[U-Boot] mx53loco: compilation broken with 2015.01-rc2
mx53loco_defconfig is broken in 2015.01-rc2 (was ok with -rc1).
I have the following warning: drivers/block/dwc_ahsata.c: In function 'reset_sata': drivers/block/dwc_ahsata.c:611:2: warning: implicit declaration of function 'disable_sata_clock' [-Wimplicit-function-declaration]
And finally this error: drivers/built-in.o: In function `reset_sata': /home/abuild/rpmbuild/BUILD/u-boot-2015.01-rc2/drivers/block/dwc_ahsata.c:611: undefined reference to `disable_sata_clock' ld.bfd: BFD (GNU Binutils; openSUSE 13.2) 2.24.0.20140403-6.1 assertion fail ../../bfd/elf32-arm.c:7696 ld.bfd: error: required section '.rel.plt' not found in the linker script ld.bfd: final link failed: Invalid operation Makefile:1066: recipe for target 'u-boot' failed
Commit 10ee8ecafbb4405ac77f6df081325630617aa7cd : "sata: implement reset_sata for dwc_ahsata" is probably the problem. mx6 is fixed by commit 8d29cef5887887157f54f98493440ce5c824d5cb : "arm: mx6: introduce disable_sata_clock", but nothing for mx5.
Guillaume
Hi Guillaume,
You're right. This is also connected to the thread:
https://www.mail-archive.com/u-boot@lists.denx.de/msg155590.html
As Soeren reports crash if sata_init() is not called, patch fixes an issue but opens a new one on i.MX6. That means, even with i.MX6 is still open. Soeren promised to send a patch for i.MX6, and after that we can decide the best way to take for MX5.
Best regards, Stefano Babic
Guillaume Gardet
Stefano Babic
