[PATCH] imx28-xea: Add missing imx28-lwe.dtsi
The following build error is seen when building imx28_xea_defconfig:
arch/arm/dts/.imx28-xea.dtb.pre.tmp:8:10: fatal error: imx28-lwe.dtsi: No such file or directory
This happens because commit ebcca534f557 ("imx28: synchronise device tree with linux") missed to import the imx28-lwe.dtsi file from Linux.
Fix it by importing the file from Linux 6.1-rc1.
Fixes: ebcca534f557 ("imx28: synchronise device tree with linux") Signed-off-by: Fabio Estevam festevam@denx.de --- This applies against u-boot-imx master-next branch.
arch/arm/dts/imx28-lwe.dtsi | 170 ++++++++++++++++++++++++++++++++++++ 1 file changed, 170 insertions(+) create mode 100644 arch/arm/dts/imx28-lwe.dtsi
diff --git a/arch/arm/dts/imx28-lwe.dtsi b/arch/arm/dts/imx28-lwe.dtsi new file mode 100644 index 000000000000..bb971e660db8 --- /dev/null +++ b/arch/arm/dts/imx28-lwe.dtsi @@ -0,0 +1,170 @@ +// SPDX-License-Identifier: GPL-2.0-or-later OR MIT +/* + * Copyright 2021 + * Lukasz Majewski, DENX Software Engineering, lukma@denx.de + */ + +/dts-v1/; +#include "imx28.dtsi" + +/ { + aliases { + spi2 = &ssp3; + }; + + chosen { + bootargs = "root=/dev/mmcblk0p2 rootfstype=ext4 ro rootwait console=ttyAMA0,115200 panic=1"; + }; + + memory@40000000 { + reg = <0x40000000 0x08000000>; + }; + + reg_3v3: regulator-reg-3v3 { + compatible = "regulator-fixed"; + regulator-name = "3V3"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + reg_usb_5v: regulator-reg-usb-5v { + compatible = "regulator-fixed"; + regulator-name = "usb_vbus"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + reg_fec_3v3: regulator-reg-fec-3v3 { + compatible = "regulator-fixed"; + regulator-name = "fec-phy"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; +}; + +&duart { + pinctrl-names = "default"; + pinctrl-0 = <&duart_pins_a>; + status = "okay"; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_pins_a>; + status = "okay"; +}; + +&saif0 { + pinctrl-names = "default"; + pinctrl-0 = <&saif0_pins_a>; + #sound-dai-cells = <0>; + assigned-clocks = <&clks 53>; + assigned-clock-rates = <12000000>; + status = "okay"; +}; + +&saif1 { + pinctrl-names = "default"; + pinctrl-0 = <&saif1_pins_a>; + fsl,saif-master = <&saif0>; + #sound-dai-cells = <0>; + status = "okay"; +}; + +&spi3_pins_a { + fsl,pinmux-ids = < + MX28_PAD_AUART2_RX__SSP3_D4 + MX28_PAD_AUART2_TX__SSP3_D5 + MX28_PAD_SSP3_SCK__SSP3_SCK + MX28_PAD_SSP3_MOSI__SSP3_CMD + MX28_PAD_SSP3_MISO__SSP3_D0 + MX28_PAD_SSP3_SS0__SSP3_D3 + MX28_PAD_AUART2_TX__GPIO_3_9 + >; +}; + +&ssp0 { + compatible = "fsl,imx28-mmc"; + pinctrl-names = "default"; + pinctrl-0 = <&mmc0_8bit_pins_a>; + bus-width = <8>; + vmmc-supply = <®_3v3>; + non-removable; + status = "okay"; +}; + +&ssp2 { + compatible = "fsl,imx28-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi2_pins_a>; + status = "okay"; +}; + +&ssp3 { + compatible = "fsl,imx28-spi"; + pinctrl-names = "default"; + pinctrl-0 = <&spi3_pins_a>; + status = "okay"; + + flash@0 { + compatible = "jedec,spi-nor"; + spi-max-frequency = <40000000>; + reg = <0>; + + partitions { + compatible = "fixed-partitions"; + #address-cells = <1>; + #size-cells = <1>; + + partition@0 { + label = "u-boot"; + reg = <0 0x80000>; + read-only; + }; + + partition@80000 { + label = "env0"; + reg = <0x80000 0x10000>; + }; + + partition@90000 { + label = "env1"; + reg = <0x90000 0x10000>; + }; + + partition@100000 { + label = "kernel"; + reg = <0x100000 0x400000>; + }; + + partition@500000 { + label = "swupdate"; + reg = <0x500000 0x800000>; + }; + }; + }; +}; + +&usb0 { + vbus-supply = <®_usb_5v>; + pinctrl-names = "default"; + pinctrl-0 = <&usb0_pins_b>, <&usb0_id_pins_a>; + dr_mode = "host"; + status = "okay"; +}; + +&usbphy0 { + status = "okay"; +}; + +&usb1 { + vbus-supply = <®_usb_5v>; + pinctrl-names = "default"; + pinctrl-0 = <&usb1_pins_b>; + dr_mode = "host"; + status = "okay"; +}; + +&usbphy1 { + status = "okay"; +};
Hi Fabio
Thanks for this fix and sorry about that.
Reviewed-by: Marcel Ziswiler marcel.ziswiler@toradex.com
- Copyright 2021
- Lukasz Majewski, DENX Software Engineering, lukma@denx.de
Cheers
Marcel
Hi Fabio
On Sat, Oct 22, 2022 at 3:02 PM Marcel Ziswiler marcel.ziswiler@toradex.com wrote:
Hi Fabio
I have seen patches that fix build issues but how they land in the first place. I mean CI is used to avoid build regression
Michael
- Copyright 2021
aliases {
spi2 = &ssp3;
chosen {
memory@40000000 {
+&duart {
status = "okay";
+&i2c0 {
status = "okay";
+&saif0 {
status = "okay";
+&saif1 {
status = "okay";
+&spi3_pins_a {
fsl,pinmux-ids = <
+&ssp0 {
bus-width = <8>;
non-removable;
status = "okay";
+&ssp2 {
status = "okay";
+&ssp3 {
status = "okay";
flash@0 {
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0 0x80000>;
read-only;
partition@80000 {
label = "env0";
partition@90000 {
label = "env1";
partition@100000 {
label = "kernel";
partition@500000 {
label = "swupdate";
+&usb0 {
dr_mode = "host";
status = "okay";
+&usbphy0 {
status = "okay";
+&usb1 {
dr_mode = "host";
status = "okay";
+&usbphy1 {
status = "okay";
Cheers
Marcel
Hi Michael,
On Sat, Oct 22, 2022 at 10:19 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
I am sorry, but I could not understand your message. Care to clarify?
Thanks
Hi
On Sat, Oct 22, 2022 at 3:24 PM Fabio Estevam festevam@gmail.com wrote:
Hi Michael,
Thanks
On my side the Continuous Integration using gitlab-ci, verify board combinations and test the build. I'm asking if this build breakage happen because those boards are not built.
Michael
On Sat, Oct 22, 2022 at 10:31 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
All boards are built by CI and the build error was reported at: https://source.denx.de/u-boot/custodians/u-boot-imx/-/jobs/517428
Hi
Should the patches need to be resend if they are not building? so you want to take care of them
Michael
Hi everybody,
On 22.10.22 15:44, Michael Nazzareno Trimarchi wrote:
Hi
Just to clarify: the broken patches *are* not applied. As pointed by Michael, CI is used to check build *before* applying. What you are looking is my master-next branch, that is patches are applied first to a test branch (master-next) before going to master. If CI is broken, they are simply removed. That is my next step, I have seen that imx28-lwe.dtsi is missing, too. But as patch is not applied, I will kindly ask Marcel to squash Fabio's in his series and repost.
Thanks, Stefano
Michael
On Sat, 2022-10-22 at 17:44 +0200, Stefano Babic wrote:
Hi everybody,
Hi
https://patchwork.ozlabs.org/project/uboot/cover/20221022215945.84052-1-marc...
Thanks, Stefano
Michael
Fabio Estevam
Marcel Ziswiler
Stefano Babic
