[U-Boot] [PATCH 00/16] stm32m1 patches for v2017.10
Some remaining patches for stm32mp1 - some cleanup in files - add 2 specific commands for stm32mp1 board - use OF_SYSTEM_SETUP to update kernel device tree - synchronization with latest device tree
Patrick Delaunay (16): stm32mp1: deactivate WATCHDOG in defconfig stm32mp1: call regulators_enable_boot_on in board_init stm32mp1: syscon: remove etzpc support stm32mp1: syscon: remove stgen dt-bindings: pinctrl: stm32: add new entry for package information stm32mp1: export get_cpu_package function stm32mp1: update package information in device tree stm32mp1: update device tree with ETZPC status stm32mp1: add stboard command stm32mp1: key: add stm32key command stm32mp1: udpate README stm32mp1: cosmetic: remove unnecessary include stm32mp1: configs: Add CONFIG_OF_SPL_REMOVE_PROPS stm32mp1: add check for presence of environment in boot device stm32mp1: force boot_net_usb_start ARM: dts: stm32mp1: sync device tree with v5.2-rc4
arch/arm/Kconfig | 1 + arch/arm/dts/stm32mp15-ddr.dtsi | 2 +- arch/arm/dts/stm32mp157-pinctrl.dtsi | 270 ++++++++++++++++++++- arch/arm/dts/stm32mp157-u-boot.dtsi | 67 ++--- arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 4 - arch/arm/dts/stm32mp157a-dk1.dts | 30 ++- arch/arm/dts/stm32mp157c-dk2.dts | 1 + arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 15 +- arch/arm/dts/stm32mp157c-ed1.dts | 205 ++++------------ arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 4 - arch/arm/dts/stm32mp157c-ev1.dts | 12 +- arch/arm/dts/stm32mp157c.dtsi | 199 +++++++++++---- arch/arm/mach-stm32mp/Kconfig | 15 ++ arch/arm/mach-stm32mp/Makefile | 2 + arch/arm/mach-stm32mp/cmd_stm32key.c | 101 ++++++++ arch/arm/mach-stm32mp/cpu.c | 7 +- arch/arm/mach-stm32mp/fdt.c | 223 +++++++++++++++++ arch/arm/mach-stm32mp/include/mach/stm32.h | 3 +- arch/arm/mach-stm32mp/include/mach/sys_proto.h | 9 + arch/arm/mach-stm32mp/syscon.c | 2 - board/st/stm32mp1/Kconfig | 7 + board/st/stm32mp1/Makefile | 1 + board/st/stm32mp1/README | 15 +- board/st/stm32mp1/cmd_stboard.c | 145 +++++++++++ board/st/stm32mp1/spl.c | 1 - board/st/stm32mp1/stm32mp1.c | 4 + configs/stm32mp15_basic_defconfig | 3 +- configs/stm32mp15_trusted_defconfig | 2 - .../pinctrl/st,stm32-pinctrl.txt | 101 +++++++- drivers/clk/clk_stm32mp1.c | 3 +- include/configs/stm32mp1.h | 7 +- include/dt-bindings/pinctrl/stm32-pinfunc.h | 6 + 32 files changed, 1158 insertions(+), 309 deletions(-) create mode 100644 arch/arm/mach-stm32mp/cmd_stm32key.c create mode 100644 arch/arm/mach-stm32mp/fdt.c create mode 100644 board/st/stm32mp1/cmd_stboard.c
Deactivate WATCHDOG by default in u-boot to avoid issue to boot kernel and rootfs without the needed daemon to reload it.
Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
configs/stm32mp15_basic_defconfig | 2 -- configs/stm32mp15_trusted_defconfig | 2 -- 2 files changed, 4 deletions(-)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index 4aa184f..b1fc3a2 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -110,5 +110,3 @@ CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_WDT=y -CONFIG_WDT_STM32MP=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index 66361c8..212b848 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -100,5 +100,3 @@ CONFIG_USB_GADGET_MANUFACTURER="STMicroelectronics" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_WDT=y -CONFIG_WDT_STM32MP=y
U-Boot activates regulators by reading the "regulator-boot-on" property in DT; it is requested by M4 early Boot feature.
board/st/stm32mp1/stm32mp1.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 7769293..e4d1723 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -515,6 +515,10 @@ int board_init(void)
board_key_check();
+#ifdef CONFIG_DM_REGULATOR + regulators_enable_boot_on(_DEBUG); +#endif + sysconf_init();
if (IS_ENABLED(CONFIG_LED))
Support for ETZPC is removed as this device is not present in Linux kernel device tree.
arch/arm/mach-stm32mp/include/mach/stm32.h | 1 - arch/arm/mach-stm32mp/syscon.c | 1 - 2 files changed, 2 deletions(-)
diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index 6795352..1e3299a 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -36,7 +36,6 @@ /* enumerated used to identify the SYSCON driver instance */ enum { STM32MP_SYSCON_UNKNOWN, - STM32MP_SYSCON_ETZPC, STM32MP_SYSCON_PWR, STM32MP_SYSCON_STGEN, STM32MP_SYSCON_SYSCFG, diff --git a/arch/arm/mach-stm32mp/syscon.c b/arch/arm/mach-stm32mp/syscon.c index 242f834..e10c42e 100644 --- a/arch/arm/mach-stm32mp/syscon.c +++ b/arch/arm/mach-stm32mp/syscon.c @@ -9,7 +9,6 @@ #include <asm/arch/stm32.h>
static const struct udevice_id stm32mp_syscon_ids[] = { - { .compatible = "st,stm32mp1-etzpc", .data = STM32MP_SYSCON_ETZPC }, { .compatible = "st,stm32mp1-pwr", .data = STM32MP_SYSCON_PWR }, { .compatible = "st,stm32-stgen", .data = STM32MP_SYSCON_STGEN }, { .compatible = "st,stm32mp157-syscfg",
Reduce difference with kernel Linux device tree.
arch/arm/dts/stm32mp157-u-boot.dtsi | 7 ------- arch/arm/mach-stm32mp/include/mach/stm32.h | 2 +- arch/arm/mach-stm32mp/syscon.c | 1 - drivers/clk/clk_stm32mp1.c | 3 +-- 4 files changed, 2 insertions(+), 11 deletions(-)
diff --git a/arch/arm/dts/stm32mp157-u-boot.dtsi b/arch/arm/dts/stm32mp157-u-boot.dtsi index 09560e2..c9f534e 100644 --- a/arch/arm/dts/stm32mp157-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157-u-boot.dtsi @@ -31,13 +31,6 @@
soc { u-boot,dm-pre-reloc; - - stgen: stgen@5C008000 { - compatible = "st,stm32-stgen"; - reg = <0x5C008000 0x1000>; - status = "okay"; - u-boot,dm-pre-reloc; - }; }; };
diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index 1e3299a..1d4b548 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -15,6 +15,7 @@ #define STM32_DBGMCU_BASE 0x50081000 #define STM32_TZC_BASE 0x5C006000 #define STM32_ETZPC_BASE 0x5C007000 +#define STM32_STGEN_BASE 0x5C008000 #define STM32_TAMP_BASE 0x5C00A000
#define STM32_USART1_BASE 0x5C000000 @@ -37,7 +38,6 @@ enum { STM32MP_SYSCON_UNKNOWN, STM32MP_SYSCON_PWR, - STM32MP_SYSCON_STGEN, STM32MP_SYSCON_SYSCFG, };
diff --git a/arch/arm/mach-stm32mp/syscon.c b/arch/arm/mach-stm32mp/syscon.c index e10c42e..6070837 100644 --- a/arch/arm/mach-stm32mp/syscon.c +++ b/arch/arm/mach-stm32mp/syscon.c @@ -10,7 +10,6 @@
static const struct udevice_id stm32mp_syscon_ids[] = { { .compatible = "st,stm32mp1-pwr", .data = STM32MP_SYSCON_PWR }, - { .compatible = "st,stm32-stgen", .data = STM32MP_SYSCON_STGEN }, { .compatible = "st,stm32mp157-syscfg", .data = STM32MP_SYSCON_SYSCFG }, { } diff --git a/drivers/clk/clk_stm32mp1.c b/drivers/clk/clk_stm32mp1.c index f295e48..5f15853 100644 --- a/drivers/clk/clk_stm32mp1.c +++ b/drivers/clk/clk_stm32mp1.c @@ -1542,8 +1542,7 @@ static void stgen_config(struct stm32mp1_clk_priv *priv) u32 stgenc, cntfid0; ulong rate;
- stgenc = (u32)syscon_get_first_range(STM32MP_SYSCON_STGEN); - + stgenc = STM32_STGEN_BASE; cntfid0 = readl(stgenc + STGENC_CNTFID0); p = stm32mp1_clk_get_parent(priv, STGEN_K); rate = stm32mp1_clk_get(priv, p);
Add "st,package" entry. Possibles values are: -STM32MP_PKG_AA for LFBGA448 (18*18) package -STM32MP_PKG_AB for LFBGA354 (16*16) package -STM32MP_PKG_AC for TFBGA361 (12*12) package -STM32MP_PKG_AD for TFBGA257 (10*10) package
see Linux commit 966d9b928f626a54a0c27c0fdae1e3dfe9bab416 for v5.2-rc1
.../pinctrl/st,stm32-pinctrl.txt | 101 ++++++++++++++++++--- include/dt-bindings/pinctrl/stm32-pinfunc.h | 6 ++ 2 files changed, 94 insertions(+), 13 deletions(-)
diff --git a/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt b/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt index c41ae91..0016925 100644 --- a/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt +++ b/doc/device-tree-bindings/pinctrl/st,stm32-pinctrl.txt @@ -8,8 +8,13 @@ controllers onto these pads. Pin controller node: Required properies: - compatible: value should be one of the following: - (a) "st,stm32f429-pinctrl" - (b) "st,stm32f746-pinctrl" + "st,stm32f429-pinctrl" + "st,stm32f469-pinctrl" + "st,stm32f746-pinctrl" + "st,stm32f769-pinctrl" + "st,stm32h743-pinctrl" + "st,stm32mp157-pinctrl" + "st,stm32mp157-z-pinctrl" - #address-cells: The value of this property must be 1 - #size-cells : The value of this property must be 1 - ranges : defines mapping between pin controller node (parent) to @@ -32,13 +37,30 @@ Required properties:
Optional properties: - reset: : Reference to the reset controller - - interrupt-parent: phandle of the interrupt parent to which the external - GPIO interrupts are forwarded to. - - st,syscfg: Should be phandle/offset pair. The phandle to the syscon node - which includes IRQ mux selection register, and the offset of the IRQ mux - selection register. + - st,syscfg: Should be phandle/offset/mask. + -The phandle to the syscon node which includes IRQ mux selection register. + -The offset of the IRQ mux selection register + -The field mask of IRQ mux, needed if different of 0xf. + - gpio-ranges: Define a dedicated mapping between a pin-controller and + a gpio controller. Format is <&phandle a b c> with: + -(phandle): phandle of pin-controller. + -(a): gpio base offset in range. + -(b): pin base offset in range. + -(c): gpio count in range + This entry has to be used either if there are holes inside a bank: + GPIOB0/B1/B2/B14/B15 (see example 2) + or if banks are not contiguous: + GPIOA/B/C/E... + NOTE: If "gpio-ranges" is used for a gpio controller, all gpio-controller + have to use a "gpio-ranges" entry. + More details in Documentation/devicetree/bindings/gpio/gpio.txt. + - st,bank-ioport: should correspond to the EXTI IOport selection (EXTI line + used to select GPIOs as interrupts). + - hwlocks: reference to a phandle of a hardware spinlock provider node. + - st,package: Indicates the SOC package used. + More details in include/dt-bindings/pinctrl/stm32-pinfunc.h
-Example: +Example 1: #include <dt-bindings/pinctrl/stm32f429-pinfunc.h> ...
@@ -60,6 +82,43 @@ Example: pin-functions nodes follow... };
+Example 2: +#include <dt-bindings/pinctrl/stm32f429-pinfunc.h> +... + + pinctrl: pin-controller { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,stm32f429-pinctrl"; + ranges = <0 0x40020000 0x3000>; + pins-are-numbered; + + gpioa: gpio@40020000 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x0 0x400>; + resets = <&reset_ahb1 0>; + st,bank-name = "GPIOA"; + gpio-ranges = <&pinctrl 0 0 16>; + }; + + gpiob: gpio@40020400 { + gpio-controller; + #gpio-cells = <2>; + reg = <0x0 0x400>; + resets = <&reset_ahb1 0>; + st,bank-name = "GPIOB"; + ngpios = 4; + gpio-ranges = <&pinctrl 0 16 3>, + <&pinctrl 14 30 2>; + }; + + + ... + pin-functions nodes follow... + }; + + Contents of function subnode node: ---------------------------------- Subnode format @@ -83,14 +142,31 @@ Required properties: - port: The gpio port index (PA = 0, PB = 1, ..., PK = 11) - line: The line offset within the port (PA0 = 0, PA1 = 1, ..., PA15 = 15) - function: The function number, can be: - * 0 : GPIO IN + * 0 : GPIO * 1 : Alternate Function 0 * 2 : Alternate Function 1 * 3 : Alternate Function 2 * ... * 16 : Alternate Function 15 * 17 : Analog - * 18 : GPIO OUT + + To simplify the usage, macro is available to generate "pinmux" field. + This macro is available here: + - include/dt-bindings/pinctrl/stm32-pinfunc.h + + Some examples of using macro: + /* GPIO A9 set as alernate function 2 */ + ... { + pinmux = <STM32_PINMUX('A', 9, AF2)>; + }; + /* GPIO A9 set as GPIO */ + ... { + pinmux = <STM32_PINMUX('A', 9, GPIO)>; + }; + /* GPIO A9 set as analog */ + ... { + pinmux = <STM32_PINMUX('A', 9, ANALOG)>; + };
Optional properties: - GENERIC_PINCONFIG: is the generic pinconfig options to use. @@ -114,13 +190,13 @@ pin-controller { ... usart1_pins_a: usart1@0 { pins1 { - pinmux = <STM32F429_PA9_FUNC_USART1_TX>; + pinmux = <STM32_PINMUX('A', 9, AF7)>; bias-disable; drive-push-pull; slew-rate = <0>; }; pins2 { - pinmux = <STM32F429_PA10_FUNC_USART1_RX>; + pinmux = <STM32_PINMUX('A', 10, AF7)>; bias-disable; }; }; @@ -129,5 +205,4 @@ pin-controller { &usart1 { pinctrl-0 = <&usart1_pins_a>; pinctrl-names = "default"; - status = "okay"; }; diff --git a/include/dt-bindings/pinctrl/stm32-pinfunc.h b/include/dt-bindings/pinctrl/stm32-pinfunc.h index b5a2174..e6fb8ad 100644 --- a/include/dt-bindings/pinctrl/stm32-pinfunc.h +++ b/include/dt-bindings/pinctrl/stm32-pinfunc.h @@ -32,5 +32,11 @@
#define STM32_PINMUX(port, line, mode) (((PIN_NO(port, line)) << 8) | (mode))
+/* package information */ +#define STM32MP_PKG_AA 0x1 +#define STM32MP_PKG_AB 0x2 +#define STM32MP_PKG_AC 0x4 +#define STM32MP_PKG_AD 0x8 + #endif /* _DT_BINDINGS_STM32_PINFUNC_H */
Prepare update of package information update in Linux device tree.
arch/arm/mach-stm32mp/cpu.c | 7 +------ arch/arm/mach-stm32mp/include/mach/sys_proto.h | 9 +++++++++ 2 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index e1a0a13..d4f2ea8 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -78,11 +78,6 @@ #define PKG_SHIFT 27 #define PKG_MASK GENMASK(2, 0)
-#define PKG_AA_LBGA448 4 -#define PKG_AB_LBGA354 3 -#define PKG_AC_TFBGA361 2 -#define PKG_AD_TFBGA257 1 - #if !defined(CONFIG_SPL) || defined(CONFIG_SPL_BUILD) #ifndef CONFIG_STM32MP1_TRUSTED static void security_init(void) @@ -277,7 +272,7 @@ u32 get_cpu_type(void) }
/* Get Package options from OTP */ -static u32 get_cpu_package(void) +u32 get_cpu_package(void) { return get_otp(BSEC_OTP_PKG, PKG_SHIFT, PKG_MASK); } diff --git a/arch/arm/mach-stm32mp/include/mach/sys_proto.h b/arch/arm/mach-stm32mp/include/mach/sys_proto.h index 71a3ba7..99eefab 100644 --- a/arch/arm/mach-stm32mp/include/mach/sys_proto.h +++ b/arch/arm/mach-stm32mp/include/mach/sys_proto.h @@ -19,5 +19,14 @@ u32 get_cpu_type(void);
/* return CPU_REV constants */ u32 get_cpu_rev(void); + +/* Get Package options from OTP */ +u32 get_cpu_package(void); + +#define PKG_AA_LBGA448 4 +#define PKG_AB_LBGA354 3 +#define PKG_AC_TFBGA361 2 +#define PKG_AD_TFBGA257 1 + /* return boot mode */ u32 get_bootmode(void);
arch/arm/Kconfig | 1 + arch/arm/mach-stm32mp/Makefile | 1 + arch/arm/mach-stm32mp/fdt.c | 45 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 47 insertions(+) create mode 100644 arch/arm/mach-stm32mp/fdt.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 01ff57c..a44cc3b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1478,6 +1478,7 @@ config ARCH_STM32MP select MISC select OF_CONTROL select OF_LIBFDT + select OF_SYSTEM_SETUP select PINCTRL select REGMAP select SUPPORT_SPL diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index 1493914..e59bd81 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -17,3 +17,4 @@ endif endif obj-$(CONFIG_ARMV7_PSCI) += psci.o obj-$(CONFIG_$(SPL_)DM_REGULATOR) += pwr_regulator.o +obj-$(CONFIG_OF_SYSTEM_SETUP) += fdt.o diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c new file mode 100644 index 0000000..c635353 --- /dev/null +++ b/arch/arm/mach-stm32mp/fdt.c @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <fdt_support.h> +#include <asm/arch/sys_proto.h> +#include <dt-bindings/pinctrl/stm32-pinfunc.h> + +/* + * This function is called right before the kernel is booted. "blob" is the + * device tree that will be passed to the kernel. + */ +int ft_system_setup(void *blob, bd_t *bd) +{ + int ret = 0; + u32 pkg; + + switch (get_cpu_package()) { + case PKG_AA_LBGA448: + pkg = STM32MP_PKG_AA; + break; + case PKG_AB_LBGA354: + pkg = STM32MP_PKG_AB; + break; + case PKG_AC_TFBGA361: + pkg = STM32MP_PKG_AC; + break; + case PKG_AD_TFBGA257: + pkg = STM32MP_PKG_AD; + break; + default: + pkg = 0; + break; + } + if (pkg) { + do_fixup_by_compat_u32(blob, "st,stm32mp157-pinctrl", + "st,package", pkg, false); + do_fixup_by_compat_u32(blob, "st,stm32mp157-z-pinctrl", + "st,package", pkg, false); + } + + return ret; +}
U-Boot should disable nodes in device tree if needed according ETZPC status in ft_system_setup().
ETZPC itself use an array on addresses to do the match between the status bits and the node.
Signed-off-by: Benjamin Gaignard benjamin.gaignard@st.com Signed-off-by: Patrick Delaunay patrick.delaunay@st.com ---
arch/arm/mach-stm32mp/Kconfig | 7 ++ arch/arm/mach-stm32mp/fdt.c | 178 ++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 185 insertions(+)
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index d9ad6b4..9c5c93c 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -83,6 +83,13 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_MMC2 Partition on the second MMC to load U-Boot from when the MMC is being used in raw mode
+config STM32_ETZPC + bool "STM32 Extended TrustZone Protection" + depends on TARGET_STM32MP1 + default y + help + Say y to enable STM32 Extended TrustZone Protection + config BOOTSTAGE_STASH_ADDR default 0xC3000000
diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index c635353..82c430b 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -7,6 +7,178 @@ #include <fdt_support.h> #include <asm/arch/sys_proto.h> #include <dt-bindings/pinctrl/stm32-pinfunc.h> +#include <linux/io.h> + +#define ETZPC_DECPROT(n) (STM32_ETZPC_BASE + 0x10 + 4 * (n)) +#define ETZPC_DECPROT_NB 6 + +#define DECPROT_MASK 0x03 +#define NB_PROT_PER_REG 0x10 +#define DECPROT_NB_BITS 2 + +#define DECPROT_SECURED 0x00 +#define DECPROT_WRITE_SECURE 0x01 +#define DECPROT_MCU_ISOLATION 0x02 +#define DECPROT_NON_SECURED 0x03 + +#define ETZPC_RESERVED 0xffffffff + +static const u32 stm32mp1_ip_addr[] = { + 0x5c008000, /* 00 stgenc */ + 0x54000000, /* 01 bkpsram */ + 0x5c003000, /* 02 iwdg1 */ + 0x5c000000, /* 03 usart1 */ + 0x5c001000, /* 04 spi6 */ + 0x5c002000, /* 05 i2c4 */ + ETZPC_RESERVED, /* 06 reserved */ + 0x54003000, /* 07 rng1 */ + 0x54002000, /* 08 hash1 */ + 0x54001000, /* 09 cryp1 */ + 0x5a003000, /* 0A ddrctrl */ + 0x5a004000, /* 0B ddrphyc */ + 0x5c009000, /* 0C i2c6 */ + ETZPC_RESERVED, /* 0D reserved */ + ETZPC_RESERVED, /* 0E reserved */ + ETZPC_RESERVED, /* 0F reserved */ + 0x40000000, /* 10 tim2 */ + 0x40001000, /* 11 tim3 */ + 0x40002000, /* 12 tim4 */ + 0x40003000, /* 13 tim5 */ + 0x40004000, /* 14 tim6 */ + 0x40005000, /* 15 tim7 */ + 0x40006000, /* 16 tim12 */ + 0x40007000, /* 17 tim13 */ + 0x40008000, /* 18 tim14 */ + 0x40009000, /* 19 lptim1 */ + 0x4000a000, /* 1A wwdg1 */ + 0x4000b000, /* 1B spi2 */ + 0x4000c000, /* 1C spi3 */ + 0x4000d000, /* 1D spdifrx */ + 0x4000e000, /* 1E usart2 */ + 0x4000f000, /* 1F usart3 */ + 0x40010000, /* 20 uart4 */ + 0x40011000, /* 21 uart5 */ + 0x40012000, /* 22 i2c1 */ + 0x40013000, /* 23 i2c2 */ + 0x40014000, /* 24 i2c3 */ + 0x40015000, /* 25 i2c5 */ + 0x40016000, /* 26 cec */ + 0x40017000, /* 27 dac */ + 0x40018000, /* 28 uart7 */ + 0x40019000, /* 29 uart8 */ + ETZPC_RESERVED, /* 2A reserved */ + ETZPC_RESERVED, /* 2B reserved */ + 0x4001c000, /* 2C mdios */ + ETZPC_RESERVED, /* 2D reserved */ + ETZPC_RESERVED, /* 2E reserved */ + ETZPC_RESERVED, /* 2F reserved */ + 0x44000000, /* 30 tim1 */ + 0x44001000, /* 31 tim8 */ + ETZPC_RESERVED, /* 32 reserved */ + 0x44003000, /* 33 usart6 */ + 0x44004000, /* 34 spi1 */ + 0x44005000, /* 35 spi4 */ + 0x44006000, /* 36 tim15 */ + 0x44007000, /* 37 tim16 */ + 0x44008000, /* 38 tim17 */ + 0x44009000, /* 39 spi5 */ + 0x4400a000, /* 3A sai1 */ + 0x4400b000, /* 3B sai2 */ + 0x4400c000, /* 3C sai3 */ + 0x4400d000, /* 3D dfsdm */ + 0x4400e000, /* 3E tt_fdcan */ + ETZPC_RESERVED, /* 3F reserved */ + 0x50021000, /* 40 lptim2 */ + 0x50022000, /* 41 lptim3 */ + 0x50023000, /* 42 lptim4 */ + 0x50024000, /* 43 lptim5 */ + 0x50027000, /* 44 sai4 */ + 0x50025000, /* 45 vrefbuf */ + 0x4c006000, /* 46 dcmi */ + 0x4c004000, /* 47 crc2 */ + 0x48003000, /* 48 adc */ + 0x4c002000, /* 49 hash2 */ + 0x4c003000, /* 4A rng2 */ + 0x4c005000, /* 4B cryp2 */ + ETZPC_RESERVED, /* 4C reserved */ + ETZPC_RESERVED, /* 4D reserved */ + ETZPC_RESERVED, /* 4E reserved */ + ETZPC_RESERVED, /* 4F reserved */ + ETZPC_RESERVED, /* 50 sram1 */ + ETZPC_RESERVED, /* 51 sram2 */ + ETZPC_RESERVED, /* 52 sram3 */ + ETZPC_RESERVED, /* 53 sram4 */ + ETZPC_RESERVED, /* 54 retram */ + 0x49000000, /* 55 otg */ + 0x48004000, /* 56 sdmmc3 */ + 0x48005000, /* 57 dlybsd3 */ + 0x48000000, /* 58 dma1 */ + 0x48001000, /* 59 dma2 */ + 0x48002000, /* 5A dmamux */ + 0x58002000, /* 5B fmc */ + 0x58003000, /* 5C qspi */ + 0x58004000, /* 5D dlybq */ + 0x5800a000, /* 5E eth */ + ETZPC_RESERVED, /* 5F reserved */ +}; + +/* fdt helper */ +static bool fdt_disable_subnode_by_address(void *fdt, int offset, u32 addr) +{ + int node; + + for (node = fdt_first_subnode(fdt, offset); + node >= 0; + node = fdt_next_subnode(fdt, node)) { + if (addr == (u32)fdt_getprop(fdt, node, "reg", 0)) { + if (fdtdec_get_is_enabled(fdt, node)) { + fdt_status_disabled(fdt, node); + + return true; + } + return false; + } + } + + return false; +} + +static int stm32_fdt_fixup_etzpc(void *fdt) +{ + const u32 *array; + int array_size, i; + int soc_node, offset, shift; + u32 addr, status, decprot[ETZPC_DECPROT_NB]; + + array = stm32mp1_ip_addr; + array_size = ARRAY_SIZE(stm32mp1_ip_addr); + + for (i = 0; i < ETZPC_DECPROT_NB; i++) + decprot[i] = readl(ETZPC_DECPROT(i)); + + soc_node = fdt_path_offset(fdt, "/soc"); + if (soc_node < 0) + return soc_node; + + for (i = 0; i < array_size; i++) { + offset = i / NB_PROT_PER_REG; + shift = (i % NB_PROT_PER_REG) * DECPROT_NB_BITS; + status = (decprot[offset] >> shift) & DECPROT_MASK; + addr = array[i]; + + debug("ETZPC: 0x%08x decprot %d=%d\n", addr, i, status); + + if (addr == ETZPC_RESERVED || + status == DECPROT_NON_SECURED) + continue; + + if (fdt_disable_subnode_by_address(fdt, soc_node, addr)) + printf("ETZPC: 0x%08x node disabled, decprot %d=%d\n", + addr, i, status); + } + + return 0; +}
/* * This function is called right before the kernel is booted. "blob" is the @@ -17,6 +189,12 @@ int ft_system_setup(void *blob, bd_t *bd) int ret = 0; u32 pkg;
+ if (CONFIG_IS_ENABLED(STM32_ETZPC)) { + ret = stm32_fdt_fixup_etzpc(blob); + if (ret) + return ret; + } + switch (get_cpu_package()) { case PKG_AA_LBGA448: pkg = STM32MP_PKG_AA;
Allow to update board identification in OTP 59.
board/st/stm32mp1/Kconfig | 7 ++ board/st/stm32mp1/Makefile | 1 + board/st/stm32mp1/cmd_stboard.c | 145 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 153 insertions(+) create mode 100644 board/st/stm32mp1/cmd_stboard.c
diff --git a/board/st/stm32mp1/Kconfig b/board/st/stm32mp1/Kconfig index 5ab9415..92d8f90 100644 --- a/board/st/stm32mp1/Kconfig +++ b/board/st/stm32mp1/Kconfig @@ -9,4 +9,11 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "stm32mp1"
+config CMD_STBOARD + bool "stboard - command for OTP board information" + default y + help + This compile the stboard command to + read and write the board in the OTP. + endif diff --git a/board/st/stm32mp1/Makefile b/board/st/stm32mp1/Makefile index 8188075..3c6c035 100644 --- a/board/st/stm32mp1/Makefile +++ b/board/st/stm32mp1/Makefile @@ -7,6 +7,7 @@ ifdef CONFIG_SPL_BUILD obj-y += spl.o else obj-y += stm32mp1.o +obj-$(CONFIG_CMD_STBOARD) += cmd_stboard.o endif
obj-y += board.o diff --git a/board/st/stm32mp1/cmd_stboard.c b/board/st/stm32mp1/cmd_stboard.c new file mode 100644 index 0000000..f781c36 --- /dev/null +++ b/board/st/stm32mp1/cmd_stboard.c @@ -0,0 +1,145 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <console.h> +#include <misc.h> +#include <dm/device.h> +#include <dm/uclass.h> + +static bool check_stboard(u16 board) +{ + unsigned int i; + const u16 st_board_id[] = { + 0x1272, + 0x1263, + 0x1264, + 0x1298, + 0x1341, + 0x1497, + }; + + for (i = 0; i < ARRAY_SIZE(st_board_id); i++) + if (board == st_board_id[i]) + return true; + + return false; +} + +static void display_stboard(u32 otp) +{ + printf("Board: MB%04x Var%d Rev.%c-%02d\n", + otp >> 16, + (otp >> 12) & 0xF, + ((otp >> 8) & 0xF) - 1 + 'A', + otp & 0xF); +} + +static int do_stboard(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + int ret; + u32 otp; + u8 revision; + unsigned long board, variant, bom; + struct udevice *dev; + int confirmed = argc == 6 && !strcmp(argv[1], "-y"); + + argc -= 1 + confirmed; + argv += 1 + confirmed; + + if (argc != 0 && argc != 4) + return CMD_RET_USAGE; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev); + + ret = misc_read(dev, STM32_BSEC_SHADOW(BSEC_OTP_BOARD), + &otp, sizeof(otp)); + + if (ret) { + puts("OTP read error"); + return CMD_RET_FAILURE; + } + + if (argc == 0) { + if (!otp) + puts("Board : OTP board FREE\n"); + else + display_stboard(otp); + return CMD_RET_SUCCESS; + } + + if (otp) { + display_stboard(otp); + printf("ERROR: OTP board not FREE\n"); + return CMD_RET_FAILURE; + } + + if (strict_strtoul(argv[0], 16, &board) < 0 || + board == 0 || board > 0xFFFF) { + printf("argument %d invalid: %s\n", 1, argv[0]); + return CMD_RET_USAGE; + } + + if (strict_strtoul(argv[1], 10, &variant) < 0 || + variant == 0 || variant > 15) { + printf("argument %d invalid: %s\n", 2, argv[1]); + return CMD_RET_USAGE; + } + + revision = argv[2][0] - 'A' + 1; + if (strlen(argv[2]) > 1 || revision == 0 || revision > 15) { + printf("argument %d invalid: %s\n", 3, argv[2]); + return CMD_RET_USAGE; + } + + if (strict_strtoul(argv[3], 10, &bom) < 0 || + bom == 0 || bom > 15) { + printf("argument %d invalid: %s\n", 4, argv[3]); + return CMD_RET_USAGE; + } + + otp = (board << 16) | (variant << 12) | (revision << 8) | bom; + display_stboard(otp); + printf("=> OTP[%d] = %08X\n", BSEC_OTP_BOARD, otp); + + if (!check_stboard((u16)board)) { + printf("Unknown board MB%04x\n", (u16)board); + return CMD_RET_FAILURE; + } + if (!confirmed) { + printf("Warning: Programming BOARD in OTP is irreversible!\n"); + printf("Really perform this OTP programming? <y/N>\n"); + + if (!confirm_yesno()) { + puts("BOARD programming aborted\n"); + return CMD_RET_FAILURE; + } + } + + ret = misc_write(dev, STM32_BSEC_OTP(BSEC_OTP_BOARD), + &otp, sizeof(otp)); + + if (ret) { + puts("BOARD programming error\n"); + return CMD_RET_FAILURE; + } + puts("BOARD programming done\n"); + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD(stboard, 6, 0, do_stboard, + "read/write board reference in OTP", + "\n" + " Print current board information\n" + "stboard [-y] <Board> <Variant> <Revision> <BOM>\n" + " Write board information\n" + " - Board: xxxx, example 1264 for MB1264\n" + " - Variant: 1 ... 15\n" + " - Revision: A...O\n" + " - BOM: 1...15\n");
Add dedicated command to register in fuse a public hash key provided by keygen tool.
arch/arm/mach-stm32mp/Kconfig | 8 +++ arch/arm/mach-stm32mp/Makefile | 1 + arch/arm/mach-stm32mp/cmd_stm32key.c | 101 +++++++++++++++++++++++++++++++++++ 3 files changed, 110 insertions(+) create mode 100644 arch/arm/mach-stm32mp/cmd_stm32key.c
diff --git a/arch/arm/mach-stm32mp/Kconfig b/arch/arm/mach-stm32mp/Kconfig index 9c5c93c..d13d76e 100644 --- a/arch/arm/mach-stm32mp/Kconfig +++ b/arch/arm/mach-stm32mp/Kconfig @@ -90,6 +90,14 @@ config STM32_ETZPC help Say y to enable STM32 Extended TrustZone Protection
+config CMD_STM32KEY + bool "command stm32key to fuse public key hash" + default y + depends on CMD_FUSE + help + fuse public key hash in corresponding fuse used to authenticate + binary. + config BOOTSTAGE_STASH_ADDR default 0xC3000000
diff --git a/arch/arm/mach-stm32mp/Makefile b/arch/arm/mach-stm32mp/Makefile index e59bd81..7745060 100644 --- a/arch/arm/mach-stm32mp/Makefile +++ b/arch/arm/mach-stm32mp/Makefile @@ -11,6 +11,7 @@ ifdef CONFIG_SPL_BUILD obj-y += spl.o else obj-y += bsec.o +obj-$(CONFIG_CMD_STM32KEY) += cmd_stm32key.o ifndef CONFIG_STM32MP1_TRUSTED obj-$(CONFIG_SYSRESET) += cmd_poweroff.o endif diff --git a/arch/arm/mach-stm32mp/cmd_stm32key.c b/arch/arm/mach-stm32mp/cmd_stm32key.c new file mode 100644 index 0000000..f1f26e7 --- /dev/null +++ b/arch/arm/mach-stm32mp/cmd_stm32key.c @@ -0,0 +1,101 @@ +// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause +/* + * Copyright (C) 2019, STMicroelectronics - All Rights Reserved + */ + +#include <common.h> +#include <command.h> +#include <console.h> +#include <misc.h> +#include <dm/device.h> +#include <dm/uclass.h> + +#define STM32_OTP_HASH_KEY_START 24 +#define STM32_OTP_HASH_KEY_SIZE 8 + +static void read_hash_value(u32 addr) +{ + int i; + + for (i = 0; i < STM32_OTP_HASH_KEY_SIZE; i++) { + printf("OTP value %i: %x\n", STM32_OTP_HASH_KEY_START + i, + __be32_to_cpu(*(u32 *)addr)); + addr += 4; + } +} + +static void fuse_hash_value(u32 addr, bool print) +{ + struct udevice *dev; + u32 word, val; + int i, ret; + + ret = uclass_get_device_by_driver(UCLASS_MISC, + DM_GET_DRIVER(stm32mp_bsec), + &dev); + if (ret) { + pr_err("Can't find stm32mp_bsec driver\n"); + return; + } + + for (i = 0; i < STM32_OTP_HASH_KEY_SIZE; i++) { + if (print) + printf("Fuse OTP %i : %x\n", + STM32_OTP_HASH_KEY_START + i, + __be32_to_cpu(*(u32 *)addr)); + + word = STM32_OTP_HASH_KEY_START + i; + val = __be32_to_cpu(*(u32 *)addr); + misc_write(dev, STM32_BSEC_OTP(word), &val, 4); + + addr += 4; + } +} + +static int confirm_prog(void) +{ + puts("Warning: Programming fuses is an irreversible operation!\n" + " This may brick your system.\n" + " Use this command only if you are sure of what you are doing!\n" + "\nReally perform this fuse programming? <y/N>\n"); + + if (confirm_yesno()) + return 1; + + puts("Fuse programming aborted\n"); + return 0; +} + +static int do_stm32key(cmd_tbl_t *cmdtp, int flag, int argc, + char * const argv[]) +{ + u32 addr; + const char *op = argc >= 2 ? argv[1] : NULL; + int confirmed = argc > 3 && !strcmp(argv[2], "-y"); + + argc -= 2 + confirmed; + argv += 2 + confirmed; + + if (argc < 1) + return CMD_RET_USAGE; + + addr = simple_strtoul(argv[0], NULL, 16); + if (!addr) + return CMD_RET_USAGE; + + if (!strcmp(op, "read")) + read_hash_value(addr); + + if (!strcmp(op, "fuse")) { + if (!confirmed && !confirm_prog()) + return CMD_RET_FAILURE; + fuse_hash_value(addr, !confirmed); + } + + return CMD_RET_SUCCESS; +} + +U_BOOT_CMD(stm32key, 4, 1, do_stm32key, + "Fuse ST Hash key", + "read <addr>: Read the hash store at addr in memory\n" + "stm32key fuse [-y] <addr> : Fuse hash store at addr in otp\n");
Add latest information and correct some information.
board/st/stm32mp1/README | 15 ++++++++++++--- 1 file changed, 12 insertions(+), 3 deletions(-)
diff --git a/board/st/stm32mp1/README b/board/st/stm32mp1/README index b0c8325..dc36a21 100644 --- a/board/st/stm32mp1/README +++ b/board/st/stm32mp1/README @@ -25,6 +25,10 @@ It features: Everything is supported in Linux but U-Boot is limited to: 1. UART 2. SDCard/MMC controller (SDMMC) +3. NAND controller (FMC) +4. NOR controller (QSPI) +5. USB controller (OTG DWC2) +6. Ethernet controller
And the necessary drivers 1. I2C @@ -54,13 +58,13 @@ with FSBL = First Stage Bootloader TF-A performs a full initialization of Secure peripherals and installs a secure monitor. U-Boot is running in normal world and uses TF-A monitor - to access to secure resources + to access to secure resources.
2) The "Basic" boot chain (defconfig_file : stm32mp15_basic_defconfig) BootRom => FSBL = U-Boot SPL => SSBL = U-Boot SPL has limited security initialisation U-Boot is running in secure mode and provide a secure monitor to the kernel - with only PSCI support (Power State Coordination Interface defined by ARM) + with only PSCI support (Power State Coordination Interface defined by ARM).
All the STM32MP1 boards supported by U-Boot use the same generic board stm32mp1 which support all the bootable devices. @@ -111,6 +115,9 @@ the supported device trees for stm32mp157 are: # export KBUILD_OUTPUT=stm32mp15_trusted # export KBUILD_OUTPUT=stm32mp15_basic
+ you can build outside of code directory: + # export KBUILD_OUTPUT=../build/stm32mp15_trusted + 4. Configure U-Boot:
# make <defconfig_file> @@ -170,6 +177,8 @@ the supported device trees for stm32mp157 are:
You can select the boot mode, on the board ed1 with the switch SW1
+- on the daugther board ed1 with the switch SW1 : BOOT0, BOOT1, BOOT2 + ----------------------------------- Boot Mode BOOT2 BOOT1 BOOT0 ----------------------------------- @@ -267,7 +276,7 @@ for example: with gpt table with 128 entries # dd if=tf-a.stm32 of=/dev/mmcblk0p2 # dd if=u-boot.stm32 of=/dev/mmcblk0p3
-To boot from SDCard, select BootPinMode = 1 1 1 and reset. +To boot from SDCard, select BootPinMode = 1 0 1 and reset.
8. Prepare eMMC ===============
Remove post.h include as it is used in spl.c
board/st/stm32mp1/spl.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/board/st/stm32mp1/spl.c b/board/st/stm32mp1/spl.c index a7844f2..e19be0f 100644 --- a/board/st/stm32mp1/spl.c +++ b/board/st/stm32mp1/spl.c @@ -9,7 +9,6 @@ #include <dm.h> #include <ram.h> #include <asm/io.h> -#include <post.h> #include <power/pmic.h> #include <power/stpmic1.h> #include <asm/arch/ddr.h>
Removes unused device tree property in SPL to reduce the SPL size by 1kB
configs/stm32mp15_basic_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index b1fc3a2..965ea71 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -43,6 +43,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_UBI=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_DEFAULT_DEVICE_TREE="stm32mp157c-ev1" +CONFIG_OF_SPL_REMOVE_PROPS="interrupts interrupt-names interrupts-extended interrupt-controller \#interrupt-cells interrupt-parent dmas dma-names assigned-clocks assigned-clock-rates assigned-clock-parents hwlocks" CONFIG_ENV_IS_NOWHERE=y CONFIG_ENV_IS_IN_EXT4=y CONFIG_ENV_IS_IN_SPI_FLASH=y
For boot from flash, check presence of default environment to force save env.
include/configs/stm32mp1.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 1d385e0..6c74b4b 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -112,6 +112,7 @@ "if test ${boot_device} = serial || test ${boot_device} = usb;" \ "then stm32prog ${boot_device} ${boot_instance}; " \ "else " \ + "run env_check;" \ "if test ${boot_device} = mmc;" \ "then env set boot_targets "mmc${boot_instance}"; fi;" \ "if test ${boot_device} = nand;" \ @@ -143,6 +144,9 @@ "ramdisk_addr_r=0xc4400000\0" \ "fdt_high=0xffffffff\0" \ "initrd_high=0xffffffff\0" \ + "env_default=1\0" \ + "env_check=if test $env_default -eq 1;"\ + " then env set env_default 0;env save;fi\0" \ STM32MP_BOOTCMD \ STM32MP_MTDPARTS \ BOOTENV
Prevent USB enumeration and avoid unnecessary delay in bootcmd_pxe as Ethernet device is not attached to USB.
include/configs/stm32mp1.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/stm32mp1.h b/include/configs/stm32mp1.h index 6c74b4b..94485a1 100644 --- a/include/configs/stm32mp1.h +++ b/include/configs/stm32mp1.h @@ -149,7 +149,8 @@ " then env set env_default 0;env save;fi\0" \ STM32MP_BOOTCMD \ STM32MP_MTDPARTS \ - BOOTENV + BOOTENV \ + "boot_net_usb_start=true\0"
#endif /* ifndef CONFIG_SPL_BUILD */ #endif /* ifdef CONFIG_DISTRO_DEFAULTS*/
Synchronize device tree with v5.2-rc4 label and update the associated u-boot dtsi.
arch/arm/dts/stm32mp15-ddr.dtsi | 2 +- arch/arm/dts/stm32mp157-pinctrl.dtsi | 270 ++++++++++++++++++++++++++++++- arch/arm/dts/stm32mp157-u-boot.dtsi | 60 ++++--- arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 4 - arch/arm/dts/stm32mp157a-dk1.dts | 30 ++-- arch/arm/dts/stm32mp157c-dk2.dts | 1 + arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 15 +- arch/arm/dts/stm32mp157c-ed1.dts | 205 +++++------------------ arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 4 - arch/arm/dts/stm32mp157c-ev1.dts | 12 +- arch/arm/dts/stm32mp157c.dtsi | 199 +++++++++++++++++------ 11 files changed, 534 insertions(+), 268 deletions(-)
diff --git a/arch/arm/dts/stm32mp15-ddr.dtsi b/arch/arm/dts/stm32mp15-ddr.dtsi index 4172c02..0164e34 100644 --- a/arch/arm/dts/stm32mp15-ddr.dtsi +++ b/arch/arm/dts/stm32mp15-ddr.dtsi @@ -5,7 +5,7 @@
/ { soc { - ddr: ddr@0x5A003000{ + ddr: ddr@5A003000{ u-boot,dm-pre-reloc;
compatible = "st,stm32mp1-ddr"; diff --git a/arch/arm/dts/stm32mp157-pinctrl.dtsi b/arch/arm/dts/stm32mp157-pinctrl.dtsi index 4c424c4..9bae850 100644 --- a/arch/arm/dts/stm32mp157-pinctrl.dtsi +++ b/arch/arm/dts/stm32mp157-pinctrl.dtsi @@ -14,6 +14,7 @@ ranges = <0 0x50002000 0xa400>; interrupt-parent = <&exti>; st,syscfg = <&exti 0x60 0xff>; + hwlocks = <&hwspinlock 0>; pins-are-numbered;
gpioa: gpio@50002000 { @@ -164,6 +165,27 @@ }; };
+ cec_pins_sleep_a: cec-sleep-0 { + pins { + pinmux = <STM32_PINMUX('A', 15, ANALOG)>; /* HDMI_CEC */ + }; + }; + + cec_pins_b: cec-1 { + pins { + pinmux = <STM32_PINMUX('B', 6, AF5)>; + bias-disable; + drive-open-drain; + slew-rate = <0>; + }; + }; + + cec_pins_sleep_b: cec-sleep-1 { + pins { + pinmux = <STM32_PINMUX('B', 6, ANALOG)>; /* HDMI_CEC */ + }; + }; + ethernet0_rgmii_pins_a: rgmii-0 { pins1 { pinmux = <STM32_PINMUX('G', 5, AF11)>, /* ETH_RGMII_CLK125 */ @@ -269,7 +291,14 @@ }; };
- i2c1_pins_b: i2c1-1 { + i2c1_pins_sleep_a: i2c1-1 { + pins { + pinmux = <STM32_PINMUX('D', 12, ANALOG)>, /* I2C1_SCL */ + <STM32_PINMUX('F', 15, ANALOG)>; /* I2C1_SDA */ + }; + }; + + i2c1_pins_b: i2c1-2 { pins { pinmux = <STM32_PINMUX('F', 14, AF5)>, /* I2C1_SCL */ <STM32_PINMUX('F', 15, AF5)>; /* I2C1_SDA */ @@ -289,7 +318,14 @@ }; };
- i2c2_pins_b: i2c2-1 { + i2c2_pins_sleep_a: i2c2-1 { + pins { + pinmux = <STM32_PINMUX('H', 4, ANALOG)>, /* I2C2_SCL */ + <STM32_PINMUX('H', 5, ANALOG)>; /* I2C2_SDA */ + }; + }; + + i2c2_pins_b: i2c2-2 { pins { pinmux = <STM32_PINMUX('Z', 0, AF3)>, /* I2C2_SCL */ <STM32_PINMUX('H', 5, AF4)>; /* I2C2_SDA */ @@ -309,6 +345,152 @@ }; };
+ i2c5_pins_sleep_a: i2c5-1 { + pins { + pinmux = <STM32_PINMUX('A', 11, ANALOG)>, /* I2C5_SCL */ + <STM32_PINMUX('A', 12, ANALOG)>; /* I2C5_SDA */ + + }; + }; + + ltdc_pins_a: ltdc-a-0 { + pins { + pinmux = <STM32_PINMUX('G', 7, AF14)>, /* LCD_CLK */ + <STM32_PINMUX('I', 10, AF14)>, /* LCD_HSYNC */ + <STM32_PINMUX('I', 9, AF14)>, /* LCD_VSYNC */ + <STM32_PINMUX('F', 10, AF14)>, /* LCD_DE */ + <STM32_PINMUX('H', 2, AF14)>, /* LCD_R0 */ + <STM32_PINMUX('H', 3, AF14)>, /* LCD_R1 */ + <STM32_PINMUX('H', 8, AF14)>, /* LCD_R2 */ + <STM32_PINMUX('H', 9, AF14)>, /* LCD_R3 */ + <STM32_PINMUX('H', 10, AF14)>, /* LCD_R4 */ + <STM32_PINMUX('C', 0, AF14)>, /* LCD_R5 */ + <STM32_PINMUX('H', 12, AF14)>, /* LCD_R6 */ + <STM32_PINMUX('E', 15, AF14)>, /* LCD_R7 */ + <STM32_PINMUX('E', 5, AF14)>, /* LCD_G0 */ + <STM32_PINMUX('E', 6, AF14)>, /* LCD_G1 */ + <STM32_PINMUX('H', 13, AF14)>, /* LCD_G2 */ + <STM32_PINMUX('H', 14, AF14)>, /* LCD_G3 */ + <STM32_PINMUX('H', 15, AF14)>, /* LCD_G4 */ + <STM32_PINMUX('I', 0, AF14)>, /* LCD_G5 */ + <STM32_PINMUX('I', 1, AF14)>, /* LCD_G6 */ + <STM32_PINMUX('I', 2, AF14)>, /* LCD_G7 */ + <STM32_PINMUX('D', 9, AF14)>, /* LCD_B0 */ + <STM32_PINMUX('G', 12, AF14)>, /* LCD_B1 */ + <STM32_PINMUX('G', 10, AF14)>, /* LCD_B2 */ + <STM32_PINMUX('D', 10, AF14)>, /* LCD_B3 */ + <STM32_PINMUX('I', 4, AF14)>, /* LCD_B4 */ + <STM32_PINMUX('A', 3, AF14)>, /* LCD_B5 */ + <STM32_PINMUX('B', 8, AF14)>, /* LCD_B6 */ + <STM32_PINMUX('D', 8, AF14)>; /* LCD_B7 */ + bias-disable; + drive-push-pull; + slew-rate = <1>; + }; + }; + + ltdc_pins_sleep_a: ltdc-a-1 { + pins { + pinmux = <STM32_PINMUX('G', 7, ANALOG)>, /* LCD_CLK */ + <STM32_PINMUX('I', 10, ANALOG)>, /* LCD_HSYNC */ + <STM32_PINMUX('I', 9, ANALOG)>, /* LCD_VSYNC */ + <STM32_PINMUX('F', 10, ANALOG)>, /* LCD_DE */ + <STM32_PINMUX('H', 2, ANALOG)>, /* LCD_R0 */ + <STM32_PINMUX('H', 3, ANALOG)>, /* LCD_R1 */ + <STM32_PINMUX('H', 8, ANALOG)>, /* LCD_R2 */ + <STM32_PINMUX('H', 9, ANALOG)>, /* LCD_R3 */ + <STM32_PINMUX('H', 10, ANALOG)>, /* LCD_R4 */ + <STM32_PINMUX('C', 0, ANALOG)>, /* LCD_R5 */ + <STM32_PINMUX('H', 12, ANALOG)>, /* LCD_R6 */ + <STM32_PINMUX('E', 15, ANALOG)>, /* LCD_R7 */ + <STM32_PINMUX('E', 5, ANALOG)>, /* LCD_G0 */ + <STM32_PINMUX('E', 6, ANALOG)>, /* LCD_G1 */ + <STM32_PINMUX('H', 13, ANALOG)>, /* LCD_G2 */ + <STM32_PINMUX('H', 14, ANALOG)>, /* LCD_G3 */ + <STM32_PINMUX('H', 15, ANALOG)>, /* LCD_G4 */ + <STM32_PINMUX('I', 0, ANALOG)>, /* LCD_G5 */ + <STM32_PINMUX('I', 1, ANALOG)>, /* LCD_G6 */ + <STM32_PINMUX('I', 2, ANALOG)>, /* LCD_G7 */ + <STM32_PINMUX('D', 9, ANALOG)>, /* LCD_B0 */ + <STM32_PINMUX('G', 12, ANALOG)>, /* LCD_B1 */ + <STM32_PINMUX('G', 10, ANALOG)>, /* LCD_B2 */ + <STM32_PINMUX('D', 10, ANALOG)>, /* LCD_B3 */ + <STM32_PINMUX('I', 4, ANALOG)>, /* LCD_B4 */ + <STM32_PINMUX('A', 3, ANALOG)>, /* LCD_B5 */ + <STM32_PINMUX('B', 8, ANALOG)>, /* LCD_B6 */ + <STM32_PINMUX('D', 8, ANALOG)>; /* LCD_B7 */ + }; + }; + + ltdc_pins_b: ltdc-b-0 { + pins { + pinmux = <STM32_PINMUX('I', 14, AF14)>, /* LCD_CLK */ + <STM32_PINMUX('I', 12, AF14)>, /* LCD_HSYNC */ + <STM32_PINMUX('I', 13, AF14)>, /* LCD_VSYNC */ + <STM32_PINMUX('K', 7, AF14)>, /* LCD_DE */ + <STM32_PINMUX('I', 15, AF14)>, /* LCD_R0 */ + <STM32_PINMUX('J', 0, AF14)>, /* LCD_R1 */ + <STM32_PINMUX('J', 1, AF14)>, /* LCD_R2 */ + <STM32_PINMUX('J', 2, AF14)>, /* LCD_R3 */ + <STM32_PINMUX('J', 3, AF14)>, /* LCD_R4 */ + <STM32_PINMUX('J', 4, AF14)>, /* LCD_R5 */ + <STM32_PINMUX('J', 5, AF14)>, /* LCD_R6 */ + <STM32_PINMUX('J', 6, AF14)>, /* LCD_R7 */ + <STM32_PINMUX('J', 7, AF14)>, /* LCD_G0 */ + <STM32_PINMUX('J', 8, AF14)>, /* LCD_G1 */ + <STM32_PINMUX('J', 9, AF14)>, /* LCD_G2 */ + <STM32_PINMUX('J', 10, AF14)>, /* LCD_G3 */ + <STM32_PINMUX('J', 11, AF14)>, /* LCD_G4 */ + <STM32_PINMUX('K', 0, AF14)>, /* LCD_G5 */ + <STM32_PINMUX('K', 1, AF14)>, /* LCD_G6 */ + <STM32_PINMUX('K', 2, AF14)>, /* LCD_G7 */ + <STM32_PINMUX('J', 12, AF14)>, /* LCD_B0 */ + <STM32_PINMUX('J', 13, AF14)>, /* LCD_B1 */ + <STM32_PINMUX('J', 14, AF14)>, /* LCD_B2 */ + <STM32_PINMUX('J', 15, AF14)>, /* LCD_B3 */ + <STM32_PINMUX('K', 3, AF14)>, /* LCD_B4 */ + <STM32_PINMUX('K', 4, AF14)>, /* LCD_B5 */ + <STM32_PINMUX('K', 5, AF14)>, /* LCD_B6 */ + <STM32_PINMUX('K', 6, AF14)>; /* LCD_B7 */ + bias-disable; + drive-push-pull; + slew-rate = <1>; + }; + }; + + ltdc_pins_sleep_b: ltdc-b-1 { + pins { + pinmux = <STM32_PINMUX('I', 14, ANALOG)>, /* LCD_CLK */ + <STM32_PINMUX('I', 12, ANALOG)>, /* LCD_HSYNC */ + <STM32_PINMUX('I', 13, ANALOG)>, /* LCD_VSYNC */ + <STM32_PINMUX('K', 7, ANALOG)>, /* LCD_DE */ + <STM32_PINMUX('I', 15, ANALOG)>, /* LCD_R0 */ + <STM32_PINMUX('J', 0, ANALOG)>, /* LCD_R1 */ + <STM32_PINMUX('J', 1, ANALOG)>, /* LCD_R2 */ + <STM32_PINMUX('J', 2, ANALOG)>, /* LCD_R3 */ + <STM32_PINMUX('J', 3, ANALOG)>, /* LCD_R4 */ + <STM32_PINMUX('J', 4, ANALOG)>, /* LCD_R5 */ + <STM32_PINMUX('J', 5, ANALOG)>, /* LCD_R6 */ + <STM32_PINMUX('J', 6, ANALOG)>, /* LCD_R7 */ + <STM32_PINMUX('J', 7, ANALOG)>, /* LCD_G0 */ + <STM32_PINMUX('J', 8, ANALOG)>, /* LCD_G1 */ + <STM32_PINMUX('J', 9, ANALOG)>, /* LCD_G2 */ + <STM32_PINMUX('J', 10, ANALOG)>, /* LCD_G3 */ + <STM32_PINMUX('J', 11, ANALOG)>, /* LCD_G4 */ + <STM32_PINMUX('K', 0, ANALOG)>, /* LCD_G5 */ + <STM32_PINMUX('K', 1, ANALOG)>, /* LCD_G6 */ + <STM32_PINMUX('K', 2, ANALOG)>, /* LCD_G7 */ + <STM32_PINMUX('J', 12, ANALOG)>, /* LCD_B0 */ + <STM32_PINMUX('J', 13, ANALOG)>, /* LCD_B1 */ + <STM32_PINMUX('J', 14, ANALOG)>, /* LCD_B2 */ + <STM32_PINMUX('J', 15, ANALOG)>, /* LCD_B3 */ + <STM32_PINMUX('K', 3, ANALOG)>, /* LCD_B4 */ + <STM32_PINMUX('K', 4, ANALOG)>, /* LCD_B5 */ + <STM32_PINMUX('K', 5, ANALOG)>, /* LCD_B6 */ + <STM32_PINMUX('K', 6, ANALOG)>; /* LCD_B7 */ + }; + }; + m_can1_pins_a: m-can1-0 { pins1 { pinmux = <STM32_PINMUX('H', 13, AF9)>; /* CAN1_TX */ @@ -322,6 +504,13 @@ }; };
+ m_can1_sleep_pins_a: m_can1-sleep@0 { + pins { + pinmux = <STM32_PINMUX('H', 13, ANALOG)>, /* CAN1_TX */ + <STM32_PINMUX('I', 9, ANALOG)>; /* CAN1_RX */ + }; + }; + pwm2_pins_a: pwm2-0 { pins { pinmux = <STM32_PINMUX('A', 3, AF1)>; /* TIM2_CH4 */ @@ -393,7 +582,8 @@ slew-rate = <3>; }; }; - sdmmc1_b4_pins_a: sdmmc1-b4@0 { + + sdmmc1_b4_pins_a: sdmmc1-b4-0 { pins { pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ @@ -407,18 +597,61 @@ }; };
- sdmmc1_dir_pins_a: sdmmc1-dir@0 { + sdmmc1_b4_od_pins_a: sdmmc1-b4-od-0 { + pins1 { + pinmux = <STM32_PINMUX('C', 8, AF12)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, AF12)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, AF12)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, AF12)>, /* SDMMC1_D3 */ + <STM32_PINMUX('C', 12, AF12)>; /* SDMMC1_CK */ + slew-rate = <3>; + drive-push-pull; + bias-disable; + }; + pins2{ + pinmux = <STM32_PINMUX('D', 2, AF12)>; /* SDMMC1_CMD */ + slew-rate = <3>; + drive-open-drain; + bias-disable; + }; + }; + + sdmmc1_b4_sleep_pins_a: sdmmc1-b4-sleep-0 { pins { + pinmux = <STM32_PINMUX('C', 8, ANALOG)>, /* SDMMC1_D0 */ + <STM32_PINMUX('C', 9, ANALOG)>, /* SDMMC1_D1 */ + <STM32_PINMUX('C', 10, ANALOG)>, /* SDMMC1_D2 */ + <STM32_PINMUX('C', 11, ANALOG)>, /* SDMMC1_D3 */ + <STM32_PINMUX('C', 12, ANALOG)>, /* SDMMC1_CK */ + <STM32_PINMUX('D', 2, ANALOG)>; /* SDMMC1_CMD */ + }; + }; + + sdmmc1_dir_pins_a: sdmmc1-dir-0 { + pins1 { pinmux = <STM32_PINMUX('F', 2, AF11)>, /* SDMMC1_D0DIR */ <STM32_PINMUX('C', 7, AF8)>, /* SDMMC1_D123DIR */ - <STM32_PINMUX('B', 9, AF11)>, /* SDMMC1_CDIR */ - <STM32_PINMUX('E', 4, AF8)>; /* SDMMC1_CKIN */ + <STM32_PINMUX('B', 9, AF11)>; /* SDMMC1_CDIR */ slew-rate = <3>; drive-push-pull; bias-pull-up; }; + pins2{ + pinmux = <STM32_PINMUX('E', 4, AF8)>; /* SDMMC1_CKIN */ + bias-pull-up; + }; }; - sdmmc2_b4_pins_a: sdmmc2-b4@0 { + + sdmmc1_dir_sleep_pins_a: sdmmc1-dir-sleep-0 { + pins { + pinmux = <STM32_PINMUX('F', 2, ANALOG)>, /* SDMMC1_D0DIR */ + <STM32_PINMUX('C', 7, ANALOG)>, /* SDMMC1_D123DIR */ + <STM32_PINMUX('B', 9, ANALOG)>, /* SDMMC1_CDIR */ + <STM32_PINMUX('E', 4, ANALOG)>; /* SDMMC1_CKIN */ + }; + }; + + sdmmc2_b4_pins_a: sdmmc2-b4-0 { pins { pinmux = <STM32_PINMUX('B', 14, AF9)>, /* SDMMC2_D0 */ <STM32_PINMUX('B', 15, AF9)>, /* SDMMC2_D1 */ @@ -432,7 +665,7 @@ }; };
- sdmmc2_d47_pins_a: sdmmc2-d47@0 { + sdmmc2_d47_pins_a: sdmmc2-d47-0 { pins { pinmux = <STM32_PINMUX('A', 8, AF9)>, /* SDMMC2_D4 */ <STM32_PINMUX('A', 9, AF10)>, /* SDMMC2_D5 */ @@ -444,6 +677,19 @@ }; };
+ spdifrx_pins_a: spdifrx-0 { + pins { + pinmux = <STM32_PINMUX('G', 12, AF8)>; /* SPDIF_IN1 */ + bias-disable; + }; + }; + + spdifrx_sleep_pins_a: spdifrx-1 { + pins { + pinmux = <STM32_PINMUX('G', 12, ANALOG)>; /* SPDIF_IN1 */ + }; + }; + spi2_pins_a: spi2-0 { pins1 { pinmux = <STM32_PINMUX('B', 10, AF5)>, /* SPI2_SCK */ @@ -522,6 +768,7 @@ pins-are-numbered; interrupt-parent = <&exti>; st,syscfg = <&exti 0x60 0xff>; + hwlocks = <&hwspinlock 0>;
gpioz: gpio@54004000 { gpio-controller; @@ -546,6 +793,13 @@ }; };
+ i2c4_pins_sleep_a: i2c4-1 { + pins { + pinmux = <STM32_PINMUX('Z', 4, ANALOG)>, /* I2C4_SCL */ + <STM32_PINMUX('Z', 5, ANALOG)>; /* I2C4_SDA */ + }; + }; + spi1_pins_a: spi1-0 { pins1 { pinmux = <STM32_PINMUX('Z', 0, AF5)>, /* SPI1_SCK */ diff --git a/arch/arm/dts/stm32mp157-u-boot.dtsi b/arch/arm/dts/stm32mp157-u-boot.dtsi index c9f534e..f7c7acc 100644 --- a/arch/arm/dts/stm32mp157-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157-u-boot.dtsi @@ -21,11 +21,11 @@ pinctrl1 = &pinctrl_z; };
- config { + clocks { u-boot,dm-pre-reloc; };
- clocks { + reboot { u-boot,dm-pre-reloc; };
@@ -35,42 +35,26 @@ };
&bsec { - u-boot,dm-pre-reloc; -}; - -&clk_hsi { - u-boot,dm-pre-reloc; -}; - -&clk_hse { - u-boot,dm-pre-reloc; -}; - -&clk_lse { - u-boot,dm-pre-reloc; -}; - -&clk_lsi { - u-boot,dm-pre-reloc; + u-boot,dm-pre-proper; };
&clk_csi { u-boot,dm-pre-reloc; };
-&rcc { +&clk_hsi { u-boot,dm-pre-reloc; };
-&rcc_reboot { +&clk_hse { u-boot,dm-pre-reloc; };
-&pinctrl { +&clk_lsi { u-boot,dm-pre-reloc; };
-&pinctrl_z { +&clk_lse { u-boot,dm-pre-reloc; };
@@ -134,6 +118,34 @@ u-boot,dm-pre-reloc; };
-&iwdg2 { +&pinctrl { + u-boot,dm-pre-reloc; +}; + +&pinctrl_z { + u-boot,dm-pre-reloc; +}; + +&pwr { u-boot,dm-pre-reloc; }; + +&rcc { + u-boot,dm-pre-reloc; +}; + +&sdmmc1 { + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; +}; + +&sdmmc2 { + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; +}; + +&sdmmc3 { + compatible = "st,stm32-sdmmc2", "arm,pl18x", "arm,primecell"; +}; + +&usbotg_hs { + compatible = "st,stm32mp1-hsotg", "snps,dwc2"; +}; diff --git a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi index 0f32a38..36c852d 100644 --- a/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi @@ -194,7 +194,3 @@ u-boot,force-b-session-valid; hnp-srp-disable; }; - -&v3v3 { - regulator-always-on; -}; diff --git a/arch/arm/dts/stm32mp157a-dk1.dts b/arch/arm/dts/stm32mp157a-dk1.dts index e36773d..c2b9c20 100644 --- a/arch/arm/dts/stm32mp157a-dk1.dts +++ b/arch/arm/dts/stm32mp157a-dk1.dts @@ -39,6 +39,13 @@ }; };
+&cec { + pinctrl-names = "default", "sleep"; + pinctrl-0 = <&cec_pins_b>; + pinctrl-1 = <&cec_pins_sleep_b>; + status = "okay"; +}; + ðernet0 { status = "okay"; pinctrl-0 = <ðernet0_rgmii_pins_a>; @@ -58,12 +65,14 @@ }; };
+ &i2c4 { pinctrl-names = "default"; pinctrl-0 = <&i2c4_pins_a>; i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay"; + /* spare dmas for other usage */ /delete-property/dmas; /delete-property/dma-names;
@@ -88,17 +97,13 @@ pmic: stpmic@33 { compatible = "st,stpmic1"; reg = <0x33>; + interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>; interrupt-controller; #interrupt-cells = <2>; status = "okay";
- st,main-control-register = <0x04>; - st,vin-control-register = <0xc0>; - st,usb-control-register = <0x20>; - regulators { compatible = "st,stpmic1-regulators"; - ldo1-supply = <&v3v3>; ldo3-supply = <&vdd_ddr>; ldo6-supply = <&v3v3>; @@ -107,7 +112,7 @@
vddcore: buck1 { regulator-name = "vddcore"; - regulator-min-microvolt = <1200000>; + regulator-min-microvolt = <800000>; regulator-max-microvolt = <1350000>; regulator-always-on; regulator-initial-mode = <0>; @@ -187,7 +192,6 @@ regulator-max-microvolt = <1200000>; regulator-always-on; interrupts = <IT_CURLIM_LDO6 0>; - };
vref_ddr: vref_ddr { @@ -204,7 +208,6 @@ vbus_otg: pwr_sw1 { regulator-name = "vbus_otg"; interrupts = <IT_OCP_OTG 0>; - regulator-active-discharge; };
vbus_sw: pwr_sw2 { @@ -216,8 +219,9 @@
onkey { compatible = "st,stpmic1-onkey"; - interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 1>; + interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 0>; interrupt-names = "onkey-falling", "onkey-rising"; + power-off-time-sec = <10>; status = "okay"; };
@@ -228,6 +232,10 @@ }; };
+&ipcc { + status = "okay"; +}; + &iwdg2 { timeout-sec = <32>; status = "okay"; @@ -246,8 +254,10 @@ };
&sdmmc1 { - pinctrl-names = "default"; + pinctrl-names = "default", "opendrain", "sleep"; pinctrl-0 = <&sdmmc1_b4_pins_a>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a>; broken-cd; st,neg-edge; bus-width = <4>; diff --git a/arch/arm/dts/stm32mp157c-dk2.dts b/arch/arm/dts/stm32mp157c-dk2.dts index 9a81d2d..020ea0f 100644 --- a/arch/arm/dts/stm32mp157c-dk2.dts +++ b/arch/arm/dts/stm32mp157c-dk2.dts @@ -42,6 +42,7 @@ compatible = "orisetech,otm8009a"; reg = <0>; reset-gpios = <&gpioe 4 GPIO_ACTIVE_LOW>; + power-supply = <&v3v3>; status = "okay";
port { diff --git a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi index 55f9903..200601e 100644 --- a/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi @@ -156,6 +156,10 @@ }; };
+&sdmmc1 { + u-boot,dm-spl; +}; + &sdmmc1_b4_pins_a { u-boot,dm-spl; pins { @@ -165,12 +169,15 @@
&sdmmc1_dir_pins_a { u-boot,dm-spl; - pins { + pins1 { + u-boot,dm-spl; + }; + pins2 { u-boot,dm-spl; }; };
-&sdmmc1 { +&sdmmc2 { u-boot,dm-spl; };
@@ -188,10 +195,6 @@ }; };
-&sdmmc2 { - u-boot,dm-spl; -}; - &uart4 { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/dts/stm32mp157c-ed1.dts b/arch/arm/dts/stm32mp157c-ed1.dts index b10208f..11981d6 100644 --- a/arch/arm/dts/stm32mp157c-ed1.dts +++ b/arch/arm/dts/stm32mp157c-ed1.dts @@ -19,6 +19,7 @@ };
memory@c0000000 { + device_type = "memory"; reg = <0xC0000000 0x40000000>; };
@@ -40,7 +41,7 @@ }; };
-&hwspinlock { +&dts { status = "okay"; };
@@ -50,23 +51,20 @@ i2c-scl-rising-time-ns = <185>; i2c-scl-falling-time-ns = <20>; status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names;
- pmic: stpmic1@33 { + pmic: stpmic@33 { compatible = "st,stpmic1"; reg = <0x33>; - interrupts = <0 2>; - interrupt-parent = <&gpioa>; + interrupts-extended = <&gpioa 0 IRQ_TYPE_EDGE_FALLING>; interrupt-controller; #interrupt-cells = <2>; status = "okay";
- st,main_control_register = <0x04>; - st,vin_control_register = <0xc0>; - st,usb_control_register = <0x30>; - regulators { compatible = "st,stpmic1-regulators"; - ldo1-supply = <&v3v3>; ldo2-supply = <&v3v3>; ldo3-supply = <&vdd_ddr>; @@ -80,20 +78,8 @@ regulator-min-microvolt = <800000>; regulator-max-microvolt = <1350000>; regulator-always-on; - regulator-initial-mode = <2>; + regulator-initial-mode = <0>; regulator-over-current-protection; - - regulator-state-standby { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1200000>; - regulator-mode = <8>; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
vdd_ddr: buck2 { @@ -101,22 +87,8 @@ regulator-min-microvolt = <1350000>; regulator-max-microvolt = <1350000>; regulator-always-on; - regulator-initial-mode = <2>; + regulator-initial-mode = <0>; regulator-over-current-protection; - - regulator-state-standby { - regulator-suspend-microvolt = <1350000>; - regulator-on-in-suspend; - regulator-mode = <8>; - }; - regulator-state-mem { - regulator-suspend-microvolt = <1350000>; - regulator-on-in-suspend; - regulator-mode = <8>; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
vdd: buck3 { @@ -124,46 +96,18 @@ regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; - st,mask_reset; - regulator-initial-mode = <8>; + st,mask-reset; + regulator-initial-mode = <0>; regulator-over-current-protection; - - regulator-state-standby { - regulator-suspend-microvolt = <3300000>; - regulator-on-in-suspend; - regulator-mode = <8>; - }; - regulator-state-mem { - regulator-suspend-microvolt = <3300000>; - regulator-on-in-suspend; - regulator-mode = <8>; - }; - regulator-state-disk { - regulator-suspend-microvolt = <3300000>; - regulator-on-in-suspend; - regulator-mode = <8>; - }; };
v3v3: buck4 { regulator-name = "v3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; - regulator-boot-on; + regulator-always-on; regulator-over-current-protection; - regulator-initial-mode = <8>; - - regulator-state-standby { - regulator-suspend-microvolt = <3300000>; - regulator-unchanged-in-suspend; - regulator-mode = <8>; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; + regulator-initial-mode = <0>; };
vdda: ldo1 { @@ -171,18 +115,6 @@ regulator-min-microvolt = <2900000>; regulator-max-microvolt = <2900000>; interrupts = <IT_CURLIM_LDO1 0>; - interrupt-parent = <&pmic>; - - regulator-state-standby { - regulator-suspend-microvolt = <2900000>; - regulator-unchanged-in-suspend; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
v2v8: ldo2 { @@ -190,36 +122,14 @@ regulator-min-microvolt = <2800000>; regulator-max-microvolt = <2800000>; interrupts = <IT_CURLIM_LDO2 0>; - interrupt-parent = <&pmic>; - - regulator-state-standby { - regulator-suspend-microvolt = <2800000>; - regulator-unchanged-in-suspend; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
vtt_ddr: ldo3 { regulator-name = "vtt_ddr"; - regulator-min-microvolt = <0000000>; - regulator-max-microvolt = <1000000>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <750000>; regulator-always-on; regulator-over-current-protection; - - regulator-state-standby { - regulator-off-in-suspend; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
vdd_usb: ldo4 { @@ -227,17 +137,6 @@ regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; interrupts = <IT_CURLIM_LDO4 0>; - interrupt-parent = <&pmic>; - - regulator-state-standby { - regulator-unchanged-in-suspend; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
vdd_sd: ldo5 { @@ -245,19 +144,7 @@ regulator-min-microvolt = <2900000>; regulator-max-microvolt = <2900000>; interrupts = <IT_CURLIM_LDO5 0>; - interrupt-parent = <&pmic>; regulator-boot-on; - - regulator-state-standby { - regulator-suspend-microvolt = <2900000>; - regulator-unchanged-in-suspend; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
v1v8: ldo6 { @@ -265,66 +152,53 @@ regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; interrupts = <IT_CURLIM_LDO6 0>; - interrupt-parent = <&pmic>; - - regulator-state-standby { - regulator-suspend-microvolt = <1800000>; - regulator-unchanged-in-suspend; - }; - regulator-state-mem { - regulator-off-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
vref_ddr: vref_ddr { regulator-name = "vref_ddr"; regulator-always-on; regulator-over-current-protection; - - regulator-state-standby { - regulator-on-in-suspend; - }; - regulator-state-mem { - regulator-on-in-suspend; - }; - regulator-state-disk { - regulator-off-in-suspend; - }; };
bst_out: boost { regulator-name = "bst_out"; interrupts = <IT_OCP_BOOST 0>; - interrupt-parent = <&pmic>; };
vbus_otg: pwr_sw1 { regulator-name = "vbus_otg"; interrupts = <IT_OCP_OTG 0>; - interrupt-parent = <&pmic>; - regulator-active-discharge; };
vbus_sw: pwr_sw2 { regulator-name = "vbus_sw"; interrupts = <IT_OCP_SWOUT 0>; - interrupt-parent = <&pmic>; regulator-active-discharge; }; }; + + onkey { + compatible = "st,stpmic1-onkey"; + interrupts = <IT_PONKEY_F 0>, <IT_PONKEY_R 0>; + interrupt-names = "onkey-falling", "onkey-rising"; + power-off-time-sec = <10>; + status = "okay"; + }; + + watchdog { + compatible = "st,stpmic1-wdt"; + status = "disabled"; + }; }; };
-&iwdg2 { - timeout-sec = <32>; +&ipcc { status = "okay"; };
-&pinctrl { - hwlocks = <&hwspinlock 0>; +&iwdg2 { + timeout-sec = <32>; + status = "okay"; };
&pwr { @@ -340,7 +214,10 @@ };
&sdmmc1 { + pinctrl-names = "default", "opendrain", "sleep"; pinctrl-0 = <&sdmmc1_b4_pins_a &sdmmc1_dir_pins_a>; + pinctrl-1 = <&sdmmc1_b4_od_pins_a &sdmmc1_dir_pins_a>; + pinctrl-2 = <&sdmmc1_b4_sleep_pins_a &sdmmc1_dir_sleep_pins_a>; broken-cd; st,sig-dir; st,neg-edge; @@ -348,11 +225,6 @@ bus-width = <4>; vmmc-supply = <&vdd_sd>; vqmmc-supply = <&sd_switch>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-ddr50; - sd-uhs-sdr104; status = "okay"; };
@@ -371,6 +243,9 @@
&timers6 { status = "okay"; + /* spare dmas for other usage */ + /delete-property/dmas; + /delete-property/dma-names; timer@5 { status = "okay"; }; @@ -382,6 +257,10 @@ status = "okay"; };
+&usbotg_hs { + vbus-supply = <&vbus_otg>; +}; + &usbphyc_port0 { phy-supply = <&vdd_usb>; }; diff --git a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi index 5b19e44..56c9c7f 100644 --- a/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi @@ -59,7 +59,3 @@ &usbotg_hs { g-tx-fifo-size = <576>; }; - -&v3v3 { - regulator-always-on; -}; diff --git a/arch/arm/dts/stm32mp157c-ev1.dts b/arch/arm/dts/stm32mp157c-ev1.dts index 663e52a..ca2a333 100644 --- a/arch/arm/dts/stm32mp157c-ev1.dts +++ b/arch/arm/dts/stm32mp157c-ev1.dts @@ -6,6 +6,7 @@ /dts-v1/;
#include "stm32mp157c-ed1.dts" +#include <dt-bindings/gpio/gpio.h>
/ { model = "STMicroelectronics STM32MP157C eval daughter on eval mother"; @@ -157,8 +158,9 @@ };
&m_can1 { - pinctrl-names = "default"; + pinctrl-names = "default", "sleep"; pinctrl-0 = <&m_can1_pins_a>; + pinctrl-1 = <&m_can1_sleep_pins_a>; status = "okay"; };
@@ -194,6 +196,9 @@ };
&timers2 { + /* spare dmas for other usage (un-delete to enable pwm capture) */ + /delete-property/dmas; + /delete-property/dma-names; status = "disabled"; pwm { pinctrl-0 = <&pwm2_pins_a>; @@ -206,6 +211,8 @@ };
&timers8 { + /delete-property/dmas; + /delete-property/dma-names; status = "disabled"; pwm { pinctrl-0 = <&pwm8_pins_a>; @@ -218,6 +225,8 @@ };
&timers12 { + /delete-property/dmas; + /delete-property/dma-names; status = "disabled"; pwm { pinctrl-0 = <&pwm12_pins_a>; @@ -232,7 +241,6 @@ &usbh_ehci { phys = <&usbphyc_port0>; phy-names = "usb"; - vbus-supply = <&vbus_sw>; status = "okay"; };
diff --git a/arch/arm/dts/stm32mp157c.dtsi b/arch/arm/dts/stm32mp157c.dtsi index 7321585..d81e13e 100644 --- a/arch/arm/dts/stm32mp157c.dtsi +++ b/arch/arm/dts/stm32mp157c.dtsi @@ -35,28 +35,6 @@ cpu_on = <0x84000003>; };
- aliases { - gpio0 = &gpioa; - gpio1 = &gpiob; - gpio2 = &gpioc; - gpio3 = &gpiod; - gpio4 = &gpioe; - gpio5 = &gpiof; - gpio6 = &gpiog; - gpio7 = &gpioh; - gpio8 = &gpioi; - gpio9 = &gpioj; - gpio10 = &gpiok; - serial0 = &usart1; - serial1 = &usart2; - serial2 = &usart3; - serial3 = &uart4; - serial4 = &uart5; - serial5 = &usart6; - serial6 = &uart7; - serial7 = &uart8; - }; - intc: interrupt-controller@a0021000 { compatible = "arm,cortex-a7-gic"; #interrupt-cells = <3>; @@ -106,6 +84,38 @@ }; };
+ thermal-zones { + cpu_thermal: cpu-thermal { + polling-delay-passive = <0>; + polling-delay = <0>; + thermal-sensors = <&dts>; + + trips { + cpu_alert1: cpu-alert1 { + temperature = <85000>; + hysteresis = <0>; + type = "passive"; + }; + + cpu-crit { + temperature = <120000>; + hysteresis = <0>; + type = "critical"; + }; + }; + + cooling-maps { + }; + }; + }; + + reboot { + compatible = "syscon-reboot"; + regmap = <&rcc>; + offset = <0x404>; + mask = <0x1>; + }; + soc { compatible = "simple-bus"; #address-cells = <1>; @@ -120,6 +130,12 @@ reg = <0x40000000 0x400>; clocks = <&rcc TIM2_K>; clock-names = "int"; + dmas = <&dmamux1 18 0x400 0x1>, + <&dmamux1 19 0x400 0x1>, + <&dmamux1 20 0x400 0x1>, + <&dmamux1 21 0x400 0x1>, + <&dmamux1 22 0x400 0x1>; + dma-names = "ch1", "ch2", "ch3", "ch4", "up"; status = "disabled";
pwm { @@ -141,6 +157,13 @@ reg = <0x40001000 0x400>; clocks = <&rcc TIM3_K>; clock-names = "int"; + dmas = <&dmamux1 23 0x400 0x1>, + <&dmamux1 24 0x400 0x1>, + <&dmamux1 25 0x400 0x1>, + <&dmamux1 26 0x400 0x1>, + <&dmamux1 27 0x400 0x1>, + <&dmamux1 28 0x400 0x1>; + dma-names = "ch1", "ch2", "ch3", "ch4", "up", "trig"; status = "disabled";
pwm { @@ -162,6 +185,11 @@ reg = <0x40002000 0x400>; clocks = <&rcc TIM4_K>; clock-names = "int"; + dmas = <&dmamux1 29 0x400 0x1>, + <&dmamux1 30 0x400 0x1>, + <&dmamux1 31 0x400 0x1>, + <&dmamux1 32 0x400 0x1>; + dma-names = "ch1", "ch2", "ch3", "ch4"; status = "disabled";
pwm { @@ -183,6 +211,13 @@ reg = <0x40003000 0x400>; clocks = <&rcc TIM5_K>; clock-names = "int"; + dmas = <&dmamux1 55 0x400 0x1>, + <&dmamux1 56 0x400 0x1>, + <&dmamux1 57 0x400 0x1>, + <&dmamux1 58 0x400 0x1>, + <&dmamux1 59 0x400 0x1>, + <&dmamux1 60 0x400 0x1>; + dma-names = "ch1", "ch2", "ch3", "ch4", "up", "trig"; status = "disabled";
pwm { @@ -204,6 +239,8 @@ reg = <0x40004000 0x400>; clocks = <&rcc TIM6_K>; clock-names = "int"; + dmas = <&dmamux1 69 0x400 0x1>; + dma-names = "up"; status = "disabled";
timer@5 { @@ -220,6 +257,8 @@ reg = <0x40005000 0x400>; clocks = <&rcc TIM7_K>; clock-names = "int"; + dmas = <&dmamux1 70 0x400 0x1>; + dma-names = "up"; status = "disabled";
timer@6 { @@ -347,6 +386,19 @@ status = "disabled"; };
+ spdifrx: audio-controller@4000d000 { + compatible = "st,stm32h7-spdifrx"; + #sound-dai-cells = <0>; + reg = <0x4000d000 0x400>; + clocks = <&rcc SPDIF_K>; + clock-names = "kclk"; + interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmamux1 93 0x400 0x01>, + <&dmamux1 94 0x400 0x01>; + dma-names = "rx", "rx-ctrl"; + status = "disabled"; + }; + usart2: serial@4000e000 { compatible = "st,stm32h7-uart"; reg = <0x4000e000 0x400>; @@ -487,6 +539,15 @@ reg = <0x44000000 0x400>; clocks = <&rcc TIM1_K>; clock-names = "int"; + dmas = <&dmamux1 11 0x400 0x1>, + <&dmamux1 12 0x400 0x1>, + <&dmamux1 13 0x400 0x1>, + <&dmamux1 14 0x400 0x1>, + <&dmamux1 15 0x400 0x1>, + <&dmamux1 16 0x400 0x1>, + <&dmamux1 17 0x400 0x1>; + dma-names = "ch1", "ch2", "ch3", "ch4", + "up", "trig", "com"; status = "disabled";
pwm { @@ -508,6 +569,15 @@ reg = <0x44001000 0x400>; clocks = <&rcc TIM8_K>; clock-names = "int"; + dmas = <&dmamux1 47 0x400 0x1>, + <&dmamux1 48 0x400 0x1>, + <&dmamux1 49 0x400 0x1>, + <&dmamux1 50 0x400 0x1>, + <&dmamux1 51 0x400 0x1>, + <&dmamux1 52 0x400 0x1>, + <&dmamux1 53 0x400 0x1>; + dma-names = "ch1", "ch2", "ch3", "ch4", + "up", "trig", "com"; status = "disabled";
pwm { @@ -565,6 +635,11 @@ reg = <0x44006000 0x400>; clocks = <&rcc TIM15_K>; clock-names = "int"; + dmas = <&dmamux1 105 0x400 0x1>, + <&dmamux1 106 0x400 0x1>, + <&dmamux1 107 0x400 0x1>, + <&dmamux1 108 0x400 0x1>; + dma-names = "ch1", "up", "trig", "com"; status = "disabled";
pwm { @@ -586,6 +661,9 @@ reg = <0x44007000 0x400>; clocks = <&rcc TIM16_K>; clock-names = "int"; + dmas = <&dmamux1 109 0x400 0x1>, + <&dmamux1 110 0x400 0x1>; + dma-names = "ch1", "up"; status = "disabled";
pwm { @@ -606,6 +684,9 @@ reg = <0x44008000 0x400>; clocks = <&rcc TIM17_K>; clock-names = "int"; + dmas = <&dmamux1 111 0x400 0x1>, + <&dmamux1 112 0x400 0x1>; + dma-names = "ch1", "up"; status = "disabled";
pwm { @@ -706,14 +787,14 @@
m_can1: can@4400e000 { compatible = "bosch,m_can"; - reg = <0x4400e000 0x400>, <0x44011000 0x2800>; + reg = <0x4400e000 0x400>, <0x44011000 0x1400>; reg-names = "m_can", "message_ram"; interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; interrupt-names = "int0", "int1"; clocks = <&rcc CK_HSE>, <&rcc FDCAN_K>; clock-names = "hclk", "cclk"; - bosch,mram-cfg = <0x0 0 0 32 0 0 2 2>; + bosch,mram-cfg = <0x1400 0 0 32 0 0 2 2>; status = "disabled"; };
@@ -811,13 +892,14 @@ };
sdmmc3: sdmmc@48004000 { - compatible = "st,stm32-sdmmc2"; - reg = <0x48004000 0x400>, <0x48005000 0x400>; - reg-names = "sdmmc", "delay"; + compatible = "arm,pl18x", "arm,primecell"; + arm,primecell-periphid = <0x10153180>; + reg = <0x48004000 0x400>; + reg-names = "sdmmc"; interrupts = <GIC_SPI 137 IRQ_TYPE_NONE>; clocks = <&rcc SDMMC3_K>; + clock-names = "apb_pclk"; resets = <&rcc SDMMC3_R>; - st,idma = <1>; cap-sd-highspeed; cap-mmc-highspeed; max-frequency = <120000000>; @@ -825,7 +907,7 @@ };
usbotg_hs: usb-otg@49000000 { - compatible = "st,stm32mp1-hsotg", "snps,dwc2"; + compatible = "snps,dwc2"; reg = <0x49000000 0x10000>; clocks = <&rcc USBO_K>; clock-names = "otg"; @@ -846,6 +928,20 @@ reg = <0x4c000000 0x400>; clocks = <&rcc HSEM>; clock-names = "hwspinlock"; + }; + + ipcc: mailbox@4c001000 { + compatible = "st,stm32mp1-ipcc"; + #mbox-cells = <1>; + reg = <0x4c001000 0x400>; + st,proc-id = <0>; + interrupts-extended = + <&intc GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, + <&intc GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, + <&exti 61 1>; + interrupt-names = "rx", "tx", "wakeup"; + clocks = <&rcc IPCC>; + wakeup-source; status = "disabled"; };
@@ -856,13 +952,6 @@ #reset-cells = <1>; };
- rcc_reboot: rcc-reboot@50000000 { - compatible = "syscon-reboot"; - regmap = <&rcc>; - offset = <0x404>; - mask = <0x1>; - }; - pwr: pwr@50001000 { compatible = "st,stm32mp1-pwr", "st,stm32-pwr", "syscon", "simple-mfd"; reg = <0x50001000 0x400>; @@ -872,7 +961,7 @@ clocks = <&rcc PLL2_R>; clock-names = "phyclk";
- pwr-regulators@c { + pwr-regulators { compatible = "st,stm32mp1,pwr-reg"; st,tzcr = <&rcc 0x0 0x1>;
@@ -906,6 +995,7 @@ syscfg: syscon@50020000 { compatible = "st,stm32mp157-syscfg", "syscon"; reg = <0x50020000 0x400>; + clocks = <&rcc SYSCFG>; };
lptimer2: timer@50021000 { @@ -994,6 +1084,16 @@ status = "disabled"; };
+ dts: thermal@50028000 { + compatible = "st,stm32-thermal"; + reg = <0x50028000 0x100>; + interrupts = <GIC_SPI 147 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&rcc TMPSENS>; + clock-names = "pclk"; + #thermal-sensor-cells = <0>; + status = "disabled"; + }; + cryp1: cryp@54001000 { compatible = "st,stm32mp1-cryp"; reg = <0x54001000 0x400>; @@ -1059,26 +1159,27 @@ };
sdmmc1: sdmmc@58005000 { - compatible = "st,stm32-sdmmc2"; - reg = <0x58005000 0x1000>, <0x58006000 0x1000>; - reg-names = "sdmmc", "delay"; + compatible = "arm,pl18x", "arm,primecell"; + arm,primecell-periphid = <0x10153180>; + reg = <0x58005000 0x1000>; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "cmd_irq"; clocks = <&rcc SDMMC1_K>; + clock-names = "apb_pclk"; resets = <&rcc SDMMC1_R>; - st,idma = <1>; cap-sd-highspeed; cap-mmc-highspeed; max-frequency = <120000000>; - status = "disabled"; };
sdmmc2: sdmmc@58007000 { - compatible = "st,stm32-sdmmc2"; - reg = <0x58007000 0x1000>, <0x58008000 0x1000>; - reg-names = "sdmmc", "delay"; + compatible = "arm,pl18x", "arm,primecell"; + arm,primecell-periphid = <0x10153180>; + reg = <0x58007000 0x1000>; interrupts = <GIC_SPI 124 IRQ_TYPE_NONE>; clocks = <&rcc SDMMC2_K>; + clock-names = "apb_pclk"; resets = <&rcc SDMMC2_R>; - st,idma = <1>; cap-sd-highspeed; cap-mmc-highspeed; max-frequency = <120000000>; @@ -1245,6 +1346,12 @@ reg = <0x5c005000 0x400>; #address-cells = <1>; #size-cells = <1>; + ts_cal1: calib@5c { + reg = <0x5c 0x2>; + }; + ts_cal2: calib@5e { + reg = <0x5e 0x2>; + }; };
i2c6: i2c@5c009000 {
for v2019.10 ;-)
On 6/21/19 3:21 PM, Patrick Delaunay wrote:
Some remaining patches for stm32mp1
- some cleanup in files
- add 2 specific commands for stm32mp1 board
- use OF_SYSTEM_SETUP to update kernel device tree
- synchronization with latest device tree
Patrick Delaunay (16): stm32mp1: deactivate WATCHDOG in defconfig stm32mp1: call regulators_enable_boot_on in board_init stm32mp1: syscon: remove etzpc support stm32mp1: syscon: remove stgen dt-bindings: pinctrl: stm32: add new entry for package information stm32mp1: export get_cpu_package function stm32mp1: update package information in device tree stm32mp1: update device tree with ETZPC status stm32mp1: add stboard command stm32mp1: key: add stm32key command stm32mp1: udpate README stm32mp1: cosmetic: remove unnecessary include stm32mp1: configs: Add CONFIG_OF_SPL_REMOVE_PROPS stm32mp1: add check for presence of environment in boot device stm32mp1: force boot_net_usb_start ARM: dts: stm32mp1: sync device tree with v5.2-rc4
arch/arm/Kconfig | 1 + arch/arm/dts/stm32mp15-ddr.dtsi | 2 +- arch/arm/dts/stm32mp157-pinctrl.dtsi | 270 ++++++++++++++++++++- arch/arm/dts/stm32mp157-u-boot.dtsi | 67 ++--- arch/arm/dts/stm32mp157a-dk1-u-boot.dtsi | 4 - arch/arm/dts/stm32mp157a-dk1.dts | 30 ++- arch/arm/dts/stm32mp157c-dk2.dts | 1 + arch/arm/dts/stm32mp157c-ed1-u-boot.dtsi | 15 +- arch/arm/dts/stm32mp157c-ed1.dts | 205 ++++------------ arch/arm/dts/stm32mp157c-ev1-u-boot.dtsi | 4 - arch/arm/dts/stm32mp157c-ev1.dts | 12 +- arch/arm/dts/stm32mp157c.dtsi | 199 +++++++++++---- arch/arm/mach-stm32mp/Kconfig | 15 ++ arch/arm/mach-stm32mp/Makefile | 2 + arch/arm/mach-stm32mp/cmd_stm32key.c | 101 ++++++++ arch/arm/mach-stm32mp/cpu.c | 7 +- arch/arm/mach-stm32mp/fdt.c | 223 +++++++++++++++++ arch/arm/mach-stm32mp/include/mach/stm32.h | 3 +- arch/arm/mach-stm32mp/include/mach/sys_proto.h | 9 + arch/arm/mach-stm32mp/syscon.c | 2 - board/st/stm32mp1/Kconfig | 7 + board/st/stm32mp1/Makefile | 1 + board/st/stm32mp1/README | 15 +- board/st/stm32mp1/cmd_stboard.c | 145 +++++++++++ board/st/stm32mp1/spl.c | 1 - board/st/stm32mp1/stm32mp1.c | 4 + configs/stm32mp15_basic_defconfig | 3 +- configs/stm32mp15_trusted_defconfig | 2 - .../pinctrl/st,stm32-pinctrl.txt | 101 +++++++- drivers/clk/clk_stm32mp1.c | 3 +- include/configs/stm32mp1.h | 7 +- include/dt-bindings/pinctrl/stm32-pinfunc.h | 6 + 32 files changed, 1158 insertions(+), 309 deletions(-) create mode 100644 arch/arm/mach-stm32mp/cmd_stm32key.c create mode 100644 arch/arm/mach-stm32mp/fdt.c create mode 100644 board/st/stm32mp1/cmd_stboard.c
Hi Patrice,
From: Patrice CHOTARD patrice.chotard@st.com Sent: vendredi 21 juin 2019 15:55
for v2019.10 ;-)
Yes Sorry :-)
I mixed the first name (target as v2019.07) the new target v2019.10. I will update the serie title if I sent a v2.
Regards
Patrick
Patrice CHOTARD
Patrick DELAUNAY
Patrick Delaunay
