[PATCH] boot: don't enable booti/bootz by default if FIT_SIGNATURE is set
To prevent boot unsigned images, same as CONFIG_LEGACY_IMAGE_FORMAT, don't enable CONFIG_CMD_BOOTI and CONFIG_CMD_BOOTI by default if CONFIG_FIT_SIGNATURE is enabled.
Signed-off-by: Yuezhang.Mo myzmzz@126.com --- cmd/Kconfig | 11 ++++++++++- 1 file changed, 10 insertions(+), 1 deletion(-)
diff --git a/cmd/Kconfig b/cmd/Kconfig index 5b30b13e43..5f9dd91928 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -203,15 +203,24 @@ config BOOTM_EFI
config CMD_BOOTZ bool "bootz" + default y if !FIT_SIGNATURE help Boot the Linux zImage + It is enabled by default for backward compatibility, unless + FIT_SIGNATURE is set where it is disabled so that unsigned images + cannot be loaded. If a board needs to boot a Linux zImage in this + case, enable it here.
config CMD_BOOTI bool "booti" depends on ARM64 || RISCV - default y + default y if !FIT_SIGNATURE help Boot an AArch64 Linux Kernel image from memory. + It is enabled by default for backward compatibility, unless + FIT_SIGNATURE is set where it is disabled so that unsigned images + cannot be loaded. If a board needs to boot an AArch64 Linux Kernel + image in this case, enable it here.
config BOOTM_LINUX bool "Support booting Linux OS images"
nits: %s/boot/booting/
Disabling the booti and the bootz command does not stop you from booting unsigned images, e.g. using the bootefi command.
- default y
- default y if !FIT_SIGNATURE
How about CONFIG_EFI_SECURE_BOOT? Should this also disable the default?
Backwards relative to UEFI?
This focuses very much on default values. How about:
"The booti command is used for launching unsigned AArch64 and RISC-V Linux kernel images. If you want to have secure boot either via signed FIT images or via signed UEFI images, this option should be disabled."
Why AArch64 and not RISC-V?
Who needs all those lines.
Best regards
Heinrich
Dear Heinrich,
Thank for your comments.
I think yes. I will update the relation to "default y if !FIT_SIGNATURE && !EFI_SECURE_BOOT", and add "!EFI_SECURE_BOOT" into LEGACY_IMAGE_FORMAT.
No.
This description is from CONFIG_LEGACY_IMAGE_FORMAT.
``` config LEGACY_IMAGE_FORMAT bool "Enable support for the legacy image format" default y if !FIT_SIGNATURE help This option enables the legacy image format. It is enabled by default for backward compatibility, unless FIT_SIGNATURE is set where it is disabled so that unsigned images cannot be loaded. If a board needs the legacy image format support in this case, enable it here. ```
In my understand, this backward compatibility is to support both secure boot and non-secure boot when necessary.
I agree, this description is more comprehensive.
So that I want to update the commit title to "boot: don't enable the non-secure boot commands by default if secure boot enabled"
The help information of CMD_BOOTI only mentions AArch64, so I followed it.
Should I update as following? ```diff - Boot an AArch64 Linux Kernel image from memory. + Boot an AArch64/RISC-V Linux Kernel image from memory. ```
Best regards, Rover
- default y
Best regards
Heinrich
On 11/4/21 04:11, Rover Mo wrote:
Dear Heinrich,
No.
In my understand,this backward compatibility is to support both secure boot and non-secure boot when necessary.
So that I want to update the commit title to "boot: don't enable thenon-secure boot commands by default ifsecure boot enabled"
Yes, please.
Best regards
Heinrich
Best regards, Rover At 2021-11-04 02:24:34, "Heinrich Schuchardt" <xypron.glpk@gmx.de> wrote: >On 11/3/21 08:44, Rover Mo wrote: >> To prevent boot unsigned images, same as CONFIG_LEGACY_IMAGE_FORMAT, > >nits: >%s/boot/booting/ > >> don't enable CONFIG_CMD_BOOTI and CONFIG_CMD_BOOTI by default if >> CONFIG_FIT_SIGNATURE is enabled. > >Disabling the booti and the bootz command does not stop you from booting >unsigned images, e.g. using the bootefi command. > >> >> Signed-off-by: Yuezhang.Mo <myzmzz@126.com> >> --- >> cmd/Kconfig | 11 ++++++++++- >> 1 file changed, 10 insertions(+), 1 deletion(-) >> >> diff --git a/cmd/Kconfig b/cmd/Kconfig >> index 5b30b13e43..5f9dd91928 100644 >> --- a/cmd/Kconfig >> +++ b/cmd/Kconfig >> @@ -203,15 +203,24 @@ config BOOTM_EFI >> >> config CMD_BOOTZ >> bool "bootz" >> + default y if !FIT_SIGNATURE >> help >> Boot the Linux zImage >> + It is enabled by default for backward compatibility, unless >> + FIT_SIGNATURE is set where it is disabled so that unsigned images >> + cannot be loaded. If a board needs to boot a Linux zImage in this >> + case, enable it here. >> >> config CMD_BOOTI >> bool "booti" >> depends on ARM64 || RISCV >> - default y >> + default y if !FIT_SIGNATURE > >How about CONFIG_EFI_SECURE_BOOT? Should this also disable the default? > >> help >> Boot an AArch64 Linux Kernel image from memory. >> + It is enabled by default for backward compatibility, unless > >Backwards relative to UEFI? > >This focuses very much on default values. How about: > >"The booti command is used for launching unsigned AArch64 and RISC-V >Linux kernel images. If you want to have secure boot either via signed >FIT images or via signed UEFI images, this option should be disabled." > >> + FIT_SIGNATURE is set where it is disabled so that unsigned images >> + cannot be loaded. If a board needs to boot an AArch64 Linux Kernel > >Why AArch64 and not RISC-V? > >Who needs all those lines. > >Best regards > >Heinrich > >> + image in this case, enable it here. >> >> config BOOTM_LINUX >> bool "Support booting Linux OS images" >>
Dear Heinrich,
No.
Yes, please.
Also please do check tests (make qcheck) since sandbox enables more options than most boards.
- Simon
Best regards
Heinrich
Rover Mo
