_PB3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DE_PJ1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_HSYNC_PJ3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_VSYNC_PJ4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D0_PE0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D1_PE1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D2_PE2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D3_PE3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D4_PE4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D5_PE5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D6_PE6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D7_PE7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D8_PF0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D9_PF1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D10_PF2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D11_PF3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D12_PF4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D13_PF5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D14_PF6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D15_PF7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D16_PM0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D17_PM1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D18_PM2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D19_PM3, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D20_PM4, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D21_PM5, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D22_PM6, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_D23_PM7, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_CS1_N_PW0, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_M1_PW1, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(LCD_DC1_PD2, DISPLAYA, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CRT_HSYNC_PV6, CRT, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CRT_VSYNC_PV7, CRT, NORMAL, NORMAL, OUTPUT), + LV_PINMUX(VI_D0_PT4, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D1_PD5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D2_PL0, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D3_PL1, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D4_PL2, VI, NORMAL, NORMAL, OUTPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D5_PL3, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D7_PL5, SDMMC2, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D10_PT2, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_MCLK_PT1, VI, UP, NORMAL, INPUT, DISABLE, DISABLE), + DEFAULT_PINMUX(UART2_RXD_PC3, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART2_TXD_PC2, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_RTS_N_PJ6, UARTB, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART2_CTS_N_PJ5, UARTB, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_TXD_PW6, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(UART3_RXD_PW7, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_CTS_N_PA1, UARTC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(UART3_RTS_N_PC0, UARTC, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU0, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU1, RSVD1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU2, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU3, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PU4, PWM1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU5, PWM2, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PU6, RSVD1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_FS_PP4, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DIN_PP5, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_DOUT_PP6, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP4_SCLK_PP7, I2S3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK3_OUT_PEE0, EXTPERIPH3, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(CLK3_REQ_PEE1, DEV3, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WP_N_PC7, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_CS2_N_PK3, RSVD1, UP, NORMAL, INPUT), /* EN_VDD_BL1 */ + DEFAULT_PINMUX(GMI_AD8_PH0, PWM0, NORMAL, NORMAL, OUTPUT), /* LCD1_BL_PWM */ + DEFAULT_PINMUX(GMI_AD10_PH2, NAND, NORMAL, NORMAL, OUTPUT), /* LCD1_BL_EN */ + DEFAULT_PINMUX(GMI_A16_PJ7, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A17_PB0, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A18_PB1, UARTD, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_A19_PK7, UARTD, NORMAL, NORMAL, INPUT), + + + /* Multiplexed with KB_ROW10/KB_ROW11/KB_ROW12/KB_ROW15 */ + DEFAULT_PINMUX(CAM_MCLK_PCC0, VI_ALT2, UP, TRISTATE, INPUT), + DEFAULT_PINMUX(PCC1, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PBB0, RSVD1, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(PBB3, VGP3, NORMAL, TRISTATE, INPUT), + + DEFAULT_PINMUX(PBB5, VGP5, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB6, VGP6, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB7, I2S4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PCC2, I2S4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(JTAG_RTCK_PU7, RTCK, NORMAL, NORMAL, OUTPUT), + + /* KBC keys */ + DEFAULT_PINMUX(KB_ROW0_PR0, RSVD2, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW1_PR1, RSVD2, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW2_PR2, RSVD2, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW3_PR3, RSVD2, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW4_PR4, RSVD3, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW5_PR5, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW6_PR6, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW7_PR7, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW8_PS0, KBC, NORMAL, TRISTATE, INPUT), + DEFAULT_PINMUX(KB_ROW9_PS1, KBC, NORMAL, TRISTATE, INPUT), + + /* SDMMC2 pinmux */ + DEFAULT_PINMUX(KB_ROW10_PS2, SDMMC2, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW11_PS3, SDMMC2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW12_PS4, SDMMC2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW13_PS5, SDMMC2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW14_PS6, SDMMC2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW15_PS7, SDMMC2, UP, NORMAL, INPUT), + + DEFAULT_PINMUX(KB_COL0_PQ0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL1_PQ1, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL2_PQ2, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL3_PQ3, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL4_PQ4, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL5_PQ5, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL6_PQ6, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(KB_COL7_PQ7, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(PV0, RSVD1, UP, NORMAL, INPUT), + + DEFAULT_PINMUX(CLK_32K_OUT_PA0, BLINK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(SYS_CLK_REQ_PZ5, SYSCLK, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(OWR, OWR, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_FS_PN0, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DIN_PN1, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_DOUT_PN2, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP1_SCLK_PN3, I2S0, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK1_REQ_PEE2, DAP, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(CLK1_OUT_PW4, EXTPERIPH1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPDIF_IN_PK6, SPDIF, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPDIF_OUT_PK5, SPDIF, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(DAP2_FS_PA2, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DIN_PA4, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_DOUT_PA5, I2S1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(DAP2_SCLK_PA3, I2S1, NORMAL, NORMAL, INPUT), + + DEFAULT_PINMUX(SPI2_CS1_N_PW2, SPI2, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_MOSI_PX4, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_SCK_PX5, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_CS0_N_PX6, SPI1, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(SPI1_MISO_PX7, SPI1, NORMAL, NORMAL, INPUT), + + /* LAN_RESET */ + DEFAULT_PINMUX(PEX_L0_PRSNT_N_PDD0, RSVD2, NORMAL, NORMAL, OUTPUT), + + DEFAULT_PINMUX(PEX_L0_RST_N_PDD1, PCIE, NORMAL, NORMAL, OUTPUT), + + /* LAN_VBUS */ + DEFAULT_PINMUX(PEX_L0_CLKREQ_N_PDD2, RSVD2, NORMAL, NORMAL, OUTPUT), + + DEFAULT_PINMUX(PEX_WAKE_N_PDD3, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_PRSNT_N_PDD4, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L1_RST_N_PDD5, PCIE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PEX_L1_CLKREQ_N_PDD6, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_PRSNT_N_PDD7, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PEX_L2_RST_N_PCC6, PCIE, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(PEX_L2_CLKREQ_N_PCC7, PCIE, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(HDMI_CEC_PEE3, CEC, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(HDMI_INT_PN7, RSVD1, NORMAL, TRISTATE, INPUT), + + /* GPIOs */ + /* SDMMC1 CD gpio */ + DEFAULT_PINMUX(GMI_IORDY_PI5, RSVD1, UP, NORMAL, INPUT), + /* SDMMC1 WP gpio */ + LV_PINMUX(VI_D11_PT3, RSVD1, UP, NORMAL, INPUT, DISABLE, DISABLE), + + /* Touch panel GPIO */ + /* Touch IRQ */ + DEFAULT_PINMUX(GMI_AD12_PH4, NAND, UP, NORMAL, INPUT), + + /* Touch RESET */ + DEFAULT_PINMUX(GMI_AD14_PH6, NAND, NORMAL, NORMAL, OUTPUT), + + /* Power rails GPIO */ + DEFAULT_PINMUX(SPI2_SCK_PX2, GMI, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(PBB4, VGP4, NORMAL, NORMAL, INPUT), + DEFAULT_PINMUX(KB_ROW8_PS0, KBC, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT5_PD0, SDMMC3, UP, NORMAL, INPUT), + DEFAULT_PINMUX(SDMMC3_DAT4_PD1, SDMMC3, UP, NORMAL, INPUT), + + LV_PINMUX(VI_D6_PL4, VI, NORMAL, NORMAL, OUTPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D8_PL6, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_D9_PL7, VI, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_PCLK_PT0, RSVD1, UP, TRISTATE, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_HSYNC_PD7, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), + LV_PINMUX(VI_VSYNC_PD6, RSVD1, NORMAL, NORMAL, INPUT, DISABLE, DISABLE), +}; + +static struct pmux_pingrp_config unused_pins_lowpower[] = { + DEFAULT_PINMUX(GMI_WAIT_PI7, NAND, UP, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_ADV_N_PK0, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CLK_PK1, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_CS3_N_PK4, NAND, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_CS7_N_PI6, NAND, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_AD0_PG0, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD1_PG1, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD2_PG2, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD3_PG3, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD4_PG4, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD5_PG5, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD6_PG6, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD7_PG7, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_AD9_PH1, PWM1, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD11_PH3, NAND, NORMAL, NORMAL, OUTPUT), + DEFAULT_PINMUX(GMI_AD13_PH5, NAND, UP, NORMAL, INPUT), + DEFAULT_PINMUX(GMI_WR_N_PI0, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_OE_N_PI1, NAND, NORMAL, TRISTATE, OUTPUT), + DEFAULT_PINMUX(GMI_DQS_PI2, NAND, NORMAL, TRISTATE, OUTPUT), +}; + +static struct pmux_drvgrp_config colibri_t30_padctrl[] = { + /* (_drvgrp, _slwf, _slwr, _drvup, _drvdn, _lpmd, _schmt, _hsm) */ + DEFAULT_PADCFG(SDIO1, SDIOCFG_DRVUP_SLWF, SDIOCFG_DRVDN_SLWR, \ + SDIOCFG_DRVUP, SDIOCFG_DRVDN, NONE, DISABLE, DISABLE), +}; +#endif /* _PINMUX_CONFIG_COLIBRI_T30_H_ */ diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h new file mode 100644 index 0000000..92eaec8 --- /dev/null +++ b/include/configs/colibri_t30.h @@ -0,0 +1,73 @@ +/* + * Copyright (c) 2013-2014 Stefan Agner + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#include "tegra30-common.h" + +#define CONFIG_DEFAULT_DEVICE_TREE tegra30-colibri +#define CONFIG_OF_CONTROL +#define CONFIG_OF_SEPARATE + +#define V_PROMPT "Colibri T30 # " +#define CONFIG_TEGRA_BOARD_STRING "Toradex Colibri T30" + +/* Board-specific config */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_TEGRA_ENABLE_UARTA +#define CONFIG_SYS_NS16550_COM1 NV_PA_APB_UARTA_BASE + +#define CONFIG_MACH_TYPE MACH_TYPE_COLIBRI_T30 + +#define CONFIG_BOARD_EARLY_INIT_F + +/* I2C */ +#define CONFIG_SYS_I2C_TEGRA +#define CONFIG_SYS_I2C_INIT_BOARD +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_SYS_MAX_I2C_BUS TEGRA_I2C_NUM_CONTROLLERS +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_CMD_I2C +#define CONFIG_SYS_I2C + +/* SD/MMC */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_TEGRA_MMC +#define CONFIG_CMD_MMC + +/* Environment in eMMC, at the end of 2nd "boot sector" */ +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_ENV_OFFSET (-CONFIG_ENV_SIZE) +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_SYS_MMC_ENV_PART 2 + +#define BOARD_EXTRA_ENV_SETTINGS \ + "board_name=colibri-eval-v3\0" \ + "fdtfile=tegra30-colibri-eval-v3.dtb\0" + +/* USB Host support */ +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_TEGRA +#define CONFIG_USB_STORAGE +#define CONFIG_USB_MAX_CONTROLLER_COUNT 3 +#define CONFIG_CMD_USB + +/* USB networking support */ +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX + +/* General networking support */ +#define CONFIG_CMD_NET +#define CONFIG_CMD_DHCP + +#include "tegra-common-ums.h" +#include "tegra-common-post.h" + +#endif /* __CONFIG_H */
Hi Stefan,
A few quick questions below...
Working functions:
- SD card boot
aliases {
memory {
board) */
i2c@7000c000 {
status = "okay";
i2c@7000c700 {
status = "okay";
i2c@7000d000 {
status = "okay";
spi@7000d400 {
status = "okay";
sdhci@78000200 {
status = "okay";
bus-width = <4>;
sdhci@78000600 {
status = "okay";
bus-width = <8>;
non-removable;
usb@7d000000 {
status = "okay";
dr_mode = "otg";
usb@7d004000 {
status = "okay";
phy_type = "utmi";
usb@7d008000 {
status = "okay";
Do we actually need this machine type stuff anymore?
- These have not yet been registered
- (C) Copyright 2014
- Stefan Agner stefan@agner.ch
Are these used?
- Routine: pinmux_init
- Description: Do individual peripheral pinmux configs
- Enable AX88772B USB to LAN controller
udelay(5);
You are using device tree for sdhci - shouldn't we use it for USB also?
- Copyright (c) 2013-2014, Stefan Agner
- This program is free software; you can redistribute it and/or modify it
- under the terms and conditions of the GNU General Public License,
- version 2, as published by the Free Software Foundation.
- This program is distributed in the hope it will be useful, but WITHOUT
- ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
- FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
- more details.
- along with this program. If not, see http://www.gnu.org/licenses/.
.slwf = _slwf, \
.slwr = _slwr, \
.drvup = _drvup, \
.drvdn = _drvdn, \
/* SDMMC3 pinmux */
/* I2C1 pinmux */
/* I2C2 pinmux */
/* I2C4 pinmux */
/* KBC keys */
/* SDMMC2 pinmux */
/* LAN_RESET */
/* LAN_VBUS */
/* GPIOs */
/* Touch IRQ */
/* Touch RESET */
- Copyright (c) 2013-2014 Stefan Agner
2.0.3
Hi Simon,
Am 2014-07-31 19:41, schrieb Simon Glass:
Hi Stefan,
Working functions:
- SD card boot
aliases {
memory {
board) */
i2c@7000c000 {
status = "okay";
i2c@7000c700 {
status = "okay";
i2c@7000d000 {
status = "okay";
spi@7000d400 {
status = "okay";
sdhci@78000200 {
status = "okay";
bus-width = <4>;
sdhci@78000600 {
status = "okay";
bus-width = <8>;
non-removable;
usb@7d000000 {
status = "okay";
dr_mode = "otg";
usb@7d004000 {
status = "okay";
phy_type = "utmi";
usb@7d008000 {
status = "okay";
That way we can also boot the 3.1 L4T Kernel, since this is the (probably last) one where we get supported binary drivers for the graphics part.
Are these used?
The address is correct, but not used right now. Should I remove?
udelay(5);
The Colibri T30 has a ASIX USB to Ethernet chip on its board. We reset/power the ASIX here. It is a very board specific reset/powering, hence I put it in here.
In my initial patches I had it in the nvidia,phy-reset-gpio and nvidia,vbus-gpio properties. Technically, it would work to have this GPIOs in the device tree as USB properties, but I think this would be logically wrong...
- more details.
.slwf = _slwf, \
.slwr = _slwr, \
.drvup = _drvup, \
.drvdn = _drvdn, \
/* SDMMC3 pinmux */
/* I2C1 pinmux */
/* I2C2 pinmux */
/* I2C4 pinmux */
/* KBC keys */
/* SDMMC2 pinmux */
/* LAN_RESET */
/* LAN_VBUS */
/* GPIOs */
/* Touch IRQ */
/* Touch RESET */
2.0.3
-- Stefan
Hi Stefan,
On 31 July 2014 19:00, Stefan Agner stefan@agner.ch wrote:
Hi Simon,
Hi Stefan,
Working functions:
- SD card boot
OK I see.
Are these used?
I think so.
udelay(5);
For VBUS I think it would be correct to put it in the USB. For the reset, I'm not sure - it looks like a separate pin so putting it in the device tree for USB would be wrong I think.
What does the kernel do for these? ...
udelay(5);
The kernel doesn't yet have a good answer to things like this, i.e. data that's not directly driven by the requirements of a controller or protocol, but rather the custom/out-of-band aspects of the device that's connected to the controller.
So, a GPIO for VBUS is something very closely tied to the USB specification, and basically any USB controller needs to represent and handle it in the same way.
However, a GPIO to reset/enable a USB device is something completely outside the scope of the USB specification, and is very device specific, and there's currently no good answer re: how to handle it.
There have been various attempts to solve it such as a generic "power sequences" DT binding, various proposals for a "slot" or "connector" or "target device" binding, or even explicitly defining the attached device in DT (even though it can be probed) and having the driver for that handle all the HW-specific details. However these threads have unfortunately all languished.
Am 2014-07-31 23:55, schrieb Simon Glass:
Hi Stefan,
Hi Simon,
Hi Stefan,
Working functions:
- SD card boot
OK I see.
Are these used?
I think so.
udelay(5);
Right now, the Kernel does not touch the reset signal on that device. I'm not sure what happens if we go in suspend mode, need to check that on the kernel side once.
Ok, when I think about it again, it totally make sense to use the VBUS property since this GPIO is really connected to the VBUS pin of that USB device...
-- Stefan
Working functions:
- SD card boot
I think in latest u-boot/master, you'll also need to add configs/colibri_t30_defconfig.
- /* EHCI instance 0: USB1_DP/N -> USBC_P/N */
- usb@7d000000 {
status = "okay";
dr_mode = "otg";
For OTG support, VBUS needs to be able to be turned on/off. Should this port be host-mode, or a VBUS GPIO defined?
- /* Enable LAN_VBUS */
- gpio_request(GPIO_PDD2, NULL);
- gpio_direction_output(GPIO_PDD2, 1);
- /* Reset ASIX using LAN_RESET */
- gpio_request(GPIO_PDD0, NULL);
- gpio_direction_output(GPIO_PDD0, 0);
- udelay(5);
- gpio_set_value(GPIO_PDD0, 1);
It might be nice to remove the blank lines around the udelay() call; I initially didn't notice that GOPIO_PDD0 was manipulated by the code both before and after the udelay() and hence there was already a comment saying what GPIO_PDD0 controlled. Nestling the lines together would make this more obvious.
Are those needed? They aren't defined in e.g. the Beaver config header.
- "board_name=colibri-eval-v3\0" \
- "fdtfile=tegra30-colibri-eval-v3.dtb\0"
It'd be nice to name the board the same in U-Boot as the kernel DT filename. Then you wouldn't need to manually override the default values here.
Did you test this? I mostly developed the USB device mode support on Tegra124. While at some point I did test it on Beaver/Tegra30, it was early on and not very extensive. I'd love to hear that it works well for you too:-)
(BTW, I sent a patch to rename that file to tegra-common-usb-gadget.h, since I added DFU support too, so depending on what order TomW applies our patches, one of us will need to rebase)
Am 2014-07-31 20:21, schrieb Stephen Warren:
Working functions:
- SD card boot
I actually created them but forgot the git add... Next version will contain those files too:
board/toradex/colibri_t30/Kconfig board/toradex/colibri_t30/MAINTAINERS configs/colibri_t30_defconfig
- usb@7d000000 {
status = "okay";
dr_mode = "otg";
This port is actually ment to be client by default, I will change dr_mode to "peripheral" in the next patch.
We do not have real OTG support on that port since the ID-Pin is not connected (the Colibri standard has all pins 3.3V level only, hence we cannot connect the ID-Pin). This port is more a dual-role port. On the Evaluation Board, we have a pin connected to allow automatic switching between the two roles, while the VBUS stuff is handled by hardware (using the ID-Pin). However, this automatic switching is currently not implemented. Hence I would like to have that port as peripheral by default while having the other as host.
- udelay(5);
Agreed.
Since we do not need to configure the PMIC, its not required no. I will remove them.
This is a somewhat complicated topic in our case. Our products are named:
"Colibri T20" "Colibri T30" "Apalis T30"
Since quite a long time, we use those names, except replacing the space by an underline character and preferable use small caps. Hence e.g. the U-Boot configurations in the downstream tree:
colibri_t20_config colibri_t30_config apalis_t30_config
However, in the kernel world, since device tree was introduced there is this reverse notation, SoC-board.dts... e.g. tegra30-colibri_t30.dts. We descided to drop that t30, since its somewhat duplicated. Not sure this was the right description, but its in the kernel that way right now.
Additionally, this whole carrier board (Evaluation Board v3)/module (Colibri T30) relation is also taken into account at kernel side, hence the full name today tegra30-colibri-eval-v3.dts
Ok, because we don't have the unique board names as the other Tegra devices have, we cannot just call the board in U-Boot as we did for the kernel: "colibri" or "colibri-eval-v3" would be used twice, for the T20 and T30. To solve that, we could change tegra30-colibri-eval-v3.dts to tegra30-colibri_t30-eval-v3.dts...
Also, since most customers never change the boot loader for their board design, I would like to avoid to have the carrier board in the boot loaders board name. Frankly, quite a lot even don't change the kernel, since they use the default pin assignment. Also we use the same boot loader configuration for our three own Carrier Boards. (Btw. currently, this is not the case for the Colibri T20. Lucas, in CC now, added back then a similar Carrier Board/Module relation we have in the kernel. I would actually prefer to squash this together the way this patch does it for the Colibri T30.)
Hence we are not synchronized between the kernel dtb and the U-Boot board name anyway...
So the name scheme I see would be U-Boot: colibri_t20 colibri_t30 apalis_t30
Kernel: tegra20-colibri.dtsi (in case we can detect the RAM size) tegra20-colibri-iris.dts tegra20-colibri-eval-v3.dts tegra30-colibri.dtsi tegra30-colibri-iris.dts tegra30-colibri-eval-v3.dts tegra30-apalis.dtsi tegra30-apalis-ixora.dts tegra30-apalis-eval-v1.dts
What do you think? I could also agree to add the T30 again for the kernel, hence tegra30-colibri_t30.dtsi and tegra30-colibri_t30-eval-v3.dts. But I don't like the idea to have the carrier board in the U-Boot name. In the end, everybody would use the one colibri_t30_eval_v3 config...
Yes I tested this, and it works great! It's really a very nice way to deploy the root file system. Create the partition table easily from your desktop PC, format the partition, and just untar whatever distribution you want. Slick!
Does DFU support NAND/and or eMMC? AFAIK it was designed more for NAND devices wasn't it? If NAND is supported, we would even have a nice solution for the Tegra 2 now.
-- Stefan
Working functions:
- SD card boot
OK, it mostly makes sense to have U-Boot configuration names that only mention the CPU module and not the carrier board in that case.
However, if the U-Boot default environment defines the full kernel DTB name, then that isn't possible. A U-Boot board will be tied to a particular carrier-board configuration that way.
Perhaps remove the DT filename from the default environment, and require the user or flashing process to set the correct value?
Alternatively, perhaps add the core U-Boot support under one (primary configuration and board directory) name, and add additional entry to boards.cfg/Kconfig to override that one fdtfile value in the environment? I see quite a few other boards do so something similar, albeit likely for larger variations than just one environment variable:-)
Working functions:
- SD card boot
Is there a run-time way to discover what board (or perhaps rather, what DT we would want to load) we're on? That's how we solve this on various TI platforms.
But yes, we'll need to sort out a way to setup the default environment, with some this-that-or-something-else tweaks in any case.
Am 2014-08-04 19:16, schrieb Tom Rini:
Working functions:
- SD card boot
No there is no standardized way to detect the carrier board.
-- Stefan
Am 2014-08-04 19:02, schrieb Stephen Warren:
Working functions:
- SD card boot
Since a lot of people use the bootloader binaries unmodified, such a solution would be preferable. I guess I could use fdtput or even extend the existing tegra-uboot-flasher for this purpose.
Yes, such a lightweight carrier board/module support would be maintainable too I guess.
I will try to implement the first approach first. One way would be setting the board_name by overriding boardcmd. Or maybe a bit more problem specific, getting the fdtfile/board_name from dts /config/fdtfile node...
-- Stefan
Working functions:
- SD card boot
There's already the --env command-line option which allows you to do this.
If necessary, it probably wouldn't be hard to add the ability for a particular tegra-uboot-flasher config file to automatically add the relevant --env option when run in flashing mode.
Stefan Agner
Stephen Warren
