[U-Boot-Users] memset bug in ext2fs_read_file()
Hello,
The ext2fs_read_file() function in fs/ext2/ext2fs.c contains the following line:
439 memset (buf, blocksize - skipfirst, 0);
This is incorrect as the prototype of the function has the fill value as the 2nd parameter and the number of bytes as the 3rd:
void *memset(void *b, int c, size_t n);
I don't have any test code that is affected by this bug. I noticed it when I was investigating a different problem (with OpenMoko).
Dear Mike,
Thanks, applied.
Hello,
this was bug! You will run into this situation, when you use a file with "holes" in it. (Not so likely with a systen image).
Best regards
Reinhard Arlt
Wolfgang Denk wrote:
Dear Mike,
Thanks, applied.
Mike Montour
Reinhard Arlt
