[U-Boot-Users] [PATCH 4/8] SPARC: Added SPARC board information to bdinfo command
This patch adds support for the U-Boot command 'bdinfo' for SPARC boards, the output is as shown below.
###################### U-Boot 1.3.2-gb42c95ff-dirty (Mar 12 2008 - 21:07:56)Gaisler GRSIM
CPU: LEON3 Board: GRSIM/TSIM Using default environment
In: serial Out: serial Err: serial Net: GRETH 10/100
Type "run flash_nfs" to mount root filesystem over NFS
Hit any key to stop autoboot: 0 => bdinfo memstart = 0x40000000 memsize = 0x04000000 flashstart = 0x00000000 CFG_MONITOR_BASE = 0x00000000 CFG_ENV_ADDR = 0x007F8000 CFG_RELOC_MONITOR_BASE = 0x43f8e000 (262144) CFG_MALLOC_BASE = 0x43fce000 (131072) CFG_INIT_SP_OFFSET = 0x43ffdfe0 (65504) CFG_PROM_OFFSET = 0x43ffe000 (8064) CFG_GBL_DATA_OFFSET = 0x43ffff80 (128) ethaddr = 00:00:7A:CC:00:12 IP addr = 192.168.0.80 baudrate = 38400 bps => ######################
Best Regards, Daniel Hellstrom
commit 6bc2ec61fd40610461266f6a7f21a01a4a47016c Author: Daniel Hellstrom daniel@gaisler.com Date: Wed Mar 12 21:16:14 2008 +0100
SPARC: added SPARC board information to the command bdinfo.
Signed-off-by: Daniel Hellstrom daniel@gaisler.com
common/cmd_bdinfo.c | 34 ++++++++++++++++++++++++++++++++++ 1 files changed, 34 insertions(+), 0 deletions(-)
diff --git a/common/cmd_bdinfo.c b/common/cmd_bdinfo.c index bbb0192..838c103 100644 --- a/common/cmd_bdinfo.c +++ b/common/cmd_bdinfo.c @@ -208,6 +208,40 @@ int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
+#elif defined(CONFIG_SPARC) /* SPARC */ +int do_bdinfo ( cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + bd_t *bd = gd->bd; +#if defined(CONFIG_CMD_NET) + int i; +#endif + +#ifdef DEBUG + print_num ("bd address ",(ulong)bd); +#endif + print_num ("memstart ",bd->bi_memstart); + print_num ("memsize ",bd->bi_memsize); + print_num ("flashstart ",bd->bi_flashstart); + print_num ("CFG_MONITOR_BASE ",CFG_MONITOR_BASE); + print_num ("CFG_ENV_ADDR ",CFG_ENV_ADDR); + printf ("CFG_RELOC_MONITOR_BASE = 0x%lx (%d)\n",CFG_RELOC_MONITOR_BASE,CFG_MONITOR_LEN); + printf ("CFG_MALLOC_BASE = 0x%lx (%d)\n",CFG_MALLOC_BASE,CFG_MALLOC_LEN); + printf ("CFG_INIT_SP_OFFSET = 0x%lx (%d)\n",CFG_INIT_SP_OFFSET,CFG_STACK_SIZE); + printf ("CFG_PROM_OFFSET = 0x%lx (%d)\n",CFG_PROM_OFFSET,CFG_PROM_SIZE); + printf ("CFG_GBL_DATA_OFFSET = 0x%lx (%d)\n",CFG_GBL_DATA_OFFSET,CFG_GBL_DATA_SIZE); + +#if defined(CONFIG_CMD_NET) + puts ("ethaddr ="); + for (i=0; i<6; ++i) { + printf ("%c%02X", i ? ':' : ' ', bd->bi_enetaddr[i]); + } + puts ("\nIP addr = "); + print_IPaddr (bd->bi_ip_addr); +#endif + printf ("\nbaudrate = %6ld bps\n", bd->bi_baudrate ); + return 0; +} + #elif defined(CONFIG_M68K) /* M68K */ static void print_str(const char *, const char *);
- bd_t *bd = gd->bd;
- int i;
+#ifdef DEBUG
- print_num ("bd address ",(ulong)bd);
- print_num ("memstart ",bd->bi_memstart);
- print_num ("memsize ",bd->bi_memsize);
- print_num ("flashstart ",bd->bi_flashstart);
- print_num ("CFG_MONITOR_BASE ",CFG_MONITOR_BASE);
- print_num ("CFG_ENV_ADDR ",CFG_ENV_ADDR);
- printf ("CFG_RELOC_MONITOR_BASE = 0x%lx
- printf ("CFG_MALLOC_BASE = 0x%lx
- printf ("CFG_INIT_SP_OFFSET = 0x%lx
- printf ("CFG_PROM_OFFSET = 0x%lx
- printf ("CFG_GBL_DATA_OFFSET = 0x%lx
The patch is line-wrapped and thus unusable, and you have again lots of coding style issues.
Daniel Hellstrom
