[U-Boot] [PATCH] 10/12 Multiadapter/multibus I2C, configs part 3
Signed-off-by: Sergey Kubushyn ksi@koi8.net --- diff -purN u-boot-i2c.orig/include/configs/MPC8555CDS.h u-boot-i2c/include/configs/MPC8555CDS.h --- u-boot-i2c.orig/include/configs/MPC8555CDS.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/MPC8555CDS.h 2009-02-12 10:46:00.000000000 -0800 @@ -320,13 +320,13 @@ extern unsigned long get_clock_freq(void /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_NEW_I2C +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */
/* EEPROM */ #define CONFIG_ID_EEPROM diff -purN u-boot-i2c.orig/include/configs/MPC8560ADS.h u-boot-i2c/include/configs/MPC8560ADS.h --- u-boot-i2c.orig/include/configs/MPC8560ADS.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/MPC8560ADS.h 2009-02-12 10:46:00.000000000 -0800 @@ -291,13 +291,13 @@ /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_NEW_I2C +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */
/* RapidIO MMU */ #define CONFIG_SYS_RIO_MEM_VIRT 0xc0000000 /* base address */ diff -purN u-boot-i2c.orig/include/configs/MPC8568MDS.h u-boot-i2c/include/configs/MPC8568MDS.h --- u-boot-i2c.orig/include/configs/MPC8568MDS.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/MPC8568MDS.h 2009-02-12 10:46:00.000000000 -0800 @@ -306,17 +306,18 @@ extern unsigned long get_clock_freq(void /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_I2C_MULTI_BUS -#define CONFIG_I2C_CMD_TREE -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_NEW_I2C +#define CONFIG_SYS_NUM_I2C_ADAPTERS 2 +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_FSL_I2C2_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0], &fsl_i2c_adap[1]} +#define CONFIG_SYS_I2C_NOPROBES {{0,0x69}} /* Don't probe these addrs */ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x52 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0,0x69}} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * General PCI diff -purN u-boot-i2c.orig/include/configs/MPC8572DS.h u-boot-i2c/include/configs/MPC8572DS.h --- u-boot-i2c.orig/include/configs/MPC8572DS.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/MPC8572DS.h 2009-02-12 10:46:00.000000000 -0800 @@ -373,17 +373,18 @@ extern unsigned long get_board_ddr_clk(u #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */
/* I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_I2C_MULTI_BUS -#define CONFIG_I2C_CMD_TREE -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_NEW_I2C +#define CONFIG_SYS_NUM_I2C_ADAPTERS 2 +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_FSL_I2C2_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0], &fsl_i2c_adap[1]} +#define CONFIG_SYS_I2C_NOPROBES {{0,0x29}} /* Don't probe these addrs */ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0,0x29}}/* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * I2C2 EEPROM diff -purN u-boot-i2c.orig/include/configs/MPC8610HPCD.h u-boot-i2c/include/configs/MPC8610HPCD.h --- u-boot-i2c.orig/include/configs/MPC8610HPCD.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/MPC8610HPCD.h 2009-02-12 10:46:00.000000000 -0800 @@ -261,13 +261,13 @@ /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_NEW_I2C +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */
/* * General PCI diff -purN u-boot-i2c.orig/include/configs/MPC8641HPCN.h u-boot-i2c/include/configs/MPC8641HPCN.h --- u-boot-i2c.orig/include/configs/MPC8641HPCN.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/MPC8641HPCN.h 2009-02-12 10:46:00.000000000 -0800 @@ -310,13 +310,13 @@ extern unsigned long get_board_sys_clk(u /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3100 +#define CONFIG_NEW_I2C +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3100 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */
/* * RapidIO MMU diff -purN u-boot-i2c.orig/include/configs/MVBLM7.h u-boot-i2c/include/configs/MVBLM7.h --- u-boot-i2c.orig/include/configs/MVBLM7.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/MVBLM7.h 2009-02-12 10:46:00.000000000 -0800 @@ -42,23 +42,22 @@ #define CONFIG_PCI #define CONFIG_83XX_GENERIC_PCI #define CONFIG_PCI_SKIP_HOST_BRIDGE -#define CONFIG_HARD_I2C #define CONFIG_TSEC_ENET #define CONFIG_MPC8XXX_SPI #define CONFIG_HARD_SPI #define MVBLM7_MMC_CS 0x04000000
/* I2C */ -#undef CONFIG_SOFT_I2C - +#define CONFIG_NEW_I2C +#define CONFIG_SYS_NUM_I2C_ADAPTERS 2 #define CONFIG_FSL_I2C -#define CONFIG_I2C_MULTI_BUS -#define CONFIG_I2C_CMD_TREE -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 - -#define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_SPEED 100000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_FSL_I2C2_SPEED 100000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0], &fsl_i2c_adap[1]}
/* * DDR Setup diff -purN u-boot-i2c.orig/include/configs/NC650.h u-boot-i2c/include/configs/NC650.h --- u-boot-i2c.orig/include/configs/NC650.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/NC650.h 2009-02-12 10:46:00.000000000 -0800 @@ -104,10 +104,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7f - +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 100000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0x7f +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ diff -purN u-boot-i2c.orig/include/configs/PM826.h u-boot-i2c/include/configs/PM826.h --- u-boot-i2c.orig/include/configs/PM826.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/PM826.h 2009-02-12 10:46:00.000000000 -0800 @@ -54,9 +54,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xFE +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ diff -purN u-boot-i2c.orig/include/configs/PM828.h u-boot-i2c/include/configs/PM828.h --- u-boot-i2c.orig/include/configs/PM828.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/PM828.h 2009-02-12 10:46:00.000000000 -0800 @@ -54,9 +54,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xFE +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ diff -purN u-boot-i2c.orig/include/configs/PM854.h u-boot-i2c/include/configs/PM854.h --- u-boot-i2c.orig/include/configs/PM854.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/PM854.h 2009-02-12 10:46:00.000000000 -0800 @@ -194,13 +194,13 @@ /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_NEW_I2C +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */
/* * EEPROM configuration diff -purN u-boot-i2c.orig/include/configs/PM856.h u-boot-i2c/include/configs/PM856.h --- u-boot-i2c.orig/include/configs/PM856.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/PM856.h 2009-02-12 10:46:00.000000000 -0800 @@ -191,13 +191,13 @@ /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_NEW_I2C +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */
/* * EEPROM configuration diff -purN u-boot-i2c.orig/include/configs/RRvision.h u-boot-i2c/include/configs/RRvision.h --- u-boot-i2c.orig/include/configs/RRvision.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/RRvision.h 2009-02-12 10:46:00.000000000 -0800 @@ -119,12 +119,12 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C /* I2C bit-banged */ - -# define CONFIG_SYS_I2C_SPEED 50000 /* 50 kHz is supposed to work */ -# define CONFIG_SYS_I2C_SLAVE 0xFE - -#ifdef CONFIG_SOFT_I2C +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ @@ -140,7 +140,6 @@ #define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ else immr->im_cpm.cp_pbdat &= ~PB_SCL #define I2C_DELAY udelay(1) /* 1/4 I2C clock duration */ -#endif /* CONFIG_SOFT_I2C */
/* diff -purN u-boot-i2c.orig/include/configs/Sandpoint8240.h u-boot-i2c/include/configs/Sandpoint8240.h --- u-boot-i2c.orig/include/configs/Sandpoint8240.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/Sandpoint8240.h 2009-02-12 10:46:00.000000000 -0800 @@ -209,6 +209,11 @@
#ifdef CONFIG_SOFT_I2C #error "Soft I2C is not configured properly. Please review!" +#define CONFIG_NEW_I2C +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} #define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ #define I2C_ACTIVE (iop->pdir |= 0x00010000) #define I2C_TRISTATE (iop->pdir &= ~0x00010000) diff -purN u-boot-i2c.orig/include/configs/Sandpoint8245.h u-boot-i2c/include/configs/Sandpoint8245.h --- u-boot-i2c.orig/include/configs/Sandpoint8245.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/Sandpoint8245.h 2009-02-12 10:46:00.000000000 -0800 @@ -179,6 +179,11 @@
#ifdef CONFIG_SOFT_I2C #error "Soft I2C is not configured properly. Please review!" +#define CONFIG_NEW_I2C +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} #define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ #define I2C_ACTIVE (iop->pdir |= 0x00010000) #define I2C_TRISTATE (iop->pdir &= ~0x00010000) diff -purN u-boot-i2c.orig/include/configs/SBC8540.h u-boot-i2c/include/configs/SBC8540.h --- u-boot-i2c.orig/include/configs/SBC8540.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/SBC8540.h 2009-02-12 10:46:00.000000000 -0800 @@ -234,13 +234,13 @@ /* * I2C */ -#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_NEW_I2C +#define CONFIG_FSL_I2C +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0]} +#define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */
#define CONFIG_SYS_PCI_MEM_BASE 0xC0000000 #define CONFIG_SYS_PCI_MEM_PHYS 0xC0000000 diff -purN u-boot-i2c.orig/include/configs/SCM.h u-boot-i2c/include/configs/SCM.h --- u-boot-i2c.orig/include/configs/SCM.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/SCM.h 2009-02-12 10:46:00.000000000 -0800 @@ -74,14 +74,15 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 400000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ - #define I2C_PORT 3 /* Port A=0, B=1, C=2, D=3 */ #define I2C_ACTIVE (iop->pdir |= 0x00010000) #define I2C_TRISTATE (iop->pdir &= ~0x00010000) diff -purN u-boot-i2c.orig/include/configs/SIMPC8313.h u-boot-i2c/include/configs/SIMPC8313.h --- u-boot-i2c.orig/include/configs/SIMPC8313.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/SIMPC8313.h 2009-02-12 10:46:00.000000000 -0800 @@ -217,15 +217,17 @@ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* I2C */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#define CONFIG_NEW_I2C +#define CONFIG_SYS_NUM_I2C_ADAPTERS 2 #define CONFIG_FSL_I2C -#define CONFIG_I2C_MULTI_BUS -#define CONFIG_I2C_CMD_TREE -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 +#define CONFIG_SYS_FSL_I2C2_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F +#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_ADAPTERS {&fsl_i2c_adap[0], &fsl_i2c_adap[1]} #define CONFIG_SYS_I2C_NOPROBES {{0,0x69}} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * General PCI diff -purN u-boot-i2c.orig/include/configs/SMN42.h u-boot-i2c/include/configs/SMN42.h --- u-boot-i2c.orig/include/configs/SMN42.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/SMN42.h 2009-02-12 10:46:00.000000000 -0800 @@ -78,17 +78,13 @@
/* enable I2C and select the hardware/software driver */ #undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 10000 /* this would be 0xAE if E0, E1 and E2 were pulled high */ -#define CONFIG_SYS_I2C_SLAVE 0xA0 -#define CONFIG_SYS_I2C_EEPROM_ADDR (0xA0 >> 1) -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* 16 bit address */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 /* 64 bytes per write */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 -/* not used but required by devices.c */ -#define CONFIG_SYS_I2C_SPEED 10000 - -#ifdef CONFIG_SOFT_I2C +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xA0 +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ @@ -107,7 +103,11 @@ i2ctmp = GET32(IO0DIR); \ i2ctmp &= ~SDA; \ PUT32(IO0DIR, i2ctmp); } -#endif /* CONFIG_SOFT_I2C */ + +#define CONFIG_SYS_I2C_EEPROM_ADDR (0xA0 >> 1) +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* 16 bit address */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 /* 64 bytes per write */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20
/* diff -purN u-boot-i2c.orig/include/configs/SX1.h u-boot-i2c/include/configs/SX1.h --- u-boot-i2c.orig/include/configs/SX1.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/SX1.h 2009-02-12 10:46:00.000000000 -0800 @@ -81,10 +81,11 @@ /* * I2C configuration */ -#define CONFIG_HARD_I2C -#define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_SYS_I2C_SLAVE 1 -#define CONFIG_DRIVER_OMAP1510_I2C +#define CONFIG_NEW_I2C +#define CONFIG_OMAP1510_I2C +#define CONFIG_SYS_OMAP1510_I2C_SPEED 100000 /* I2C speed and slave address */ +#define CONFIG_SYS_OMAP1510_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_ADAPTERS {&omap1510_i2c_adap}
#define CONFIG_ENV_OVERWRITE
diff -purN u-boot-i2c.orig/include/configs/SXNI855T.h u-boot-i2c/include/configs/SXNI855T.h --- u-boot-i2c.orig/include/configs/SXNI855T.h 2009-02-12 10:43:41.000000000 -0800 +++ u-boot-i2c/include/configs/SXNI855T.h 2009-02-12 10:46:00.000000000 -0800 @@ -119,7 +119,12 @@
#define CONFIG_RTC_DS1306 /* Dallas 1306 real time clock */
-#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_NEW_I2C +#define CONFIG_SOFT_I2C /* I2C bit-banged */ +#define I2C_SOFT_DECLARATIONS I2C_SOFT_DEFS +#define CONFIG_SYS_SOFT_I2C_SPEED 50000 +#define CONFIG_SYS_SOFT_I2C_SLAVE 0xFE +#define CONFIG_SYS_I2C_ADAPTERS {&soft_i2c_adap[0]} /* * Software (bit-bang) I2C driver configuration */ @@ -136,8 +141,6 @@ else immr->im_cpm.cp_pbdat &= ~PB_SCL #define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */
-# define CONFIG_SYS_I2C_SPEED 50000 -# define CONFIG_SYS_I2C_SLAVE 0xFE # define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* Atmel 24C64 */ # define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* two byte address */
ksi@koi8.net
