[RFC PATCH] clk: scmi: Provide channel information to every clock
When assigned-clocks/assigned-clock-rates is defined U-Boot DM core finds out leaf which is registered via clk_register(). But new clock doesn't have information about channel which is stored in private data. That's why copy parents private data (channel only now) to all childs. It will fix the issue when there is reference to clk child and operations with it.
Signed-off-by: Michal Simek michal.simek@amd.com ---
I am not really sure that this is the right way how to solve this problem. I had another patch which is pretty much written in a way if current device doesn't have private data it looks at parents private data. Anyway I am sending it as RFC to start to have discussion about it. --- drivers/clk/clk_scmi.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/drivers/clk/clk_scmi.c b/drivers/clk/clk_scmi.c index d172fed24c9d..98a779fdc81b 100644 --- a/drivers/clk/clk_scmi.c +++ b/drivers/clk/clk_scmi.c @@ -12,6 +12,7 @@ #include <scmi_protocols.h> #include <asm/types.h> #include <linux/clk-provider.h> +#include <dm/device-internal.h>
/** * struct scmi_clk_priv - Private data for SCMI clocks @@ -186,6 +187,7 @@ static int scmi_clk_probe(struct udevice *dev) return ret; }
+ dev_set_priv(clk->dev, dev_get_priv(dev)); clk_dm(i, clk); } }
- struct scmi_clk_priv - Private data for SCMI clocks
} }dev_set_priv(clk->dev, dev_get_priv(dev)); clk_dm(i, clk);
Please ignore this patch. Takahiro's series is fixing this problem https://lore.kernel.org/all/20230926065750.734440-1-takahiro.akashi@linaro.o...
Thanks, Michal
Michal Simek
