[U-Boot-Users] Patch: flash_write return value in saveenv
In the CFG_ENV_ADDR_REDUND version of the function saveenv in common/env_flash.c...
If there is a failure with the flash_write function it will always display an error message for a Flash Timeout regardless of what the actual error is. The variable "rc" is set to 1 at declaration and flash_perror(rc) is called if there is an error, but the actual return value of flash_write is not stored in rc, therefore the error code displayed will always be 1.
The below patch corrects this...
Dan
diff -uNr clean/common/env_flash.c u-boot-1.0.2/common/env_flash.c --- clean/common/env_flash.c 2004-02-25 16:36:28.000000000 -0600 +++ u-boot-1.0.2/common/env_flash.c 2004-02-26 12:55:38.000000000 -0600 @@ -207,21 +207,21 @@ debug (" %08lX ... %08lX ...", (ulong)&(flash_addr_new->data), sizeof(env_ptr->data)+(ulong)&(flash_addr_new->data)); - if (flash_write(env_ptr->data, + if ((rc = flash_write(env_ptr->data, (ulong)&(flash_addr_new->data), - sizeof(env_ptr->data)) || + sizeof(env_ptr->data))) ||
- flash_write((char *)&(env_ptr->crc), + (rc = flash_write((char *)&(env_ptr->crc), (ulong)&(flash_addr_new->crc), - sizeof(env_ptr->crc)) || + sizeof(env_ptr->crc))) ||
- flash_write((char *)&obsolete_flag, + (rc = flash_write((char *)&obsolete_flag, (ulong)&(flash_addr->flags), - sizeof(flash_addr->flags)) || + sizeof(flash_addr->flags))) ||
- flash_write((char *)&active_flag, + (rc = flash_write((char *)&active_flag, (ulong)&(flash_addr_new->flags), - sizeof(flash_addr_new->flags))) + sizeof(flash_addr_new->flags)))) { flash_perror (rc); goto Done; diff -uNr clean/CHANGELOG u-boot-1.0.2/CHANGELOG --- clean/CHANGELOG 2004-02-26 13:02:21.000000000 -0600 +++ u-boot-1.0.2/CHANGELOG 2004-02-26 13:03:33.000000000 -0600 @@ -2,6 +2,9 @@ Changes for U-Boot 1.0.2: ======================================================================
+* Patch by Dan Eisenhut, 26 Feb 2004: + fix flash_write return value in saveenv + * Patch by Masami Komiya, 24 Feb 2004: Update NetBootFileXferSize in NFS code
Dear Daniel,
in message 77FE4A1FA59FF947845A42194AD6676277310D@uswaumsx07medge.med.ge.com you wrote:
Thanks, checked in.
Eisenhut, Daniel (MED)
