[PATCH] imx8mn_beacon: Fix booting hang and switch to binman
Somewhere along the line, the board stopped being able to boot. Rather than just fixing the issue, let's fix the issue and migrate to binman to eliminate a warning when using custom imx tools for generating the binary.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi index bbc64a2819..69fd69c8d0 100644 --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi @@ -4,6 +4,10 @@ */
/ { + binman: binman { + multiple-images; + }; + wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>; @@ -40,6 +44,9 @@ &clk { u-boot,dm-spl; u-boot,dm-pre-reloc; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-parents; + /delete-property/ assigned-clock-rates; };
&gpio1 { @@ -99,6 +106,10 @@ u-boot,off-on-delay-us = <20000>; };
+&uart2 { + u-boot,dm-spl; +}; + &usdhc1 { u-boot,dm-spl; sd-uhs-sdr104; @@ -120,3 +131,122 @@ &wdog1 { u-boot,dm-spl; }; + +&binman { + u-boot-spl-ddr { + filename = "u-boot-spl-ddr.bin"; + pad-byte = <0xff>; + align-size = <4>; + align = <4>; + + u-boot-spl { + align-end = <4>; + }; + + blob_1: blob-ext@1 { + filename = "lpddr4_pmu_train_1d_imem.bin"; + size = <0x8000>; + }; + + blob_2: blob-ext@2 { + filename = "lpddr4_pmu_train_1d_dmem.bin"; + size = <0x4000>; + }; + + blob_3: blob-ext@3 { + filename = "lpddr4_pmu_train_2d_imem.bin"; + size = <0x8000>; + }; + + blob_4: blob-ext@4 { + filename = "lpddr4_pmu_train_2d_dmem.bin"; + size = <0x4000>; + }; + }; + + + spl { + filename = "spl.bin"; + + mkimage { + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; + + blob { + filename = "u-boot-spl-ddr.bin"; + }; + }; + }; + + itb { + filename = "u-boot.itb"; + + fit { + description = "Configuration to load ATF before U-Boot"; + #address-cells = <1>; + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; + + images { + uboot { + description = "U-Boot (64-bit)"; + type = "standalone"; + arch = "arm64"; + compression = "none"; + load = <CONFIG_SYS_TEXT_BASE>; + + uboot_blob: blob-ext { + filename = "u-boot-nodtb.bin"; + }; + }; + + atf { + description = "ARM Trusted Firmware"; + type = "firmware"; + arch = "arm64"; + compression = "none"; + load = <0x960000>; + entry = <0x960000>; + + atf_blob: blob-ext { + filename = "bl31.bin"; + }; + }; + + fdt { + description = "NAME"; + type = "flat_dt"; + compression = "none"; + + uboot_fdt_blob: blob-ext { + filename = "u-boot.dtb"; + }; + }; + }; + + configurations { + default = "conf"; + + conf { + description = "NAME"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt"; + }; + }; + }; + }; + + imx-boot { + filename = "flash.bin"; + pad-byte = <0x00>; + + spl: blob-ext@1 { + offset = <0x0>; + filename = "spl.bin"; + }; + + uboot: blob-ext@2 { + offset = <0x58000>; + filename = "u-boot.itb"; + }; + }; +}; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 8fedf45987..9a1eb108e4 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -116,6 +116,7 @@ config TARGET_IMX8MM_BEACON
config TARGET_IMX8MN_BEACON bool "imx8mn Beacon Embedded devkit" + select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_LPDDR4 diff --git a/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg new file mode 100644 index 0000000000..7286b26494 --- /dev/null +++ b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright 2021 NXP + */ + +#define __ASSEMBLY__ + +ROM_VERSION v2 +BOOT_FROM sd +LOADER u-boot-spl-ddr.bin 0x912000 diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index 5296204aad..f2515874a2 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -26,9 +26,9 @@ CONFIG_LTO=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" +# CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg" +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/beacon/imx8mn/imximage-8mn-lpddr4.cfg" CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" CONFIG_ARCH_MISC_INIT=y CONFIG_SPL_BOARD_INIT=y @@ -36,6 +36,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_I2C=y CONFIG_SPL_POWER=y +CONFIG_SPL_WATCHDOG=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="u-boot=> " # CONFIG_BOOTM_NETBSD is not set @@ -62,7 +63,6 @@ CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent interrupts" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SYS_MMC_ENV_DEV=2 @@ -106,6 +106,7 @@ CONFIG_PHY_GIGE=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PINCTRL=y +CONFIG_SPL_PINCTRL=y CONFIG_PINCTRL_IMX8M=y CONFIG_DM_PMIC=y # CONFIG_SPL_PMIC_CHILDREN is not set @@ -122,7 +123,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_NXP_FSPI=y CONFIG_SYSRESET=y +CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_PSCI=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_USB=y # CONFIG_SPL_DM_USB is not set @@ -134,3 +137,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_SDP_LOADADDR=0x0 CONFIG_OF_LIBFDT_OVERLAY=y +CONFIG_IMX_WATCHDOG=y
- binman: binman {
multiple-images;
- wdt-reboot { compatible = "wdt-reboot"; wdt = <&wdog1>;
&gpio1 {
+&uart2 {
- u-boot,dm-spl;
- &usdhc1 { u-boot,dm-spl; sd-uhs-sdr104;
+&binman {
u-boot-spl-ddr {
pad-byte = <0xff>;
align-size = <4>;
align = <4>;
u-boot-spl {
align-end = <4>;
size = <0x8000>;
size = <0x4000>;
size = <0x8000>;
size = <0x4000>;
- spl {
mkimage {
blob {
- itb {
fit {
images {
uboot {
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x960000>;
entry = <0x960000>;
fdt {
type = "flat_dt";
configurations {
default = "conf";
conf {
firmware = "uboot";
loadables = "atf";
fdt = "fdt";
- imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x58000>;
- select BINMAN select IMX8MN select SUPPORT_SPL select IMX8M_LPDDR4
- Copyright 2021 NXP
Reviewed-by: Peng Fan peng.fan@nxp.com
Any chance this can make it into 2021.10? it's currently broken, and this seems to fix the problem. i didn't bisect to see where the issue broke, or i would have added a fixes tag.
adam
binman: binman {
multiple-images;
&gpio1 {
+&uart2 {
u-boot,dm-spl;
+&binman {
u-boot-spl-ddr {
pad-byte = <0xff>;
align-size = <4>;
align = <4>;
u-boot-spl {
align-end = <4>;
size = <0x8000>;
size = <0x4000>;
size = <0x8000>;
size = <0x4000>;
spl {
mkimage {
blob {
itb {
fit {
images {
uboot {
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x960000>;
entry = <0x960000>;
fdt {
type = "flat_dt";
configurations {
default = "conf";
conf {
firmware = "uboot";
loadables = "atf";
fdt = "fdt";
imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x58000>;
Stefano or Tom? could someone comment and/or merge? the board is currently not booting, and this fixes the issue
adam
binman: binman {
multiple-images;
&gpio1 {
+&uart2 {
u-boot,dm-spl;
+&binman {
u-boot-spl-ddr {
pad-byte = <0xff>;
align-size = <4>;
align = <4>;
u-boot-spl {
align-end = <4>;
size = <0x8000>;
size = <0x4000>;
size = <0x8000>;
size = <0x4000>;
spl {
mkimage {
blob {
itb {
fit {
images {
uboot {
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x960000>;
entry = <0x960000>;
fdt {
type = "flat_dt";
configurations {
default = "conf";
conf {
firmware = "uboot";
loadables = "atf";
fdt = "fdt";
imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x58000>;
It's been over a month, and we missed the 2021.10 release. Is there something stopping this from being applied?
adam
adam
binman: binman {
multiple-images;
&gpio1 {
+&uart2 {
u-boot,dm-spl;
+&binman {
u-boot-spl-ddr {
pad-byte = <0xff>;
align-size = <4>;
align = <4>;
u-boot-spl {
align-end = <4>;
size = <0x8000>;
size = <0x4000>;
size = <0x8000>;
size = <0x4000>;
spl {
mkimage {
blob {
itb {
fit {
images {
uboot {
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x960000>;
entry = <0x960000>;
fdt {
type = "flat_dt";
configurations {
default = "conf";
conf {
firmware = "uboot";
loadables = "atf";
fdt = "fdt";
imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x58000>;
+Tom Rini
Tom,
Is there any chance you can apply this? I can't get anyone to respond to me, and it's been over 2 months since the initial submission.
thanks,
adam
adam
adam
binman: binman {
multiple-images;
&gpio1 {
+&uart2 {
u-boot,dm-spl;
+&binman {
u-boot-spl-ddr {
pad-byte = <0xff>;
align-size = <4>;
align = <4>;
u-boot-spl {
align-end = <4>;
size = <0x8000>;
size = <0x4000>;
size = <0x8000>;
size = <0x4000>;
spl {
mkimage {
blob {
itb {
fit {
images {
uboot {
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x960000>;
entry = <0x960000>;
fdt {
type = "flat_dt";
configurations {
default = "conf";
conf {
firmware = "uboot";
loadables = "atf";
fdt = "fdt";
imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x58000>;
+Tom Rini
Tom,
thanks,
adam
adam
adam
binman: binman {
multiple-images;
&gpio1 {
+&uart2 {
u-boot,dm-spl;
+&binman {
u-boot-spl-ddr {
pad-byte = <0xff>;
align-size = <4>;
align = <4>;
u-boot-spl {
align-end = <4>;
size = <0x8000>;
size = <0x4000>;
size = <0x8000>;
size = <0x4000>;
spl {
mkimage {
blob {
itb {
fit {
images {
uboot {
arch = "arm64";
atf {
type = "firmware";
arch = "arm64";
load = <0x960000>;
entry = <0x960000>;
fdt {
type = "flat_dt";
configurations {
default = "conf";
conf {
firmware = "uboot";
loadables = "atf";
fdt = "fdt";
imx-boot {
pad-byte = <0x00>;
spl: blob-ext@1 {
offset = <0x0>;
uboot: blob-ext@2 {
offset = <0x58000>;
This introduces failure to build now: https://source.denx.de/u-boot/u-boot/-/jobs/352491
+Tom Rini
On 2021/9/11 4:19, Adam Ford wrote: > Somewhere along the line, the board stopped being able to boot. > Rather than just fixing the issue, let's fix the issue and migrate > to binman to eliminate a warning when using custom imx tools for > generating the binary. >
Tom,
thanks,
adam
adam
adam
> Signed-off-by: Adam Ford aford173@gmail.com > > diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > index bbc64a2819..69fd69c8d0 100644 > --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > @@ -4,6 +4,10 @@ > */ > > / { > + binman: binman { > + multiple-images; > + }; > + > wdt-reboot { > compatible = "wdt-reboot"; > wdt = <&wdog1>; > @@ -40,6 +44,9 @@ > &clk { > u-boot,dm-spl; > u-boot,dm-pre-reloc; > + /delete-property/ assigned-clocks; > + /delete-property/ assigned-clock-parents; > + /delete-property/ assigned-clock-rates; > }; > > &gpio1 { > @@ -99,6 +106,10 @@ > u-boot,off-on-delay-us = <20000>; > }; > > +&uart2 { > + u-boot,dm-spl; > +}; > + > &usdhc1 { > u-boot,dm-spl; > sd-uhs-sdr104; > @@ -120,3 +131,122 @@ > &wdog1 { > u-boot,dm-spl; > }; > + > +&binman { > + u-boot-spl-ddr { > + filename = "u-boot-spl-ddr.bin"; > + pad-byte = <0xff>; > + align-size = <4>; > + align = <4>; > + > + u-boot-spl { > + align-end = <4>; > + }; > + > + blob_1: blob-ext@1 { > + filename = "lpddr4_pmu_train_1d_imem.bin"; > + size = <0x8000>; > + }; > + > + blob_2: blob-ext@2 { > + filename = "lpddr4_pmu_train_1d_dmem.bin"; > + size = <0x4000>; > + }; > + > + blob_3: blob-ext@3 { > + filename = "lpddr4_pmu_train_2d_imem.bin"; > + size = <0x8000>; > + }; > + > + blob_4: blob-ext@4 { > + filename = "lpddr4_pmu_train_2d_dmem.bin"; > + size = <0x4000>; > + }; > + }; > + > + > + spl { > + filename = "spl.bin"; > + > + mkimage { > + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; > + > + blob { > + filename = "u-boot-spl-ddr.bin"; > + }; > + }; > + }; > + > + itb { > + filename = "u-boot.itb"; > + > + fit { > + description = "Configuration to load ATF before U-Boot"; > + #address-cells = <1>; > + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; > + > + images { > + uboot { > + description = "U-Boot (64-bit)"; > + type = "standalone"; > + arch = "arm64"; > + compression = "none"; > + load = <CONFIG_SYS_TEXT_BASE>; > + > + uboot_blob: blob-ext { > + filename = "u-boot-nodtb.bin"; > + }; > + }; > + > + atf { > + description = "ARM Trusted Firmware"; > + type = "firmware"; > + arch = "arm64"; > + compression = "none"; > + load = <0x960000>; > + entry = <0x960000>; > + > + atf_blob: blob-ext { > + filename = "bl31.bin"; > + }; > + }; > + > + fdt { > + description = "NAME"; > + type = "flat_dt"; > + compression = "none"; > + > + uboot_fdt_blob: blob-ext { > + filename = "u-boot.dtb"; > + }; > + }; > + }; > + > + configurations { > + default = "conf"; > + > + conf { > + description = "NAME"; > + firmware = "uboot"; > + loadables = "atf"; > + fdt = "fdt"; > + }; > + }; > + }; > + }; > + > + imx-boot { > + filename = "flash.bin"; > + pad-byte = <0x00>; > + > + spl: blob-ext@1 { > + offset = <0x0>; > + filename = "spl.bin"; > + }; > + > + uboot: blob-ext@2 { > + offset = <0x58000>; > + filename = "u-boot.itb"; > + }; > + }; > +}; > diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig > index 8fedf45987..9a1eb108e4 100644 > --- a/arch/arm/mach-imx/imx8m/Kconfig > +++ b/arch/arm/mach-imx/imx8m/Kconfig > @@ -116,6 +116,7 @@ config TARGET_IMX8MM_BEACON > > config TARGET_IMX8MN_BEACON > bool "imx8mn Beacon Embedded devkit" > + select BINMAN > select IMX8MN > select SUPPORT_SPL > select IMX8M_LPDDR4 > diff --git a/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > new file mode 100644 > index 0000000000..7286b26494 > --- /dev/null > +++ b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > @@ -0,0 +1,10 @@ > +/* SPDX-License-Identifier: GPL-2.0+ */ > +/* > + * Copyright 2021 NXP > + */ > + > +#define __ASSEMBLY__ > + > +ROM_VERSION v2 > +BOOT_FROM sd > +LOADER u-boot-spl-ddr.bin 0x912000 > diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig > index 5296204aad..f2515874a2 100644 > --- a/configs/imx8mn_beacon_defconfig > +++ b/configs/imx8mn_beacon_defconfig > @@ -26,9 +26,9 @@ CONFIG_LTO=y > CONFIG_FIT=y > CONFIG_FIT_EXTERNAL_OFFSET=0x3000 > CONFIG_SPL_LOAD_FIT=y > -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > +# CONFIG_USE_SPL_FIT_GENERATOR is not set > CONFIG_OF_SYSTEM_SETUP=y > -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg" > +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/beacon/imx8mn/imximage-8mn-lpddr4.cfg" > CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" > CONFIG_ARCH_MISC_INIT=y > CONFIG_SPL_BOARD_INIT=y > @@ -36,6 +36,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y > CONFIG_SPL_SEPARATE_BSS=y > CONFIG_SPL_I2C=y > CONFIG_SPL_POWER=y > +CONFIG_SPL_WATCHDOG=y > CONFIG_HUSH_PARSER=y > CONFIG_SYS_PROMPT="u-boot=> " > # CONFIG_BOOTM_NETBSD is not set > @@ -62,7 +63,6 @@ CONFIG_CMD_EXT4_WRITE=y > CONFIG_CMD_FAT=y > CONFIG_OF_CONTROL=y > CONFIG_SPL_OF_CONTROL=y > -CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent interrupts" > CONFIG_ENV_IS_IN_MMC=y > CONFIG_SYS_RELOC_GD_ENV_ADDR=y > CONFIG_SYS_MMC_ENV_DEV=2 > @@ -106,6 +106,7 @@ CONFIG_PHY_GIGE=y > CONFIG_FEC_MXC=y > CONFIG_MII=y > CONFIG_PINCTRL=y > +CONFIG_SPL_PINCTRL=y > CONFIG_PINCTRL_IMX8M=y > CONFIG_DM_PMIC=y > # CONFIG_SPL_PMIC_CHILDREN is not set > @@ -122,7 +123,9 @@ CONFIG_SPI=y > CONFIG_DM_SPI=y > CONFIG_NXP_FSPI=y > CONFIG_SYSRESET=y > +CONFIG_SPL_SYSRESET=y > CONFIG_SYSRESET_PSCI=y > +CONFIG_SYSRESET_WATCHDOG=y > CONFIG_DM_THERMAL=y > CONFIG_USB=y > # CONFIG_SPL_DM_USB is not set > @@ -134,3 +137,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 > CONFIG_CI_UDC=y > CONFIG_SDP_LOADADDR=0x0 > CONFIG_OF_LIBFDT_OVERLAY=y > +CONFIG_IMX_WATCHDOG=y >
This goes to another discussion [1] because the binman requires some file outside of U-Boot in order to create the binary. If we could let the CI build with missing files, that would be helpful.
[1] - https://lore.kernel.org/all/20211109194224.GB24579@bill-the-cat/
adam
-- Tom
On Tue, Sep 14, 2021 at 9:49 PM Peng Fan (OSS) peng.fan@oss.nxp.com wrote: > > >
+Tom Rini
> On 2021/9/11 4:19, Adam Ford wrote: > > Somewhere along the line, the board stopped being able to boot. > > Rather than just fixing the issue, let's fix the issue and migrate > > to binman to eliminate a warning when using custom imx tools for > > generating the binary. > >
Tom,
thanks,
adam
adam
adam > > Signed-off-by: Adam Ford aford173@gmail.com > > > > diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > index bbc64a2819..69fd69c8d0 100644 > > --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > @@ -4,6 +4,10 @@ > > */ > > > > / { > > + binman: binman { > > + multiple-images; > > + }; > > + > > wdt-reboot { > > compatible = "wdt-reboot"; > > wdt = <&wdog1>; > > @@ -40,6 +44,9 @@ > > &clk { > > u-boot,dm-spl; > > u-boot,dm-pre-reloc; > > + /delete-property/ assigned-clocks; > > + /delete-property/ assigned-clock-parents; > > + /delete-property/ assigned-clock-rates; > > }; > > > > &gpio1 { > > @@ -99,6 +106,10 @@ > > u-boot,off-on-delay-us = <20000>; > > }; > > > > +&uart2 { > > + u-boot,dm-spl; > > +}; > > + > > &usdhc1 { > > u-boot,dm-spl; > > sd-uhs-sdr104; > > @@ -120,3 +131,122 @@ > > &wdog1 { > > u-boot,dm-spl; > > }; > > + > > +&binman { > > + u-boot-spl-ddr { > > + filename = "u-boot-spl-ddr.bin"; > > + pad-byte = <0xff>; > > + align-size = <4>; > > + align = <4>; > > + > > + u-boot-spl { > > + align-end = <4>; > > + }; > > + > > + blob_1: blob-ext@1 { > > + filename = "lpddr4_pmu_train_1d_imem.bin"; > > + size = <0x8000>; > > + }; > > + > > + blob_2: blob-ext@2 { > > + filename = "lpddr4_pmu_train_1d_dmem.bin"; > > + size = <0x4000>; > > + }; > > + > > + blob_3: blob-ext@3 { > > + filename = "lpddr4_pmu_train_2d_imem.bin"; > > + size = <0x8000>; > > + }; > > + > > + blob_4: blob-ext@4 { > > + filename = "lpddr4_pmu_train_2d_dmem.bin"; > > + size = <0x4000>; > > + }; > > + }; > > + > > + > > + spl { > > + filename = "spl.bin"; > > + > > + mkimage { > > + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; > > + > > + blob { > > + filename = "u-boot-spl-ddr.bin"; > > + }; > > + }; > > + }; > > + > > + itb { > > + filename = "u-boot.itb"; > > + > > + fit { > > + description = "Configuration to load ATF before U-Boot"; > > + #address-cells = <1>; > > + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; > > + > > + images { > > + uboot { > > + description = "U-Boot (64-bit)"; > > + type = "standalone"; > > + arch = "arm64"; > > + compression = "none"; > > + load = <CONFIG_SYS_TEXT_BASE>; > > + > > + uboot_blob: blob-ext { > > + filename = "u-boot-nodtb.bin"; > > + }; > > + }; > > + > > + atf { > > + description = "ARM Trusted Firmware"; > > + type = "firmware"; > > + arch = "arm64"; > > + compression = "none"; > > + load = <0x960000>; > > + entry = <0x960000>; > > + > > + atf_blob: blob-ext { > > + filename = "bl31.bin"; > > + }; > > + }; > > + > > + fdt { > > + description = "NAME"; > > + type = "flat_dt"; > > + compression = "none"; > > + > > + uboot_fdt_blob: blob-ext { > > + filename = "u-boot.dtb"; > > + }; > > + }; > > + }; > > + > > + configurations { > > + default = "conf"; > > + > > + conf { > > + description = "NAME"; > > + firmware = "uboot"; > > + loadables = "atf"; > > + fdt = "fdt"; > > + }; > > + }; > > + }; > > + }; > > + > > + imx-boot { > > + filename = "flash.bin"; > > + pad-byte = <0x00>; > > + > > + spl: blob-ext@1 { > > + offset = <0x0>; > > + filename = "spl.bin"; > > + }; > > + > > + uboot: blob-ext@2 { > > + offset = <0x58000>; > > + filename = "u-boot.itb"; > > + }; > > + }; > > +}; > > diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig > > index 8fedf45987..9a1eb108e4 100644 > > --- a/arch/arm/mach-imx/imx8m/Kconfig > > +++ b/arch/arm/mach-imx/imx8m/Kconfig > > @@ -116,6 +116,7 @@ config TARGET_IMX8MM_BEACON > > > > config TARGET_IMX8MN_BEACON > > bool "imx8mn Beacon Embedded devkit" > > + select BINMAN > > select IMX8MN > > select SUPPORT_SPL > > select IMX8M_LPDDR4 > > diff --git a/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > > new file mode 100644 > > index 0000000000..7286b26494 > > --- /dev/null > > +++ b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > > @@ -0,0 +1,10 @@ > > +/* SPDX-License-Identifier: GPL-2.0+ */ > > +/* > > + * Copyright 2021 NXP > > + */ > > + > > +#define __ASSEMBLY__ > > + > > +ROM_VERSION v2 > > +BOOT_FROM sd > > +LOADER u-boot-spl-ddr.bin 0x912000 > > diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig > > index 5296204aad..f2515874a2 100644 > > --- a/configs/imx8mn_beacon_defconfig > > +++ b/configs/imx8mn_beacon_defconfig > > @@ -26,9 +26,9 @@ CONFIG_LTO=y > > CONFIG_FIT=y > > CONFIG_FIT_EXTERNAL_OFFSET=0x3000 > > CONFIG_SPL_LOAD_FIT=y > > -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > +# CONFIG_USE_SPL_FIT_GENERATOR is not set > > CONFIG_OF_SYSTEM_SETUP=y > > -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg" > > +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/beacon/imx8mn/imximage-8mn-lpddr4.cfg" > > CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" > > CONFIG_ARCH_MISC_INIT=y > > CONFIG_SPL_BOARD_INIT=y > > @@ -36,6 +36,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y > > CONFIG_SPL_SEPARATE_BSS=y > > CONFIG_SPL_I2C=y > > CONFIG_SPL_POWER=y > > +CONFIG_SPL_WATCHDOG=y > > CONFIG_HUSH_PARSER=y > > CONFIG_SYS_PROMPT="u-boot=> " > > # CONFIG_BOOTM_NETBSD is not set > > @@ -62,7 +63,6 @@ CONFIG_CMD_EXT4_WRITE=y > > CONFIG_CMD_FAT=y > > CONFIG_OF_CONTROL=y > > CONFIG_SPL_OF_CONTROL=y > > -CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent interrupts" > > CONFIG_ENV_IS_IN_MMC=y > > CONFIG_SYS_RELOC_GD_ENV_ADDR=y > > CONFIG_SYS_MMC_ENV_DEV=2 > > @@ -106,6 +106,7 @@ CONFIG_PHY_GIGE=y > > CONFIG_FEC_MXC=y > > CONFIG_MII=y > > CONFIG_PINCTRL=y > > +CONFIG_SPL_PINCTRL=y > > CONFIG_PINCTRL_IMX8M=y > > CONFIG_DM_PMIC=y > > # CONFIG_SPL_PMIC_CHILDREN is not set > > @@ -122,7 +123,9 @@ CONFIG_SPI=y > > CONFIG_DM_SPI=y > > CONFIG_NXP_FSPI=y > > CONFIG_SYSRESET=y > > +CONFIG_SPL_SYSRESET=y > > CONFIG_SYSRESET_PSCI=y > > +CONFIG_SYSRESET_WATCHDOG=y > > CONFIG_DM_THERMAL=y > > CONFIG_USB=y > > # CONFIG_SPL_DM_USB is not set > > @@ -134,3 +137,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 > > CONFIG_CI_UDC=y > > CONFIG_SDP_LOADADDR=0x0 > > CONFIG_OF_LIBFDT_OVERLAY=y > > +CONFIG_IMX_WATCHDOG=y > > > > Reviewed-by: Peng Fan peng.fan@nxp.com
Oh this fun.. :(
On Thu, Sep 23, 2021 at 3:03 PM Adam Ford aford173@gmail.com wrote: > > On Tue, Sep 14, 2021 at 9:49 PM Peng Fan (OSS) peng.fan@oss.nxp.com wrote: > > > > > >
+Tom Rini
> > On 2021/9/11 4:19, Adam Ford wrote: > > > Somewhere along the line, the board stopped being able to boot. > > > Rather than just fixing the issue, let's fix the issue and migrate > > > to binman to eliminate a warning when using custom imx tools for > > > generating the binary. > > > > > Any chance this can make it into 2021.10? it's currently broken, and > this seems to fix the problem. i didn't bisect to see where the issue > broke, or i would have added a fixes tag.
Tom,
thanks,
adam
adam
> > adam > > > Signed-off-by: Adam Ford aford173@gmail.com > > > > > > diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > > index bbc64a2819..69fd69c8d0 100644 > > > --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > > +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > > @@ -4,6 +4,10 @@ > > > */ > > > > > > / { > > > + binman: binman { > > > + multiple-images; > > > + }; > > > + > > > wdt-reboot { > > > compatible = "wdt-reboot"; > > > wdt = <&wdog1>; > > > @@ -40,6 +44,9 @@ > > > &clk { > > > u-boot,dm-spl; > > > u-boot,dm-pre-reloc; > > > + /delete-property/ assigned-clocks; > > > + /delete-property/ assigned-clock-parents; > > > + /delete-property/ assigned-clock-rates; > > > }; > > > > > > &gpio1 { > > > @@ -99,6 +106,10 @@ > > > u-boot,off-on-delay-us = <20000>; > > > }; > > > > > > +&uart2 { > > > + u-boot,dm-spl; > > > +}; > > > + > > > &usdhc1 { > > > u-boot,dm-spl; > > > sd-uhs-sdr104; > > > @@ -120,3 +131,122 @@ > > > &wdog1 { > > > u-boot,dm-spl; > > > }; > > > + > > > +&binman { > > > + u-boot-spl-ddr { > > > + filename = "u-boot-spl-ddr.bin"; > > > + pad-byte = <0xff>; > > > + align-size = <4>; > > > + align = <4>; > > > + > > > + u-boot-spl { > > > + align-end = <4>; > > > + }; > > > + > > > + blob_1: blob-ext@1 { > > > + filename = "lpddr4_pmu_train_1d_imem.bin"; > > > + size = <0x8000>; > > > + }; > > > + > > > + blob_2: blob-ext@2 { > > > + filename = "lpddr4_pmu_train_1d_dmem.bin"; > > > + size = <0x4000>; > > > + }; > > > + > > > + blob_3: blob-ext@3 { > > > + filename = "lpddr4_pmu_train_2d_imem.bin"; > > > + size = <0x8000>; > > > + }; > > > + > > > + blob_4: blob-ext@4 { > > > + filename = "lpddr4_pmu_train_2d_dmem.bin"; > > > + size = <0x4000>; > > > + }; > > > + }; > > > + > > > + > > > + spl { > > > + filename = "spl.bin"; > > > + > > > + mkimage { > > > + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; > > > + > > > + blob { > > > + filename = "u-boot-spl-ddr.bin"; > > > + }; > > > + }; > > > + }; > > > + > > > + itb { > > > + filename = "u-boot.itb"; > > > + > > > + fit { > > > + description = "Configuration to load ATF before U-Boot"; > > > + #address-cells = <1>; > > > + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; > > > + > > > + images { > > > + uboot { > > > + description = "U-Boot (64-bit)"; > > > + type = "standalone"; > > > + arch = "arm64"; > > > + compression = "none"; > > > + load = <CONFIG_SYS_TEXT_BASE>; > > > + > > > + uboot_blob: blob-ext { > > > + filename = "u-boot-nodtb.bin"; > > > + }; > > > + }; > > > + > > > + atf { > > > + description = "ARM Trusted Firmware"; > > > + type = "firmware"; > > > + arch = "arm64"; > > > + compression = "none"; > > > + load = <0x960000>; > > > + entry = <0x960000>; > > > + > > > + atf_blob: blob-ext { > > > + filename = "bl31.bin"; > > > + }; > > > + }; > > > + > > > + fdt { > > > + description = "NAME"; > > > + type = "flat_dt"; > > > + compression = "none"; > > > + > > > + uboot_fdt_blob: blob-ext { > > > + filename = "u-boot.dtb"; > > > + }; > > > + }; > > > + }; > > > + > > > + configurations { > > > + default = "conf"; > > > + > > > + conf { > > > + description = "NAME"; > > > + firmware = "uboot"; > > > + loadables = "atf"; > > > + fdt = "fdt"; > > > + }; > > > + }; > > > + }; > > > + }; > > > + > > > + imx-boot { > > > + filename = "flash.bin"; > > > + pad-byte = <0x00>; > > > + > > > + spl: blob-ext@1 { > > > + offset = <0x0>; > > > + filename = "spl.bin"; > > > + }; > > > + > > > + uboot: blob-ext@2 { > > > + offset = <0x58000>; > > > + filename = "u-boot.itb"; > > > + }; > > > + }; > > > +}; > > > diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig > > > index 8fedf45987..9a1eb108e4 100644 > > > --- a/arch/arm/mach-imx/imx8m/Kconfig > > > +++ b/arch/arm/mach-imx/imx8m/Kconfig > > > @@ -116,6 +116,7 @@ config TARGET_IMX8MM_BEACON > > > > > > config TARGET_IMX8MN_BEACON > > > bool "imx8mn Beacon Embedded devkit" > > > + select BINMAN > > > select IMX8MN > > > select SUPPORT_SPL > > > select IMX8M_LPDDR4 > > > diff --git a/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > > > new file mode 100644 > > > index 0000000000..7286b26494 > > > --- /dev/null > > > +++ b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > > > @@ -0,0 +1,10 @@ > > > +/* SPDX-License-Identifier: GPL-2.0+ */ > > > +/* > > > + * Copyright 2021 NXP > > > + */ > > > + > > > +#define __ASSEMBLY__ > > > + > > > +ROM_VERSION v2 > > > +BOOT_FROM sd > > > +LOADER u-boot-spl-ddr.bin 0x912000 > > > diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig > > > index 5296204aad..f2515874a2 100644 > > > --- a/configs/imx8mn_beacon_defconfig > > > +++ b/configs/imx8mn_beacon_defconfig > > > @@ -26,9 +26,9 @@ CONFIG_LTO=y > > > CONFIG_FIT=y > > > CONFIG_FIT_EXTERNAL_OFFSET=0x3000 > > > CONFIG_SPL_LOAD_FIT=y > > > -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > +# CONFIG_USE_SPL_FIT_GENERATOR is not set > > > CONFIG_OF_SYSTEM_SETUP=y > > > -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg" > > > +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/beacon/imx8mn/imximage-8mn-lpddr4.cfg" > > > CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" > > > CONFIG_ARCH_MISC_INIT=y > > > CONFIG_SPL_BOARD_INIT=y > > > @@ -36,6 +36,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y > > > CONFIG_SPL_SEPARATE_BSS=y > > > CONFIG_SPL_I2C=y > > > CONFIG_SPL_POWER=y > > > +CONFIG_SPL_WATCHDOG=y > > > CONFIG_HUSH_PARSER=y > > > CONFIG_SYS_PROMPT="u-boot=> " > > > # CONFIG_BOOTM_NETBSD is not set > > > @@ -62,7 +63,6 @@ CONFIG_CMD_EXT4_WRITE=y > > > CONFIG_CMD_FAT=y > > > CONFIG_OF_CONTROL=y > > > CONFIG_SPL_OF_CONTROL=y > > > -CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent interrupts" > > > CONFIG_ENV_IS_IN_MMC=y > > > CONFIG_SYS_RELOC_GD_ENV_ADDR=y > > > CONFIG_SYS_MMC_ENV_DEV=2 > > > @@ -106,6 +106,7 @@ CONFIG_PHY_GIGE=y > > > CONFIG_FEC_MXC=y > > > CONFIG_MII=y > > > CONFIG_PINCTRL=y > > > +CONFIG_SPL_PINCTRL=y > > > CONFIG_PINCTRL_IMX8M=y > > > CONFIG_DM_PMIC=y > > > # CONFIG_SPL_PMIC_CHILDREN is not set > > > @@ -122,7 +123,9 @@ CONFIG_SPI=y > > > CONFIG_DM_SPI=y > > > CONFIG_NXP_FSPI=y > > > CONFIG_SYSRESET=y > > > +CONFIG_SPL_SYSRESET=y > > > CONFIG_SYSRESET_PSCI=y > > > +CONFIG_SYSRESET_WATCHDOG=y > > > CONFIG_DM_THERMAL=y > > > CONFIG_USB=y > > > # CONFIG_SPL_DM_USB is not set > > > @@ -134,3 +137,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 > > > CONFIG_CI_UDC=y > > > CONFIG_SDP_LOADADDR=0x0 > > > CONFIG_OF_LIBFDT_OVERLAY=y > > > +CONFIG_IMX_WATCHDOG=y > > > > > > > Reviewed-by: Peng Fan peng.fan@nxp.com
Oh this fun.. :(
Does that mean I should find a solution without binman?
-- Tom
On Wed, Sep 29, 2021 at 8:26 AM Adam Ford aford173@gmail.com wrote: > > On Thu, Sep 23, 2021 at 3:03 PM Adam Ford aford173@gmail.com wrote: > > > > On Tue, Sep 14, 2021 at 9:49 PM Peng Fan (OSS) peng.fan@oss.nxp.com wrote: > > > > > > > > >
+Tom Rini
> > > On 2021/9/11 4:19, Adam Ford wrote: > > > > Somewhere along the line, the board stopped being able to boot. > > > > Rather than just fixing the issue, let's fix the issue and migrate > > > > to binman to eliminate a warning when using custom imx tools for > > > > generating the binary. > > > > > > > > Any chance this can make it into 2021.10? it's currently broken, and > > this seems to fix the problem. i didn't bisect to see where the issue > > broke, or i would have added a fixes tag. > > Stefano or Tom? could someone comment and/or merge? the board is > currently not booting, and this fixes the issue
Tom,
thanks,
adam
adam > > > > adam > > > > Signed-off-by: Adam Ford aford173@gmail.com > > > > > > > > diff --git a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > > > index bbc64a2819..69fd69c8d0 100644 > > > > --- a/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > > > +++ b/arch/arm/dts/imx8mn-beacon-kit-u-boot.dtsi > > > > @@ -4,6 +4,10 @@ > > > > */ > > > > > > > > / { > > > > + binman: binman { > > > > + multiple-images; > > > > + }; > > > > + > > > > wdt-reboot { > > > > compatible = "wdt-reboot"; > > > > wdt = <&wdog1>; > > > > @@ -40,6 +44,9 @@ > > > > &clk { > > > > u-boot,dm-spl; > > > > u-boot,dm-pre-reloc; > > > > + /delete-property/ assigned-clocks; > > > > + /delete-property/ assigned-clock-parents; > > > > + /delete-property/ assigned-clock-rates; > > > > }; > > > > > > > > &gpio1 { > > > > @@ -99,6 +106,10 @@ > > > > u-boot,off-on-delay-us = <20000>; > > > > }; > > > > > > > > +&uart2 { > > > > + u-boot,dm-spl; > > > > +}; > > > > + > > > > &usdhc1 { > > > > u-boot,dm-spl; > > > > sd-uhs-sdr104; > > > > @@ -120,3 +131,122 @@ > > > > &wdog1 { > > > > u-boot,dm-spl; > > > > }; > > > > + > > > > +&binman { > > > > + u-boot-spl-ddr { > > > > + filename = "u-boot-spl-ddr.bin"; > > > > + pad-byte = <0xff>; > > > > + align-size = <4>; > > > > + align = <4>; > > > > + > > > > + u-boot-spl { > > > > + align-end = <4>; > > > > + }; > > > > + > > > > + blob_1: blob-ext@1 { > > > > + filename = "lpddr4_pmu_train_1d_imem.bin"; > > > > + size = <0x8000>; > > > > + }; > > > > + > > > > + blob_2: blob-ext@2 { > > > > + filename = "lpddr4_pmu_train_1d_dmem.bin"; > > > > + size = <0x4000>; > > > > + }; > > > > + > > > > + blob_3: blob-ext@3 { > > > > + filename = "lpddr4_pmu_train_2d_imem.bin"; > > > > + size = <0x8000>; > > > > + }; > > > > + > > > > + blob_4: blob-ext@4 { > > > > + filename = "lpddr4_pmu_train_2d_dmem.bin"; > > > > + size = <0x4000>; > > > > + }; > > > > + }; > > > > + > > > > + > > > > + spl { > > > > + filename = "spl.bin"; > > > > + > > > > + mkimage { > > > > + args = "-n spl/u-boot-spl.cfgout -T imx8mimage -e 0x912000"; > > > > + > > > > + blob { > > > > + filename = "u-boot-spl-ddr.bin"; > > > > + }; > > > > + }; > > > > + }; > > > > + > > > > + itb { > > > > + filename = "u-boot.itb"; > > > > + > > > > + fit { > > > > + description = "Configuration to load ATF before U-Boot"; > > > > + #address-cells = <1>; > > > > + fit,external-offset = <CONFIG_FIT_EXTERNAL_OFFSET>; > > > > + > > > > + images { > > > > + uboot { > > > > + description = "U-Boot (64-bit)"; > > > > + type = "standalone"; > > > > + arch = "arm64"; > > > > + compression = "none"; > > > > + load = <CONFIG_SYS_TEXT_BASE>; > > > > + > > > > + uboot_blob: blob-ext { > > > > + filename = "u-boot-nodtb.bin"; > > > > + }; > > > > + }; > > > > + > > > > + atf { > > > > + description = "ARM Trusted Firmware"; > > > > + type = "firmware"; > > > > + arch = "arm64"; > > > > + compression = "none"; > > > > + load = <0x960000>; > > > > + entry = <0x960000>; > > > > + > > > > + atf_blob: blob-ext { > > > > + filename = "bl31.bin"; > > > > + }; > > > > + }; > > > > + > > > > + fdt { > > > > + description = "NAME"; > > > > + type = "flat_dt"; > > > > + compression = "none"; > > > > + > > > > + uboot_fdt_blob: blob-ext { > > > > + filename = "u-boot.dtb"; > > > > + }; > > > > + }; > > > > + }; > > > > + > > > > + configurations { > > > > + default = "conf"; > > > > + > > > > + conf { > > > > + description = "NAME"; > > > > + firmware = "uboot"; > > > > + loadables = "atf"; > > > > + fdt = "fdt"; > > > > + }; > > > > + }; > > > > + }; > > > > + }; > > > > + > > > > + imx-boot { > > > > + filename = "flash.bin"; > > > > + pad-byte = <0x00>; > > > > + > > > > + spl: blob-ext@1 { > > > > + offset = <0x0>; > > > > + filename = "spl.bin"; > > > > + }; > > > > + > > > > + uboot: blob-ext@2 { > > > > + offset = <0x58000>; > > > > + filename = "u-boot.itb"; > > > > + }; > > > > + }; > > > > +}; > > > > diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig > > > > index 8fedf45987..9a1eb108e4 100644 > > > > --- a/arch/arm/mach-imx/imx8m/Kconfig > > > > +++ b/arch/arm/mach-imx/imx8m/Kconfig > > > > @@ -116,6 +116,7 @@ config TARGET_IMX8MM_BEACON > > > > > > > > config TARGET_IMX8MN_BEACON > > > > bool "imx8mn Beacon Embedded devkit" > > > > + select BINMAN > > > > select IMX8MN > > > > select SUPPORT_SPL > > > > select IMX8M_LPDDR4 > > > > diff --git a/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > > > > new file mode 100644 > > > > index 0000000000..7286b26494 > > > > --- /dev/null > > > > +++ b/board/beacon/imx8mn/imximage-8mn-lpddr4.cfg > > > > @@ -0,0 +1,10 @@ > > > > +/* SPDX-License-Identifier: GPL-2.0+ */ > > > > +/* > > > > + * Copyright 2021 NXP > > > > + */ > > > > + > > > > +#define __ASSEMBLY__ > > > > + > > > > +ROM_VERSION v2 > > > > +BOOT_FROM sd > > > > +LOADER u-boot-spl-ddr.bin 0x912000 > > > > diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig > > > > index 5296204aad..f2515874a2 100644 > > > > --- a/configs/imx8mn_beacon_defconfig > > > > +++ b/configs/imx8mn_beacon_defconfig > > > > @@ -26,9 +26,9 @@ CONFIG_LTO=y > > > > CONFIG_FIT=y > > > > CONFIG_FIT_EXTERNAL_OFFSET=0x3000 > > > > CONFIG_SPL_LOAD_FIT=y > > > > -CONFIG_SPL_FIT_GENERATOR="arch/arm/mach-imx/mkimage_fit_atf.sh" > > > > +# CONFIG_USE_SPL_FIT_GENERATOR is not set > > > > CONFIG_OF_SYSTEM_SETUP=y > > > > -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/imx8m/imximage-8mn-lpddr4.cfg" > > > > +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/beacon/imx8mn/imximage-8mn-lpddr4.cfg" > > > > CONFIG_DEFAULT_FDT_FILE="imx8mn-beacon-kit.dtb" > > > > CONFIG_ARCH_MISC_INIT=y > > > > CONFIG_SPL_BOARD_INIT=y > > > > @@ -36,6 +36,7 @@ CONFIG_SPL_BOOTROM_SUPPORT=y > > > > CONFIG_SPL_SEPARATE_BSS=y > > > > CONFIG_SPL_I2C=y > > > > CONFIG_SPL_POWER=y > > > > +CONFIG_SPL_WATCHDOG=y > > > > CONFIG_HUSH_PARSER=y > > > > CONFIG_SYS_PROMPT="u-boot=> " > > > > # CONFIG_BOOTM_NETBSD is not set > > > > @@ -62,7 +63,6 @@ CONFIG_CMD_EXT4_WRITE=y > > > > CONFIG_CMD_FAT=y > > > > CONFIG_OF_CONTROL=y > > > > CONFIG_SPL_OF_CONTROL=y > > > > -CONFIG_OF_SPL_REMOVE_PROPS="interrupt-parent interrupts" > > > > CONFIG_ENV_IS_IN_MMC=y > > > > CONFIG_SYS_RELOC_GD_ENV_ADDR=y > > > > CONFIG_SYS_MMC_ENV_DEV=2 > > > > @@ -106,6 +106,7 @@ CONFIG_PHY_GIGE=y > > > > CONFIG_FEC_MXC=y > > > > CONFIG_MII=y > > > > CONFIG_PINCTRL=y > > > > +CONFIG_SPL_PINCTRL=y > > > > CONFIG_PINCTRL_IMX8M=y > > > > CONFIG_DM_PMIC=y > > > > # CONFIG_SPL_PMIC_CHILDREN is not set > > > > @@ -122,7 +123,9 @@ CONFIG_SPI=y > > > > CONFIG_DM_SPI=y > > > > CONFIG_NXP_FSPI=y > > > > CONFIG_SYSRESET=y > > > > +CONFIG_SPL_SYSRESET=y > > > > CONFIG_SYSRESET_PSCI=y > > > > +CONFIG_SYSRESET_WATCHDOG=y > > > > CONFIG_DM_THERMAL=y > > > > CONFIG_USB=y > > > > # CONFIG_SPL_DM_USB is not set > > > > @@ -134,3 +137,4 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 > > > > CONFIG_CI_UDC=y > > > > CONFIG_SDP_LOADADDR=0x0 > > > > CONFIG_OF_LIBFDT_OVERLAY=y > > > > +CONFIG_IMX_WATCHDOG=y > > > > > > > > > > Reviewed-by: Peng Fan peng.fan@nxp.com
Oh this fun.. :(
I think it depends on how the RFC to allow binman to handle dummy files goes.
Reviewed-by: Fabio Estevam festevam@gmail.com
Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Peng Fan peng.fan@nxp.com Reviewed-by: Fabio Estevam festevam@gmail.com
Adam Ford
Fabio Estevam
Peng Fan (OSS)
