[U-Boot] Pull request: u-boot-dfu
Hi Marek,
The following changes since commit af41d6b4cb1602abebaaa9c8774a9b0ece564796:
common: fixed linker-list example (2014-05-05 10:24:13 +0200)
ssh://gu-dfu@git.denx.de/u-boot-dfu master
for you to fetch changes up to c805776ce7079c7b7dd54c644b499e1b8f6296b1:
ums: allow the user to specify the device type (2014-05-06 11:13:23 +0200)
---------------------------------------------------------------- Stephen Warren (9): usb: ums: add error handling for failed registration ums: support block devices not MMC devices ums: remove UMS_{NUM,START}_SECTORS + UMS_START_SECTOR ums: remove error-checking of MMC device size ums: remove ums_disk_init() ums: move IO support code to common location ums: use get_device() not find_mmc_device(); ums: move all variable declarations to the start of the block ums: allow the user to specify the device type
board/samsung/common/Makefile | 1 - board/samsung/common/ums.c | 74 -------------------------------------------------------------------------- common/cmd_usb_mass_storage.c | 91 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------ include/usb_mass_storage.h | 13 ++-----------
4 files changed, 81 insertions(+), 98 deletions(-) delete mode 100644 board/samsung/common/ums.c
On Tuesday, May 06, 2014 at 11:29:32 AM, Lukasz Majewski wrote:
Hi Marek,
This doesn't match what's in U-Boot-dfu.git/master [1] it seems. Or does it ... ?
[1] http://git.denx.de/?p=u-boot/u-boot-dfu.git;a=summary
Best regards, Marek Vasut
Hi Marek,
Hi Marek,
This PR seems outdated :-).
I've also added to u-boot-dfu work done Rob Herring in the meantime.
I will prepare new PR with those changes included. Thanks for pointing out.
Hello Lukasz,
Am 08.05.2014 08:30, schrieb Lukasz Majewski:
Hi Marek,
Hi Marek,
Hmm, I have 2 patches pending ...
[U-Boot,1/2] musb-new, dfu: first send request answer then call completions http://patchwork.ozlabs.org/patch/337982/
and
[U-Boot,v2] dfu, nand: add medium specific polltimeout function http://patchwork.ozlabs.org/patch/338369/
Could you (or Marek) add them? Or are there some issues with them?
Thanks!
bye, Heiko
Hi Heiko,
Hello Lukasz,
Hi Marek,
Hi Marek,
and
I will test them and if no regressions appear I will add them to u-boot-dfu tree.
Thanks!
bye, Heiko
On Thursday, May 08, 2014 at 09:08:24 AM, Lukasz Majewski wrote:
Hi Heiko,
Hello Lukasz,
Hi Marek,
Hi Marek,
af41d6b4cb1602abebaaa9c8774a9b0ece564796: common: fixed linker-list example (2014-05-05 10:24:13 +0200)
are available in the git repository at: ssh://gu-dfu@git.denx.de/u-boot-dfu master
c805776ce7079c7b7dd54c644b499e1b8f6296b1: ums: allow the user to specify the device type (2014-05-06
11:13:23 +0200)
and
Thanks.
Heiko Schocher
Lukasz Majewski
