[U-Boot] [PATCH 1/2] rockchip: not depends on TPL_BUILD for rk3188 makefile including
The rk3188/Makefile already depends on !TPL_BUILD, so no need to add this again in parent Makefile, remove it.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/mach-rockchip/Makefile | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 207f900011..616dd8f0f2 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -31,9 +31,7 @@ endif
obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ obj-$(CONFIG_ROCKCHIP_RK3128) += rk3128/ -ifndef CONFIG_TPL_BUILD obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188/ -endif obj-$(CONFIG_ROCKCHIP_RK322X) += rk322x/ obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288/ obj-$(CONFIG_ROCKCHIP_RK3328) += rk3328/
Use obj-$(config) instead of #ifdef $config to make the code looks clean, and move the misc_init for U-Boot proper only.
arch/arm/mach-rockchip/Makefile | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 616dd8f0f2..45d9b06233 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -1,6 +1,7 @@ # SPDX-License-Identifier: GPL-2.0+ # # Copyright (c) 2014 Google, Inc +# Copyright (c) 2019 Rockchip Electronics Co., Ltd.
# We don't want the bootrom-helper present in a full U-Boot build, as # this may have entered from ATF with the stack-pointer pointing to @@ -21,14 +22,11 @@ ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_TPL_BUILD),) # meaning "turn it off". obj-y += boot_mode.o obj-$(CONFIG_ROCKCHIP_COMMON_BOARD) += board.o +obj-$(CONFIG_MISC_INIT_R) += misc.o endif
obj-$(CONFIG_$(SPL_TPL_)RAM) += sdram_common.o
-ifdef CONFIG_MISC_INIT_R -obj-y += misc.o -endif - obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ obj-$(CONFIG_ROCKCHIP_RK3128) += rk3128/ obj-$(CONFIG_ROCKCHIP_RK3188) += rk3188/
Kever Yang
