[U-Boot] [PATCH] common/memsize: panic if maxsize is not power of two
The memory write and recover loop in get_ram_size() work correctly only if maxsize is power of two, otherwise the function will return a small size.
Signed-off-by: Iru Cai mytbk920423@gmail.com --- common/memsize.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/common/memsize.c b/common/memsize.c index 13b0047786..f627149a05 100644 --- a/common/memsize.c +++ b/common/memsize.c @@ -33,6 +33,10 @@ long get_ram_size(long *base, long maxsize) long size; int i = 0;
+ if ((maxsize & (maxsize - 1)) != 0) { + panic("maxsize must be power of 2!"); + } + for (cnt = (maxsize / sizeof(long)) >> 1; cnt > 0; cnt >>= 1) { addr = base + cnt; /* pointer arith! */ sync();
- if ((maxsize & (maxsize - 1)) != 0) {
- for (cnt = (maxsize / sizeof(long)) >> 1; cnt > 0; cnt >>= 1) { addr = base + cnt; /* pointer arith! */ sync();
The first problem is that this causes cl-som-imx7 to fail to link due to missing a reference to reset_cpu(). The second problem is, we're increasing everyone with a new string included. Is this a problem that can really be found outside of development (and so caught and memory init fixed) or is something else going on here? Thanks!
Iru Cai
