[U-Boot] [PATCH 00/18] various Gateworks Ventana fixes and enhancements
This series represents a large chunk of patches in my queue for Gateworks Ventana boards based on the IMX6 Soc's.
Tim Harvey (18): imx: ventana: config: add env vars for disk and part imx: ventana: config: add fixfdt script to apply manual fdt fixups imx: ventana: config: use bootdir env var for directory of fdt files imx: ventana: config: use fs env var for block dev filesystem type imx: ventana: config: use explicit addr in loadscript imx: ventana: config: add PREBOOT support imx: ventana: SPL: only disable boot watchdog if Falcon mode imx: ventana: SPL: added support for 32bit IMX6DQ 8Gb density DRAM config imx: ventana: gsc: add gsc sleep command imx: ventana: gsc: fix negative temperature readings imx: ventana: gsc: show board temp on boot imx: ventana: export backlight gpio after gpio driver is available imx: ventana: fix invalid dio configuration for pwm mode imx: ventana: enable pwm device-tree property based on hwconfig imx: ventana: remove dependence on EECONFIG_SATA eeprom feature bit imx: ventana: remove several EEPROM config bit dependence imx: ventana: add GW553x support imx: ventana: add fdt fixup to enable UHS-I support on selected boards
board/gateworks/gw_ventana/common.c | 100 ++++++++++++++++++++++++---- board/gateworks/gw_ventana/common.h | 3 + board/gateworks/gw_ventana/eeprom.c | 34 +--------- board/gateworks/gw_ventana/gsc.c | 57 +++++++++++++++- board/gateworks/gw_ventana/gw_ventana.c | 69 +++++++++++++++++-- board/gateworks/gw_ventana/gw_ventana_spl.c | 38 ++++++++++- board/gateworks/gw_ventana/ventana_eeprom.h | 1 + include/configs/gw_ventana.h | 37 ++++++---- 8 files changed, 272 insertions(+), 67 deletions(-)
In order to make the default boot scripts more flexible, use the variable 'disk' to specify the disk device number and the variable 'part' to specify the partition number.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/gw_ventana.h | 12 ++++++++---- 1 file changed, 8 insertions(+), 4 deletions(-)
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 874bb04..3aeb0df 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -281,6 +281,8 @@ \ "mtdparts=" MTDPARTS_DEFAULT "\0" \ "mtdids=" MTDIDS_DEFAULT "\0" \ + "disk=0\0" \ + "part=1\0" \ \ "fdt_high=0xffffffff\0" \ "fdt_addr=0x18000000\0" \ @@ -304,8 +306,8 @@ "uimage=uImage\0" \ "mmc_root=/dev/mmcblk0p1 rootfstype=ext4 rootwait rw\0" \ "mmc_boot=" \ - "setenv fsload 'ext2load mmc 0:1'; " \ - "mmc dev 0 && mmc rescan && " \ + "setenv fsload "ext2load mmc ${disk}:${part}"; " \ + "mmc dev ${disk} && mmc rescan && " \ "setenv dtype mmc; run loadscript; " \ "if ${fsload} ${loadaddr} ${bootdir}/${uimage}; then " \ "setenv bootargs console=${console},${baudrate} " \ @@ -319,7 +321,8 @@ "fi\0" \ \ "sata_boot=" \ - "setenv fsload 'ext2load sata 0:1'; sata init && " \ + "setenv fsload "ext2load sata ${disk}:${part}"; " \ + "sata init && " \ "setenv dtype sata; run loadscript; " \ "if ${fsload} ${loadaddr} ${bootdir}/${uimage}; then " \ "setenv bootargs console=${console},${baudrate} " \ @@ -332,7 +335,8 @@ "fi; " \ "fi\0" \ "usb_boot=" \ - "setenv fsload 'ext2load usb 0:1'; usb start && usb dev 0 && " \ + "setenv fsload "ext2load usb ${disk}:${part}"; " \ + "usb start && usb dev ${disk} && " \ "setenv dtype usb; run loadscript; " \ "if ${fsload} ${loadaddr} ${bootdir}/${uimage}; then " \ "setenv bootargs console=${console},${baudrate} " \
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/gw_ventana.h | 25 +++++++++++++++---------- 1 file changed, 15 insertions(+), 10 deletions(-)
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 3aeb0df..e57b120 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -287,14 +287,19 @@ "fdt_high=0xffffffff\0" \ "fdt_addr=0x18000000\0" \ "initrd_high=0xffffffff\0" \ + "fixfdt=" \ + "fdt addr ${fdt_addr}\0" \ "bootdir=boot\0" \ "loadfdt=" \ - "if ${fsload} ${fdt_addr} ${bootdir}/${fdt_file}; then " \ - "echo Loaded DTB from ${bootdir}/${fdt_file}; " \ - "elif ${fsload} ${fdt_addr} ${bootdir}/${fdt_file1}; then " \ - "echo Loaded DTB from ${bootdir}/${fdt_file1}; " \ - "elif ${fsload} ${fdt_addr} ${bootdir}/${fdt_file2}; then " \ - "echo Loaded DTB from ${bootdir}/${fdt_file2}; " \ + "if ${fsload} ${fdt_addr} boot/${fdt_file}; then " \ + "echo Loaded DTB from boot/${fdt_file}; " \ + "run fixfdt; " \ + "elif ${fsload} ${fdt_addr} boot/${fdt_file1}; then " \ + "echo Loaded DTB from boot/${fdt_file1}; " \ + "run fixfdt; " \ + "elif ${fsload} ${fdt_addr} boot/${fdt_file2}; then " \ + "echo Loaded DTB from boot/${fdt_file2}; " \ + "run fixfdt; " \ "fi\0" \ \ "script=6x_bootscript-ventana\0" \ @@ -313,7 +318,7 @@ "setenv bootargs console=${console},${baudrate} " \ "root=/dev/mmcblk0p1 rootfstype=ext4 " \ "rootwait rw ${video} ${extra}; " \ - "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \ "else " \ "bootm; " \ @@ -328,7 +333,7 @@ "setenv bootargs console=${console},${baudrate} " \ "root=/dev/sda1 rootfstype=ext4 " \ "rootwait rw ${video} ${extra}; " \ - "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \ "else " \ "bootm; " \ @@ -342,7 +347,7 @@ "setenv bootargs console=${console},${baudrate} " \ "root=/dev/sda1 rootfstype=ext4 " \ "rootwait rw ${video} ${extra}; " \ - "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \ "else " \ "bootm; " \ @@ -405,7 +410,7 @@ "if ${fsload} ${loadaddr} ${bootdir}/${uimage}; then " \ "setenv bootargs console=${console},${baudrate} " \ "root=${root} ${video} ${extra}; " \ - "if run loadfdt && fdt addr ${fdt_addr}; then " \ + "if run loadfdt; then " \ "ubifsumount; " \ "bootm ${loadaddr} - ${fdt_addr}; " \ "else " \
In order to make the default boot scripts more flexible, use the variable 'bootdir' to specify the filesystem directory to look for fdt files in.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/gw_ventana.h | 12 ++++++------ 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index e57b120..dff4303 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -291,14 +291,14 @@ "fdt addr ${fdt_addr}\0" \ "bootdir=boot\0" \ "loadfdt=" \ - "if ${fsload} ${fdt_addr} boot/${fdt_file}; then " \ - "echo Loaded DTB from boot/${fdt_file}; " \ + "if ${fsload} ${fdt_addr} ${bootdir}/${fdt_file}; then " \ + "echo Loaded DTB from ${bootdir}/${fdt_file}; " \ "run fixfdt; " \ - "elif ${fsload} ${fdt_addr} boot/${fdt_file1}; then " \ - "echo Loaded DTB from boot/${fdt_file1}; " \ + "elif ${fsload} ${fdt_addr} ${bootdir}/${fdt_file1}; then " \ + "echo Loaded DTB from ${bootdir}/${fdt_file1}; " \ "run fixfdt; " \ - "elif ${fsload} ${fdt_addr} boot/${fdt_file2}; then " \ - "echo Loaded DTB from boot/${fdt_file2}; " \ + "elif ${fsload} ${fdt_addr} ${bootdir}/${fdt_file2}; then " \ + "echo Loaded DTB from ${bootdir}/${fdt_file2}; " \ "run fixfdt; " \ "fi\0" \ \
In order to make the default boot scripts more flexible, use the variable 'fs' to specify the filesystem type to use for block storage devices (USB/MMC/SATA) when loading files.
Additionally default this to ext4 and enable ext4 filesystem support (which encompasses ext2 support) instead of just ext2 support.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/gw_ventana.h | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index dff4303..fe81cbd 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -302,6 +302,7 @@ "run fixfdt; " \ "fi\0" \ \ + "fs=ext4\0" \ "script=6x_bootscript-ventana\0" \ "loadscript=" \ "if ${fsload} ${loadaddr} ${bootdir}/${script}; then " \ @@ -309,14 +310,14 @@ "fi\0" \ \ "uimage=uImage\0" \ - "mmc_root=/dev/mmcblk0p1 rootfstype=ext4 rootwait rw\0" \ + "mmc_root=/dev/mmcblk0p1 rootfstype=${fs} rootwait rw\0" \ "mmc_boot=" \ - "setenv fsload "ext2load mmc ${disk}:${part}"; " \ + "setenv fsload "${fs}load mmc ${disk}:${part}"; " \ "mmc dev ${disk} && mmc rescan && " \ "setenv dtype mmc; run loadscript; " \ "if ${fsload} ${loadaddr} ${bootdir}/${uimage}; then " \ "setenv bootargs console=${console},${baudrate} " \ - "root=/dev/mmcblk0p1 rootfstype=ext4 " \ + "root=/dev/mmcblk0p1 rootfstype=${fs} " \ "rootwait rw ${video} ${extra}; " \ "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \ @@ -326,12 +327,12 @@ "fi\0" \ \ "sata_boot=" \ - "setenv fsload "ext2load sata ${disk}:${part}"; " \ + "setenv fsload "${fs}load sata ${disk}:${part}"; " \ "sata init && " \ "setenv dtype sata; run loadscript; " \ "if ${fsload} ${loadaddr} ${bootdir}/${uimage}; then " \ "setenv bootargs console=${console},${baudrate} " \ - "root=/dev/sda1 rootfstype=ext4 " \ + "root=/dev/sda1 rootfstype=${fs} " \ "rootwait rw ${video} ${extra}; " \ "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \ @@ -340,12 +341,12 @@ "fi; " \ "fi\0" \ "usb_boot=" \ - "setenv fsload "ext2load usb ${disk}:${part}"; " \ + "setenv fsload "${fs}load usb ${disk}:${part}"; " \ "usb start && usb dev ${disk} && " \ "setenv dtype usb; run loadscript; " \ "if ${fsload} ${loadaddr} ${bootdir}/${uimage}; then " \ "setenv bootargs console=${console},${baudrate} " \ - "root=/dev/sda1 rootfstype=ext4 " \ + "root=/dev/sda1 rootfstype=${fs} " \ "rootwait rw ${video} ${extra}; " \ "if run loadfdt; then " \ "bootm ${loadaddr} - ${fdt_addr}; " \
If we are loading a script to ${loadaddr} then we need to use that address explicitly when calling the source command in case user has changed loadaddr
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/gw_ventana.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index fe81cbd..435ca0a 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -306,7 +306,7 @@ "script=6x_bootscript-ventana\0" \ "loadscript=" \ "if ${fsload} ${loadaddr} ${bootdir}/${script}; then " \ - "source; " \ + "source ${loadaddr}; " \ "fi\0" \ \ "uimage=uImage\0" \
This allows the 'preboot' env variable to be executed prior to bootcmd if defined.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- include/configs/gw_ventana.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 435ca0a..982ddba 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -201,6 +201,7 @@
/* Miscellaneous configurable options */ #define CONFIG_HWCONFIG +#define CONFIG_PREBOOT
/* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16)
If not booting Falcon mode, leave the boot watchdog enabled as a work-around for other non-resolved bootloader hangs.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana_spl.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/gateworks/gw_ventana/gw_ventana_spl.c b/board/gateworks/gw_ventana/gw_ventana_spl.c index ed42b86..c045d74 100644 --- a/board/gateworks/gw_ventana/gw_ventana_spl.c +++ b/board/gateworks/gw_ventana/gw_ventana_spl.c @@ -527,9 +527,6 @@ void board_init_f(ulong dummy)
/* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start); - - /* disable boot watchdog */ - gsc_boot_wd_disable(); }
/* called from board_init_r after gd setup if CONFIG_SPL_BOARD_INIT defined */ @@ -575,6 +572,9 @@ int spl_start_uboot(void) i2c_set_bus_num(0); gsc_i2c_read(0x50, 0x0, 1, &ret, 1); #endif + if (!ret) + gsc_boot_wd_disable(); + debug("%s booting %s\n", __func__, ret ? "uboot" : "linux"); return ret; }
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana_spl.c | 32 +++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/board/gateworks/gw_ventana/gw_ventana_spl.c b/board/gateworks/gw_ventana/gw_ventana_spl.c index c045d74..e7f699a 100644 --- a/board/gateworks/gw_ventana/gw_ventana_spl.c +++ b/board/gateworks/gw_ventana/gw_ventana_spl.c @@ -190,6 +190,20 @@ static struct mx6_ddr3_cfg mt41k256m16ha_125 = { .trasmin = 3500, };
+/* MT41K512M16HA-125 (8Gb density) */ +static struct mx6_ddr3_cfg mt41k512m16ha_125 = { + .mem_speed = 1600, + .density = 8, + .width = 16, + .banks = 8, + .rowaddr = 16, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; + /* * calibration - these are the various CPU/DDR3 combinations we support */ @@ -341,6 +355,19 @@ static struct mx6_mmdc_calibration mx6dq_256x64_mmdc_calib = { .p1_mpwrdlctl = 0X40304239, };
+static struct mx6_mmdc_calibration mx6dq_512x32_mmdc_calib = { + /* write leveling calibration determine */ + .p0_mpwldectrl0 = 0x002A0025, + .p0_mpwldectrl1 = 0x003A002A, + /* Read DQS Gating calibration */ + .p0_mpdgctrl0 = 0x43430356, + .p0_mpdgctrl1 = 0x033C0335, + /* Read Calibration: DQS delay relative to DQ read access */ + .p0_mprddlctl = 0x4B373F42, + /* Write Calibration: DQ/DM delay relative to DQS write access */ + .p0_mpwrdlctl = 0x303E3C36, +}; + static void spl_dram_init(int width, int size_mb, int board_model) { struct mx6_ddr3_cfg *mem = NULL; @@ -420,6 +447,11 @@ static void spl_dram_init(int width, int size_mb, int board_model) else calib = &mx6sdl_256x32_mmdc_calib; debug("4gB density\n"); + } else if (width == 32 && size_mb == 2048) { + mem = &mt41k512m16ha_125; + if (is_cpu_type(MXC_CPU_MX6Q)) + calib = &mx6dq_512x32_mmdc_calib; + debug("8gB density\n"); } else if (width == 64 && size_mb == 512) { mem = &mt41k64m16jt_125; debug("1gB density\n");
The Gateworks System Controller on Ventana boards has the ability to disable the board's primary power supply until the RTC hits a specific time. When sleeping a button-down event on the GSC user pushbutton will wake the board before it's wake time has been reached. This feature is referred to as GSC sleep.
Add a command to invoke sleep mode for a specified number of seconds.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gsc.c | 46 +++++++++++++++++++++++++++++++++++++++- 1 file changed, 45 insertions(+), 1 deletion(-)
diff --git a/board/gateworks/gw_ventana/gsc.c b/board/gateworks/gw_ventana/gsc.c index 4f26bfd..2555824 100644 --- a/board/gateworks/gw_ventana/gsc.c +++ b/board/gateworks/gw_ventana/gsc.c @@ -160,6 +160,48 @@ int gsc_boot_wd_disable(void) }
#ifdef CONFIG_CMD_GSC +static int do_gsc_sleep(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + unsigned char reg; + unsigned long secs = 0; + + if (argc < 2) + return CMD_RET_USAGE; + + secs = simple_strtoul(argv[1], NULL, 10); + printf("GSC Sleeping for %ld seconds\n", secs); + + i2c_set_bus_num(0); + reg = (secs >> 24) & 0xff; + if (gsc_i2c_write(GSC_SC_ADDR, 9, 1, ®, 1)) + goto error; + reg = (secs >> 16) & 0xff; + if (gsc_i2c_write(GSC_SC_ADDR, 8, 1, ®, 1)) + goto error; + reg = (secs >> 8) & 0xff; + if (gsc_i2c_write(GSC_SC_ADDR, 7, 1, ®, 1)) + goto error; + reg = secs & 0xff; + if (gsc_i2c_write(GSC_SC_ADDR, 6, 1, ®, 1)) + goto error; + if (gsc_i2c_read(GSC_SC_ADDR, GSC_SC_CTRL1, 1, ®, 1)) + goto error; + reg |= (1 << 2); + if (gsc_i2c_write(GSC_SC_ADDR, GSC_SC_CTRL1, 1, ®, 1)) + goto error; + reg &= ~(1 << 2); + reg |= 0x3; + if (gsc_i2c_write(GSC_SC_ADDR, GSC_SC_CTRL1, 1, ®, 1)) + goto error; + + return CMD_RET_SUCCESS; + +error: + printf("i2c error\n"); + return CMD_RET_FAILURE; +} + static int do_gsc_wd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { unsigned char reg; @@ -206,13 +248,15 @@ static int do_gsc(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
if (strcasecmp(argv[1], "wd") == 0) return do_gsc_wd(cmdtp, flag, --argc, ++argv); + else if (strcasecmp(argv[1], "sleep") == 0) + return do_gsc_sleep(cmdtp, flag, --argc, ++argv);
return CMD_RET_USAGE; }
U_BOOT_CMD( gsc, 4, 1, do_gsc, "GSC configuration", - "[wd enable [30|60]]|[wd disable]\n" + "[wd enable [30|60]]|[wd disable]|[sleep <secs>]\n" );
#endif /* CONFIG_CMD_GSC */
The GSC Temperature sensor is a 2's complement value - adjust accordingly for negative temperatures.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gsc.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/board/gateworks/gw_ventana/gsc.c b/board/gateworks/gw_ventana/gsc.c index 2555824..c626ba2 100644 --- a/board/gateworks/gw_ventana/gsc.c +++ b/board/gateworks/gw_ventana/gsc.c @@ -71,6 +71,8 @@ static void read_hwmon(const char *name, uint reg, uint size) puts("fRD\n"); } else { ui = buf[0] | (buf[1]<<8) | (buf[2]<<16); + if (reg == GSC_HWMON_TEMP && ui > 0x8000) + ui -= 0xffff; if (ui == 0xffffff) puts("invalid\n"); else
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gsc.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/board/gateworks/gw_ventana/gsc.c b/board/gateworks/gw_ventana/gsc.c index c626ba2..042f55a 100644 --- a/board/gateworks/gw_ventana/gsc.c +++ b/board/gateworks/gw_ventana/gsc.c @@ -98,6 +98,12 @@ int gsc_info(int verbose) gsc_i2c_write(GSC_SC_ADDR, GSC_SC_STATUS, 1, &buf[GSC_SC_STATUS], 1); } + if (!gsc_i2c_read(GSC_HWMON_ADDR, GSC_HWMON_TEMP, 1, buf, 2)) { + int ui = buf[0] | buf[1]<<8; + if (ui > 0x8000) + ui -= 0xffff; + printf(" board temp at %dC", ui / 10); + } puts("\n"); if (!verbose) return CMD_RET_SUCCESS;
Calling request_gpio to register bklt_gpio with the GPIO driver had no effect in setup_display called from early board init (although pinmuxing it and configuring it as output-low does do what it should). Therefore move the request_gpio later in enable_lvds so that its registered for use by the gpio command if LVDS is actually enabled.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/gw_ventana.c | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 3b7c82b..7a3d96a 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -317,6 +317,8 @@ static void enable_lvds(struct display_info_t const *dev) writel(reg, &iomux->gpr[2]);
/* Enable Backlight */ + gpio_request(IMX_GPIO_NR(1, 10), "bklt_gpio"); + gpio_direction_output(IMX_GPIO_NR(1, 10), 0); gpio_request(IMX_GPIO_NR(1, 18), "bklt_en"); SETUP_IOMUX_PAD(PAD_SD1_CMD__GPIO1_IO18 | DIO_PAD_CFG); gpio_direction_output(IMX_GPIO_NR(1, 18), 1); @@ -456,8 +458,7 @@ static void setup_display(void) <<IOMUXC_GPR3_LVDS0_MUX_CTL_OFFSET); writel(reg, &iomux->gpr[3]);
- /* Backlight CABEN on LVDS connector */ - gpio_request(IMX_GPIO_NR(1, 10), "bklt_gpio"); + /* LVDS Backlight GPIO on LVDS connector - output low */ SETUP_IOMUX_PAD(PAD_SD2_CLK__GPIO1_IO10 | DIO_PAD_CFG); gpio_direction_output(IMX_GPIO_NR(1, 10), 0); }
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index a20190e..7610381 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -760,7 +760,7 @@ void setup_board_gpio(int board, struct ventana_board_info *info) ctrl); gpio_requestf(cfg->gpio_param, "dio%d", i); gpio_direction_input(cfg->gpio_param); - } else if (hwconfig_subarg_cmp("dio2", "mode", "pwm") && + } else if (hwconfig_subarg_cmp(arg, "mode", "pwm") && cfg->pwm_padmux) { if (!quiet) printf("DIO%d: pwm%d\n", i, cfg->pwm_param);
Most Ventana boards have a connector with off-board digital-I/O signals including some that can be pinmuxed as either a PWM or a GPIO. The hwconfig env variable is used to configure these and they will be pinmuxed according to this configuration in the bootloader.
This patch adds a device-tree fixup that will enable the pwm controller nodes appropriately for digital-I/O's that are configured as pwm via hwconfig so that the pin can be used with the Linux kernel /sys/class/pwm API.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 5 +++++ board/gateworks/gw_ventana/gw_ventana.c | 30 ++++++++++++++++++++++++++++++ 2 files changed, 35 insertions(+)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 7610381..44ee73f 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -762,6 +762,11 @@ void setup_board_gpio(int board, struct ventana_board_info *info) gpio_direction_input(cfg->gpio_param); } else if (hwconfig_subarg_cmp(arg, "mode", "pwm") && cfg->pwm_padmux) { + if (!cfg->pwm_param) { + printf("DIO%d: Error: pwm config invalid\n", + i); + continue; + } if (!quiet) printf("DIO%d: pwm%d\n", i, cfg->pwm_param); imx_iomux_v3_setup_pad(cfg->pwm_padmux[cputype] | diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 7a3d96a..feb2df8 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -21,6 +21,7 @@ #include <asm/io.h> #include <dm.h> #include <dm/platform_data/serial_mxc.h> +#include <hwconfig.h> #include <i2c.h> #include <fdt_support.h> #include <fsl_esdhc.h> @@ -777,6 +778,16 @@ static int ft_sethdmiinfmt(void *blob, char *mode) return 0; }
+/* enable a property of a node if the node is found */ +static inline void ft_enable_path(void *blob, const char *path) +{ + int i = fdt_path_offset(blob, path); + if (i >= 0) { + debug("enabling %s\n", path); + fdt_status_okay(blob, i); + } +} + /* * called prior to booting kernel or by 'fdt boardsetup' command * @@ -920,6 +931,25 @@ int ft_board_setup(void *blob, bd_t *bd) ft_sethdmiinfmt(blob, "yuv422bt656"); }
+ /* Configure DIO */ + for (i = 0; i < gpio_cfg[board_type].num_gpios; i++) { + struct dio_cfg *cfg = &gpio_cfg[board_type].dio_cfg[i]; + char arg[10]; + + sprintf(arg, "dio%d", i); + if (!hwconfig(arg)) + continue; + if (hwconfig_subarg_cmp(arg, "mode", "pwm") && cfg->pwm_param) + { + char path[48]; + sprintf(path, "/soc/aips-bus@02000000/pwm@%08x", + 0x02080000 + (0x4000 * (cfg->pwm_param - 1))); + printf(" Enabling pwm%d for DIO%d\n", + cfg->pwm_param, i); + ft_enable_path(blob, path); + } + } + /* * Peripheral Config: * remove nodes by alias path if EEPROM config tells us the
The MSATA feature is a board-specific feature on Gateworks Ventana boards.
In most cases a 2:1 mux will steer either PCIe or SATA to a miniPCIe socket through an MSATA_EN gpio. In these such cases assign the gpio in the board specific struct and use its presence to determine if we default the GPIO to PCIe and if we later steer it according to hwconfig.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 32 +++++++++++++++++++++----------- board/gateworks/gw_ventana/common.h | 1 + 2 files changed, 22 insertions(+), 11 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 44ee73f..5a8bacd 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -132,8 +132,6 @@ void setup_ventana_i2c(void)
/* common to add baseboards */ static iomux_v3_cfg_t const gw_gpio_pads[] = { - /* MSATA_EN */ - IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* RS232_EN# */ IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), }; @@ -183,6 +181,8 @@ static iomux_v3_cfg_t const gw51xx_gpio_pads[] = { };
static iomux_v3_cfg_t const gw52xx_gpio_pads[] = { + /* MSATA_EN */ + IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* PANLEDG# */ IOMUX_PADS(PAD_KEY_COL0__GPIO4_IO06 | DIO_PAD_CFG), /* PANLEDR# */ @@ -212,6 +212,8 @@ static iomux_v3_cfg_t const gw52xx_gpio_pads[] = { };
static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { + /* MSATA_EN */ + IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* USB_HUBRST# */ @@ -241,6 +243,8 @@ static iomux_v3_cfg_t const gw53xx_gpio_pads[] = { };
static iomux_v3_cfg_t const gw54xx_gpio_pads[] = { + /* MSATA_EN */ + IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* CAN_STBY */ IOMUX_PADS(PAD_GPIO_2__GPIO1_IO02 | DIO_PAD_CFG), /* PANLEDG# */ @@ -283,6 +287,8 @@ static iomux_v3_cfg_t const gw551x_gpio_pads[] = { };
static iomux_v3_cfg_t const gw552x_gpio_pads[] = { + /* MSATA_EN */ + IOMUX_PADS(PAD_SD4_DAT0__GPIO2_IO08 | DIO_PAD_CFG), /* USBOTG_SEL */ IOMUX_PADS(PAD_GPIO_7__GPIO1_IO07 | DIO_PAD_CFG), /* USB_HUBRST# */ @@ -445,6 +451,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .vidin_en = IMX_GPIO_NR(3, 31), .usb_sel = IMX_GPIO_NR(1, 2), .wdis = IMX_GPIO_NR(7, 12), + .msata_en = GP_MSATA_SEL, },
/* GW53xx */ @@ -489,6 +496,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .gps_shdn = IMX_GPIO_NR(1, 27), .vidin_en = IMX_GPIO_NR(3, 31), .wdis = IMX_GPIO_NR(7, 12), + .msata_en = GP_MSATA_SEL, },
/* GW54xx */ @@ -535,6 +543,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .dioi2c_en = IMX_GPIO_NR(4, 5), .pcie_sson = IMX_GPIO_NR(1, 20), .wdis = IMX_GPIO_NR(5, 17), + .msata_en = GP_MSATA_SEL, },
/* GW551x */ @@ -602,6 +611,7 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .pcie_rst = IMX_GPIO_NR(1, 29), .usb_sel = IMX_GPIO_NR(1, 7), .wdis = IMX_GPIO_NR(7, 12), + .msata_en = GP_MSATA_SEL, }, };
@@ -616,10 +626,6 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) gpio_request(GP_USB_OTG_PWR, "usbotg_pwr"); gpio_direction_output(GP_USB_OTG_PWR, 0);
- /* MSATA Enable - default to PCI */ - gpio_request(GP_MSATA_SEL, "msata_en"); - gpio_direction_output(GP_MSATA_SEL, 0); - /* RS232_EN# */ gpio_request(GP_RS232_EN, "rs232_en"); gpio_direction_output(GP_RS232_EN, 0); @@ -649,6 +655,12 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) } }
+ /* MSATA Enable - default to PCI */ + if (gpio_cfg[board].msata_en) { + gpio_request(gpio_cfg[board].msata_en, "msata_en"); + gpio_direction_output(gpio_cfg[board].msata_en, 0); + } + /* Expansion Mezzanine IO */ if (gpio_cfg[board].mezz_pwren) { gpio_request(gpio_cfg[board].mezz_pwren, "mezz_pwr"); @@ -718,10 +730,9 @@ void setup_board_gpio(int board, struct ventana_board_info *info) gpio_direction_output(GP_RS232_EN, (hwconfig("rs232")) ? 0 : 1);
/* MSATA Enable */ - if (is_cpu_type(MXC_CPU_MX6Q) && - test_bit(EECONFIG_SATA, info->config)) { + if (gpio_cfg[board].msata_en && is_cpu_type(MXC_CPU_MX6Q)) { gpio_direction_output(GP_MSATA_SEL, - (hwconfig("msata")) ? 1 : 0); + (hwconfig("msata")) ? 1 : 0); }
/* USBOTG Select (PCISKT or FrontPanel) */ @@ -775,8 +786,7 @@ void setup_board_gpio(int board, struct ventana_board_info *info) }
if (!quiet) { - if (is_cpu_type(MXC_CPU_MX6Q) && - (test_bit(EECONFIG_SATA, info->config))) { + if (gpio_cfg[board].msata_en && is_cpu_type(MXC_CPU_MX6Q)) { printf("MSATA: %s\n", (hwconfig("msata") ? "enabled" : "disabled")); } diff --git a/board/gateworks/gw_ventana/common.h b/board/gateworks/gw_ventana/common.h index 28f5816..58ad5ff 100644 --- a/board/gateworks/gw_ventana/common.h +++ b/board/gateworks/gw_ventana/common.h @@ -76,6 +76,7 @@ struct ventana { int pcie_sson; int usb_sel; int wdis; + int msata_en; };
extern struct ventana gpio_cfg[GW_UNKNOWN];
Removed several EEPROM bit dependencies: - for dt aliases that don't exist and thus don't ever do anything (pcie,lvds1,uart*,vpu,csi*,hdmi_in,hdmi_out,cvbs_in,cvbs_out,gps) - for features that don't effect bus ordering or have no detrimental affect if erroneously enabled when not present (ahci,nand,i2c*) - for features that have little to no impact on being erroneously enabled but high impact if erroneously disabled (can*, spi*) - for features that have an high adverse affect of not being set when they should and no adverse affect of being set when they shouldn't (ipu*).
Removing these means the following: - these no longer are supported with the econfig command - these no longer affect the device-tree in any way
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/eeprom.c | 31 ------------------------------- 1 file changed, 31 deletions(-)
diff --git a/board/gateworks/gw_ventana/eeprom.c b/board/gateworks/gw_ventana/eeprom.c index ba15969..e86c98e 100644 --- a/board/gateworks/gw_ventana/eeprom.c +++ b/board/gateworks/gw_ventana/eeprom.c @@ -100,43 +100,12 @@ read_eeprom(int bus, struct ventana_board_info *info) /* list of config bits that the bootloader will remove from dtb if not set */ struct ventana_eeprom_config econfig[] = { { "eth0", "ethernet0", EECONFIG_ETH0 }, - { "eth1", "ethernet1", EECONFIG_ETH1 }, - { "sata", "ahci0", EECONFIG_SATA }, - { "pcie", NULL, EECONFIG_PCIE}, - { "lvds0", NULL, EECONFIG_LVDS0 }, - { "lvds1", NULL, EECONFIG_LVDS1 }, { "usb0", NULL, EECONFIG_USB0 }, { "usb1", NULL, EECONFIG_USB1 }, { "mmc0", NULL, EECONFIG_SD0 }, { "mmc1", NULL, EECONFIG_SD1 }, { "mmc2", NULL, EECONFIG_SD2 }, { "mmc3", NULL, EECONFIG_SD3 }, - { "uart0", NULL, EECONFIG_UART0 }, - { "uart1", NULL, EECONFIG_UART1 }, - { "uart2", NULL, EECONFIG_UART2 }, - { "uart3", NULL, EECONFIG_UART3 }, - { "uart4", NULL, EECONFIG_UART4 }, - { "ipu0", NULL, EECONFIG_IPU0 }, - { "ipu1", NULL, EECONFIG_IPU1 }, - { "can0", NULL, EECONFIG_FLEXCAN }, - { "i2c0", NULL, EECONFIG_I2C0 }, - { "i2c1", NULL, EECONFIG_I2C1 }, - { "i2c2", NULL, EECONFIG_I2C2 }, - { "vpu", NULL, EECONFIG_VPU }, - { "csi0", NULL, EECONFIG_CSI0 }, - { "csi1", NULL, EECONFIG_CSI1 }, - { "spi0", NULL, EECONFIG_ESPCI0 }, - { "spi1", NULL, EECONFIG_ESPCI1 }, - { "spi2", NULL, EECONFIG_ESPCI2 }, - { "spi3", NULL, EECONFIG_ESPCI3 }, - { "spi4", NULL, EECONFIG_ESPCI4 }, - { "spi5", NULL, EECONFIG_ESPCI5 }, - { "gps", "pps", EECONFIG_GPS }, - { "hdmi_in", NULL, EECONFIG_HDMI_IN }, - { "hdmi_out", NULL, EECONFIG_HDMI_OUT }, - { "cvbs_in", NULL, EECONFIG_VID_IN }, - { "cvbs_out", NULL, EECONFIG_VID_OUT }, - { "nand", NULL, EECONFIG_NAND }, { /* Sentinel */ } };
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 54 +++++++++++++++++++++++++++++ board/gateworks/gw_ventana/eeprom.c | 3 ++ board/gateworks/gw_ventana/gsc.c | 3 +- board/gateworks/gw_ventana/gw_ventana.c | 8 +++-- board/gateworks/gw_ventana/ventana_eeprom.h | 1 + 5 files changed, 66 insertions(+), 3 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 5a8bacd..2c3ac93 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -316,6 +316,20 @@ static iomux_v3_cfg_t const gw552x_gpio_pads[] = { IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), };
+static iomux_v3_cfg_t const gw553x_gpio_pads[] = { + /* PANLEDG# */ + IOMUX_PADS(PAD_KEY_COL2__GPIO4_IO10 | DIO_PAD_CFG), + /* PANLEDR# */ + IOMUX_PADS(PAD_KEY_ROW2__GPIO4_IO11 | DIO_PAD_CFG), + + /* VID_PWR */ + IOMUX_PADS(PAD_CSI0_DATA_EN__GPIO5_IO20 | DIO_PAD_CFG), + /* PCI_RST# */ + IOMUX_PADS(PAD_GPIO_0__GPIO1_IO00 | DIO_PAD_CFG), + /* PCIESKT_WDIS# */ + IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | DIO_PAD_CFG), +}; +
/* * Board Specific GPIO @@ -613,6 +627,46 @@ struct ventana gpio_cfg[GW_UNKNOWN] = { .wdis = IMX_GPIO_NR(7, 12), .msata_en = GP_MSATA_SEL, }, + + /* GW553x */ + { + .gpio_pads = gw553x_gpio_pads, + .num_pads = ARRAY_SIZE(gw553x_gpio_pads)/2, + .dio_cfg = { + { + { IOMUX_PADS(PAD_SD1_DAT0__GPIO1_IO16) }, + IMX_GPIO_NR(1, 16), + { 0, 0 }, + 0 + }, + { + { IOMUX_PADS(PAD_SD1_DAT2__GPIO1_IO19) }, + IMX_GPIO_NR(1, 19), + { IOMUX_PADS(PAD_SD1_DAT2__PWM2_OUT) }, + 2 + }, + { + { IOMUX_PADS(PAD_SD1_DAT1__GPIO1_IO17) }, + IMX_GPIO_NR(1, 17), + { IOMUX_PADS(PAD_SD1_DAT1__PWM3_OUT) }, + 3 + }, + { + { IOMUX_PADS(PAD_SD1_CMD__GPIO1_IO18) }, + IMX_GPIO_NR(1, 18), + { IOMUX_PADS(PAD_SD1_CMD__PWM4_OUT) }, + 4 + }, + }, + .num_gpios = 4, + .leds = { + IMX_GPIO_NR(4, 10), + IMX_GPIO_NR(4, 11), + }, + .pcie_rst = IMX_GPIO_NR(1, 0), + .vidin_en = IMX_GPIO_NR(5, 20), + .wdis = IMX_GPIO_NR(7, 12), + }, };
void setup_iomux_gpio(int board, struct ventana_board_info *info) diff --git a/board/gateworks/gw_ventana/eeprom.c b/board/gateworks/gw_ventana/eeprom.c index e86c98e..1382e5d 100644 --- a/board/gateworks/gw_ventana/eeprom.c +++ b/board/gateworks/gw_ventana/eeprom.c @@ -87,6 +87,9 @@ read_eeprom(int bus, struct ventana_board_info *info) } else if (info->model[4] == '2') { type = GW552x; break; + } else if (info->model[4] == '3') { + type = GW553x; + break; } /* fall through */ default: diff --git a/board/gateworks/gw_ventana/gsc.c b/board/gateworks/gw_ventana/gsc.c index 042f55a..2ca6d5c 100644 --- a/board/gateworks/gw_ventana/gsc.c +++ b/board/gateworks/gw_ventana/gsc.c @@ -117,7 +117,8 @@ int gsc_info(int verbose) read_hwmon("VDD_HIGH", GSC_HWMON_VDD_HIGH, 3); read_hwmon("VDD_DDR", GSC_HWMON_VDD_DDR, 3); read_hwmon("VDD_5P0", GSC_HWMON_VDD_5P0, 3); - read_hwmon("VDD_2P5", GSC_HWMON_VDD_2P5, 3); + if (strncasecmp((const char*) ventana_info.model, "GW553", 5)) + read_hwmon("VDD_2P5", GSC_HWMON_VDD_2P5, 3); read_hwmon("VDD_1P8", GSC_HWMON_VDD_1P8, 3); read_hwmon("VDD_IO2", GSC_HWMON_VDD_IO2, 3); switch (ventana_info.model[3]) { diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index feb2df8..15e4bf1 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -267,7 +267,9 @@ int board_phy_config(struct phy_device *phydev) int board_eth_init(bd_t *bis) { #ifdef CONFIG_FEC_MXC - if (board_type != GW551x && board_type != GW552x) { + struct ventana_board_info *info = &ventana_info; + + if (test_bit(EECONFIG_ETH0, info->config)) { setup_iomux_enet(GP_PHY_RST); cpu_eth_init(bis); } @@ -699,7 +701,9 @@ int misc_init_r(void) setenv("model_base", str); sprintf(fdt, "%s-%s.dtb", cputype, str); setenv("fdt_file1", fdt); - if (board_type != GW551x && board_type != GW552x) + if (board_type != GW551x && + board_type != GW552x && + board_type != GW553x) str[4] = 'x'; str[5] = 'x'; str[6] = 0; diff --git a/board/gateworks/gw_ventana/ventana_eeprom.h b/board/gateworks/gw_ventana/ventana_eeprom.h index daff375..9ffad58 100644 --- a/board/gateworks/gw_ventana/ventana_eeprom.h +++ b/board/gateworks/gw_ventana/ventana_eeprom.h @@ -111,6 +111,7 @@ enum { GW54xx, GW551x, GW552x, + GW553x, GW_UNKNOWN, GW_BADCRC, };
UHS-I support is available on Ventana boards with micro-SD sockets depending on the board revision. For backwards compatibility to not break users who have old bootloaders and newer kernels the device-tree on boards with microSD disables UHS-I support by default by defining the no-1-8-v property in the esdhc controller node. For models/revisions that support switchable 1.8V/3.3V I/O which is detectable by the presence of a pull-down on the SD3_VSELECT pin we remove that property to enable support in the kernel.
Additionally we add SD3_VSELECT to the pinmux for clarity (even though U-Boot does not currently support UHS-I modes requiring 1.8V I/O).
Signed-off-by: Tim Harvey tharvey@gateworks.com --- board/gateworks/gw_ventana/common.c | 7 +++++++ board/gateworks/gw_ventana/common.h | 2 ++ board/gateworks/gw_ventana/gw_ventana.c | 26 ++++++++++++++++++++++++-- 3 files changed, 33 insertions(+), 2 deletions(-)
diff --git a/board/gateworks/gw_ventana/common.c b/board/gateworks/gw_ventana/common.c index 2c3ac93..929dde9 100644 --- a/board/gateworks/gw_ventana/common.c +++ b/board/gateworks/gw_ventana/common.c @@ -134,6 +134,8 @@ void setup_ventana_i2c(void) static iomux_v3_cfg_t const gw_gpio_pads[] = { /* RS232_EN# */ IOMUX_PADS(PAD_SD4_DAT3__GPIO2_IO11 | DIO_PAD_CFG), + /* SD3_VSELECT */ + IOMUX_PADS(PAD_NANDF_CS1__GPIO6_IO14 | DIO_PAD_CFG), };
/* prototype */ @@ -766,6 +768,11 @@ void setup_iomux_gpio(int board, struct ventana_board_info *info) gpio_request(gpio_cfg[board].wdis, "wlan_dis"); gpio_direction_output(gpio_cfg[board].wdis, 1); } + + /* sense vselect pin to see if we support uhs-i */ + gpio_request(GP_SD3_VSELECT, "sd3_vselect"); + gpio_direction_input(GP_SD3_VSELECT); + gpio_cfg[board].usd_vsel = !gpio_get_value(GP_SD3_VSELECT); }
/* setup GPIO pinmux and default configuration per baseboard and env */ diff --git a/board/gateworks/gw_ventana/common.h b/board/gateworks/gw_ventana/common.h index 58ad5ff..d037767 100644 --- a/board/gateworks/gw_ventana/common.h +++ b/board/gateworks/gw_ventana/common.h @@ -17,6 +17,7 @@ #define GP_SD3_CD IMX_GPIO_NR(7, 0) #define GP_RS232_EN IMX_GPIO_NR(2, 11) #define GP_MSATA_SEL IMX_GPIO_NR(2, 8) +#define GP_SD3_VSELECT IMX_GPIO_NR(6, 14)
#define UART_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ @@ -77,6 +78,7 @@ struct ventana { int usb_sel; int wdis; int msata_en; + bool usd_vsel; };
extern struct ventana gpio_cfg[GW_UNKNOWN]; diff --git a/board/gateworks/gw_ventana/gw_ventana.c b/board/gateworks/gw_ventana/gw_ventana.c index 15e4bf1..82313e8 100644 --- a/board/gateworks/gw_ventana/gw_ventana.c +++ b/board/gateworks/gw_ventana/gw_ventana.c @@ -60,8 +60,7 @@ static iomux_v3_cfg_t const usdhc3_pads[] = { IOMUX_PADS(PAD_SD3_DAT1__SD3_DATA1 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), IOMUX_PADS(PAD_SD3_DAT2__SD3_DATA2 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), IOMUX_PADS(PAD_SD3_DAT3__SD3_DATA3 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), - /* CD */ - IOMUX_PADS(PAD_SD3_DAT5__GPIO7_IO00 | MUX_PAD_CTRL(IRQ_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT5__GPIO7_IO00 | MUX_PAD_CTRL(USDHC_PAD_CTRL)), };
/* ENET */ @@ -792,6 +791,17 @@ static inline void ft_enable_path(void *blob, const char *path) } }
+/* remove a property of a node if the node is found */ +static inline void ft_delprop_path(void *blob, const char *path, + const char *name) +{ + int i = fdt_path_offset(blob, path); + if (i) { + debug("removing %s/%s\n", path, name); + fdt_delprop(blob, i, name); + } +} + /* * called prior to booting kernel or by 'fdt boardsetup' command * @@ -895,6 +905,11 @@ int ft_board_setup(void *blob, bd_t *bd) range[1] = cpu_to_fdt32(23); } } + + /* these have broken usd_vsel */ + if (strstr((const char *)info->model, "SP318-B") || + strstr((const char *)info->model, "SP331-B")) + gpio_cfg[board_type].usd_vsel = 0; }
/* @@ -954,6 +969,13 @@ int ft_board_setup(void *blob, bd_t *bd) } }
+ /* remove no-1-8-v if UHS-I support is present */ + if (gpio_cfg[board_type].usd_vsel) { + debug("Enabling UHS-I support\n"); + ft_delprop_path(blob, "/soc/aips-bus@02100000/usdhc@02198000", + "no-1-8-v"); + } + /* * Peripheral Config: * remove nodes by alias path if EEPROM config tells us the
-- 1.9.1
Stefano,
Any comment on these? I've got a few more after this.
Regards,
Tim
Hi Tim,
-- 1.9.1
Stefano,
I have merged the patchset 10 days ago...they are part of my last PR, too.
Best regards, Stefano
Stefano Babic
Tim Harvey
