[U-Boot] [PATCH 5/7] omap3: Copy twl4030 device tree from Linux 4.9.y stable
Many OMAP3 boards use a TWL4030 PMIC. This brings in the related device tree information for common TWL4030 and TWL4030 with OMAP3.
Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
diff --git a/arch/arm/dts/twl4030.dtsi b/arch/arm/dts/twl4030.dtsi new file mode 100644 index 0000000..6cb0a01 --- /dev/null +++ b/arch/arm/dts/twl4030.dtsi @@ -0,0 +1,161 @@ +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +/* + * Integrated Power Management Chip + */ +&twl { + compatible = "ti,twl4030"; + interrupt-controller; + #interrupt-cells = <1>; + + rtc { + compatible = "ti,twl4030-rtc"; + interrupts = <11>; + }; + + charger: bci { + compatible = "ti,twl4030-bci"; + interrupts = <9>, <2>; + bci3v1-supply = <&vusb3v1>; + }; + + watchdog { + compatible = "ti,twl4030-wdt"; + }; + + vaux1: regulator-vaux1 { + compatible = "ti,twl4030-vaux1"; + }; + + vaux2: regulator-vaux2 { + compatible = "ti,twl4030-vaux2"; + }; + + vaux3: regulator-vaux3 { + compatible = "ti,twl4030-vaux3"; + }; + + vaux4: regulator-vaux4 { + compatible = "ti,twl4030-vaux4"; + }; + + vcc: regulator-vdd1 { + compatible = "ti,twl4030-vdd1"; + regulator-min-microvolt = <600000>; + regulator-max-microvolt = <1450000>; + }; + + vdac: regulator-vdac { + compatible = "ti,twl4030-vdac"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vio: regulator-vio { + compatible = "ti,twl4030-vio"; + }; + + vintana1: regulator-vintana1 { + compatible = "ti,twl4030-vintana1"; + }; + + vintana2: regulator-vintana2 { + compatible = "ti,twl4030-vintana2"; + }; + + vintdig: regulator-vintdig { + compatible = "ti,twl4030-vintdig"; + }; + + vmmc1: regulator-vmmc1 { + compatible = "ti,twl4030-vmmc1"; + regulator-min-microvolt = <1850000>; + regulator-max-microvolt = <3150000>; + }; + + vmmc2: regulator-vmmc2 { + compatible = "ti,twl4030-vmmc2"; + regulator-min-microvolt = <1850000>; + regulator-max-microvolt = <3150000>; + }; + + vusb1v5: regulator-vusb1v5 { + compatible = "ti,twl4030-vusb1v5"; + }; + + vusb1v8: regulator-vusb1v8 { + compatible = "ti,twl4030-vusb1v8"; + }; + + vusb3v1: regulator-vusb3v1 { + compatible = "ti,twl4030-vusb3v1"; + }; + + vpll1: regulator-vpll1 { + compatible = "ti,twl4030-vpll1"; + }; + + vpll2: regulator-vpll2 { + compatible = "ti,twl4030-vpll2"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vsim: regulator-vsim { + compatible = "ti,twl4030-vsim"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + }; + + twl_gpio: gpio { + compatible = "ti,twl4030-gpio"; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <1>; + }; + + usb2_phy: twl4030-usb { + compatible = "ti,twl4030-usb"; + interrupts = <10>, <4>; + usb1v5-supply = <&vusb1v5>; + usb1v8-supply = <&vusb1v8>; + usb3v1-supply = <&vusb3v1>; + usb_mode = <1>; + #phy-cells = <0>; + }; + + twl_pwm: pwm { + compatible = "ti,twl4030-pwm"; + #pwm-cells = <2>; + }; + + twl_pwmled: pwmled { + compatible = "ti,twl4030-pwmled"; + #pwm-cells = <2>; + }; + + twl_pwrbutton: pwrbutton { + compatible = "ti,twl4030-pwrbutton"; + interrupts = <8>; + }; + + twl_keypad: keypad { + compatible = "ti,twl4030-keypad"; + interrupts = <1>; + keypad,num-rows = <8>; + keypad,num-columns = <8>; + }; + + twl_madc: madc { + compatible = "ti,twl4030-madc"; + interrupts = <3>; + #io-channel-cells = <1>; + }; +}; diff --git a/arch/arm/dts/twl4030_omap3.dtsi b/arch/arm/dts/twl4030_omap3.dtsi new file mode 100644 index 0000000..f9aaa53 --- /dev/null +++ b/arch/arm/dts/twl4030_omap3.dtsi @@ -0,0 +1,42 @@ +/* + * Copyright (C) 2013 Linaro, Ltd. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +&twl { + pinctrl-names = "default"; + pinctrl-0 = <&twl4030_pins &twl4030_vpins>; +}; + +&omap3_pmx_core { + /* + * On most OMAP3 platforms, the twl4030 IRQ line is connected + * to the SYS_NIRQ line on OMAP. Therefore, configure the + * defaults for the SYS_NIRQ pin here. + */ + twl4030_pins: pinmux_twl4030_pins { + pinctrl-single,pins = < + OMAP3_CORE1_IOPAD(0x21e0, PIN_INPUT_PULLUP | PIN_OFF_WAKEUPENABLE | MUX_MODE0) /* sys_nirq.sys_nirq */ + >; + }; +}; + +/* + * If your board is not using the I2C4 pins with twl4030, then don't include + * this file. For proper idle mode signaling with sys_clkreq and sys_off_mode + * pins we need to configure I2C4, or else use the legacy sys_nvmode1 and + * sys_nvmode2 signaling. + */ +&omap3_pmx_wkup { + twl4030_vpins: pinmux_twl4030_vpins { + pinctrl-single,pins = < + OMAP3_WKUP_IOPAD(0x2a00, PIN_INPUT | MUX_MODE0) /* i2c4_scl.i2c4_scl */ + OMAP3_WKUP_IOPAD(0x2a02, PIN_INPUT | MUX_MODE0) /* i2c4_sda.i2c4_sda */ + OMAP3_WKUP_IOPAD(0x2a06, PIN_OUTPUT | MUX_MODE0) /* sys_clkreq.sys_clkreq */ + OMAP3_WKUP_IOPAD(0x2a18, PIN_OUTPUT | MUX_MODE0) /* sys_off_mode.sys_off_mode */ + >; + }; +};
Adam Ford
