[U-Boot] Watchdog doesn't get triggered on U-Boot command line
I initialized the watchdog on a S3C6400 processor. The U-Boot boots fine until the command line prompt.
If I don't use the hush parser, watchdog resets the board approx. after 15 seconds, no matter if I do nothing or if I type in commands. Reading the watchdog counter with "md" shows that it continuously counts down.
If I use the hush parser the watchdog is only triggered if I run commands, e.g. reading the watchdog counter. I can watch, that it gets updated. If I do nothing, the board is resetted approx. after 15 seconds.
Is it intended, that the watchdog isn't triggered in U-Boot's interactive mode? I can't believe that. Or did I missed something?
On which position could I insert in a "WATCHDOG_RESET();" call? The main_loop and the hush parser are very hard to understand. Thanks in advance for help.
U-Boot is 1.3.4.
Kind regards, Jens
P.S.: I hope my e-mail is readable. I currently have to use M$ Outlo*k unitl the mail system on our Linux machine does work again.
Dear "Jens Gehrlein",
In message 47F3F98010FF784EBEE6526EAAB078D103AC722F@tq-mailsrv.tq-net.de you wrote:
Please restrict your line length to something readable, i. e. some 70 characters or so. Thanks.
Normally the console I/O routines will trigger the watchdog while waiting for characters to arrive or to be sent. Obviously you missed to add such code.
Hi Wolfgang, hi Andrew,
OK. It seems Outlo*k needs some manual override... Hope, this mail is better...
On 2008-09-14 in "Re: [U-Boot] Watchdog support." you wrote to Luigi, that this souldn't be necessary. Why couldn't it be in the main loop of U-Boot?
Andrew, I read the mail thread but didn't quite unterstand it, especially it was about PPC and MIPS. Now, I see more clear.
It seems, PPC uses real interrupts. Up to now I thought U-Boot doesn't handle interrupts at all.
Kind regards, Jens
Dear Jens,
In message 47F3F98010FF784EBEE6526EAAB078D103AC7230@tq-mailsrv.tq-net.de you wrote:
I see. Indeed I wasn;t really clear about that, there. I was ignoring the first part of the question and just replying the the second half ("lot of commands (copy in flash, tftp, ...)") - that's what I meant when I wrote " the common infeastructure should work just fine."
Because it wouldn't work. When you are waiting for input, you are usually blocking in a getc() which waits for some status bit to be set that will indicate that the next character was received. You will have to trigger the watchdog in this polling loop.
U-Boot usually doesn't use them, but they are avaiable and can be used where it makes sense. It's just that usually it doesn;t make sense - it only adds complexity to the code without advantages, so we tend to avoid it.
Jens Gehrlein
