[U-Boot] [PATCH v2] blackfin: Fix using gd->baudrate before setting its value
Current code uses gd->baudrate before setting its value. Besides, I got below build warning which is introduced by commit ddb5c5be "blackfin: add baudrate to bdinfo".
board.c:235:3: warning: passing argument 1 of 'simple_strtoul' makes pointer from integer without a cast [enabled by default] include/vsprintf.h:27:7: note: expected 'const char *' but argument is of type 'unsigned int'
This patch ensures we get the baudrate setting before using it.
Signed-off-by: Axel Lin axel.lin@ingics.com --- v2: The change is based on Sonic 's suggestion: move "gd->bd->bi_baudrate = gd->baudrate;" into init_baudrate()
arch/blackfin/lib/board.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/blackfin/lib/board.c b/arch/blackfin/lib/board.c index f1d5547..460c97d 100644 --- a/arch/blackfin/lib/board.c +++ b/arch/blackfin/lib/board.c @@ -63,6 +63,7 @@ static int display_banner(void) static int init_baudrate(void) { gd->baudrate = getenv_ulong("baudrate", 10, CONFIG_BAUDRATE); + gd->bd->bi_baudrate = gd->baudrate; return 0; }
@@ -231,8 +232,6 @@ static int global_board_data_init(void) bd->bi_sclk = get_sclk(); bd->bi_memstart = CONFIG_SYS_SDRAM_BASE; bd->bi_memsize = CONFIG_SYS_MAX_RAM_SIZE; - bd->bi_baudrate = (gd->baudrate > 0) - ? simple_strtoul(gd->baudrate, NULL, 10) : CONFIG_BAUDRATE;
return 0; }
Acked-by: Sonic Zhangsonic.zhang@analog.com
? simple_strtoul(gd->baudrate, NULL, 10) : CONFIG_BAUDRATE; return 0;
1.8.1.2
2013/7/1 Sonic Zhang sonic.adi@gmail.com:
hi Sonic, I thought you will pick up this patch, but now I got your ACK and I have no idea who will take this patch.
Just wondering if this patch should be applied for v2013.07?
Regards, Axel
Hi Axel,
It is in the blackfin u-boot next tree.
Regards,
Sonic
-----Original Message----- From: Axel Lin [mailto:axel.lin@ingics.com] Sent: Sunday, July 14, 2013 3:06 PM To: Sonic Zhang Cc: Zhang, Sonic; Tom Rini; Marek Vasut; Bob Liu; U-Boot Subject: Re: [U-Boot] [PATCH v2] blackfin: Fix using gd->baudrate before setting its value
Regards, Axel
Axel Lin
Sonic Zhang
Zhang, Sonic
