[U-Boot] [PATCH 1/2] tools/env: complete environment device config early
Currently flash_read completes a crucial part of the environment device configuration, the device type (mtd_type). This is rather confusing as flash_io calls flash_read conditionally, and one might think flash_write, which also makes use of mtd_type, gets called before flash_read. But since flash_io is always called with O_RDONLY first, this is not actually the case in reality.
However, it is much cleaner to complete and verify the config early in parse_config. This also prepares the code for further extension.
Signed-off-by: Stefan Agner stefan.agner@toradex.com ---
tools/env/fw_env.c | 110 +++++++++++++++++++++++++++++------------------------ 1 file changed, 60 insertions(+), 50 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 692abda..06d6865 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -1021,41 +1021,10 @@ static int flash_write (int fd_current, int fd_target, int dev_target)
static int flash_read (int fd) { - struct mtd_info_user mtdinfo; - struct stat st; int rc;
- rc = fstat(fd, &st); - if (rc < 0) { - fprintf(stderr, "Cannot stat the file %s\n", - DEVNAME(dev_current)); - return -1; - } - - if (S_ISCHR(st.st_mode)) { - rc = ioctl(fd, MEMGETINFO, &mtdinfo); - if (rc < 0) { - fprintf(stderr, "Cannot get MTD information for %s\n", - DEVNAME(dev_current)); - return -1; - } - if (mtdinfo.type != MTD_NORFLASH && - mtdinfo.type != MTD_NANDFLASH && - mtdinfo.type != MTD_DATAFLASH && - mtdinfo.type != MTD_UBIVOLUME) { - fprintf (stderr, "Unsupported flash type %u on %s\n", - mtdinfo.type, DEVNAME(dev_current)); - return -1; - } - } else { - memset(&mtdinfo, 0, sizeof(mtdinfo)); - mtdinfo.type = MTD_ABSENT; - } - - DEVTYPE(dev_current) = mtdinfo.type; - rc = flash_read_buf(dev_current, fd, environment.image, CUR_ENVSIZE, - DEVOFFSET (dev_current), mtdinfo.type); + DEVOFFSET(dev_current), DEVTYPE(dev_current)); if (rc != CUR_ENVSIZE) return -1;
@@ -1328,10 +1297,55 @@ int fw_env_open(struct env_opts *opts) return 0; }
+static int check_device_config(int dev) +{ + struct stat st; + int fd, rc = 0; + + fd = open(DEVNAME(dev), O_RDONLY); + if (fd < 0) { + fprintf(stderr, + "Cannot open %s: %s\n", + DEVNAME(dev), strerror(errno)); + return -1; + } + + rc = fstat(fd, &st); + if (rc < 0) { + fprintf(stderr, "Cannot stat the file %s\n", + DEVNAME(dev)); + goto err; + } + + if (S_ISCHR(st.st_mode)) { + struct mtd_info_user mtdinfo; + rc = ioctl(fd, MEMGETINFO, &mtdinfo); + if (rc < 0) { + fprintf(stderr, "Cannot get MTD information for %s\n", + DEVNAME(dev)); + goto err; + } + if (mtdinfo.type != MTD_NORFLASH && + mtdinfo.type != MTD_NANDFLASH && + mtdinfo.type != MTD_DATAFLASH && + mtdinfo.type != MTD_UBIVOLUME) { + fprintf(stderr, "Unsupported flash type %u on %s\n", + mtdinfo.type, DEVNAME(dev)); + goto err; + } + DEVTYPE(dev) = mtdinfo.type; + } else { + DEVTYPE(dev) = MTD_ABSENT; + } + +err: + close(fd); + return rc; +}
static int parse_config(struct env_opts *opts) { - struct stat st; + int rc;
if (!opts) opts = &default_opts; @@ -1375,25 +1389,21 @@ static int parse_config(struct env_opts *opts) HaveRedundEnv = 1; #endif #endif - if (stat (DEVNAME (0), &st)) { - fprintf (stderr, - "Cannot access MTD device %s: %s\n", - DEVNAME (0), strerror (errno)); - return -1; - } + rc = check_device_config(0); + if (rc < 0) + return rc;
- if (HaveRedundEnv && stat (DEVNAME (1), &st)) { - fprintf (stderr, - "Cannot access MTD device %s: %s\n", - DEVNAME (1), strerror (errno)); - return -1; - } + if (HaveRedundEnv) { + rc = check_device_config(1); + if (rc < 0) + return rc;
- if (HaveRedundEnv && ENVSIZE(0) != ENVSIZE(1)) { - ENVSIZE(0) = ENVSIZE(1) = min(ENVSIZE(0), ENVSIZE(1)); - fprintf(stderr, - "Redundant environments have inequal size, set to 0x%08lx\n", - ENVSIZE(1)); + if (ENVSIZE(0) != ENVSIZE(1)) { + ENVSIZE(0) = ENVSIZE(1) = min(ENVSIZE(0), ENVSIZE(1)); + fprintf(stderr, + "Redundant environments have inequal size, set to 0x%08lx\n", + ENVSIZE(1)); + } }
usable_envsize = CUR_ENVSIZE - sizeof(uint32_t);
A negative value for the offset is treated as a backwards offset for from the end of the device/partition for block devices. This aligns the behavior of the config file with the syntax of CONFIG_ENV_OFFSET where the functionality has been introduced with commit 5c088ee841f9 ("env_mmc: allow negative CONFIG_ENV_OFFSET").
tools/env/fw_env.c | 39 ++++++++++++++++++++++++++++++--------- tools/env/fw_env.config | 5 +++++ 2 files changed, 35 insertions(+), 9 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 06d6865..be338a5b 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -14,6 +14,7 @@ #include <errno.h> #include <env_flags.h> #include <fcntl.h> +#include <linux/fs.h> #include <linux/stringify.h> #include <ctype.h> #include <stdio.h> @@ -51,7 +52,7 @@ struct env_opts default_opts = {
struct envdev_s { const char *devname; /* Device name */ - ulong devoff; /* Device offset */ + long long devoff; /* Device offset */ ulong env_size; /* environment size */ ulong erase_size; /* device erase size */ ulong env_sectors; /* number of environment sectors */ @@ -994,7 +995,7 @@ static int flash_write (int fd_current, int fd_target, int dev_target) }
#ifdef DEBUG - fprintf(stderr, "Writing new environment at 0x%lx on %s\n", + fprintf(stderr, "Writing new environment at 0x%llx on %s\n", DEVOFFSET (dev_target), DEVNAME (dev_target)); #endif
@@ -1010,7 +1011,7 @@ static int flash_write (int fd_current, int fd_target, int dev_target) offsetof (struct env_image_redundant, flags); #ifdef DEBUG fprintf(stderr, - "Setting obsolete flag in environment at 0x%lx on %s\n", + "Setting obsolete flag in environment at 0x%llx on %s\n", DEVOFFSET (dev_current), DEVNAME (dev_current)); #endif flash_flag_obsolete (dev_current, fd_current, offset); @@ -1335,7 +1336,27 @@ static int check_device_config(int dev) } DEVTYPE(dev) = mtdinfo.type; } else { + uint64_t size; DEVTYPE(dev) = MTD_ABSENT; + + /* + * Check for negative offsets, treat it as backwards offset + * from the end of the block device + */ + if (DEVOFFSET(dev) < 0) { + rc = ioctl(fd, BLKGETSIZE64, &size); + if (rc < 0) { + fprintf(stderr, "Could not get block device size on %s\n", + DEVNAME(dev)); + goto err; + } + + DEVOFFSET(dev) = DEVOFFSET(dev) + size; +#ifdef DEBUG + fprintf(stderr, "Calculated device offset 0x%llx on %s\n", + DEVOFFSET(dev), DEVNAME(dev)); +#endif + } }
err: @@ -1434,12 +1455,12 @@ static int get_config (char *fname) if (dump[0] == '#') continue;
- rc = sscanf (dump, "%ms %lx %lx %lx %lx", - &devname, - &DEVOFFSET (i), - &ENVSIZE (i), - &DEVESIZE (i), - &ENVSECTORS (i)); + rc = sscanf(dump, "%ms %lli %lx %lx %lx", + &devname, + &DEVOFFSET(i), + &ENVSIZE(i), + &DEVESIZE(i), + &ENVSECTORS(i));
if (rc < 3) continue; diff --git a/tools/env/fw_env.config b/tools/env/fw_env.config index 6f216f9..f0f66aa 100644 --- a/tools/env/fw_env.config +++ b/tools/env/fw_env.config @@ -4,6 +4,7 @@ # Notice, that the "Number of sectors" is not required on NOR and SPI-dataflash. # Futhermore, if the Flash sector size is ommitted, this value is assumed to # be the same as the Environment size, which is valid for NOR and SPI-dataflash +# Device offset must be prefixed with 0x to be parsed as a hexadecimal value.
# NOR example # MTD device name Device offset Env. size Flash sector size Number of sectors @@ -18,8 +19,12 @@ # NAND example #/dev/mtd0 0x4000 0x4000 0x20000 2
+# On a block device a negative offset is treated as a backwards offset from the +# end of the device/partition, rather than a forwards offset from the start. + # Block device example #/dev/mmcblk0 0xc0000 0x20000 +#/dev/mmcblk0 -0x20000 0x20000
# VFAT example #/boot/uboot.env 0x0000 0x4000
2016-07-14 2:14 GMT+02:00 Stefan Agner stefan@agner.ch:
lgtm
#ifdef DEBUG
#endif
if (rc < 0) {
DEVNAME(dev));
goto err;
I wonder if we need a check, that the redundant areas don't overlap. But we can add that later
+#ifdef DEBUG
&devname,
&DEVOFFSET (i),
&ENVSIZE (i),
&DEVESIZE (i),
&ENVSECTORS (i));
&devname,
&DEVOFFSET(i),
&ENVSIZE(i),
&DEVESIZE(i),
&ENVSECTORS(i)); if (rc < 3) continue;
# VFAT example
2.9.0
lgtm
#ifdef DEBUG
#endif
if (rc < 0) {
DEVNAME(dev));
goto err;
We haven't had it before, but yeah I agree it would be a sensible thing to do. And we have now a good place to add such checks...
-- Stefan
+#ifdef DEBUG
&devname,
&DEVOFFSET (i),
&ENVSIZE (i),
&DEVESIZE (i),
&ENVSECTORS (i));
&devname,
&DEVOFFSET(i),
&ENVSIZE(i),
&DEVESIZE(i),
# VFAT example
2.9.0
Reviewed-by: Andreas Fenkart
if (rc < 0) {
return -1;
if (rc < 0) {
return -1;
return -1;
} else {
struct stat st;
int fd, rc = 0;
if (fd < 0) {
fprintf(stderr,
return -1;
if (rc < 0) {
DEVNAME(dev));
goto err;
if (rc < 0) {
DEVNAME(dev));
goto err;
goto err;
} else {
+err:
close(fd);
return rc;
struct stat st;
int rc; if (!opts) opts = &default_opts;
fprintf (stderr,
return -1;
if (rc < 0)
return rc;
fprintf (stderr,
return -1;
if (rc < 0)
return rc;
fprintf(stderr,
ENVSIZE(1));
fprintf(stderr,
ENVSIZE(1));
} } usable_envsize = CUR_ENVSIZE - sizeof(uint32_t);
-- 2.9.0
Signed-off-by: Stefan Agner stefan.agner@toradex.com Reviewed-by: Andreas Fenkart
Andreas Fenkart
Stefan Agner
