[U-Boot] [PATCH] tools/kwboot: Add parameters to set delay and timeout via cmdline
To support the Armada 38x, new values for the request-delay and the response-timeout are needed. As the values already implemented in this tool (for Kirkwood and Armada XP) don't seem to work here. To make this more flexible, lets add make those 2 parameters configurable via the cmdline. Here the new parameters:
-q <req-delay>: use specific request-delay -s <resp-timeo>: use specific response-timeout
For the Marvell DB-88F6820 these values are known to work:
One board: -q 2 -s 1
2nd board: -q 5 -s 5
So this seems to be even board specific. But with this patch now those values can be specified and tested via the cmdline.
Signed-off-by: Stefan Roese sr@denx.de Cc: Kevin Smith kevin.smith@elecsyscorp.com Cc: Dirk Eibach dirk.eibach@gdsys.cc Cc: Luka Perkov luka.perkov@sartura.hr --- tools/kwboot.c | 14 ++++++++++++-- 1 file changed, 12 insertions(+), 2 deletions(-)
diff --git a/tools/kwboot.c b/tools/kwboot.c index 1368b4c..af7a6ee 100644 --- a/tools/kwboot.c +++ b/tools/kwboot.c @@ -657,7 +657,7 @@ static void kwboot_usage(FILE *stream, char *progname) { fprintf(stream, - "Usage: %s [-d | -a | -b <image> | -D <image> ] [ -t ] [-B <baud> ] <TTY>\n", + "Usage: %s [-d | -a | -q <req-delay> | -s <resp-timeo> | -b <image> | -D <image> ] [ -t ] [-B <baud> ] <TTY>\n", progname); fprintf(stream, "\n"); fprintf(stream, @@ -667,6 +667,8 @@ kwboot_usage(FILE *stream, char *progname) " -D <image>: boot <image> without preamble (Dove)\n"); fprintf(stream, " -d: enter debug mode\n"); fprintf(stream, " -a: use timings for Armada XP\n"); + fprintf(stream, " -q <req-delay>: use specific request-delay\n"); + fprintf(stream, " -s <resp-timeo>: use specific response-timeout\n"); fprintf(stream, "\n"); fprintf(stream, " -t: mini terminal\n"); fprintf(stream, "\n"); @@ -699,7 +701,7 @@ main(int argc, char **argv) kwboot_verbose = isatty(STDOUT_FILENO);
do { - int c = getopt(argc, argv, "hb:ptaB:dD:"); + int c = getopt(argc, argv, "hb:ptaB:dD:q:s:"); if (c < 0) break;
@@ -731,6 +733,14 @@ main(int argc, char **argv) msg_rsp_timeo = KWBOOT_MSG_RSP_TIMEO_AXP; break;
+ case 'q': + msg_req_delay = atoi(optarg); + break; + + case 's': + msg_rsp_timeo = atoi(optarg); + break; + case 'B': speed = kwboot_tty_speed(atoi(optarg)); if (speed == -1)
Hi Stefan,
This seems strange... Anyhow, I have pushed this patch as well as couple of others to marvell/master so it is easier for everybody to test mvebu codebase which is not yet merged in master.
Unless there will be no comments and/or fixups I'll send pull request week after next.
Regards, Luka
Luka Perkov
Stefan Roese
