[PATCH 00/33] pci: Drop all pre-driver model code
The hard work to actually enable DM_PCI everywhere was done recently. This series attempts to drop most of the code that it no-longer needed now that PCI has been converted to driver model.
It also drops the UCP1020 board since it has various unique build issues. It doesn't even support driver model so it seems reasonable to just remove it.
The DM_PCI option disappears and only PCI is left.
We can drop about 50 ad-hoc CONFIGs also, but this series doesn't do that since it is probably best done when the CONFIGs are resynced. It does include a CONFIG resync patch which can be dropped if that is done separately.
Simon Glass (33): configs: Resync with savedefconfig pci: Drop old code from pci command ppc: Remove UCP1020 board pci: Drop old code from header file pci: Remove guard around compatibility functions pci: Drop DM_PCI check from fdtdec pci: Drop DM_PCI check from pci_common ppc: Drop CONFIG_SYS_PCI_SUBSYS_VENDORID pci: powerpc: Drop old code pci: freescale: Drop old code pci: dm: core: Drop DM_PCI check from devfdt_get_addr_pci() ppc: Drop DM_PCI from config files pci: acpi: Drop DM_PCI check from ahci pci: usb: Drop DM_PCI from ohci ppc: malta: Drop use of DM_PCI ppc: socrates: Drop use of DM_PCI pci: gt64120: Drop use of DM_PCI pci: msc01: Drop use of DM_PCI pci: imx: Drop use of DM_PCI pci: scsi: pci: Drop DM_PCI check from scsi pci: Drop DM_PCI check from bios_emul net: Drop DM_PCI check from designware driver pci: imx: Drop DM_PCI check from cpu driver pci: arm: mvebu: Drop DM_PCI check from pci: sata_sil: Drop DM_PCI checks distro_bootcmd: Drop DM_PCI check pci: Drop pci_init_board() pci: ppc: Drop ftpci100 driver ppc: Drop idt8t49n222a_serdes_clk driver ppc: Drop t4qds and b4860qds references pci: Drop PCI_INDIRECT_BRIDGE pci: Drop DM_PCI pci: Drop migration method
.azure-pipelines.yml | 4 +- README | 3 - arch/Kconfig | 1 - arch/arm/Kconfig | 2 +- arch/arm/mach-imx/cpu.c | 4 - arch/arm/mach-imx/mx6/Kconfig | 2 +- arch/arm/mach-mvebu/arm64-common.c | 5 +- arch/mips/Kconfig | 2 +- arch/nds32/include/asm/arch-ag102/ag102.h | 2 - arch/powerpc/cpu/mpc83xx/pci.c | 160 ---- arch/powerpc/cpu/mpc85xx/Makefile | 1 - arch/powerpc/cpu/mpc85xx/pci.c | 191 ---- board/Arcturus/ucp1020/Kconfig | 28 +- board/Arcturus/ucp1020/MAINTAINERS | 7 - board/Arcturus/ucp1020/Makefile | 31 - board/Arcturus/ucp1020/README | 54 -- board/Arcturus/ucp1020/cmd_arc.c | 408 --------- board/Arcturus/ucp1020/ddr.c | 161 ---- board/Arcturus/ucp1020/law.c | 24 - board/Arcturus/ucp1020/spl.c | 127 --- board/Arcturus/ucp1020/spl_minimal.c | 67 -- board/Arcturus/ucp1020/tlb.c | 100 --- board/Arcturus/ucp1020/ucp1020.c | 372 -------- board/Arcturus/ucp1020/ucp1020.h | 45 - board/cavium/thunderx/thunderx.c | 7 - board/emulation/qemu-riscv/Kconfig | 1 - board/freescale/common/Makefile | 1 - board/freescale/common/cds_pci_ft.c | 59 -- .../common/idt8t49n222a_serdes_clk.c | 208 ----- .../common/idt8t49n222a_serdes_clk.h | 106 --- board/freescale/common/p_corenet/Makefile | 1 - board/freescale/common/p_corenet/pci.c | 25 - board/freescale/mpc8349emds/pci.c | 73 -- board/freescale/mpc837xerdb/Makefile | 1 - board/freescale/mpc837xerdb/pci.c | 109 --- board/freescale/mpc8548cds/mpc8548cds.c | 114 --- board/freescale/p1010rdb/p1010rdb.c | 11 - board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 11 - board/freescale/t102xrdb/Makefile | 1 - board/freescale/t102xrdb/pci.c | 25 - board/freescale/t104xrdb/Makefile | 1 - board/freescale/t104xrdb/pci.c | 25 - board/freescale/t208xqds/Makefile | 1 - board/freescale/t208xqds/pci.c | 25 - board/freescale/t208xrdb/Makefile | 1 - board/freescale/t208xrdb/pci.c | 25 - board/freescale/t4rdb/Makefile | 1 - board/freescale/t4rdb/pci.c | 25 - board/imgtec/malta/malta.c | 67 -- board/socionext/developerbox/Kconfig | 1 - board/socrates/socrates.c | 4 +- board/xes/common/fsl_8xxx_pci.c | 50 -- cmd/pci.c | 212 ----- common/Kconfig | 1 - configs/MPC8349EMDS_PCI64_defconfig | 1 - configs/MPC8349EMDS_SDRAM_defconfig | 1 - configs/MPC8349EMDS_SLAVE_defconfig | 1 - configs/MPC8349EMDS_defconfig | 1 - configs/MPC837XERDB_defconfig | 2 - configs/MPC8548CDS_36BIT_defconfig | 1 - configs/MPC8548CDS_defconfig | 1 - configs/MPC8548CDS_legacy_defconfig | 1 - configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 - configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 - configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PA_NAND_defconfig | 1 - configs/P1010RDB-PA_NOR_defconfig | 1 - configs/P1010RDB-PA_SDCARD_defconfig | 1 - configs/P1010RDB-PA_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 - configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 - configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_NAND_defconfig | 1 - configs/P1010RDB-PB_NOR_defconfig | 1 - configs/P1010RDB-PB_SDCARD_defconfig | 1 - configs/P1010RDB-PB_SPIFLASH_defconfig | 1 - configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 - configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 2 - configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 2 - configs/P1020RDB-PC_36BIT_defconfig | 2 - configs/P1020RDB-PC_NAND_defconfig | 2 - configs/P1020RDB-PC_SDCARD_defconfig | 2 - configs/P1020RDB-PC_SPIFLASH_defconfig | 2 - configs/P1020RDB-PC_defconfig | 2 - configs/P1020RDB-PD_NAND_defconfig | 2 - configs/P1020RDB-PD_SDCARD_defconfig | 2 - configs/P1020RDB-PD_SPIFLASH_defconfig | 2 - configs/P1020RDB-PD_defconfig | 2 - configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 - configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 2 - configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 2 - configs/P2020RDB-PC_36BIT_defconfig | 2 - configs/P2020RDB-PC_NAND_defconfig | 2 - configs/P2020RDB-PC_SDCARD_defconfig | 2 - configs/P2020RDB-PC_SPIFLASH_defconfig | 2 - configs/P2020RDB-PC_defconfig | 2 - configs/P2041RDB_NAND_defconfig | 2 - configs/P2041RDB_SDCARD_defconfig | 2 - configs/P2041RDB_SPIFLASH_defconfig | 2 - configs/P2041RDB_defconfig | 2 - configs/P3041DS_NAND_defconfig | 2 - configs/P3041DS_SDCARD_defconfig | 2 - configs/P3041DS_SPIFLASH_defconfig | 2 - configs/P3041DS_defconfig | 2 - configs/P4080DS_SDCARD_defconfig | 2 - configs/P4080DS_SPIFLASH_defconfig | 2 - configs/P4080DS_defconfig | 2 - configs/P5040DS_NAND_defconfig | 2 - configs/P5040DS_SDCARD_defconfig | 2 - configs/P5040DS_SPIFLASH_defconfig | 2 - configs/P5040DS_defconfig | 2 - configs/T1024RDB_NAND_defconfig | 2 - configs/T1024RDB_SDCARD_defconfig | 2 - configs/T1024RDB_SPIFLASH_defconfig | 2 - configs/T1024RDB_defconfig | 2 - configs/T1042D4RDB_NAND_defconfig | 2 - configs/T1042D4RDB_SDCARD_defconfig | 2 - configs/T1042D4RDB_SPIFLASH_defconfig | 2 - configs/T1042D4RDB_defconfig | 2 - configs/T2080QDS_NAND_defconfig | 4 +- configs/T2080QDS_SDCARD_defconfig | 4 +- configs/T2080QDS_SECURE_BOOT_defconfig | 4 +- configs/T2080QDS_SPIFLASH_defconfig | 4 +- configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 4 +- configs/T2080QDS_defconfig | 4 +- configs/T2080RDB_NAND_defconfig | 2 - configs/T2080RDB_SDCARD_defconfig | 2 - configs/T2080RDB_SPIFLASH_defconfig | 2 - configs/T2080RDB_defconfig | 2 - configs/T2080RDB_revD_NAND_defconfig | 2 - configs/T2080RDB_revD_SDCARD_defconfig | 2 - configs/T2080RDB_revD_SPIFLASH_defconfig | 2 - configs/T2080RDB_revD_defconfig | 2 - configs/T4240RDB_SDCARD_defconfig | 2 - configs/T4240RDB_defconfig | 2 - configs/UCP1020_defconfig | 59 -- configs/alt_defconfig | 2 - configs/am335x_baltos_defconfig | 1 - configs/am335x_boneblack_vboot_defconfig | 1 - configs/am335x_evm_defconfig | 1 - configs/am335x_evm_spiboot_defconfig | 1 - configs/am335x_guardian_defconfig | 13 +- configs/am335x_hs_evm_defconfig | 1 - configs/am335x_hs_evm_uart_defconfig | 1 - configs/am3517_evm_defconfig | 1 - configs/am43xx_evm_defconfig | 1 - configs/am43xx_evm_qspiboot_defconfig | 1 - configs/am43xx_evm_rtconly_defconfig | 1 - configs/am43xx_evm_usbhost_boot_defconfig | 1 - configs/am43xx_hs_evm_defconfig | 1 - configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/am57xx_hs_evm_usb_defconfig | 1 - configs/am64x_evm_a53_defconfig | 1 - configs/am64x_evm_r5_defconfig | 1 - configs/am65x_evm_a53_defconfig | 1 - configs/am65x_evm_r5_usbdfu_defconfig | 2 - configs/am65x_evm_r5_usbmsc_defconfig | 2 - configs/am65x_hs_evm_a53_defconfig | 1 - configs/apalis-imx8x_defconfig | 1 - configs/apalis-tk1_defconfig | 2 - configs/apalis_imx6_defconfig | 3 +- configs/apalis_t30_defconfig | 2 - configs/aristainetos2c_defconfig | 2 - configs/aristainetos2ccslb_defconfig | 2 - configs/arndale_defconfig | 1 - configs/at91sam9260ek_dataflash_cs0_defconfig | 2 - configs/at91sam9260ek_dataflash_cs1_defconfig | 2 - configs/at91sam9260ek_nandflash_defconfig | 2 - configs/at91sam9261ek_dataflash_cs0_defconfig | 2 - configs/at91sam9261ek_dataflash_cs3_defconfig | 2 - configs/at91sam9261ek_nandflash_defconfig | 2 - configs/at91sam9263ek_dataflash_cs0_defconfig | 3 - configs/at91sam9263ek_dataflash_defconfig | 3 - configs/at91sam9263ek_nandflash_defconfig | 3 - configs/at91sam9263ek_norflash_boot_defconfig | 3 - configs/at91sam9263ek_norflash_defconfig | 3 - configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 - configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 - configs/at91sam9g10ek_nandflash_defconfig | 2 - configs/at91sam9g20ek_2mmc_defconfig | 3 - .../at91sam9g20ek_2mmc_nandflash_defconfig | 3 - configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 - configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 - configs/at91sam9g20ek_nandflash_defconfig | 2 - configs/at91sam9m10g45ek_mmc_defconfig | 1 - configs/at91sam9m10g45ek_nandflash_defconfig | 1 - configs/at91sam9n12ek_mmc_defconfig | 3 - configs/at91sam9n12ek_nandflash_defconfig | 3 - configs/at91sam9n12ek_spiflash_defconfig | 3 - configs/at91sam9x5ek_dataflash_defconfig | 1 - configs/at91sam9x5ek_mmc_defconfig | 1 - configs/at91sam9x5ek_nandflash_defconfig | 1 - configs/at91sam9x5ek_spiflash_defconfig | 1 - configs/at91sam9xeek_dataflash_cs0_defconfig | 2 - configs/at91sam9xeek_dataflash_cs1_defconfig | 2 - configs/at91sam9xeek_nandflash_defconfig | 2 - configs/axs101_defconfig | 1 - configs/axs103_defconfig | 1 - configs/beaver_defconfig | 6 +- configs/beelink-gtking_defconfig | 1 - configs/beelink-gtkingpro_defconfig | 1 - configs/blanche_defconfig | 2 - configs/boston32r2_defconfig | 1 - configs/boston32r2el_defconfig | 1 - configs/boston32r6_defconfig | 1 - configs/boston32r6el_defconfig | 1 - configs/boston64r2_defconfig | 1 - configs/boston64r2el_defconfig | 1 - configs/boston64r6_defconfig | 1 - configs/boston64r6el_defconfig | 1 - configs/brppt1_mmc_defconfig | 1 - configs/brppt1_nand_defconfig | 2 - configs/brppt1_spi_defconfig | 1 - configs/brppt2_defconfig | 1 - configs/brsmarc1_defconfig | 1 - configs/brxre1_defconfig | 1 - configs/cardhu_defconfig | 2 - configs/cei-tk1-som_defconfig | 6 +- configs/chiliboard_defconfig | 1 - configs/cl-som-imx7_defconfig | 1 - configs/clearfog_defconfig | 1 - configs/clearfog_gt_8k_defconfig | 2 - configs/cm_fx6_defconfig | 1 - configs/cm_t43_defconfig | 1 - configs/colibri-imx6ull_defconfig | 1 - configs/colibri_imx6_defconfig | 3 +- configs/colibri_imx7_defconfig | 1 - configs/colibri_imx7_emmc_defconfig | 1 - configs/colibri_pxa270_defconfig | 1 - configs/colibri_t20_defconfig | 5 +- configs/colibri_t30_defconfig | 5 +- configs/colibri_vf_defconfig | 1 - configs/comtrend_ar5315u_ram_defconfig | 1 - configs/comtrend_ar5387un_ram_defconfig | 1 - configs/comtrend_ct5361_ram_defconfig | 1 - configs/comtrend_vr3032u_ram_defconfig | 1 - configs/comtrend_wap5813n_ram_defconfig | 1 - configs/controlcenterdc_defconfig | 1 - configs/corvus_defconfig | 2 - configs/d2net_v2_defconfig | 2 - configs/da850evm_defconfig | 1 - configs/da850evm_direct_nor_defconfig | 2 - configs/da850evm_nand_defconfig | 1 - configs/dalmore_defconfig | 5 +- configs/db-88f6720_defconfig | 2 - configs/db-88f6820-amc_defconfig | 3 - configs/db-88f6820-gp_defconfig | 2 - configs/db-mv784mp-gp_defconfig | 3 - configs/db-xc3-24g4xg_defconfig | 2 - configs/devkit3250_defconfig | 3 - configs/dh_imx6_defconfig | 1 - configs/display5_factory_defconfig | 1 - configs/dns325_defconfig | 2 - configs/dra7xx_evm_defconfig | 1 - configs/dra7xx_hs_evm_defconfig | 1 - configs/dra7xx_hs_evm_usb_defconfig | 1 - configs/dragonboard410c_defconfig | 9 +- configs/dreamplug_defconfig | 2 - configs/ds109_defconfig | 2 - configs/ds414_defconfig | 2 - configs/durian_defconfig | 1 - configs/edison_defconfig | 2 +- configs/edminiv2_defconfig | 3 - configs/ethernut5_defconfig | 1 - configs/ev-imx280-nano-x-mb_defconfig | 1 - configs/firefly-rk3288_defconfig | 4 +- configs/ge_b1x5v2_defconfig | 1 - configs/ge_bx50v3_defconfig | 1 - configs/goflexhome_defconfig | 2 - configs/gose_defconfig | 2 - configs/grpeach_defconfig | 2 - configs/guruplug_defconfig | 2 - configs/gwventana_emmc_defconfig | 9 +- configs/gwventana_gw5904_defconfig | 9 +- configs/gwventana_nand_defconfig | 9 +- configs/harmony_defconfig | 2 - configs/helios4_defconfig | 1 - configs/hihope_rzg2_defconfig | 1 - configs/hikey_defconfig | 1 - configs/hsdk_defconfig | 1 - configs/huawei_hg556a_ram_defconfig | 1 - configs/imx6q_logic_defconfig | 1 - configs/imx7_cm_defconfig | 1 - configs/imx8mm-cl-iot-gate_defconfig | 5 +- configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - configs/imx8mq_evk_defconfig | 8 +- configs/imxrt1050-evk_defconfig | 1 - configs/inetspace_v2_defconfig | 2 - configs/iot_devkit_defconfig | 1 - configs/j7200_evm_a72_defconfig | 1 - configs/j7200_evm_r5_defconfig | 5 +- configs/j721e_evm_a72_defconfig | 1 - configs/j721e_evm_r5_defconfig | 1 - configs/j721e_hs_evm_a72_defconfig | 1 - configs/jetson-tk1_defconfig | 6 +- configs/k2e_evm_defconfig | 1 - configs/k2e_hs_evm_defconfig | 1 - configs/k2g_evm_defconfig | 1 - configs/k2g_hs_evm_defconfig | 1 - configs/k2hk_evm_defconfig | 1 - configs/k2hk_hs_evm_defconfig | 1 - configs/k2l_evm_defconfig | 1 - configs/k2l_hs_evm_defconfig | 1 - configs/khadas-vim2_defconfig | 1 - configs/khadas-vim3_defconfig | 1 - configs/khadas-vim3l_defconfig | 1 - configs/khadas-vim_defconfig | 1 - configs/kmcent2_defconfig | 1 - configs/koelsch_defconfig | 2 - configs/kylin-rk3036_defconfig | 4 +- configs/lager_defconfig | 2 - configs/libretech-ac_defconfig | 1 - configs/libretech-cc_defconfig | 1 - configs/libretech-cc_v2_defconfig | 1 - configs/libretech-s905d-pc_defconfig | 1 - configs/libretech-s912-pc_defconfig | 1 - configs/linkit-smart-7688_defconfig | 2 - configs/liteboard_defconfig | 1 - configs/ls1012a2g5rdb_qspi_defconfig | 1 - configs/ls1012a2g5rdb_tfa_defconfig | 1 - configs/ls1012afrdm_qspi_defconfig | 3 - configs/ls1012afrdm_tfa_defconfig | 3 - .../ls1012afrwy_qspi_SECURE_BOOT_defconfig | 2 - configs/ls1012afrwy_qspi_defconfig | 2 - configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 2 - configs/ls1012afrwy_tfa_defconfig | 2 - configs/ls1012aqds_qspi_defconfig | 2 - configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 2 - configs/ls1012aqds_tfa_defconfig | 2 - configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 2 - configs/ls1012ardb_qspi_defconfig | 2 - configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 2 - configs/ls1012ardb_tfa_defconfig | 2 - configs/ls1021aiot_qspi_defconfig | 2 - configs/ls1021aiot_sdcard_defconfig | 1 - configs/ls1021aqds_ddr4_nor_defconfig | 4 +- configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 4 +- configs/ls1021aqds_nand_defconfig | 4 +- configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 4 +- configs/ls1021aqds_nor_defconfig | 4 +- configs/ls1021aqds_nor_lpuart_defconfig | 4 +- configs/ls1021aqds_qspi_defconfig | 4 +- configs/ls1021aqds_sdcard_ifc_defconfig | 4 +- configs/ls1021aqds_sdcard_qspi_defconfig | 4 +- configs/ls1021atsn_qspi_defconfig | 2 - configs/ls1021atsn_sdcard_defconfig | 2 - configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 2 - configs/ls1021atwr_nor_defconfig | 2 - configs/ls1021atwr_nor_lpuart_defconfig | 2 - configs/ls1021atwr_qspi_defconfig | 2 - ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 - configs/ls1021atwr_sdcard_ifc_defconfig | 2 - configs/ls1021atwr_sdcard_qspi_defconfig | 2 - configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 2 - configs/ls1028aqds_tfa_defconfig | 2 - configs/ls1028aqds_tfa_lpuart_defconfig | 2 - configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 2 - configs/ls1028ardb_tfa_defconfig | 2 - configs/ls1043aqds_defconfig | 4 +- configs/ls1043aqds_lpuart_defconfig | 4 +- configs/ls1043aqds_nand_defconfig | 4 +- configs/ls1043aqds_nor_ddr3_defconfig | 4 +- configs/ls1043aqds_qspi_defconfig | 4 +- configs/ls1043aqds_sdcard_ifc_defconfig | 4 +- configs/ls1043aqds_sdcard_qspi_defconfig | 4 +- configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 4 +- configs/ls1043aqds_tfa_defconfig | 4 +- configs/ls1043ardb_SECURE_BOOT_defconfig | 2 - configs/ls1043ardb_defconfig | 2 - configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 - configs/ls1043ardb_nand_defconfig | 2 - .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 - configs/ls1043ardb_sdcard_defconfig | 2 - configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 2 - configs/ls1043ardb_tfa_defconfig | 2 - configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 4 +- configs/ls1046afrwy_tfa_defconfig | 4 +- configs/ls1046aqds_SECURE_BOOT_defconfig | 4 +- configs/ls1046aqds_defconfig | 4 +- configs/ls1046aqds_lpuart_defconfig | 4 +- configs/ls1046aqds_nand_defconfig | 4 +- configs/ls1046aqds_qspi_defconfig | 4 +- configs/ls1046aqds_sdcard_ifc_defconfig | 4 +- configs/ls1046aqds_sdcard_qspi_defconfig | 4 +- configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 4 +- configs/ls1046aqds_tfa_defconfig | 4 +- configs/ls1046ardb_emmc_defconfig | 2 - configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 2 - configs/ls1046ardb_qspi_defconfig | 2 - configs/ls1046ardb_qspi_spl_defconfig | 2 - .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 - configs/ls1046ardb_sdcard_defconfig | 2 - configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 2 - configs/ls1046ardb_tfa_defconfig | 2 - configs/ls1088aqds_defconfig | 4 +- configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 4 +- configs/ls1088aqds_qspi_defconfig | 4 +- configs/ls1088aqds_sdcard_ifc_defconfig | 4 +- configs/ls1088aqds_sdcard_qspi_defconfig | 4 +- configs/ls1088aqds_tfa_defconfig | 4 +- configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 4 +- configs/ls1088ardb_qspi_defconfig | 4 +- ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 4 +- configs/ls1088ardb_sdcard_qspi_defconfig | 4 +- configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 4 +- configs/ls1088ardb_tfa_defconfig | 6 +- configs/ls2080aqds_SECURE_BOOT_defconfig | 4 +- configs/ls2080aqds_defconfig | 4 +- configs/ls2080aqds_nand_defconfig | 4 +- configs/ls2080aqds_qspi_defconfig | 4 +- configs/ls2080aqds_sdcard_defconfig | 4 +- configs/ls2080ardb_SECURE_BOOT_defconfig | 4 +- configs/ls2080ardb_defconfig | 4 +- configs/ls2080ardb_nand_defconfig | 4 +- configs/ls2081ardb_defconfig | 4 +- configs/ls2088aqds_tfa_defconfig | 4 +- configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 4 +- configs/ls2088ardb_qspi_defconfig | 4 +- configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 4 +- configs/ls2088ardb_tfa_defconfig | 4 +- configs/lschlv2_defconfig | 2 - configs/lsxhl_defconfig | 2 - configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 4 +- configs/lx2160aqds_tfa_defconfig | 4 +- configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 4 +- configs/lx2160ardb_tfa_defconfig | 4 +- configs/lx2160ardb_tfa_stmm_defconfig | 4 +- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 4 +- configs/lx2162aqds_tfa_defconfig | 4 +- .../lx2162aqds_tfa_verified_boot_defconfig | 4 +- configs/m53menlo_defconfig | 1 - configs/marsboard_defconfig | 1 - configs/medcom-wide_defconfig | 1 - configs/meerkat96_defconfig | 1 - configs/miqi-rk3288_defconfig | 4 +- configs/mt7620_rfb_defconfig | 1 - configs/mt7622_rfb_defconfig | 1 - configs/mt7629_rfb_defconfig | 2 - configs/mt8183_pumpkin_defconfig | 1 - configs/mt8512_bm1_emmc_defconfig | 1 - configs/mt8516_pumpkin_defconfig | 1 - configs/mt8518_ap1_emmc_defconfig | 1 - configs/mvebu_crb_cn9130_defconfig | 2 - configs/mvebu_db-88f3720_defconfig | 2 - configs/mvebu_db_armada8k_defconfig | 2 - configs/mvebu_db_cn9130_defconfig | 2 - configs/mvebu_espressobin-88f3720_defconfig | 2 - configs/mvebu_mcbin-88f8040_defconfig | 2 - configs/mvebu_puzzle-m801-88f8040_defconfig | 2 - configs/mx23evk_defconfig | 1 - configs/mx28evk_auart_console_defconfig | 6 - configs/mx28evk_defconfig | 6 - configs/mx28evk_nand_defconfig | 6 - configs/mx28evk_spi_defconfig | 6 - configs/mx51evk_defconfig | 1 - configs/mx53cx9020_defconfig | 1 - configs/mx53loco_defconfig | 1 - configs/mx53ppd_defconfig | 1 - configs/mx6cuboxi_defconfig | 1 - configs/mx6qsabrelite_defconfig | 1 - configs/mx6sabreauto_defconfig | 5 +- configs/mx6sabresd_defconfig | 6 +- configs/mx6slevk_defconfig | 1 - configs/mx6slevk_spinor_defconfig | 1 - configs/mx6slevk_spl_defconfig | 1 - configs/mx6sllevk_defconfig | 1 - configs/mx6sllevk_plugin_defconfig | 1 - configs/mx6sxsabreauto_defconfig | 1 - configs/mx6sxsabresd_defconfig | 2 - configs/mx6ul_14x14_evk_defconfig | 1 - configs/mx6ul_9x9_evk_defconfig | 1 - configs/mx7dsabresd_defconfig | 5 +- configs/mx7dsabresd_qspi_defconfig | 5 +- configs/mx7ulp_com_defconfig | 1 - configs/myir_mys_6ulx_defconfig | 1 - configs/nanopc-t4-rk3399_defconfig | 2 +- configs/nas220_defconfig | 2 - configs/net2big_v2_defconfig | 2 - configs/netgear_dgnd3700v2_ram_defconfig | 1 - configs/netspace_lite_v2_defconfig | 2 - configs/netspace_max_v2_defconfig | 2 - configs/netspace_v2_defconfig | 2 - configs/nitrogen6dl2g_defconfig | 1 - configs/nitrogen6dl_defconfig | 1 - configs/nitrogen6q2g_defconfig | 1 - configs/nitrogen6q_defconfig | 1 - configs/nitrogen6s1g_defconfig | 1 - configs/nitrogen6s_defconfig | 1 - configs/novena_defconfig | 6 +- configs/nsa310s_defconfig | 18 +- configs/nyan-big_defconfig | 5 +- configs/o4-imx6ull-nano_defconfig | 1 - configs/octeon_ebb7304_defconfig | 2 - configs/octeon_nic23_defconfig | 1 - configs/octeontx2_95xx_defconfig | 1 - configs/octeontx2_96xx_defconfig | 2 - configs/octeontx_81xx_defconfig | 2 - configs/octeontx_83xx_defconfig | 2 - configs/odroid-c2_defconfig | 1 - configs/odroid-c4_defconfig | 1 - configs/odroid-n2_defconfig | 1 - configs/odroid-xu3_defconfig | 3 +- configs/odroid_defconfig | 5 +- configs/omap35_logic_defconfig | 1 - configs/omap35_logic_somlv_defconfig | 1 - configs/omap3_beagle_defconfig | 9 +- configs/omap3_evm_defconfig | 9 +- configs/omap3_logic_defconfig | 1 - configs/omap3_logic_somlv_defconfig | 1 - configs/omap4_panda_defconfig | 3 +- configs/omap4_sdp4430_defconfig | 1 - configs/omap5_uevm_defconfig | 5 +- configs/omapl138_lcdk_defconfig | 1 - configs/opos6uldev_defconfig | 1 - configs/origen_defconfig | 1 - configs/p212_defconfig | 1 - configs/p2371-0000_defconfig | 5 +- configs/p2371-2180_defconfig | 6 +- configs/p2571_defconfig | 5 +- configs/p2771-0000-000_defconfig | 3 - configs/p2771-0000-500_defconfig | 3 - configs/p3450-0000_defconfig | 6 +- configs/paz00_defconfig | 1 - configs/peach-pi_defconfig | 1 - configs/peach-pit_defconfig | 1 - configs/phycore-am335x-r2-regor_defconfig | 1 - configs/phycore-am335x-r2-wega_defconfig | 1 - configs/phycore-rk3288_defconfig | 4 +- configs/phycore_pcl063_defconfig | 1 - configs/phycore_pcl063_ull_defconfig | 1 - configs/pic32mzdask_defconfig | 1 - configs/pico-dwarf-imx7d_defconfig | 1 - configs/pico-hobbit-imx7d_defconfig | 1 - configs/pico-imx6_defconfig | 1 - configs/pico-imx6ul_defconfig | 1 - configs/pico-imx7d_bl33_defconfig | 1 - configs/pico-imx7d_defconfig | 1 - configs/pico-nymph-imx7d_defconfig | 1 - configs/pico-pi-imx7d_defconfig | 1 - configs/plutux_defconfig | 1 - configs/pm9261_defconfig | 3 - configs/pm9263_defconfig | 3 - configs/pm9g45_defconfig | 1 - configs/poplar_defconfig | 4 +- configs/popmetal-rk3288_defconfig | 4 +- configs/porter_defconfig | 2 - configs/qemu-ppce500_defconfig | 1 - configs/qemu_arm64_defconfig | 3 - configs/qemu_arm_defconfig | 3 - configs/r2dplus_defconfig | 1 - configs/r8a774a1_beacon_defconfig | 1 - configs/r8a774b1_beacon_defconfig | 1 - configs/r8a774e1_beacon_defconfig | 1 - configs/r8a77970_eagle_defconfig | 2 - configs/r8a77980_condor_defconfig | 2 - configs/r8a77990_ebisu_defconfig | 1 - configs/r8a77995_draak_defconfig | 1 - configs/rcar3_salvator-x_defconfig | 2 - configs/rcar3_ulcb_defconfig | 3 +- configs/riotboard_defconfig | 1 - configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rpi_0_w_defconfig | 1 - configs/rpi_2_defconfig | 1 - configs/rpi_3_32b_defconfig | 1 - configs/rpi_3_b_plus_defconfig | 1 - configs/rpi_3_defconfig | 1 - configs/rpi_4_32b_defconfig | 2 - configs/rpi_4_defconfig | 2 - configs/rpi_arm64_defconfig | 2 - configs/rpi_defconfig | 1 - configs/s400_defconfig | 1 - configs/s5pc210_universal_defconfig | 1 - configs/sama5d27_giantboard_defconfig | 1 - configs/sama5d27_som1_ek_mmc1_defconfig | 1 - configs/sama5d27_som1_ek_mmc_defconfig | 1 - configs/sama5d27_som1_ek_qspiflash_defconfig | 1 - configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 - .../sama5d27_wlsom1_ek_qspiflash_defconfig | 1 - configs/sama5d2_ptc_ek_mmc_defconfig | 1 - configs/sama5d2_ptc_ek_nandflash_defconfig | 1 - configs/sama5d2_xplained_emmc_defconfig | 1 - configs/sama5d2_xplained_mmc_defconfig | 1 - configs/sama5d2_xplained_qspiflash_defconfig | 1 - configs/sama5d2_xplained_spiflash_defconfig | 1 - configs/sama5d3_xplained_mmc_defconfig | 1 - configs/sama5d3_xplained_nandflash_defconfig | 1 - configs/sama5d3xek_mmc_defconfig | 1 - configs/sama5d3xek_nandflash_defconfig | 1 - configs/sama5d3xek_spiflash_defconfig | 1 - configs/sama5d4_xplained_mmc_defconfig | 1 - configs/sama5d4_xplained_nandflash_defconfig | 1 - configs/sama5d4_xplained_spiflash_defconfig | 1 - configs/sama5d4ek_mmc_defconfig | 1 - configs/sama5d4ek_nandflash_defconfig | 1 - configs/sama5d4ek_spiflash_defconfig | 1 - configs/sandbox64_defconfig | 2 - configs/sandbox_defconfig | 25 +- configs/sandbox_flattree_defconfig | 2 - configs/sandbox_noinst_defconfig | 2 - configs/sandbox_spl_defconfig | 2 - configs/seaboard_defconfig | 1 - configs/seeed_npi_imx6ull_defconfig | 1 - configs/sei510_defconfig | 1 - configs/sei610_defconfig | 1 - configs/sfr_nb4-ser_ram_defconfig | 1 - configs/sheevaplug_defconfig | 10 +- configs/sifive_unmatched_defconfig | 1 - configs/silinux_ek874_defconfig | 1 - configs/silk_defconfig | 2 - configs/smartweb_defconfig | 5 - configs/smdk5250_defconfig | 1 - configs/smdk5420_defconfig | 1 - configs/smdkv310_defconfig | 1 - configs/sniper_defconfig | 12 - configs/snow_defconfig | 1 - configs/socfpga_agilex_atf_defconfig | 1 - configs/socfpga_agilex_defconfig | 1 - configs/socfpga_agilex_vab_defconfig | 1 - configs/socfpga_arria10_defconfig | 1 - configs/socfpga_arria5_defconfig | 1 - configs/socfpga_cyclone5_defconfig | 1 - configs/socfpga_dbm_soc1_defconfig | 1 - configs/socfpga_de0_nano_soc_defconfig | 1 - configs/socfpga_de10_nano_defconfig | 1 - configs/socfpga_de1_soc_defconfig | 1 - configs/socfpga_mcvevk_defconfig | 1 - configs/socfpga_sockit_defconfig | 1 - configs/socfpga_socrates_defconfig | 1 - configs/socfpga_stratix10_atf_defconfig | 1 - configs/socfpga_stratix10_defconfig | 3 +- configs/socfpga_vining_fpga_defconfig | 1 - configs/socrates_defconfig | 3 - configs/somlabs_visionsom_6ull_defconfig | 1 - configs/spring_defconfig | 1 - configs/stih410-b2260_defconfig | 1 - configs/stm32mp15_basic_defconfig | 1 - configs/stm32mp15_dhcom_basic_defconfig | 5 +- configs/stm32mp15_dhcor_basic_defconfig | 5 +- configs/stm32mp15_trusted_defconfig | 1 - configs/stout_defconfig | 2 - configs/synquacer_developerbox_defconfig | 1 - configs/taurus_defconfig | 5 - configs/tbs2910_defconfig | 2 - configs/tec-ng_defconfig | 1 - configs/tec_defconfig | 1 - configs/theadorable_debug_defconfig | 3 - configs/tinker-rk3288_defconfig | 4 +- configs/tinker-s-rk3288_defconfig | 4 +- configs/tools-only_defconfig | 1 - configs/total_compute_defconfig | 1 - configs/tplink_wdr4300_defconfig | 1 - configs/trats2_defconfig | 1 - configs/trats_defconfig | 1 - configs/trimslice_defconfig | 2 - configs/turris_mox_defconfig | 2 - configs/turris_omnia_defconfig | 7 +- configs/u200_defconfig | 1 - configs/uDPU_defconfig | 2 - configs/usbarmory_defconfig | 1 - configs/variscite_dart6ul_defconfig | 1 - configs/venice2_defconfig | 5 +- configs/ventana_defconfig | 1 - configs/verdin-imx8mm_defconfig | 1 - configs/vexpress_aemv8a_juno_defconfig | 1 - configs/vinco_defconfig | 6 +- configs/vining_2000_defconfig | 6 +- configs/vocore2_defconfig | 1 - configs/vyasa-rk3288_defconfig | 6 +- configs/wandboard_defconfig | 1 - configs/warp7_bl33_defconfig | 1 - configs/warp7_defconfig | 1 - configs/warp_defconfig | 8 - configs/wetek-core2_defconfig | 1 - configs/x530_defconfig | 2 - configs/xilinx_versal_virt_defconfig | 1 - configs/xilinx_zynqmp_virt_defconfig | 4 +- configs/zmx25_defconfig | 3 - doc/board/freescale/b4860qds.rst | 453 ---------- doc/board/freescale/index.rst | 1 - doc/develop/driver-model/migration.rst | 9 - drivers/ata/ahci.c | 55 -- drivers/ata/sata_sil.c | 8 - drivers/ata/sata_sil.h | 4 - drivers/bios_emulator/atibios.c | 98 --- drivers/bios_emulator/bios.c | 39 - drivers/core/fdtaddr.c | 3 +- drivers/gpio/Kconfig | 2 +- drivers/i2c/Makefile | 2 +- drivers/net/Kconfig | 6 +- drivers/net/designware.c | 22 +- drivers/net/mscc_eswitch/Kconfig | 2 +- drivers/pci/Kconfig | 40 +- drivers/pci/Makefile | 2 - drivers/pci/pci_common.c | 4 +- drivers/pci/pci_ftpci100.c | 319 ------- drivers/pci/pci_gt64120.c | 64 -- drivers/pci/pci_indirect.c | 71 -- drivers/pci/pci_msc01.c | 64 -- drivers/pci/pcie_imx.c | 81 -- drivers/scsi/scsi.c | 6 - drivers/spi/Kconfig | 2 +- drivers/usb/host/ohci-hcd.c | 15 +- drivers/virtio/Kconfig | 2 +- include/ahci.h | 4 - include/bios_emul.h | 16 - include/config_distro_bootcmd.h | 5 - include/configs/MPC8349EMDS.h | 5 - include/configs/MPC8349EMDS_SDRAM.h | 5 - include/configs/MPC837XERDB.h | 3 - include/configs/MPC8540ADS.h | 2 - include/configs/MPC8548CDS.h | 16 - include/configs/MPC8560ADS.h | 2 - include/configs/P1010RDB.h | 28 - include/configs/P2041RDB.h | 17 - include/configs/T102xRDB.h | 17 - include/configs/T104xRDB.h | 20 - include/configs/T208xQDS.h | 20 - include/configs/T208xRDB.h | 20 - include/configs/T4240RDB.h | 21 - include/configs/UCP1020.h | 832 ------------------ include/configs/corenet_ds.h | 21 - include/configs/p1_p2_rdb_pc.h | 24 - include/configs/t4qds.h | 240 ----- include/init.h | 3 - include/pci.h | 76 +- lib/fdtdec.c | 10 +- scripts/config_whitelist.txt | 6 - test/dm/Makefile | 2 +- 735 files changed, 260 insertions(+), 6976 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc85xx/pci.c delete mode 100644 board/Arcturus/ucp1020/MAINTAINERS delete mode 100644 board/Arcturus/ucp1020/Makefile delete mode 100644 board/Arcturus/ucp1020/README delete mode 100644 board/Arcturus/ucp1020/cmd_arc.c delete mode 100644 board/Arcturus/ucp1020/ddr.c delete mode 100644 board/Arcturus/ucp1020/law.c delete mode 100644 board/Arcturus/ucp1020/spl.c delete mode 100644 board/Arcturus/ucp1020/spl_minimal.c delete mode 100644 board/Arcturus/ucp1020/tlb.c delete mode 100644 board/Arcturus/ucp1020/ucp1020.c delete mode 100644 board/Arcturus/ucp1020/ucp1020.h delete mode 100644 board/freescale/common/idt8t49n222a_serdes_clk.c delete mode 100644 board/freescale/common/idt8t49n222a_serdes_clk.h delete mode 100644 board/freescale/common/p_corenet/pci.c delete mode 100644 board/freescale/mpc837xerdb/pci.c delete mode 100644 board/freescale/t102xrdb/pci.c delete mode 100644 board/freescale/t104xrdb/pci.c delete mode 100644 board/freescale/t208xqds/pci.c delete mode 100644 board/freescale/t208xrdb/pci.c delete mode 100644 board/freescale/t4rdb/pci.c delete mode 100644 configs/UCP1020_defconfig delete mode 100644 doc/board/freescale/b4860qds.rst delete mode 100644 drivers/pci/pci_ftpci100.c delete mode 100644 drivers/pci/pci_indirect.c delete mode 100644 include/configs/UCP1020.h delete mode 100644 include/configs/t4qds.h
Rsync all defconfig files using moveconfig.py
This is to drop the use of DM_PCI in there.
configs/MPC8349EMDS_PCI64_defconfig | 1 - configs/MPC8349EMDS_SDRAM_defconfig | 1 - configs/MPC8349EMDS_SLAVE_defconfig | 1 - configs/MPC8349EMDS_defconfig | 1 - configs/MPC837XERDB_defconfig | 2 -- configs/MPC8548CDS_36BIT_defconfig | 1 - configs/MPC8548CDS_defconfig | 1 - configs/MPC8548CDS_legacy_defconfig | 1 - configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 - configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 - configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PA_NAND_defconfig | 1 - configs/P1010RDB-PA_NOR_defconfig | 1 - configs/P1010RDB-PA_SDCARD_defconfig | 1 - configs/P1010RDB-PA_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 - configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 - configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 - configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 - configs/P1010RDB-PB_NAND_defconfig | 1 - configs/P1010RDB-PB_NOR_defconfig | 1 - configs/P1010RDB-PB_SDCARD_defconfig | 1 - configs/P1010RDB-PB_SPIFLASH_defconfig | 1 - configs/P1020RDB-PC_36BIT_NAND_defconfig | 2 -- configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 2 -- configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 2 -- configs/P1020RDB-PC_36BIT_defconfig | 2 -- configs/P1020RDB-PC_NAND_defconfig | 2 -- configs/P1020RDB-PC_SDCARD_defconfig | 2 -- configs/P1020RDB-PC_SPIFLASH_defconfig | 2 -- configs/P1020RDB-PC_defconfig | 2 -- configs/P1020RDB-PD_NAND_defconfig | 2 -- configs/P1020RDB-PD_SDCARD_defconfig | 2 -- configs/P1020RDB-PD_SPIFLASH_defconfig | 2 -- configs/P1020RDB-PD_defconfig | 2 -- configs/P2020RDB-PC_36BIT_NAND_defconfig | 2 -- configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 2 -- configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 2 -- configs/P2020RDB-PC_36BIT_defconfig | 2 -- configs/P2020RDB-PC_NAND_defconfig | 2 -- configs/P2020RDB-PC_SDCARD_defconfig | 2 -- configs/P2020RDB-PC_SPIFLASH_defconfig | 2 -- configs/P2020RDB-PC_defconfig | 2 -- configs/P2041RDB_NAND_defconfig | 2 -- configs/P2041RDB_SDCARD_defconfig | 2 -- configs/P2041RDB_SPIFLASH_defconfig | 2 -- configs/P2041RDB_defconfig | 2 -- configs/P3041DS_NAND_defconfig | 2 -- configs/P3041DS_SDCARD_defconfig | 2 -- configs/P3041DS_SPIFLASH_defconfig | 2 -- configs/P3041DS_defconfig | 2 -- configs/P4080DS_SDCARD_defconfig | 2 -- configs/P4080DS_SPIFLASH_defconfig | 2 -- configs/P4080DS_defconfig | 2 -- configs/P5040DS_NAND_defconfig | 2 -- configs/P5040DS_SDCARD_defconfig | 2 -- configs/P5040DS_SPIFLASH_defconfig | 2 -- configs/P5040DS_defconfig | 2 -- configs/T1024RDB_NAND_defconfig | 2 -- configs/T1024RDB_SDCARD_defconfig | 2 -- configs/T1024RDB_SPIFLASH_defconfig | 2 -- configs/T1024RDB_defconfig | 2 -- configs/T1042D4RDB_NAND_defconfig | 2 -- configs/T1042D4RDB_SDCARD_defconfig | 2 -- configs/T1042D4RDB_SPIFLASH_defconfig | 2 -- configs/T1042D4RDB_defconfig | 2 -- configs/T2080QDS_NAND_defconfig | 4 +-- configs/T2080QDS_SDCARD_defconfig | 4 +-- configs/T2080QDS_SECURE_BOOT_defconfig | 4 +-- configs/T2080QDS_SPIFLASH_defconfig | 4 +-- configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 4 +-- configs/T2080QDS_defconfig | 4 +-- configs/T2080RDB_NAND_defconfig | 2 -- configs/T2080RDB_SDCARD_defconfig | 2 -- configs/T2080RDB_SPIFLASH_defconfig | 2 -- configs/T2080RDB_defconfig | 2 -- configs/T2080RDB_revD_NAND_defconfig | 2 -- configs/T2080RDB_revD_SDCARD_defconfig | 2 -- configs/T2080RDB_revD_SPIFLASH_defconfig | 2 -- configs/T2080RDB_revD_defconfig | 2 -- configs/T4240RDB_SDCARD_defconfig | 2 -- configs/T4240RDB_defconfig | 2 -- configs/UCP1020_defconfig | 1 - configs/alt_defconfig | 2 -- configs/am335x_baltos_defconfig | 1 - configs/am335x_boneblack_vboot_defconfig | 1 - configs/am335x_evm_defconfig | 1 - configs/am335x_evm_spiboot_defconfig | 1 - configs/am335x_guardian_defconfig | 13 +++------- configs/am335x_hs_evm_defconfig | 1 - configs/am335x_hs_evm_uart_defconfig | 1 - configs/am3517_evm_defconfig | 1 - configs/am43xx_evm_defconfig | 1 - configs/am43xx_evm_qspiboot_defconfig | 1 - configs/am43xx_evm_rtconly_defconfig | 1 - configs/am43xx_evm_usbhost_boot_defconfig | 1 - configs/am43xx_hs_evm_defconfig | 1 - configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/am57xx_hs_evm_usb_defconfig | 1 - configs/am64x_evm_a53_defconfig | 1 - configs/am64x_evm_r5_defconfig | 1 - configs/am65x_evm_a53_defconfig | 1 - configs/am65x_evm_r5_usbdfu_defconfig | 2 -- configs/am65x_evm_r5_usbmsc_defconfig | 2 -- configs/am65x_hs_evm_a53_defconfig | 1 - configs/apalis-imx8x_defconfig | 1 - configs/apalis-tk1_defconfig | 2 -- configs/apalis_imx6_defconfig | 3 +-- configs/apalis_t30_defconfig | 2 -- configs/aristainetos2c_defconfig | 2 -- configs/aristainetos2ccslb_defconfig | 2 -- configs/arndale_defconfig | 1 - configs/at91sam9260ek_dataflash_cs0_defconfig | 2 -- configs/at91sam9260ek_dataflash_cs1_defconfig | 2 -- configs/at91sam9260ek_nandflash_defconfig | 2 -- configs/at91sam9261ek_dataflash_cs0_defconfig | 2 -- configs/at91sam9261ek_dataflash_cs3_defconfig | 2 -- configs/at91sam9261ek_nandflash_defconfig | 2 -- configs/at91sam9263ek_dataflash_cs0_defconfig | 3 --- configs/at91sam9263ek_dataflash_defconfig | 3 --- configs/at91sam9263ek_nandflash_defconfig | 3 --- configs/at91sam9263ek_norflash_boot_defconfig | 3 --- configs/at91sam9263ek_norflash_defconfig | 3 --- configs/at91sam9g10ek_dataflash_cs0_defconfig | 2 -- configs/at91sam9g10ek_dataflash_cs3_defconfig | 2 -- configs/at91sam9g10ek_nandflash_defconfig | 2 -- configs/at91sam9g20ek_2mmc_defconfig | 3 --- .../at91sam9g20ek_2mmc_nandflash_defconfig | 3 --- configs/at91sam9g20ek_dataflash_cs0_defconfig | 2 -- configs/at91sam9g20ek_dataflash_cs1_defconfig | 2 -- configs/at91sam9g20ek_nandflash_defconfig | 2 -- configs/at91sam9m10g45ek_mmc_defconfig | 1 - configs/at91sam9m10g45ek_nandflash_defconfig | 1 - configs/at91sam9n12ek_mmc_defconfig | 3 --- configs/at91sam9n12ek_nandflash_defconfig | 3 --- configs/at91sam9n12ek_spiflash_defconfig | 3 --- configs/at91sam9x5ek_dataflash_defconfig | 1 - configs/at91sam9x5ek_mmc_defconfig | 1 - configs/at91sam9x5ek_nandflash_defconfig | 1 - configs/at91sam9x5ek_spiflash_defconfig | 1 - configs/at91sam9xeek_dataflash_cs0_defconfig | 2 -- configs/at91sam9xeek_dataflash_cs1_defconfig | 2 -- configs/at91sam9xeek_nandflash_defconfig | 2 -- configs/axs101_defconfig | 1 - configs/axs103_defconfig | 1 - configs/beaver_defconfig | 6 ++--- configs/beelink-gtking_defconfig | 1 - configs/beelink-gtkingpro_defconfig | 1 - configs/blanche_defconfig | 2 -- configs/boston32r2_defconfig | 1 - configs/boston32r2el_defconfig | 1 - configs/boston32r6_defconfig | 1 - configs/boston32r6el_defconfig | 1 - configs/boston64r2_defconfig | 1 - configs/boston64r2el_defconfig | 1 - configs/boston64r6_defconfig | 1 - configs/boston64r6el_defconfig | 1 - configs/brppt1_mmc_defconfig | 1 - configs/brppt1_nand_defconfig | 2 -- configs/brppt1_spi_defconfig | 1 - configs/brppt2_defconfig | 1 - configs/brsmarc1_defconfig | 1 - configs/brxre1_defconfig | 1 - configs/cardhu_defconfig | 2 -- configs/cei-tk1-som_defconfig | 6 ++--- configs/chiliboard_defconfig | 1 - configs/cl-som-imx7_defconfig | 1 - configs/clearfog_defconfig | 1 - configs/clearfog_gt_8k_defconfig | 2 -- configs/cm_fx6_defconfig | 1 - configs/cm_t43_defconfig | 1 - configs/colibri-imx6ull_defconfig | 1 - configs/colibri_imx6_defconfig | 3 +-- configs/colibri_imx7_defconfig | 1 - configs/colibri_imx7_emmc_defconfig | 1 - configs/colibri_pxa270_defconfig | 1 - configs/colibri_t20_defconfig | 5 ++-- configs/colibri_t30_defconfig | 5 ++-- configs/colibri_vf_defconfig | 1 - configs/comtrend_ar5315u_ram_defconfig | 1 - configs/comtrend_ar5387un_ram_defconfig | 1 - configs/comtrend_ct5361_ram_defconfig | 1 - configs/comtrend_vr3032u_ram_defconfig | 1 - configs/comtrend_wap5813n_ram_defconfig | 1 - configs/controlcenterdc_defconfig | 1 - configs/corvus_defconfig | 2 -- configs/d2net_v2_defconfig | 2 -- configs/da850evm_defconfig | 1 - configs/da850evm_direct_nor_defconfig | 2 -- configs/da850evm_nand_defconfig | 1 - configs/dalmore_defconfig | 5 ++-- configs/db-88f6720_defconfig | 2 -- configs/db-88f6820-amc_defconfig | 3 --- configs/db-88f6820-gp_defconfig | 2 -- configs/db-mv784mp-gp_defconfig | 3 --- configs/db-xc3-24g4xg_defconfig | 2 -- configs/devkit3250_defconfig | 3 --- configs/dh_imx6_defconfig | 1 - configs/display5_factory_defconfig | 1 - configs/dns325_defconfig | 2 -- configs/dra7xx_evm_defconfig | 1 - configs/dra7xx_hs_evm_defconfig | 1 - configs/dra7xx_hs_evm_usb_defconfig | 1 - configs/dragonboard410c_defconfig | 9 +++---- configs/dreamplug_defconfig | 2 -- configs/ds109_defconfig | 2 -- configs/ds414_defconfig | 2 -- configs/durian_defconfig | 1 - configs/edison_defconfig | 2 +- configs/edminiv2_defconfig | 3 --- configs/ethernut5_defconfig | 1 - configs/ev-imx280-nano-x-mb_defconfig | 1 - configs/firefly-rk3288_defconfig | 4 +-- configs/ge_b1x5v2_defconfig | 1 - configs/ge_bx50v3_defconfig | 1 - configs/goflexhome_defconfig | 2 -- configs/gose_defconfig | 2 -- configs/grpeach_defconfig | 2 -- configs/guruplug_defconfig | 2 -- configs/gwventana_emmc_defconfig | 9 +++---- configs/gwventana_gw5904_defconfig | 9 +++---- configs/gwventana_nand_defconfig | 9 +++---- configs/harmony_defconfig | 2 -- configs/helios4_defconfig | 1 - configs/hihope_rzg2_defconfig | 1 - configs/hikey_defconfig | 1 - configs/hsdk_defconfig | 1 - configs/huawei_hg556a_ram_defconfig | 1 - configs/imx6q_logic_defconfig | 1 - configs/imx7_cm_defconfig | 1 - configs/imx8mm-cl-iot-gate_defconfig | 5 ++-- configs/imx8mn_beacon_2g_defconfig | 1 - configs/imx8mn_beacon_defconfig | 1 - configs/imx8mq_evk_defconfig | 8 +++--- configs/imxrt1050-evk_defconfig | 1 - configs/inetspace_v2_defconfig | 2 -- configs/iot_devkit_defconfig | 1 - configs/j7200_evm_a72_defconfig | 1 - configs/j7200_evm_r5_defconfig | 5 ++-- configs/j721e_evm_a72_defconfig | 1 - configs/j721e_evm_r5_defconfig | 1 - configs/j721e_hs_evm_a72_defconfig | 1 - configs/jetson-tk1_defconfig | 6 ++--- configs/k2e_evm_defconfig | 1 - configs/k2e_hs_evm_defconfig | 1 - configs/k2g_evm_defconfig | 1 - configs/k2g_hs_evm_defconfig | 1 - configs/k2hk_evm_defconfig | 1 - configs/k2hk_hs_evm_defconfig | 1 - configs/k2l_evm_defconfig | 1 - configs/k2l_hs_evm_defconfig | 1 - configs/khadas-vim2_defconfig | 1 - configs/khadas-vim3_defconfig | 1 - configs/khadas-vim3l_defconfig | 1 - configs/khadas-vim_defconfig | 1 - configs/kmcent2_defconfig | 1 - configs/koelsch_defconfig | 2 -- configs/kylin-rk3036_defconfig | 4 +-- configs/lager_defconfig | 2 -- configs/libretech-ac_defconfig | 1 - configs/libretech-cc_defconfig | 1 - configs/libretech-cc_v2_defconfig | 1 - configs/libretech-s905d-pc_defconfig | 1 - configs/libretech-s912-pc_defconfig | 1 - configs/linkit-smart-7688_defconfig | 2 -- configs/liteboard_defconfig | 1 - configs/ls1012a2g5rdb_qspi_defconfig | 1 - configs/ls1012a2g5rdb_tfa_defconfig | 1 - configs/ls1012afrdm_qspi_defconfig | 3 --- configs/ls1012afrdm_tfa_defconfig | 3 --- .../ls1012afrwy_qspi_SECURE_BOOT_defconfig | 2 -- configs/ls1012afrwy_qspi_defconfig | 2 -- configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig | 2 -- configs/ls1012afrwy_tfa_defconfig | 2 -- configs/ls1012aqds_qspi_defconfig | 2 -- configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 2 -- configs/ls1012aqds_tfa_defconfig | 2 -- configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 2 -- configs/ls1012ardb_qspi_defconfig | 2 -- configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 2 -- configs/ls1012ardb_tfa_defconfig | 2 -- configs/ls1021aiot_qspi_defconfig | 2 -- configs/ls1021aiot_sdcard_defconfig | 1 - configs/ls1021aqds_ddr4_nor_defconfig | 4 +-- configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 4 +-- configs/ls1021aqds_nand_defconfig | 4 +-- configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 4 +-- configs/ls1021aqds_nor_defconfig | 4 +-- configs/ls1021aqds_nor_lpuart_defconfig | 4 +-- configs/ls1021aqds_qspi_defconfig | 4 +-- configs/ls1021aqds_sdcard_ifc_defconfig | 4 +-- configs/ls1021aqds_sdcard_qspi_defconfig | 4 +-- configs/ls1021atsn_qspi_defconfig | 2 -- configs/ls1021atsn_sdcard_defconfig | 2 -- configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 2 -- configs/ls1021atwr_nor_defconfig | 2 -- configs/ls1021atwr_nor_lpuart_defconfig | 2 -- configs/ls1021atwr_qspi_defconfig | 2 -- ...s1021atwr_sdcard_ifc_SECURE_BOOT_defconfig | 2 -- configs/ls1021atwr_sdcard_ifc_defconfig | 2 -- configs/ls1021atwr_sdcard_qspi_defconfig | 2 -- configs/ls1028aqds_tfa_SECURE_BOOT_defconfig | 2 -- configs/ls1028aqds_tfa_defconfig | 2 -- configs/ls1028aqds_tfa_lpuart_defconfig | 2 -- configs/ls1028ardb_tfa_SECURE_BOOT_defconfig | 2 -- configs/ls1028ardb_tfa_defconfig | 2 -- configs/ls1043aqds_defconfig | 4 +-- configs/ls1043aqds_lpuart_defconfig | 4 +-- configs/ls1043aqds_nand_defconfig | 4 +-- configs/ls1043aqds_nor_ddr3_defconfig | 4 +-- configs/ls1043aqds_qspi_defconfig | 4 +-- configs/ls1043aqds_sdcard_ifc_defconfig | 4 +-- configs/ls1043aqds_sdcard_qspi_defconfig | 4 +-- configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 4 +-- configs/ls1043aqds_tfa_defconfig | 4 +-- configs/ls1043ardb_SECURE_BOOT_defconfig | 2 -- configs/ls1043ardb_defconfig | 2 -- configs/ls1043ardb_nand_SECURE_BOOT_defconfig | 2 -- configs/ls1043ardb_nand_defconfig | 2 -- .../ls1043ardb_sdcard_SECURE_BOOT_defconfig | 2 -- configs/ls1043ardb_sdcard_defconfig | 2 -- configs/ls1043ardb_tfa_SECURE_BOOT_defconfig | 2 -- configs/ls1043ardb_tfa_defconfig | 2 -- configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig | 4 +-- configs/ls1046afrwy_tfa_defconfig | 4 +-- configs/ls1046aqds_SECURE_BOOT_defconfig | 4 +-- configs/ls1046aqds_defconfig | 4 +-- configs/ls1046aqds_lpuart_defconfig | 4 +-- configs/ls1046aqds_nand_defconfig | 4 +-- configs/ls1046aqds_qspi_defconfig | 4 +-- configs/ls1046aqds_sdcard_ifc_defconfig | 4 +-- configs/ls1046aqds_sdcard_qspi_defconfig | 4 +-- configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 4 +-- configs/ls1046aqds_tfa_defconfig | 4 +-- configs/ls1046ardb_emmc_defconfig | 2 -- configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 2 -- configs/ls1046ardb_qspi_defconfig | 2 -- configs/ls1046ardb_qspi_spl_defconfig | 2 -- .../ls1046ardb_sdcard_SECURE_BOOT_defconfig | 2 -- configs/ls1046ardb_sdcard_defconfig | 2 -- configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 2 -- configs/ls1046ardb_tfa_defconfig | 2 -- configs/ls1088aqds_defconfig | 4 +-- configs/ls1088aqds_qspi_SECURE_BOOT_defconfig | 4 +-- configs/ls1088aqds_qspi_defconfig | 4 +-- configs/ls1088aqds_sdcard_ifc_defconfig | 4 +-- configs/ls1088aqds_sdcard_qspi_defconfig | 4 +-- configs/ls1088aqds_tfa_defconfig | 4 +-- configs/ls1088ardb_qspi_SECURE_BOOT_defconfig | 4 +-- configs/ls1088ardb_qspi_defconfig | 4 +-- ...1088ardb_sdcard_qspi_SECURE_BOOT_defconfig | 4 +-- configs/ls1088ardb_sdcard_qspi_defconfig | 4 +-- configs/ls1088ardb_tfa_SECURE_BOOT_defconfig | 4 +-- configs/ls1088ardb_tfa_defconfig | 6 ++--- configs/ls2080aqds_SECURE_BOOT_defconfig | 4 +-- configs/ls2080aqds_defconfig | 4 +-- configs/ls2080aqds_nand_defconfig | 4 +-- configs/ls2080aqds_qspi_defconfig | 4 +-- configs/ls2080aqds_sdcard_defconfig | 4 +-- configs/ls2080ardb_SECURE_BOOT_defconfig | 4 +-- configs/ls2080ardb_defconfig | 4 +-- configs/ls2080ardb_nand_defconfig | 4 +-- configs/ls2081ardb_defconfig | 4 +-- configs/ls2088aqds_tfa_defconfig | 4 +-- configs/ls2088ardb_qspi_SECURE_BOOT_defconfig | 4 +-- configs/ls2088ardb_qspi_defconfig | 4 +-- configs/ls2088ardb_tfa_SECURE_BOOT_defconfig | 4 +-- configs/ls2088ardb_tfa_defconfig | 4 +-- configs/lschlv2_defconfig | 2 -- configs/lsxhl_defconfig | 2 -- configs/lx2160aqds_tfa_SECURE_BOOT_defconfig | 4 +-- configs/lx2160aqds_tfa_defconfig | 4 +-- configs/lx2160ardb_tfa_SECURE_BOOT_defconfig | 4 +-- configs/lx2160ardb_tfa_defconfig | 4 +-- configs/lx2160ardb_tfa_stmm_defconfig | 4 +-- configs/lx2162aqds_tfa_SECURE_BOOT_defconfig | 4 +-- configs/lx2162aqds_tfa_defconfig | 4 +-- .../lx2162aqds_tfa_verified_boot_defconfig | 4 +-- configs/m53menlo_defconfig | 1 - configs/marsboard_defconfig | 1 - configs/medcom-wide_defconfig | 1 - configs/meerkat96_defconfig | 1 - configs/miqi-rk3288_defconfig | 4 +-- configs/mt7620_rfb_defconfig | 1 - configs/mt7622_rfb_defconfig | 1 - configs/mt7629_rfb_defconfig | 2 -- configs/mt8183_pumpkin_defconfig | 1 - configs/mt8512_bm1_emmc_defconfig | 1 - configs/mt8516_pumpkin_defconfig | 1 - configs/mt8518_ap1_emmc_defconfig | 1 - configs/mvebu_crb_cn9130_defconfig | 2 -- configs/mvebu_db-88f3720_defconfig | 2 -- configs/mvebu_db_armada8k_defconfig | 2 -- configs/mvebu_db_cn9130_defconfig | 2 -- configs/mvebu_espressobin-88f3720_defconfig | 2 -- configs/mvebu_mcbin-88f8040_defconfig | 2 -- configs/mvebu_puzzle-m801-88f8040_defconfig | 2 -- configs/mx23evk_defconfig | 1 - configs/mx28evk_auart_console_defconfig | 6 ----- configs/mx28evk_defconfig | 6 ----- configs/mx28evk_nand_defconfig | 6 ----- configs/mx28evk_spi_defconfig | 6 ----- configs/mx51evk_defconfig | 1 - configs/mx53cx9020_defconfig | 1 - configs/mx53loco_defconfig | 1 - configs/mx53ppd_defconfig | 1 - configs/mx6cuboxi_defconfig | 1 - configs/mx6qsabrelite_defconfig | 1 - configs/mx6sabreauto_defconfig | 5 ++-- configs/mx6sabresd_defconfig | 6 ++--- configs/mx6slevk_defconfig | 1 - configs/mx6slevk_spinor_defconfig | 1 - configs/mx6slevk_spl_defconfig | 1 - configs/mx6sllevk_defconfig | 1 - configs/mx6sllevk_plugin_defconfig | 1 - configs/mx6sxsabreauto_defconfig | 1 - configs/mx6sxsabresd_defconfig | 2 -- configs/mx6ul_14x14_evk_defconfig | 1 - configs/mx6ul_9x9_evk_defconfig | 1 - configs/mx7dsabresd_defconfig | 5 ++-- configs/mx7dsabresd_qspi_defconfig | 5 ++-- configs/mx7ulp_com_defconfig | 1 - configs/myir_mys_6ulx_defconfig | 1 - configs/nanopc-t4-rk3399_defconfig | 2 +- configs/nas220_defconfig | 2 -- configs/net2big_v2_defconfig | 2 -- configs/netgear_dgnd3700v2_ram_defconfig | 1 - configs/netspace_lite_v2_defconfig | 2 -- configs/netspace_max_v2_defconfig | 2 -- configs/netspace_v2_defconfig | 2 -- configs/nitrogen6dl2g_defconfig | 1 - configs/nitrogen6dl_defconfig | 1 - configs/nitrogen6q2g_defconfig | 1 - configs/nitrogen6q_defconfig | 1 - configs/nitrogen6s1g_defconfig | 1 - configs/nitrogen6s_defconfig | 1 - configs/novena_defconfig | 6 ++--- configs/nsa310s_defconfig | 18 ++++++------- configs/nyan-big_defconfig | 5 ++-- configs/o4-imx6ull-nano_defconfig | 1 - configs/octeon_ebb7304_defconfig | 2 -- configs/octeon_nic23_defconfig | 1 - configs/octeontx2_95xx_defconfig | 1 - configs/octeontx2_96xx_defconfig | 2 -- configs/octeontx_81xx_defconfig | 2 -- configs/octeontx_83xx_defconfig | 2 -- configs/odroid-c2_defconfig | 1 - configs/odroid-c4_defconfig | 1 - configs/odroid-n2_defconfig | 1 - configs/odroid-xu3_defconfig | 3 +-- configs/odroid_defconfig | 5 ++-- configs/omap35_logic_defconfig | 1 - configs/omap35_logic_somlv_defconfig | 1 - configs/omap3_beagle_defconfig | 9 +++---- configs/omap3_evm_defconfig | 9 +++---- configs/omap3_logic_defconfig | 1 - configs/omap3_logic_somlv_defconfig | 1 - configs/omap4_panda_defconfig | 3 +-- configs/omap4_sdp4430_defconfig | 1 - configs/omap5_uevm_defconfig | 5 ++-- configs/omapl138_lcdk_defconfig | 1 - configs/opos6uldev_defconfig | 1 - configs/origen_defconfig | 1 - configs/p212_defconfig | 1 - configs/p2371-0000_defconfig | 5 ++-- configs/p2371-2180_defconfig | 6 ++--- configs/p2571_defconfig | 5 ++-- configs/p2771-0000-000_defconfig | 3 --- configs/p2771-0000-500_defconfig | 3 --- configs/p3450-0000_defconfig | 6 ++--- configs/paz00_defconfig | 1 - configs/peach-pi_defconfig | 1 - configs/peach-pit_defconfig | 1 - configs/phycore-am335x-r2-regor_defconfig | 1 - configs/phycore-am335x-r2-wega_defconfig | 1 - configs/phycore-rk3288_defconfig | 4 +-- configs/phycore_pcl063_defconfig | 1 - configs/phycore_pcl063_ull_defconfig | 1 - configs/pic32mzdask_defconfig | 1 - configs/pico-dwarf-imx7d_defconfig | 1 - configs/pico-hobbit-imx7d_defconfig | 1 - configs/pico-imx6_defconfig | 1 - configs/pico-imx6ul_defconfig | 1 - configs/pico-imx7d_bl33_defconfig | 1 - configs/pico-imx7d_defconfig | 1 - configs/pico-nymph-imx7d_defconfig | 1 - configs/pico-pi-imx7d_defconfig | 1 - configs/plutux_defconfig | 1 - configs/pm9261_defconfig | 3 --- configs/pm9263_defconfig | 3 --- configs/pm9g45_defconfig | 1 - configs/poplar_defconfig | 4 +-- configs/popmetal-rk3288_defconfig | 4 +-- configs/porter_defconfig | 2 -- configs/qemu-ppce500_defconfig | 1 - configs/qemu_arm64_defconfig | 3 --- configs/qemu_arm_defconfig | 3 --- configs/r2dplus_defconfig | 1 - configs/r8a774a1_beacon_defconfig | 1 - configs/r8a774b1_beacon_defconfig | 1 - configs/r8a774e1_beacon_defconfig | 1 - configs/r8a77970_eagle_defconfig | 2 -- configs/r8a77980_condor_defconfig | 2 -- configs/r8a77990_ebisu_defconfig | 1 - configs/r8a77995_draak_defconfig | 1 - configs/rcar3_salvator-x_defconfig | 2 -- configs/rcar3_ulcb_defconfig | 3 +-- configs/riotboard_defconfig | 1 - configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rpi_0_w_defconfig | 1 - configs/rpi_2_defconfig | 1 - configs/rpi_3_32b_defconfig | 1 - configs/rpi_3_b_plus_defconfig | 1 - configs/rpi_3_defconfig | 1 - configs/rpi_4_32b_defconfig | 2 -- configs/rpi_4_defconfig | 2 -- configs/rpi_arm64_defconfig | 2 -- configs/rpi_defconfig | 1 - configs/s400_defconfig | 1 - configs/s5pc210_universal_defconfig | 1 - configs/sama5d27_giantboard_defconfig | 1 - configs/sama5d27_som1_ek_mmc1_defconfig | 1 - configs/sama5d27_som1_ek_mmc_defconfig | 1 - configs/sama5d27_som1_ek_qspiflash_defconfig | 1 - configs/sama5d27_wlsom1_ek_mmc_defconfig | 1 - .../sama5d27_wlsom1_ek_qspiflash_defconfig | 1 - configs/sama5d2_ptc_ek_mmc_defconfig | 1 - configs/sama5d2_ptc_ek_nandflash_defconfig | 1 - configs/sama5d2_xplained_emmc_defconfig | 1 - configs/sama5d2_xplained_mmc_defconfig | 1 - configs/sama5d2_xplained_qspiflash_defconfig | 1 - configs/sama5d2_xplained_spiflash_defconfig | 1 - configs/sama5d3_xplained_mmc_defconfig | 1 - configs/sama5d3_xplained_nandflash_defconfig | 1 - configs/sama5d3xek_mmc_defconfig | 1 - configs/sama5d3xek_nandflash_defconfig | 1 - configs/sama5d3xek_spiflash_defconfig | 1 - configs/sama5d4_xplained_mmc_defconfig | 1 - configs/sama5d4_xplained_nandflash_defconfig | 1 - configs/sama5d4_xplained_spiflash_defconfig | 1 - configs/sama5d4ek_mmc_defconfig | 1 - configs/sama5d4ek_nandflash_defconfig | 1 - configs/sama5d4ek_spiflash_defconfig | 1 - configs/sandbox64_defconfig | 2 -- configs/sandbox_defconfig | 25 ++++++++----------- configs/sandbox_flattree_defconfig | 2 -- configs/sandbox_noinst_defconfig | 2 -- configs/sandbox_spl_defconfig | 2 -- configs/seaboard_defconfig | 1 - configs/seeed_npi_imx6ull_defconfig | 1 - configs/sei510_defconfig | 1 - configs/sei610_defconfig | 1 - configs/sfr_nb4-ser_ram_defconfig | 1 - configs/sheevaplug_defconfig | 10 +++----- configs/sifive_unmatched_defconfig | 1 - configs/silinux_ek874_defconfig | 1 - configs/silk_defconfig | 2 -- configs/smartweb_defconfig | 5 ---- configs/smdk5250_defconfig | 1 - configs/smdk5420_defconfig | 1 - configs/smdkv310_defconfig | 1 - configs/sniper_defconfig | 12 --------- configs/snow_defconfig | 1 - configs/socfpga_agilex_atf_defconfig | 1 - configs/socfpga_agilex_defconfig | 1 - configs/socfpga_agilex_vab_defconfig | 1 - configs/socfpga_arria10_defconfig | 1 - configs/socfpga_arria5_defconfig | 1 - configs/socfpga_cyclone5_defconfig | 1 - configs/socfpga_dbm_soc1_defconfig | 1 - configs/socfpga_de0_nano_soc_defconfig | 1 - configs/socfpga_de10_nano_defconfig | 1 - configs/socfpga_de1_soc_defconfig | 1 - configs/socfpga_mcvevk_defconfig | 1 - configs/socfpga_sockit_defconfig | 1 - configs/socfpga_socrates_defconfig | 1 - configs/socfpga_stratix10_atf_defconfig | 1 - configs/socfpga_stratix10_defconfig | 3 +-- configs/socfpga_vining_fpga_defconfig | 1 - configs/socrates_defconfig | 3 --- configs/somlabs_visionsom_6ull_defconfig | 1 - configs/spring_defconfig | 1 - configs/stih410-b2260_defconfig | 1 - configs/stm32mp15_basic_defconfig | 1 - configs/stm32mp15_dhcom_basic_defconfig | 5 ++-- configs/stm32mp15_dhcor_basic_defconfig | 5 ++-- configs/stm32mp15_trusted_defconfig | 1 - configs/stout_defconfig | 2 -- configs/synquacer_developerbox_defconfig | 1 - configs/taurus_defconfig | 5 ---- configs/tbs2910_defconfig | 2 -- configs/tec-ng_defconfig | 1 - configs/tec_defconfig | 1 - configs/theadorable_debug_defconfig | 3 --- configs/tinker-rk3288_defconfig | 4 +-- configs/tinker-s-rk3288_defconfig | 4 +-- configs/tools-only_defconfig | 1 - configs/total_compute_defconfig | 1 - configs/tplink_wdr4300_defconfig | 1 - configs/trats2_defconfig | 1 - configs/trats_defconfig | 1 - configs/trimslice_defconfig | 2 -- configs/turris_mox_defconfig | 2 -- configs/turris_omnia_defconfig | 7 +++--- configs/u200_defconfig | 1 - configs/uDPU_defconfig | 2 -- configs/usbarmory_defconfig | 1 - configs/variscite_dart6ul_defconfig | 1 - configs/venice2_defconfig | 5 ++-- configs/ventana_defconfig | 1 - configs/verdin-imx8mm_defconfig | 1 - configs/vexpress_aemv8a_juno_defconfig | 1 - configs/vinco_defconfig | 6 ++--- configs/vining_2000_defconfig | 6 ++--- configs/vocore2_defconfig | 1 - configs/vyasa-rk3288_defconfig | 6 ++--- configs/wandboard_defconfig | 1 - configs/warp7_bl33_defconfig | 1 - configs/warp7_defconfig | 1 - configs/warp_defconfig | 8 ------ configs/wetek-core2_defconfig | 1 - configs/x530_defconfig | 2 -- configs/xilinx_versal_virt_defconfig | 1 - configs/xilinx_zynqmp_virt_defconfig | 4 +-- configs/zmx25_defconfig | 3 --- 630 files changed, 205 insertions(+), 1191 deletions(-)
diff --git a/configs/MPC8349EMDS_PCI64_defconfig b/configs/MPC8349EMDS_PCI64_defconfig index ad41da03bf7..8652ff2adcc 100644 --- a/configs/MPC8349EMDS_PCI64_defconfig +++ b/configs/MPC8349EMDS_PCI64_defconfig @@ -113,6 +113,5 @@ CONFIG_PHY_REALTEK=y CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_TSEC_ENET=y -# CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349EMDS_SDRAM_defconfig b/configs/MPC8349EMDS_SDRAM_defconfig index 650d42dd1fb..a79fb0e2b47 100644 --- a/configs/MPC8349EMDS_SDRAM_defconfig +++ b/configs/MPC8349EMDS_SDRAM_defconfig @@ -123,7 +123,6 @@ CONFIG_PHY_REALTEK=y CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_TSEC_ENET=y -# CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349EMDS_SLAVE_defconfig b/configs/MPC8349EMDS_SLAVE_defconfig index 944b0517a51..2b7d2fd43fc 100644 --- a/configs/MPC8349EMDS_SLAVE_defconfig +++ b/configs/MPC8349EMDS_SLAVE_defconfig @@ -113,6 +113,5 @@ CONFIG_PHY_REALTEK=y CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_TSEC_ENET=y -# CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index 191b11f64b8..d8c7951385f 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -115,7 +115,6 @@ CONFIG_PHY_REALTEK=y CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_TSEC_ENET=y -# CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index 446d5948da3..7106fd15f65 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -180,8 +180,6 @@ CONFIG_DM_ETH_PHY=y CONFIG_RGMII=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index c88c4798f91..72ec1e0f77a 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -42,7 +42,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_CONS_INDEX=2 diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 8cd9019552e..9db54768fb5 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -41,7 +41,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_CONS_INDEX=2 diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 3112c4e1360..83f7382e916 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -41,7 +41,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_CONS_INDEX=2 diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 91a3b9de9f0..d75eab8f635 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -76,7 +76,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 1e9d40994ad..34d2dbbb813 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -58,7 +58,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 43ca53213cf..584cae5ed16 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -70,7 +70,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 116893bf441..749be89dca0 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -72,7 +72,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index ffb402fe238..1c8fe09a661 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -75,7 +75,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 98c7d032c07..baa245a9883 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -57,7 +57,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index e4febfb9117..030093226da 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -69,7 +69,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index a32de2c826c..d44885655f1 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -71,7 +71,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 1627f8a335a..16282b07a09 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -76,7 +76,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 5749acc4fbc..8f149181030 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -58,7 +58,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 5884167b96c..9004c44ae01 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -70,7 +70,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 2228e6f3914..88c22c0f7cf 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -72,7 +72,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 07b739968e9..42169ec5ff1 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -75,7 +75,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index bc0ab873f5b..a1c6fbf4d4f 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -57,7 +57,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index adc3d40e463..641e6a76c8f 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -69,7 +69,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index 1561475d4a2..4d689df17e5 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -71,7 +71,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index d989d66e9c7..e01025f031e 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -76,7 +76,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -84,6 +83,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index 41d96c451e7..1d5c4fef600 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -71,7 +71,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -79,6 +78,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 616e5f1ea3e..6f31dac2aa1 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -73,7 +73,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -81,6 +80,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 052b5330480..86b36bcd3ba 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -60,7 +60,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -68,6 +67,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 3e58c95ddae..0d4a2964dab 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -75,7 +75,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -83,5 +82,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 9716ed17652..eba19066b84 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -70,7 +70,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -78,5 +77,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index ab33fde94cd..12fd335da5e 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -72,7 +72,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -80,5 +79,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 2e1b3003fb5..1af1d2cae92 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -59,7 +59,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -67,5 +66,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index e996e9e23f7..f393caf5df4 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -79,7 +79,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -87,5 +86,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index e92e0ca8467..3d469a3909a 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -74,7 +74,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -82,5 +81,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index c1d333deb0f..bec1b90e5ea 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -76,7 +76,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -84,5 +83,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 55357cd76b9..bcc00dc84d6 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -63,7 +63,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -71,5 +70,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index fc4a6a69346..e0c64f0d82e 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -81,7 +81,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -89,6 +88,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index 3d4d6bdacd7..d07fa39445a 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -76,7 +76,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -84,6 +83,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index 4b6288cf33a..ef8cb68dbcd 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -78,7 +78,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -86,6 +85,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index fc3ac6b47d1..3f9c9f3357a 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -65,7 +65,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -73,6 +72,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index f2335b5606a..f674b39f03b 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -80,7 +80,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -88,5 +87,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index d4614dc9235..e9793db27c1 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -75,7 +75,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -83,4 +82,3 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index defcf550603..eb61686eebc 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -77,7 +77,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -85,5 +84,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index dd344e56e14..cd9d8dad871 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -64,7 +64,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -72,5 +71,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index 1eda09747d1..40d4c78a69b 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -55,7 +55,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y CONFIG_SYS_NS16550=y @@ -63,7 +62,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 171859fe840..55766d1efe7 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -54,7 +54,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y CONFIG_SYS_NS16550=y @@ -62,7 +61,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 1fb6b434617..1e0711e9c35 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -55,7 +55,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y CONFIG_SYS_NS16550=y @@ -63,7 +62,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index c6cf2d5b8dc..224ae422d1e 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -53,7 +53,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y CONFIG_SYS_NS16550=y @@ -61,7 +60,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index 9c9ab0d711c..20ab931d3e6 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -52,7 +52,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y @@ -61,7 +60,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 7a59d0d858e..87ed18dc518 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -51,7 +51,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -60,7 +59,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 3ae8ea62fa4..48ca8b731d5 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -52,7 +52,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -61,7 +60,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 87341865a2d..4369f404a55 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -50,7 +50,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -59,7 +58,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 6646e594e57..97ef317b07f 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -50,7 +50,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -59,7 +58,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 0290987e57a..6447124c6e0 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -51,7 +51,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -60,7 +59,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index 16bc7223b3e..f6c43bcd290 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -49,7 +49,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -58,7 +57,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 86c14b6efbc..1a55f498b94 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -53,7 +53,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y @@ -62,7 +61,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index d8bab748459..85c8da15376 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -51,7 +51,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -60,7 +59,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index f2b5d74c286..48020df78cf 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -52,7 +52,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -61,7 +60,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 331579aca30..2be7c7769e4 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -50,7 +50,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -59,7 +58,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 6aab6364503..92882046d94 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -76,7 +76,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y CONFIG_DM_RTC=y @@ -85,7 +84,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 2fdc62d796b..5f7511db4c7 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -73,7 +73,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y CONFIG_DM_RTC=y @@ -82,7 +81,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 3f6b6c02e3f..e49da1021f7 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -75,7 +75,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y CONFIG_DM_RTC=y @@ -84,7 +83,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 087ea28c885..3533b78ba23 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -61,7 +61,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y CONFIG_DM_RTC=y @@ -70,7 +69,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 72c7a6ba0db..7fee6608c4f 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -72,7 +72,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y CONFIG_DM_RTC=y @@ -81,7 +80,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 2d08dd27b0a..8df9d7e9898 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -69,7 +69,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y CONFIG_DM_RTC=y @@ -78,7 +77,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index e0e3f40983a..b80fb9aba8b 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -71,7 +71,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y CONFIG_DM_RTC=y @@ -80,7 +79,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 16bc071e3d4..cf6c264f8f9 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -57,7 +57,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y CONFIG_DM_RTC=y @@ -66,7 +65,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index b06117bda2d..170400a3b37 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x140000 CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_SPL_TEXT_BASE=0xFFFD8000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y @@ -70,7 +71,6 @@ CONFIG_PHY_VITESSE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y @@ -79,8 +79,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 7c4ba2f53cb..b11da8ebfc9 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x100000 CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_SPL_TEXT_BASE=0xFFFD8000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y @@ -67,7 +68,6 @@ CONFIG_PHY_VITESSE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -76,8 +76,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index f8f031f7787..739fbf8d70d 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DEFAULT_DEVICE_TREE="t2080qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -54,7 +55,6 @@ CONFIG_PHY_VITESSE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -63,11 +63,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 2230e214d40..c1ee34df02d 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_OFFSET=0x100000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DEFAULT_DEVICE_TREE="t2080qds" CONFIG_SPL_TEXT_BASE=0xFFFD8000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y @@ -69,7 +70,6 @@ CONFIG_PHY_VITESSE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -78,8 +78,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 9ab1cdfe8ca..c7bc3ecf7a3 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_SYS_TEXT_BASE=0xFFF40000 CONFIG_ENV_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="t2080qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -47,7 +48,6 @@ CONFIG_PHY_VITESSE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_REMOTE=y @@ -56,8 +56,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index 1cbc9474546..f92a4573bf1 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -3,6 +3,7 @@ CONFIG_SYS_TEXT_BASE=0xEFF40000 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DEFAULT_DEVICE_TREE="t2080qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_MPC85xx=y CONFIG_TARGET_T2080QDS=y CONFIG_MPC85XX_HAVE_RESET_VECTOR=y @@ -55,7 +56,6 @@ CONFIG_PHY_VITESSE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -64,8 +64,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index dea81a12133..13ec9d5328b 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -75,7 +75,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y CONFIG_DM_RTC=y @@ -85,7 +84,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index c59da1b25df..6b032d25b25 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -72,7 +72,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y CONFIG_DM_RTC=y @@ -82,7 +81,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 7b296dbec17..b65067ab027 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -74,7 +74,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y CONFIG_DM_RTC=y @@ -84,7 +83,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index b7facfea5a9..24e927c7350 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -59,7 +59,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y CONFIG_DM_RTC=y @@ -69,7 +68,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080RDB_revD_NAND_defconfig b/configs/T2080RDB_revD_NAND_defconfig index 9284616c528..1b383fd7ebd 100644 --- a/configs/T2080RDB_revD_NAND_defconfig +++ b/configs/T2080RDB_revD_NAND_defconfig @@ -76,7 +76,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y @@ -87,7 +86,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080RDB_revD_SDCARD_defconfig b/configs/T2080RDB_revD_SDCARD_defconfig index c6634795883..7026256f1f9 100644 --- a/configs/T2080RDB_revD_SDCARD_defconfig +++ b/configs/T2080RDB_revD_SDCARD_defconfig @@ -73,7 +73,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -84,7 +83,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080RDB_revD_SPIFLASH_defconfig b/configs/T2080RDB_revD_SPIFLASH_defconfig index 4c6879b7a5d..650158b2343 100644 --- a/configs/T2080RDB_revD_SPIFLASH_defconfig +++ b/configs/T2080RDB_revD_SPIFLASH_defconfig @@ -75,7 +75,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -86,7 +85,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T2080RDB_revD_defconfig b/configs/T2080RDB_revD_defconfig index 79397ab30a8..2ecbabf99ec 100644 --- a/configs/T2080RDB_revD_defconfig +++ b/configs/T2080RDB_revD_defconfig @@ -60,7 +60,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -71,7 +70,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index f2a4bef038f..76c7906c165 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -65,7 +65,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -74,7 +73,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index b931eb025f5..abb2137d91e 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -53,7 +53,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_FSL=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -62,7 +61,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_ESPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_ADDR_MAP=y CONFIG_SYS_NUM_ADDR_MAP=64 diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index a016a855937..1fdb1952c8f 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -53,7 +53,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y -# CONFIG_PCI is not set CONFIG_SYS_NS16550=y CONFIG_FS_CRAMFS=y CONFIG_OF_LIBFDT=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 3025c13d1dc..216adf6777e 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -79,7 +79,6 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -92,7 +91,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 7b09214597f..26c73d96ae7 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -68,7 +68,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_DSPS=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index a0baeec79ed..3ffc4a9a40f 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -64,7 +64,6 @@ CONFIG_OMAP3_SPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index a33efff42a7..c48be6bde14 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -75,7 +75,6 @@ CONFIG_OMAP3_SPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 8f0c330674a..b106141eafd 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -74,7 +74,6 @@ CONFIG_OMAP3_SPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 8ae5c678ae2..3921aac4bd4 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -1,14 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y -# CONFIG_SPL_GPIO_SUPPORT is not set CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MEMTEST_START=0x80000000 +CONFIG_SYS_MEMTEST_END=0x81000000 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x500000 CONFIG_DEFAULT_DEVICE_TREE="am335x-guardian" -CONFIG_SYS_MEMTEST_START=0x80000000 -CONFIG_SYS_MEMTEST_END=0x81000000 CONFIG_AM33XX=y CONFIG_TARGET_AM335X_GUARDIAN=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -24,7 +23,6 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " -CONFIG_CONSOLE_MUX=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_ARCH_MISC_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set @@ -42,12 +40,10 @@ CONFIG_SPL_NET_VCI_STRING="Guardian U-Boot SPL" CONFIG_SPL_POWER_SUPPORT=y CONFIG_SPL_USB_GADGET=y CONFIG_SPL_USB_ETHER=y -# CONFIG_CMD_SPL is not set -CONFIG_CMD_SPL_NAND_OFS=0x0 CONFIG_CMD_ASKENV=y -# CONFIG_CMD_FLASH is not set CONFIG_CMD_MEMINFO=y CONFIG_CMD_MEMTEST=y +# CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y @@ -115,9 +111,6 @@ CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y -CONFIG_DM_VIDEO=y -CONFIG_DM_PANEL_HX8238D=y -CONFIG_VIDEO_BPP16=y CONFIG_SYS_WHITE_ON_BLACK=y CONFIG_AM335X_LCD=y CONFIG_SPL_WDT=y diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 83815e1131f..bc19d070529 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -68,7 +68,6 @@ CONFIG_OMAP3_SPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index 9c5ac032bd8..a1e19b6ce90 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -70,7 +70,6 @@ CONFIG_OMAP3_SPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 66185630db2..504b38cbfd4 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -76,7 +76,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_AM35X=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index 05e7e774c63..ae1fffddb21 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -71,7 +71,6 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 352050204d6..f42218bb46b 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -52,7 +52,6 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_TI_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index c8db636e256..955ea087acb 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -55,7 +55,6 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index ae233434099..a3e55ce3469 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -77,7 +77,6 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index f568aa646ef..62c1ecbfed8 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -76,7 +76,6 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index e21b3dff537..650357de0f2 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -102,7 +102,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_TI_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 3807732b02a..c96132847b5 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -98,7 +98,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_TI_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index b0cfecdd63b..8fd29ba4f26 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -106,7 +106,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_TI_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 6fab1deeb27..f766a1177c4 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -116,7 +116,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index 4a16cdea2ef..c207cdf90b3 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -116,7 +116,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am65x_evm_a53_defconfig b/configs/am65x_evm_a53_defconfig index a5858fe27ee..2d580f72bdf 100644 --- a/configs/am65x_evm_a53_defconfig +++ b/configs/am65x_evm_a53_defconfig @@ -156,7 +156,6 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am65x_evm_r5_usbdfu_defconfig b/configs/am65x_evm_r5_usbdfu_defconfig index e08a80ef4b0..5bc713f648e 100644 --- a/configs/am65x_evm_r5_usbdfu_defconfig +++ b/configs/am65x_evm_r5_usbdfu_defconfig @@ -61,7 +61,6 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_BLK=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y @@ -106,7 +105,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am65x_evm_r5_usbmsc_defconfig b/configs/am65x_evm_r5_usbmsc_defconfig index 61c00b83a00..e75852d4228 100644 --- a/configs/am65x_evm_r5_usbmsc_defconfig +++ b/configs/am65x_evm_r5_usbmsc_defconfig @@ -60,7 +60,6 @@ CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_BLK=y CONFIG_CLK=y CONFIG_SPL_CLK=y CONFIG_CLK_TI_SCI=y @@ -103,7 +102,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/am65x_hs_evm_a53_defconfig b/configs/am65x_hs_evm_a53_defconfig index e0297d4ce9a..4e32eabac19 100644 --- a/configs/am65x_hs_evm_a53_defconfig +++ b/configs/am65x_hs_evm_a53_defconfig @@ -139,7 +139,6 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/apalis-imx8x_defconfig b/configs/apalis-imx8x_defconfig index fc537839b87..ed9686e0d87 100644 --- a/configs/apalis-imx8x_defconfig +++ b/configs/apalis-imx8x_defconfig @@ -62,7 +62,6 @@ CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX8=y CONFIG_POWER_DOMAIN=y diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 276541b57da..39e1c1dff17 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -45,7 +45,6 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_TEGRA124_MMC_DISABLE_EXT_LOOPBACK=y CONFIG_E1000=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_DM_PMIC=y CONFIG_PMIC_AS3722=y @@ -53,7 +52,6 @@ CONFIG_DM_REGULATOR=y CONFIG_REGULATOR_AS3722=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_GADGET=y diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index ad109c444fe..0fc7cf0ed31 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -89,15 +89,14 @@ CONFIG_DM_SCSI=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 21b31b44bc7..1420ca219f3 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -38,11 +38,9 @@ CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y CONFIG_E1000=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_GADGET=y diff --git a/configs/aristainetos2c_defconfig b/configs/aristainetos2c_defconfig index d0e83508940..67fc4e3e23c 100644 --- a/configs/aristainetos2c_defconfig +++ b/configs/aristainetos2c_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg" CONFIG_BOOTDELAY=-2 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_ENCRYPTION=y -CONFIG_AUTOBOOT_STOP_STR_SHA256="30bb0bce5f77da71a6e8e436fe40af54bc823db9501ae170f77e9992499d88fb" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run ari_boot" # CONFIG_CONSOLE_MUX is not set @@ -111,7 +110,6 @@ CONFIG_MXC_SPI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/aristainetos2ccslb_defconfig b/configs/aristainetos2ccslb_defconfig index cad9c8b44d5..c156a6ade80 100644 --- a/configs/aristainetos2ccslb_defconfig +++ b/configs/aristainetos2ccslb_defconfig @@ -17,7 +17,6 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg" CONFIG_BOOTDELAY=-2 CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_ENCRYPTION=y -CONFIG_AUTOBOOT_STOP_STR_SHA256="30bb0bce5f77da71a6e8e436fe40af54bc823db9501ae170f77e9992499d88fb" CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run ari_boot" # CONFIG_CONSOLE_MUX is not set @@ -111,7 +110,6 @@ CONFIG_MXC_SPI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index bc7af829fb8..a3e74ab6260 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -44,7 +44,6 @@ CONFIG_I2S_SAMSUNG=y CONFIG_SOUND_MAX98095=y CONFIG_SOUND_WM8994=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index ce0a3ce35ac..76ad67bf9ee 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -59,4 +58,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 5bb6ae68adf..07d3911d900 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -59,4 +58,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 95a0798afaf..24a40f2137d 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -23,7 +23,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -56,4 +55,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 48780fd4937..79e3e02e9f8 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -56,4 +55,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 8705e881e56..29e08af51d8 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -56,4 +55,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 1483b6f45c4..e5d54e463fd 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -53,4 +52,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 3d6e6cf6df9..64e2ea8eeda 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -62,5 +61,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 3d6e6cf6df9..64e2ea8eeda 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -62,5 +61,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index e716d7156e4..73aef06a7cf 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -26,7 +26,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -59,5 +58,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index db3d0fbff13..8b5377dc1bd 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -62,5 +61,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 01b2c84526b..ee4edec2daa 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -62,5 +61,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 4b0135f607b..a9acd1d46ef 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -54,4 +53,3 @@ CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index c37a8c4a333..4c92ee4593c 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -54,4 +53,3 @@ CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index e7ee1440239..414e41b48fb 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -51,4 +50,3 @@ CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index 00cc182f852..d3d95c726cb 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -57,5 +56,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index 9610ddd34ed..4e9f8e2dbc9 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -24,7 +24,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -57,5 +56,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 6c85767b3da..e0478ef1a93 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -59,4 +58,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index 28195da7e9f..2bc57c8af73 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -59,4 +58,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index a98f759d100..14b32a9e6e8 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -23,7 +23,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -56,4 +55,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index cdcd67b017c..07683608d04 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -52,6 +52,5 @@ CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index a958162574b..568743d5e2e 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -52,6 +52,5 @@ CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index f4c3fb864ef..2e0e5969628 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -57,6 +56,4 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y CONFIG_ATMEL_HLCD=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 161ec94695f..483e5e9618c 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -57,6 +56,4 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y CONFIG_ATMEL_HLCD=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 3a66fe60756..0bed29bb431 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -24,7 +24,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -59,6 +58,4 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y CONFIG_ATMEL_HLCD=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 49f6a7dd2e4..a8e1a36b507 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -62,7 +62,6 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 8194c137890..3bd0897cfed 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -60,7 +60,6 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 25c8a16813b..90c8f796f9e 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -60,7 +60,6 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index b7f8903b1a0..71bbd743df6 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -62,7 +62,6 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index d2f280c2546..2573c3c3407 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -59,4 +58,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index 4fd826b8ff5..f2baad78e6c 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -59,4 +58,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index a1374208bc3..a1026a78fd5 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -23,7 +23,6 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -56,4 +55,3 @@ CONFIG_DM_SPI=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_USB_STORAGE=y diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index ada72651e48..7af881e45bc 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -51,7 +51,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index cc6a09e9023..7394272ee3f 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -51,7 +51,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_USB_STORAGE=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index 7c0a71446ed..76ad5efb6aa 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -42,19 +42,17 @@ CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SLINK=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/beelink-gtking_defconfig b/configs/beelink-gtking_defconfig index b429c8237c0..ebd88797830 100644 --- a/configs/beelink-gtking_defconfig +++ b/configs/beelink-gtking_defconfig @@ -47,7 +47,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/beelink-gtkingpro_defconfig b/configs/beelink-gtkingpro_defconfig index 7a8bd56a654..df2580287d4 100644 --- a/configs/beelink-gtkingpro_defconfig +++ b/configs/beelink-gtkingpro_defconfig @@ -47,7 +47,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/blanche_defconfig b/configs/blanche_defconfig index 67482b1a4ff..eb1dd71c67b 100644 --- a/configs/blanche_defconfig +++ b/configs/blanche_defconfig @@ -57,7 +57,6 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x18000000 CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -70,7 +69,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 8826e1f35ba..1985a43cc9c 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -43,7 +43,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 8c0052d4187..3aef947402d 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -44,7 +44,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/boston32r6_defconfig b/configs/boston32r6_defconfig index 7ccc925060b..6c436d0a75c 100644 --- a/configs/boston32r6_defconfig +++ b/configs/boston32r6_defconfig @@ -44,7 +44,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/boston32r6el_defconfig b/configs/boston32r6el_defconfig index 78d4b2e9414..eb6c8e63d11 100644 --- a/configs/boston32r6el_defconfig +++ b/configs/boston32r6el_defconfig @@ -45,7 +45,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 332f3d93050..d2e16bf667e 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -44,7 +44,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index f543137237b..64ef559dcef 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -45,7 +45,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/boston64r6_defconfig b/configs/boston64r6_defconfig index 3896d668527..23a7c46e969 100644 --- a/configs/boston64r6_defconfig +++ b/configs/boston64r6_defconfig @@ -44,7 +44,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/boston64r6el_defconfig b/configs/boston64r6el_defconfig index 1353a1b280b..6424c05a4ac 100644 --- a/configs/boston64r6el_defconfig +++ b/configs/boston64r6el_defconfig @@ -45,7 +45,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_DM_ETH=y CONFIG_PCH_GBE=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_XILINX=y CONFIG_SYS_NS16550=y CONFIG_LZ4=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 759880246ff..bd4c4e5a7b9 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -89,7 +89,6 @@ CONFIG_DM_ETH=y CONFIG_DRIVER_TI_CPSW=y CONFIG_DM_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y diff --git a/configs/brppt1_nand_defconfig b/configs/brppt1_nand_defconfig index 97b69c1a13c..9a0158299f5 100644 --- a/configs/brppt1_nand_defconfig +++ b/configs/brppt1_nand_defconfig @@ -80,7 +80,6 @@ CONFIG_DM=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y # CONFIG_OF_TRANSLATE is not set -CONFIG_BLK=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_DM_I2C=y CONFIG_I2C_SET_DEFAULT_BUS_NUM=y @@ -95,7 +94,6 @@ CONFIG_DM_ETH=y CONFIG_DRIVER_TI_CPSW=y CONFIG_DM_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y diff --git a/configs/brppt1_spi_defconfig b/configs/brppt1_spi_defconfig index b834c210266..e8699a9dc18 100644 --- a/configs/brppt1_spi_defconfig +++ b/configs/brppt1_spi_defconfig @@ -105,7 +105,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y diff --git a/configs/brppt2_defconfig b/configs/brppt2_defconfig index 1f466bea5a7..f362aeaa75e 100644 --- a/configs/brppt2_defconfig +++ b/configs/brppt2_defconfig @@ -94,7 +94,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_SPL_TINY_MEMSET=y # CONFIG_EFI_LOADER is not set diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index 6df2ffc831f..830cd4456c1 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -105,7 +105,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index af5d5a65b40..757585e8daf 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -85,7 +85,6 @@ CONFIG_DM_ETH=y CONFIG_DRIVER_TI_CPSW=y CONFIG_DM_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_TI=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index 5098a71d281..b4d38c569cc 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -34,12 +34,10 @@ CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SLINK=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/cei-tk1-som_defconfig b/configs/cei-tk1-som_defconfig index ec520e367b6..077324a0de9 100644 --- a/configs/cei-tk1-som_defconfig +++ b/configs/cei-tk1-som_defconfig @@ -42,7 +42,6 @@ CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_DM_PMIC=y CONFIG_PMIC_AS3722=y @@ -51,14 +50,13 @@ CONFIG_REGULATOR_AS3722=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index f4b685a1d53..3ab76d50861 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -61,7 +61,6 @@ CONFIG_OMAP3_SPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_TI=y CONFIG_LZO=y diff --git a/configs/cl-som-imx7_defconfig b/configs/cl-som-imx7_defconfig index 6e379126c6b..9fb1d670aad 100644 --- a/configs/cl-som-imx7_defconfig +++ b/configs/cl-som-imx7_defconfig @@ -83,7 +83,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_STORAGE=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 4702cf2df18..ad943a3196e 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -69,5 +69,4 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/clearfog_gt_8k_defconfig b/configs/clearfog_gt_8k_defconfig index a94dc225697..ee701883d7e 100644 --- a/configs/clearfog_gt_8k_defconfig +++ b/configs/clearfog_gt_8k_defconfig @@ -57,7 +57,6 @@ CONFIG_PHY_GIGE=y CONFIG_MVPP2=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -68,7 +67,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index 2f44157adfe..2ef935d8516 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -91,7 +91,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y CONFIG_DM_VIDEO=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 101d77c9d26..3752ff55de2 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -82,7 +82,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_OMAP_USB_PHY=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index bec5fd7b311..739eea7c07f 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -87,7 +87,6 @@ CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 19d70c0cf8f..23cdea969d9 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -87,15 +87,14 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 7a0d69f1de5..39149167e00 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -82,7 +82,6 @@ CONFIG_PMIC_RN5T567=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index d076a520808..87527671fef 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -79,7 +79,6 @@ CONFIG_PMIC_RN5T567=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index ec62ec3ba83..814d87e9393 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -24,7 +24,6 @@ CONFIG_CMD_DM=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index c8f1e32b1bb..ac98e84b440 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -54,19 +54,18 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_VIDEO_TEGRA20=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index fab035b4073..618f7c10a1b 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -37,15 +37,14 @@ CONFIG_SPL_DM=y CONFIG_SYS_I2C_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Toradex" CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 722c9938f50..abb81178046 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -85,7 +85,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/comtrend_ar5315u_ram_defconfig b/configs/comtrend_ar5315u_ram_defconfig index 14795197a9e..0e7d9cd8b15 100644 --- a/configs/comtrend_ar5315u_ram_defconfig +++ b/configs/comtrend_ar5315u_ram_defconfig @@ -57,7 +57,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_BCM63XX_HSSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/comtrend_ar5387un_ram_defconfig b/configs/comtrend_ar5387un_ram_defconfig index baff4b365d4..655db1bba6e 100644 --- a/configs/comtrend_ar5387un_ram_defconfig +++ b/configs/comtrend_ar5387un_ram_defconfig @@ -58,7 +58,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_BCM63XX_HSSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/comtrend_ct5361_ram_defconfig b/configs/comtrend_ct5361_ram_defconfig index f733eb4a183..6a7ce99e79c 100644 --- a/configs/comtrend_ct5361_ram_defconfig +++ b/configs/comtrend_ct5361_ram_defconfig @@ -54,7 +54,6 @@ CONFIG_RESET_BCM6345=y CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_GENERIC=y CONFIG_WDT_BCM6345=y diff --git a/configs/comtrend_vr3032u_ram_defconfig b/configs/comtrend_vr3032u_ram_defconfig index f9a921a7621..ac963efdcc2 100644 --- a/configs/comtrend_vr3032u_ram_defconfig +++ b/configs/comtrend_vr3032u_ram_defconfig @@ -56,7 +56,6 @@ CONFIG_RESET_BCM6345=y CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/comtrend_wap5813n_ram_defconfig b/configs/comtrend_wap5813n_ram_defconfig index dcc64bb6b76..16e0caa6a0d 100644 --- a/configs/comtrend_wap5813n_ram_defconfig +++ b/configs/comtrend_wap5813n_ram_defconfig @@ -54,7 +54,6 @@ CONFIG_RESET_BCM6345=y CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/controlcenterdc_defconfig b/configs/controlcenterdc_defconfig index a8d961a7c50..14577a41537 100644 --- a/configs/controlcenterdc_defconfig +++ b/configs/controlcenterdc_defconfig @@ -79,7 +79,6 @@ CONFIG_TPM_ATMEL_TWI=y CONFIG_TPM_AUTH_SESSIONS=y CONFIG_TPM_FLUSH_RESOURCES=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_TPM=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index ef21e965ce7..921049352b7 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -47,7 +47,6 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y @@ -61,7 +60,6 @@ CONFIG_NAND_ATMEL=y CONFIG_PHYLIB=y CONFIG_ATMEL_USART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 33e21495058..017bb216230 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y @@ -55,6 +54,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 99cb4be8c22..3ed89781b02 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -84,7 +84,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_DA8XX=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index b595acf4009..e69da40a110 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -44,7 +44,6 @@ CONFIG_ENV_ADDR=0x60100000 CONFIG_VERSION_VARIABLE=y CONFIG_BOOTP_SEND_HOSTNAME=y CONFIG_DM=y -CONFIG_BLK=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_DAVINCI=y @@ -74,7 +73,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_DA8XX=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 414fca53839..7803bf5c506 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -83,7 +83,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_DA8XX=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index a58605d7619..dabdb070642 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -42,14 +42,13 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index bb73635d92b..2d07ddf7f51 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -46,7 +46,6 @@ CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_BLK=y CONFIG_MISC=y # CONFIG_MMC is not set CONFIG_SPI_FLASH_MACRONIX=y @@ -59,6 +58,5 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/db-88f6820-amc_defconfig b/configs/db-88f6820-amc_defconfig index a7c84985999..5eec9982a89 100644 --- a/configs/db-88f6820-amc_defconfig +++ b/configs/db-88f6820-amc_defconfig @@ -43,14 +43,12 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_OVERWRITE=y CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_BLK=y # CONFIG_SPL_BLK is not set # CONFIG_BLOCK_CACHE is not set CONFIG_DM_I2C=y @@ -74,6 +72,5 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 6fa00d1a179..74c963470bf 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -43,7 +43,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_OVERWRITE=y CONFIG_USE_ENV_SPI_MAX_HZ=y @@ -67,6 +66,5 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index e1f6aff8f59..014929042d0 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -43,7 +43,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_OVERWRITE=y CONFIG_USE_ENV_SPI_MAX_HZ=y @@ -51,7 +50,6 @@ CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y @@ -69,6 +67,5 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/db-xc3-24g4xg_defconfig b/configs/db-xc3-24g4xg_defconfig index f2da99c5d3f..9a162df295d 100644 --- a/configs/db-xc3-24g4xg_defconfig +++ b/configs/db-xc3-24g4xg_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_UBI=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set @@ -55,7 +54,6 @@ CONFIG_PCI_MVEBU=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index 2034cd11d59..b56408f98af 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -27,7 +27,6 @@ CONFIG_CMD_IMLS=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -57,6 +56,4 @@ CONFIG_CONS_INDEX=5 CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_USB=y -# CONFIG_SPL_DM_USB is not set -CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT=y diff --git a/configs/dh_imx6_defconfig b/configs/dh_imx6_defconfig index a22053396c7..ef905ec3709 100644 --- a/configs/dh_imx6_defconfig +++ b/configs/dh_imx6_defconfig @@ -98,7 +98,6 @@ CONFIG_MXC_SPI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="dh" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 diff --git a/configs/display5_factory_defconfig b/configs/display5_factory_defconfig index 2ade8c2055e..d5fb73de394 100644 --- a/configs/display5_factory_defconfig +++ b/configs/display5_factory_defconfig @@ -121,7 +121,6 @@ CONFIG_MXC_SPI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Liebherr" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index d5d79f5297f..edcdb87d54f 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -36,7 +36,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NETCONSOLE=y CONFIG_DM=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y @@ -46,6 +45,5 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 9d222f1ef30..115a21c8fd1 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -118,7 +118,6 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 86ec00396d1..e63b09c815d 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -121,7 +121,6 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 229309c8f41..a4900fe5099 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -115,7 +115,6 @@ CONFIG_TI_QSPI=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index a46283f980e..b8aae592b66 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -46,18 +46,17 @@ CONFIG_PMIC_PM8916=y CONFIG_MSM_SERIAL=y CONFIG_SPMI_MSM=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_MSM=y CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd00d -CONFIG_CI_UDC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 +CONFIG_USB_GADGET_PRODUCT_NUM=0xd00d +CONFIG_CI_UDC=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index 8956d2f3c59..288182a51b1 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -34,7 +34,6 @@ CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_ENV_ADDR=0x100000 CONFIG_NETCONSOLE=y CONFIG_DM=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y @@ -48,6 +47,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 77c094b7663..9f146ec3d4a 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -30,7 +30,6 @@ CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_ENV_ADDR=0x3D0000 CONFIG_NETCONSOLE=y CONFIG_DM=y -CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y # CONFIG_MMC is not set @@ -46,5 +45,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index b8a0bd09d42..030a85d315e 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -47,7 +47,6 @@ CONFIG_USE_ENV_SPI_MAX_HZ=y CONFIG_ENV_SPI_MAX_HZ=50000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_OF_TRANSLATE=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_SPI_FLASH_STMICRO=y @@ -62,7 +61,6 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y # CONFIG_USB_XHCI_MVEBU is not set CONFIG_USB_XHCI_PCI=y diff --git a/configs/durian_defconfig b/configs/durian_defconfig index c55084b6204..77b9795d106 100644 --- a/configs/durian_defconfig +++ b/configs/durian_defconfig @@ -26,7 +26,6 @@ CONFIG_AHCI_PCI=y CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_PHYTIUM=y CONFIG_SCSI=y CONFIG_DM_SCSI=y diff --git a/configs/edison_defconfig b/configs/edison_defconfig index 82265484bc2..a78963006c2 100644 --- a/configs/edison_defconfig +++ b/configs/edison_defconfig @@ -38,12 +38,12 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_DM_USB_GADGET=y +# CONFIG_USB_HOST_ETHER is not set CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Intel" CONFIG_USB_GADGET_VENDOR_NUM=0x8087 CONFIG_USB_GADGET_PRODUCT_NUM=0x0a99 CONFIG_USB_GADGET_DOWNLOAD=y -# CONFIG_USB_HOST_ETHER is not set CONFIG_WDT=y CONFIG_WDT_TANGIER=y CONFIG_SHA1=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 0aacb35e44c..3d1365dd68f 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -24,7 +24,6 @@ CONFIG_SYS_PROMPT="EDMiniV2> " CONFIG_CMD_IMLS=y CONFIG_CMD_IDE=y CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT2=y CONFIG_ISO_PARTITION=y @@ -40,5 +39,3 @@ CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 585024158ef..4da3c1d4f4c 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y CONFIG_CMD_SAVES=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_RARP=y CONFIG_CMD_MII=y diff --git a/configs/ev-imx280-nano-x-mb_defconfig b/configs/ev-imx280-nano-x-mb_defconfig index cc95fdb0deb..afb2a68a302 100644 --- a/configs/ev-imx280-nano-x-mb_defconfig +++ b/configs/ev-imx280-nano-x-mb_defconfig @@ -45,7 +45,6 @@ CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 3fa8e155e34..91b7974c408 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -73,11 +73,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_DISPLAY=y diff --git a/configs/ge_b1x5v2_defconfig b/configs/ge_b1x5v2_defconfig index efd4eed61a5..d3a628c3636 100644 --- a/configs/ge_b1x5v2_defconfig +++ b/configs/ge_b1x5v2_defconfig @@ -120,7 +120,6 @@ CONFIG_POWEROFF_GPIO=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y diff --git a/configs/ge_bx50v3_defconfig b/configs/ge_bx50v3_defconfig index b831850ec0f..76e478b5806 100644 --- a/configs/ge_bx50v3_defconfig +++ b/configs/ge_bx50v3_defconfig @@ -70,7 +70,6 @@ CONFIG_CMD_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index 9285e8d4d71..7207fa27e0f 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -37,7 +37,6 @@ CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_NETCONSOLE=y CONFIG_DM=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y @@ -47,6 +46,5 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 5cd4cb8c125..5276f4c123e 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -77,7 +77,6 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -90,7 +89,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/grpeach_defconfig b/configs/grpeach_defconfig index d497ac80076..e4a570de564 100644 --- a/configs/grpeach_defconfig +++ b/configs/grpeach_defconfig @@ -39,7 +39,6 @@ CONFIG_USE_ENV_SPI_MODE=y CONFIG_ENV_SPI_MODE=0x0 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_BLK=y CONFIG_RZA1_GPIO=y CONFIG_LED=y CONFIG_LED_GPIO=y @@ -61,7 +60,6 @@ CONFIG_RENESAS_RPC_SPI=y CONFIG_TIMER=y CONFIG_RENESAS_OSTM_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_R8A66597_HCD=y CONFIG_USB_STORAGE=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/guruplug_defconfig b/configs/guruplug_defconfig index 954e429a9d5..619254c2b55 100644 --- a/configs/guruplug_defconfig +++ b/configs/guruplug_defconfig @@ -38,7 +38,6 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y @@ -48,7 +47,6 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LZMA=y diff --git a/configs/gwventana_emmc_defconfig b/configs/gwventana_emmc_defconfig index 2fa30d470a4..3190fbed232 100644 --- a/configs/gwventana_emmc_defconfig +++ b/configs/gwventana_emmc_defconfig @@ -91,7 +91,6 @@ CONFIG_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_REGULATOR=y @@ -105,9 +104,10 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Gateworks" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 @@ -116,9 +116,6 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y # CONFIG_BACKLIGHT is not set # CONFIG_CMD_VIDCONSOLE is not set diff --git a/configs/gwventana_gw5904_defconfig b/configs/gwventana_gw5904_defconfig index 5b75fca9f2c..b11dc907fd9 100644 --- a/configs/gwventana_gw5904_defconfig +++ b/configs/gwventana_gw5904_defconfig @@ -95,7 +95,6 @@ CONFIG_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_REGULATOR=y @@ -109,9 +108,10 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Gateworks" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 @@ -120,9 +120,6 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y # CONFIG_BACKLIGHT is not set # CONFIG_CMD_VIDCONSOLE is not set diff --git a/configs/gwventana_nand_defconfig b/configs/gwventana_nand_defconfig index 16c0374804e..2b39f9027ce 100644 --- a/configs/gwventana_nand_defconfig +++ b/configs/gwventana_nand_defconfig @@ -97,7 +97,6 @@ CONFIG_E1000=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_REGULATOR=y @@ -111,9 +110,10 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y -CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Gateworks" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 @@ -122,9 +122,6 @@ CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_DM_VIDEO=y # CONFIG_BACKLIGHT is not set # CONFIG_CMD_VIDCONSOLE is not set diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 99060461743..874311e487b 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -38,14 +38,12 @@ CONFIG_DM_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_MTD_UBI_FASTMAP=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_ULPI_VIEWPORT=y diff --git a/configs/helios4_defconfig b/configs/helios4_defconfig index 202e57344d9..c70787a2d78 100644 --- a/configs/helios4_defconfig +++ b/configs/helios4_defconfig @@ -69,5 +69,4 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/hihope_rzg2_defconfig b/configs/hihope_rzg2_defconfig index be71ebb6a2e..1e977444d41 100644 --- a/configs/hihope_rzg2_defconfig +++ b/configs/hihope_rzg2_defconfig @@ -71,7 +71,6 @@ CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 243733618b6..0ec1ed78a0b 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -26,7 +26,6 @@ CONFIG_MMC_DW_K3=y CONFIG_DM_ETH=y CONFIG_CONS_INDEX=4 CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/hsdk_defconfig b/configs/hsdk_defconfig index dd2cfb92646..e4245630c0b 100644 --- a/configs/hsdk_defconfig +++ b/configs/hsdk_defconfig @@ -54,7 +54,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/huawei_hg556a_ram_defconfig b/configs/huawei_hg556a_ram_defconfig index f08e2ad9d1b..004fea1fa3d 100644 --- a/configs/huawei_hg556a_ram_defconfig +++ b/configs/huawei_hg556a_ram_defconfig @@ -54,7 +54,6 @@ CONFIG_RESET_BCM6345=y CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 85a29f3ee24..c1abe700485 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -96,7 +96,6 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" diff --git a/configs/imx7_cm_defconfig b/configs/imx7_cm_defconfig index d7a7924d515..6220ebf8b17 100644 --- a/configs/imx7_cm_defconfig +++ b/configs/imx7_cm_defconfig @@ -93,7 +93,6 @@ CONFIG_FSL_QSPI=y # CONFIG_FSL_QSPI_AHB_FULL_MAP is not set CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/imx8mm-cl-iot-gate_defconfig b/configs/imx8mm-cl-iot-gate_defconfig index f46f45bda91..af584cde5e4 100644 --- a/configs/imx8mm-cl-iot-gate_defconfig +++ b/configs/imx8mm-cl-iot-gate_defconfig @@ -123,9 +123,10 @@ CONFIG_DM_THERMAL=y CONFIG_TPM2_TIS_SPI=y CONFIG_TPM2_FTPM_TEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 @@ -133,8 +134,6 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_SDP_LOADADDR=0x40400000 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX88179=y CONFIG_IMX_WATCHDOG=y CONFIG_SPL_TINY_MEMSET=y CONFIG_TPM=y diff --git a/configs/imx8mn_beacon_2g_defconfig b/configs/imx8mn_beacon_2g_defconfig index ecbc8c30a54..5fbcf70b93f 100644 --- a/configs/imx8mn_beacon_2g_defconfig +++ b/configs/imx8mn_beacon_2g_defconfig @@ -121,7 +121,6 @@ CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_DM_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y diff --git a/configs/imx8mn_beacon_defconfig b/configs/imx8mn_beacon_defconfig index fa3fdfa880f..bc5ce39750f 100644 --- a/configs/imx8mn_beacon_defconfig +++ b/configs/imx8mn_beacon_defconfig @@ -125,7 +125,6 @@ CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_DM_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_GADGET=y diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index f4d53976746..50132c833e2 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -26,6 +26,7 @@ CONFIG_CMD_FUSE=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y # CONFIG_CMD_MDIO is not set CONFIG_CMD_CACHE=y CONFIG_CMD_REGULATOR=y @@ -43,6 +44,8 @@ CONFIG_FSL_USDHC=y CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_DM_ETH=y +CONFIG_PHY=y +CONFIG_PHY_IMX8MQ_USB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX8M=y CONFIG_POWER_DOMAIN=y @@ -53,12 +56,7 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_RESET=y CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y -CONFIG_CMD_USB=y CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y -CONFIG_PHY=y -CONFIG_PHY_IMX8MQ_USB=y diff --git a/configs/imxrt1050-evk_defconfig b/configs/imxrt1050-evk_defconfig index ca72f8c1697..bbcbb988121 100644 --- a/configs/imxrt1050-evk_defconfig +++ b/configs/imxrt1050-evk_defconfig @@ -67,7 +67,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_IMX_GPT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_DM_VIDEO=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index fe48f56cc59..6141e15179d 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y @@ -55,6 +54,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/iot_devkit_defconfig b/configs/iot_devkit_defconfig index 4d9c85aa78c..e58b98dcdb2 100644 --- a/configs/iot_devkit_defconfig +++ b/configs/iot_devkit_defconfig @@ -32,7 +32,6 @@ CONFIG_MMC_DW_SNPS=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_DWC2_BUFFER_SIZE=16 CONFIG_USB_STORAGE=y diff --git a/configs/j7200_evm_a72_defconfig b/configs/j7200_evm_a72_defconfig index b0cde842ddd..160c36d6a10 100644 --- a/configs/j7200_evm_a72_defconfig +++ b/configs/j7200_evm_a72_defconfig @@ -168,7 +168,6 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/j7200_evm_r5_defconfig b/configs/j7200_evm_r5_defconfig index 862061e5b27..8b14ceab1ae 100644 --- a/configs/j7200_evm_r5_defconfig +++ b/configs/j7200_evm_r5_defconfig @@ -90,6 +90,7 @@ CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y CONFIG_FS_LOADER=y +CONFIG_K3_AVS0=y CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_SPL_MMC_HS200_SUPPORT=y CONFIG_MMC_SDHCI=y @@ -113,14 +114,13 @@ CONFIG_SPL_PINCTRL=y # CONFIG_SPL_PINCTRL_GENERIC is not set CONFIG_PINCTRL_SINGLE=y CONFIG_POWER_DOMAIN=y -CONFIG_TI_POWER_DOMAIN=y CONFIG_TI_SCI_POWER_DOMAIN=y +CONFIG_TI_POWER_DOMAIN=y CONFIG_DM_PMIC=y CONFIG_PMIC_TPS65941=y CONFIG_DM_REGULATOR=y CONFIG_SPL_DM_REGULATOR=y CONFIG_DM_REGULATOR_TPS65941=y -CONFIG_K3_AVS0=y CONFIG_K3_SYSTEM_CONTROLLER=y CONFIG_REMOTEPROC_TI_K3_ARM64=y CONFIG_DM_RESET=y @@ -139,7 +139,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_CDNS3=y diff --git a/configs/j721e_evm_a72_defconfig b/configs/j721e_evm_a72_defconfig index 2e890cdfe60..7f2eb1ebdba 100644 --- a/configs/j721e_evm_a72_defconfig +++ b/configs/j721e_evm_a72_defconfig @@ -167,7 +167,6 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/j721e_evm_r5_defconfig b/configs/j721e_evm_r5_defconfig index 0f8fda795ac..26775b3978d 100644 --- a/configs/j721e_evm_r5_defconfig +++ b/configs/j721e_evm_r5_defconfig @@ -130,7 +130,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_CDNS3=y diff --git a/configs/j721e_hs_evm_a72_defconfig b/configs/j721e_hs_evm_a72_defconfig index 82b25e695a7..87825512692 100644 --- a/configs/j721e_hs_evm_a72_defconfig +++ b/configs/j721e_hs_evm_a72_defconfig @@ -148,7 +148,6 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_TI_SCI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_SPL_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index 938e03b0573..31acb2770fb 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -42,7 +42,6 @@ CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_DM_PMIC=y CONFIG_PMIC_AS3722=y @@ -51,14 +50,13 @@ CONFIG_REGULATOR_AS3722=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index 44cba295f49..f095f977c77 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -75,7 +75,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/k2e_hs_evm_defconfig b/configs/k2e_hs_evm_defconfig index 62689162ed3..b59cf2bdae2 100644 --- a/configs/k2e_hs_evm_defconfig +++ b/configs/k2e_hs_evm_defconfig @@ -60,7 +60,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 2d579764892..01df88210b4 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -81,7 +81,6 @@ CONFIG_DM_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_DWC3=y diff --git a/configs/k2g_hs_evm_defconfig b/configs/k2g_hs_evm_defconfig index 296afa43fed..528b95f680a 100644 --- a/configs/k2g_hs_evm_defconfig +++ b/configs/k2g_hs_evm_defconfig @@ -65,7 +65,6 @@ CONFIG_DM_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 2392aec37c3..312e3923d7c 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -75,7 +75,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/k2hk_hs_evm_defconfig b/configs/k2hk_hs_evm_defconfig index 0665abd1a65..030dd47c191 100644 --- a/configs/k2hk_hs_evm_defconfig +++ b/configs/k2hk_hs_evm_defconfig @@ -60,7 +60,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 021129be244..35b93964b15 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -75,7 +75,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/k2l_hs_evm_defconfig b/configs/k2l_hs_evm_defconfig index 47275a28099..096d65b302e 100644 --- a/configs/k2l_hs_evm_defconfig +++ b/configs/k2l_hs_evm_defconfig @@ -61,7 +61,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_DAVINCI_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/khadas-vim2_defconfig b/configs/khadas-vim2_defconfig index 32513998393..e3bba3edc09 100644 --- a/configs/khadas-vim2_defconfig +++ b/configs/khadas-vim2_defconfig @@ -54,7 +54,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MESON_SPIFC=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/khadas-vim3_defconfig b/configs/khadas-vim3_defconfig index c4b24fc3142..5bdb9f7fa62 100644 --- a/configs/khadas-vim3_defconfig +++ b/configs/khadas-vim3_defconfig @@ -65,7 +65,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MESON_SPIFC=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/khadas-vim3l_defconfig b/configs/khadas-vim3l_defconfig index 0c731d4cee6..2bb2fa0487c 100644 --- a/configs/khadas-vim3l_defconfig +++ b/configs/khadas-vim3l_defconfig @@ -65,7 +65,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MESON_SPIFC=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/khadas-vim_defconfig b/configs/khadas-vim_defconfig index 2df00d54ec4..869ea2983b3 100644 --- a/configs/khadas-vim_defconfig +++ b/configs/khadas-vim_defconfig @@ -45,7 +45,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/kmcent2_defconfig b/configs/kmcent2_defconfig index a561de27406..dd6ba88d377 100644 --- a/configs/kmcent2_defconfig +++ b/configs/kmcent2_defconfig @@ -69,7 +69,6 @@ CONFIG_PHY_GIGE=y CONFIG_FMAN_ENET=y CONFIG_RGMII=y CONFIG_MII=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCIE_FSL=y CONFIG_U_QE=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index ecbb4c9b8f0..ec0b5c41af3 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -77,7 +77,6 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -90,7 +89,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index b7076672747..c051307939d 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -56,11 +56,11 @@ CONFIG_SYSRESET=y # CONFIG_SPL_SYSRESET is not set CONFIG_USB=y CONFIG_USB_DWC2=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_SPL_TINY_MEMSET=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index 0e7340e9587..13ea7cf13e7 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -79,7 +79,6 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -92,7 +91,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/libretech-ac_defconfig b/configs/libretech-ac_defconfig index 9abbcad3c02..c494b581fb3 100644 --- a/configs/libretech-ac_defconfig +++ b/configs/libretech-ac_defconfig @@ -63,7 +63,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MESON_SPIFC=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/libretech-cc_defconfig b/configs/libretech-cc_defconfig index 4029039340d..8beb850ae24 100644 --- a/configs/libretech-cc_defconfig +++ b/configs/libretech-cc_defconfig @@ -46,7 +46,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/libretech-cc_v2_defconfig b/configs/libretech-cc_v2_defconfig index 7dc6ed2f29c..be9501052fc 100644 --- a/configs/libretech-cc_v2_defconfig +++ b/configs/libretech-cc_v2_defconfig @@ -57,7 +57,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MESON_SPIFC=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_XHCI_DWC3_OF_SIMPLE=y diff --git a/configs/libretech-s905d-pc_defconfig b/configs/libretech-s905d-pc_defconfig index 93523c23cf6..825add43875 100644 --- a/configs/libretech-s905d-pc_defconfig +++ b/configs/libretech-s905d-pc_defconfig @@ -59,7 +59,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MESON_SPIFC=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/libretech-s912-pc_defconfig b/configs/libretech-s912-pc_defconfig index 669f000f7fb..49e7d85ac76 100644 --- a/configs/libretech-s912-pc_defconfig +++ b/configs/libretech-s912-pc_defconfig @@ -58,7 +58,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MESON_SPIFC=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 05bc8240492..cf2f204ad46 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -47,7 +47,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y # CONFIG_DM_DEVICE_REMOVE is not set -CONFIG_BLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y @@ -66,7 +65,6 @@ CONFIG_CONS_INDEX=3 CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y diff --git a/configs/liteboard_defconfig b/configs/liteboard_defconfig index 106f472ad72..dbad0093c9a 100644 --- a/configs/liteboard_defconfig +++ b/configs/liteboard_defconfig @@ -57,5 +57,4 @@ CONFIG_DM_REGULATOR=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y diff --git a/configs/ls1012a2g5rdb_qspi_defconfig b/configs/ls1012a2g5rdb_qspi_defconfig index bc200b8cb6b..79ac94a2334 100644 --- a/configs/ls1012a2g5rdb_qspi_defconfig +++ b/configs/ls1012a2g5rdb_qspi_defconfig @@ -56,6 +56,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012a2g5rdb_tfa_defconfig b/configs/ls1012a2g5rdb_tfa_defconfig index 94bd37ad018..7360a13cb55 100644 --- a/configs/ls1012a2g5rdb_tfa_defconfig +++ b/configs/ls1012a2g5rdb_tfa_defconfig @@ -56,6 +56,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index aa018519813..3844691403b 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -37,7 +37,6 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_BLK=y CONFIG_DM_I2C=y # CONFIG_MMC is not set CONFIG_MTD=y @@ -50,7 +49,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -58,6 +56,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012afrdm_tfa_defconfig b/configs/ls1012afrdm_tfa_defconfig index d2d61afb4f0..9046ec7617d 100644 --- a/configs/ls1012afrdm_tfa_defconfig +++ b/configs/ls1012afrdm_tfa_defconfig @@ -37,7 +37,6 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_BLK=y CONFIG_DM_I2C=y # CONFIG_MMC is not set CONFIG_MTD=y @@ -50,7 +49,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_SYS_NS16550=y @@ -58,6 +56,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig index e913993f51e..9d357272487 100644 --- a/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_qspi_SECURE_BOOT_defconfig @@ -48,7 +48,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -57,7 +56,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1012afrwy_qspi_defconfig b/configs/ls1012afrwy_qspi_defconfig index 0f1e42e0203..853014e76f8 100644 --- a/configs/ls1012afrwy_qspi_defconfig +++ b/configs/ls1012afrwy_qspi_defconfig @@ -52,7 +52,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -60,6 +59,5 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig index 24b6660cab4..ca055570ea5 100644 --- a/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012afrwy_tfa_SECURE_BOOT_defconfig @@ -48,7 +48,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -57,7 +56,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1012afrwy_tfa_defconfig b/configs/ls1012afrwy_tfa_defconfig index d04cffccf61..3282756be0e 100644 --- a/configs/ls1012afrwy_tfa_defconfig +++ b/configs/ls1012afrwy_tfa_defconfig @@ -52,7 +52,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -61,7 +60,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index e5ff71a10d7..2124716d77c 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -68,7 +68,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF8563=y @@ -80,6 +79,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index 3065863f243..ec92358b008 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -56,7 +56,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF8563=y @@ -68,7 +67,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index 6267e48d660..82a698f6e33 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -68,7 +68,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF8563=y @@ -80,6 +79,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index 60d42759d22..da45a3d9cfa 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -51,7 +51,6 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y @@ -62,7 +61,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 617cf91b365..830e7868c04 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -55,7 +55,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -65,6 +64,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig index 1524d27cb54..fd1f6fa62fe 100644 --- a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig @@ -52,7 +52,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -62,7 +61,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index d02f87bf92f..c83248c3040 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -54,7 +54,6 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -64,6 +63,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021aiot_qspi_defconfig b/configs/ls1021aiot_qspi_defconfig index 01a870d310e..131026ca4d4 100644 --- a/configs/ls1021aiot_qspi_defconfig +++ b/configs/ls1021aiot_qspi_defconfig @@ -42,7 +42,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -52,6 +51,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021aiot_sdcard_defconfig b/configs/ls1021aiot_sdcard_defconfig index dfdb3c0623c..7c198988b88 100644 --- a/configs/ls1021aiot_sdcard_defconfig +++ b/configs/ls1021aiot_sdcard_defconfig @@ -48,7 +48,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 04ad8667314..cf64f0fc762 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -57,7 +58,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -65,8 +65,6 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 700768294d6..cb63fb65e82 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -58,15 +59,12 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index f969fdc4e08..a1c18472969 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x140000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y @@ -74,14 +75,11 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index 43e77c95bc7..e9d29f43144 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set CONFIG_FIT=y @@ -56,16 +57,13 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 26d2e5e5673..4c4050a403c 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -58,7 +59,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -66,8 +66,6 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index f2d81ce0e17..3378fc1e787 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -59,15 +60,12 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 1f6f819d91e..69a02a4af90 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -55,7 +56,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -65,8 +65,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index aa75d140435..738ddcd6613 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y @@ -73,14 +74,11 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 2427760dc61..280c231e18b 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y @@ -67,7 +68,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -77,8 +77,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1021atsn_qspi_defconfig b/configs/ls1021atsn_qspi_defconfig index f0574c05300..6103ab32a49 100644 --- a/configs/ls1021atsn_qspi_defconfig +++ b/configs/ls1021atsn_qspi_defconfig @@ -49,7 +49,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_NS16550=y CONFIG_SPI=y @@ -57,6 +56,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021atsn_sdcard_defconfig b/configs/ls1021atsn_sdcard_defconfig index 52c29babaa2..34a48b4b4d7 100644 --- a/configs/ls1021atsn_sdcard_defconfig +++ b/configs/ls1021atsn_sdcard_defconfig @@ -60,7 +60,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_NS16550=y CONFIG_SPI=y @@ -68,6 +67,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index bc3b1f927f4..d2d2fcc1ba1 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -51,12 +51,10 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index adf43eed228..fa20ee8c0e9 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -53,13 +53,11 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 4791cb0e820..11d210846c4 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -55,12 +55,10 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_DM_SERIAL=y CONFIG_FSL_LPUART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index bcc76a4423f..50337a874f1 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -54,7 +54,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y @@ -63,6 +62,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig index 1f807d6b24d..24d61935b67 100644 --- a/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_SECURE_BOOT_defconfig @@ -69,11 +69,9 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 68e38ee5800..f44d72cec5c 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -68,11 +68,9 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index b74463ac35e..12a5ab8dc63 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -65,7 +65,6 @@ CONFIG_MII=y CONFIG_TSEC_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y @@ -74,6 +73,5 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig index 0c79b517bec..5b60c4af8d9 100644 --- a/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028aqds_tfa_SECURE_BOOT_defconfig @@ -66,7 +66,6 @@ CONFIG_MSCC_FELIX_SWITCH=y CONFIG_MDIO_MUX_I2CREG=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y @@ -79,7 +78,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y diff --git a/configs/ls1028aqds_tfa_defconfig b/configs/ls1028aqds_tfa_defconfig index bacd044a1c5..311cfe3c7a2 100644 --- a/configs/ls1028aqds_tfa_defconfig +++ b/configs/ls1028aqds_tfa_defconfig @@ -72,7 +72,6 @@ CONFIG_MSCC_FELIX_SWITCH=y CONFIG_MDIO_MUX_I2CREG=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y @@ -85,7 +84,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y diff --git a/configs/ls1028aqds_tfa_lpuart_defconfig b/configs/ls1028aqds_tfa_lpuart_defconfig index 195c6f85ccf..6805f5eaaa1 100644 --- a/configs/ls1028aqds_tfa_lpuart_defconfig +++ b/configs/ls1028aqds_tfa_lpuart_defconfig @@ -70,7 +70,6 @@ CONFIG_FSL_ENETC=y CONFIG_MDIO_MUX_I2CREG=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y @@ -85,7 +84,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y diff --git a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig index 3974918b298..7eecbae13e7 100644 --- a/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1028ardb_tfa_SECURE_BOOT_defconfig @@ -61,7 +61,6 @@ CONFIG_E1000=y CONFIG_MSCC_FELIX_SWITCH=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y @@ -74,7 +73,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y diff --git a/configs/ls1028ardb_tfa_defconfig b/configs/ls1028ardb_tfa_defconfig index 7210e9467e4..6934a597a52 100644 --- a/configs/ls1028ardb_tfa_defconfig +++ b/configs/ls1028ardb_tfa_defconfig @@ -67,7 +67,6 @@ CONFIG_E1000=y CONFIG_MSCC_FELIX_SWITCH=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y @@ -80,7 +79,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index 6fc6c327bab..d89f6571bd0 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -56,7 +57,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -65,8 +65,6 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index b2223b8d4e3..8e4eaf22bec 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-lpuart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -57,7 +58,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -67,8 +67,6 @@ CONFIG_FSL_LPUART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 42830d3228d..3fde3301f44 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y @@ -72,7 +73,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y @@ -81,8 +81,6 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 481f6eaa6f6..1fbb5ea0b80 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -57,7 +58,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y @@ -66,8 +66,6 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 1a33968d37d..4f7e457a36c 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -53,7 +54,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -63,8 +63,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index f5185173098..24e7442d2e3 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -73,7 +74,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -82,8 +82,6 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 10e87b7df9a..3c798dd6a11 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -66,7 +67,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -76,8 +76,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index cafb09ab8c8..6b908edc868 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -57,7 +58,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -66,11 +66,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index 848f571b8f8..a229001d8af 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -67,7 +68,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -76,8 +76,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 75fa56b85b2..8885896f7b1 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -47,14 +47,12 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 55925089fc0..413e0c7941c 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -50,14 +50,12 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NOR=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig index 5c687508a91..82ae5a1e4a2 100644 --- a/configs/ls1043ardb_nand_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_nand_SECURE_BOOT_defconfig @@ -67,14 +67,12 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y # CONFIG_SPL_USE_TINY_PRINTF is not set diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 75f89b7bd64..e412ff0ef9b 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -68,14 +68,12 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_NAND=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y # CONFIG_SPL_USE_TINY_PRINTF is not set diff --git a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig index 9bf2dbb2d29..833cad74e72 100644 --- a/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_sdcard_SECURE_BOOT_defconfig @@ -69,14 +69,12 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y # CONFIG_SPL_USE_TINY_PRINTF is not set diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 0085a032789..f0657525bb9 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -68,14 +68,12 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y # CONFIG_SPL_USE_TINY_PRINTF is not set diff --git a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig index 18e13d8210c..a3c17f0b9a0 100644 --- a/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_tfa_SECURE_BOOT_defconfig @@ -49,13 +49,11 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1043ardb_tfa_defconfig b/configs/ls1043ardb_tfa_defconfig index 1a1871b1d26..58313e4ae51 100644 --- a/configs/ls1043ardb_tfa_defconfig +++ b/configs/ls1043ardb_tfa_defconfig @@ -55,13 +55,11 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig index f094ee7053e..b5100282dc1 100644 --- a/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046afrwy_tfa_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-frwy" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -44,7 +45,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y @@ -52,7 +52,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y @@ -60,4 +59,3 @@ CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_RTL8152=y CONFIG_RSA=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046afrwy_tfa_defconfig b/configs/ls1046afrwy_tfa_defconfig index 38d7df923f2..96ab70bfaf5 100644 --- a/configs/ls1046afrwy_tfa_defconfig +++ b/configs/ls1046afrwy_tfa_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-frwy" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -51,7 +52,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -61,11 +61,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_RTL8152=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_SECURE_BOOT_defconfig b/configs/ls1046aqds_SECURE_BOOT_defconfig index 7b68ef1f9a7..1e70e37fe59 100644 --- a/configs/ls1046aqds_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_SECURE_BOOT_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -54,7 +55,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -65,9 +65,7 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_defconfig b/configs/ls1046aqds_defconfig index 3a00325dc9c..7351e490566 100644 --- a/configs/ls1046aqds_defconfig +++ b/configs/ls1046aqds_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -57,7 +58,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -68,8 +68,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_lpuart_defconfig b/configs/ls1046aqds_lpuart_defconfig index 41c9e6c8f16..c6f8a363475 100644 --- a/configs/ls1046aqds_lpuart_defconfig +++ b/configs/ls1046aqds_lpuart_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-lpuart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -58,7 +59,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -70,8 +70,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_nand_defconfig b/configs/ls1046aqds_nand_defconfig index 92d7bb9204e..c406d866bd0 100644 --- a/configs/ls1046aqds_nand_defconfig +++ b/configs/ls1046aqds_nand_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL=y @@ -65,7 +66,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -76,8 +76,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 620d400a81f..a088c82904d 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y @@ -54,7 +55,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -66,8 +66,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_sdcard_ifc_defconfig b/configs/ls1046aqds_sdcard_ifc_defconfig index d16d4e8f1c6..b4017368dae 100644 --- a/configs/ls1046aqds_sdcard_ifc_defconfig +++ b/configs/ls1046aqds_sdcard_ifc_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -75,7 +76,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -86,8 +86,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 6e6006f109a..2e4bcd81737 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" CONFIG_SPL_TEXT_BASE=0x10000000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -69,7 +70,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -81,8 +81,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index 2711e242532..42d67dc7072 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -57,7 +58,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -67,9 +67,7 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index aebd9e68f33..8ae5159f423 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1046a-qds-duart" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -67,7 +68,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y @@ -78,8 +78,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1046ardb_emmc_defconfig b/configs/ls1046ardb_emmc_defconfig index 71bcbe6391d..19e178ada66 100644 --- a/configs/ls1046ardb_emmc_defconfig +++ b/configs/ls1046ardb_emmc_defconfig @@ -68,7 +68,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -78,7 +77,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index 7f1848d3faf..edb20e7e9f8 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -50,7 +50,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -60,7 +59,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 12250f91108..087c17bb613 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -54,7 +54,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -64,7 +63,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1046ardb_qspi_spl_defconfig b/configs/ls1046ardb_qspi_spl_defconfig index 2201242f19c..feabaa1d47a 100644 --- a/configs/ls1046ardb_qspi_spl_defconfig +++ b/configs/ls1046ardb_qspi_spl_defconfig @@ -72,7 +72,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_SYS_QE_FMAN_FW_IN_SPIFLASH=y @@ -82,7 +81,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_SPL_GZIP=y diff --git a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig index 0ce7c471946..e415aeddf95 100644 --- a/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_sdcard_SECURE_BOOT_defconfig @@ -67,7 +67,6 @@ CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -76,7 +75,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1046ardb_sdcard_defconfig b/configs/ls1046ardb_sdcard_defconfig index d2c72ad5833..a441d1565fe 100644 --- a/configs/ls1046ardb_sdcard_defconfig +++ b/configs/ls1046ardb_sdcard_defconfig @@ -67,7 +67,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_SYS_QE_FMAN_FW_IN_MMC=y @@ -77,7 +76,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index 1fc4b21640e..bc37699c0a6 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -50,7 +50,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_DM_SCSI=y @@ -59,7 +58,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 6ebda172910..997fa1936e7 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -56,7 +56,6 @@ CONFIG_E1000=y CONFIG_FMAN_ENET=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_EP=y CONFIG_DM_SCSI=y @@ -65,7 +64,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y diff --git a/configs/ls1088aqds_defconfig b/configs/ls1088aqds_defconfig index c36f37d5d17..ef35ae4a077 100644 --- a/configs/ls1088aqds_defconfig +++ b/configs/ls1088aqds_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set @@ -60,7 +61,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -68,10 +68,8 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig index d401b91c400..eddfd40733c 100644 --- a/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088aqds_qspi_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y @@ -57,7 +58,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -67,7 +67,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y @@ -75,4 +74,3 @@ CONFIG_USB_GADGET=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_qspi_defconfig b/configs/ls1088aqds_qspi_defconfig index 5711464e77e..255b97739cb 100644 --- a/configs/ls1088aqds_qspi_defconfig +++ b/configs/ls1088aqds_qspi_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y @@ -60,7 +61,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -70,10 +70,8 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_sdcard_ifc_defconfig b/configs/ls1088aqds_sdcard_ifc_defconfig index fdeddaef446..e33ede2c667 100644 --- a/configs/ls1088aqds_sdcard_ifc_defconfig +++ b/configs/ls1088aqds_sdcard_ifc_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -70,16 +71,13 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_sdcard_qspi_defconfig b/configs/ls1088aqds_sdcard_qspi_defconfig index 6f30c6a2846..edb8f5608c1 100644 --- a/configs/ls1088aqds_sdcard_qspi_defconfig +++ b/configs/ls1088aqds_sdcard_qspi_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -70,7 +71,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -80,9 +80,7 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088aqds_tfa_defconfig b/configs/ls1088aqds_tfa_defconfig index 0df21ccd21d..a2d0d6da57b 100644 --- a/configs/ls1088aqds_tfa_defconfig +++ b/configs/ls1088aqds_tfa_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -83,7 +84,6 @@ CONFIG_MDIO_MUX_I2CREG=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF2127=y @@ -94,10 +94,8 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig index 981da5f9af5..dae51c4e70c 100644 --- a/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_qspi_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y @@ -59,7 +60,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y @@ -68,7 +68,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y @@ -76,4 +75,3 @@ CONFIG_USB_GADGET=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_qspi_defconfig b/configs/ls1088ardb_qspi_defconfig index 1b3affc86a7..6032f6ca8b1 100644 --- a/configs/ls1088ardb_qspi_defconfig +++ b/configs/ls1088ardb_qspi_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y @@ -62,7 +63,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y @@ -71,10 +71,8 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig index a351ae48c53..bdbccdd5e8d 100644 --- a/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_SECURE_BOOT_defconfig @@ -12,6 +12,7 @@ CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -73,7 +74,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_SYS_NS16550=y CONFIG_SPI=y @@ -81,10 +81,8 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_RSA=y CONFIG_SPL_RSA=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_sdcard_qspi_defconfig b/configs/ls1088ardb_sdcard_qspi_defconfig index 790ccbdb514..27437fc2f68 100644 --- a/configs/ls1088ardb_sdcard_qspi_defconfig +++ b/configs/ls1088ardb_sdcard_qspi_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -72,7 +73,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y @@ -81,9 +81,7 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y CONFIG_USB_GADGET=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig index 344fa73a995..69a3cef7a40 100644 --- a/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1088ardb_tfa_SECURE_BOOT_defconfig @@ -11,6 +11,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -65,7 +66,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF2127=y @@ -76,7 +76,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y @@ -85,4 +84,3 @@ CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls1088ardb_tfa_defconfig b/configs/ls1088ardb_tfa_defconfig index 082578d16b1..79490896252 100644 --- a/configs/ls1088ardb_tfa_defconfig +++ b/configs/ls1088ardb_tfa_defconfig @@ -12,6 +12,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1088a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -71,7 +72,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF2127=y @@ -82,14 +82,12 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_GADGET=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 8fca07fc931..fcbd732dd67 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set @@ -53,7 +54,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -62,10 +62,8 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 681afc027da..3a457a72d7a 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set @@ -56,7 +57,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -65,8 +65,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 54cca1990df..c39fc370fc1 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0xE0000 CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y @@ -63,7 +64,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -72,8 +72,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080aqds_qspi_defconfig b/configs/ls2080aqds_qspi_defconfig index 51ab47a583c..0b0e673816a 100644 --- a/configs/ls2080aqds_qspi_defconfig +++ b/configs/ls2080aqds_qspi_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_AHCI=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y @@ -55,7 +56,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -64,8 +64,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080aqds_sdcard_defconfig b/configs/ls2080aqds_sdcard_defconfig index fec32278186..155cfa39154 100644 --- a/configs/ls2080aqds_sdcard_defconfig +++ b/configs/ls2080aqds_sdcard_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x300000 CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_SERIAL_SUPPORT=y @@ -62,7 +63,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -71,8 +71,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index 6fb07177d30..b1477eac141 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set @@ -50,7 +51,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -60,10 +60,8 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index eb511d83ea7..c107bcddad7 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -6,6 +6,7 @@ CONFIG_NR_DRAM_BANKS=3 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_AHCI=y # CONFIG_SYS_MALLOC_F is not set @@ -53,7 +54,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y @@ -63,8 +63,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index ec81987884d..07dd149894b 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x200000 CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-rdb" CONFIG_SPL_TEXT_BASE=0x1800a000 +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_SPL_SERIAL_SUPPORT=y CONFIG_SPL_DRIVERS_MISC_SUPPORT=y CONFIG_SPL=y @@ -61,15 +62,12 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2081ardb_defconfig b/configs/ls2081ardb_defconfig index d775f56a4e8..da02de270fb 100644 --- a/configs/ls2081ardb_defconfig +++ b/configs/ls2081ardb_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2081a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y @@ -48,7 +49,6 @@ CONFIG_E1000=y CONFIG_MII=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_PCI_COMPAT=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_RTC_PCF8563=y @@ -61,8 +61,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2088aqds_tfa_defconfig b/configs/ls2088aqds_tfa_defconfig index 6eb707206ec..113f6a4139f 100644 --- a/configs/ls2088aqds_tfa_defconfig +++ b/configs/ls2088aqds_tfa_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2080a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y CONFIG_AHCI=y @@ -76,7 +77,6 @@ CONFIG_MDIO_MUX_I2CREG=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -85,8 +85,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig index 2575345703f..0201fce1a72 100644 --- a/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_qspi_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y @@ -50,7 +51,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 @@ -60,10 +60,8 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2088ardb_qspi_defconfig b/configs/ls2088ardb_qspi_defconfig index 1cc382c811e..336a0a7b32b 100644 --- a/configs/ls2088ardb_qspi_defconfig +++ b/configs/ls2088ardb_qspi_defconfig @@ -8,6 +8,7 @@ CONFIG_ENV_OFFSET=0x300000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSL_LS_PPA=y CONFIG_QSPI_AHB_INIT=y CONFIG_AHCI=y @@ -57,7 +58,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_SCSI=y CONFIG_CONS_INDEX=2 @@ -67,8 +67,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig index b05bfbce716..1799c09fbfb 100644 --- a/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls2088ardb_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -64,7 +65,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -75,11 +75,9 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/ls2088ardb_tfa_defconfig b/configs/ls2088ardb_tfa_defconfig index decf6a84d78..cfd3df430f8 100644 --- a/configs/ls2088ardb_tfa_defconfig +++ b/configs/ls2088ardb_tfa_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x40000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-ls2088a-rdb-qspi" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_QSPI_AHB_INIT=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -72,7 +73,6 @@ CONFIG_MII=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_DM_SCSI=y @@ -83,8 +83,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 16611dc52a2..79f5960e71d 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -36,7 +36,6 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y @@ -49,5 +48,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index dae76d34cfe..08405a1fc76 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -36,7 +36,6 @@ CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y @@ -49,5 +48,4 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig index 9c5d0067dcc..ed4304c7048 100644 --- a/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160aqds_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -66,7 +67,6 @@ CONFIG_MDIO_MUX_I2CREG=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_GEN4=y CONFIG_DM_RTC=y @@ -78,11 +78,9 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lx2160aqds_tfa_defconfig b/configs/lx2160aqds_tfa_defconfig index 2a755e05740..faa8da770b5 100644 --- a/configs/lx2160aqds_tfa_defconfig +++ b/configs/lx2160aqds_tfa_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -73,7 +74,6 @@ CONFIG_MDIO_MUX_I2CREG=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_GEN4=y CONFIG_DM_RTC=y @@ -85,10 +85,8 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y CONFIG_WDT_SBSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig index 40fbaca4ed0..f8511cb193d 100644 --- a/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2160ardb_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_EMC2305=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y @@ -58,7 +59,6 @@ CONFIG_E1000=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_GEN4=y CONFIG_DM_RTC=y @@ -69,11 +69,9 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lx2160ardb_tfa_defconfig b/configs/lx2160ardb_tfa_defconfig index b75d217d67c..004eb7de74f 100644 --- a/configs/lx2160ardb_tfa_defconfig +++ b/configs/lx2160ardb_tfa_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_EMC2305=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y @@ -67,7 +68,6 @@ CONFIG_E1000=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_GEN4=y CONFIG_DM_RTC=y @@ -80,10 +80,8 @@ CONFIG_NXP_FSPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y CONFIG_WDT_SBSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lx2160ardb_tfa_stmm_defconfig b/configs/lx2160ardb_tfa_stmm_defconfig index 9d1e9dc5b7a..140f851ba27 100644 --- a/configs/lx2160ardb_tfa_stmm_defconfig +++ b/configs/lx2160ardb_tfa_stmm_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2160a-rdb" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_EMC2305=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y @@ -67,7 +68,6 @@ CONFIG_E1000=y CONFIG_FSL_LS_MDIO=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_PCIE_LAYERSCAPE_GEN4=y CONFIG_DM_RTC=y @@ -80,9 +80,7 @@ CONFIG_NXP_FSPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_EFI_MM_COMM_TEE=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig index f9fdee8a093..7ade20205c6 100644 --- a/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/lx2162aqds_tfa_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_ENV_SIZE=0x2000 CONFIG_NXP_ESBC=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -68,7 +69,6 @@ CONFIG_E1000=y CONFIG_MDIO_MUX_I2CREG=y CONFIG_FSL_LS_MDIO=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF2127=y @@ -79,7 +79,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_DSPI=y CONFIG_NXP_FSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y @@ -88,4 +87,3 @@ CONFIG_RSA=y CONFIG_SPL_RSA=y CONFIG_RSA_SOFTWARE_EXP=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lx2162aqds_tfa_defconfig b/configs/lx2162aqds_tfa_defconfig index 76f4abab32d..2724f045ed6 100644 --- a/configs/lx2162aqds_tfa_defconfig +++ b/configs/lx2162aqds_tfa_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -76,7 +77,6 @@ CONFIG_E1000=y CONFIG_MDIO_MUX_I2CREG=y CONFIG_FSL_LS_MDIO=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF2127=y @@ -89,10 +89,8 @@ CONFIG_NXP_FSPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y CONFIG_WDT_SBSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/lx2162aqds_tfa_verified_boot_defconfig b/configs/lx2162aqds_tfa_verified_boot_defconfig index b31403a25e4..fa2a02753f4 100644 --- a/configs/lx2162aqds_tfa_verified_boot_defconfig +++ b/configs/lx2162aqds_tfa_verified_boot_defconfig @@ -10,6 +10,7 @@ CONFIG_ENV_OFFSET=0x500000 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="fsl-lx2162a-qds" +CONFIG_FSL_USE_PCA9547_MUX=y CONFIG_FSPI_AHB_EN_4BYTE=y CONFIG_ARMV8_SEC_FIRMWARE_SUPPORT=y CONFIG_SEC_FIRMWARE_ARMV8_PSCI=y @@ -77,7 +78,6 @@ CONFIG_E1000=y CONFIG_MDIO_MUX_I2CREG=y CONFIG_FSL_LS_MDIO=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_LAYERSCAPE_RC=y CONFIG_DM_RTC=y CONFIG_RTC_PCF2127=y @@ -90,10 +90,8 @@ CONFIG_NXP_FSPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_WDT=y CONFIG_WDT_SBSA=y CONFIG_EFI_LOADER_BOUNCE_BUFFER=y -CONFIG_FSL_USE_PCA9547_MUX=y diff --git a/configs/m53menlo_defconfig b/configs/m53menlo_defconfig index 277be6daaf9..ba9ec7bd774 100644 --- a/configs/m53menlo_defconfig +++ b/configs/m53menlo_defconfig @@ -87,7 +87,6 @@ CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_MX5=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 09f4a373b0b..62f0b2f1c2a 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -48,7 +48,6 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 8d7b9ef15e0..92378389168 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -37,7 +37,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/meerkat96_defconfig b/configs/meerkat96_defconfig index 0c40546cf19..ee6b9e14d05 100644 --- a/configs/meerkat96_defconfig +++ b/configs/meerkat96_defconfig @@ -47,7 +47,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/miqi-rk3288_defconfig b/configs/miqi-rk3288_defconfig index 9a728ccaa1f..d815fda9a1e 100644 --- a/configs/miqi-rk3288_defconfig +++ b/configs/miqi-rk3288_defconfig @@ -71,11 +71,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_DISPLAY=y diff --git a/configs/mt7620_rfb_defconfig b/configs/mt7620_rfb_defconfig index 82b525c4d43..cbdd9b67baf 100644 --- a/configs/mt7620_rfb_defconfig +++ b/configs/mt7620_rfb_defconfig @@ -68,7 +68,6 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SPI=y CONFIG_MT7620_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_LZMA=y diff --git a/configs/mt7622_rfb_defconfig b/configs/mt7622_rfb_defconfig index 6c0d4ba46d3..ebb4045cda2 100644 --- a/configs/mt7622_rfb_defconfig +++ b/configs/mt7622_rfb_defconfig @@ -39,7 +39,6 @@ CONFIG_PHY_FIXED=y CONFIG_DM_ETH=y CONFIG_MEDIATEK_ETH=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_MEDIATEK=y CONFIG_PINCTRL=y CONFIG_PINCONF=y diff --git a/configs/mt7629_rfb_defconfig b/configs/mt7629_rfb_defconfig index a624e706d27..cc0e2633615 100644 --- a/configs/mt7629_rfb_defconfig +++ b/configs/mt7629_rfb_defconfig @@ -50,7 +50,6 @@ CONFIG_REGMAP=y CONFIG_SPL_REGMAP=y CONFIG_SYSCON=y CONFIG_SPL_SYSCON=y -CONFIG_BLK=y CONFIG_CLK=y CONFIG_SPL_CLK=y # CONFIG_MMC is not set @@ -85,7 +84,6 @@ CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_MTK=y CONFIG_USB_STORAGE=y diff --git a/configs/mt8183_pumpkin_defconfig b/configs/mt8183_pumpkin_defconfig index 4ff2cdfb2f1..a2f06a952ab 100644 --- a/configs/mt8183_pumpkin_defconfig +++ b/configs/mt8183_pumpkin_defconfig @@ -65,7 +65,6 @@ CONFIG_DM_SERIAL=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_MTK_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_MTU3=y CONFIG_USB_GADGET=y diff --git a/configs/mt8512_bm1_emmc_defconfig b/configs/mt8512_bm1_emmc_defconfig index b835436735b..3e2d6458296 100644 --- a/configs/mt8512_bm1_emmc_defconfig +++ b/configs/mt8512_bm1_emmc_defconfig @@ -46,7 +46,6 @@ CONFIG_MTK_SERIAL=y CONFIG_TIMER=y CONFIG_MTK_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_MTU3=y diff --git a/configs/mt8516_pumpkin_defconfig b/configs/mt8516_pumpkin_defconfig index cafad0ef622..0a6c1fccaed 100644 --- a/configs/mt8516_pumpkin_defconfig +++ b/configs/mt8516_pumpkin_defconfig @@ -66,7 +66,6 @@ CONFIG_DM_SERIAL=y CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_MTK_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_MT85XX=y CONFIG_USB_GADGET=y diff --git a/configs/mt8518_ap1_emmc_defconfig b/configs/mt8518_ap1_emmc_defconfig index 09075765f85..e6c2dd019d6 100644 --- a/configs/mt8518_ap1_emmc_defconfig +++ b/configs/mt8518_ap1_emmc_defconfig @@ -37,7 +37,6 @@ CONFIG_MTK_SERIAL=y CONFIG_TIMER=y CONFIG_MTK_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_MT85XX=y CONFIG_USB_GADGET=y diff --git a/configs/mvebu_crb_cn9130_defconfig b/configs/mvebu_crb_cn9130_defconfig index 65cce2e63bc..7acb8fedd4b 100644 --- a/configs/mvebu_crb_cn9130_defconfig +++ b/configs/mvebu_crb_cn9130_defconfig @@ -63,7 +63,6 @@ CONFIG_PHY_GIGE=y CONFIG_MVPP2=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -73,7 +72,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mvebu_db-88f3720_defconfig b/configs/mvebu_db-88f3720_defconfig index ff4668e8376..a9578570802 100644 --- a/configs/mvebu_db-88f3720_defconfig +++ b/configs/mvebu_db-88f3720_defconfig @@ -58,7 +58,6 @@ CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_AARDVARK=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -68,7 +67,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_MVEBU_A3700_UART=y CONFIG_MVEBU_A3700_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mvebu_db_armada8k_defconfig b/configs/mvebu_db_armada8k_defconfig index b11badb52a3..1ae7ea758c6 100644 --- a/configs/mvebu_db_armada8k_defconfig +++ b/configs/mvebu_db_armada8k_defconfig @@ -52,7 +52,6 @@ CONFIG_PHY_GIGE=y CONFIG_MVPP2=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -62,7 +61,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mvebu_db_cn9130_defconfig b/configs/mvebu_db_cn9130_defconfig index bc12b75c79d..73e778cdd50 100644 --- a/configs/mvebu_db_cn9130_defconfig +++ b/configs/mvebu_db_cn9130_defconfig @@ -67,7 +67,6 @@ CONFIG_PHY_GIGE=y CONFIG_MVPP2=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -77,7 +76,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mvebu_espressobin-88f3720_defconfig b/configs/mvebu_espressobin-88f3720_defconfig index 78796115cd3..8ddc08dec07 100644 --- a/configs/mvebu_espressobin-88f3720_defconfig +++ b/configs/mvebu_espressobin-88f3720_defconfig @@ -71,7 +71,6 @@ CONFIG_E1000=y CONFIG_MVNETA=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_AARDVARK=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -82,7 +81,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_MVEBU_A3700_UART=y CONFIG_MVEBU_A3700_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mvebu_mcbin-88f8040_defconfig b/configs/mvebu_mcbin-88f8040_defconfig index 68a98f07326..cc45999ac16 100644 --- a/configs/mvebu_mcbin-88f8040_defconfig +++ b/configs/mvebu_mcbin-88f8040_defconfig @@ -57,7 +57,6 @@ CONFIG_PHY_GIGE=y CONFIG_MVPP2=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -68,7 +67,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mvebu_puzzle-m801-88f8040_defconfig b/configs/mvebu_puzzle-m801-88f8040_defconfig index dd5ac764198..c6822163209 100644 --- a/configs/mvebu_puzzle-m801-88f8040_defconfig +++ b/configs/mvebu_puzzle-m801-88f8040_defconfig @@ -61,7 +61,6 @@ CONFIG_PHY_GIGE=y CONFIG_MVPP2=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_DW_MVEBU=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -74,7 +73,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y # CONFIG_EFI_LOADER is not set diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index c6f3c3f9123..47fa05945be 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -42,6 +42,5 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_CONS_INDEX=0 CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 4fc764829e7..3b916ad82e0 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -49,10 +48,5 @@ CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_SPLASH_SCREEN=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index ff1d0ed24ee..3128af77584 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -49,10 +48,5 @@ CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_SPLASH_SCREEN=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 94e4244128e..7a96d7db4d4 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -50,10 +49,5 @@ CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_SPLASH_SCREEN=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index 2122bbe870a..7caefa8e2e0 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -20,7 +20,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPIO=y CONFIG_CMD_MMC=y CONFIG_CMD_NAND_TRIMFFS=y -CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -46,10 +45,5 @@ CONFIG_MII=y CONFIG_CONS_INDEX=0 CONFIG_SPI=y CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_SPLASH_SCREEN=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index a5bda10a2ed..6c8b9b62e51 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -48,7 +48,6 @@ CONFIG_MXC_UART=y CONFIG_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_MX5=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mx53cx9020_defconfig b/configs/mx53cx9020_defconfig index 4d25373966d..8ee442f2b90 100644 --- a/configs/mx53cx9020_defconfig +++ b/configs/mx53cx9020_defconfig @@ -32,7 +32,6 @@ CONFIG_PINCTRL_IMX5=y CONFIG_DM_REGULATOR=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_MX5=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 6c68234746b..296886dd6c8 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -47,7 +47,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_MX5=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/mx53ppd_defconfig b/configs/mx53ppd_defconfig index e34f72796ce..4a8fa34c275 100644 --- a/configs/mx53ppd_defconfig +++ b/configs/mx53ppd_defconfig @@ -68,7 +68,6 @@ CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_MX5=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 5252e3f46bc..c2b867146f8 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -67,7 +67,6 @@ CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y # CONFIG_BACKLIGHT is not set diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index d9f54da3e7e..7d0453ac384 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -66,7 +66,6 @@ CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y CONFIG_USB_GADGET=y diff --git a/configs/mx6sabreauto_defconfig b/configs/mx6sabreauto_defconfig index e1d8eb606bf..6c2997e60f3 100644 --- a/configs/mx6sabreauto_defconfig +++ b/configs/mx6sabreauto_defconfig @@ -91,16 +91,15 @@ CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index 6284d9daae0..8df4afd1a7b 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -91,7 +91,6 @@ CONFIG_FEC_MXC=y CONFIG_RGMII=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_REGULATOR=y @@ -102,14 +101,13 @@ CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 9469c35bbd6..9e1032938f1 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -64,7 +64,6 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 5dd0dfba266..8df10ed2ae5 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -64,7 +64,6 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 99fd2186d0d..c67eb4b4ee7 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -73,7 +73,6 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/mx6sllevk_defconfig b/configs/mx6sllevk_defconfig index 771d69b3f0d..9f02ec838a0 100644 --- a/configs/mx6sllevk_defconfig +++ b/configs/mx6sllevk_defconfig @@ -49,7 +49,6 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/mx6sllevk_plugin_defconfig b/configs/mx6sllevk_plugin_defconfig index d0001223a9b..6fc49150b3c 100644 --- a/configs/mx6sllevk_plugin_defconfig +++ b/configs/mx6sllevk_plugin_defconfig @@ -50,7 +50,6 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 4bd1988c488..d888e7255d2 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -62,7 +62,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 225b7e4b119..67dfcda8fa7 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -52,7 +52,6 @@ CONFIG_PHYLIB=y CONFIG_PHY_ATHEROS=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_DM_PMIC=y @@ -67,7 +66,6 @@ CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index ee80038fdca..26280fb3b15 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -82,7 +82,6 @@ CONFIG_FSL_QSPI=y CONFIG_SOFT_SPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index 6b8fd3b5995..150dbaf5726 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -77,7 +77,6 @@ CONFIG_FSL_QSPI=y CONFIG_SOFT_SPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index dffb66ea354..d3079c1d9e4 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -71,17 +71,16 @@ CONFIG_DM_SPI=y CONFIG_SOFT_SPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_SPLASH_SCREEN=y CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_ERRNO_STR=y diff --git a/configs/mx7dsabresd_qspi_defconfig b/configs/mx7dsabresd_qspi_defconfig index 023f2bb60e0..f5d2f253657 100644 --- a/configs/mx7dsabresd_qspi_defconfig +++ b/configs/mx7dsabresd_qspi_defconfig @@ -78,17 +78,16 @@ CONFIG_FSL_QSPI=y CONFIG_SOFT_SPI=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_SPLASH_SCREEN=y CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_ERRNO_STR=y diff --git a/configs/mx7ulp_com_defconfig b/configs/mx7ulp_com_defconfig index 698e138910a..62992fecdf2 100644 --- a/configs/mx7ulp_com_defconfig +++ b/configs/mx7ulp_com_defconfig @@ -47,7 +47,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_FSL_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/myir_mys_6ulx_defconfig b/configs/myir_mys_6ulx_defconfig index f16a1b663db..3c93f580690 100644 --- a/configs/myir_mys_6ulx_defconfig +++ b/configs/myir_mys_6ulx_defconfig @@ -68,5 +68,4 @@ CONFIG_SYSINFO=y CONFIG_SYSINFO_SMBIOS=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index ec040a2395c..a94f428deff 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -53,13 +53,13 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 72f062e807c..10fcf214466 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -38,7 +38,6 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y @@ -48,6 +47,5 @@ CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 712e029fa1c..841842cefb6 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y @@ -55,6 +54,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/netgear_dgnd3700v2_ram_defconfig b/configs/netgear_dgnd3700v2_ram_defconfig index 47c44812f1f..1f21f685996 100644 --- a/configs/netgear_dgnd3700v2_ram_defconfig +++ b/configs/netgear_dgnd3700v2_ram_defconfig @@ -53,7 +53,6 @@ CONFIG_RESET_BCM6345=y CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index 07047d9592b..1c577faab74 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y @@ -55,6 +54,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 5fe88085306..d5af1150647 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y @@ -55,6 +54,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index df1f6982af7..c152a310a27 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -43,7 +43,6 @@ CONFIG_ENV_ADDR=0x70000 CONFIG_NETCONSOLE=y CONFIG_DM=y CONFIG_SATA_MV=y -CONFIG_BLK=y # CONFIG_MMC is not set CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y @@ -55,6 +54,5 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index df931c752ef..865f6fac84a 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -66,7 +66,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index 9ea4546a75a..7852eb8638c 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -66,7 +66,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 2de5b7cb0c4..2007126023d 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -68,7 +68,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 7353081d0bd..af38dd711f2 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -68,7 +68,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index d885749d396..ae00482f9cb 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -66,7 +66,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index caf05de8d9b..92ccabaa26c 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -66,7 +66,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y diff --git a/configs/novena_defconfig b/configs/novena_defconfig index dcbbf4dac02..b24ac93b688 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -68,13 +68,13 @@ CONFIG_IMX_THERMAL=y CONFIG_USB=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_CONTROL_EP=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_SMSC95XX=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set CONFIG_SYS_WHITE_ON_BLACK=y diff --git a/configs/nsa310s_defconfig b/configs/nsa310s_defconfig index fac0322e2be..8765dc3dd18 100644 --- a/configs/nsa310s_defconfig +++ b/configs/nsa310s_defconfig @@ -7,17 +7,17 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_NSA310S=y CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0xE0000 -CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DEFAULT_DEVICE_TREE="kirkwood-nsa310s" +CONFIG_IDENT_STRING="\nZyXEL NSA310S/320S 1/2-Bay Power Media Server" CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nsa310s => " -CONFIG_IDENT_STRING="\nZyXEL NSA310S/320S 1/2-Bay Power Media Server" CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y +CONFIG_CMD_SATA=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -30,13 +30,18 @@ CONFIG_CMD_MTDPARTS=y CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:0xe0000@0x0(uboot),0x20000@0xe0000(uboot_env),0x100000@0x100000(second_stage_uboot),-@0x200000(root)" CONFIG_CMD_UBI=y CONFIG_ISO_PARTITION=y +CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y +CONFIG_DM=y +CONFIG_SATA_MV=y # CONFIG_MMC is not set CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_DM_ETH=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_SYS_NS16550=y @@ -45,12 +50,3 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LZMA=y CONFIG_BZIP2=y -CONFIG_OF_LIBFDT=y -CONFIG_DM=y -CONFIG_BLK=y -CONFIG_OF_CONTROL=y -CONFIG_DM_USB=y -CONFIG_DM_ETH=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_CMD_SATA=y -CONFIG_SATA_MV=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index e3716a90045..3f6bb94c7b8 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -75,17 +75,16 @@ CONFIG_SOUND_MAX98090=y CONFIG_TEGRA114_SPI=y CONFIG_TPM_TIS_INFINEON=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/o4-imx6ull-nano_defconfig b/configs/o4-imx6ull-nano_defconfig index 36e10c659b5..45d4dcadb9d 100644 --- a/configs/o4-imx6ull-nano_defconfig +++ b/configs/o4-imx6ull-nano_defconfig @@ -53,7 +53,6 @@ CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/octeon_ebb7304_defconfig b/configs/octeon_ebb7304_defconfig index bf34ac8cbf2..e69e8730e97 100644 --- a/configs/octeon_ebb7304_defconfig +++ b/configs/octeon_ebb7304_defconfig @@ -54,7 +54,6 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_E1000=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_OCTEON=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y @@ -71,7 +70,6 @@ CONFIG_OCTEON_SPI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_OCTEON=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_STORAGE=y diff --git a/configs/octeon_nic23_defconfig b/configs/octeon_nic23_defconfig index 2dd160a70c5..3d60b36160a 100644 --- a/configs/octeon_nic23_defconfig +++ b/configs/octeon_nic23_defconfig @@ -50,7 +50,6 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_NETDEVICES is not set CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_RAM=y diff --git a/configs/octeontx2_95xx_defconfig b/configs/octeontx2_95xx_defconfig index 745eda9f456..8a912d86b1b 100644 --- a/configs/octeontx2_95xx_defconfig +++ b/configs/octeontx2_95xx_defconfig @@ -89,7 +89,6 @@ CONFIG_DM_ETH=y CONFIG_NET_OCTEONTX2=y CONFIG_OCTEONTX_SMI=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_SRIOV=y CONFIG_PCI_ARID=y diff --git a/configs/octeontx2_96xx_defconfig b/configs/octeontx2_96xx_defconfig index baef32f3767..02bb0f6d5c1 100644 --- a/configs/octeontx2_96xx_defconfig +++ b/configs/octeontx2_96xx_defconfig @@ -103,7 +103,6 @@ CONFIG_NET_OCTEONTX2=y CONFIG_OCTEONTX_SMI=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_SRIOV=y CONFIG_PCI_ARID=y @@ -121,7 +120,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OCTEON_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/octeontx_81xx_defconfig b/configs/octeontx_81xx_defconfig index ebc1d4c251a..e14957c9b1e 100644 --- a/configs/octeontx_81xx_defconfig +++ b/configs/octeontx_81xx_defconfig @@ -105,7 +105,6 @@ CONFIG_NET_OCTEONTX=y CONFIG_OCTEONTX_SMI=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_SRIOV=y CONFIG_PCI_ARID=y @@ -122,7 +121,6 @@ CONFIG_PL01X_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/octeontx_83xx_defconfig b/configs/octeontx_83xx_defconfig index d61ea704d3e..f9f285a899b 100644 --- a/configs/octeontx_83xx_defconfig +++ b/configs/octeontx_83xx_defconfig @@ -102,7 +102,6 @@ CONFIG_NET_OCTEONTX=y CONFIG_OCTEONTX_SMI=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_SRIOV=y CONFIG_PCI_ARID=y @@ -119,7 +118,6 @@ CONFIG_PL01X_SERIAL=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/odroid-c2_defconfig b/configs/odroid-c2_defconfig index 5457ab24002..7c968316404 100644 --- a/configs/odroid-c2_defconfig +++ b/configs/odroid-c2_defconfig @@ -48,7 +48,6 @@ CONFIG_MESON_SERIAL=y CONFIG_SYSINFO=y CONFIG_SYSINFO_SMBIOS=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y diff --git a/configs/odroid-c4_defconfig b/configs/odroid-c4_defconfig index 0c6989d4ba4..356a9c9be29 100644 --- a/configs/odroid-c4_defconfig +++ b/configs/odroid-c4_defconfig @@ -47,7 +47,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/odroid-n2_defconfig b/configs/odroid-n2_defconfig index 065ecbcfb05..bac44b61abb 100644 --- a/configs/odroid-n2_defconfig +++ b/configs/odroid-n2_defconfig @@ -47,7 +47,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index e0b87dfc259..99ac4170a17 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -52,18 +52,17 @@ CONFIG_PMIC_S2MPS11=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_S2MPS11=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_PHY_SAMSUNG=y +CONFIG_USB_HOST_ETHER=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_THOR=y -CONFIG_USB_HOST_ETHER=y CONFIG_VIDEO_BRIDGE=y CONFIG_ERRNO_STR=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 36719d91f66..b95cefd54d0 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -54,8 +54,9 @@ CONFIG_DM_PMIC_MAX77686=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_MAX77686=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 @@ -63,7 +64,5 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x6601 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_USB_FUNCTION_THOR=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_LIB_HW_RAND=y CONFIG_ERRNO_STR=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 896fc87c2ef..aed1f6f9f8b 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -74,7 +74,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_OMAP is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 61b8cad7724..e300b2cda09 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -79,7 +79,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index f58112ef3fa..462f94ed056 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -80,21 +80,20 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y CONFIG_TWL4030_USB=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="TI" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_USB_ETHER=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_MCS7830=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO_OMAP3=y CONFIG_BCH=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 4d96505e361..2571545f0e4 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -69,20 +69,19 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_OMAP3=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_MUSB_OMAP2PLUS=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0x5678 CONFIG_USB_ETHER=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_MCS7830=y -CONFIG_USB_ETHER_SMSC95XX=y CONFIG_VIDEO_OMAP3=y CONFIG_BCH=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 1a7421bd619..b3f763847b7 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -74,7 +74,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_OMAP is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index fa1bdbe33a6..aa8d4cebc7b 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -80,7 +80,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 9e99e8bc699..60ea53a51d4 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -37,9 +37,8 @@ CONFIG_DM_ETH=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_OMAP3=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index fd93dc5c785..4231bf3c5ae 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -38,7 +38,6 @@ CONFIG_DM_ETH=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_OMAP3=y CONFIG_USB_GADGET=y CONFIG_FAT_WRITE=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index a08c7fa6704..16264ae457d 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -46,15 +46,14 @@ CONFIG_SCSI=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_OMAP=y CONFIG_USB_DWC3_PHY_OMAP=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0403 CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 6f95fc4aa59..0cde86a2f96 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -75,7 +75,6 @@ CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_DA8XX=y diff --git a/configs/opos6uldev_defconfig b/configs/opos6uldev_defconfig index e1b39435696..458cf5c888f 100644 --- a/configs/opos6uldev_defconfig +++ b/configs/opos6uldev_defconfig @@ -94,7 +94,6 @@ CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Armadeus Systems" diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 43dbae206c9..932c107c57c 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -38,7 +38,6 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_S5P=y CONFIG_MTD=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 diff --git a/configs/p212_defconfig b/configs/p212_defconfig index 338fcdebbbc..493b33391ee 100644 --- a/configs/p212_defconfig +++ b/configs/p212_defconfig @@ -42,7 +42,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 024afdb5dd1..039293feef4 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -37,14 +37,13 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 5c8452325ba..a4dfed72a1b 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -40,19 +40,17 @@ CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index b613e9f0335..8c3a184d195 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -38,14 +38,13 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/p2771-0000-000_defconfig b/configs/p2771-0000-000_defconfig index 8634ed7dc63..18ec21aaa79 100644 --- a/configs/p2771-0000-000_defconfig +++ b/configs/p2771-0000-000_defconfig @@ -17,7 +17,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y # CONFIG_CMD_NFS is not set @@ -31,10 +30,8 @@ CONFIG_DWC_ETH_QOS=y CONFIG_E1000=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_POWER_DOMAIN=y CONFIG_TEGRA186_POWER_DOMAIN=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/p2771-0000-500_defconfig b/configs/p2771-0000-500_defconfig index d5e9333af60..c0a9a459f75 100644 --- a/configs/p2771-0000-500_defconfig +++ b/configs/p2771-0000-500_defconfig @@ -17,7 +17,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PCI=y CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_BOOTP_PREFER_SERVERIP=y # CONFIG_CMD_NFS is not set @@ -31,10 +30,8 @@ CONFIG_DWC_ETH_QOS=y CONFIG_E1000=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_POWER_DOMAIN=y CONFIG_TEGRA186_POWER_DOMAIN=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/p3450-0000_defconfig b/configs/p3450-0000_defconfig index 81f0ac44f31..9f9a5edd0e2 100644 --- a/configs/p3450-0000_defconfig +++ b/configs/p3450-0000_defconfig @@ -42,20 +42,18 @@ CONFIG_SPI_FLASH_MACRONIX=y CONFIG_RTL8169=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_TEGRA210_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index e26445cc318..4ce36474e2b 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -33,7 +33,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index d3fbc4eca96..45162a5b168 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -69,7 +69,6 @@ CONFIG_SOUND_WM8994=y CONFIG_EXYNOS_SPI=y CONFIG_TPM_TIS_INFINEON=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index d6d97a84c36..1354aa78ae2 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -68,7 +68,6 @@ CONFIG_SOUND_WM8994=y CONFIG_EXYNOS_SPI=y CONFIG_TPM_TIS_INFINEON=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/phycore-am335x-r2-regor_defconfig b/configs/phycore-am335x-r2-regor_defconfig index 87de31d63a9..ec885dc837a 100644 --- a/configs/phycore-am335x-r2-regor_defconfig +++ b/configs/phycore-am335x-r2-regor_defconfig @@ -76,7 +76,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 591ac755321..77ce723f91c 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -77,7 +77,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_OMAP3_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/phycore-rk3288_defconfig b/configs/phycore-rk3288_defconfig index b7a52cfa5c7..8ee99e54c76 100644 --- a/configs/phycore-rk3288_defconfig +++ b/configs/phycore-rk3288_defconfig @@ -73,10 +73,10 @@ CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/phycore_pcl063_defconfig b/configs/phycore_pcl063_defconfig index 104f6a4ebaa..346fae04ea1 100644 --- a/configs/phycore_pcl063_defconfig +++ b/configs/phycore_pcl063_defconfig @@ -61,7 +61,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Phytec" CONFIG_USB_GADGET_VENDOR_NUM=0x01b67 diff --git a/configs/phycore_pcl063_ull_defconfig b/configs/phycore_pcl063_ull_defconfig index f76eb62603b..2520c895e56 100644 --- a/configs/phycore_pcl063_ull_defconfig +++ b/configs/phycore_pcl063_ull_defconfig @@ -50,7 +50,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Phytec" CONFIG_USB_GADGET_VENDOR_NUM=0x01b67 diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index ff15d80b4d2..f8c46fa3470 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -39,7 +39,6 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_FULL is not set CONFIG_DM_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_PIC32=y CONFIG_FAT_WRITE=y diff --git a/configs/pico-dwarf-imx7d_defconfig b/configs/pico-dwarf-imx7d_defconfig index a5dbcc8989b..169a0dacfcc 100644 --- a/configs/pico-dwarf-imx7d_defconfig +++ b/configs/pico-dwarf-imx7d_defconfig @@ -68,7 +68,6 @@ CONFIG_PINCTRL_IMX7=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/pico-hobbit-imx7d_defconfig b/configs/pico-hobbit-imx7d_defconfig index a3ba67fe852..7aecb7c8c44 100644 --- a/configs/pico-hobbit-imx7d_defconfig +++ b/configs/pico-hobbit-imx7d_defconfig @@ -68,7 +68,6 @@ CONFIG_PINCTRL_IMX7=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/pico-imx6_defconfig b/configs/pico-imx6_defconfig index 798eaf363a7..ad9221efe43 100644 --- a/configs/pico-imx6_defconfig +++ b/configs/pico-imx6_defconfig @@ -73,7 +73,6 @@ CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 diff --git a/configs/pico-imx6ul_defconfig b/configs/pico-imx6ul_defconfig index 40e64e80ddb..34cdf85879a 100644 --- a/configs/pico-imx6ul_defconfig +++ b/configs/pico-imx6ul_defconfig @@ -71,7 +71,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="FSL" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 diff --git a/configs/pico-imx7d_bl33_defconfig b/configs/pico-imx7d_bl33_defconfig index 415b2a15224..9970eebef25 100644 --- a/configs/pico-imx7d_bl33_defconfig +++ b/configs/pico-imx7d_bl33_defconfig @@ -63,7 +63,6 @@ CONFIG_CONS_INDEX=4 CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/pico-imx7d_defconfig b/configs/pico-imx7d_defconfig index 41207fbde1b..f8a80f20eba 100644 --- a/configs/pico-imx7d_defconfig +++ b/configs/pico-imx7d_defconfig @@ -68,7 +68,6 @@ CONFIG_PINCTRL_IMX7=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/pico-nymph-imx7d_defconfig b/configs/pico-nymph-imx7d_defconfig index a5dbcc8989b..169a0dacfcc 100644 --- a/configs/pico-nymph-imx7d_defconfig +++ b/configs/pico-nymph-imx7d_defconfig @@ -68,7 +68,6 @@ CONFIG_PINCTRL_IMX7=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/pico-pi-imx7d_defconfig b/configs/pico-pi-imx7d_defconfig index 4f1219f3e68..3f62372fc98 100644 --- a/configs/pico-pi-imx7d_defconfig +++ b/configs/pico-pi-imx7d_defconfig @@ -68,7 +68,6 @@ CONFIG_PINCTRL_IMX7=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index d55bf467536..f47a8f57673 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -32,7 +32,6 @@ CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index b27fc8dbc1a..f253deacc43 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -23,7 +23,6 @@ CONFIG_SYS_PROMPT="pm9261> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.0,nand0=nand" @@ -56,8 +55,6 @@ CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP32 is not set CONFIG_LCD=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index ef18e742d27..193622e5945 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -22,7 +22,6 @@ CONFIG_SYS_PROMPT="u-boot-pm9263> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -57,8 +56,6 @@ CONFIG_ATMEL_USART=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y -CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP32 is not set CONFIG_LCD=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index dd5000e7db0..7941ee27724 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -55,6 +55,5 @@ CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y diff --git a/configs/poplar_defconfig b/configs/poplar_defconfig index 31bfa09a5e3..82833ff0967 100644 --- a/configs/poplar_defconfig +++ b/configs/poplar_defconfig @@ -28,11 +28,11 @@ CONFIG_RESET_HISILICON=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="HiSilicon" CONFIG_USB_GADGET_VENDOR_NUM=0x18d1 CONFIG_USB_GADGET_PRODUCT_NUM=0xd00d CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DWC2_OTG_PHY_BUS_WIDTH_8=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/popmetal-rk3288_defconfig b/configs/popmetal-rk3288_defconfig index 697c5545fbe..5b6d8cab870 100644 --- a/configs/popmetal-rk3288_defconfig +++ b/configs/popmetal-rk3288_defconfig @@ -70,10 +70,10 @@ CONFIG_SYSRESET=y CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index a7f5deb2703..ab890ee20a1 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -77,7 +77,6 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -90,7 +89,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index a1b9ea56cad..55f646537b2 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -41,7 +41,6 @@ CONFIG_DM_ETH=y CONFIG_DM_MDIO=y CONFIG_E1000=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCI_MPC85XX=y CONFIG_DM_RTC=y CONFIG_DM_SERIAL=y diff --git a/configs/qemu_arm64_defconfig b/configs/qemu_arm64_defconfig index f6e586627a8..c31d9340d28 100644 --- a/configs/qemu_arm64_defconfig +++ b/configs/qemu_arm64_defconfig @@ -27,7 +27,6 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x4000000 CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y -CONFIG_BLK=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_MTD=y @@ -44,13 +43,11 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y diff --git a/configs/qemu_arm_defconfig b/configs/qemu_arm_defconfig index 278d8f41f48..cd60f816ef2 100644 --- a/configs/qemu_arm_defconfig +++ b/configs/qemu_arm_defconfig @@ -29,7 +29,6 @@ CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x4000000 CONFIG_SCSI_AHCI=y CONFIG_AHCI_PCI=y -CONFIG_BLK=y CONFIG_DFU_TFTP=y CONFIG_DFU_RAM=y CONFIG_DFU_MTD=y @@ -46,13 +45,11 @@ CONFIG_DM_ETH=y CONFIG_E1000=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_SCSI=y CONFIG_DM_SCSI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_PSCI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index a2d666ebd6e..73b2c99c6ae 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -36,7 +36,6 @@ CONFIG_PCNET=y CONFIG_RTL8139=y CONFIG_TULIP=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y CONFIG_SERIAL_RX_BUFFER=y diff --git a/configs/r8a774a1_beacon_defconfig b/configs/r8a774a1_beacon_defconfig index ee74e89778b..23c423060d2 100644 --- a/configs/r8a774a1_beacon_defconfig +++ b/configs/r8a774a1_beacon_defconfig @@ -57,7 +57,6 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/r8a774b1_beacon_defconfig b/configs/r8a774b1_beacon_defconfig index 90074f0ae80..034ed219e2b 100644 --- a/configs/r8a774b1_beacon_defconfig +++ b/configs/r8a774b1_beacon_defconfig @@ -62,7 +62,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_RENESAS_RPC_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/r8a774e1_beacon_defconfig b/configs/r8a774e1_beacon_defconfig index 7463618fa72..a6e1ea0e161 100644 --- a/configs/r8a774e1_beacon_defconfig +++ b/configs/r8a774e1_beacon_defconfig @@ -57,7 +57,6 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_SCIF_CONSOLE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/r8a77970_eagle_defconfig b/configs/r8a77970_eagle_defconfig index 99a99e13ffd..5455eb7f49c 100644 --- a/configs/r8a77970_eagle_defconfig +++ b/configs/r8a77970_eagle_defconfig @@ -40,7 +40,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y @@ -69,7 +68,6 @@ CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/r8a77980_condor_defconfig b/configs/r8a77980_condor_defconfig index d7c34a719cb..b1c422f20d0 100644 --- a/configs/r8a77980_condor_defconfig +++ b/configs/r8a77980_condor_defconfig @@ -41,7 +41,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_VERSION_VARIABLE=y CONFIG_REGMAP=y CONFIG_SYSCON=y -CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_RENESAS=y CONFIG_DFU_TFTP=y @@ -70,7 +69,6 @@ CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/r8a77990_ebisu_defconfig b/configs/r8a77990_ebisu_defconfig index 0c5dcb0a201..12d04dada9c 100644 --- a/configs/r8a77990_ebisu_defconfig +++ b/configs/r8a77990_ebisu_defconfig @@ -89,7 +89,6 @@ CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/r8a77995_draak_defconfig b/configs/r8a77995_draak_defconfig index b1186eef146..58d5299ab03 100644 --- a/configs/r8a77995_draak_defconfig +++ b/configs/r8a77995_draak_defconfig @@ -79,7 +79,6 @@ CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/rcar3_salvator-x_defconfig b/configs/rcar3_salvator-x_defconfig index 8e492ceec70..61b984084ff 100644 --- a/configs/rcar3_salvator-x_defconfig +++ b/configs/rcar3_salvator-x_defconfig @@ -82,7 +82,6 @@ CONFIG_DM_ETH=y CONFIG_RENESAS_RAVB=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_RCAR_GEN3=y CONFIG_DM_REGULATOR=y @@ -96,7 +95,6 @@ CONFIG_SYSINFO=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/rcar3_ulcb_defconfig b/configs/rcar3_ulcb_defconfig index e3487589b84..0528dc99d78 100644 --- a/configs/rcar3_ulcb_defconfig +++ b/configs/rcar3_ulcb_defconfig @@ -87,12 +87,11 @@ CONFIG_SCIF_CONSOLE=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_RENESAS_RPC_SPI=y -CONFIG_SYSRESET=y CONFIG_SYSINFO=y +CONFIG_SYSRESET=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 6769cf86f50..0e487b9d4e6 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -60,7 +60,6 @@ CONFIG_MXC_SPI=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index 9db842287ad..d2372cbc8a4 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -71,13 +71,13 @@ CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index ed6628c9228..0c647e0900f 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -68,13 +68,13 @@ CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index b1ea38e92b8..f01b6a39354 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -59,13 +59,13 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index 81516e9144f..ae35633292e 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -59,13 +59,13 @@ CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/rpi_0_w_defconfig b/configs/rpi_0_w_defconfig index ca92645c033..dfa72532ce8 100644 --- a/configs/rpi_0_w_defconfig +++ b/configs/rpi_0_w_defconfig @@ -29,7 +29,6 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index b0aab1bfc53..9001e2b20bc 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -29,7 +29,6 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 7b1b08cc4d9..a2a44aa63eb 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -31,7 +31,6 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/rpi_3_b_plus_defconfig b/configs/rpi_3_b_plus_defconfig index 62ef2dd51a4..e34302ddf8e 100644 --- a/configs/rpi_3_b_plus_defconfig +++ b/configs/rpi_3_b_plus_defconfig @@ -31,7 +31,6 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index a19a42839e2..c48ec9c3ef1 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -31,7 +31,6 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/rpi_4_32b_defconfig b/configs/rpi_4_32b_defconfig index e3ccdf7adfb..b1503e91fbd 100644 --- a/configs/rpi_4_32b_defconfig +++ b/configs/rpi_4_32b_defconfig @@ -33,7 +33,6 @@ CONFIG_MMC_SDHCI_BCM2835=y CONFIG_DM_ETH=y CONFIG_BCMGENET=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_BRCMSTB=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set @@ -42,7 +41,6 @@ CONFIG_DM_RNG=y CONFIG_RNG_IPROC200=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y diff --git a/configs/rpi_4_defconfig b/configs/rpi_4_defconfig index b41d29836df..9375885622a 100644 --- a/configs/rpi_4_defconfig +++ b/configs/rpi_4_defconfig @@ -33,7 +33,6 @@ CONFIG_MMC_SDHCI_BCM2835=y CONFIG_DM_ETH=y CONFIG_BCMGENET=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_BRCMSTB=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set @@ -42,7 +41,6 @@ CONFIG_DM_RNG=y CONFIG_RNG_IPROC200=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y diff --git a/configs/rpi_arm64_defconfig b/configs/rpi_arm64_defconfig index 84e223790cc..6b18a8cada7 100644 --- a/configs/rpi_arm64_defconfig +++ b/configs/rpi_arm64_defconfig @@ -28,7 +28,6 @@ CONFIG_MMC_SDHCI_BCM2835=y CONFIG_DM_ETH=y CONFIG_BCMGENET=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_BRCMSTB=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set @@ -37,7 +36,6 @@ CONFIG_DM_RNG=y CONFIG_RNG_IPROC200=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_DWC2=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 1880f22c5d2..48ed929afa2 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -29,7 +29,6 @@ CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_KEYBOARD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/s400_defconfig b/configs/s400_defconfig index 2b55eedd5e5..313c6575cda 100644 --- a/configs/s400_defconfig +++ b/configs/s400_defconfig @@ -39,7 +39,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index 734a99f8efa..f6bb60e9ca8 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -43,7 +43,6 @@ CONFIG_MTD=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_MAX8998=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 diff --git a/configs/sama5d27_giantboard_defconfig b/configs/sama5d27_giantboard_defconfig index f3bec6a1a29..34f259f446f 100644 --- a/configs/sama5d27_giantboard_defconfig +++ b/configs/sama5d27_giantboard_defconfig @@ -76,7 +76,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d27_som1_ek_mmc1_defconfig b/configs/sama5d27_som1_ek_mmc1_defconfig index 525b7a50280..4d00bb0b737 100644 --- a/configs/sama5d27_som1_ek_mmc1_defconfig +++ b/configs/sama5d27_som1_ek_mmc1_defconfig @@ -87,7 +87,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d27_som1_ek_mmc_defconfig b/configs/sama5d27_som1_ek_mmc_defconfig index 3eb1cdcd078..920e3519505 100644 --- a/configs/sama5d27_som1_ek_mmc_defconfig +++ b/configs/sama5d27_som1_ek_mmc_defconfig @@ -87,7 +87,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d27_som1_ek_qspiflash_defconfig b/configs/sama5d27_som1_ek_qspiflash_defconfig index 0ddc36fbb28..e832c908c4e 100644 --- a/configs/sama5d27_som1_ek_qspiflash_defconfig +++ b/configs/sama5d27_som1_ek_qspiflash_defconfig @@ -95,7 +95,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d27_wlsom1_ek_mmc_defconfig b/configs/sama5d27_wlsom1_ek_mmc_defconfig index 1ca5e44a796..5bcf6715fad 100644 --- a/configs/sama5d27_wlsom1_ek_mmc_defconfig +++ b/configs/sama5d27_wlsom1_ek_mmc_defconfig @@ -92,7 +92,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig index 04d7e423999..61189d68302 100644 --- a/configs/sama5d27_wlsom1_ek_qspiflash_defconfig +++ b/configs/sama5d27_wlsom1_ek_qspiflash_defconfig @@ -104,7 +104,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d2_ptc_ek_mmc_defconfig b/configs/sama5d2_ptc_ek_mmc_defconfig index 31c5dccf293..8e8d41bb509 100644 --- a/configs/sama5d2_ptc_ek_mmc_defconfig +++ b/configs/sama5d2_ptc_ek_mmc_defconfig @@ -66,7 +66,6 @@ CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_W1=y diff --git a/configs/sama5d2_ptc_ek_nandflash_defconfig b/configs/sama5d2_ptc_ek_nandflash_defconfig index 4d0d2b525f8..cd73859db12 100644 --- a/configs/sama5d2_ptc_ek_nandflash_defconfig +++ b/configs/sama5d2_ptc_ek_nandflash_defconfig @@ -66,7 +66,6 @@ CONFIG_ATMEL_USART=y CONFIG_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_W1=y diff --git a/configs/sama5d2_xplained_emmc_defconfig b/configs/sama5d2_xplained_emmc_defconfig index f4fb7e6c2a9..69b30621846 100644 --- a/configs/sama5d2_xplained_emmc_defconfig +++ b/configs/sama5d2_xplained_emmc_defconfig @@ -86,7 +86,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 9322647071f..d1e8a5beb6f 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -88,7 +88,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d2_xplained_qspiflash_defconfig b/configs/sama5d2_xplained_qspiflash_defconfig index 0f9a827616e..5280dec7446 100644 --- a/configs/sama5d2_xplained_qspiflash_defconfig +++ b/configs/sama5d2_xplained_qspiflash_defconfig @@ -87,7 +87,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 8897fea6722..051dab1d50e 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -91,7 +91,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 6d42a7ab2d6..b07eebd4b86 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -80,7 +80,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_W1=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index c0e36860b0f..4666dd07945 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -79,7 +79,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_W1=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 69d1f3ec75c..65b6d75a2e2 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -88,7 +88,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 9107eee738b..a1852a485eb 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -86,7 +86,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index bf2d5164d25..e1706d9d43f 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -89,7 +89,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 01aa9d0ffa9..e7638636237 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -81,7 +81,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index a27293e57f5..b717e2e2882 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -81,7 +81,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index bafad6b5fb3..2885d6caea2 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -87,7 +87,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 4420a507823..972038afbff 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -79,7 +79,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 0ad8e84ea2e..4de5e015f10 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -79,7 +79,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 97fafcca4d1..ec9fdd8d6ec 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -82,7 +82,6 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_ATMEL_PIT_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 5fb1da49e4b..f7098b49698 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -158,7 +158,6 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_SANDBOX=y CONFIG_PHY=y CONFIG_PHY_SANDBOX=y @@ -213,7 +212,6 @@ CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index a1e77a511db..96c9f617a07 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -18,6 +18,13 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_BOOTSTAGE_FDT=y CONFIG_BOOTSTAGE_STASH=y CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Enter password "a" in %d seconds to stop autoboot\n" +CONFIG_AUTOBOOT_ENCRYPTION=y +CONFIG_AUTOBOOT_SHA256_FALLBACK=y +CONFIG_AUTOBOOT_NEVER_TIMEOUT=y +CONFIG_AUTOBOOT_STOP_STR_ENABLE=y +CONFIG_AUTOBOOT_STOP_STR_CRYPT="$5$rounds=640000$HrpE65IkB8CM5nCL$BKT3QdF98Bo8fJpTr9tjZLZQyzqPASBY20xuK5Rent9" CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 CONFIG_PRE_CONSOLE_BUFFER=y @@ -192,7 +199,6 @@ CONFIG_MUX_MMIO=y CONFIG_DM_ETH=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_SANDBOX=y CONFIG_PHY=y @@ -228,6 +234,9 @@ CONFIG_DM_PWM=y CONFIG_PWM_CROS_EC=y CONFIG_PWM_SANDBOX=y CONFIG_RAM=y +CONFIG_DM_REBOOT_MODE=y +CONFIG_DM_REBOOT_MODE_GPIO=y +CONFIG_DM_REBOOT_MODE_RTC=y CONFIG_REMOTEPROC_SANDBOX=y CONFIG_DM_RESET=y CONFIG_SANDBOX_RESET=y @@ -255,7 +264,6 @@ CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y @@ -287,19 +295,6 @@ CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y -CONFIG_CRYPT_PW=y -CONFIG_CRYPT_PW_SHA256=y -CONFIG_CRYPT_PW_SHA512=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Enter password "a" in %d seconds to stop autoboot\n" -CONFIG_AUTOBOOT_ENCRYPTION=y -CONFIG_AUTOBOOT_STOP_STR_ENABLE=y -CONFIG_AUTOBOOT_STOP_STR_CRYPT="$5$rounds=640000$HrpE65IkB8CM5nCL$BKT3QdF98Bo8fJpTr9tjZLZQyzqPASBY20xuK5Rent9" -CONFIG_AUTOBOOT_NEVER_TIMEOUT=y -CONFIG_AUTOBOOT_SHA256_FALLBACK=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y -CONFIG_DM_REBOOT_MODE=y -CONFIG_DM_REBOOT_MODE_GPIO=y -CONFIG_DM_REBOOT_MODE_RTC=y diff --git a/configs/sandbox_flattree_defconfig b/configs/sandbox_flattree_defconfig index 869b2bc95ab..a6e2544dc13 100644 --- a/configs/sandbox_flattree_defconfig +++ b/configs/sandbox_flattree_defconfig @@ -134,7 +134,6 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_REGION_MULTI_ENTRY=y CONFIG_PCI_SANDBOX=y CONFIG_PHY=y @@ -186,7 +185,6 @@ CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y diff --git a/configs/sandbox_noinst_defconfig b/configs/sandbox_noinst_defconfig index 13f62729f1b..d837029a93b 100644 --- a/configs/sandbox_noinst_defconfig +++ b/configs/sandbox_noinst_defconfig @@ -152,7 +152,6 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_SANDBOX=y CONFIG_PHY=y CONFIG_PHY_SANDBOX=y @@ -204,7 +203,6 @@ CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y diff --git a/configs/sandbox_spl_defconfig b/configs/sandbox_spl_defconfig index 66bda2a1ac1..edb21035413 100644 --- a/configs/sandbox_spl_defconfig +++ b/configs/sandbox_spl_defconfig @@ -154,7 +154,6 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_DM_ETH=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_SANDBOX=y CONFIG_PHY=y CONFIG_PHY_SANDBOX=y @@ -206,7 +205,6 @@ CONFIG_TIMER=y CONFIG_TIMER_EARLY=y CONFIG_SANDBOX_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EMUL=y CONFIG_USB_KEYBOARD=y CONFIG_DM_VIDEO=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index c0bef12c3a9..aef9a1c681b 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -40,7 +40,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_ULPI_VIEWPORT=y diff --git a/configs/seeed_npi_imx6ull_defconfig b/configs/seeed_npi_imx6ull_defconfig index 71ab08fb7dc..46daa03af2b 100644 --- a/configs/seeed_npi_imx6ull_defconfig +++ b/configs/seeed_npi_imx6ull_defconfig @@ -68,5 +68,4 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/sei510_defconfig b/configs/sei510_defconfig index 8ff99cbea04..63b3043a152 100644 --- a/configs/sei510_defconfig +++ b/configs/sei510_defconfig @@ -61,7 +61,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/sei610_defconfig b/configs/sei610_defconfig index 51c7d600518..56f136ed961 100644 --- a/configs/sei610_defconfig +++ b/configs/sei610_defconfig @@ -61,7 +61,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/sfr_nb4-ser_ram_defconfig b/configs/sfr_nb4-ser_ram_defconfig index ca4ef80d181..752c17d3d4a 100644 --- a/configs/sfr_nb4-ser_ram_defconfig +++ b/configs/sfr_nb4-ser_ram_defconfig @@ -56,7 +56,6 @@ CONFIG_RESET_BCM6345=y CONFIG_DM_SERIAL=y CONFIG_BCM6345_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_OHCI_HCD=y diff --git a/configs/sheevaplug_defconfig b/configs/sheevaplug_defconfig index 4c7259e6d71..d09789a96e0 100644 --- a/configs/sheevaplug_defconfig +++ b/configs/sheevaplug_defconfig @@ -19,6 +19,7 @@ CONFIG_CMD_BOOTZ=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MMC=y CONFIG_CMD_NAND=y +CONFIG_CMD_SATA=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y @@ -36,24 +37,21 @@ CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_NAND=y +CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETCONSOLE=y CONFIG_DM=y +CONFIG_SATA_MV=y CONFIG_MVEBU_MMC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y +CONFIG_DM_ETH=y CONFIG_MVGBE=y CONFIG_MII=y CONFIG_DM_RTC=y CONFIG_RTC_MV=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LZMA=y CONFIG_BZIP2=y -CONFIG_BLK=y -CONFIG_DM_ETH=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_CMD_SATA=y -CONFIG_SATA_MV=y diff --git a/configs/sifive_unmatched_defconfig b/configs/sifive_unmatched_defconfig index 4caf0de5dc7..c90b7bbeef0 100644 --- a/configs/sifive_unmatched_defconfig +++ b/configs/sifive_unmatched_defconfig @@ -35,6 +35,5 @@ CONFIG_PCI=y CONFIG_PCIE_DW_SIFIVE=y CONFIG_DM_RESET=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y diff --git a/configs/silinux_ek874_defconfig b/configs/silinux_ek874_defconfig index 10c7af1a2f0..0377c9e28e9 100644 --- a/configs/silinux_ek874_defconfig +++ b/configs/silinux_ek874_defconfig @@ -66,7 +66,6 @@ CONFIG_RENESAS_RPC_SPI=y CONFIG_TEE=y CONFIG_OPTEE=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 73440cd98ce..268451ff9f3 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -79,7 +79,6 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -92,7 +91,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index 56ea0fe6dff..6ef61efb8cc 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -35,7 +35,6 @@ CONFIG_SYS_PROMPT="U-Boot# " CONFIG_CMD_DFU=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_NAND=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -63,15 +62,11 @@ CONFIG_NAND_ATMEL=y CONFIG_PHYLIB=y CONFIG_ATMEL_USART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" CONFIG_USB_GADGET_VENDOR_NUM=0x0908 CONFIG_USB_GADGET_PRODUCT_NUM=0x02d2 CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y -CONFIG_USB_ETHER_MCS7830=y CONFIG_WDT=y CONFIG_WDT_AT91=y CONFIG_SPL_TINY_MEMSET=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index a2a20cf6c4c..0a7f1c515f0 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -60,7 +60,6 @@ CONFIG_SOUND_MAX98095=y CONFIG_SOUND_WM8994=y CONFIG_EXYNOS_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index 04b560a8a80..b3cb188f5fe 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -48,7 +48,6 @@ CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_EXYNOS_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 568f95a813c..fcc655c1f57 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -30,4 +30,3 @@ CONFIG_MTD=y CONFIG_SMC911X=y CONFIG_SMC911X_BASE=0x5000000 CONFIG_USB=y -CONFIG_DM_USB=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index c52e7cbd886..20a8211f615 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -22,20 +22,8 @@ CONFIG_CMD_MMC=y # CONFIG_CMD_NFS is not set CONFIG_ENV_OVERWRITE=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_BUF_ADDR=0x82000000 -CONFIG_FASTBOOT_BUF_SIZE=0x2000000 -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=0 CONFIG_SYS_OMAP24_I2C_SPEED=400000 CONFIG_TWL4030_INPUT=y CONFIG_MMC_OMAP_HS=y CONFIG_CONS_INDEX=3 -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_OMAP2PLUS=y -CONFIG_TWL4030_USB=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 CONFIG_OF_LIBFDT=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index cb7dabfaba6..d6b16802b18 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -77,7 +77,6 @@ CONFIG_SOUND_WM8994=y CONFIG_EXYNOS_SPI=y CONFIG_TPM_TIS_INFINEON=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/socfpga_agilex_atf_defconfig b/configs/socfpga_agilex_atf_defconfig index 1a57a6e5d9d..39e3eba461c 100644 --- a/configs/socfpga_agilex_atf_defconfig +++ b/configs/socfpga_agilex_atf_defconfig @@ -65,7 +65,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/configs/socfpga_agilex_defconfig b/configs/socfpga_agilex_defconfig index 2dfac1db799..15713ee6db9 100644 --- a/configs/socfpga_agilex_defconfig +++ b/configs/socfpga_agilex_defconfig @@ -58,7 +58,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/configs/socfpga_agilex_vab_defconfig b/configs/socfpga_agilex_vab_defconfig index 3135b61d6bf..d494528a58b 100644 --- a/configs/socfpga_agilex_vab_defconfig +++ b/configs/socfpga_agilex_vab_defconfig @@ -66,7 +66,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/configs/socfpga_arria10_defconfig b/configs/socfpga_arria10_defconfig index 17f13ff4d56..01ebb0e3e91 100644 --- a/configs/socfpga_arria10_defconfig +++ b/configs/socfpga_arria10_defconfig @@ -51,6 +51,5 @@ CONFIG_TIMER=y CONFIG_SPL_TIMER=y CONFIG_DESIGNWARE_APB_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y # CONFIG_SPL_WDT is not set diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index b9198abbf12..80f3cd1892d 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -59,7 +59,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="altera" diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index fb51921006d..5d03b81a17a 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -60,7 +60,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="altera" diff --git a/configs/socfpga_dbm_soc1_defconfig b/configs/socfpga_dbm_soc1_defconfig index e622bb85e6c..fb1a5050e77 100644 --- a/configs/socfpga_dbm_soc1_defconfig +++ b/configs/socfpga_dbm_soc1_defconfig @@ -58,7 +58,6 @@ CONFIG_MII=y CONFIG_DM_RESET=y CONFIG_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index 20626c115a1..6b1b6d1921f 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -56,7 +56,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="terasic" diff --git a/configs/socfpga_de10_nano_defconfig b/configs/socfpga_de10_nano_defconfig index ef2ce3c4f86..dd9a71e1d9a 100644 --- a/configs/socfpga_de10_nano_defconfig +++ b/configs/socfpga_de10_nano_defconfig @@ -53,7 +53,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="terasic" diff --git a/configs/socfpga_de1_soc_defconfig b/configs/socfpga_de1_soc_defconfig index b99a22bd68d..945ff08d5b6 100644 --- a/configs/socfpga_de1_soc_defconfig +++ b/configs/socfpga_de1_soc_defconfig @@ -47,7 +47,6 @@ CONFIG_MII=y CONFIG_DM_RESET=y CONFIG_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y # CONFIG_SPL_WDT is not set # CONFIG_EFI_LOADER is not set diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 435b46ff623..f39c97d6d1a 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -52,7 +52,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="denx" diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index fe707d6bac9..fed6792e4d3 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -60,7 +60,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="terasic" diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 75ce57256c0..cc4dd95eed7 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -62,7 +62,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="ebv" diff --git a/configs/socfpga_stratix10_atf_defconfig b/configs/socfpga_stratix10_atf_defconfig index 4eed5476a98..ab83e246bdf 100644 --- a/configs/socfpga_stratix10_atf_defconfig +++ b/configs/socfpga_stratix10_atf_defconfig @@ -66,7 +66,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/configs/socfpga_stratix10_defconfig b/configs/socfpga_stratix10_defconfig index f83a90c5aea..99b2fbd4ef4 100644 --- a/configs/socfpga_stratix10_defconfig +++ b/configs/socfpga_stratix10_defconfig @@ -32,6 +32,7 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y +CONFIG_CMD_WDT=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y @@ -39,7 +40,6 @@ CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y -CONFIG_CMD_WDT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y @@ -63,7 +63,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_STORAGE=y CONFIG_DESIGNWARE_WATCHDOG=y diff --git a/configs/socfpga_vining_fpga_defconfig b/configs/socfpga_vining_fpga_defconfig index 09b00f5b494..0334e36f737 100644 --- a/configs/socfpga_vining_fpga_defconfig +++ b/configs/socfpga_vining_fpga_defconfig @@ -89,7 +89,6 @@ CONFIG_SPI=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_DWC2=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="softing" diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 1631b4f162a..72c07179dbf 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -42,7 +42,6 @@ CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_ENV_ADDR=0xFFF40000 CONFIG_ENV_ADDR_REDUND=0xFFF20000 CONFIG_DM=y -CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_FSL=y # CONFIG_MMC is not set @@ -62,7 +61,6 @@ CONFIG_PHY_SMSC=y CONFIG_PHY_VITESSE=y CONFIG_MII=y CONFIG_TSEC_ENET=y -CONFIG_DM_PCI=y CONFIG_PCI_MPC85XX=y CONFIG_DM_RTC=y CONFIG_RTC_RX8025=y @@ -71,7 +69,6 @@ CONFIG_DM_SERIAL=y CONFIG_SERIAL_SEARCH_ALL=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_USB_EHCI_HCD is not set CONFIG_USB_OHCI_HCD=y CONFIG_USB_OHCI_PCI=y diff --git a/configs/somlabs_visionsom_6ull_defconfig b/configs/somlabs_visionsom_6ull_defconfig index 52e34e3b3f7..0c407b3ff9b 100644 --- a/configs/somlabs_visionsom_6ull_defconfig +++ b/configs/somlabs_visionsom_6ull_defconfig @@ -51,7 +51,6 @@ CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_LZO=y # CONFIG_EFI_LOADER is not set diff --git a/configs/spring_defconfig b/configs/spring_defconfig index bbe5ab29a8c..a6cc2b42bf3 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -78,7 +78,6 @@ CONFIG_SOUND_WM8994=y CONFIG_EXYNOS_SPI=y CONFIG_TPM_TIS_INFINEON=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/stih410-b2260_defconfig b/configs/stih410-b2260_defconfig index f86eff94f42..071dac96aff 100644 --- a/configs/stih410-b2260_defconfig +++ b/configs/stih410-b2260_defconfig @@ -43,7 +43,6 @@ CONFIG_STI_ASC_SERIAL=y CONFIG_SYSRESET=y CONFIG_TIMER=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/stm32mp15_basic_defconfig b/configs/stm32mp15_basic_defconfig index ab02c35b124..e6d50b7f7ef 100644 --- a/configs/stm32mp15_basic_defconfig +++ b/configs/stm32mp15_basic_defconfig @@ -146,7 +146,6 @@ CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_STM32_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/stm32mp15_dhcom_basic_defconfig b/configs/stm32mp15_dhcom_basic_defconfig index 17f2c8799e5..d054d94f55d 100644 --- a/configs/stm32mp15_dhcom_basic_defconfig +++ b/configs/stm32mp15_dhcom_basic_defconfig @@ -129,18 +129,17 @@ CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_STM32_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="dh" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y diff --git a/configs/stm32mp15_dhcor_basic_defconfig b/configs/stm32mp15_dhcor_basic_defconfig index cd248747d36..17dae194556 100644 --- a/configs/stm32mp15_dhcor_basic_defconfig +++ b/configs/stm32mp15_dhcor_basic_defconfig @@ -123,18 +123,17 @@ CONFIG_DM_SPI=y CONFIG_STM32_QSPI=y CONFIG_STM32_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="dh" CONFIG_USB_GADGET_VENDOR_NUM=0x0483 CONFIG_USB_GADGET_PRODUCT_NUM=0x5720 CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y CONFIG_BACKLIGHT_GPIO=y CONFIG_VIDEO_LCD_ORISETECH_OTM8009A=y diff --git a/configs/stm32mp15_trusted_defconfig b/configs/stm32mp15_trusted_defconfig index a58ea91d3ef..1671cb24f56 100644 --- a/configs/stm32mp15_trusted_defconfig +++ b/configs/stm32mp15_trusted_defconfig @@ -128,7 +128,6 @@ CONFIG_TEE=y CONFIG_OPTEE=y # CONFIG_OPTEE_TA_AVB is not set CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/stout_defconfig b/configs/stout_defconfig index e8ac46fb7dc..1c87b6fd626 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -77,7 +77,6 @@ CONFIG_PHY_MICREL_KSZ8XXX=y CONFIG_DM_ETH=y CONFIG_SH_ETHER=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_RCAR_GEN2=y CONFIG_PINCTRL=y CONFIG_PINCONF=y @@ -90,7 +89,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SH_QSPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/synquacer_developerbox_defconfig b/configs/synquacer_developerbox_defconfig index ed372f7df90..13736a4f039 100644 --- a/configs/synquacer_developerbox_defconfig +++ b/configs/synquacer_developerbox_defconfig @@ -84,7 +84,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_SYNQUACER_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_STORAGE=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index 4c47d7b5eab..440e9d5d29d 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -53,13 +53,11 @@ CONFIG_CMD_DFU=y CONFIG_CMD_NAND=y # CONFIG_CMD_PINMUX is not set CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y -# CONFIG_DOS_PARTITION is not set CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y CONFIG_SPL_OF_PLATDATA=y @@ -67,7 +65,6 @@ CONFIG_ENV_IS_IN_NAND=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM=y -CONFIG_BLK=y CONFIG_CLK=y CONFIG_CLK_AT91=y CONFIG_DFU_NAND=y @@ -86,9 +83,7 @@ CONFIG_PINCTRL_AT91=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_ATMEL_USART=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set -CONFIG_USB_STORAGE=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Siemens AG" CONFIG_USB_GADGET_VENDOR_NUM=0x0908 diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index a1f1884bd2f..a14f9d46c9d 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -74,7 +74,6 @@ CONFIG_DM_ETH=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y # CONFIG_PCI_PNP is not set CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y @@ -84,7 +83,6 @@ CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y CONFIG_USB_KEYBOARD=y CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index d6a072e4e5a..9d0b1f01e5a 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -35,7 +35,6 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SLINK=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 1de5c5769c6..529016841fe 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -37,7 +37,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 6d32e6c5be2..a298e417b0d 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -47,7 +47,6 @@ CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_EFI_PARTITION=y -# CONFIG_PARTITION_UUIDS is not set # CONFIG_SPL_PARTITION_UUIDS is not set CONFIG_ENV_OVERWRITE=y CONFIG_USE_ENV_SPI_MAX_HZ=y @@ -56,7 +55,6 @@ CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SATA_MV=y -CONFIG_BLK=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y CONFIG_FPGA_ALTERA=y @@ -75,7 +73,6 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y diff --git a/configs/tinker-rk3288_defconfig b/configs/tinker-rk3288_defconfig index 196348ac6f4..a2d2aa21baf 100644 --- a/configs/tinker-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -77,11 +77,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y CONFIG_DISPLAY=y CONFIG_VIDEO_ROCKCHIP=y diff --git a/configs/tinker-s-rk3288_defconfig b/configs/tinker-s-rk3288_defconfig index 3720caabde5..a4c1ff4db7a 100644 --- a/configs/tinker-s-rk3288_defconfig +++ b/configs/tinker-s-rk3288_defconfig @@ -77,11 +77,11 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_DISPLAY=y diff --git a/configs/tools-only_defconfig b/configs/tools-only_defconfig index c6f287e9cbf..f54bc1802ca 100644 --- a/configs/tools-only_defconfig +++ b/configs/tools-only_defconfig @@ -22,7 +22,6 @@ CONFIG_AXI_SANDBOX=y # CONFIG_UDP_FUNCTION_FASTBOOT is not set CONFIG_SANDBOX_GPIO=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_SANDBOX=y CONFIG_DM_RTC=y CONFIG_SOUND=y diff --git a/configs/total_compute_defconfig b/configs/total_compute_defconfig index 63f2e9c3750..d95918ee993 100644 --- a/configs/total_compute_defconfig +++ b/configs/total_compute_defconfig @@ -13,7 +13,6 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_LEGACY_IMAGE_FORMAT=y CONFIG_BOOTDELAY=5 -# CONFIG_USE_BOOTARGS is not set # CONFIG_USE_BOOTCOMMAND is not set # CONFIG_DISPLAY_CPUINFO is not set # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/tplink_wdr4300_defconfig b/configs/tplink_wdr4300_defconfig index 7573c8883f4..849d3329c4e 100644 --- a/configs/tplink_wdr4300_defconfig +++ b/configs/tplink_wdr4300_defconfig @@ -50,7 +50,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_ATH79_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index a3955e1ffc5..17c8c755455 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -47,7 +47,6 @@ CONFIG_DM_PMIC_MAX77686=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_MAX77686=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 64cd5dcdb3b..5709c4fd3c3 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -44,7 +44,6 @@ CONFIG_MTD=y CONFIG_DM_PMIC=y CONFIG_PMIC_MAX8997=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Samsung" CONFIG_USB_GADGET_VENDOR_NUM=0x04e8 diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 3826cc10cec..0b418e731bb 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -36,12 +36,10 @@ CONFIG_SF_DEFAULT_MODE=0 CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_TEGRA20_SFLASH=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/turris_mox_defconfig b/configs/turris_mox_defconfig index fd5b6f351ee..56c027e5fec 100644 --- a/configs/turris_mox_defconfig +++ b/configs/turris_mox_defconfig @@ -73,7 +73,6 @@ CONFIG_PHY_GIGE=y CONFIG_MVNETA=y CONFIG_NVME=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_AARDVARK=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -86,7 +85,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_MVEBU_A3700_UART=y CONFIG_MVEBU_A3700_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_PCI=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/turris_omnia_defconfig b/configs/turris_omnia_defconfig index 5f7b1a67a20..f98cd207888 100644 --- a/configs/turris_omnia_defconfig +++ b/configs/turris_omnia_defconfig @@ -23,11 +23,11 @@ CONFIG_SPL=y CONFIG_DEBUG_UART_BASE=0xd0012000 CONFIG_DEBUG_UART_CLOCK=250000000 CONFIG_DEBUG_UART=y -CONFIG_OF_BOARD_SETUP=y CONFIG_AHCI=y CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y CONFIG_BOOTDELAY=3 CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y @@ -69,11 +69,11 @@ CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MV=y CONFIG_MTD=y CONFIG_DM_MTD=y +CONFIG_SF_DEFAULT_MODE=0x0 +CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_MTD=y -CONFIG_SF_DEFAULT_MODE=0x0 -CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_PHY_MARVELL=y CONFIG_PHY_GIGE=y CONFIG_MVNETA=y @@ -87,7 +87,6 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_WDT=y diff --git a/configs/u200_defconfig b/configs/u200_defconfig index 3b31aa4a1e7..909afc59ea1 100644 --- a/configs/u200_defconfig +++ b/configs/u200_defconfig @@ -41,7 +41,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/uDPU_defconfig b/configs/uDPU_defconfig index 649248d74dc..c7f362a3cdc 100644 --- a/configs/uDPU_defconfig +++ b/configs/uDPU_defconfig @@ -72,7 +72,6 @@ CONFIG_PHY_GIGE=y CONFIG_E1000=y CONFIG_MVNETA=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCI_AARDVARK=y CONFIG_MVEBU_COMPHY_SUPPORT=y CONFIG_PINCTRL=y @@ -86,7 +85,6 @@ CONFIG_MVEBU_A3700_SPI=y CONFIG_SYSINFO=y CONFIG_SYSINFO_SMBIOS=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index 91eb3a49650..b52cfc6673e 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -32,5 +32,4 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_MX5=y diff --git a/configs/variscite_dart6ul_defconfig b/configs/variscite_dart6ul_defconfig index 595e8ecc23b..01cb13f7d77 100644 --- a/configs/variscite_dart6ul_defconfig +++ b/configs/variscite_dart6ul_defconfig @@ -53,7 +53,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Variscite" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 8caaefeae98..cdc76062b0b 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -41,14 +41,13 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_TEGRA114_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="NVIDIA" CONFIG_USB_GADGET_VENDOR_NUM=0x0955 CONFIG_USB_GADGET_PRODUCT_NUM=0x701a CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index bf1965d0b5f..d628840047c 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -33,7 +33,6 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_TEGRA=y CONFIG_USB_ULPI_VIEWPORT=y diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index d969370e25a..2f9c89c5daa 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -103,7 +103,6 @@ CONFIG_SYSRESET_PSCI=y CONFIG_SYSRESET_WATCHDOG=y CONFIG_DM_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y # CONFIG_SPL_DM_USB is not set CONFIG_USB_EHCI_HCD=y CONFIG_IMX_WATCHDOG=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index d73d0d678e2..118b917dfd8 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -45,7 +45,6 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_SMC911X=y CONFIG_SMC911X_32_BIT=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PCIE_ECAM_GENERIC=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 434d90ccd21..07fb27f68b7 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -22,7 +22,6 @@ CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y # CONFIG_CMD_LOADS is not set CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y @@ -40,11 +39,10 @@ CONFIG_PHY_SMSC=y CONFIG_ETH_DESIGNWARE=y CONFIG_ATMEL_USART=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_SMSC95XX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="L+G VInCo" CONFIG_USB_GADGET_ATMEL_USBA=y CONFIG_USB_ETHER=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_SMSC95XX=y diff --git a/configs/vining_2000_defconfig b/configs/vining_2000_defconfig index 92034b34f75..010873882f9 100644 --- a/configs/vining_2000_defconfig +++ b/configs/vining_2000_defconfig @@ -71,7 +71,6 @@ CONFIG_DM_ETH=y CONFIG_FEC_MXC=y CONFIG_MII=y CONFIG_PCI=y -CONFIG_DM_PCI=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y CONFIG_PWM_IMX=y @@ -79,13 +78,12 @@ CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Softing" CONFIG_USB_GADGET_VENDOR_NUM=0x0525 CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y diff --git a/configs/vocore2_defconfig b/configs/vocore2_defconfig index 86692bffeb8..9ca285285ec 100644 --- a/configs/vocore2_defconfig +++ b/configs/vocore2_defconfig @@ -88,7 +88,6 @@ CONFIG_CONS_INDEX=3 CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_STORAGE=y diff --git a/configs/vyasa-rk3288_defconfig b/configs/vyasa-rk3288_defconfig index dd9c0d4a651..2faaa801c5a 100644 --- a/configs/vyasa-rk3288_defconfig +++ b/configs/vyasa-rk3288_defconfig @@ -72,12 +72,12 @@ CONFIG_USB=y CONFIG_USB_DWC2=y CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_DWC2_OTG=y -CONFIG_USB_FUNCTION_MASS_STORAGE=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_FUNCTION_MASS_STORAGE=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set CONFIG_DISPLAY=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index d6b34454c82..fa6e2b123f7 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -72,7 +72,6 @@ CONFIG_DM_SCSI=y CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP8 is not set # CONFIG_VIDEO_BPP32 is not set diff --git a/configs/warp7_bl33_defconfig b/configs/warp7_bl33_defconfig index 0617018f42f..ec078178abf 100644 --- a/configs/warp7_bl33_defconfig +++ b/configs/warp7_bl33_defconfig @@ -54,7 +54,6 @@ CONFIG_MXC_UART=y CONFIG_OPTEE=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 5bac902dd0a..19c0c183f7e 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -60,7 +60,6 @@ CONFIG_MXC_UART=y CONFIG_OPTEE=y CONFIG_IMX_THERMAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_MXC_USB_OTG_HACTIVE=y CONFIG_USB_GADGET=y diff --git a/configs/warp_defconfig b/configs/warp_defconfig index ffad519cd0b..dce2170354b 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -18,7 +18,6 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_PART=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_CACHE=y CONFIG_CMD_EXT2=y @@ -37,13 +36,6 @@ CONFIG_SUPPORT_EMMC_BOOT=y CONFIG_FSL_USDHC=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="FSL" -CONFIG_USB_GADGET_VENDOR_NUM=0x0525 -CONFIG_USB_GADGET_PRODUCT_NUM=0xa4a5 -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_WATCHDOG_TIMEOUT_MSECS=30000 CONFIG_IMX_WATCHDOG=y CONFIG_OF_LIBFDT=y diff --git a/configs/wetek-core2_defconfig b/configs/wetek-core2_defconfig index 7d3e7cc4d18..40726735ba9 100644 --- a/configs/wetek-core2_defconfig +++ b/configs/wetek-core2_defconfig @@ -48,7 +48,6 @@ CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_DEBUG_UART_SKIP_INIT=y CONFIG_MESON_SERIAL=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_DWC3=y diff --git a/configs/x530_defconfig b/configs/x530_defconfig index dbde3923743..0ff095671c4 100644 --- a/configs/x530_defconfig +++ b/configs/x530_defconfig @@ -50,7 +50,6 @@ CONFIG_CMD_UBI=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_ADDR=0x100000 CONFIG_SPL_OF_TRANSLATE=y -CONFIG_BLK=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_MVTWSI=y CONFIG_I2C_MUX=y @@ -74,7 +73,6 @@ CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYS_NS16550=y CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_USB_HOST_ETHER=y diff --git a/configs/xilinx_versal_virt_defconfig b/configs/xilinx_versal_virt_defconfig index 121c3ae7205..fe0afbfb0c3 100644 --- a/configs/xilinx_versal_virt_defconfig +++ b/configs/xilinx_versal_virt_defconfig @@ -98,7 +98,6 @@ CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_ZYNQ_SPI=y CONFIG_USB=y -CONFIG_DM_USB=y CONFIG_DM_USB_GADGET=y CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y diff --git a/configs/xilinx_zynqmp_virt_defconfig b/configs/xilinx_zynqmp_virt_defconfig index 5f32ca49300..bf1081331d3 100644 --- a/configs/xilinx_zynqmp_virt_defconfig +++ b/configs/xilinx_zynqmp_virt_defconfig @@ -165,6 +165,8 @@ CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USB_ULPI=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Xilinx" CONFIG_USB_GADGET_VENDOR_NUM=0x03FD @@ -172,8 +174,6 @@ CONFIG_USB_GADGET_PRODUCT_NUM=0x0300 CONFIG_USB_FUNCTION_THOR=y CONFIG_USB_ETHER=y CONFIG_USB_ETH_CDC=y -CONFIG_USB_HOST_ETHER=y -CONFIG_USB_ETHER_ASIX=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_COPY=y CONFIG_DISPLAY=y diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index f479146e201..2afe4299868 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -17,7 +17,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_AUTO_COMPLETE is not set CONFIG_SYS_PROMPT="zmx25> " CONFIG_CMD_IMLS=y -CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y @@ -33,6 +32,4 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_MII=y CONFIG_MXC_UART=y CONFIG_USB=y -CONFIG_USB_EHCI_HCD=y -CONFIG_USB_STORAGE=y CONFIG_LZO=y
Drop the pre-driver model code from this file.
cmd/pci.c | 212 ------------------------------------------------------ 1 file changed, 212 deletions(-)
diff --git a/cmd/pci.c b/cmd/pci.c index e53b7c858c6..8cfa5bbdaa7 100644 --- a/cmd/pci.c +++ b/cmd/pci.c @@ -47,7 +47,6 @@ static int pci_field_width(enum pci_size_t size) return pci_byte_size(size) * 2; }
-#ifdef CONFIG_DM_PCI static void pci_show_regs(struct udevice *dev, struct pci_reg_info *regs) { for (; regs->name; regs++) { @@ -59,40 +58,7 @@ static void pci_show_regs(struct udevice *dev, struct pci_reg_info *regs) pci_field_width(regs->size), val); } } -#else -static unsigned long pci_read_config(pci_dev_t dev, int offset, - enum pci_size_t size) -{ - u32 val32; - u16 val16; - u8 val8;
- switch (size) { - case PCI_SIZE_8: - pci_read_config_byte(dev, offset, &val8); - return val8; - case PCI_SIZE_16: - pci_read_config_word(dev, offset, &val16); - return val16; - case PCI_SIZE_32: - default: - pci_read_config_dword(dev, offset, &val32); - return val32; - } -} - -static void pci_show_regs(pci_dev_t dev, struct pci_reg_info *regs) -{ - for (; regs->name; regs++) { - printf(" %s =%*s%#.*lx\n", regs->name, - (int)(28 - strlen(regs->name)), "", - pci_field_width(regs->size), - pci_read_config(dev, regs->offset, regs->size)); - } -} -#endif - -#ifdef CONFIG_DM_PCI int pci_bar_show(struct udevice *dev) { u8 header_type; @@ -162,7 +128,6 @@ int pci_bar_show(struct udevice *dev)
return 0; } -#endif
static struct pci_reg_info regs_start[] = { { "vendor ID", PCI_SIZE_16, PCI_VENDOR_ID }, @@ -258,23 +223,12 @@ static struct pci_reg_info regs_cardbus[] = { * * @dev: Bus+Device+Function number */ -#ifdef CONFIG_DM_PCI void pci_header_show(struct udevice *dev) -#else -void pci_header_show(pci_dev_t dev) -#endif { -#ifdef CONFIG_DM_PCI unsigned long class, header_type;
dm_pci_read_config(dev, PCI_CLASS_CODE, &class, PCI_SIZE_8); dm_pci_read_config(dev, PCI_HEADER_TYPE, &header_type, PCI_SIZE_8); -#else - u8 class, header_type; - - pci_read_config_byte(dev, PCI_CLASS_CODE, &class); - pci_read_config_byte(dev, PCI_HEADER_TYPE, &header_type); -#endif pci_show_regs(dev, regs_start); printf(" class code = 0x%.2x (%s)\n", (int)class, pci_class_str(class)); @@ -307,7 +261,6 @@ void pciinfo_header(int busnum, bool short_listing) } }
-#ifdef CONFIG_DM_PCI /** * pci_header_show_brief() - Show the short-form PCI device header * @@ -355,102 +308,6 @@ static void pciinfo(struct udevice *bus, bool short_listing) } }
-#else - -/** - * pci_header_show_brief() - Show the short-form PCI device header - * - * Reads and prints the header of the specified PCI device in short form. - * - * @dev: Bus+Device+Function number - */ -void pci_header_show_brief(pci_dev_t dev) -{ - u16 vendor, device; - u8 class, subclass; - - pci_read_config_word(dev, PCI_VENDOR_ID, &vendor); - pci_read_config_word(dev, PCI_DEVICE_ID, &device); - pci_read_config_byte(dev, PCI_CLASS_CODE, &class); - pci_read_config_byte(dev, PCI_CLASS_SUB_CODE, &subclass); - - printf("0x%.4x 0x%.4x %-23s 0x%.2x\n", - vendor, device, - pci_class_str(class), subclass); -} - -/** - * pciinfo() - Show a list of devices on the PCI bus - * - * Show information about devices on PCI bus. Depending on @short_pci_listing - * the output will be more or less exhaustive. - * - * @bus_num: The number of the bus to be scanned - * @short_pci_listing: true to use short form, showing only a brief header - * for each device - */ -void pciinfo(int bus_num, int short_pci_listing) -{ - struct pci_controller *hose = pci_bus_to_hose(bus_num); - int device; - int function; - unsigned char header_type; - unsigned short vendor_id; - pci_dev_t dev; - int ret; - - if (!hose) - return; - - pciinfo_header(bus_num, short_pci_listing); - - for (device = 0; device < PCI_MAX_PCI_DEVICES; device++) { - header_type = 0; - vendor_id = 0; - for (function = 0; function < PCI_MAX_PCI_FUNCTIONS; - function++) { - /* - * If this is not a multi-function device, we skip - * the rest. - */ - if (function && !(header_type & 0x80)) - break; - - dev = PCI_BDF(bus_num, device, function); - - if (pci_skip_dev(hose, dev)) - continue; - - ret = pci_read_config_word(dev, PCI_VENDOR_ID, - &vendor_id); - if (ret) - goto error; - if ((vendor_id == 0xFFFF) || (vendor_id == 0x0000)) - continue; - - if (!function) { - pci_read_config_byte(dev, PCI_HEADER_TYPE, - &header_type); - } - - if (short_pci_listing) { - printf("%02x.%02x.%02x ", bus_num, device, - function); - pci_header_show_brief(dev); - } else { - printf("\nFound PCI device %02x.%02x.%02x:\n", - bus_num, device, function); - pci_header_show(dev); - } - } - } - - return; -error: - printf("Cannot read bus configuration: %d\n", ret); -} -#endif - /** * get_pci_dev() - Convert the "bus.device.function" identifier into a number * @@ -482,13 +339,8 @@ static pci_dev_t get_pci_dev(char *name) return PCI_BDF(bdfs[0], bdfs[1], bdfs[2]); }
-#ifdef CONFIG_DM_PCI static int pci_cfg_display(struct udevice *dev, ulong addr, enum pci_size_t size, ulong length) -#else -static int pci_cfg_display(pci_dev_t bdf, ulong addr, enum pci_size_t size, - ulong length) -#endif { #define DISP_LINE_LEN 16 ulong i, nbytes, linebytes; @@ -509,11 +361,7 @@ static int pci_cfg_display(pci_dev_t bdf, ulong addr, enum pci_size_t size, for (i = 0; i < linebytes; i += byte_size) { unsigned long val;
-#ifdef CONFIG_DM_PCI dm_pci_read_config(dev, addr, &val, size); -#else - val = pci_read_config(bdf, addr, size); -#endif printf(" %0*lx", pci_field_width(size), val); addr += byte_size; } @@ -528,31 +376,8 @@ static int pci_cfg_display(pci_dev_t bdf, ulong addr, enum pci_size_t size, return (rc); }
-#ifndef CONFIG_DM_PCI -static int pci_cfg_write (pci_dev_t bdf, ulong addr, ulong size, ulong value) -{ - if (size == 4) { - pci_write_config_dword(bdf, addr, value); - } - else if (size == 2) { - ushort val = value & 0xffff; - pci_write_config_word(bdf, addr, val); - } - else { - u_char val = value & 0xff; - pci_write_config_byte(bdf, addr, val); - } - return 0; -} -#endif - -#ifdef CONFIG_DM_PCI static int pci_cfg_modify(struct udevice *dev, ulong addr, ulong size, ulong value, int incrflag) -#else -static int pci_cfg_modify(pci_dev_t bdf, ulong addr, ulong size, ulong value, - int incrflag) -#endif { ulong i; int nbytes; @@ -563,11 +388,7 @@ static int pci_cfg_modify(pci_dev_t bdf, ulong addr, ulong size, ulong value, */ do { printf("%08lx:", addr); -#ifdef CONFIG_DM_PCI dm_pci_read_config(dev, addr, &val, size); -#else - val = pci_read_config(bdf, addr, size); -#endif printf(" %0*lx", pci_field_width(size), val);
nbytes = cli_readline(" ? "); @@ -594,11 +415,7 @@ static int pci_cfg_modify(pci_dev_t bdf, ulong addr, ulong size, ulong value, /* good enough to not time out */ bootretry_reset_cmd_timeout(); -#ifdef CONFIG_DM_PCI dm_pci_write_config(dev, addr, i, size); -#else - pci_cfg_write(bdf, addr, size, i); -#endif if (incrflag) addr += size; } @@ -608,7 +425,6 @@ static int pci_cfg_modify(pci_dev_t bdf, ulong addr, ulong size, ulong value, return 0; }
-#ifdef CONFIG_DM_PCI static const struct pci_flag_info { uint flag; const char *name; @@ -647,7 +463,6 @@ static void pci_show_regions(struct udevice *bus) printf("\n"); } } -#endif
/* PCI Configuration Space access commands * @@ -661,11 +476,7 @@ static int do_pci(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { ulong addr = 0, value = 0, cmd_size = 0; enum pci_size_t size = PCI_SIZE_32; -#ifdef CONFIG_DM_PCI struct udevice *dev, *bus; -#else - pci_dev_t dev; -#endif int busnum = 0; pci_dev_t bdf = 0; char cmd = 's'; @@ -687,19 +498,15 @@ static int do_pci(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if (argc > 4) value = simple_strtoul(argv[4], NULL, 16); case 'h': /* header */ -#ifdef CONFIG_DM_PCI case 'b': /* bars */ -#endif if (argc < 3) goto usage; if ((bdf = get_pci_dev(argv[2])) == -1) return 1; break; -#if defined(CONFIG_DM_PCI) case 'e': pci_init(); return 0; -#endif case 'r': /* no break */ default: /* scan bus */ value = 1; /* short listing */ @@ -711,7 +518,6 @@ static int do_pci(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) if (argc > 1) busnum = simple_strtoul(argv[1], NULL, 16); } -#ifdef CONFIG_DM_PCI ret = uclass_get_device_by_seq(UCLASS_PCI, busnum, &bus); if (ret) { printf("No such bus\n"); @@ -721,21 +527,14 @@ static int do_pci(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) pci_show_regions(bus); else pciinfo(bus, value); -#else - pciinfo(busnum, value); -#endif return 0; }
-#ifdef CONFIG_DM_PCI ret = dm_pci_bus_find_bdf(bdf, &dev); if (ret) { printf("No such device\n"); return CMD_RET_FAILURE; } -#else - dev = bdf; -#endif
switch (argv[1][0]) { case 'h': /* header */ @@ -756,17 +555,10 @@ static int do_pci(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) case 'w': /* write */ if (argc < 5) goto usage; -#ifdef CONFIG_DM_PCI ret = dm_pci_write_config(dev, addr, value, size); -#else - ret = pci_cfg_write(dev, addr, size, value); -#endif break; -#ifdef CONFIG_DM_PCI - case 'b': /* bars */ return pci_bar_show(dev); -#endif default: ret = CMD_RET_USAGE; break; @@ -783,18 +575,14 @@ static int do_pci(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) static char pci_help_text[] = "[bus] [long]\n" " - short or long list of PCI devices on bus 'bus'\n" -#if defined(CONFIG_DM_PCI) "pci enum\n" " - Enumerate PCI buses\n" -#endif "pci header b.d.f\n" " - show header of PCI device 'bus.device.function'\n" -#ifdef CONFIG_DM_PCI "pci bar b.d.f\n" " - show BARs base and size for device b.d.f'\n" "pci regions\n" " - show PCI regions\n" -#endif "pci display[.b, .w, .l] b.d.f [address] [# of objects]\n" " - display PCI configuration space (CFG)\n" "pci next[.b, .w, .l] b.d.f address\n"
This board has not been converted to CONFIG_DM by the deadline. Remove it.
Leave the Kconfig options to avoid warnings on other boards.
board/Arcturus/ucp1020/Kconfig | 28 +- board/Arcturus/ucp1020/MAINTAINERS | 7 - board/Arcturus/ucp1020/Makefile | 31 - board/Arcturus/ucp1020/README | 54 -- board/Arcturus/ucp1020/cmd_arc.c | 408 ------------- board/Arcturus/ucp1020/ddr.c | 161 ------ board/Arcturus/ucp1020/law.c | 24 - board/Arcturus/ucp1020/spl.c | 127 ---- board/Arcturus/ucp1020/spl_minimal.c | 67 --- board/Arcturus/ucp1020/tlb.c | 100 ---- board/Arcturus/ucp1020/ucp1020.c | 372 ------------ board/Arcturus/ucp1020/ucp1020.h | 45 -- configs/UCP1020_defconfig | 58 -- include/configs/UCP1020.h | 832 --------------------------- 14 files changed, 1 insertion(+), 2313 deletions(-) delete mode 100644 board/Arcturus/ucp1020/MAINTAINERS delete mode 100644 board/Arcturus/ucp1020/Makefile delete mode 100644 board/Arcturus/ucp1020/README delete mode 100644 board/Arcturus/ucp1020/cmd_arc.c delete mode 100644 board/Arcturus/ucp1020/ddr.c delete mode 100644 board/Arcturus/ucp1020/law.c delete mode 100644 board/Arcturus/ucp1020/spl.c delete mode 100644 board/Arcturus/ucp1020/spl_minimal.c delete mode 100644 board/Arcturus/ucp1020/tlb.c delete mode 100644 board/Arcturus/ucp1020/ucp1020.c delete mode 100644 board/Arcturus/ucp1020/ucp1020.h delete mode 100644 configs/UCP1020_defconfig delete mode 100644 include/configs/UCP1020.h
diff --git a/board/Arcturus/ucp1020/Kconfig b/board/Arcturus/ucp1020/Kconfig index fe2c3be1b7a..60d80bab822 100644 --- a/board/Arcturus/ucp1020/Kconfig +++ b/board/Arcturus/ucp1020/Kconfig @@ -1,28 +1,4 @@ -if TARGET_UCP1020 - -config SYS_BOARD - string - default "ucp1020" - -config SYS_VENDOR - string - default "Arcturus" - -config SYS_CONFIG_NAME - string - default "UCP1020" - -choice - prompt "Target image select" - -config TARGET_UCP1020_NOR - bool "NOR flash u-boot image" - -config TARGET_UCP1020_SPIFLASH - bool "SPI flash u-boot image" - -endchoice - +# This exists only to avoid a warning for an unconverted value if TARGET_UCP1020_SPIFLASH config UCBOOT bool @@ -32,5 +8,3 @@ config SPIFLASH bool default y endif - -endif diff --git a/board/Arcturus/ucp1020/MAINTAINERS b/board/Arcturus/ucp1020/MAINTAINERS deleted file mode 100644 index e4a4718188f..00000000000 --- a/board/Arcturus/ucp1020/MAINTAINERS +++ /dev/null @@ -1,7 +0,0 @@ -UCP1020 BOARD -M: Oleksandr Zhadan and Michael Durrant arcsupport@arcturusnetworks.com -S: Maintained -F: board/Arcturus/ucp1020/ -F: include/configs/UCP1020.h -F: configs/UCP1020_defconfig -F: configs/UCP1020_SPIFLASH_defconfig diff --git a/board/Arcturus/ucp1020/Makefile b/board/Arcturus/ucp1020/Makefile deleted file mode 100644 index 46d04fb78c1..00000000000 --- a/board/Arcturus/ucp1020/Makefile +++ /dev/null @@ -1,31 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright 2013-2015 Arcturus Networks, Inc. -# based on board/freescale/p1_p2_rdb_pc/Makefile -# original copyright follows: -# Copyright 2010-2011 Freescale Semiconductor, Inc. - -MINIMAL= - -ifdef CONFIG_SPL_BUILD -ifdef CONFIG_SPL_INIT_MINIMAL -MINIMAL=y -endif -endif - -ifdef MINIMAL - -obj-y += spl_minimal.o tlb.o law.o - -else -ifdef CONFIG_SPL_BUILD -obj-y += spl.o -endif - -obj-y += ucp1020.o -obj-y += ddr.o -obj-y += law.o -obj-y += tlb.o -obj-y += cmd_arc.o - -endif diff --git a/board/Arcturus/ucp1020/README b/board/Arcturus/ucp1020/README deleted file mode 100644 index 555c4ef79fe..00000000000 --- a/board/Arcturus/ucp1020/README +++ /dev/null @@ -1,54 +0,0 @@ -The uCP1020 product family (ucp1020) is an Arcturus Networks Inc. System on Modules -product featuring a Freescale P1020 CPU, optionally populated with 1, 2 or 3 Gig-Ethernet PHYs, -DDR3, NOR Flash, eMMC NAND Flash and/or SPI Flash. - -Information on the generic product family can be found here: - http://www.arcturusnetworks.com/products/ucp1020 - -The UCP1020 several configurable options -======================================== - -- the selection of populated phy(s): - KSZ9031 (current default for eTSEC 1 and 3) - -- the selection of boot location: - SPI Flash or NOR flash - -The UCP1020 includes 2 default configurations -============================================= -NOR boot image: - configs/UCP1020_defconfig -SPI boot image: - configs/UCP1020_SPIFLASH_defconfig - -The UCP1020 adds an additional command in cmd_arc.c to access and program -SPI resident factory defaults for serial number, and 1, 2 or 3 Ethernet -HW Addresses. - - -Build example -============= - -make distclean -make UCP1020_defconfig -make - -Default Scripts -=============== -A default upgrade scripts is included in the default environment variable example: - -B$ run tftpflash - -Dual Environment -================ - -This build enables dual / failover environment environment. - -NOR Flash Partition declarations and scripts -============================================ -Several scripts are available to allow TFTP of images and programming directly -into defined NOR flash partitions. Examples: - -B$ run program0 -B$ run program1 -B$ run program2 diff --git a/board/Arcturus/ucp1020/cmd_arc.c b/board/Arcturus/ucp1020/cmd_arc.c deleted file mode 100644 index 4b30b66e208..00000000000 --- a/board/Arcturus/ucp1020/cmd_arc.c +++ /dev/null @@ -1,408 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR BSD-3-Clause -/* - * Command for accessing Arcturus factory environment. - * - * Copyright 2013-2019 Arcturus Networks Inc. - * https://www.arcturusnetworks.com/products/ - * by Oleksandr G Zhadan et al. - * - */ - -#include <common.h> -#include <command.h> -#include <cpu_func.h> -#include <div64.h> -#include <env.h> -#include <flash.h> -#include <malloc.h> -#include <spi_flash.h> -#include <mmc.h> -#include <version.h> -#include <asm/io.h> -#include <linux/stringify.h> - -static ulong fwenv_addr[MAX_FWENV_ADDR]; -const char mystrerr[] = "ERROR: Failed to save factory info"; - -static int ishwaddr(char *hwaddr) -{ - if (strlen(hwaddr) == MAX_HWADDR_SIZE) - if (hwaddr[2] == ':' && - hwaddr[5] == ':' && - hwaddr[8] == ':' && - hwaddr[11] == ':' && - hwaddr[14] == ':') - return 0; - return -1; -} - -#if (FWENV_TYPE == FWENV_MMC) - -static char smac[29][18] __attribute__ ((aligned(0x200))); /* 1 MMC block is 512 bytes */ - -int set_mmc_arc_product(int argc, char *const argv[]) -{ - struct mmc *mmc; - u32 blk, cnt, n; - int i, err = 1; - void *addr; - const u8 mmc_dev_num = CONFIG_SYS_MMC_ENV_DEV; - - mmc = find_mmc_device(mmc_dev_num); - if (!mmc) { - printf("No SD/MMC/eMMC card found\n"); - return 0; - } - if (mmc_init(mmc)) { - printf("%s(%d) init failed\n", IS_SD(mmc) ? "SD" : "MMC", - mmc_dev_num); - return 0; - } - if (mmc_getwp(mmc) == 1) { - printf("Error: card is write protected!\n"); - return CMD_RET_FAILURE; - } - - /* Save factory defaults */ - addr = (void *)smac; - cnt = 1; /* One 512 bytes block */ - - for (i = 0; i < MAX_FWENV_ADDR; i++) - if (fwenv_addr[i] != -1) { - blk = fwenv_addr[i] / 512; - n = blk_dwrite(mmc_get_blk_desc(mmc), blk, cnt, addr); - if (n != cnt) - printf("%s: %s [%d]\n", __func__, mystrerr, i); - else - err = 0; - } - if (err) - return -2; - - return err; -} - -static int read_mmc_arc_info(void) -{ - struct mmc *mmc; - u32 blk, cnt, n; - int i; - void *addr; - const u8 mmc_dev_num = CONFIG_SYS_MMC_ENV_DEV; - - mmc = find_mmc_device(mmc_dev_num); - if (!mmc) { - printf("No SD/MMC/eMMC card found\n"); - return 0; - } - if (mmc_init(mmc)) { - printf("%s(%d) init failed\n", IS_SD(mmc) ? "SD" : "MMC", - mmc_dev_num); - return 0; - } - - addr = (void *)smac; - cnt = 1; /* One 512 bytes block */ - - for (i = 0; i < MAX_FWENV_ADDR; i++) - if (fwenv_addr[i] != -1) { - blk = fwenv_addr[i] / 512; - n = blk_dread(mmc_get_blk_desc(mmc), blk, cnt, addr); - flush_cache((ulong) addr, 512); - if (n == cnt) - return (i + 1); - } - return 0; -} -#endif - -#if (FWENV_TYPE == FWENV_SPI_FLASH) - -static struct spi_flash *flash; -static char smac[4][18]; - -int set_spi_arc_product(int argc, char *const argv[]) -{ - int i, err = 1; - - flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, - CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); - if (!flash) { - printf("Failed to initialize SPI flash at %u:%u\n", - CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS); - return -1; - } - - /* Save factory defaults */ - for (i = 0; i < MAX_FWENV_ADDR; i++) - if (fwenv_addr[i] != -1) - if (spi_flash_write - (flash, fwenv_addr[i], sizeof(smac), smac)) - printf("%s: %s [%d]\n", __func__, mystrerr, i); - else - err = 0; - if (err) - return -2; - - return err; -} - -static int read_spi_arc_info(void) -{ - int i; - - flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, - CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); - if (!flash) { - printf("Failed to initialize SPI flash at %u:%u\n", - CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS); - return 0; - } - for (i = 0; i < MAX_FWENV_ADDR; i++) - if (fwenv_addr[i] != -1) - if (!spi_flash_read - (flash, fwenv_addr[i], sizeof(smac), smac)) - return (i + 1); - return 0; -} -#endif - -#if (FWENV_TYPE == FWENV_NOR_FLASH) - -static char smac[4][18]; - -int set_nor_arc_product(int argc, char *const argv[]) -{ - int i, err = 1; - - /* Save factory defaults */ - for (i = 0; i < MAX_FWENV_ADDR; i++) - if (fwenv_addr[i] != -1) { - ulong fwenv_end = fwenv_addr[i] + 4; - - flash_sect_roundb(&fwenv_end); - flash_sect_protect(0, fwenv_addr[i], fwenv_end); - if (flash_write - ((char *)smac, fwenv_addr[i], sizeof(smac))) - printf("%s: %s [%d]\n", __func__, mystrerr, i); - else - err = 0; - flash_sect_protect(1, fwenv_addr[i], fwenv_end); - } - if (err) - return -2; - - return err; -} - -static int read_nor_arc_info(void) -{ - int i; - - for (i = 0; i < MAX_FWENV_ADDR; i++) - if (fwenv_addr[i] != -1) { - memcpy(smac, (void *)fwenv_addr[i], sizeof(smac)); - return (i + 1); - } - - return 0; -} -#endif - -int set_arc_product(int argc, char *const argv[]) -{ - if (argc != 5) - return -1; - - /* Check serial number */ - if (strlen(argv[1]) != MAX_SERIAL_SIZE) - return -1; - - /* Check HWaddrs */ - if (ishwaddr(argv[2]) || ishwaddr(argv[3]) || ishwaddr(argv[4])) - return -1; - - strcpy(smac[0], argv[1]); - strcpy(smac[1], argv[2]); - strcpy(smac[2], argv[3]); - strcpy(smac[3], argv[4]); - -#if (FWENV_TYPE == FWENV_NOR_FLASH) - return set_nor_arc_product(argc, argv); -#endif -#if (FWENV_TYPE == FWENV_SPI_FLASH) - return set_spi_arc_product(argc, argv); -#endif -#if (FWENV_TYPE == FWENV_MMC) - return set_mmc_arc_product(argc, argv); -#endif - return -2; -} - -static int read_arc_info(void) -{ -#if (FWENV_TYPE == FWENV_NOR_FLASH) - return read_nor_arc_info(); -#endif -#if (FWENV_TYPE == FWENV_SPI_FLASH) - return read_spi_arc_info(); -#endif -#if (FWENV_TYPE == FWENV_MMC) - return read_mmc_arc_info(); -#endif - return 0; -} - -static int do_get_arc_info(void) -{ - int l = read_arc_info(); - char *oldserial = env_get("SERIAL"); - char *oldversion = env_get("VERSION"); - - if (oldversion != NULL) - if (strcmp(oldversion, U_BOOT_VERSION) != 0) - oldversion = NULL; - - if (l == 0) { - printf("%s: failed to read factory info\n", __func__); - return -2; - } - - printf("\rSERIAL: "); - if (smac[0][0] == EMPY_CHAR) { - printf("<not found>\n"); - } else { - printf("%s\n", smac[0]); - env_set("SERIAL", smac[0]); - } - - if (strcmp(smac[1], "00:00:00:00:00:00") == 0) { - env_set("ethaddr", NULL); - env_set("eth1addr", NULL); - env_set("eth2addr", NULL); - goto done; - } - - printf("HWADDR0: "); - if (smac[1][0] == EMPY_CHAR) { - printf("<not found>\n"); - } else { - char *ret = env_get("ethaddr"); - - if (ret == NULL) { - env_set("ethaddr", smac[1]); - printf("%s\n", smac[1]); - } else if (strcmp(ret, __stringify(CONFIG_ETHADDR)) == 0) { - env_set("ethaddr", smac[1]); - printf("%s (factory)\n", smac[1]); - } else { - printf("%s\n", ret); - } - } - - if (strcmp(smac[2], "00:00:00:00:00:00") == 0) { - env_set("eth1addr", NULL); - env_set("eth2addr", NULL); - goto done; - } - - printf("HWADDR1: "); - if (smac[2][0] == EMPY_CHAR) { - printf("<not found>\n"); - } else { - char *ret = env_get("eth1addr"); - - if (ret == NULL) { - env_set("ethaddr", smac[2]); - printf("%s\n", smac[2]); - } else if (strcmp(ret, __stringify(CONFIG_ETH1ADDR)) == 0) { - env_set("eth1addr", smac[2]); - printf("%s (factory)\n", smac[2]); - } else { - printf("%s\n", ret); - } - } - - if (strcmp(smac[3], "00:00:00:00:00:00") == 0) { - env_set("eth2addr", NULL); - goto done; - } - - printf("HWADDR2: "); - if (smac[3][0] == EMPY_CHAR) { - printf("<not found>\n"); - } else { - char *ret = env_get("eth2addr"); - - if (ret == NULL) { - env_set("ethaddr", smac[3]); - printf("%s\n", smac[3]); - } else if (strcmp(ret, __stringify(CONFIG_ETH2ADDR)) == 0) { - env_set("eth2addr", smac[3]); - printf("%s (factory)\n", smac[3]); - } else { - printf("%s\n", ret); - } - } -done: - if (oldserial == NULL || oldversion == NULL) { - if (oldversion == NULL) - env_set("VERSION", U_BOOT_VERSION); - env_save(); - } - - return 0; -} - -static int init_fwenv(void) -{ - int i, ret = -1; - - fwenv_addr[0] = FWENV_ADDR1; - fwenv_addr[1] = FWENV_ADDR2; - fwenv_addr[2] = FWENV_ADDR3; - fwenv_addr[3] = FWENV_ADDR4; - - for (i = 0; i < MAX_FWENV_ADDR; i++) - if (fwenv_addr[i] != -1) - ret = 0; - if (ret) - printf("%s: No firmfare info storage address is defined\n", - __func__); - return ret; -} - -void get_arc_info(void) -{ - if (!init_fwenv()) - do_get_arc_info(); -} - -static int do_arc_cmd(struct cmd_tbl *cmdtp, int flag, int argc, - char *const argv[]) -{ - const char *cmd; - int ret = -1; - - cmd = argv[1]; - --argc; - ++argv; - - if (init_fwenv()) - return ret; - - if (strcmp(cmd, "product") == 0) - ret = set_arc_product(argc, argv); - else if (strcmp(cmd, "info") == 0) - ret = do_get_arc_info(); - - if (ret == -1) - return CMD_RET_USAGE; - - return ret; -} - -U_BOOT_CMD(arc, 6, 1, do_arc_cmd, - "Arcturus product command sub-system", - "product serial hwaddr0 hwaddr1 hwaddr2 - save Arcturus factory env\n" - "info - show Arcturus factory env\n\n"); diff --git a/board/Arcturus/ucp1020/ddr.c b/board/Arcturus/ucp1020/ddr.c deleted file mode 100644 index a3285ebe5cd..00000000000 --- a/board/Arcturus/ucp1020/ddr.c +++ /dev/null @@ -1,161 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013-2015 Arcturus Networks, Inc. - * http://www.arcturusnetworks.com/products/ucp1020/ - * based on board/freescale/p1_p2_rdb_pc/spl.c - * original copyright follows: - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <vsprintf.h> -#include <asm/mmu.h> -#include <asm/immap_85xx.h> -#include <asm/processor.h> -#include <fsl_ddr_sdram.h> -#include <fsl_ddr_dimm_params.h> -#include <asm/io.h> -#include <asm/fsl_law.h> - -#ifdef CONFIG_SYS_DDR_RAW_TIMING -#if defined(CONFIG_UCP1020) || defined(CONFIG_UCP1020T1) -/* - * Micron MT41J128M16HA-15E - * */ -dimm_params_t ddr_raw_timing = { - .n_ranks = 1, - .rank_density = 536870912u, - .capacity = 536870912u, - .primary_sdram_width = 32, - .ec_sdram_width = 8, - .registered_dimm = 0, - .mirrored_dimm = 0, - .n_row_addr = 14, - .n_col_addr = 10, - .n_banks_per_sdram_device = 8, - .edc_config = 2, - .burst_lengths_bitmask = 0x0c, - - .tckmin_x_ps = 1650, - .caslat_x = 0x7e << 4, /* 5,6,7,8,9,10 */ - .taa_ps = 14050, - .twr_ps = 15000, - .trcd_ps = 13500, - .trrd_ps = 75000, - .trp_ps = 13500, - .tras_ps = 40000, - .trc_ps = 49500, - .trfc_ps = 160000, - .twtr_ps = 75000, - .trtp_ps = 75000, - .refresh_rate_ps = 7800000, - .tfaw_ps = 30000, -}; - -#else -#error Missing raw timing data for this board -#endif - -int fsl_ddr_get_dimm_params(dimm_params_t *pdimm, - unsigned int controller_number, - unsigned int dimm_number) -{ - const char dimm_model[] = "Fixed DDR on board"; - - if ((controller_number == 0) && (dimm_number == 0)) { - memcpy(pdimm, &ddr_raw_timing, sizeof(dimm_params_t)); - memset(pdimm->mpart, 0, sizeof(pdimm->mpart)); - memcpy(pdimm->mpart, dimm_model, sizeof(dimm_model) - 1); - } - - return 0; -} -#endif /* CONFIG_SYS_DDR_RAW_TIMING */ - -#ifdef CONFIG_SYS_DDR_CS0_BNDS -/* Fixed sdram init -- doesn't use serial presence detect. */ -phys_size_t fixed_sdram(void) -{ - sys_info_t sysinfo; - char buf[32]; - size_t ddr_size; - fsl_ddr_cfg_regs_t ddr_cfg_regs = { - .cs[0].bnds = CONFIG_SYS_DDR_CS0_BNDS, - .cs[0].config = CONFIG_SYS_DDR_CS0_CONFIG, - .cs[0].config_2 = CONFIG_SYS_DDR_CS0_CONFIG_2, -#if CONFIG_CHIP_SELECTS_PER_CTRL > 1 - .cs[1].bnds = CONFIG_SYS_DDR_CS1_BNDS, - .cs[1].config = CONFIG_SYS_DDR_CS1_CONFIG, - .cs[1].config_2 = CONFIG_SYS_DDR_CS1_CONFIG_2, -#endif - .timing_cfg_3 = CONFIG_SYS_DDR_TIMING_3, - .timing_cfg_0 = CONFIG_SYS_DDR_TIMING_0, - .timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1, - .timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2, - .ddr_sdram_cfg = CONFIG_SYS_DDR_CONTROL, - .ddr_sdram_cfg_2 = CONFIG_SYS_DDR_CONTROL_2, - .ddr_sdram_mode = CONFIG_SYS_DDR_MODE_1, - .ddr_sdram_mode_2 = CONFIG_SYS_DDR_MODE_2, - .ddr_sdram_md_cntl = CONFIG_SYS_DDR_MODE_CONTROL, - .ddr_sdram_interval = CONFIG_SYS_DDR_INTERVAL, - .ddr_data_init = CONFIG_SYS_DDR_DATA_INIT, - .ddr_sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CTRL, - .ddr_init_addr = CONFIG_SYS_DDR_INIT_ADDR, - .ddr_init_ext_addr = CONFIG_SYS_DDR_INIT_EXT_ADDR, - .timing_cfg_4 = CONFIG_SYS_DDR_TIMING_4, - .timing_cfg_5 = CONFIG_SYS_DDR_TIMING_5, - .ddr_zq_cntl = CONFIG_SYS_DDR_ZQ_CONTROL, - .ddr_wrlvl_cntl = CONFIG_SYS_DDR_WRLVL_CONTROL, - .ddr_sr_cntr = CONFIG_SYS_DDR_SR_CNTR, - .ddr_sdram_rcw_1 = CONFIG_SYS_DDR_RCW_1, - .ddr_sdram_rcw_2 = CONFIG_SYS_DDR_RCW_2 - }; - - get_sys_info(&sysinfo); - printf("Configuring DDR for %s MT/s data rate\n", - strmhz(buf, sysinfo.freq_ddrbus)); - - ddr_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; - - fsl_ddr_set_memctl_regs(&ddr_cfg_regs, 0, 0); - - if (set_ddr_laws(CONFIG_SYS_DDR_SDRAM_BASE, - ddr_size, LAW_TRGT_IF_DDR_1) < 0) { - printf("ERROR setting Local Access Windows for DDR\n"); - return 0; - }; - - return ddr_size; -} -#endif - -void fsl_ddr_board_options(memctl_options_t *popts, - dimm_params_t *pdimm, - unsigned int ctrl_num) -{ - int i; - - popts->clk_adjust = 6; - popts->cpo_override = 0x1f; - popts->write_data_delay = 2; - popts->half_strength_driver_enable = 1; - /* Write leveling override */ - popts->wrlvl_en = 1; - popts->wrlvl_override = 1; - popts->wrlvl_sample = 0xf; - popts->wrlvl_start = 0x8; - popts->trwt_override = 1; - popts->trwt = 0; - - if (pdimm->primary_sdram_width == 64) - popts->data_bus_width = 0; - else if (pdimm->primary_sdram_width == 32) - popts->data_bus_width = 1; - else - printf("Error in DDR bus width configuration!\n"); - - for (i = 0; i < CONFIG_CHIP_SELECTS_PER_CTRL; i++) { - popts->cs_local_opts[i].odt_rd_cfg = FSL_DDR_ODT_NEVER; - popts->cs_local_opts[i].odt_wr_cfg = FSL_DDR_ODT_CS; - } -} diff --git a/board/Arcturus/ucp1020/law.c b/board/Arcturus/ucp1020/law.c deleted file mode 100644 index cb53692a32b..00000000000 --- a/board/Arcturus/ucp1020/law.c +++ /dev/null @@ -1,24 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013-2015 Arcturus Networks, Inc. - * http://www.arcturusnetworks.com/products/ucp1020/ - * based on board/freescale/p1_p2_rdb_pc/spl.c - * original copyright follows: - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <asm/fsl_law.h> -#include <asm/mmu.h> - -struct law_entry law_table[] = { -#ifdef CONFIG_VSC7385_ENET - SET_LAW(CONFIG_SYS_VSC7385_BASE_PHYS, LAW_SIZE_1M, LAW_TRGT_IF_LBC), -#endif - SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_64M, LAW_TRGT_IF_LBC), -#ifdef CONFIG_SYS_NAND_BASE_PHYS - SET_LAW(CONFIG_SYS_NAND_BASE_PHYS, LAW_SIZE_32K, LAW_TRGT_IF_LBC), -#endif -}; - -int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/Arcturus/ucp1020/spl.c b/board/Arcturus/ucp1020/spl.c deleted file mode 100644 index 437e975fdf7..00000000000 --- a/board/Arcturus/ucp1020/spl.c +++ /dev/null @@ -1,127 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013-2015 Arcturus Networks, Inc. - * http://www.arcturusnetworks.com/products/ucp1020/ - * based on board/freescale/p1_p2_rdb_pc/spl.c - * original copyright follows: - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <clock_legacy.h> -#include <console.h> -#include <env.h> -#include <env_internal.h> -#include <init.h> -#include <ns16550.h> -#include <malloc.h> -#include <mmc.h> -#include <nand.h> -#include <i2c.h> -#include <fsl_esdhc.h> -#include <spi_flash.h> -#include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; - -static const u32 sysclk_tbl[] = { - 66666000, 7499900, 83332500, 8999900, - 99999000, 11111000, 12499800, 13333200 -}; - -phys_size_t get_effective_memsize(void) -{ - return CONFIG_SYS_L2_SIZE; -} - -void board_init_f(ulong bootflag) -{ - u32 plat_ratio, bus_clk; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - - console_init_f(); - - /* Set pmuxcr to allow both i2c1 and i2c2 */ - setbits_be32(&gur->pmuxcr, in_be32(&gur->pmuxcr) | 0x1000); - setbits_be32(&gur->pmuxcr, - in_be32(&gur->pmuxcr) | MPC85xx_PMUXCR_SD_DATA); - - /* Read back the register to synchronize the write. */ - in_be32(&gur->pmuxcr); - -#ifdef CONFIG_SPL_SPI_BOOT - clrbits_be32(&gur->pmuxcr, MPC85xx_PMUXCR_SD_DATA); -#endif - - /* initialize selected port with appropriate baud rate */ - plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; - plat_ratio >>= 1; - bus_clk = CONFIG_SYS_CLK_FREQ * plat_ratio; - gd->bus_clk = bus_clk; - - ns16550_init((struct ns16550 *)CONFIG_SYS_NS16550_COM1, - bus_clk / 16 / CONFIG_BAUDRATE); -#ifdef CONFIG_SPL_MMC_BOOT - puts("\nSD boot...\n"); -#elif defined(CONFIG_SPL_SPI_BOOT) - puts("\nSPI Flash boot...\n"); -#endif - - /* copy code to RAM and jump to it - this should not return */ - /* NOTE - code has to be copied out of NAND buffer before - * other blocks can be read. - */ - relocate_code(CONFIG_SPL_RELOC_STACK, 0, CONFIG_SPL_RELOC_TEXT_BASE); -} - -void board_init_r(gd_t *gd, ulong dest_addr) -{ - /* Pointer is writable since we allocated a register for it */ - gd = (gd_t *)CONFIG_SPL_GD_ADDR; - struct bd_info *bd; - - memset(gd, 0, sizeof(gd_t)); - bd = (struct bd_info *)(CONFIG_SPL_GD_ADDR + sizeof(gd_t)); - memset(bd, 0, sizeof(struct bd_info)); - gd->bd = bd; - - arch_cpu_init(); - get_clocks(); - mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, - CONFIG_SPL_RELOC_MALLOC_SIZE); - -#ifndef CONFIG_SPL_NAND_BOOT - env_init(); -#endif -#ifdef CONFIG_SPL_MMC_BOOT - mmc_initialize(bd); -#endif - /* relocate environment function pointers etc. */ -#ifdef CONFIG_SPL_NAND_BOOT - nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, - (uchar *)CONFIG_ENV_ADDR); - gd->env_addr = (ulong)(CONFIG_ENV_ADDR); - gd->env_valid = ENV_VALID; -#else - env_relocate(); -#endif - -#ifdef CONFIG_SYS_I2C - i2c_init_all(); -#else - i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); -#endif - - dram_init(); -#ifdef CONFIG_SPL_NAND_BOOT - puts("Tertiary program loader running in sram..."); -#else - puts("Second program loader running in sram...\n"); -#endif - -#ifdef CONFIG_SPL_MMC_BOOT - mmc_boot(); -#elif defined(CONFIG_SPL_NAND_BOOT) - nand_boot(); -#endif -} diff --git a/board/Arcturus/ucp1020/spl_minimal.c b/board/Arcturus/ucp1020/spl_minimal.c deleted file mode 100644 index 90abec9cce5..00000000000 --- a/board/Arcturus/ucp1020/spl_minimal.c +++ /dev/null @@ -1,67 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013-2015 Arcturus Networks, Inc. - * http://www.arcturusnetworks.com/products/ucp1020/ - * based on board/freescale/p1_p2_rdb_pc/spl_minimal.c - * original copyright follows: - * Copyright 2011 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <init.h> -#include <ns16550.h> -#include <asm/io.h> -#include <nand.h> -#include <linux/compiler.h> -#include <asm/fsl_law.h> -#include <fsl_ddr_sdram.h> -#include <asm/global_data.h> - -DECLARE_GLOBAL_DATA_PTR; - -void board_init_f(ulong bootflag) -{ - u32 plat_ratio; - ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; - -#if defined(CONFIG_SYS_NAND_BR_PRELIM) && defined(CONFIG_SYS_NAND_OR_PRELIM) - set_lbc_br(0, CONFIG_SYS_NAND_BR_PRELIM); - set_lbc_or(0, CONFIG_SYS_NAND_OR_PRELIM); -#endif - - /* initialize selected port with appropriate baud rate */ - plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; - plat_ratio >>= 1; - gd->bus_clk = CONFIG_SYS_CLK_FREQ * plat_ratio; - - ns16550_init((struct ns16550 *)CONFIG_SYS_NS16550_COM1, - gd->bus_clk / 16 / CONFIG_BAUDRATE); - - puts("\nNAND boot... "); - - /* copy code to RAM and jump to it - this should not return */ - /* NOTE - code has to be copied out of NAND buffer before - * other blocks can be read. - */ - relocate_code(CONFIG_SPL_RELOC_STACK, 0, CONFIG_SPL_RELOC_TEXT_BASE); -} - -void board_init_r(gd_t *gd, ulong dest_addr) -{ - puts("\nSecond program loader running in sram..."); - nand_boot(); -} - -void putc(char c) -{ - if (c == '\n') - ns16550_putc((struct ns16550 *)CONFIG_SYS_NS16550_COM1, '\r'); - - ns16550_putc((struct ns16550 *)CONFIG_SYS_NS16550_COM1, c); -} - -void puts(const char *str) -{ - while (*str) - putc(*str++); -} diff --git a/board/Arcturus/ucp1020/tlb.c b/board/Arcturus/ucp1020/tlb.c deleted file mode 100644 index 2c07df63e5b..00000000000 --- a/board/Arcturus/ucp1020/tlb.c +++ /dev/null @@ -1,100 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013-2015 Arcturus Networks, Inc - * http://www.arcturusnetworks.com/products/ucp1020/ - * based on board/freescale/p1_p2_rdb_pc/tlb.c - * original copyright follows: - * Copyright 2010-2011 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <asm/mmu.h> - -struct fsl_e_tlb_entry tlb_table[] = { - /* TLB 0 - for temp stack in cache */ - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, - CONFIG_SYS_INIT_RAM_ADDR_PHYS, - MAS3_SX | MAS3_SW | MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, - CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, - MAS3_SX | MAS3_SW | MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, - CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, - MAS3_SX | MAS3_SW | MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, - CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, - MAS3_SX | MAS3_SW | MAS3_SR, 0, - 0, 0, BOOKE_PAGESZ_4K, 0), - - /* TLB 1 */ - /* *I*** - Covers boot page */ - SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I, - 0, 0, BOOKE_PAGESZ_4K, 1), - - /* *I*G* - CCSRBAR */ - SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, - 0, 1, BOOKE_PAGESZ_1M, 1), - -#ifndef CONFIG_SPL_BUILD - /* W**G* - Flash/promjet, localbus */ - /* This will be changed to *I*G* after relocation to RAM. */ - SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, - MAS3_SX | MAS3_SR, MAS2_W | MAS2_G, - 0, 2, BOOKE_PAGESZ_64M, 1), - -#ifdef CONFIG_PCI - /* *I*G* - PCI memory 1.5G */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, - 0, 3, BOOKE_PAGESZ_1G, 1), - - /* *I*G* - PCI I/O effective: 192K */ - SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, - 0, 4, BOOKE_PAGESZ_256K, 1), -#endif - -#ifdef CONFIG_VSC7385_ENET - /* *I*G - VSC7385 Switch */ - SET_TLB_ENTRY(1, CONFIG_SYS_VSC7385_BASE, CONFIG_SYS_VSC7385_BASE_PHYS, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, - 0, 5, BOOKE_PAGESZ_1M, 1), -#endif -#endif /* not SPL */ - -#ifdef CONFIG_SYS_NAND_BASE - /* *I*G - NAND */ - SET_TLB_ENTRY(1, CONFIG_SYS_NAND_BASE, CONFIG_SYS_NAND_BASE_PHYS, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, - 0, 7, BOOKE_PAGESZ_1M, 1), -#endif - -#if defined(CONFIG_SYS_RAMBOOT) || \ - (defined(CONFIG_SPL) && !defined(CONFIG_SPL_COMMON_INIT_DDR)) - /* *I*G - eSDHC/eSPI/NAND boot */ - SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_M, - 0, 8, BOOKE_PAGESZ_1G, 1), - -#endif /* RAMBOOT/SPL */ - -#ifdef CONFIG_SYS_INIT_L2_ADDR - /* *I*G - L2SRAM */ - SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR, CONFIG_SYS_INIT_L2_ADDR_PHYS, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_G, - 0, 11, BOOKE_PAGESZ_256K, 1), -#if CONFIG_SYS_L2_SIZE >= (256 << 10) - SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR + 0x40000, - CONFIG_SYS_INIT_L2_ADDR_PHYS + 0x40000, - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, - 0, 12, BOOKE_PAGESZ_256K, 1) -#endif -#endif -}; - -int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/board/Arcturus/ucp1020/ucp1020.c b/board/Arcturus/ucp1020/ucp1020.c deleted file mode 100644 index 24d1d57ec4b..00000000000 --- a/board/Arcturus/ucp1020/ucp1020.c +++ /dev/null @@ -1,372 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013-2019 Arcturus Networks, Inc. - * https://www.arcturusnetworks.com/products/ucp1020/ - * by Oleksandr G Zhadan et al. - * based on board/freescale/p1_p2_rdb_pc/spl.c - * original copyright follows: - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <command.h> -#include <env.h> -#include <hwconfig.h> -#include <image.h> -#include <init.h> -#include <net.h> -#include <pci.h> -#include <i2c.h> -#include <miiphy.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <fsl_mdio.h> -#include <tsec.h> -#include <ioports.h> -#include <netdev.h> -#include <micrel.h> -#include <spi_flash.h> -#include <mmc.h> -#include <linux/ctype.h> -#include <asm/fsl_serdes.h> -#include <asm/gpio.h> -#include <asm/processor.h> -#include <asm/mmu.h> -#include <asm/cache.h> -#include <asm/immap_85xx.h> -#include <asm/fsl_pci.h> -#include <fsl_ddr_sdram.h> -#include <asm/io.h> -#include <asm/fsl_law.h> -#include <asm/fsl_lbc.h> -#include <asm/mp.h> -#include "ucp1020.h" - -void spi_set_speed(struct spi_slave *slave, uint hz) -{ - /* TO DO: It's actially have to be in spi/ */ -} - -/* - * To be compatible with cmd_gpio - */ -int name_to_gpio(const char *name) -{ - int gpio = 31 - simple_strtoul(name, NULL, 10); - - if (gpio < 16) - gpio = -1; - - return gpio; -} - -void board_gpio_init(void) -{ - int i; - char envname[8], *val; - - for (i = 0; i < GPIO_MAX_NUM; i++) { - sprintf(envname, "GPIO%d", i); - val = env_get(envname); - if (val) { - char direction = toupper(val[0]); - char level = toupper(val[1]); - - if (direction == 'I') { - gpio_direction_input(i); - } else { - if (direction == 'O') { - if (level == '1') - gpio_direction_output(i, 1); - else - gpio_direction_output(i, 0); - } - } - } - } - - val = env_get("PCIE_OFF"); - if (val) { - gpio_direction_input(GPIO_PCIE1_EN); - gpio_direction_input(GPIO_PCIE2_EN); - } else { - gpio_direction_output(GPIO_PCIE1_EN, 1); - gpio_direction_output(GPIO_PCIE2_EN, 1); - } - - val = env_get("SDHC_CDWP_OFF"); - if (!val) { - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - - setbits_be32(&gur->pmuxcr, - (MPC85xx_PMUXCR_SDHC_CD | MPC85xx_PMUXCR_SDHC_WP)); - } -} - -int board_early_init_f(void) -{ - return 0; /* Just in case. Could be disable in config file */ -} - -int checkboard(void) -{ - printf("Board: %s\n", CONFIG_BOARDNAME_LOCAL); - board_gpio_init(); -#ifdef CONFIG_MMC - printf("SD/MMC: 4-bit Mode\n"); -#endif - - return 0; -} - -#ifdef CONFIG_PCI -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} -#endif - -int board_early_init_r(void) -{ - const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; - const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); - - /* - * Remap Boot flash region to caching-inhibited - * so that flash can be erased properly. - */ - - /* Flush d-cache and invalidate i-cache of any FLASH data */ - flush_dcache(); - invalidate_icache(); - - /* invalidate existing TLB entry for flash */ - disable_tlb(flash_esel); - - set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, /* tlb, epn, rpn */ - MAS3_SX | MAS3_SW | MAS3_SR, MAS2_I | MAS2_G, /* perms, wimge */ - 0, flash_esel, BOOKE_PAGESZ_64M, 1);/* ts, esel, tsize, iprot */ - - return 0; -} - -int board_phy_config(struct phy_device *phydev) -{ -#if defined(CONFIG_PHY_MICREL_KSZ9021) - int regval; - static int cnt; - - if (cnt++ == 0) - printf("PHYs address ["); - - if (phydev->addr == TSEC1_PHY_ADDR || phydev->addr == TSEC3_PHY_ADDR) { - regval = - ksz9021_phy_extended_read(phydev, - MII_KSZ9021_EXT_STRAP_STATUS); - /* - * min rx data delay - */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_RX_DATA_SKEW, - 0x6666); - /* - * max rx/tx clock delay, min rx/tx control - */ - ksz9021_phy_extended_write(phydev, - MII_KSZ9021_EXT_RGMII_CLOCK_SKEW, - 0xf6f6); - printf("0x%x", (regval & 0x1f)); - } else { - printf("0x%x", (TSEC2_PHY_ADDR & 0x1f)); - } - if (cnt == 3) - printf("] "); - else - printf(","); -#endif - -#if defined(CONFIG_PHY_MICREL_KSZ9031_DEBUG) - regval = ksz9031_phy_extended_read(phydev, 2, 0x01, 0x4000); - if (regval >= 0) - printf(" (ADDR 0x%x) ", regval & 0x1f); -#endif - - return 0; -} - -int last_stage_init(void) -{ - static char newkernelargs[256]; - static u8 id1[16]; - static u8 id2; -#ifdef CONFIG_MMC - struct mmc *mmc; -#endif - char *sval, *kval; - - if (i2c_read(CONFIG_SYS_I2C_IDT6V49205B, 7, 1, &id1[0], 2) < 0) { - printf("Error reading i2c IDT6V49205B information!\n"); - } else { - printf("IDT6V49205B(0x%02x): ready\n", id1[1]); - i2c_read(CONFIG_SYS_I2C_IDT6V49205B, 4, 1, &id1[0], 2); - if (!(id1[1] & 0x02)) { - id1[1] |= 0x02; - i2c_write(CONFIG_SYS_I2C_IDT6V49205B, 4, 1, &id1[0], 2); - asm("nop; nop"); - } - } - - if (i2c_read(CONFIG_SYS_I2C_NCT72_ADDR, 0xFE, 1, &id2, 1) < 0) - printf("Error reading i2c NCT72 information!\n"); - else - printf("NCT72(0x%x): ready\n", id2); - - kval = env_get("kernelargs"); - -#ifdef CONFIG_MMC - mmc = find_mmc_device(0); - if (mmc) - if (!mmc_init(mmc)) { - printf("MMC/SD card detected\n"); - if (kval) { - int n = strlen(defkargs); - char *tmp = strstr(kval, defkargs); - - *tmp = 0; - strcpy(newkernelargs, kval); - strcat(newkernelargs, " "); - strcat(newkernelargs, mmckargs); - strcat(newkernelargs, " "); - strcat(newkernelargs, &tmp[n]); - env_set("kernelargs", newkernelargs); - } else { - env_set("kernelargs", mmckargs); - } - } -#endif - get_arc_info(); - - if (kval) { - sval = env_get("SERIAL"); - if (sval) { - strcpy(newkernelargs, "SN="); - strcat(newkernelargs, sval); - strcat(newkernelargs, " "); - strcat(newkernelargs, kval); - env_set("kernelargs", newkernelargs); - } - } else { - printf("Error reading kernelargs env variable!\n"); - } - - return 0; -} - -int board_eth_init(struct bd_info *bis) -{ - struct fsl_pq_mdio_info mdio_info; - struct tsec_info_struct tsec_info[4]; -#ifdef CONFIG_TSEC2 - ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); -#endif - int num = 0; - -#ifdef CONFIG_TSEC1 - SET_STD_TSEC_INFO(tsec_info[num], 1); - num++; -#endif -#ifdef CONFIG_TSEC2 - SET_STD_TSEC_INFO(tsec_info[num], 2); - if (is_serdes_configured(SGMII_TSEC2)) { - if (!(in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_SGMII2_DIS)) { - puts("eTSEC2 is in sgmii mode.\n"); - tsec_info[num].flags |= TSEC_SGMII; - tsec_info[num].phyaddr = TSEC2_PHY_ADDR_SGMII; - } - } - num++; -#endif -#ifdef CONFIG_TSEC3 - SET_STD_TSEC_INFO(tsec_info[num], 3); - num++; -#endif - - if (!num) { - printf("No TSECs initialized\n"); - return 0; - } - - mdio_info.regs = (struct tsec_mii_mng *)CONFIG_SYS_MDIO_BASE_ADDR; - mdio_info.name = DEFAULT_MII_NAME; - - fsl_pq_mdio_init(bis, &mdio_info); - - tsec_eth_init(bis, tsec_info, num); - - return pci_eth_init(bis); -} - -#ifdef CONFIG_OF_BOARD_SETUP -int ft_board_setup(void *blob, struct bd_info *bd) -{ - phys_addr_t base; - phys_size_t size; - const char *soc_usb_compat = "fsl-usb2-dr"; - int err, usb1_off, usb2_off; - - ft_cpu_setup(blob, bd); - - base = env_get_bootm_low(); - size = env_get_bootm_size(); - - fdt_fixup_memory(blob, (u64)base, (u64)size); - - FT_FSL_PCI_SETUP; - -#if defined(CONFIG_HAS_FSL_DR_USB) - fsl_fdt_fixup_dr_usb(blob, bd); -#endif - -#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) - /* Delete eLBC node as it is muxed with USB2 controller */ - if (hwconfig("usb2")) { - const char *soc_elbc_compat = "fsl,p1020-elbc"; - int off = fdt_node_offset_by_compatible(blob, -1, - soc_elbc_compat); - if (off < 0) { - printf - ("WARNING: could not find compatible node %s: %s\n", - soc_elbc_compat, fdt_strerror(off)); - return off; - } - err = fdt_del_node(blob, off); - if (err < 0) { - printf("WARNING: could not remove %s: %s\n", - soc_elbc_compat, fdt_strerror(err)); - } - return err; - } -#endif - -/* Delete USB2 node as it is muxed with eLBC */ - usb1_off = fdt_node_offset_by_compatible(blob, -1, soc_usb_compat); - if (usb1_off < 0) { - printf("WARNING: could not find compatible node %s: %s.\n", - soc_usb_compat, fdt_strerror(usb1_off)); - return usb1_off; - } - usb2_off = - fdt_node_offset_by_compatible(blob, usb1_off, soc_usb_compat); - if (usb2_off < 0) { - printf("WARNING: could not find compatible node %s: %s.\n", - soc_usb_compat, fdt_strerror(usb2_off)); - return usb2_off; - } - err = fdt_del_node(blob, usb2_off); - if (err < 0) { - printf("WARNING: could not remove %s: %s.\n", - soc_usb_compat, fdt_strerror(err)); - } - return 0; -} -#endif diff --git a/board/Arcturus/ucp1020/ucp1020.h b/board/Arcturus/ucp1020/ucp1020.h deleted file mode 100644 index 1b527cdb1cf..00000000000 --- a/board/Arcturus/ucp1020/ucp1020.h +++ /dev/null @@ -1,45 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2013-2019 Arcturus Networks, Inc. - * https://www.arcturusnetworks.com/products/ucp1020/ - * by Oleksandr G Zhadan et al. - */ - -#ifndef __UCP1020_H__ -#define __UCP1020_H__ - -#define GPIO0 31 -#define GPIO1 30 -#define GPIO2 29 -#define GPIO3 28 -#define GPIO4 27 -#define GPIO5 26 -#define GPIO6 25 -#define GPIO7 24 -#define GPIO8 23 -#define GPIO9 22 -#define GPIO10 21 -#define GPIO11 20 -#define GPIO12 19 -#define GPIO13 18 -#define GPIO14 17 -#define GPIO15 16 -#define GPIO_MAX_NUM 16 - -#define GPIO_SDHC_CD GPIO8 -#define GPIO_SDHC_WP GPIO9 -#define GPIO_USB_PCTL0 GPIO10 -#define GPIO_PCIE1_EN GPIO11 -#define GPIO_PCIE2_EN GPIO10 -#define GPIO_USB_PCTL1 GPIO11 - -#define GPIO_WD GPIO15 - -#ifdef CONFIG_MMC -static char *defkargs = "root=/dev/mtdblock1 rootfstype=cramfs ro"; -static char *mmckargs = "root=/dev/mmcblk0p1 rootwait rw"; -#endif - -int get_arc_info(void); - -#endif diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig deleted file mode 100644 index 1fdb1952c8f..00000000000 --- a/configs/UCP1020_defconfig +++ /dev/null @@ -1,58 +0,0 @@ -CONFIG_PPC=y -CONFIG_SYS_TEXT_BASE=0xEFF80000 -CONFIG_ENV_SIZE=0x20000 -CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_MPC85xx=y -CONFIG_TARGET_UCP1020=y -CONFIG_FIT=y -CONFIG_FIT_VERBOSE=y -CONFIG_OF_BOARD_SETUP=y -CONFIG_OF_STDOUT_VIA_ALIAS=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" -CONFIG_AUTOBOOT_STOP_STR="\x1b" -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_BOARD_EARLY_INIT_R=y -CONFIG_LAST_STAGE_INIT=y -# CONFIG_MISC_INIT_R is not set -CONFIG_HUSH_PARSER=y -# CONFIG_AUTO_COMPLETE is not set -CONFIG_SYS_PROMPT="B$ " -CONFIG_CMD_IMLS=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -# CONFIG_CMD_PCI is not set -# CONFIG_CMD_SATA is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_DATE=y -CONFIG_MP=y -# CONFIG_CMD_HASH is not set -CONFIG_CMD_CRAMFS=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_ADDR=0xEC0C0000 -# CONFIG_MMC is not set -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_PHY_ATHEROS=y -CONFIG_PHY_BROADCOM=y -CONFIG_PHY_DAVICOM=y -CONFIG_PHY_LXT=y -CONFIG_PHY_MARVELL=y -CONFIG_PHY_NATSEMI=y -CONFIG_PHY_REALTEK=y -CONFIG_PHY_SMSC=y -CONFIG_PHY_VITESSE=y -CONFIG_PHY_GIGE=y -CONFIG_E1000=y -CONFIG_MII=y -CONFIG_TSEC_ENET=y -CONFIG_SYS_NS16550=y -CONFIG_FS_CRAMFS=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h deleted file mode 100644 index c3cc72e13f7..00000000000 --- a/include/configs/UCP1020.h +++ /dev/null @@ -1,832 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2013-2019 Arcturus Networks, Inc. - * https://www.arcturusnetworks.com/products/ucp1020/ - * based on include/configs/p1_p2_rdb_pc.h - * original copyright follows: - * Copyright 2009-2011 Freescale Semiconductor, Inc. - */ - -/* - * QorIQ uCP1020-xx boards configuration file - */ -#ifndef __CONFIG_H -#define __CONFIG_H - -#include <linux/stringify.h> - -/*** Arcturus FirmWare Environment */ - -#define MAX_SERIAL_SIZE 15 -#define MAX_HWADDR_SIZE 17 - -#define MAX_FWENV_ADDR 4 - -#define FWENV_MMC 1 -#define FWENV_SPI_FLASH 2 -#define FWENV_NOR_FLASH 3 -/* - #define FWENV_TYPE FWENV_MMC - #define FWENV_TYPE FWENV_SPI_FLASH -*/ -#define FWENV_TYPE FWENV_NOR_FLASH - -#if (FWENV_TYPE == FWENV_MMC) -#define FWENV_ADDR1 -1 -#define FWENV_ADDR2 -1 -#define FWENV_ADDR3 -1 -#define FWENV_ADDR4 -1 -#define EMPY_CHAR 0 -#endif - -#if (FWENV_TYPE == FWENV_SPI_FLASH) -#ifndef CONFIG_SF_DEFAULT_SPEED -#define CONFIG_SF_DEFAULT_SPEED 1000000 -#endif -#ifndef CONFIG_SF_DEFAULT_MODE -#define CONFIG_SF_DEFAULT_MODE SPI_MODE0 -#endif -#ifndef CONFIG_SF_DEFAULT_CS -#define CONFIG_SF_DEFAULT_CS 0 -#endif -#ifndef CONFIG_SF_DEFAULT_BUS -#define CONFIG_SF_DEFAULT_BUS 0 -#endif -#define FWENV_ADDR1 (0x200 - sizeof(smac)) -#define FWENV_ADDR2 (0x400 - sizeof(smac)) -#define FWENV_ADDR3 (CONFIG_ENV_SECT_SIZE + 0x200 - sizeof(smac)) -#define FWENV_ADDR4 (CONFIG_ENV_SECT_SIZE + 0x400 - sizeof(smac)) -#define EMPY_CHAR 0xff -#endif - -#if (FWENV_TYPE == FWENV_NOR_FLASH) -#define FWENV_ADDR1 0xEC080000 -#define FWENV_ADDR2 -1 -#define FWENV_ADDR3 -1 -#define FWENV_ADDR4 -1 -#define EMPY_CHAR 0xff -#endif -/***********************************/ - -#define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ -#define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ - -#if defined(CONFIG_TARTGET_UCP1020T1) - -#define CONFIG_UCP1020_REV_1_3 - -#define CONFIG_BOARDNAME "uCP1020-64EE512-0U1-XR-T1" - -#define CONFIG_TSEC1 -#define CONFIG_TSEC3 -#define CONFIG_HAS_ETH0 -#define CONFIG_HAS_ETH1 -#define CONFIG_ETHADDR 00:19:D3:FF:FF:FF -#define CONFIG_ETH1ADDR 00:19:D3:FF:FF:FE -#define CONFIG_ETH2ADDR 00:19:D3:FF:FF:FD -#define CONFIG_IPADDR 10.80.41.229 -#define CONFIG_SERVERIP 10.80.41.227 -#define CONFIG_NETMASK 255.255.252.0 -#define CONFIG_ETHPRIME "eTSEC3" - -#define CONFIG_SYS_L2_SIZE (256 << 10) - -#endif - -#if defined(CONFIG_TARGET_UCP1020) - -#define CONFIG_UCP1020 -#define CONFIG_UCP1020_REV_1_3 - -#define CONFIG_BOARDNAME_LOCAL "uCP1020-64EEE512-OU1-XR" - -#define CONFIG_TSEC1 -#define CONFIG_TSEC3 -#define CONFIG_HAS_ETH0 -#define CONFIG_HAS_ETH1 -#define CONFIG_HAS_ETH2 -#define CONFIG_ETHADDR 00:06:3B:FF:FF:FF -#define CONFIG_ETH1ADDR 00:06:3B:FF:FF:FE -#define CONFIG_ETH2ADDR 00:06:3B:FF:FF:FD -#define CONFIG_IPADDR 192.168.1.81 -#define CONFIG_IPADDR1 192.168.1.82 -#define CONFIG_IPADDR2 192.168.1.83 -#define CONFIG_SERVERIP 192.168.1.80 -#define CONFIG_GATEWAYIP 102.168.1.1 -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_ETHPRIME "eTSEC1" - -#define CONFIG_SYS_L2_SIZE (256 << 10) - -#endif - -#ifdef CONFIG_SDCARD -#define CONFIG_RAMBOOT_SDCARD -#define CONFIG_SYS_RAMBOOT -#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc -#endif - -#ifdef CONFIG_SPIFLASH -#define CONFIG_RAMBOOT_SPIFLASH -#define CONFIG_SYS_RAMBOOT -#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc -#endif - -#define CONFIG_SYS_TEXT_BASE_NOR 0xeff80000 - -#ifndef CONFIG_RESET_VECTOR_ADDRESS -#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc -#endif - -#ifndef CONFIG_SYS_MONITOR_BASE -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ -#endif - -#define CONFIG_SYS_SATA_MAX_DEVICE 2 -#define CONFIG_LBA48 - -#define CONFIG_SYS_CLK_FREQ 66666666 -#define CONFIG_DDR_CLK_FREQ 66666666 - -#define CONFIG_HWCONFIG - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_L2_CACHE -#define CONFIG_BTB - -#define CONFIG_ENABLE_36BIT_PHYS - -#define CONFIG_SYS_CCSRBAR 0xffe00000 -#define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR - -/* IN case of NAND bootloader relocate CCSRBAR in RAMboot code not in the 4k - SPL code*/ -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SYS_CCSR_DO_NOT_RELOCATE -#endif - -/* DDR Setup */ -#define CONFIG_DDR_ECC_ENABLE -#ifndef CONFIG_DDR_ECC_ENABLE -#define CONFIG_SYS_DDR_RAW_TIMING -#define CONFIG_DDR_SPD -#endif -#define CONFIG_SYS_SPD_BUS_NUM 1 - -#define CONFIG_SYS_SDRAM_SIZE_LAW LAW_SIZE_512M -#define CONFIG_CHIP_SELECTS_PER_CTRL 1 -#define CONFIG_SYS_SDRAM_SIZE (1u << (CONFIG_SYS_SDRAM_SIZE_LAW - 19)) -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE - -#define CONFIG_DIMM_SLOTS_PER_CTLR 1 - -/* Default settings for DDR3 */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000003f -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80014302 -#define CONFIG_SYS_DDR_CS0_CONFIG_2 0x00000000 -#define CONFIG_SYS_DDR_CS1_BNDS 0x0040007f -#define CONFIG_SYS_DDR_CS1_CONFIG 0x80014302 -#define CONFIG_SYS_DDR_CS1_CONFIG_2 0x00000000 - -#define CONFIG_SYS_DDR_DATA_INIT 0xdeadbeef -#define CONFIG_SYS_DDR_INIT_ADDR 0x00000000 -#define CONFIG_SYS_DDR_INIT_EXT_ADDR 0x00000000 -#define CONFIG_SYS_DDR_MODE_CONTROL 0x00000000 - -#define CONFIG_SYS_DDR_ZQ_CONTROL 0x89080600 -#define CONFIG_SYS_DDR_WRLVL_CONTROL 0x8655A608 -#define CONFIG_SYS_DDR_SR_CNTR 0x00000000 -#define CONFIG_SYS_DDR_RCW_1 0x00000000 -#define CONFIG_SYS_DDR_RCW_2 0x00000000 -#ifdef CONFIG_DDR_ECC_ENABLE -#define CONFIG_SYS_DDR_CONTROL 0xE70C0000 /* Type = DDR3 & ECC */ -#else -#define CONFIG_SYS_DDR_CONTROL 0xC70C0000 /* Type = DDR3 */ -#endif -#define CONFIG_SYS_DDR_CONTROL_2 0x04401050 -#define CONFIG_SYS_DDR_TIMING_4 0x00220001 -#define CONFIG_SYS_DDR_TIMING_5 0x03402400 - -#define CONFIG_SYS_DDR_TIMING_3 0x00020000 -#define CONFIG_SYS_DDR_TIMING_0 0x00330004 -#define CONFIG_SYS_DDR_TIMING_1 0x6f6B4846 -#define CONFIG_SYS_DDR_TIMING_2 0x0FA8C8CF -#define CONFIG_SYS_DDR_CLK_CTRL 0x03000000 -#define CONFIG_SYS_DDR_MODE_1 0x40461520 -#define CONFIG_SYS_DDR_MODE_2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x0C300000 - -/* - * Memory map - * - * 0x0000_0000 0x7fff_ffff DDR Up to 2GB cacheable - * 0x8000_0000 0xdfff_ffff PCI Express Mem 1G non-cacheable(PCIe * 2) - * 0xec00_0000 0xefff_ffff NOR flash Up to 64M non-cacheable CS0/1 - * 0xf8f8_0000 0xf8ff_ffff L2 SRAM Up to 256K cacheable - * (early boot only) - * 0xffc0_0000 0xffc3_ffff PCI IO range 256k non-cacheable - * 0xffd0_0000 0xffd0_3fff L1 for stack 16K cacheable - * 0xffe0_0000 0xffef_ffff CCSR 1M non-cacheable - */ - -/* - * Local Bus Definitions - */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* 64M */ -#define CONFIG_SYS_FLASH_BASE 0xec000000 - -#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE - -#define CONFIG_FLASH_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) \ - | BR_PS_16 | BR_V) - -#define CONFIG_FLASH_OR_PRELIM 0xfc000ff7 - -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} -#define CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ - -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ - -#undef CONFIG_SYS_FLASH_CHECKSUM -#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ - -#define CONFIG_SYS_FLASH_EMPTY_INFO - -#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* stack in RAM */ -/* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS CONFIG_SYS_INIT_RAM_ADDR -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS -/* Size of used area in RAM */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_LEN (256 * 1024)/* Reserve 256 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (1024 * 1024)/* Reserved for malloc */ - -#define CONFIG_SYS_PMC_BASE 0xff980000 -#define CONFIG_SYS_PMC_BASE_PHYS CONFIG_SYS_PMC_BASE -#define CONFIG_PMC_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_PMC_BASE_PHYS) | \ - BR_PS_8 | BR_V) -#define CONFIG_PMC_OR_PRELIM (OR_AM_64KB | OR_GPCM_CSNT | OR_GPCM_XACS | \ - OR_GPCM_SCY | OR_GPCM_TRLX | OR_GPCM_EHTR | \ - OR_GPCM_EAD) - -#define CONFIG_SYS_BR0_PRELIM CONFIG_FLASH_BR_PRELIM /* NOR Base Address */ -#define CONFIG_SYS_OR0_PRELIM CONFIG_FLASH_OR_PRELIM /* NOR Options */ -#ifdef CONFIG_NAND_FSL_ELBC -#define CONFIG_SYS_BR1_PRELIM CONFIG_SYS_NAND_BR_PRELIM /* NAND Base Addr */ -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */ -#endif - -/* Serial Port - controlled on board with jumper J8 - * open - index 2 - * shorted - index 1 - */ -#undef CONFIG_SERIAL_SOFTWARE_FIFO -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK get_bus_freq(0) -#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_INIT_MINIMAL) -#define CONFIG_NS16550_MIN_FUNCTIONS -#endif - -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} - -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600) - -/* I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_FSL -#define CONFIG_SYS_FSL_I2C_SPEED 400000 -#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C_OFFSET 0x3000 -#define CONFIG_SYS_FSL_I2C2_SPEED 400000 -#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100 -#define CONFIG_SYS_I2C_NOPROBES { {0, 0x29} } -#define CONFIG_SYS_SPD_BUS_NUM 1 /* For rom_loc and flash bank */ - -#define CONFIG_RTC_DS1337 -#define CONFIG_RTC_DS1337_NOOSC -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 -#define CONFIG_SYS_I2C_PCA9557_ADDR 0x18 -#define CONFIG_SYS_I2C_NCT72_ADDR 0x4C -#define CONFIG_SYS_I2C_IDT6V49205B 0x69 - -#if defined(CONFIG_PCI) -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ - -/* controller 2, direct to uli, tgtid 2, Base address 9000 */ -#define CONFIG_SYS_PCIE2_NAME "PCIe SLOT CON9" -#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_VIRT 0xffc10000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ - -/* controller 1, Slot 2, tgtid 1, Base address a000 */ -#define CONFIG_SYS_PCIE1_NAME "PCIe SLOT CON10" -#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_VIRT 0xffc00000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ - -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - -/* - * Environment - */ -#if !defined(CONFIG_ENV_FIT_UCBOOT) && defined(CONFIG_RAMBOOT_SDCARD) -#define CONFIG_FSL_FIXED_MMC_LOCATION -#endif - -#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ - -/* - * USB - */ -#define CONFIG_HAS_FSL_DR_USB - -#if defined(CONFIG_HAS_FSL_DR_USB) -#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 - -#ifdef CONFIG_USB_EHCI_HCD -#define CONFIG_EHCI_HCD_INIT_AFTER_RESET -#define CONFIG_USB_EHCI_FSL -#endif -#endif - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#ifdef CONFIG_MMC -#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR -#endif - -/* Misc Extra Settings */ -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms tick */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 64 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial Memory for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ -#endif - -/* - * Environment Configuration - */ - -#if defined(CONFIG_TSEC_ENET) - -#if defined(CONFIG_UCP1020_REV_1_2) || defined(CONFIG_UCP1020_REV_1_3) -#else -#error "UCP1020 module revision is not defined !!!" -#endif - -#define CONFIG_BOOTP_SERVERIP - -#define CONFIG_TSEC1_NAME "eTSEC1" -#define CONFIG_TSEC2_NAME "eTSEC2" -#define CONFIG_TSEC3_NAME "eTSEC3" - -#define TSEC1_PHY_ADDR 4 -#define TSEC2_PHY_ADDR 0 -#define TSEC2_PHY_ADDR_SGMII 0x00 -#define TSEC3_PHY_ADDR 6 - -#define TSEC1_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) -#define TSEC2_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) -#define TSEC3_FLAGS (TSEC_GIGABIT | TSEC_REDUCED) - -#define TSEC1_PHYIDX 0 -#define TSEC2_PHYIDX 0 -#define TSEC3_PHYIDX 0 - -#endif - -#define CONFIG_HOSTNAME "UCP1020" -#define CONFIG_ROOTPATH "/opt/nfsroot" -#define CONFIG_BOOTFILE "uImage" -#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ - -/* default location for tftp and bootm */ -#define CONFIG_LOADADDR 1000000 - -#if defined(CONFIG_DONGLE) - -#define CONFIG_EXTRA_ENV_SETTINGS \ -"bootcmd=run prog_spi_mbrbootcramfs\0" \ -"bootfile=uImage\0" \ -"consoledev=ttyS0\0" \ -"cramfsfile=image.cramfs\0" \ -"dtbaddr=0x00c00000\0" \ -"dtbfile=image.dtb\0" \ -"ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \ -"eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" \ -"eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" \ -"fileaddr=0x01000000\0" \ -"filesize=0x00080000\0" \ -"flashmbr=sf probe 0; " \ - "tftp $loadaddr $mbr; " \ - "sf erase $mbr_offset +$filesize; " \ - "sf write $loadaddr $mbr_offset $filesize\0" \ -"flashrecovery=tftp $recoveryaddr $cramfsfile; " \ - "protect off $nor_recoveryaddr +$filesize; " \ - "erase $nor_recoveryaddr +$filesize; " \ - "cp.b $recoveryaddr $nor_recoveryaddr $filesize; " \ - "protect on $nor_recoveryaddr +$filesize\0 " \ -"flashuboot=tftp $ubootaddr $ubootfile; " \ - "protect off $nor_ubootaddr +$filesize; " \ - "erase $nor_ubootaddr +$filesize; " \ - "cp.b $ubootaddr $nor_ubootaddr $filesize; " \ - "protect on $nor_ubootaddr +$filesize\0 " \ -"flashworking=tftp $workingaddr $cramfsfile; " \ - "protect off $nor_workingaddr +$filesize; " \ - "erase $nor_workingaddr +$filesize; " \ - "cp.b $workingaddr $nor_workingaddr $filesize; " \ - "protect on $nor_workingaddr +$filesize\0 " \ -"hwconfig=usb1:dr_mode=host,phy_type=ulpi\0 " \ -"kerneladdr=0x01100000\0" \ -"kernelfile=uImage\0" \ -"loadaddr=0x01000000\0" \ -"mbr=uCP1020d.mbr\0" \ -"mbr_offset=0x00000000\0" \ -"mmbr=uCP1020Quiet.mbr\0" \ -"mmcpart=0:2\0" \ -"mmc__mbrd=fatload mmc $mmcpart $loadaddr $mbr; " \ - "mmc erase 1 1; " \ - "mmc write $loadaddr 1 1\0" \ -"mmc__uboot=fatload mmc $mmcpart $loadaddr $ubootfile; " \ - "mmc erase 0x40 0x400; " \ - "mmc write $loadaddr 0x40 0x400\0" \ -"netdev=eth0\0" \ -"nor_recoveryaddr=0xEC0A0000\0" \ -"nor_ubootaddr=0xEFF80000\0" \ -"nor_workingaddr=0xECFA0000\0" \ -"norbootrecovery=setenv bootargs $recoverybootargs" \ - " console=$consoledev,$baudrate $othbootargs; " \ - "run norloadrecovery; " \ - "bootm $kerneladdr - $dtbaddr\0" \ -"norbootworking=setenv bootargs $workingbootargs" \ - " console=$consoledev,$baudrate $othbootargs; " \ - "run norloadworking; " \ - "bootm $kerneladdr - $dtbaddr\0" \ -"norloadrecovery=mw.l $kerneladdr 0x0 0x00a00000; " \ - "setenv cramfsaddr $nor_recoveryaddr; " \ - "cramfsload $dtbaddr $dtbfile; " \ - "cramfsload $kerneladdr $kernelfile\0" \ -"norloadworking=mw.l $kerneladdr 0x0 0x00a00000; " \ - "setenv cramfsaddr $nor_workingaddr; " \ - "cramfsload $dtbaddr $dtbfile; " \ - "cramfsload $kerneladdr $kernelfile\0" \ -"prog_spi_mbr=run spi__mbr\0" \ -"prog_spi_mbrboot=run spi__mbr; run spi__boot1; run spi__boot2\0" \ -"prog_spi_mbrbootcramfs=run spi__mbr; run spi__boot1; run spi__boot2; " \ - "run spi__cramfs\0" \ -"ramboot=setenv bootargs root=/dev/ram ramdisk_size=$ramdisk_size ro" \ - " console=$consoledev,$baudrate $othbootargs; " \ - "tftp $rootfsaddr $rootfsfile; " \ - "tftp $loadaddr $kernelfile; " \ - "tftp $dtbaddr $dtbfile; " \ - "bootm $loadaddr $rootfsaddr $dtbaddr\0" \ -"ramdisk_size=120000\0" \ -"ramdiskfile=rootfs.ext2.gz.uboot\0" \ -"recoveryaddr=0x02F00000\0" \ -"recoverybootargs=root=/dev/mtdblock0 rootfstype=cramfs ro\0" \ -"releasefpga=mw.l 0xffe0f000 0x00400000; mw.l 0xffe0f004 0x00000000; " \ - "mw.l 0xffe0f008 0x00400000\0" \ -"rootfsaddr=0x02F00000\0" \ -"rootfsfile=rootfs.ext2.gz.uboot\0" \ -"rootpath=/opt/nfsroot\0" \ -"spi__boot1=fatload mmc $mmcpart $loadaddr u-boot.bin; " \ - "protect off 0xeC000000 +$filesize; " \ - "erase 0xEC000000 +$filesize; " \ - "cp.b $loadaddr 0xEC000000 $filesize; " \ - "cmp.b $loadaddr 0xEC000000 $filesize; " \ - "protect on 0xeC000000 +$filesize\0" \ -"spi__boot2=fatload mmc $mmcpart $loadaddr u-boot.bin; " \ - "protect off 0xeFF80000 +$filesize; " \ - "erase 0xEFF80000 +$filesize; " \ - "cp.b $loadaddr 0xEFF80000 $filesize; " \ - "cmp.b $loadaddr 0xEFF80000 $filesize; " \ - "protect on 0xeFF80000 +$filesize\0" \ -"spi__bootd=fatload mmc $mmcpart $loadaddr $ubootd; " \ - "sf probe 0; sf erase 0x8000 +$filesize; " \ - "sf write $loadaddr 0x8000 $filesize\0" \ -"spi__cramfs=fatload mmc $mmcpart $loadaddr image.cramfs; " \ - "protect off 0xec0a0000 +$filesize; " \ - "erase 0xeC0A0000 +$filesize; " \ - "cp.b $loadaddr 0xeC0A0000 $filesize; " \ - "protect on 0xec0a0000 +$filesize\0" \ -"spi__mbr=fatload mmc $mmcpart $loadaddr $mmbr; " \ - "sf probe 1; sf erase 0 +$filesize; " \ - "sf write $loadaddr 0 $filesize\0" \ -"spi__mbrd=fatload mmc $mmcpart $loadaddr $mbr; " \ - "sf probe 0; sf erase 0 +$filesize; " \ - "sf write $loadaddr 0 $filesize\0" \ -"tftpflash=tftpboot $loadaddr $uboot; " \ - "protect off " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "erase " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "cp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize; " \ - "protect on " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "cmp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize\0"\ -"uboot= " __stringify(CONFIG_UBOOTPATH) "\0" \ -"ubootaddr=0x01000000\0" \ -"ubootfile=u-boot.bin\0" \ -"ubootd=u-boot4dongle.bin\0" \ -"upgrade=run flashworking\0" \ -"usb_phy_type=ulpi\0 " \ -"workingaddr=0x02F00000\0" \ -"workingbootargs=root=/dev/mtdblock1 rootfstype=cramfs ro\0" - -#else - -#if defined(CONFIG_UCP1020T1) - -#define CONFIG_EXTRA_ENV_SETTINGS \ -"bootcmd=run releasefpga; run norbootworking || run norbootrecovery\0" \ -"bootfile=uImage\0" \ -"consoledev=ttyS0\0" \ -"cramfsfile=image.cramfs\0" \ -"dtbaddr=0x00c00000\0" \ -"dtbfile=image.dtb\0" \ -"ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \ -"eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" \ -"eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" \ -"fileaddr=0x01000000\0" \ -"filesize=0x00080000\0" \ -"flashmbr=sf probe 0; " \ - "tftp $loadaddr $mbr; " \ - "sf erase $mbr_offset +$filesize; " \ - "sf write $loadaddr $mbr_offset $filesize\0" \ -"flashrecovery=tftp $recoveryaddr $cramfsfile; " \ - "protect off $nor_recoveryaddr +$filesize; " \ - "erase $nor_recoveryaddr +$filesize; " \ - "cp.b $recoveryaddr $nor_recoveryaddr $filesize; " \ - "protect on $nor_recoveryaddr +$filesize\0 " \ -"flashuboot=tftp $ubootaddr $ubootfile; " \ - "protect off $nor_ubootaddr +$filesize; " \ - "erase $nor_ubootaddr +$filesize; " \ - "cp.b $ubootaddr $nor_ubootaddr $filesize; " \ - "protect on $nor_ubootaddr +$filesize\0 " \ -"flashworking=tftp $workingaddr $cramfsfile; " \ - "protect off $nor_workingaddr +$filesize; " \ - "erase $nor_workingaddr +$filesize; " \ - "cp.b $workingaddr $nor_workingaddr $filesize; " \ - "protect on $nor_workingaddr +$filesize\0 " \ -"hwconfig=usb1:dr_mode=host,phy_type=ulpi\0 " \ -"kerneladdr=0x01100000\0" \ -"kernelfile=uImage\0" \ -"loadaddr=0x01000000\0" \ -"mbr=uCP1020.mbr\0" \ -"mbr_offset=0x00000000\0" \ -"netdev=eth0\0" \ -"nor_recoveryaddr=0xEC0A0000\0" \ -"nor_ubootaddr=0xEFF80000\0" \ -"nor_workingaddr=0xECFA0000\0" \ -"norbootrecovery=setenv bootargs $recoverybootargs" \ - " console=$consoledev,$baudrate $othbootargs; " \ - "run norloadrecovery; " \ - "bootm $kerneladdr - $dtbaddr\0" \ -"norbootworking=setenv bootargs $workingbootargs" \ - " console=$consoledev,$baudrate $othbootargs; " \ - "run norloadworking; " \ - "bootm $kerneladdr - $dtbaddr\0" \ -"norloadrecovery=mw.l $kerneladdr 0x0 0x00a00000; " \ - "setenv cramfsaddr $nor_recoveryaddr; " \ - "cramfsload $dtbaddr $dtbfile; " \ - "cramfsload $kerneladdr $kernelfile\0" \ -"norloadworking=mw.l $kerneladdr 0x0 0x00a00000; " \ - "setenv cramfsaddr $nor_workingaddr; " \ - "cramfsload $dtbaddr $dtbfile; " \ - "cramfsload $kerneladdr $kernelfile\0" \ -"othbootargs=quiet\0" \ -"ramboot=setenv bootargs root=/dev/ram ramdisk_size=$ramdisk_size ro" \ - " console=$consoledev,$baudrate $othbootargs; " \ - "tftp $rootfsaddr $rootfsfile; " \ - "tftp $loadaddr $kernelfile; " \ - "tftp $dtbaddr $dtbfile; " \ - "bootm $loadaddr $rootfsaddr $dtbaddr\0" \ -"ramdisk_size=120000\0" \ -"ramdiskfile=rootfs.ext2.gz.uboot\0" \ -"recoveryaddr=0x02F00000\0" \ -"recoverybootargs=root=/dev/mtdblock0 rootfstype=cramfs ro\0" \ -"releasefpga=mw.l 0xffe0f000 0x00400000; mw.l 0xffe0f004 0x00000000; " \ - "mw.l 0xffe0f008 0x00400000\0" \ -"rootfsaddr=0x02F00000\0" \ -"rootfsfile=rootfs.ext2.gz.uboot\0" \ -"rootpath=/opt/nfsroot\0" \ -"silent=1\0" \ -"tftpflash=tftpboot $loadaddr $uboot; " \ - "protect off " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "erase " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "cp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize; " \ - "protect on " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "cmp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize\0"\ -"uboot= " __stringify(CONFIG_UBOOTPATH) "\0" \ -"ubootaddr=0x01000000\0" \ -"ubootfile=u-boot.bin\0" \ -"upgrade=run flashworking\0" \ -"workingaddr=0x02F00000\0" \ -"workingbootargs=root=/dev/mtdblock1 rootfstype=cramfs ro\0" - -#else /* For Arcturus Modules */ - -#define CONFIG_EXTRA_ENV_SETTINGS \ -"bootcmd=run norkernel\0" \ -"bootfile=uImage\0" \ -"consoledev=ttyS0\0" \ -"dtbaddr=0x00c00000\0" \ -"dtbfile=image.dtb\0" \ -"ethaddr=" __stringify(CONFIG_ETHADDR) "\0" \ -"eth1addr=" __stringify(CONFIG_ETH1ADDR) "\0" \ -"eth2addr=" __stringify(CONFIG_ETH2ADDR) "\0" \ -"fileaddr=0x01000000\0" \ -"filesize=0x00080000\0" \ -"flashmbr=sf probe 0; " \ - "tftp $loadaddr $mbr; " \ - "sf erase $mbr_offset +$filesize; " \ - "sf write $loadaddr $mbr_offset $filesize\0" \ -"flashuboot=tftp $loadaddr $ubootfile; " \ - "protect off $nor_ubootaddr0 +$filesize; " \ - "erase $nor_ubootaddr0 +$filesize; " \ - "cp.b $loadaddr $nor_ubootaddr0 $filesize; " \ - "protect on $nor_ubootaddr0 +$filesize; " \ - "protect off $nor_ubootaddr1 +$filesize; " \ - "erase $nor_ubootaddr1 +$filesize; " \ - "cp.b $loadaddr $nor_ubootaddr1 $filesize; " \ - "protect on $nor_ubootaddr1 +$filesize\0 " \ -"format0=protect off $part0base +$part0size; " \ - "erase $part0base +$part0size\0" \ -"format1=protect off $part1base +$part1size; " \ - "erase $part1base +$part1size\0" \ -"format2=protect off $part2base +$part2size; " \ - "erase $part2base +$part2size\0" \ -"format3=protect off $part3base +$part3size; " \ - "erase $part3base +$part3size\0" \ -"hwconfig=usb1:dr_mode=host,phy_type=ulpi\0 " \ -"kerneladdr=0x01100000\0" \ -"kernelargs=root=/dev/mtdblock1 rootfstype=cramfs ro\0" \ -"kernelfile=uImage\0" \ -"loadaddr=0x01000000\0" \ -"mbr=uCP1020.mbr\0" \ -"mbr_offset=0x00000000\0" \ -"netdev=eth0\0" \ -"nor_ubootaddr0=0xEC000000\0" \ -"nor_ubootaddr1=0xEFF80000\0" \ -"norkernel=setenv bootargs $kernelargs console=$consoledev,$baudrate; " \ - "run norkernelload; " \ - "bootm $kerneladdr - $dtbaddr\0" \ -"norkernelload=mw.l $kerneladdr 0x0 0x00a00000; " \ - "setenv cramfsaddr $part0base; " \ - "cramfsload $dtbaddr $dtbfile; " \ - "cramfsload $kerneladdr $kernelfile\0" \ -"part0base=0xEC100000\0" \ -"part0size=0x00700000\0" \ -"part1base=0xEC800000\0" \ -"part1size=0x02000000\0" \ -"part2base=0xEE800000\0" \ -"part2size=0x00800000\0" \ -"part3base=0xEF000000\0" \ -"part3size=0x00F80000\0" \ -"partENVbase=0xEC080000\0" \ -"partENVsize=0x00080000\0" \ -"program0=tftp part0-000000.bin; " \ - "protect off $part0base +$filesize; " \ - "erase $part0base +$filesize; " \ - "cp.b $loadaddr $part0base $filesize; " \ - "echo Verifying...; " \ - "cmp.b $loadaddr $part0base $filesize\0" \ -"program1=tftp part1-000000.bin; " \ - "protect off $part1base +$filesize; " \ - "erase $part1base +$filesize; " \ - "cp.b $loadaddr $part1base $filesize; " \ - "echo Verifying...; " \ - "cmp.b $loadaddr $part1base $filesize\0" \ -"program2=tftp part2-000000.bin; " \ - "protect off $part2base +$filesize; " \ - "erase $part2base +$filesize; " \ - "cp.b $loadaddr $part2base $filesize; " \ - "echo Verifying...; " \ - "cmp.b $loadaddr $part2base $filesize\0" \ -"ramboot=setenv bootargs root=/dev/ram ramdisk_size=$ramdisk_size ro" \ - " console=$consoledev,$baudrate $othbootargs; " \ - "tftp $rootfsaddr $rootfsfile; " \ - "tftp $loadaddr $kernelfile; " \ - "tftp $dtbaddr $dtbfile; " \ - "bootm $loadaddr $rootfsaddr $dtbaddr\0" \ -"ramdisk_size=120000\0" \ -"ramdiskfile=rootfs.ext2.gz.uboot\0" \ -"releasefpga=mw.l 0xffe0f000 0x00400000; mw.l 0xffe0f004 0x00000000; " \ - "mw.l 0xffe0f008 0x00400000\0" \ -"rootfsaddr=0x02F00000\0" \ -"rootfsfile=rootfs.ext2.gz.uboot\0" \ -"rootpath=/opt/nfsroot\0" \ -"spi__mbr=fatload mmc $mmcpart $loadaddr $mmbr; " \ - "sf probe 0; sf erase 0 +$filesize; " \ - "sf write $loadaddr 0 $filesize\0" \ -"spi__boot=fatload mmc $mmcpart $loadaddr u-boot.bin; " \ - "protect off 0xeC000000 +$filesize; " \ - "erase 0xEC000000 +$filesize; " \ - "cp.b $loadaddr 0xEC000000 $filesize; " \ - "cmp.b $loadaddr 0xEC000000 $filesize; " \ - "protect on 0xeC000000 +$filesize\0" \ -"tftpflash=tftpboot $loadaddr $uboot; " \ - "protect off " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "erase " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "cp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize; " \ - "protect on " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " +$filesize; " \ - "cmp.b $loadaddr " __stringify(CONFIG_SYS_TEXT_BASE_NOR) " $filesize\0"\ -"uboot= " __stringify(CONFIG_UBOOTPATH) "\0" \ -"ubootfile=u-boot.bin\0" \ -"upgrade=run flashuboot\0" \ -"usb_phy_type=ulpi\0 " \ -"boot_nfs= " \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr\0" \ -"boot_hd = " \ - "setenv bootargs root=/dev/$bdev rw rootdelay=30 " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "usb start;" \ - "ext2load usb 0:1 $loadaddr /boot/$bootfile;" \ - "ext2load usb 0:1 $fdtaddr /boot/$fdtfile;" \ - "bootm $loadaddr - $fdtaddr\0" \ -"boot_usb_fat = " \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs " \ - "ramdisk_size=$ramdisk_size;" \ - "usb start;" \ - "fatload usb 0:2 $loadaddr $bootfile;" \ - "fatload usb 0:2 $fdtaddr $fdtfile;" \ - "fatload usb 0:2 $ramdiskaddr $ramdiskfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr\0 " \ -"boot_usb_ext2 = " \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs " \ - "ramdisk_size=$ramdisk_size;" \ - "usb start;" \ - "ext2load usb 0:4 $loadaddr $bootfile;" \ - "ext2load usb 0:4 $fdtaddr $fdtfile;" \ - "ext2load usb 0:4 $ramdiskaddr $ramdiskfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr\0 " \ -"boot_nor = " \ - "setenv bootargs root=/dev/$jffs2nor rw " \ - "console=$consoledev,$baudrate rootfstype=jffs2 $othbootargs;" \ - "bootm $norbootaddr - $norfdtaddr\0 " \ -"boot_ram = " \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs " \ - "ramdisk_size=$ramdisk_size;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr\0" - -#endif -#endif - -#endif /* __CONFIG_H */
On Mon, Jul 26, 2021 at 07:34:09AM -0600, Simon Glass wrote:
This board has not been converted to CONFIG_DM by the deadline. Remove it.
Leave the Kconfig options to avoid warnings on other boards.
Signed-off-by: Simon Glass sjg@chromium.org
Note the big missed migration deadline here is DM_PCI, although the usage of CONFIG_PCI_INDIRECT_BRIDGE without CONFIG_PCI directly is why this particular board wasn't caught before.
We don't need this code anymore since when PCI is enabled, driver model is always used.
include/pci.h | 60 +++------------------------------------------------ 1 file changed, 3 insertions(+), 57 deletions(-)
diff --git a/include/pci.h b/include/pci.h index 258c8f831ce..e07d6c31bc1 100644 --- a/include/pci.h +++ b/include/pci.h @@ -623,13 +623,9 @@ extern void pci_cfgfunc_config_device(struct pci_controller* hose, pci_dev_t dev * about a small subset of PCI devices. This is normally false. */ struct pci_controller { -#ifdef CONFIG_DM_PCI struct udevice *bus; struct udevice *ctlr; bool skip_auto_config_until_reloc; -#else - struct pci_controller *next; -#endif
int first_busno; int last_busno; @@ -655,54 +651,16 @@ struct pci_controller { struct pci_config_table *config_table;
void (*fixup_irq)(struct pci_controller *, pci_dev_t); -#ifndef CONFIG_DM_PCI - /* Low-level architecture-dependent routines */ - int (*read_byte)(struct pci_controller*, pci_dev_t, int where, u8 *); - int (*read_word)(struct pci_controller*, pci_dev_t, int where, u16 *); - int (*read_dword)(struct pci_controller*, pci_dev_t, int where, u32 *); - int (*write_byte)(struct pci_controller*, pci_dev_t, int where, u8); - int (*write_word)(struct pci_controller*, pci_dev_t, int where, u16); - int (*write_dword)(struct pci_controller*, pci_dev_t, int where, u32); -#endif
/* Used by auto config */ struct pci_region *pci_mem, *pci_io, *pci_prefetch; - -#ifndef CONFIG_DM_PCI - int current_busno; - - void *priv_data; -#endif };
-#ifndef CONFIG_DM_PCI -static inline void pci_set_ops(struct pci_controller *hose, - int (*read_byte)(struct pci_controller*, - pci_dev_t, int where, u8 *), - int (*read_word)(struct pci_controller*, - pci_dev_t, int where, u16 *), - int (*read_dword)(struct pci_controller*, - pci_dev_t, int where, u32 *), - int (*write_byte)(struct pci_controller*, - pci_dev_t, int where, u8), - int (*write_word)(struct pci_controller*, - pci_dev_t, int where, u16), - int (*write_dword)(struct pci_controller*, - pci_dev_t, int where, u32)) { - hose->read_byte = read_byte; - hose->read_word = read_word; - hose->read_dword = read_dword; - hose->write_byte = write_byte; - hose->write_word = write_word; - hose->write_dword = write_dword; -} -#endif - #ifdef CONFIG_PCI_INDIRECT_BRIDGE extern void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data); #endif
-#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) +#if defined(CONFIG_DM_PCI_COMPAT) extern phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, pci_addr_t addr, unsigned long flags); extern pci_addr_t pci_hose_phys_to_bus(struct pci_controller* hose, @@ -752,15 +710,6 @@ extern int pci_hose_write_config_dword(struct pci_controller *hose, pci_dev_t dev, int where, u32 val); #endif
-#ifndef CONFIG_DM_PCI -extern int pci_read_config_byte(pci_dev_t dev, int where, u8 *val); -extern int pci_read_config_word(pci_dev_t dev, int where, u16 *val); -extern int pci_read_config_dword(pci_dev_t dev, int where, u32 *val); -extern int pci_write_config_byte(pci_dev_t dev, int where, u8 val); -extern int pci_write_config_word(pci_dev_t dev, int where, u16 val); -extern int pci_write_config_dword(pci_dev_t dev, int where, u32 val); -#endif - void pciauto_region_init(struct pci_region *res); void pciauto_region_align(struct pci_region *res, pci_size_t size); void pciauto_config_init(struct pci_controller *hose); @@ -780,7 +729,7 @@ void pciauto_config_init(struct pci_controller *hose); int pciauto_region_allocate(struct pci_region *res, pci_size_t size, pci_addr_t *bar, bool supports_64bit);
-#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) +#if defined(CONFIG_DM_PCI_COMPAT) extern int pci_hose_read_config_byte_via_dword(struct pci_controller *hose, pci_dev_t dev, int where, u8 *val); extern int pci_hose_read_config_word_via_dword(struct pci_controller *hose, @@ -827,7 +776,7 @@ int pci_find_next_ext_capability(struct pci_controller *hose, int pci_hose_find_ext_capability(struct pci_controller *hose, pci_dev_t dev, int cap);
-#endif /* !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) */ +#endif /* defined(CONFIG_DM_PCI_COMPAT) */
const char * pci_class_str(u8 class); int pci_last_busno(void); @@ -890,7 +839,6 @@ enum pci_size_t {
struct udevice;
-#ifdef CONFIG_DM_PCI /** * struct pci_child_plat - information stored about each PCI device * @@ -1691,8 +1639,6 @@ int sandbox_pci_get_client(struct udevice *emul, struct udevice **devp); */ extern void board_pci_fixup_dev(struct udevice *bus, struct udevice *dev);
-#endif /* CONFIG_DM_PCI */ - /** * PCI_DEVICE - macro used to describe a specific pci device * @vend: the 16 bit PCI Vendor ID
This prevents use of IS_ENABLED() in other files. Functions should be visible in headers even if they are not available at link time.
Fix it.
include/pci.h | 8 ++++++-- 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/include/pci.h b/include/pci.h index e07d6c31bc1..ca086420ff2 100644 --- a/include/pci.h +++ b/include/pci.h @@ -789,7 +789,6 @@ extern void pci_mpc85xx_init (struct pci_controller *hose); extern void imx_pcie_remove(void); #endif
-#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) /** * pci_write_bar32() - Write the address of a BAR including control bits * @@ -797,6 +796,8 @@ extern void imx_pcie_remove(void); * with devices which require hard-coded addresses, not part of the normal * PCI enumeration process. * + * This is only available if CONFIG_DM_PCI_COMPAT is enabled + * * @hose: PCI hose to use * @dev: PCI device to update * @barnum: BAR number (0-5) @@ -808,6 +809,8 @@ void pci_write_bar32(struct pci_controller *hose, pci_dev_t dev, int barnum, /** * pci_read_bar32() - read the address of a bar * + * This is only available if CONFIG_DM_PCI_COMPAT is enabled + * * @hose: PCI hose to use * @dev: PCI device to inspect * @barnum: BAR number (0-5) @@ -818,6 +821,8 @@ u32 pci_read_bar32(struct pci_controller *hose, pci_dev_t dev, int barnum); /** * pci_hose_find_devices() - Find devices by vendor/device ID * + * This is only available if CONFIG_DM_PCI_COMPAT is enabled + * * @hose: PCI hose to search * @busnum: Bus number to search * @ids: PCI vendor/device IDs to look for, terminated by 0, 0 record @@ -828,7 +833,6 @@ u32 pci_read_bar32(struct pci_controller *hose, pci_dev_t dev, int barnum); */ pci_dev_t pci_hose_find_devices(struct pci_controller *hose, int busnum, struct pci_device_id *ids, int *indexp); -#endif /* !CONFIG_DM_PCI || CONFIG_DM_PCI_COMPAT */
/* Access sizes for PCI reads and writes */ enum pci_size_t {
We don't need this check anymore since when PCI is enabled, driver model is always used.
Sadly this doesn't work with nds32 for some reason to do with the toolchain. Add a work-around for that.
lib/fdtdec.c | 10 ++++++++-- 1 file changed, 8 insertions(+), 2 deletions(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 4b097fb588e..d12c6d340a0 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -192,7 +192,6 @@ fdt_addr_t fdtdec_get_addr(const void *blob, int node, const char *prop_name) return fdtdec_get_addr_size(blob, node, prop_name, NULL); }
-#if CONFIG_IS_ENABLED(PCI) && defined(CONFIG_DM_PCI) int fdtdec_get_pci_vendev(const void *blob, int node, u16 *vendor, u16 *device) { const char *list, *end; @@ -240,7 +239,15 @@ int fdtdec_get_pci_bar32(const struct udevice *dev, struct fdt_pci_addr *addr, return -EINVAL;
barnum = (barnum - PCI_BASE_ADDRESS_0) / 4; + + /* + * There is a strange toolchain bug with nds32 which complains about + * an undefined reference here, even if fdtdec_get_pci_bar32() is never + * called. An #ifdef seems to be the only fix! + */ +#if !IS_ENABLED(CONFIG_NDS32) *bar = dm_pci_read_bar32(dev, barnum); +#endif
return 0; } @@ -260,7 +267,6 @@ int fdtdec_get_pci_bus_range(const void *blob, int node,
return 0; } -#endif
uint64_t fdtdec_get_uint64(const void *blob, int node, const char *prop_name, uint64_t default_val)
drivers/pci/pci_common.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/pci/pci_common.c b/drivers/pci/pci_common.c index 5231b69dc9a..02a71da30fa 100644 --- a/drivers/pci/pci_common.c +++ b/drivers/pci/pci_common.c @@ -99,7 +99,7 @@ __weak int pci_skip_dev(struct pci_controller *hose, pci_dev_t dev) return 0; }
-#if !defined(CONFIG_DM_PCI) || defined(CONFIG_DM_PCI_COMPAT) +#if defined(CONFIG_DM_PCI_COMPAT) /* Get a virtual address associated with a BAR region */ void *pci_map_bar(pci_dev_t pdev, int bar, int flags) { @@ -361,4 +361,4 @@ pci_dev_t pci_find_class(uint find_class, int index)
return -ENODEV; } -#endif /* !CONFIG_DM_PCI || CONFIG_DM_PCI_COMPAT */ +#endif /* CONFIG_DM_PCI_COMPAT */
This is not used. Drop it.
include/configs/MPC8349EMDS.h | 1 - include/configs/MPC8349EMDS_SDRAM.h | 1 - include/configs/MPC837XERDB.h | 1 - include/configs/MPC8540ADS.h | 1 - include/configs/MPC8560ADS.h | 1 - scripts/config_whitelist.txt | 1 - 6 files changed, 6 deletions(-)
diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 2cf2e2de5e6..11959e509a5 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -228,7 +228,6 @@ #endif
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1957 /* Freescale */
diff --git a/include/configs/MPC8349EMDS_SDRAM.h b/include/configs/MPC8349EMDS_SDRAM.h index cfec59e8605..d424427e0c8 100644 --- a/include/configs/MPC8349EMDS_SDRAM.h +++ b/include/configs/MPC8349EMDS_SDRAM.h @@ -283,7 +283,6 @@ #endif
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index ae368a1f1e3..c37cdae07f8 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -258,7 +258,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1957 /* Freescale */ #endif /* CONFIG_PCI */
/* diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index af90fe167a7..afe972ee105 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -241,7 +241,6 @@ #endif
#undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1057 /* Motorola */
diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 5e1bef8f3b0..d24b5b5eac3 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -238,7 +238,6 @@ #endif
diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 042ca116e99..f947ecdb3eb 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -2959,7 +2959,6 @@ CONFIG_SYS_PCI_NR_INBOUND_WIN CONFIG_SYS_PCI_SLV_MEM_BUS CONFIG_SYS_PCI_SLV_MEM_LOCAL CONFIG_SYS_PCI_SLV_MEM_SIZE -CONFIG_SYS_PCI_SUBSYS_VENDORID CONFIG_SYS_PCI_SYS_MEM_BUS CONFIG_SYS_PCI_SYS_MEM_PHYS CONFIG_SYS_PCI_SYS_MEM_SIZE
Drop the old pre-driver model code from these drivers.
arch/powerpc/cpu/mpc83xx/pci.c | 160 ------------------------- arch/powerpc/cpu/mpc85xx/Makefile | 1 - arch/powerpc/cpu/mpc85xx/pci.c | 191 ------------------------------ 3 files changed, 352 deletions(-) delete mode 100644 arch/powerpc/cpu/mpc85xx/pci.c
diff --git a/arch/powerpc/cpu/mpc83xx/pci.c b/arch/powerpc/cpu/mpc83xx/pci.c index 507ab3417b3..65ef0497c2a 100644 --- a/arch/powerpc/cpu/mpc83xx/pci.c +++ b/arch/powerpc/cpu/mpc83xx/pci.c @@ -27,166 +27,6 @@ DECLARE_GLOBAL_DATA_PTR; static struct pci_controller pci_hose[MAX_BUSES]; static int pci_num_buses;
-#if !defined(CONFIG_DM_PCI) -static void pci_init_bus(int bus, struct pci_region *reg) -{ - volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; - volatile pot83xx_t *pot = immr->ios.pot; - volatile pcictrl83xx_t *pci_ctrl = &immr->pci_ctrl[bus]; - struct pci_controller *hose = &pci_hose[bus]; - u32 dev; - u16 reg16; - int i; - - if (bus == 1) - pot += 3; - - /* Setup outbound translation windows */ - for (i = 0; i < 3; i++, reg++, pot++) { - if (reg->size == 0) - break; - - hose->regions[i] = *reg; - hose->region_count++; - - pot->potar = reg->bus_start >> 12; - pot->pobar = reg->phys_start >> 12; - pot->pocmr = ~(reg->size - 1) >> 12; - - if (reg->flags & PCI_REGION_IO) - pot->pocmr |= POCMR_IO; -#ifdef CONFIG_83XX_PCI_STREAMING - else if (reg->flags & PCI_REGION_PREFETCH) - pot->pocmr |= POCMR_SE; -#endif - - if (bus == 1) - pot->pocmr |= POCMR_DST; - - pot->pocmr |= POCMR_EN; - } - - /* Point inbound translation at RAM */ - pci_ctrl->pitar1 = 0; - pci_ctrl->pibar1 = 0; - pci_ctrl->piebar1 = 0; - pci_ctrl->piwar1 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | - PIWAR_WTT_SNOOP | (__ilog2(gd->ram_size - 1)); - - i = hose->region_count++; - hose->regions[i].bus_start = 0; - hose->regions[i].phys_start = 0; - hose->regions[i].size = gd->ram_size; - hose->regions[i].flags = PCI_REGION_MEM | PCI_REGION_SYS_MEMORY; - - hose->first_busno = pci_last_busno() + 1; - hose->last_busno = 0xff; - - pci_setup_indirect(hose, CONFIG_SYS_IMMR + 0x8300 + bus * 0x80, - CONFIG_SYS_IMMR + 0x8304 + bus * 0x80); - - pci_register_hose(hose); - - /* - * Write to Command register - */ - reg16 = 0xff; - dev = PCI_BDF(hose->first_busno, 0, 0); - pci_hose_read_config_word(hose, dev, PCI_COMMAND, ®16); - reg16 |= PCI_COMMAND_SERR | PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY; - pci_hose_write_config_word(hose, dev, PCI_COMMAND, reg16); - - /* - * Clear non-reserved bits in status register. - */ - pci_hose_write_config_word(hose, dev, PCI_STATUS, 0xffff); - pci_hose_write_config_byte(hose, dev, PCI_LATENCY_TIMER, 0x80); - pci_hose_write_config_byte(hose, dev, PCI_CACHE_LINE_SIZE, 0x08); - -#ifdef CONFIG_PCI_SCAN_SHOW - printf("PCI: Bus Dev VenId DevId Class Int\n"); -#endif -#ifndef CONFIG_PCISLAVE - /* - * Hose scan. - */ - hose->last_busno = pci_hose_scan(hose); -#endif -} - -/* - * The caller must have already set OCCR, and the PCI_LAW BARs - * must have been set to cover all of the requested regions. - * - * If fewer than three regions are requested, then the region - * list is terminated with a region of size 0. - */ -void mpc83xx_pci_init(int num_buses, struct pci_region **reg) -{ - volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; - int i; - - if (num_buses > MAX_BUSES) { - printf("%d PCI buses requested, %d supported\n", - num_buses, MAX_BUSES); - - num_buses = MAX_BUSES; - } - - pci_num_buses = num_buses; - - /* - * Release PCI RST Output signal. - * Power on to RST high must be at least 100 ms as per PCI spec. - * On warm boots only 1 ms is required, but we play it safe. - */ - udelay(100000); - - for (i = 0; i < num_buses; i++) - immr->pci_ctrl[i].gcr = 1; - - /* - * RST high to first config access must be at least 2^25 cycles - * as per PCI spec. This could be cut in half if we know we're - * running at 66MHz. This could be insufficiently long if we're - * running the PCI bus at significantly less than 33MHz. - */ - udelay(1020000); - - for (i = 0; i < num_buses; i++) - pci_init_bus(i, reg[i]); -} - -#ifdef CONFIG_PCISLAVE - -#define PCI_FUNCTION_CONFIG 0x44 -#define PCI_FUNCTION_CFG_LOCK 0x20 - -/* - * Unlock the configuration bit so that the host system can begin booting - * - * This should be used after you have: - * 1) Called mpc83xx_pci_init() - * 2) Set up your inbound translation windows to the appropriate size - */ -void mpc83xx_pcislave_unlock(int bus) -{ - struct pci_controller *hose = &pci_hose[bus]; - u32 dev; - u16 reg16; - - /* Unlock configuration lock in PCI function configuration register */ - dev = PCI_BDF(hose->first_busno, 0, 0); - pci_hose_read_config_word (hose, dev, PCI_FUNCTION_CONFIG, ®16); - reg16 &= ~(PCI_FUNCTION_CFG_LOCK); - pci_hose_write_config_word (hose, dev, PCI_FUNCTION_CONFIG, reg16); - - /* The configuration bit is now unlocked, so we can scan the bus */ - hose->last_busno = pci_hose_scan(hose); -} -#endif -#endif /* CONFIG_DM_PCI */ - #if defined(CONFIG_OF_LIBFDT) void ft_pci_setup(void *blob, struct bd_info *bd) { diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index 993e4873184..15248a40824 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -33,7 +33,6 @@ obj-$(CONFIG_CPM2) += ether_fcc.o obj-$(CONFIG_OF_LIBFDT) += fdt.o obj-$(CONFIG_FSL_CORENET) += liodn.o obj-$(CONFIG_MP) += mp.o -obj-$(CONFIG_PCI) += pci.o obj-$(CONFIG_SYS_DPAA_QBMAN) += portals.o
# various SoC specific assignments diff --git a/arch/powerpc/cpu/mpc85xx/pci.c b/arch/powerpc/cpu/mpc85xx/pci.c deleted file mode 100644 index b7835c0fee5..00000000000 --- a/arch/powerpc/cpu/mpc85xx/pci.c +++ /dev/null @@ -1,191 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2004 Freescale Semiconductor. - * Copyright (C) 2003 Motorola Inc. - * Xianghua Xiao (x.xiao@motorola.com) - */ - -/* - * PCI Configuration space access support for MPC85xx PCI Bridge - */ -#include <common.h> -#include <asm/bitops.h> -#include <asm/cpm_85xx.h> -#include <pci.h> - -#if !defined(CONFIG_FSL_PCI_INIT) && !defined(CONFIG_DM_PCI) - -#ifndef CONFIG_SYS_PCI1_MEM_BUS -#define CONFIG_SYS_PCI1_MEM_BUS CONFIG_SYS_PCI1_MEM_BASE -#endif - -#ifndef CONFIG_SYS_PCI1_IO_BUS -#define CONFIG_SYS_PCI1_IO_BUS CONFIG_SYS_PCI1_IO_BASE -#endif - -#ifndef CONFIG_SYS_PCI2_MEM_BUS -#define CONFIG_SYS_PCI2_MEM_BUS CONFIG_SYS_PCI2_MEM_BASE -#endif - -#ifndef CONFIG_SYS_PCI2_IO_BUS -#define CONFIG_SYS_PCI2_IO_BUS CONFIG_SYS_PCI2_IO_BASE -#endif - -static struct pci_controller *pci_hose; - -void -pci_mpc85xx_init(struct pci_controller *board_hose) -{ - u16 reg16; - u32 dev; - - volatile ccsr_pcix_t *pcix = (void *)(CONFIG_SYS_MPC85xx_PCIX_ADDR); -#ifdef CONFIG_MPC85XX_PCI2 - volatile ccsr_pcix_t *pcix2 = (void *)(CONFIG_SYS_MPC85xx_PCIX2_ADDR); -#endif - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct pci_controller * hose; - - pci_hose = board_hose; - - hose = &pci_hose[0]; - - hose->first_busno = 0; - hose->last_busno = 0xff; - - pci_setup_indirect(hose, - (CONFIG_SYS_IMMR+0x8000), - (CONFIG_SYS_IMMR+0x8004)); - - /* - * Hose scan. - */ - dev = PCI_BDF(hose->first_busno, 0, 0); - pci_hose_read_config_word (hose, dev, PCI_COMMAND, ®16); - reg16 |= PCI_COMMAND_SERR | PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY; - pci_hose_write_config_word(hose, dev, PCI_COMMAND, reg16); - - /* - * Clear non-reserved bits in status register. - */ - pci_hose_write_config_word(hose, dev, PCI_STATUS, 0xffff); - - if (!(gur->pordevsr & MPC85xx_PORDEVSR_PCI1)) { - /* PCI-X init */ - if (CONFIG_SYS_CLK_FREQ < 66000000) - printf("PCI-X will only work at 66 MHz\n"); - - reg16 = PCI_X_CMD_MAX_SPLIT | PCI_X_CMD_MAX_READ - | PCI_X_CMD_ERO | PCI_X_CMD_DPERR_E; - pci_hose_write_config_word(hose, dev, PCIX_COMMAND, reg16); - } - - pcix->potar1 = (CONFIG_SYS_PCI1_MEM_BUS >> 12) & 0x000fffff; - pcix->potear1 = 0x00000000; - pcix->powbar1 = (CONFIG_SYS_PCI1_MEM_PHYS >> 12) & 0x000fffff; - pcix->powbear1 = 0x00000000; - pcix->powar1 = (POWAR_EN | POWAR_MEM_READ | - POWAR_MEM_WRITE | (__ilog2(CONFIG_SYS_PCI1_MEM_SIZE) - 1)); - - pcix->potar2 = (CONFIG_SYS_PCI1_IO_BUS >> 12) & 0x000fffff; - pcix->potear2 = 0x00000000; - pcix->powbar2 = (CONFIG_SYS_PCI1_IO_PHYS >> 12) & 0x000fffff; - pcix->powbear2 = 0x00000000; - pcix->powar2 = (POWAR_EN | POWAR_IO_READ | - POWAR_IO_WRITE | (__ilog2(CONFIG_SYS_PCI1_IO_SIZE) - 1)); - - pcix->pitar1 = 0x00000000; - pcix->piwbar1 = 0x00000000; - pcix->piwar1 = (PIWAR_EN | PIWAR_PF | PIWAR_LOCAL | - PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP | PIWAR_MEM_2G); - - pcix->powar3 = 0; - pcix->powar4 = 0; - pcix->piwar2 = 0; - pcix->piwar3 = 0; - - pci_set_region(hose->regions + 0, - CONFIG_SYS_PCI1_MEM_BUS, - CONFIG_SYS_PCI1_MEM_PHYS, - CONFIG_SYS_PCI1_MEM_SIZE, - PCI_REGION_MEM); - - pci_set_region(hose->regions + 1, - CONFIG_SYS_PCI1_IO_BUS, - CONFIG_SYS_PCI1_IO_PHYS, - CONFIG_SYS_PCI1_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = 2; - - pci_register_hose(hose); - - hose->last_busno = pci_hose_scan(hose); - -#ifdef CONFIG_MPC85XX_PCI2 - hose = &pci_hose[1]; - - hose->first_busno = pci_hose[0].last_busno + 1; - hose->last_busno = 0xff; - - pci_setup_indirect(hose, - (CONFIG_SYS_IMMR+0x9000), - (CONFIG_SYS_IMMR+0x9004)); - - dev = PCI_BDF(hose->first_busno, 0, 0); - pci_hose_read_config_word (hose, dev, PCI_COMMAND, ®16); - reg16 |= PCI_COMMAND_SERR | PCI_COMMAND_MASTER | PCI_COMMAND_MEMORY; - pci_hose_write_config_word(hose, dev, PCI_COMMAND, reg16); - - /* - * Clear non-reserved bits in status register. - */ - pci_hose_write_config_word(hose, dev, PCI_STATUS, 0xffff); - - pcix2->potar1 = (CONFIG_SYS_PCI2_MEM_BUS >> 12) & 0x000fffff; - pcix2->potear1 = 0x00000000; - pcix2->powbar1 = (CONFIG_SYS_PCI2_MEM_PHYS >> 12) & 0x000fffff; - pcix2->powbear1 = 0x00000000; - pcix2->powar1 = (POWAR_EN | POWAR_MEM_READ | - POWAR_MEM_WRITE | (__ilog2(CONFIG_SYS_PCI2_MEM_SIZE) - 1)); - - pcix2->potar2 = (CONFIG_SYS_PCI2_IO_BUS >> 12) & 0x000fffff; - pcix2->potear2 = 0x00000000; - pcix2->powbar2 = (CONFIG_SYS_PCI2_IO_PHYS >> 12) & 0x000fffff; - pcix2->powbear2 = 0x00000000; - pcix2->powar2 = (POWAR_EN | POWAR_IO_READ | - POWAR_IO_WRITE | (__ilog2(CONFIG_SYS_PCI2_IO_SIZE) - 1)); - - pcix2->pitar1 = 0x00000000; - pcix2->piwbar1 = 0x00000000; - pcix2->piwar1 = (PIWAR_EN | PIWAR_PF | PIWAR_LOCAL | - PIWAR_READ_SNOOP | PIWAR_WRITE_SNOOP | PIWAR_MEM_2G); - - pcix2->powar3 = 0; - pcix2->powar4 = 0; - pcix2->piwar2 = 0; - pcix2->piwar3 = 0; - - pci_set_region(hose->regions + 0, - CONFIG_SYS_PCI2_MEM_BUS, - CONFIG_SYS_PCI2_MEM_PHYS, - CONFIG_SYS_PCI2_MEM_SIZE, - PCI_REGION_MEM); - - pci_set_region(hose->regions + 1, - CONFIG_SYS_PCI2_IO_BUS, - CONFIG_SYS_PCI2_IO_PHYS, - CONFIG_SYS_PCI2_IO_SIZE, - PCI_REGION_IO); - - hose->region_count = 2; - - /* - * Hose scan. - */ - pci_register_hose(hose); - - hose->last_busno = pci_hose_scan(hose); -#endif -} -#endif /* !CONFIG_FSL_PCI_INIT */
Drop this old pre-driver model code.
board/freescale/common/cds_pci_ft.c | 59 ---------- board/freescale/common/p_corenet/Makefile | 1 - board/freescale/common/p_corenet/pci.c | 25 ----- board/freescale/mpc8548cds/mpc8548cds.c | 114 -------------------- board/freescale/p1010rdb/p1010rdb.c | 11 -- board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c | 11 -- board/freescale/t102xrdb/Makefile | 1 - board/freescale/t102xrdb/pci.c | 25 ----- board/freescale/t104xrdb/Makefile | 1 - board/freescale/t104xrdb/pci.c | 25 ----- board/freescale/t208xqds/Makefile | 1 - board/freescale/t208xqds/pci.c | 25 ----- board/freescale/t208xrdb/Makefile | 1 - board/freescale/t208xrdb/pci.c | 25 ----- board/freescale/t4rdb/Makefile | 1 - board/freescale/t4rdb/pci.c | 25 ----- 16 files changed, 351 deletions(-) delete mode 100644 board/freescale/common/p_corenet/pci.c delete mode 100644 board/freescale/t102xrdb/pci.c delete mode 100644 board/freescale/t104xrdb/pci.c delete mode 100644 board/freescale/t208xqds/pci.c delete mode 100644 board/freescale/t208xrdb/pci.c delete mode 100644 board/freescale/t4rdb/pci.c
diff --git a/board/freescale/common/cds_pci_ft.c b/board/freescale/common/cds_pci_ft.c index be97a28ed25..dc2d62850d1 100644 --- a/board/freescale/common/cds_pci_ft.c +++ b/board/freescale/common/cds_pci_ft.c @@ -9,68 +9,9 @@ #include "cadmus.h"
#if defined(CONFIG_OF_BOARD_SETUP) -#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) -static void cds_pci_fixup(void *blob) -{ - int node; - const char *path; - int len, slot, i; - u32 *map = NULL, *piccells = NULL; - int off, cells; - - node = fdt_path_offset(blob, "/aliases"); - if (node >= 0) { - path = fdt_getprop(blob, node, "pci0", NULL); - if (path) { - node = fdt_path_offset(blob, path); - if (node >= 0) { - map = fdt_getprop_w(blob, node, "interrupt-map", &len); - } - /* Each item in "interrupt-map" property is translated with - * following cells: - * PCI #address-cells, PCI #interrupt-cells, - * PIC address, PIC #address-cells, PIC #interrupt-cells. - */ - cells = fdt_getprop_u32_default(blob, path, "#address-cells", 1); - cells += fdt_getprop_u32_default(blob, path, "#interrupt-cells", 1); - off = fdt_node_offset_by_phandle(blob, fdt32_to_cpu(*(map+cells))); - if (off <= 0) - return; - cells += 1; - piccells = (u32 *)fdt_getprop(blob, off, "#address-cells", NULL); - if (piccells == NULL) - return; - cells += *piccells; - piccells = (u32 *)fdt_getprop(blob, off, "#interrupt-cells", NULL); - if (piccells == NULL) - return; - cells += *piccells; - } - } - - if (map) { - len /= sizeof(u32); - - slot = get_pci_slot(); - - for (i=0;i<len;i+=cells) { - /* We rotate the interrupt pins so that the mapping - * changes depending on the slot the carrier card is in. - */ - map[3] = ((map[3] + slot - 2) % 4) + 1; - map+=cells; - } - } -} -#endif - int ft_board_setup(void *blob, struct bd_info *bd) { ft_cpu_setup(blob, bd); -#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) - ft_pci_setup(blob, bd); - cds_pci_fixup(blob); -#endif
return 0; } diff --git a/board/freescale/common/p_corenet/Makefile b/board/freescale/common/p_corenet/Makefile index 29c9d544ae5..ce156018a06 100644 --- a/board/freescale/common/p_corenet/Makefile +++ b/board/freescale/common/p_corenet/Makefile @@ -4,5 +4,4 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-y += law.o -obj-$(CONFIG_PCI) += pci.o obj-y += tlb.o diff --git a/board/freescale/common/p_corenet/pci.c b/board/freescale/common/p_corenet/pci.c deleted file mode 100644 index 636334863e1..00000000000 --- a/board/freescale/common/p_corenet/pci.c +++ /dev/null @@ -1,25 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2007-2011 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <command.h> -#include <init.h> -#include <pci.h> -#include <asm/fsl_pci.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <asm/fsl_serdes.h> - -#if !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} - -void pci_of_setup(void *blob, struct bd_info *bd) -{ - FT_FSL_PCI_SETUP; -} -#endif diff --git a/board/freescale/mpc8548cds/mpc8548cds.c b/board/freescale/mpc8548cds/mpc8548cds.c index a1a9742bfa4..cfb5b0b38bb 100644 --- a/board/freescale/mpc8548cds/mpc8548cds.c +++ b/board/freescale/mpc8548cds/mpc8548cds.c @@ -168,113 +168,6 @@ void lbc_sdram_init(void) #endif /* enable SDRAM init */ }
-#if (defined(CONFIG_PCI) || defined(CONFIG_PCI1)) && !defined(CONFIG_DM_PCI) -/* For some reason the Tundra PCI bridge shows up on itself as a - * different device. Work around that by refusing to configure it. - */ -void dummy_func(struct pci_controller* hose, pci_dev_t dev, struct pci_config_table *tab) { } - -static struct pci_config_table pci_mpc85xxcds_config_table[] = { - {0x10e3, 0x0513, PCI_ANY_ID, 1, 3, PCI_ANY_ID, dummy_func, {0,0,0}}, - {0x1106, 0x0686, PCI_ANY_ID, 1, VIA_ID, 0, mpc85xx_config_via, {0,0,0}}, - {0x1106, 0x0571, PCI_ANY_ID, 1, VIA_ID, 1, - mpc85xx_config_via_usbide, {0,0,0}}, - {0x1105, 0x3038, PCI_ANY_ID, 1, VIA_ID, 2, - mpc85xx_config_via_usb, {0,0,0}}, - {0x1106, 0x3038, PCI_ANY_ID, 1, VIA_ID, 3, - mpc85xx_config_via_usb2, {0,0,0}}, - {0x1106, 0x3058, PCI_ANY_ID, 1, VIA_ID, 5, - mpc85xx_config_via_power, {0,0,0}}, - {0x1106, 0x3068, PCI_ANY_ID, 1, VIA_ID, 6, - mpc85xx_config_via_ac97, {0,0,0}}, - {}, -}; - -static struct pci_controller pci1_hose; -#endif /* CONFIG_PCI */ - -#if !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - struct fsl_pci_info pci_info; - u32 devdisr, pordevsr, io_sel; - u32 porpllsr, pci_agent, pci_speed, pci_32, pci_arb, pci_clk_sel; - int first_free_busno = 0; - char buf[32]; - - devdisr = in_be32(&gur->devdisr); - pordevsr = in_be32(&gur->pordevsr); - porpllsr = in_be32(&gur->porpllsr); - io_sel = (pordevsr & MPC85xx_PORDEVSR_IO_SEL) >> 19; - - debug (" pci_init_board: devdisr=%x, io_sel=%x\n", devdisr, io_sel); - -#ifdef CONFIG_PCI1 - pci_speed = get_clock_freq (); /* PCI PSPEED in [4:5] */ - pci_32 = pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; /* PORDEVSR[15] */ - pci_arb = pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; - pci_clk_sel = porpllsr & MPC85xx_PORDEVSR_PCI1_SPD; - - if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info, 1); - set_next_law(pci_info.mem_phys, - law_size_bits(pci_info.mem_size), pci_info.law); - set_next_law(pci_info.io_phys, - law_size_bits(pci_info.io_size), pci_info.law); - - pci_agent = fsl_setup_hose(&pci1_hose, pci_info.regs); - printf("PCI1: %d bit, %s MHz, %s, %s, %s (base address %lx)\n", - (pci_32) ? 32 : 64, - strmhz(buf, pci_speed), - pci_clk_sel ? "sync" : "async", - pci_agent ? "agent" : "host", - pci_arb ? "arbiter" : "external-arbiter", - pci_info.regs); - - pci1_hose.config_table = pci_mpc85xxcds_config_table; - first_free_busno = fsl_pci_init_port(&pci_info, - &pci1_hose, first_free_busno); - -#ifdef CONFIG_PCIX_CHECK - if (!(pordevsr & MPC85xx_PORDEVSR_PCI1)) { - /* PCI-X init */ - if (CONFIG_SYS_CLK_FREQ < 66000000) - printf("PCI-X will only work at 66 MHz\n"); - - reg16 = PCI_X_CMD_MAX_SPLIT | PCI_X_CMD_MAX_READ - | PCI_X_CMD_ERO | PCI_X_CMD_DPERR_E; - pci_hose_write_config_word(hose, bus, PCIX_COMMAND, reg16); - } -#endif - } else { - printf("PCI1: disabled\n"); - } - - puts("\n"); -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); /* disable */ -#endif - -#ifdef CONFIG_PCI2 -{ - uint pci2_clk_sel = porpllsr & 0x4000; /* PORPLLSR[17] */ - uint pci_dual = get_pci_dual (); /* PCI DUAL in CM_PCI[3] */ - if (pci_dual) { - printf("PCI2: 32 bit, 66 MHz, %s\n", - pci2_clk_sel ? "sync" : "async"); - } else { - printf("PCI2: disabled\n"); - } -} -#else - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI2); /* disable */ -#endif /* CONFIG_PCI2 */ - - fsl_pcie_init_board(first_free_busno); -} -#endif - void configure_rgmii(void) { unsigned short temp; @@ -354,10 +247,3 @@ int board_eth_init(struct bd_info *bis)
return pci_eth_init(bis); } - -#if defined(CONFIG_OF_BOARD_SETUP) && !defined(CONFIG_DM_PCI) -void ft_pci_setup(void *blob, struct bd_info *bd) -{ - FT_FSL_PCI_SETUP; -} -#endif diff --git a/board/freescale/p1010rdb/p1010rdb.c b/board/freescale/p1010rdb/p1010rdb.c index 90436337df1..84fc891b67c 100644 --- a/board/freescale/p1010rdb/p1010rdb.c +++ b/board/freescale/p1010rdb/p1010rdb.c @@ -129,13 +129,6 @@ int board_early_init_r(void) return 0; }
-#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} -#endif /* ifdef CONFIG_PCI */ - int config_board_mux(int ctrl_type) { ccsr_gur_t __iomem *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); @@ -617,10 +610,6 @@ int ft_board_setup(void *blob, struct bd_info *bd) base = env_get_bootm_low(); size = env_get_bootm_size();
-#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) - FT_FSL_PCI_SETUP; -#endif - fdt_fixup_memory(blob, (u64)base, (u64)size);
#if defined(CONFIG_HAS_FSL_DR_USB) diff --git a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c index 8273384f2d5..fb9bf795e30 100644 --- a/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c +++ b/board/freescale/p1_p2_rdb_pc/p1_p2_rdb_pc.c @@ -239,13 +239,6 @@ int checkboard(void) return 0; }
-#if defined(CONFIG_PCI) && !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} -#endif - int board_early_init_r(void) { const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; @@ -363,10 +356,6 @@ int ft_board_setup(void *blob, struct bd_info *bd)
-#if !defined(CONFIG_DM_PCI) - FT_FSL_PCI_SETUP; -#endif - #ifdef CONFIG_QE do_fixup_by_compat(blob, "fsl,qe", "status", "okay", sizeof("okay"), 0); diff --git a/board/freescale/t102xrdb/Makefile b/board/freescale/t102xrdb/Makefile index ddeb44f36e2..e597486c940 100644 --- a/board/freescale/t102xrdb/Makefile +++ b/board/freescale/t102xrdb/Makefile @@ -10,7 +10,6 @@ else obj-y += t102xrdb.o obj-$(CONFIG_TARGET_T1024RDB) += cpld.o obj-y += eth_t102xrdb.o -obj-$(CONFIG_PCI) += pci.o endif obj-y += ddr.o obj-y += law.o diff --git a/board/freescale/t102xrdb/pci.c b/board/freescale/t102xrdb/pci.c deleted file mode 100644 index 45ab9223ae1..00000000000 --- a/board/freescale/t102xrdb/pci.c +++ /dev/null @@ -1,25 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2007-2014 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <command.h> -#include <init.h> -#include <pci.h> -#include <asm/fsl_pci.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <asm/fsl_serdes.h> - -#if !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} - -void pci_of_setup(void *blob, struct bd_info *bd) -{ - FT_FSL_PCI_SETUP; -} -#endif diff --git a/board/freescale/t104xrdb/Makefile b/board/freescale/t104xrdb/Makefile index 31abbd9aca0..d67e9412ecd 100644 --- a/board/freescale/t104xrdb/Makefile +++ b/board/freescale/t104xrdb/Makefile @@ -8,7 +8,6 @@ else obj-y += t104xrdb.o obj-y += cpld.o obj-y += eth.o -obj-$(CONFIG_PCI) += pci.o obj-$(CONFIG_FSL_DIU_FB)+= diu.o endif obj-y += ddr.o diff --git a/board/freescale/t104xrdb/pci.c b/board/freescale/t104xrdb/pci.c deleted file mode 100644 index 1fd24027000..00000000000 --- a/board/freescale/t104xrdb/pci.c +++ /dev/null @@ -1,25 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <command.h> -#include <init.h> -#include <pci.h> -#include <asm/fsl_pci.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <asm/fsl_serdes.h> - -#if !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} - -void pci_of_setup(void *blob, struct bd_info *bd) -{ - FT_FSL_PCI_SETUP; -} -#endif diff --git a/board/freescale/t208xqds/Makefile b/board/freescale/t208xqds/Makefile index 55b1e7390a0..de8613058de 100644 --- a/board/freescale/t208xqds/Makefile +++ b/board/freescale/t208xqds/Makefile @@ -8,7 +8,6 @@ ifdef CONFIG_SPL_BUILD obj-y += spl.o else obj-$(CONFIG_TARGET_T2080QDS) += t208xqds.o eth_t208xqds.o -obj-$(CONFIG_PCI) += pci.o endif
obj-y += ddr.o diff --git a/board/freescale/t208xqds/pci.c b/board/freescale/t208xqds/pci.c deleted file mode 100644 index a03b11ccb50..00000000000 --- a/board/freescale/t208xqds/pci.c +++ /dev/null @@ -1,25 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2007-2013 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <command.h> -#include <init.h> -#include <pci.h> -#include <asm/fsl_pci.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <asm/fsl_serdes.h> - -#if !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} - -void pci_of_setup(void *blob, struct bd_info *bd) -{ - FT_FSL_PCI_SETUP; -} -#endif diff --git a/board/freescale/t208xrdb/Makefile b/board/freescale/t208xrdb/Makefile index 25ea66a0248..7af3cd0ac4c 100644 --- a/board/freescale/t208xrdb/Makefile +++ b/board/freescale/t208xrdb/Makefile @@ -8,7 +8,6 @@ ifdef CONFIG_SPL_BUILD obj-y += spl.o else obj-$(CONFIG_TARGET_T2080RDB) += t208xrdb.o eth_t208xrdb.o cpld.o -obj-$(CONFIG_PCI) += pci.o endif
obj-y += ddr.o diff --git a/board/freescale/t208xrdb/pci.c b/board/freescale/t208xrdb/pci.c deleted file mode 100644 index 45ab9223ae1..00000000000 --- a/board/freescale/t208xrdb/pci.c +++ /dev/null @@ -1,25 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2007-2014 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <command.h> -#include <init.h> -#include <pci.h> -#include <asm/fsl_pci.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <asm/fsl_serdes.h> - -#if !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} - -void pci_of_setup(void *blob, struct bd_info *bd) -{ - FT_FSL_PCI_SETUP; -} -#endif diff --git a/board/freescale/t4rdb/Makefile b/board/freescale/t4rdb/Makefile index f1fd623339c..3106848639c 100644 --- a/board/freescale/t4rdb/Makefile +++ b/board/freescale/t4rdb/Makefile @@ -10,7 +10,6 @@ else obj-$(CONFIG_TARGET_T4240RDB) += t4240rdb.o obj-y += cpld.o obj-y += eth.o -obj-$(CONFIG_PCI) += pci.o endif
obj-y += ddr.o diff --git a/board/freescale/t4rdb/pci.c b/board/freescale/t4rdb/pci.c deleted file mode 100644 index c2bc05164dd..00000000000 --- a/board/freescale/t4rdb/pci.c +++ /dev/null @@ -1,25 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2014 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <command.h> -#include <init.h> -#include <pci.h> -#include <asm/fsl_pci.h> -#include <linux/libfdt.h> -#include <fdt_support.h> -#include <asm/fsl_serdes.h> - -#if !defined(CONFIG_DM_PCI) -void pci_init_board(void) -{ - fsl_pcie_init_board(0); -} - -void pci_of_setup(void *blob, struct bd_info *bd) -{ - FT_FSL_PCI_SETUP; -} -#endif
drivers/core/fdtaddr.c | 3 +-- 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/core/fdtaddr.c b/drivers/core/fdtaddr.c index b9874c743d1..4ffbd6b2ebc 100644 --- a/drivers/core/fdtaddr.c +++ b/drivers/core/fdtaddr.c @@ -200,8 +200,7 @@ fdt_addr_t devfdt_get_addr_pci(const struct udevice *dev) ulong addr;
addr = devfdt_get_addr(dev); - if (CONFIG_IS_ENABLED(PCI) && IS_ENABLED(CONFIG_DM_PCI) && - addr == FDT_ADDR_T_NONE) { + if (CONFIG_IS_ENABLED(PCI) && addr == FDT_ADDR_T_NONE) { struct fdt_pci_addr pci_addr; u32 bar; int ret;
Now that DM_PCI is always enabled we don't need to check it. Drop this old code.
include/configs/MPC8548CDS.h | 16 ---------------- include/configs/P1010RDB.h | 28 ---------------------------- include/configs/P2041RDB.h | 17 ----------------- include/configs/T102xRDB.h | 17 ----------------- include/configs/T104xRDB.h | 20 -------------------- include/configs/T208xQDS.h | 20 -------------------- include/configs/T208xRDB.h | 20 -------------------- include/configs/T4240RDB.h | 21 --------------------- include/configs/corenet_ds.h | 21 --------------------- include/configs/p1_p2_rdb_pc.h | 24 ------------------------ 10 files changed, 204 deletions(-)
diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 9f83931bed5..bcb02b0612e 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -371,23 +371,7 @@ extern unsigned long get_clock_freq(void); #endif
#if defined(CONFIG_PCI) - -#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT 1 /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE 1 -#define CONFIG_SYS_PCIE1_NAME "Slot" -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#else -#define CONFIG_SYS_PCIE1_MEM_BUS 0xa0000000 -#endif -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00100000 /* 1M */ -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ - #endif /* CONFIG_PCI */
#if defined(CONFIG_TSEC_ENET) diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 1b68fd10728..7f14e99595c 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -150,34 +150,6 @@ #define CONFIG_SYS_PCIE2_IO_PHYS 0xffc10000 #endif
-#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ -#define CONFIG_SYS_PCIE1_NAME "mini PCIe Slot" -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#else -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#endif -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ - -#if defined(CONFIG_TARGET_P1010RDB_PA) -#define CONFIG_SYS_PCIE2_NAME "PCIe Slot" -#elif defined(CONFIG_TARGET_P1010RDB_PB) -#define CONFIG_SYS_PCIE2_NAME "mini PCIe Slot" -#endif -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 -#else -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 -#endif -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif
diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 715154a0ddf..498735ed85c 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -417,23 +417,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
#ifdef CONFIG_PCI -#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 35b11ad88a8..dd0160b9bad 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -487,23 +487,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull #endif
-#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index ea239f74c14..2c496551233 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -537,26 +537,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull #endif
-#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#endif #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 7bc792b8d19..4dcc49583f7 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -486,26 +486,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull
#ifdef CONFIG_PCI -#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#endif #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 9449e30bfca..c3c93783ed7 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -435,26 +435,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull
diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 139beae08db..89e9d62bb2d 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -196,27 +196,6 @@ #define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull
#ifdef CONFIG_PCI -#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index d0843c284e6..b343ac83519 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -430,27 +430,6 @@ #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH)
#ifdef CONFIG_PCI -#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 066311a97e4..84e330dd691 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -529,30 +529,6 @@ #define CONFIG_SYS_PCIE1_IO_PHYS 0xffc00000 #endif
-#if !defined(CONFIG_DM_PCI) -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_PCI_INDIRECT_BRIDGE -#define CONFIG_SYS_PCIE2_NAME "PCIe SLOT" -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE2_MEM_BUS 0xc0000000 -#else -#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 -#endif -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ - -#define CONFIG_SYS_PCIE1_NAME "mini PCIe SLOT" -#ifdef CONFIG_PHYS_64BIT -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#else -#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 -#endif -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ -#endif - #define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
We don't need these checks anymore since when PCI is enabled, driver model is always used.
Drop them.
drivers/ata/ahci.c | 55 ---------------------------------------------- include/ahci.h | 4 ---- 2 files changed, 59 deletions(-)
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index d4047c04f5d..2062197afcd 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -170,13 +170,8 @@ int ahci_reset(void __iomem *base) static int ahci_host_init(struct ahci_uc_priv *uc_priv) { #if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) -# ifdef CONFIG_DM_PCI struct udevice *dev = uc_priv->dev; struct pci_child_plat *pplat = dev_get_parent_plat(dev); -# else - pci_dev_t pdev = uc_priv->dev; - unsigned short vendor; -# endif u16 tmp16; #endif void __iomem *mmio = uc_priv->mmio_base; @@ -200,23 +195,12 @@ static int ahci_host_init(struct ahci_uc_priv *uc_priv) writel_with_flush(0xf, mmio + HOST_PORTS_IMPL);
#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) -# ifdef CONFIG_DM_PCI if (pplat->vendor == PCI_VENDOR_ID_INTEL) { u16 tmp16;
dm_pci_read_config16(dev, 0x92, &tmp16); dm_pci_write_config16(dev, 0x92, tmp16 | 0xf); } -# else - pci_read_config_word(pdev, PCI_VENDOR_ID, &vendor); - - if (vendor == PCI_VENDOR_ID_INTEL) { - u16 tmp16; - pci_read_config_word(pdev, 0x92, &tmp16); - tmp16 |= 0xf; - pci_write_config_word(pdev, 0x92, tmp16); - } -# endif #endif uc_priv->cap = readl(mmio + HOST_CAP); uc_priv->port_map = readl(mmio + HOST_PORTS_IMPL); @@ -331,15 +315,9 @@ static int ahci_host_init(struct ahci_uc_priv *uc_priv) debug("HOST_CTL 0x%x\n", tmp); #if !defined(CONFIG_DM_SCSI) #ifndef CONFIG_SCSI_AHCI_PLAT -# ifdef CONFIG_DM_PCI dm_pci_read_config16(dev, PCI_COMMAND, &tmp16); tmp |= PCI_COMMAND_MASTER; dm_pci_write_config16(dev, PCI_COMMAND, tmp16); -# else - pci_read_config_word(pdev, PCI_COMMAND, &tmp16); - tmp |= PCI_COMMAND_MASTER; - pci_write_config_word(pdev, PCI_COMMAND, tmp16); -# endif #endif #endif return 0; @@ -349,11 +327,7 @@ static int ahci_host_init(struct ahci_uc_priv *uc_priv) static void ahci_print_info(struct ahci_uc_priv *uc_priv) { #if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) -# if defined(CONFIG_DM_PCI) struct udevice *dev = uc_priv->dev; -# else - pci_dev_t pdev = uc_priv->dev; -# endif u16 cc; #endif void __iomem *mmio = uc_priv->mmio_base; @@ -379,11 +353,7 @@ static void ahci_print_info(struct ahci_uc_priv *uc_priv) #if defined(CONFIG_SCSI_AHCI_PLAT) || defined(CONFIG_DM_SCSI) scc_s = "SATA"; #else -# ifdef CONFIG_DM_PCI dm_pci_read_config16(dev, 0x0a, &cc); -# else - pci_read_config_word(pdev, 0x0a, &cc); -# endif if (cc == 0x0101) scc_s = "IDE"; else if (cc == 0x0106) @@ -428,11 +398,7 @@ static void ahci_print_info(struct ahci_uc_priv *uc_priv) }
#if defined(CONFIG_DM_SCSI) || !defined(CONFIG_SCSI_AHCI_PLAT) -# if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SCSI) static int ahci_init_one(struct ahci_uc_priv *uc_priv, struct udevice *dev) -# else -static int ahci_init_one(struct ahci_uc_priv *uc_priv, pci_dev_t dev) -# endif { #if !defined(CONFIG_DM_SCSI) u16 vendor; @@ -450,7 +416,6 @@ static int ahci_init_one(struct ahci_uc_priv *uc_priv, pci_dev_t dev) uc_priv->udma_mask = 0x7f; /*Fixme,assume to support UDMA6 */
#if !defined(CONFIG_DM_SCSI) -#ifdef CONFIG_DM_PCI uc_priv->mmio_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_5, PCI_REGION_MEM);
@@ -461,18 +426,6 @@ static int ahci_init_one(struct ahci_uc_priv *uc_priv, pci_dev_t dev) dm_pci_read_config16(dev, PCI_VENDOR_ID, &vendor); if (vendor == 0x197b) dm_pci_write_config8(dev, 0x41, 0xa1); -#else - uc_priv->mmio_base = pci_map_bar(dev, PCI_BASE_ADDRESS_5, - PCI_REGION_MEM); - - /* Take from kernel: - * JMicron-specific fixup: - * make sure we're in AHCI mode - */ - pci_read_config_word(dev, PCI_VENDOR_ID, &vendor); - if (vendor == 0x197b) - pci_write_config_byte(dev, 0x41, 0xa1); -#endif #else struct scsi_plat *plat = dev_get_uclass_plat(dev); uc_priv->mmio_base = (void *)plat->base; @@ -1006,7 +959,6 @@ void scsi_low_level_init(int busdevfunc) return; } uc_priv = probe_ent; -# if defined(CONFIG_DM_PCI) struct udevice *dev; int ret;
@@ -1014,9 +966,6 @@ void scsi_low_level_init(int busdevfunc) if (ret) return; ahci_init_one(uc_priv, dev); -# else - ahci_init_one(uc_priv, busdevfunc); -# endif #else uc_priv = probe_ent; #endif @@ -1026,7 +975,6 @@ void scsi_low_level_init(int busdevfunc) #endif
#ifndef CONFIG_SCSI_AHCI_PLAT -# if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SCSI) int ahci_init_one_dm(struct udevice *dev) { struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev); @@ -1034,7 +982,6 @@ int ahci_init_one_dm(struct udevice *dev) return ahci_init_one(uc_priv, dev); } #endif -#endif
int ahci_start_ports_dm(struct udevice *dev) { @@ -1196,7 +1143,6 @@ int ahci_probe_scsi(struct udevice *ahci_dev, ulong base) return 0; }
-#ifdef CONFIG_DM_PCI int ahci_probe_scsi_pci(struct udevice *ahci_dev) { ulong base; @@ -1221,7 +1167,6 @@ int ahci_probe_scsi_pci(struct udevice *ahci_dev) PCI_REGION_MEM); return ahci_probe_scsi(ahci_dev, base); } -#endif
struct scsi_ops scsi_ops = { .exec = ahci_scsi_exec, diff --git a/include/ahci.h b/include/ahci.h index fb96dd88611..d5453042d15 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -148,16 +148,12 @@ struct ahci_ioports { * where dev is the controller (although at present it sometimes stands alone). */ struct ahci_uc_priv { -#if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SCSI) /* * TODO(sjg@chromium.org): Drop this once this structure is only used * in a driver-model context (i.e. attached to a device with * dev_get_uclass_priv() */ struct udevice *dev; -#else - pci_dev_t dev; -#endif struct ahci_ioports port[AHCI_MAX_PORTS]; u16 *ataid[AHCI_MAX_PORTS]; u32 n_ports;
Now that DM_PCI is always enabled we don't need to check it. Drop this old condition and update the comment.
drivers/usb/host/ohci-hcd.c | 15 +++++---------- 1 file changed, 5 insertions(+), 10 deletions(-)
diff --git a/drivers/usb/host/ohci-hcd.c b/drivers/usb/host/ohci-hcd.c index c62d8feecce..7fa84f8bbe4 100644 --- a/drivers/usb/host/ohci-hcd.c +++ b/drivers/usb/host/ohci-hcd.c @@ -52,13 +52,6 @@ #include <asm/arch/hardware.h> /* needed for AT91_USB_HOST_BASE */ #endif
-#if defined(CONFIG_CPU_ARM920T) || \ - defined(CONFIG_PCI_OHCI) || \ - defined(CONFIG_DM_PCI) || \ - defined(CONFIG_SYS_OHCI_USE_NPS) -# define OHCI_USE_NPS /* force NoPowerSwitching mode */ -#endif - #undef OHCI_VERBOSE_DEBUG /* not always helpful */ #undef DEBUG #undef SHOW_INFO @@ -1885,12 +1878,14 @@ static int hc_start(ohci_t *ohci) mask = OHCI_INTR_RHSC | OHCI_INTR_UE | OHCI_INTR_WDH | OHCI_INTR_SO; ohci_writel(mask, &ohci->regs->intrenable);
-#ifdef OHCI_USE_NPS - /* required for AMD-756 and some Mac platforms */ + /* + * required for AMD-756 and some Mac platforms + * Note: this is always enabled at present, since driver model is used + * for PCI + */ ohci_writel((roothub_a(ohci) | RH_A_NPS) & ~RH_A_PSM, &ohci->regs->roothub.a); ohci_writel(RH_HS_LPSC, &ohci->regs->roothub.status); -#endif /* OHCI_USE_NPS */
/* connect the virtual root hub */ ohci->rh.devnum = 0;
board/imgtec/malta/malta.c | 67 -------------------------------------- 1 file changed, 67 deletions(-)
diff --git a/board/imgtec/malta/malta.c b/board/imgtec/malta/malta.c index 9af1f92e5db..d2e2e4ae209 100644 --- a/board/imgtec/malta/malta.c +++ b/board/imgtec/malta/malta.c @@ -196,7 +196,6 @@ int board_fix_fdt(void *rw_fdt_blob) } #endif
-#if IS_ENABLED(CONFIG_DM_PCI) int board_early_init_r(void) { struct udevice *dev; @@ -243,69 +242,3 @@ int board_early_init_r(void)
return 0; } -#else -void pci_init_board(void) -{ - pci_dev_t bdf; - u32 val32; - u8 val8; - - switch (malta_sys_con()) { - case SYSCON_GT64120: - gt64120_pci_init((void *)CKSEG1ADDR(MALTA_GT_BASE), - 0x00000000, 0x00000000, CONFIG_SYS_MEM_SIZE, - 0x10000000, 0x10000000, 128 * 1024 * 1024, - 0x00000000, 0x00000000, 0x20000); - break; - - default: - case SYSCON_MSC01: - msc01_pci_init((void *)CKSEG1ADDR(MALTA_MSC01_PCI_BASE), - 0x00000000, 0x00000000, CONFIG_SYS_MEM_SIZE, - MALTA_MSC01_PCIMEM_MAP, - CKSEG1ADDR(MALTA_MSC01_PCIMEM_BASE), - MALTA_MSC01_PCIMEM_SIZE, MALTA_MSC01_PCIIO_MAP, - 0x00000000, MALTA_MSC01_PCIIO_SIZE); - break; - } - - bdf = pci_find_device(PCI_VENDOR_ID_INTEL, - PCI_DEVICE_ID_INTEL_82371AB_0, 0); - if (bdf == -1) - panic("Failed to find PIIX4 PCI bridge\n"); - - /* setup PCI interrupt routing */ - pci_write_config_byte(bdf, PCI_CFG_PIIX4_PIRQRCA, 10); - pci_write_config_byte(bdf, PCI_CFG_PIIX4_PIRQRCB, 10); - pci_write_config_byte(bdf, PCI_CFG_PIIX4_PIRQRCC, 11); - pci_write_config_byte(bdf, PCI_CFG_PIIX4_PIRQRCD, 11); - - /* mux SERIRQ onto SERIRQ pin */ - pci_read_config_dword(bdf, PCI_CFG_PIIX4_GENCFG, &val32); - val32 |= PCI_CFG_PIIX4_GENCFG_SERIRQ; - pci_write_config_dword(bdf, PCI_CFG_PIIX4_GENCFG, val32); - - /* enable SERIRQ - Linux currently depends upon this */ - pci_read_config_byte(bdf, PCI_CFG_PIIX4_SERIRQC, &val8); - val8 |= PCI_CFG_PIIX4_SERIRQC_EN | PCI_CFG_PIIX4_SERIRQC_CONT; - pci_write_config_byte(bdf, PCI_CFG_PIIX4_SERIRQC, val8); - - bdf = pci_find_device(PCI_VENDOR_ID_INTEL, - PCI_DEVICE_ID_INTEL_82371AB, 0); - if (bdf == -1) - panic("Failed to find PIIX4 IDE controller\n"); - - /* enable bus master & IO access */ - val32 |= PCI_COMMAND_MASTER | PCI_COMMAND_IO; - pci_write_config_dword(bdf, PCI_COMMAND, val32); - - /* set latency */ - pci_write_config_byte(bdf, PCI_LATENCY_TIMER, 0x40); - - /* enable IDE/ATA */ - pci_write_config_dword(bdf, PCI_CFG_PIIX4_IDETIM_PRI, - PCI_CFG_PIIX4_IDETIM_IDE); - pci_write_config_dword(bdf, PCI_CFG_PIIX4_IDETIM_SEC, - PCI_CFG_PIIX4_IDETIM_IDE); -} -#endif
Am Montag, den 26.07.2021, 07:34 -0600 schrieb Simon Glass:
commit subject should be "mips: malta: ..." and not "ppc: malta: ..." ;)
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
board/socrates/socrates.c | 4 +--- 1 file changed, 1 insertion(+), 3 deletions(-)
diff --git a/board/socrates/socrates.c b/board/socrates/socrates.c index 3444af6a8c7..3ba2fbbd560 100644 --- a/board/socrates/socrates.c +++ b/board/socrates/socrates.c @@ -53,7 +53,7 @@ int checkboard (void) } putc('\n');
-#if defined(CONFIG_PCI) || defined(CONFIG_DM_PCI) +#if defined(CONFIG_PCI) /* Check the PCI_clk sel bit */ if (in_be32(&gur->porpllsr) & (1<<15)) { src = "SYSCLK"; @@ -130,9 +130,7 @@ int misc_init_r (void) &flash_info[CONFIG_SYS_MAX_FLASH_BANKS - 1]); }
-#if defined(CONFIG_DM_PCI) pci_init(); -#endif
return 0; }
drivers/pci/pci_gt64120.c | 64 --------------------------------------- 1 file changed, 64 deletions(-)
diff --git a/drivers/pci/pci_gt64120.c b/drivers/pci/pci_gt64120.c index e57fedf036e..153c65b119a 100644 --- a/drivers/pci/pci_gt64120.c +++ b/drivers/pci/pci_gt64120.c @@ -114,69 +114,6 @@ static int gt_config_access(struct gt64120_pci_controller *gt, return 0; }
-#if !IS_ENABLED(CONFIG_DM_PCI) -static int gt_read_config_dword(struct pci_controller *hose, pci_dev_t dev, - int where, u32 *value) -{ - struct gt64120_pci_controller *gt = hose_to_gt64120(hose); - - *value = 0xffffffff; - return gt_config_access(gt, PCI_ACCESS_READ, dev, where, value); -} - -static int gt_write_config_dword(struct pci_controller *hose, pci_dev_t dev, - int where, u32 value) -{ - struct gt64120_pci_controller *gt = hose_to_gt64120(hose); - u32 data = value; - - return gt_config_access(gt, PCI_ACCESS_WRITE, dev, where, &data); -} - -void gt64120_pci_init(void *regs, unsigned long sys_bus, unsigned long sys_phys, - unsigned long sys_size, unsigned long mem_bus, - unsigned long mem_phys, unsigned long mem_size, - unsigned long io_bus, unsigned long io_phys, - unsigned long io_size) -{ - static struct gt64120_pci_controller global_gt; - struct gt64120_pci_controller *gt; - struct pci_controller *hose; - - gt = &global_gt; - gt->regs = regs; - - hose = >->hose; - - hose->first_busno = 0; - hose->last_busno = 0; - - /* System memory space */ - pci_set_region(&hose->regions[0], sys_bus, sys_phys, sys_size, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - /* PCI memory space */ - pci_set_region(&hose->regions[1], mem_bus, mem_phys, mem_size, - PCI_REGION_MEM); - - /* PCI I/O space */ - pci_set_region(&hose->regions[2], io_bus, io_phys, io_size, - PCI_REGION_IO); - - hose->region_count = 3; - - pci_set_ops(hose, - pci_hose_read_config_byte_via_dword, - pci_hose_read_config_word_via_dword, - gt_read_config_dword, - pci_hose_write_config_byte_via_dword, - pci_hose_write_config_word_via_dword, - gt_write_config_dword); - - pci_register_hose(hose); - hose->last_busno = pci_hose_scan(hose); -} -#else static int gt64120_pci_read_config(const struct udevice *dev, pci_dev_t bdf, uint where, ulong *val, enum pci_size_t size) @@ -246,4 +183,3 @@ U_BOOT_DRIVER(gt64120_pci) = { .probe = gt64120_pci_probe, .priv_auto = sizeof(struct gt64120_pci_controller), }; -#endif
Signed-off-by: Simon Glass sjg@chromium.org
drivers/pci/pci_msc01.c | 64 ----------------------------------------- 1 file changed, 64 deletions(-)
diff --git a/drivers/pci/pci_msc01.c b/drivers/pci/pci_msc01.c index c17da475d01..2f1b688fc32 100644 --- a/drivers/pci/pci_msc01.c +++ b/drivers/pci/pci_msc01.c @@ -62,69 +62,6 @@ static int msc01_config_access(struct msc01_pci_controller *msc01, return 0; }
-#if !IS_ENABLED(CONFIG_DM_PCI) -static int msc01_read_config_dword(struct pci_controller *hose, pci_dev_t dev, - int where, u32 *value) -{ - struct msc01_pci_controller *msc01 = hose_to_msc01(hose); - - *value = 0xffffffff; - return msc01_config_access(msc01, PCI_ACCESS_READ, dev, where, value); -} - -static int msc01_write_config_dword(struct pci_controller *hose, pci_dev_t dev, - int where, u32 value) -{ - struct msc01_pci_controller *gt = hose_to_msc01(hose); - u32 data = value; - - return msc01_config_access(gt, PCI_ACCESS_WRITE, dev, where, &data); -} - -void msc01_pci_init(void *base, unsigned long sys_bus, unsigned long sys_phys, - unsigned long sys_size, unsigned long mem_bus, - unsigned long mem_phys, unsigned long mem_size, - unsigned long io_bus, unsigned long io_phys, - unsigned long io_size) -{ - static struct msc01_pci_controller global_msc01; - struct msc01_pci_controller *msc01; - struct pci_controller *hose; - - msc01 = &global_msc01; - msc01->base = base; - - hose = &msc01->hose; - - hose->first_busno = 0; - hose->last_busno = 0; - - /* System memory space */ - pci_set_region(&hose->regions[0], sys_bus, sys_phys, sys_size, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - /* PCI memory space */ - pci_set_region(&hose->regions[1], mem_bus, mem_phys, mem_size, - PCI_REGION_MEM); - - /* PCI I/O space */ - pci_set_region(&hose->regions[2], io_bus, io_phys, io_size, - PCI_REGION_IO); - - hose->region_count = 3; - - pci_set_ops(hose, - pci_hose_read_config_byte_via_dword, - pci_hose_read_config_word_via_dword, - msc01_read_config_dword, - pci_hose_write_config_byte_via_dword, - pci_hose_write_config_word_via_dword, - msc01_write_config_dword); - - pci_register_hose(hose); - hose->last_busno = pci_hose_scan(hose); -} -#else static int msc01_pci_read_config(const struct udevice *dev, pci_dev_t bdf, uint where, ulong *val, enum pci_size_t size) { @@ -192,4 +129,3 @@ U_BOOT_DRIVER(msc01_pci) = { .probe = msc01_pci_probe, .priv_auto = sizeof(struct msc01_pci_controller), }; -#endif
drivers/pci/pcie_imx.c | 81 ------------------------------------------ 1 file changed, 81 deletions(-)
diff --git a/drivers/pci/pcie_imx.c b/drivers/pci/pcie_imx.c index 7b46fdb89a3..756166fd3ea 100644 --- a/drivers/pci/pcie_imx.c +++ b/drivers/pci/pcie_imx.c @@ -681,86 +681,6 @@ static int imx_pcie_link_up(struct imx_pcie_priv *priv) return 0; }
-#if !CONFIG_IS_ENABLED(DM_PCI) -static struct imx_pcie_priv imx_pcie_priv = { - .dbi_base = (void __iomem *)MX6_DBI_ADDR, - .cfg_base = (void __iomem *)MX6_ROOT_ADDR, -}; - -static struct imx_pcie_priv *priv = &imx_pcie_priv; - -static int imx_pcie_read_config(struct pci_controller *hose, pci_dev_t d, - int where, u32 *val) -{ - struct imx_pcie_priv *priv = hose->priv_data; - - return imx_pcie_read_cfg(priv, d, where, val); -} - -static int imx_pcie_write_config(struct pci_controller *hose, pci_dev_t d, - int where, u32 val) -{ - struct imx_pcie_priv *priv = hose->priv_data; - - return imx_pcie_write_cfg(priv, d, where, val); -} - -void imx_pcie_init(void) -{ - /* Static instance of the controller. */ - static struct pci_controller pcc; - struct pci_controller *hose = &pcc; - int ret; - - memset(&pcc, 0, sizeof(pcc)); - - hose->priv_data = priv; - - /* PCI I/O space */ - pci_set_region(&hose->regions[0], - MX6_IO_ADDR, MX6_IO_ADDR, - MX6_IO_SIZE, PCI_REGION_IO); - - /* PCI memory space */ - pci_set_region(&hose->regions[1], - MX6_MEM_ADDR, MX6_MEM_ADDR, - MX6_MEM_SIZE, PCI_REGION_MEM); - - /* System memory space */ - pci_set_region(&hose->regions[2], - MMDC0_ARB_BASE_ADDR, MMDC0_ARB_BASE_ADDR, - 0xefffffff, PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - - hose->region_count = 3; - - pci_set_ops(hose, - pci_hose_read_config_byte_via_dword, - pci_hose_read_config_word_via_dword, - imx_pcie_read_config, - pci_hose_write_config_byte_via_dword, - pci_hose_write_config_word_via_dword, - imx_pcie_write_config); - - /* Start the controller. */ - ret = imx_pcie_link_up(priv); - - if (!ret) { - pci_register_hose(hose); - hose->last_busno = pci_hose_scan(hose); - } -} - -void imx_pcie_remove(void) -{ - imx6_pcie_assert_core_reset(priv, true); -} - -/* Probe function. */ -void pci_init_board(void) -{ - imx_pcie_init(); -} -#else static int imx_pcie_dm_read_config(const struct udevice *dev, pci_dev_t bdf, uint offset, ulong *value, enum pci_size_t size) @@ -852,4 +772,3 @@ U_BOOT_DRIVER(imx_pcie) = { .priv_auto = sizeof(struct imx_pcie_priv), .flags = DM_FLAG_OS_PREPARE, }; -#endif
We don't need this check anymore since when PCI is enabled, driver model is always used.
Drop it.
drivers/scsi/scsi.c | 6 ------ 1 file changed, 6 deletions(-)
diff --git a/drivers/scsi/scsi.c b/drivers/scsi/scsi.c index ce69750c7ff..d93d2419285 100644 --- a/drivers/scsi/scsi.c +++ b/drivers/scsi/scsi.c @@ -284,7 +284,6 @@ void scsi_init(void) */ for (i = 0; i < ARRAY_SIZE(scsi_device_list); i++) { /* get PCI Device ID */ -#ifdef CONFIG_DM_PCI struct udevice *dev; int ret;
@@ -294,11 +293,6 @@ void scsi_init(void) busdevfunc = dm_pci_get_bdf(dev); break; } -#else - busdevfunc = pci_find_device(scsi_device_list[i].vendor, - scsi_device_list[i].device, - 0); -#endif if (busdevfunc != -1) break; }
Drop them.
drivers/bios_emulator/atibios.c | 98 --------------------------------- drivers/bios_emulator/bios.c | 39 ------------- include/bios_emul.h | 16 ------ 3 files changed, 153 deletions(-)
diff --git a/drivers/bios_emulator/atibios.c b/drivers/bios_emulator/atibios.c index 6c7cc24cbd9..9547470a2f7 100644 --- a/drivers/bios_emulator/atibios.c +++ b/drivers/bios_emulator/atibios.c @@ -230,19 +230,12 @@ This function executes the BIOS POST code on the controller. We assume that at this stage the controller has its I/O and memory space enabled and that all other controllers are in a disabled state. ****************************************************************************/ -#ifdef CONFIG_DM_PCI static void PCI_doBIOSPOST(struct udevice *pcidev, BE_VGAInfo *vga_info, int vesa_mode, struct vbe_mode_info *mode_info) -#else -static void PCI_doBIOSPOST(pci_dev_t pcidev, BE_VGAInfo *vga_info, - int vesa_mode, struct vbe_mode_info *mode_info) -#endif { RMREGS regs; RMSREGS sregs; -#ifdef CONFIG_DM_PCI pci_dev_t bdf; -#endif
/* Determine the value to store in AX for BIOS POST. Per the PCI specs, AH must contain the bus and AL must contain the devfn, encoded as @@ -250,14 +243,9 @@ static void PCI_doBIOSPOST(pci_dev_t pcidev, BE_VGAInfo *vga_info, */ memset(®s, 0, sizeof(regs)); memset(&sregs, 0, sizeof(sregs)); -#ifdef CONFIG_DM_PCI bdf = dm_pci_get_bdf(pcidev); regs.x.ax = (int)PCI_BUS(bdf) << 8 | (int)PCI_DEV(bdf) << 3 | (int)PCI_FUNC(bdf); -#else - regs.x.ax = ((int)PCI_BUS(pcidev) << 8) | - ((int)PCI_DEV(pcidev) << 3) | (int)PCI_FUNC(pcidev); -#endif /*Setup the X86 emulator for the VGA BIOS*/ BE_setVGA(vga_info);
@@ -300,28 +288,15 @@ NOTE: This function leaves the original memory aperture disabled by leaving it programmed to all 1's. It must be restored to the correct value later. ****************************************************************************/ -#ifdef CONFIG_DM_PCI static u32 PCI_findBIOSAddr(struct udevice *pcidev, int *bar) -#else -static u32 PCI_findBIOSAddr(pci_dev_t pcidev, int *bar) -#endif { u32 base, size;
for (*bar = 0x10; *bar <= 0x14; (*bar) += 4) { -#ifdef CONFIG_DM_PCI dm_pci_read_config32(pcidev, *bar, &base); -#else - pci_read_config_dword(pcidev, *bar, &base); -#endif if (!(base & 0x1)) { -#ifdef CONFIG_DM_PCI dm_pci_write_config32(pcidev, *bar, 0xFFFFFFFF); dm_pci_read_config32(pcidev, *bar, &size); -#else - pci_write_config_dword(pcidev, *bar, 0xFFFFFFFF); - pci_read_config_dword(pcidev, *bar, &size); -#endif size = ~(size & ~0xFF) + 1; if (size >= MAX_BIOSLEN) return base & ~0xFF; @@ -344,19 +319,11 @@ necessary). Anyway to fix this we change all I/O mapped base registers and chop off the top bits. ****************************************************************************/ -#ifdef CONFIG_DM_PCI static void PCI_fixupIObase(struct udevice *pcidev, int reg, u32 *base) -#else -static void PCI_fixupIObase(pci_dev_t pcidev, int reg, u32 * base) -#endif { if ((*base & 0x1) && (*base > 0xFFFE)) { *base &= 0xFFFF; -#ifdef CONFIG_DM_PCI dm_pci_write_config32(pcidev, reg, *base); -#else - pci_write_config_dword(pcidev, reg, *base); -#endif
} } @@ -371,30 +338,18 @@ Pointers to the mapped BIOS image REMARKS: Maps a pointer to the BIOS image on the graphics card on the PCI bus. ****************************************************************************/ -#ifdef CONFIG_DM_PCI void *PCI_mapBIOSImage(struct udevice *pcidev) -#else -void *PCI_mapBIOSImage(pci_dev_t pcidev) -#endif { u32 BIOSImageBus; int BIOSImageBAR; u8 *BIOSImage;
/*Save PCI BAR registers that might get changed*/ -#ifdef CONFIG_DM_PCI dm_pci_read_config32(pcidev, PCI_ROM_ADDRESS, &saveROMBaseAddress); dm_pci_read_config32(pcidev, PCI_BASE_ADDRESS_0, &saveBaseAddress10); dm_pci_read_config32(pcidev, PCI_BASE_ADDRESS_1, &saveBaseAddress14); dm_pci_read_config32(pcidev, PCI_BASE_ADDRESS_2, &saveBaseAddress18); dm_pci_read_config32(pcidev, PCI_BASE_ADDRESS_4, &saveBaseAddress20); -#else - pci_read_config_dword(pcidev, PCI_ROM_ADDRESS, &saveROMBaseAddress); - pci_read_config_dword(pcidev, PCI_BASE_ADDRESS_0, &saveBaseAddress10); - pci_read_config_dword(pcidev, PCI_BASE_ADDRESS_1, &saveBaseAddress14); - pci_read_config_dword(pcidev, PCI_BASE_ADDRESS_2, &saveBaseAddress18); - pci_read_config_dword(pcidev, PCI_BASE_ADDRESS_4, &saveBaseAddress20); -#endif
/*Fix up I/O base registers to less than 64K */ if(saveBaseAddress14 != 0) @@ -413,21 +368,12 @@ void *PCI_mapBIOSImage(pci_dev_t pcidev) return NULL; }
-#ifdef CONFIG_DM_PCI BIOSImage = dm_pci_bus_to_virt(pcidev, BIOSImageBus, PCI_REGION_MEM, 0, MAP_NOCACHE);
/*Change the PCI BAR registers to map it onto the bus.*/ dm_pci_write_config32(pcidev, BIOSImageBAR, 0); dm_pci_write_config32(pcidev, PCI_ROM_ADDRESS, BIOSImageBus | 0x1); -#else - BIOSImage = pci_bus_to_virt(pcidev, BIOSImageBus, - PCI_REGION_MEM, 0, MAP_NOCACHE); - - /*Change the PCI BAR registers to map it onto the bus.*/ - pci_write_config_dword(pcidev, BIOSImageBAR, 0); - pci_write_config_dword(pcidev, PCI_ROM_ADDRESS, BIOSImageBus | 0x1); -#endif udelay(1);
/*Check that the BIOS image is valid. If not fail, or return the @@ -447,7 +393,6 @@ pcidev - PCI device info for the video card on the bus REMARKS: Unmaps the BIOS image for the device and restores framebuffer mappings ****************************************************************************/ -#ifdef CONFIG_DM_PCI void PCI_unmapBIOSImage(struct udevice *pcidev, void *BIOSImage) { dm_pci_write_config32(pcidev, PCI_ROM_ADDRESS, saveROMBaseAddress); @@ -456,16 +401,6 @@ void PCI_unmapBIOSImage(struct udevice *pcidev, void *BIOSImage) dm_pci_write_config32(pcidev, PCI_BASE_ADDRESS_2, saveBaseAddress18); dm_pci_write_config32(pcidev, PCI_BASE_ADDRESS_4, saveBaseAddress20); } -#else -void PCI_unmapBIOSImage(pci_dev_t pcidev, void *BIOSImage) -{ - pci_write_config_dword(pcidev, PCI_ROM_ADDRESS, saveROMBaseAddress); - pci_write_config_dword(pcidev, PCI_BASE_ADDRESS_0, saveBaseAddress10); - pci_write_config_dword(pcidev, PCI_BASE_ADDRESS_1, saveBaseAddress14); - pci_write_config_dword(pcidev, PCI_BASE_ADDRESS_2, saveBaseAddress18); - pci_write_config_dword(pcidev, PCI_BASE_ADDRESS_4, saveBaseAddress20); -} -#endif
/**************************************************************************** PARAMETERS: @@ -479,22 +414,14 @@ REMARKS: Loads and POST's the display controllers BIOS, directly from the BIOS image we can extract over the PCI bus. ****************************************************************************/ -#ifdef CONFIG_DM_PCI static int PCI_postController(struct udevice *pcidev, uchar *bios_rom, int bios_len, BE_VGAInfo *vga_info, int vesa_mode, struct vbe_mode_info *mode_info) -#else -static int PCI_postController(pci_dev_t pcidev, uchar *bios_rom, int bios_len, - BE_VGAInfo *vga_info, int vesa_mode, - struct vbe_mode_info *mode_info) -#endif { u32 bios_image_len; uchar *mapped_bios; uchar *copy_of_bios; -#ifdef CONFIG_DM_PCI pci_dev_t bdf; -#endif
if (bios_rom) { copy_of_bios = bios_rom; @@ -522,16 +449,10 @@ static int PCI_postController(pci_dev_t pcidev, uchar *bios_rom, int bios_len, }
/*Save information in vga_info structure*/ -#ifdef CONFIG_DM_PCI bdf = dm_pci_get_bdf(pcidev); vga_info->function = PCI_FUNC(bdf); vga_info->device = PCI_DEV(bdf); vga_info->bus = PCI_BUS(bdf); -#else - vga_info->function = PCI_FUNC(pcidev); - vga_info->device = PCI_DEV(pcidev); - vga_info->bus = PCI_BUS(pcidev); -#endif vga_info->pcidev = pcidev; vga_info->BIOSImage = copy_of_bios; vga_info->BIOSImageLen = bios_image_len; @@ -549,22 +470,13 @@ static int PCI_postController(pci_dev_t pcidev, uchar *bios_rom, int bios_len, return true; }
-#ifdef CONFIG_DM_PCI int biosemu_setup(struct udevice *pcidev, BE_VGAInfo **vga_infop) -#else -int biosemu_setup(pci_dev_t pcidev, BE_VGAInfo **vga_infop) -#endif { BE_VGAInfo *VGAInfo; -#ifdef CONFIG_DM_PCI pci_dev_t bdf = dm_pci_get_bdf(pcidev);
printf("videoboot: Booting PCI video card bus %d, function %d, device %d\n", PCI_BUS(bdf), PCI_FUNC(bdf), PCI_DEV(bdf)); -#else - printf("videoboot: Booting PCI video card bus %d, function %d, device %d\n", - PCI_BUS(pcidev), PCI_FUNC(pcidev), PCI_DEV(pcidev)); -#endif /*Initialise the x86 BIOS emulator*/ if ((VGAInfo = malloc(sizeof(*VGAInfo))) == NULL) { printf("videoboot: Out of memory!\n"); @@ -582,15 +494,9 @@ void biosemu_set_interrupt_handler(int intnum, int (*int_func)(void)) X86EMU_setupIntrFunc(intnum, (X86EMU_intrFuncs)int_func); }
-#ifdef CONFIG_DM_PCI int biosemu_run(struct udevice *pcidev, uchar *bios_rom, int bios_len, BE_VGAInfo *vga_info, int clean_up, int vesa_mode, struct vbe_mode_info *mode_info) -#else -int biosemu_run(pci_dev_t pcidev, uchar *bios_rom, int bios_len, - BE_VGAInfo *vga_info, int clean_up, int vesa_mode, - struct vbe_mode_info *mode_info) -#endif { /*Post all the display controller BIOS'es*/ if (!PCI_postController(pcidev, bios_rom, bios_len, vga_info, @@ -623,12 +529,8 @@ REMARKS: Boots the PCI/AGP video card on the bus using the Video ROM BIOS image and the X86 BIOS emulator module. ****************************************************************************/ -#ifdef CONFIG_DM_PCI int BootVideoCardBIOS(struct udevice *pcidev, BE_VGAInfo **pVGAInfo, int clean_up) -#else -int BootVideoCardBIOS(pci_dev_t pcidev, BE_VGAInfo **pVGAInfo, int clean_up) -#endif { BE_VGAInfo *VGAInfo; int ret; diff --git a/drivers/bios_emulator/bios.c b/drivers/bios_emulator/bios.c index 77c7f94bc63..9596a1fdd3e 100644 --- a/drivers/bios_emulator/bios.c +++ b/drivers/bios_emulator/bios.c @@ -185,21 +185,12 @@ static void X86API int1A(int unused) case 0xB103: /* Find PCI class code */ M.x86.R_AH = DEVICE_NOT_FOUND; #ifdef __KERNEL__ -#ifdef CONFIG_DM_PCI dm_pci_read_config8(_BE_env.vgaInfo.pcidev, PCI_CLASS_PROG, &interface); dm_pci_read_config8(_BE_env.vgaInfo.pcidev, PCI_CLASS_DEVICE, &subclass); dm_pci_read_config8(_BE_env.vgaInfo.pcidev, PCI_CLASS_DEVICE + 1, &baseclass); -#else - pci_read_config_byte(_BE_env.vgaInfo.pcidev, PCI_CLASS_PROG, - &interface); - pci_read_config_byte(_BE_env.vgaInfo.pcidev, PCI_CLASS_DEVICE, - &subclass); - pci_read_config_byte(_BE_env.vgaInfo.pcidev, - PCI_CLASS_DEVICE + 1, &baseclass); -#endif if (M.x86.R_CL == interface && M.x86.R_CH == subclass && (u8) (M.x86.R_ECX >> 16) == baseclass) { #else @@ -218,13 +209,8 @@ static void X86API int1A(int unused) if (M.x86.R_BX == pciSlot) { M.x86.R_AH = SUCCESSFUL; #ifdef __KERNEL__ -# ifdef CONFIG_DM_PCI dm_pci_read_config8(_BE_env.vgaInfo.pcidev, M.x86.R_DI, &M.x86.R_CL); -# else - pci_read_config_byte(_BE_env.vgaInfo.pcidev, M.x86.R_DI, - &M.x86.R_CL); -# endif #else M.x86.R_CL = (u8) PCI_accessReg(M.x86.R_DI, 0, PCI_READ_BYTE, @@ -238,13 +224,8 @@ static void X86API int1A(int unused) if (M.x86.R_BX == pciSlot) { M.x86.R_AH = SUCCESSFUL; #ifdef __KERNEL__ -# ifdef CONFIG_DM_PCI dm_pci_read_config16(_BE_env.vgaInfo.pcidev, M.x86.R_DI, &M.x86.R_CX); -# else - pci_read_config_word(_BE_env.vgaInfo.pcidev, M.x86.R_DI, - &M.x86.R_CX); -# endif #else M.x86.R_CX = (u16) PCI_accessReg(M.x86.R_DI, 0, PCI_READ_WORD, @@ -258,13 +239,8 @@ static void X86API int1A(int unused) if (M.x86.R_BX == pciSlot) { M.x86.R_AH = SUCCESSFUL; #ifdef __KERNEL__ -# ifdef CONFIG_DM_PCI dm_pci_read_config32(_BE_env.vgaInfo.pcidev, M.x86.R_DI, &M.x86.R_ECX); -# else - pci_read_config_dword(_BE_env.vgaInfo.pcidev, - M.x86.R_DI, &M.x86.R_ECX); -# endif #else M.x86.R_ECX = (u32) PCI_accessReg(M.x86.R_DI, 0, PCI_READ_DWORD, @@ -278,13 +254,8 @@ static void X86API int1A(int unused) if (M.x86.R_BX == pciSlot) { M.x86.R_AH = SUCCESSFUL; #ifdef __KERNEL__ -# ifdef CONFIG_DM_PCI dm_pci_write_config8(_BE_env.vgaInfo.pcidev, M.x86.R_DI, M.x86.R_CL); -# else - pci_write_config_byte(_BE_env.vgaInfo.pcidev, - M.x86.R_DI, M.x86.R_CL); -# endif #else PCI_accessReg(M.x86.R_DI, M.x86.R_CL, PCI_WRITE_BYTE, _BE_env.vgaInfo.pciInfo); @@ -297,13 +268,8 @@ static void X86API int1A(int unused) if (M.x86.R_BX == pciSlot) { M.x86.R_AH = SUCCESSFUL; #ifdef __KERNEL__ -# ifdef CONFIG_DM_PCI dm_pci_write_config32(_BE_env.vgaInfo.pcidev, M.x86.R_DI, M.x86.R_CX); -# else - pci_write_config_word(_BE_env.vgaInfo.pcidev, - M.x86.R_DI, M.x86.R_CX); -# endif #else PCI_accessReg(M.x86.R_DI, M.x86.R_CX, PCI_WRITE_WORD, _BE_env.vgaInfo.pciInfo); @@ -316,13 +282,8 @@ static void X86API int1A(int unused) if (M.x86.R_BX == pciSlot) { M.x86.R_AH = SUCCESSFUL; #ifdef __KERNEL__ -# ifdef CONFIG_DM_PCI dm_pci_write_config32(_BE_env.vgaInfo.pcidev, M.x86.R_DI, M.x86.R_ECX); -# else - pci_write_config_dword(_BE_env.vgaInfo.pcidev, - M.x86.R_DI, M.x86.R_ECX); -# endif #else PCI_accessReg(M.x86.R_DI, M.x86.R_ECX, PCI_WRITE_DWORD, _BE_env.vgaInfo.pciInfo); diff --git a/include/bios_emul.h b/include/bios_emul.h index 158e0f223d8..72410dc7948 100644 --- a/include/bios_emul.h +++ b/include/bios_emul.h @@ -30,11 +30,7 @@ typedef struct { int bus; u32 VendorID; u32 DeviceID; -#ifdef CONFIG_DM_PCI struct udevice *pcidev; -#else - pci_dev_t pcidev; -#endif void *BIOSImage; u32 BIOSImageLen; u8 LowMem[1536]; @@ -42,12 +38,8 @@ typedef struct {
struct vbe_mode_info;
-#ifdef CONFIG_DM_PCI int BootVideoCardBIOS(struct udevice *pcidev, BE_VGAInfo **pVGAInfo, int clean_up); -#else -int BootVideoCardBIOS(pci_dev_t pcidev, BE_VGAInfo **pVGAInfo, int clean_up); -#endif
/* Run a BIOS ROM natively (only supported on x86 machines) */ void bios_run_on_x86(struct udevice *dev, unsigned long addr, int vesa_mode, @@ -65,18 +57,10 @@ void bios_set_interrupt_handler(int intnum, int (*int_handler_func)(void));
void biosemu_set_interrupt_handler(int intnum, int (*int_func)(void));
-#ifdef CONFIG_DM_PCI int biosemu_setup(struct udevice *pcidev, BE_VGAInfo **pVGAInfo);
int biosemu_run(struct udevice *dev, uchar *bios_rom, int bios_len, BE_VGAInfo *vga_info, int clean_up, int vesa_mode, struct vbe_mode_info *mode_info); -#else -int biosemu_setup(pci_dev_t pcidev, BE_VGAInfo **pVGAInfo); - -int biosemu_run(pci_dev_t pcidev, uchar *bios_rom, int bios_len, - BE_VGAInfo *vga_info, int clean_up, int vesa_mode, - struct vbe_mode_info *mode_info); -#endif
#endif
Drop it.
drivers/net/designware.c | 22 ++++++++++------------ 1 file changed, 10 insertions(+), 12 deletions(-)
diff --git a/drivers/net/designware.c b/drivers/net/designware.c index 5d92257e74d..5aaac603a0e 100644 --- a/drivers/net/designware.c +++ b/drivers/net/designware.c @@ -756,16 +756,16 @@ int designware_eth_write_hwaddr(struct udevice *dev)
static int designware_eth_bind(struct udevice *dev) { -#ifdef CONFIG_DM_PCI - static int num_cards; - char name[20]; - - /* Create a unique device name for PCI type devices */ - if (device_is_on_pci_bus(dev)) { - sprintf(name, "eth_designware#%u", num_cards++); - device_set_name(dev, name); + if (IS_ENABLED(CONFIG_PCI)) { + static int num_cards; + char name[20]; + + /* Create a unique device name for PCI type devices */ + if (device_is_on_pci_bus(dev)) { + sprintf(name, "eth_designware#%u", num_cards++); + device_set_name(dev, name); + } } -#endif
return 0; } @@ -831,12 +831,11 @@ int designware_eth_probe(struct udevice *dev) else reset_deassert_bulk(&reset_bulk);
-#ifdef CONFIG_DM_PCI /* * If we are on PCI bus, either directly attached to a PCI root port, * or via a PCI bridge, fill in plat before we probe the hardware. */ - if (device_is_on_pci_bus(dev)) { + if (IS_ENABLED(CONFIG_PCI) && device_is_on_pci_bus(dev)) { dm_pci_read_config32(dev, PCI_BASE_ADDRESS_0, &iobase); iobase &= PCI_BASE_ADDRESS_MEM_MASK; iobase = dm_pci_mem_to_phys(dev, iobase); @@ -844,7 +843,6 @@ int designware_eth_probe(struct udevice *dev) pdata->iobase = iobase; pdata->phy_interface = PHY_INTERFACE_MODE_RMII; } -#endif
debug("%s, iobase=%x, priv=%p\n", __func__, iobase, priv); ioaddr = iobase;
Drop it.
char name[20];
char name[20];
-#endif
-- 2.32.0.432.gabb21c7263-goog
Reviewed-by: Ramon Fried rfried.dev@gmail.com
Drop it.
arch/arm/mach-imx/cpu.c | 4 ---- include/pci.h | 4 ---- 2 files changed, 8 deletions(-)
diff --git a/arch/arm/mach-imx/cpu.c b/arch/arm/mach-imx/cpu.c index 423b7153522..8eb05c8dd67 100644 --- a/arch/arm/mach-imx/cpu.c +++ b/arch/arm/mach-imx/cpu.c @@ -283,10 +283,6 @@ u32 get_ahb_clk(void)
void arch_preboot_os(void) { -#if defined(CONFIG_PCIE_IMX) && !CONFIG_IS_ENABLED(DM_PCI) - imx_pcie_remove(); -#endif - #if defined(CONFIG_IMX_AHCI) struct udevice *dev; int rc; diff --git a/include/pci.h b/include/pci.h index ca086420ff2..2c2930e7a74 100644 --- a/include/pci.h +++ b/include/pci.h @@ -785,10 +785,6 @@ int pci_last_busno(void); extern void pci_mpc85xx_init (struct pci_controller *hose); #endif
-#ifdef CONFIG_PCIE_IMX -extern void imx_pcie_remove(void); -#endif - /** * pci_write_bar32() - Write the address of a BAR including control bits *
Use CONFIG_PCI instead.
arch/arm/mach-mvebu/arm64-common.c | 5 ++--- 1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-mvebu/arm64-common.c b/arch/arm/mach-mvebu/arm64-common.c index fa687d8abbb..06c4994e065 100644 --- a/arch/arm/mach-mvebu/arm64-common.c +++ b/arch/arm/mach-mvebu/arm64-common.c @@ -104,10 +104,9 @@ int arch_early_init_r(void) /* Cause the SATA device to do its early init */ uclass_first_device(UCLASS_AHCI, &dev);
-#ifdef CONFIG_DM_PCI /* Trigger PCIe devices detection */ - pci_init(); -#endif + if (IS_ENABLED(PCI)) + pci_init();
return 0; }
Drop them.
drivers/ata/sata_sil.c | 8 -------- drivers/ata/sata_sil.h | 4 ---- 2 files changed, 12 deletions(-)
diff --git a/drivers/ata/sata_sil.c b/drivers/ata/sata_sil.c index 7e4e97d803e..dda712f42cb 100644 --- a/drivers/ata/sata_sil.c +++ b/drivers/ata/sata_sil.c @@ -27,11 +27,7 @@
#include "sata_sil.h"
-#ifdef CONFIG_DM_PCI #define virt_to_bus(devno, v) dm_pci_virt_to_mem(devno, (void *) (v)) -#else -#define virt_to_bus(devno, v) pci_virt_to_mem(devno, (void *) (v)) -#endif
/* just compatible ahci_ops */ struct sil_ops { @@ -616,11 +612,7 @@ static int sil_init_sata(struct udevice *uc_dev, int dev) #else priv->sil_sata_desc[dev] = sata; priv->port_num = dev; -#ifdef CONFIG_DM_PCI sata->devno = uc_dev->parent; -#else - sata->devno = sata_info.devno; -#endif /* CONFIG_DM_PCI */ #endif sata->id = dev; sata->port = port; diff --git a/drivers/ata/sata_sil.h b/drivers/ata/sata_sil.h index a300c0c3887..bea4322c919 100644 --- a/drivers/ata/sata_sil.h +++ b/drivers/ata/sata_sil.h @@ -21,11 +21,7 @@ struct sil_sata { u16 pio; u16 mwdma; u16 udma; -#ifdef CONFIG_DM_PCI struct udevice *devno; -#else - pci_dev_t devno; -#endif int wcache; int flush; int flush_ext;
include/config_distro_bootcmd.h | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/include/config_distro_bootcmd.h b/include/config_distro_bootcmd.h index e70423f25dd..9b9dd308e68 100644 --- a/include/config_distro_bootcmd.h +++ b/include/config_distro_bootcmd.h @@ -265,14 +265,9 @@ BOOT_TARGET_DEVICES_references_IDE_without_CONFIG_IDE #endif
-#if defined(CONFIG_DM_PCI) #define BOOTENV_RUN_PCI_ENUM "run boot_pci_enum; " #define BOOTENV_SHARED_PCI \ "boot_pci_enum=pci enum\0" -#else -#define BOOTENV_RUN_PCI_ENUM -#define BOOTENV_SHARED_PCI -#endif
#ifdef CONFIG_CMD_USB #define BOOTENV_RUN_NET_USB_START "run boot_net_usb_start; "
With the conversion to driver model, this is not needed now. Drop it.
board/cavium/thunderx/thunderx.c | 7 -- board/freescale/mpc8349emds/pci.c | 73 ------------------ board/freescale/mpc837xerdb/Makefile | 1 - board/freescale/mpc837xerdb/pci.c | 109 --------------------------- board/xes/common/fsl_8xxx_pci.c | 50 ------------ include/init.h | 3 - 6 files changed, 243 deletions(-) delete mode 100644 board/freescale/mpc837xerdb/pci.c
diff --git a/board/cavium/thunderx/thunderx.c b/board/cavium/thunderx/thunderx.c index a7dc5c6aeb6..a8f8c785584 100644 --- a/board/cavium/thunderx/thunderx.c +++ b/board/cavium/thunderx/thunderx.c @@ -123,10 +123,3 @@ int board_eth_init(struct bd_info *bis)
return rc; } - -#ifdef CONFIG_PCI -void pci_init_board(void) -{ - printf("DEBUG: PCI Init TODO *****\n"); -} -#endif diff --git a/board/freescale/mpc8349emds/pci.c b/board/freescale/mpc8349emds/pci.c index 3ddbe717756..8c76c46d420 100644 --- a/board/freescale/mpc8349emds/pci.c +++ b/board/freescale/mpc8349emds/pci.c @@ -115,77 +115,4 @@ void pib_init(void) i2c_set_bus_num(orig_i2c_bus); }
-void pci_init_board(void) -{ - volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; - volatile clk83xx_t *clk = (volatile clk83xx_t *)&immr->clk; - volatile law83xx_t *pci_law = immr->sysconf.pcilaw; -#ifndef CONFIG_MPC83XX_PCI2 - struct pci_region *reg[] = { pci1_regions }; -#else - struct pci_region *reg[] = { pci1_regions, pci2_regions }; -#endif - - /* initialize the PCA9555PW IO expander on the PIB board */ - pib_init(); - - /* Enable all 8 PCI_CLK_OUTPUTS */ - clk->occr = 0xff000000; - udelay(2000); - - /* Configure PCI Local Access Windows */ - pci_law[0].bar = CONFIG_SYS_PCI1_MEM_PHYS & LAWBAR_BAR; - pci_law[0].ar = LAWAR_EN | LAWAR_SIZE_1G; - - pci_law[1].bar = CONFIG_SYS_PCI1_IO_PHYS & LAWBAR_BAR; - pci_law[1].ar = LAWAR_EN | LAWAR_SIZE_4M; - - udelay(2000); - -#ifndef CONFIG_MPC83XX_PCI2 - mpc83xx_pci_init(1, reg); -#else - mpc83xx_pci_init(2, reg); -#endif -} - -#else -void pci_init_board(void) -{ - volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; - volatile law83xx_t *pci_law = immr->sysconf.pcilaw; - volatile pcictrl83xx_t *pci_ctrl = &immr->pci_ctrl[0]; - struct pci_region *reg[] = { pci1_regions }; - - /* Configure PCI Local Access Windows */ - pci_law[0].bar = CONFIG_SYS_PCI1_MEM_PHYS & LAWBAR_BAR; - pci_law[0].ar = LAWAR_EN | LAWAR_SIZE_1G; - - pci_law[1].bar = CONFIG_SYS_PCI1_IO_PHYS & LAWBAR_BAR; - pci_law[1].ar = LAWAR_EN | LAWAR_SIZE_4M; - - mpc83xx_pci_init(1, reg); - - /* Configure PCI Inbound Translation Windows (3 1MB windows) */ - pci_ctrl->pitar0 = 0x0; - pci_ctrl->pibar0 = 0x0; - pci_ctrl->piwar0 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | - PIWAR_WTT_SNOOP | PIWAR_IWS_1M; - - pci_ctrl->pitar1 = 0x0; - pci_ctrl->pibar1 = 0x0; - pci_ctrl->piebar1 = 0x0; - pci_ctrl->piwar1 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | - PIWAR_WTT_SNOOP | PIWAR_IWS_1M; - - pci_ctrl->pitar2 = 0x0; - pci_ctrl->pibar2 = 0x0; - pci_ctrl->piebar2 = 0x0; - pci_ctrl->piwar2 = PIWAR_EN | PIWAR_PF | PIWAR_RTT_SNOOP | - PIWAR_WTT_SNOOP | PIWAR_IWS_1M; - - /* Unlock the configuration bit */ - mpc83xx_pcislave_unlock(0); - printf("PCI: Agent mode enabled\n"); -} #endif /* CONFIG_PCISLAVE */ diff --git a/board/freescale/mpc837xerdb/Makefile b/board/freescale/mpc837xerdb/Makefile index c683b017b55..4661e4cf232 100644 --- a/board/freescale/mpc837xerdb/Makefile +++ b/board/freescale/mpc837xerdb/Makefile @@ -4,4 +4,3 @@ # Wolfgang Denk, DENX Software Engineering, wd@denx.de.
obj-y += mpc837xerdb.o -obj-$(CONFIG_PCI) += pci.o diff --git a/board/freescale/mpc837xerdb/pci.c b/board/freescale/mpc837xerdb/pci.c deleted file mode 100644 index dccf8c5551b..00000000000 --- a/board/freescale/mpc837xerdb/pci.c +++ /dev/null @@ -1,109 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright (C) 2006-2009 Freescale Semiconductor, Inc. - */ - -#include <common.h> -#include <init.h> -#include <mpc83xx.h> -#include <pci.h> -#include <asm/io.h> -#include <linux/delay.h> - -static struct pci_region pci_regions[] = { - { - bus_start: CONFIG_SYS_PCI_MEM_BASE, - phys_start: CONFIG_SYS_PCI_MEM_PHYS, - size: CONFIG_SYS_PCI_MEM_SIZE, - flags: PCI_REGION_MEM | PCI_REGION_PREFETCH - }, - { - bus_start: CONFIG_SYS_PCI_MMIO_BASE, - phys_start: CONFIG_SYS_PCI_MMIO_PHYS, - size: CONFIG_SYS_PCI_MMIO_SIZE, - flags: PCI_REGION_MEM - }, - { - bus_start: CONFIG_SYS_PCI_IO_BASE, - phys_start: CONFIG_SYS_PCI_IO_PHYS, - size: CONFIG_SYS_PCI_IO_SIZE, - flags: PCI_REGION_IO - } -}; - -static struct pci_region pcie_regions_0[] = { - { - .bus_start = CONFIG_SYS_PCIE1_MEM_BASE, - .phys_start = CONFIG_SYS_PCIE1_MEM_PHYS, - .size = CONFIG_SYS_PCIE1_MEM_SIZE, - .flags = PCI_REGION_MEM, - }, - { - .bus_start = CONFIG_SYS_PCIE1_IO_BASE, - .phys_start = CONFIG_SYS_PCIE1_IO_PHYS, - .size = CONFIG_SYS_PCIE1_IO_SIZE, - .flags = PCI_REGION_IO, - }, -}; - -static struct pci_region pcie_regions_1[] = { - { - .bus_start = CONFIG_SYS_PCIE2_MEM_BASE, - .phys_start = CONFIG_SYS_PCIE2_MEM_PHYS, - .size = CONFIG_SYS_PCIE2_MEM_SIZE, - .flags = PCI_REGION_MEM, - }, - { - .bus_start = CONFIG_SYS_PCIE2_IO_BASE, - .phys_start = CONFIG_SYS_PCIE2_IO_PHYS, - .size = CONFIG_SYS_PCIE2_IO_SIZE, - .flags = PCI_REGION_IO, - }, -}; - -void pci_init_board(void) -{ - volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; - volatile sysconf83xx_t *sysconf = &immr->sysconf; - volatile clk83xx_t *clk = (volatile clk83xx_t *)&immr->clk; - volatile law83xx_t *pci_law = immr->sysconf.pcilaw; - volatile law83xx_t *pcie_law = sysconf->pcielaw; - struct pci_region *reg[] = { pci_regions }; - struct pci_region *pcie_reg[] = { pcie_regions_0, pcie_regions_1, }; - u32 spridr = in_be32(&immr->sysconf.spridr); - - /* Enable all 5 PCI_CLK_OUTPUTS */ - clk->occr |= 0xf8000000; - udelay(2000); - - /* Configure PCI Local Access Windows */ - pci_law[0].bar = CONFIG_SYS_PCI_MEM_PHYS & LAWBAR_BAR; - pci_law[0].ar = LBLAWAR_EN | LBLAWAR_512MB; - - pci_law[1].bar = CONFIG_SYS_PCI_IO_PHYS & LAWBAR_BAR; - pci_law[1].ar = LBLAWAR_EN | LBLAWAR_1MB; - - mpc83xx_pci_init(1, reg); - - /* There is no PEX in MPC8379 parts. */ - if (PARTID_NO_E(spridr) == SPR_8379) - return; - - /* Configure the clock for PCIE controller */ - clrsetbits_be32(&clk->sccr, SCCR_PCIEXP1CM | SCCR_PCIEXP2CM, - SCCR_PCIEXP1CM_1 | SCCR_PCIEXP2CM_1); - - /* Deassert the resets in the control register */ - out_be32(&sysconf->pecr1, 0xE0008000); - out_be32(&sysconf->pecr2, 0xE0008000); - udelay(2000); - - /* Configure PCI Express Local Access Windows */ - out_be32(&pcie_law[0].bar, CONFIG_SYS_PCIE1_BASE & LAWBAR_BAR); - out_be32(&pcie_law[0].ar, LBLAWAR_EN | LBLAWAR_512MB); - - out_be32(&pcie_law[1].bar, CONFIG_SYS_PCIE2_BASE & LAWBAR_BAR); - out_be32(&pcie_law[1].ar, LBLAWAR_EN | LBLAWAR_512MB); - - mpc83xx_pcie_init(2, pcie_reg); -} diff --git a/board/xes/common/fsl_8xxx_pci.c b/board/xes/common/fsl_8xxx_pci.c index 157aa32826a..c1fce7d3313 100644 --- a/board/xes/common/fsl_8xxx_pci.c +++ b/board/xes/common/fsl_8xxx_pci.c @@ -14,56 +14,6 @@ #include <linux/libfdt.h> #include <fdt_support.h>
- -#ifdef CONFIG_PCI1 -static struct pci_controller pci1_hose; -#endif - -void pci_init_board(void) -{ - int first_free_busno = 0; - -#ifdef CONFIG_PCI1 - int pcie_ep; - struct fsl_pci_info pci_info; - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 devdisr = in_be32(&gur->devdisr); - uint pci_spd_norm = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_SPD; - uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; - uint pci_arb = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_ARB; - uint pcix = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1; - uint freq = CONFIG_SYS_CLK_FREQ / 1000 / 1000; - - if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { - SET_STD_PCI_INFO(pci_info, 1); - set_next_law(pci_info.mem_phys, - law_size_bits(pci_info.mem_size), pci_info.law); - set_next_law(pci_info.io_phys, - law_size_bits(pci_info.io_size), pci_info.law); - - pcie_ep = fsl_setup_hose(&pci1_hose, pci_info.regs); - printf("PCI1: %d bit %s, %s %d MHz, %s, %s\n", - pci_32 ? 32 : 64, - pcix ? "PCIX" : "PCI", - pci_spd_norm ? ">=" : "<=", - pcix ? freq * 2 : freq, - pcie_ep ? "agent" : "host", - pci_arb ? "arbiter" : "external-arbiter"); - - first_free_busno = fsl_pci_init_port(&pci_info, - &pci1_hose, first_free_busno); - } else { - printf("PCI1: disabled\n"); - } -#elif defined CONFIG_ARCH_MPC8548 - volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - /* PCI1 not present on MPC8572 */ - setbits_be32(&gur->devdisr, MPC85xx_DEVDISR_PCI1); -#endif - - fsl_pcie_init_board(first_free_busno); -} - #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_pci_setup(void *blob, struct bd_info *bd) { diff --git a/include/init.h b/include/init.h index fd51d7f9667..c781789e367 100644 --- a/include/init.h +++ b/include/init.h @@ -297,9 +297,6 @@ int board_late_init(void); int board_postclk_init(void); /* after clocks/timebase, before env/serial */ int board_early_init_r(void);
-/* TODO(sjg@chromium.org): Drop this when DM_PCI migration is completed */ -void pci_init_board(void); - /** * arch_initr_trap() - Init traps *
This is not used in U-Boot at present. Drop it and related config options.
arch/nds32/include/asm/arch-ag102/ag102.h | 2 - drivers/pci/Makefile | 1 - drivers/pci/pci_ftpci100.c | 319 ---------------------- scripts/config_whitelist.txt | 4 - 4 files changed, 326 deletions(-) delete mode 100644 drivers/pci/pci_ftpci100.c
diff --git a/arch/nds32/include/asm/arch-ag102/ag102.h b/arch/nds32/include/asm/arch-ag102/ag102.h index d1f4b02e10e..3255db6592e 100644 --- a/arch/nds32/include/asm/arch-ag102/ag102.h +++ b/arch/nds32/include/asm/arch-ag102/ag102.h @@ -11,8 +11,6 @@ * Hardware register bases */
-/* PCI Controller */ -#define CONFIG_FTPCI100_BASE 0x90000000 /* LPC Controller */ #define CONFIG_LPC_IO_BASE 0x90100000 /* LPC Controller */ diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index 83d7a4e403c..bdfdec98a08 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -19,7 +19,6 @@ obj-$(CONFIG_PCI_GT64120) += pci_gt64120.o obj-$(CONFIG_PCI_MPC85XX) += pci_mpc85xx.o obj-$(CONFIG_PCI_MSC01) += pci_msc01.o obj-$(CONFIG_PCIE_IMX) += pcie_imx.o -obj-$(CONFIG_FTPCI100) += pci_ftpci100.o obj-$(CONFIG_PCI_MVEBU) += pci_mvebu.o obj-$(CONFIG_PCI_RCAR_GEN2) += pci-rcar-gen2.o obj-$(CONFIG_PCI_RCAR_GEN3) += pci-rcar-gen3.o diff --git a/drivers/pci/pci_ftpci100.c b/drivers/pci/pci_ftpci100.c deleted file mode 100644 index 32fac878a67..00000000000 --- a/drivers/pci/pci_ftpci100.c +++ /dev/null @@ -1,319 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Faraday FTPCI100 PCI Bridge Controller Device Driver Implementation - * - * Copyright (C) 2011 Andes Technology Corporation - * Gavin Guo, Andes Technology Corporation gavinguo@andestech.com - * Macpaul Lin, Andes Technology Corporation macpaul@andestech.com - */ -#include <common.h> -#include <init.h> -#include <log.h> -#include <malloc.h> -#include <pci.h> - -#include <faraday/ftpci100.h> - -#include <asm/io.h> -#include <asm/types.h> /* u32, u16.... used by pci.h */ - -struct ftpci100_data { - unsigned int reg_base; - unsigned int io_base; - unsigned int mem_base; - unsigned int mmio_base; - unsigned int ndevs; -}; - -static struct pci_config devs[FTPCI100_MAX_FUNCTIONS]; -static struct pci_controller local_hose; - -static void setup_pci_bar(unsigned int bus, unsigned int dev, unsigned func, - unsigned char header, struct ftpci100_data *priv) -{ - struct pci_controller *hose = (struct pci_controller *)&local_hose; - unsigned int i, tmp32, bar_no, iovsmem = 1; - pci_dev_t dev_nu; - - /* A device is present, add an entry to the array */ - devs[priv->ndevs].bus = bus; - devs[priv->ndevs].dev = dev; - devs[priv->ndevs].func = func; - - dev_nu = PCI_BDF(bus, dev, func); - - if ((header & 0x7f) == 0x01) - /* PCI-PCI Bridge */ - bar_no = 2; - else - bar_no = 6; - - /* Allocate address spaces by configuring BARs */ - for (i = 0; i < bar_no; i++) { - pci_hose_write_config_dword(hose, dev_nu, - PCI_BASE_ADDRESS_0 + i * 4, 0xffffffff); - pci_hose_read_config_dword(hose, dev_nu, - PCI_BASE_ADDRESS_0 + i * 4, &tmp32); - - if (tmp32 == 0x0) - continue; - - /* IO space */ - if (tmp32 & 0x1) { - iovsmem = 0; - unsigned int size_mask = ~(tmp32 & 0xfffffffc); - - if (priv->io_base & size_mask) - priv->io_base = (priv->io_base & ~size_mask) + \ - size_mask + 1; - - devs[priv->ndevs].bar[i].addr = priv->io_base; - devs[priv->ndevs].bar[i].size = size_mask + 1; - - pci_hose_write_config_dword(hose, dev_nu, - PCI_BASE_ADDRESS_0 + i * 4, - priv->io_base); - - debug("Allocated IO address 0x%X-" \ - "0x%X for Bus %d, Device %d, Function %d\n", - priv->io_base, - priv->io_base + size_mask, bus, dev, func); - - priv->io_base += size_mask + 1; - } else { - /* Memory space */ - unsigned int is_64bit = ((tmp32 & 0x6) == 0x4); - unsigned int is_pref = tmp32 & 0x8; - unsigned int size_mask = ~(tmp32 & 0xfffffff0); - unsigned int alloc_base; - unsigned int *addr_mem_base; - - if (is_pref) - addr_mem_base = &priv->mem_base; - else - addr_mem_base = &priv->mmio_base; - - alloc_base = *addr_mem_base; - - if (alloc_base & size_mask) - alloc_base = (alloc_base & ~size_mask) \ - + size_mask + 1; - - pci_hose_write_config_dword(hose, dev_nu, - PCI_BASE_ADDRESS_0 + i * 4, alloc_base); - - debug("Allocated %s address 0x%X-" \ - "0x%X for Bus %d, Device %d, Function %d\n", - is_pref ? "MEM" : "MMIO", alloc_base, - alloc_base + size_mask, bus, dev, func); - - devs[priv->ndevs].bar[i].addr = alloc_base; - devs[priv->ndevs].bar[i].size = size_mask + 1; - - debug("BAR address BAR size\n"); - debug("%010x %08d\n", - devs[priv->ndevs].bar[0].addr, - devs[priv->ndevs].bar[0].size); - - alloc_base += size_mask + 1; - *addr_mem_base = alloc_base; - - if (is_64bit) { - i++; - pci_hose_write_config_dword(hose, dev_nu, - PCI_BASE_ADDRESS_0 + i * 4, 0x0); - } - } - } - - /* Enable Bus Master, Memory Space, and IO Space */ - pci_hose_read_config_dword(hose, dev_nu, PCI_CACHE_LINE_SIZE, &tmp32); - pci_hose_write_config_dword(hose, dev_nu, PCI_CACHE_LINE_SIZE, 0x08); - pci_hose_read_config_dword(hose, dev_nu, PCI_CACHE_LINE_SIZE, &tmp32); - - pci_hose_read_config_dword(hose, dev_nu, PCI_COMMAND, &tmp32); - - tmp32 &= 0xffff; - - if (iovsmem == 0) - tmp32 |= 0x5; - else - tmp32 |= 0x6; - - pci_hose_write_config_dword(hose, dev_nu, PCI_COMMAND, tmp32); -} - -static void pci_bus_scan(struct ftpci100_data *priv) -{ - struct pci_controller *hose = (struct pci_controller *)&local_hose; - unsigned int bus, dev, func; - pci_dev_t dev_nu; - unsigned int data32; - unsigned int tmp; - unsigned char header; - unsigned char int_pin; - unsigned int niobars; - unsigned int nmbars; - - priv->ndevs = 1; - - nmbars = 0; - niobars = 0; - - for (bus = 0; bus < MAX_BUS_NUM; bus++) - for (dev = 0; dev < MAX_DEV_NUM; dev++) - for (func = 0; func < MAX_FUN_NUM; func++) { - dev_nu = PCI_BDF(bus, dev, func); - pci_hose_read_config_dword(hose, dev_nu, - PCI_VENDOR_ID, &data32); - - /* - * some broken boards return 0 or ~0, - * if a slot is empty. - */ - if (data32 == 0xffffffff || - data32 == 0x00000000 || - data32 == 0x0000ffff || - data32 == 0xffff0000) - continue; - - pci_hose_read_config_dword(hose, dev_nu, - PCI_HEADER_TYPE, &tmp); - header = (unsigned char)tmp; - setup_pci_bar(bus, dev, func, header, priv); - - devs[priv->ndevs].v_id = (u16)(data32 & \ - 0x0000ffff); - - devs[priv->ndevs].d_id = (u16)((data32 & \ - 0xffff0000) >> 16); - - /* Figure out what INTX# line the card uses */ - pci_hose_read_config_byte(hose, dev_nu, - PCI_INTERRUPT_PIN, &int_pin); - - /* assign the appropriate irq line */ - if (int_pin > PCI_IRQ_LINES) { - printf("more irq lines than expect\n"); - } else if (int_pin != 0) { - /* This device uses an interrupt line */ - devs[priv->ndevs].pin = int_pin; - } - - pci_hose_read_config_dword(hose, dev_nu, - PCI_CLASS_DEVICE, &data32); - - debug("%06d %03d %03d " \ - "%04d %08x %08x " \ - "%03d %08x %06d %08x\n", - priv->ndevs, devs[priv->ndevs].bus, - devs[priv->ndevs].dev, - devs[priv->ndevs].func, - devs[priv->ndevs].d_id, - devs[priv->ndevs].v_id, - devs[priv->ndevs].pin, - devs[priv->ndevs].bar[0].addr, - devs[priv->ndevs].bar[0].size, - data32 >> 8); - - priv->ndevs++; - } -} - -static void ftpci_preinit(struct ftpci100_data *priv) -{ - struct ftpci100_ahbc *ftpci100; - struct pci_controller *hose = (struct pci_controller *)&local_hose; - u32 pci_config_addr; - u32 pci_config_data; - - priv->reg_base = CONFIG_FTPCI100_BASE; - priv->io_base = CONFIG_FTPCI100_BASE + CONFIG_FTPCI100_IO_SIZE; - priv->mmio_base = CONFIG_FTPCI100_MEM_BASE; - priv->mem_base = CONFIG_FTPCI100_MEM_BASE + CONFIG_FTPCI100_MEM_SIZE; - - ftpci100 = (struct ftpci100_ahbc *)priv->reg_base; - - pci_config_addr = (u32) &ftpci100->conf; - pci_config_data = (u32) &ftpci100->data; - - /* print device name */ - printf("FTPCI100\n"); - - /* dump basic configuration */ - debug("%s: Config addr is %08X, data port is %08X\n", - __func__, pci_config_addr, pci_config_data); - - /* PCI memory space */ - pci_set_region(hose->regions + 0, - CONFIG_PCI_MEM_BUS, - CONFIG_PCI_MEM_PHYS, - CONFIG_PCI_MEM_SIZE, - PCI_REGION_MEM); - hose->region_count++; - - /* PCI IO space */ - pci_set_region(hose->regions + 1, - CONFIG_PCI_IO_BUS, - CONFIG_PCI_IO_PHYS, - CONFIG_PCI_IO_SIZE, - PCI_REGION_IO); - hose->region_count++; - -#if defined(CONFIG_PCI_SYS_BUS) - /* PCI System Memory space */ - pci_set_region(hose->regions + 2, - CONFIG_PCI_SYS_BUS, - CONFIG_PCI_SYS_PHYS, - CONFIG_PCI_SYS_SIZE, - PCI_REGION_MEM | PCI_REGION_SYS_MEMORY); - hose->region_count++; -#endif - - /* setup indirect read/write function */ - pci_setup_indirect(hose, pci_config_addr, pci_config_data); - - /* register hose */ - pci_register_hose(hose); -} - -void pci_ftpci_init(void) -{ - struct ftpci100_data *priv = NULL; - struct pci_controller *hose = (struct pci_controller *)&local_hose; - pci_dev_t bridge_num; - - struct pci_device_id bridge_ids[] = { - {FTPCI100_BRIDGE_VENDORID, FTPCI100_BRIDGE_DEVICEID}, - {0, 0} - }; - - priv = malloc(sizeof(struct ftpci100_data)); - - if (!priv) { - printf("%s(): failed to malloc priv\n", __func__); - return; - } - - memset(priv, 0, sizeof(struct ftpci100_data)); - - ftpci_preinit(priv); - - debug("Device bus dev func deviceID vendorID pin address" \ - " size class\n"); - - pci_bus_scan(priv); - - /* - * Setup the PCI Bridge Window to 1GB, - * it will cause USB OHCI Host controller Unrecoverable Error - * if it is not set. - */ - bridge_num = pci_find_devices(bridge_ids, 0); - if (bridge_num == -1) { - printf("PCI Bridge not found\n"); - return; - } - pci_hose_write_config_dword(hose, bridge_num, PCI_MEM_BASE_SIZE1, - FTPCI100_BASE_ADR_SIZE(1024)); -} diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index f947ecdb3eb..98a80680f6e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -505,10 +505,6 @@ CONFIG_FTINTC010_BASE CONFIG_FTLCDC100_BASE CONFIG_FTMAC100_BASE CONFIG_FTMAC110_BASE -CONFIG_FTPCI100_BASE -CONFIG_FTPCI100_IO_SIZE -CONFIG_FTPCI100_MEM_BASE -CONFIG_FTPCI100_MEM_SIZE CONFIG_FTPMU010 CONFIG_FTPMU010_BASE CONFIG_FTPMU010_POWER
This is not used. Drop it.
board/freescale/common/Makefile | 1 - .../common/idt8t49n222a_serdes_clk.c | 208 ------------------ .../common/idt8t49n222a_serdes_clk.h | 106 --------- 3 files changed, 315 deletions(-) delete mode 100644 board/freescale/common/idt8t49n222a_serdes_clk.c delete mode 100644 board/freescale/common/idt8t49n222a_serdes_clk.h
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 116c1e71cc1..3a171688c3f 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -63,7 +63,6 @@ obj-$(CONFIG_TARGET_P3041DS) += ics307_clk.o obj-$(CONFIG_TARGET_P4080DS) += ics307_clk.o obj-$(CONFIG_TARGET_P5040DS) += ics307_clk.o obj-$(CONFIG_VSC_CROSSBAR) += vsc3316_3308.o -obj-$(CONFIG_IDT8T49N222A) += idt8t49n222a_serdes_clk.o obj-$(CONFIG_ZM7300) += zm7300.o obj-$(CONFIG_POWER_PFUZE100) += pfuze.o obj-$(CONFIG_DM_PMIC_PFUZE100) += pfuze.o diff --git a/board/freescale/common/idt8t49n222a_serdes_clk.c b/board/freescale/common/idt8t49n222a_serdes_clk.c deleted file mode 100644 index bb3cdac8418..00000000000 --- a/board/freescale/common/idt8t49n222a_serdes_clk.c +++ /dev/null @@ -1,208 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * Author: Shaveta Leekha shaveta@freescale.com - */ - -#include "idt8t49n222a_serdes_clk.h" -#include <log.h> -#include <linux/delay.h> - -#define DEVICE_ID_REG 0x00 - -static int check_pll_status(u8 idt_addr) -{ - u8 val = 0; - int ret; - - ret = i2c_read(idt_addr, 0x17, 1, &val, 1); - if (ret < 0) { - printf("IDT:0x%x could not read status register from device.\n", - idt_addr); - return ret; - } - - if (val & 0x04) { - debug("idt8t49n222a PLL is LOCKED: %x\n", val); - } else { - printf("idt8t49n222a PLL is not LOCKED: %x\n", val); - return -1; - } - - return 0; -} - -int set_serdes_refclk(u8 idt_addr, u8 serdes_num, - enum serdes_refclk refclk1, - enum serdes_refclk refclk2, u8 feedback) -{ - u8 dev_id = 0; - int i, ret; - - debug("IDT:Configuring idt8t49n222a device at I2C address: 0x%2x\n", - idt_addr); - - ret = i2c_read(idt_addr, DEVICE_ID_REG, 1, &dev_id, 1); - if (ret < 0) { - debug("IDT:0x%x could not read DEV_ID from device.\n", - idt_addr); - return ret; - } - - if ((dev_id != 0x00) && (dev_id != 0x24) && (dev_id != 0x2a)) { - debug("IDT: device at address 0x%x is not idt8t49n222a.\n", - idt_addr); - } - - if (serdes_num != 1 && serdes_num != 2) { - debug("serdes_num should be 1 for SerDes1 and" - " 2 for SerDes2.\n"); - return -1; - } - - if ((refclk1 == SERDES_REFCLK_122_88 && refclk2 != SERDES_REFCLK_122_88) - || (refclk1 != SERDES_REFCLK_122_88 - && refclk2 == SERDES_REFCLK_122_88)) { - debug("Only one refclk at 122.88MHz is not supported." - " Please set both refclk1 & refclk2 to 122.88MHz" - " or both not to 122.88MHz.\n"); - return -1; - } - - if (refclk1 != SERDES_REFCLK_100 && refclk1 != SERDES_REFCLK_122_88 - && refclk1 != SERDES_REFCLK_125 - && refclk1 != SERDES_REFCLK_156_25) { - debug("refclk1 should be 100MHZ, 122.88MHz, 125MHz" - " or 156.25MHz.\n"); - return -1; - } - - if (refclk2 != SERDES_REFCLK_100 && refclk2 != SERDES_REFCLK_122_88 - && refclk2 != SERDES_REFCLK_125 - && refclk2 != SERDES_REFCLK_156_25) { - debug("refclk2 should be 100MHZ, 122.88MHz, 125MHz" - " or 156.25MHz.\n"); - return -1; - } - - if (feedback != 0 && feedback != 1) { - debug("valid values for feedback are 0(default) or 1.\n"); - return -1; - } - - /* Configuring IDT for output refclks as - * Refclk1 = 122.88MHz Refclk2 = 122.88MHz - */ - if (refclk1 == SERDES_REFCLK_122_88 && - refclk2 == SERDES_REFCLK_122_88) { - printf("Setting refclk1:122.88 and refclk2:122.88\n"); - for (i = 0; i < NUM_IDT_REGS; i++) - i2c_reg_write(idt_addr, idt_conf_122_88[i][0], - idt_conf_122_88[i][1]); - - if (feedback) { - for (i = 0; i < NUM_IDT_REGS_FEEDBACK; i++) - i2c_reg_write(idt_addr, - idt_conf_122_88_feedback[i][0], - idt_conf_122_88_feedback[i][1]); - } - } - - if (refclk1 != SERDES_REFCLK_122_88 && - refclk2 != SERDES_REFCLK_122_88) { - for (i = 0; i < NUM_IDT_REGS; i++) - i2c_reg_write(idt_addr, idt_conf_not_122_88[i][0], - idt_conf_not_122_88[i][1]); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 100MHz Refclk2 = 125MHz - */ - if (refclk1 == SERDES_REFCLK_100 && refclk2 == SERDES_REFCLK_125) { - printf("Setting refclk1:100 and refclk2:125\n"); - i2c_reg_write(idt_addr, 0x11, 0x10); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 125MHz Refclk2 = 125MHz - */ - if (refclk1 == SERDES_REFCLK_125 && refclk2 == SERDES_REFCLK_125) { - printf("Setting refclk1:125 and refclk2:125\n"); - i2c_reg_write(idt_addr, 0x10, 0x10); - i2c_reg_write(idt_addr, 0x11, 0x10); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 125MHz Refclk2 = 100MHz - */ - if (refclk1 == SERDES_REFCLK_125 && refclk2 == SERDES_REFCLK_100) { - printf("Setting refclk1:125 and refclk2:100\n"); - i2c_reg_write(idt_addr, 0x10, 0x10); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 156.25MHz Refclk2 = 156.25MHz - */ - if (refclk1 == SERDES_REFCLK_156_25 && - refclk2 == SERDES_REFCLK_156_25) { - printf("Setting refclk1:156.25 and refclk2:156.25\n"); - for (i = 0; i < NUM_IDT_REGS_156_25; i++) - i2c_reg_write(idt_addr, idt_conf_156_25[i][0], - idt_conf_156_25[i][1]); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 100MHz Refclk2 = 156.25MHz - */ - if (refclk1 == SERDES_REFCLK_100 && - refclk2 == SERDES_REFCLK_156_25) { - printf("Setting refclk1:100 and refclk2:156.25\n"); - for (i = 0; i < NUM_IDT_REGS_156_25; i++) - i2c_reg_write(idt_addr, idt_conf_100_156_25[i][0], - idt_conf_100_156_25[i][1]); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 125MHz Refclk2 = 156.25MHz - */ - if (refclk1 == SERDES_REFCLK_125 && - refclk2 == SERDES_REFCLK_156_25) { - printf("Setting refclk1:125 and refclk2:156.25\n"); - for (i = 0; i < NUM_IDT_REGS_156_25; i++) - i2c_reg_write(idt_addr, idt_conf_125_156_25[i][0], - idt_conf_125_156_25[i][1]); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 156.25MHz Refclk2 = 100MHz - */ - if (refclk1 == SERDES_REFCLK_156_25 && - refclk2 == SERDES_REFCLK_100) { - printf("Setting refclk1:156.25 and refclk2:100\n"); - for (i = 0; i < NUM_IDT_REGS_156_25; i++) - i2c_reg_write(idt_addr, idt_conf_156_25_100[i][0], - idt_conf_156_25_100[i][1]); - } - - /* Configuring IDT for output refclks as - * Refclk1 = 156.25MHz Refclk2 = 125MHz - */ - if (refclk1 == SERDES_REFCLK_156_25 && - refclk2 == SERDES_REFCLK_125) { - printf("Setting refclk1:156.25 and refclk2:125\n"); - for (i = 0; i < NUM_IDT_REGS_156_25; i++) - i2c_reg_write(idt_addr, idt_conf_156_25_125[i][0], - idt_conf_156_25_125[i][1]); - } - - /* waiting for maximum of 1 second if PLL doesn'r get locked - * initially. then check the status again. - */ - if (check_pll_status(idt_addr)) { - mdelay(1000); - if (check_pll_status(idt_addr)) - return -1; - } - - return 0; -} diff --git a/board/freescale/common/idt8t49n222a_serdes_clk.h b/board/freescale/common/idt8t49n222a_serdes_clk.h deleted file mode 100644 index b1528e32669..00000000000 --- a/board/freescale/common/idt8t49n222a_serdes_clk.h +++ /dev/null @@ -1,106 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2013 Freescale Semiconductor, Inc. - * Author: Shaveta Leekha shaveta@freescale.com - */ - -#ifndef __IDT8T49N222A_SERDES_CLK_H_ -#define __IDT8T49N222A_SERDES_CLK_H_ 1 - -#include <common.h> -#include <i2c.h> -#include "qixis.h" -#include "../b4860qds/b4860qds_qixis.h" -#include <errno.h> - -#define NUM_IDT_REGS 23 -#define NUM_IDT_REGS_FEEDBACK 12 -#define NUM_IDT_REGS_156_25 11 - -/* CLK */ -enum serdes_refclk { - SERDES_REFCLK_100, /* refclk 100Mhz */ - SERDES_REFCLK_122_88, /* refclk 122.88Mhz */ - SERDES_REFCLK_125, /* refclk 125Mhz */ - SERDES_REFCLK_156_25, /* refclk 156.25Mhz */ - SERDES_REFCLK_NONE = -1, -}; - -/* configuration values for IDT registers for Output Refclks: - * Refclk1 = 122.88MHz Refclk2 = 122.88MHz - */ -static const u8 idt_conf_122_88[23][2] = { {0x00, 0x3C}, {0x01, 0x00}, - {0x02, 0x9F}, {0x03, 0x00}, {0x04, 0x0B}, {0x05, 0x00}, - {0x06, 0x00}, {0x07, 0x00}, {0x08, 0x7D}, {0x09, 0x00}, - {0x0A, 0x08}, {0x0B, 0x00}, {0x0C, 0xDC}, {0x0D, 0x00}, - {0x0E, 0x00}, {0x0F, 0x00}, {0x10, 0x12}, {0x11, 0x12}, - {0x12, 0xB9}, {0x13, 0xBC}, {0x14, 0x40}, {0x15, 0x08}, - {0x16, 0xA0} }; - - -/* configuration values for IDT registers for Output Refclks: - * Refclk1 not equal to 122.88MHz Refclk2 not equal to 122.88MHz - */ -static const u8 idt_conf_not_122_88[23][2] = { {0x00, 0x00}, {0x01, 0x00}, - {0x02, 0x00}, {0x03, 0x00}, {0x04, 0x0A}, {0x05, 0x00}, - {0x06, 0x00}, {0x07, 0x00}, {0x08, 0x7D}, {0x09, 0x00}, - {0x0A, 0x08}, {0x0B, 0x00}, {0x0C, 0xDC}, {0x0D, 0x00}, - {0x0E, 0x00}, {0x0F, 0x00}, {0x10, 0x14}, {0x11, 0x14}, - {0x12, 0x35}, {0x13, 0xBC}, {0x14, 0x40}, {0x15, 0x08}, - {0x16, 0xA0} }; - -/* Reconfiguration values for some of IDT registers for - * Output Refclks: - * Refclk1 = 122.88MHz Refclk2 = 122.88MHz - * and with feedback as 1 - */ -static const u8 idt_conf_122_88_feedback[12][2] = { {0x00, 0x50}, {0x02, 0xD7}, - {0x04, 0x89}, {0x06, 0xC3}, {0x08, 0xC0}, {0x0A, 0x07}, - {0x0C, 0x80}, {0x10, 0x10}, {0x11, 0x10}, {0x12, 0x1B}, - {0x14, 0x00}, {0x15, 0xE8} }; - -/* configuration values for IDT registers for Output Refclks: - * Refclk1 : 156.25MHz Refclk2 : 156.25MHz - */ -static const u8 idt_conf_156_25[11][2] = { {0x04, 0x19}, {0x06, 0x03}, - {0x08, 0xC0}, {0x0A, 0x07}, {0x0C, 0xA1}, {0x0E, 0x20}, - {0x10, 0x10}, {0x11, 0x10}, {0x12, 0xB5}, {0x13, 0x3C}, - {0x15, 0xE8} }; - -/* configuration values for IDT registers for Output Refclks: - * Refclk1 : 100MHz Refclk2 : 156.25MHz - */ -static const u8 idt_conf_100_156_25[11][2] = { {0x04, 0x19}, {0x06, 0x03}, - {0x08, 0xC0}, {0x0A, 0x07}, {0x0C, 0xA1}, {0x0E, 0x20}, - {0x10, 0x19}, {0x11, 0x10}, {0x12, 0xB5}, {0x13, 0x3C}, - {0x15, 0xE8} }; - -/* configuration values for IDT registers for Output Refclks: - * Refclk1 : 125MHz Refclk2 : 156.25MHz - */ -static const u8 idt_conf_125_156_25[11][2] = { {0x04, 0x19}, {0x06, 0x03}, - {0x08, 0xC0}, {0x0A, 0x07}, {0x0C, 0xA1}, {0x0E, 0x20}, - {0x10, 0x14}, {0x11, 0x10}, {0x12, 0xB5}, {0x13, 0x3C}, - {0x15, 0xE8} }; - -/* configuration values for IDT registers for Output Refclks: - * Refclk1 : 156.25MHz Refclk2 : 100MHz - */ -static const u8 idt_conf_156_25_100[11][2] = { {0x04, 0x19}, {0x06, 0x03}, - {0x08, 0xC0}, {0x0A, 0x07}, {0x0C, 0xA1}, {0x0E, 0x20}, - {0x10, 0x10}, {0x11, 0x19}, {0x12, 0xB5}, {0x13, 0x3C}, - {0x15, 0xE8} }; - -/* configuration values for IDT registers for Output Refclks: - * Refclk1 : 156.25MHz Refclk2 : 125MHz - */ -static const u8 idt_conf_156_25_125[11][2] = { {0x04, 0x19}, {0x06, 0x03}, - {0x08, 0xC0}, {0x0A, 0x07}, {0x0C, 0xA1}, {0x0E, 0x20}, - {0x10, 0x10}, {0x11, 0x14}, {0x12, 0xB5}, {0x13, 0x3C}, - {0x15, 0xE8} }; - -int set_serdes_refclk(u8 idt_addr, u8 serdes_num, - enum serdes_refclk refclk1, - enum serdes_refclk refclk2, u8 feedback); - -#endif /*__IDT8T49N222A_SERDES_CLK_H_ */
These boards have been removed. Drop the config file and other references.
.azure-pipelines.yml | 4 +- doc/board/freescale/b4860qds.rst | 453 ------------------------------- doc/board/freescale/index.rst | 1 - include/configs/t4qds.h | 240 ---------------- 4 files changed, 2 insertions(+), 696 deletions(-) delete mode 100644 doc/board/freescale/b4860qds.rst delete mode 100644 include/configs/t4qds.h
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index e3a994e0c44..6c8eb55423f 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -411,11 +411,11 @@ jobs: non_fsl_ppc: BUILDMAN: "powerpc -x freescale" mpc85xx_freescale: - BUILDMAN: "mpc85xx&freescale -x t208xrdb -x t4qds -x t102* -x p1_p2_rdb_pc -x p1010rdb -x corenet_ds -x b4860qds -x bsc91*" + BUILDMAN: "mpc85xx&freescale -x t208xrdb -x t102* -x p1_p2_rdb_pc -x p1010rdb -x corenet_ds -x bsc91*" t208xrdb_corenet_ds: BUILDMAN: "t208xrdb corenet_ds" fsl_ppc: - BUILDMAN: "t4qds b4860qds mpc83xx&freescale" + BUILDMAN: "mpc83xx&freescale" t102x: BUILDMAN: "t102*" p1_p2_rdb_pc: diff --git a/doc/board/freescale/b4860qds.rst b/doc/board/freescale/b4860qds.rst deleted file mode 100644 index de14d857b91..00000000000 --- a/doc/board/freescale/b4860qds.rst +++ /dev/null @@ -1,453 +0,0 @@ -.. SPDX-License-Identifier: GPL-2.0+ - -B4860QDS -======== - -The B4860QDS is a Freescale reference board that hosts the B4860 SoC -(and variants). - -B4860 Overview --------------- -The B4860 QorIQ Qonverge device is a Freescale high-end, multicore SoC based on -StarCore and Power Architecture® cores. It targets the broadband wireless -infrastructure and builds upon the proven success of the existing multicore -DSPs and Power CPUs. It is designed to bolster the rapidly changing and -expanding wireless markets, such as 3GLTE (FDD and TDD), LTE-Advanced, and UMTS. - -The B4860 is a highly-integrated StarCore and Power Architecture processor that -contains: - -* Six fully-programmable StarCore SC3900 FVP subsystems, divided into three - clusters-each core runs up to 1.2 GHz, with an architecture highly optimized - for wireless base station applications -* Four dual-thread e6500 Power Architecture processors organized in one - cluster-each core runs up to 1.8 GHz -* Two DDR3/3L controllers for high-speed, industry-standard memory interface - each runs at up to 1866.67 MHz -* MAPLE-B3 hardware acceleration-for forward error correction schemes including - Turbo or Viterbi decoding, Turbo encoding and rate matching, MIMO MMSE - equalization scheme, matrix operations, CRC insertion and check, DFT/iDFT and - FFT/iFFT calculations, PUSCH/PDSCH acceleration, and UMTS chip rate - acceleration -* CoreNet fabric that fully supports coherency using MESI protocol between the - e6500 cores, SC3900 FVP cores, memories and external interfaces. - CoreNet fabric interconnect runs at 667 MHz and supports coherent and - non-coherent out of order transactions with prioritization and bandwidth - allocation amongst CoreNet endpoints. -* Data Path Acceleration Architecture, which includes the following: - - * Frame Manager (FMan), which supports in-line packet parsing and general - classification to enable policing and QoS-based packet distribution - * Queue Manager (QMan) and Buffer Manager (BMan), which allow offloading - of queue management, task management, load distribution, flow ordering, - buffer management, and allocation tasks from the cores - * Security engine (SEC 5.3)-crypto-acceleration for protocols such as - IPsec, SSL, and 802.16 - * RapidIO manager (RMAN) - Support SRIO types 8, 9, 10, and 11 (inbound - and outbound). Supports types 5, 6 (outbound only) - -* Large internal cache memory with snooping and stashing capabilities for - bandwidth saving and high utilization of processor elements. The 9856-Kbyte - internal memory space includes the following: - - * 32 Kbyte L1 ICache per e6500/SC3900 core - * 32 Kbyte L1 DCache per e6500/SC3900 core - * 2048 Kbyte unified L2 cache for each SC3900 FVP cluster - * 2048 Kbyte unified L2 cache for the e6500 cluster - * Two 512 Kbyte shared L3 CoreNet platform caches (CPC) - -* Sixteen 10-GHz SerDes lanes serving: - - * Two Serial RapidIO interfaces - * Each supports up to 4 lanes and a total of up to 8 lanes - -* Up to 8-lanes Common Public Radio Interface (CPRI) controller for - glue-less antenna connection -* Two 10-Gbit Ethernet controllers (10GEC) -* Six 1G/2.5-Gbit Ethernet controllers for network communications -* PCI Express controller -* Debug (Aurora) -* Two OCeaN DMAs -* Various system peripherals -* 182 32-bit timers - -B4860QDS Overview ------------------ -- DDRC1: Ten separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, - ECC, 4 GB of memory in two ranks of 2 GB. -- DDRC2: Five separate DDR3 parts of 16-bit to support 72-bit (ECC) at 1866MT/s, - ECC, 2 GB of memory. Single rank. -- SerDes 1 multiplexing: Two Vitesse (transmit and receive path) cross-point - 16x16 switch VSC3316 -- SerDes 2 multiplexing: Two Vitesse (transmit and receive path) cross-point - 8x8 switch VSC3308 -- USB 2.0 ULPI PHY USB3315 by SMSC supports USB port in host mode. - B4860 UART port is available over USB-to-UART translator USB2SER or over - RS232 flat cable. -- A Vitesse dual SGMII phy VSC8662 links the B4860 SGMII lines to 2xRJ-45 - copper connectors for Stand-alone mode and to the 1000Base-X over AMC - MicroTCA connector ports 0 and 2 for AMC mode. -- The B4860 configuration may be loaded from nine bits coded reset configuration - reset source. The RCW source is set by appropriate DIP-switches. -- 16-bit NOR Flash / PROMJet -- QIXIS 8-bit NOR Flash Emulator -- 8-bit NAND Flash -- 24-bit SPI Flash -- Long address I2C EEPROM -- Available debug interfaces are: - - - On-board eCWTAP controller with ETH and USB I/F - - JTAG/COP 16-pin header for any external TAP controller - - External JTAG source over AMC to support B2B configuration - - 70-pin Aurora debug connector - -- QIXIS (FPGA) logic: - - 2 KB internal memory space including - -- IDT840NT4 clock synthesizer provides B4860 essential clocks : SYSCLK, - DDRCLK1,2 and RTCCLK. -- Two 8T49N222A SerDes ref clock devices support two SerDes port clock - frequency - total four refclk, including CPRI clock scheme. - - -B4420 Personality ------------------ - -B4420 is a reduced personality of B4860 with less core/clusters(both SC3900 -and e6500), less DDR controllers, less serdes lanes, less SGMII interfaces -and reduced target frequencies. - -Key differences between B4860 and B4420 ---------------------------------------- - -B4420 has: - -1. Less e6500 cores: 1 cluster with 2 e6500 cores -2. Less SC3900 cores/clusters: 1 cluster with 2 SC3900 cores per cluster -3. Single DDRC -4. 2X 4 lane serdes -5. 3 SGMII interfaces -6. no sRIO -7. no 10G - -B4860QDS Default Settings -------------------------- - -Switch Settings -^^^^^^^^^^^^^^^ - -.. code-block:: none - - SW1 OFF [0] OFF [0] OFF [0] OFF [0] OFF [0] OFF [0] OFF [0] OFF [0] - SW2 ON ON ON ON ON ON OFF OFF - SW3 OFF OFF OFF ON OFF OFF ON OFF - SW5 OFF OFF OFF OFF OFF OFF ON ON - -Note: - -- PCIe slots modes: All the PCIe devices work as Root Complex. -- Boot location: NOR flash. - -SysClk/Core(e6500)/CCB/DDR/FMan/DDRCLK/StarCore/CPRI-Maple/eTVPE-Maple/ULB-Maple -66MHz/1.6GHz/667MHz/1.6GHz data rate/667MHz/133MHz/1200MHz/500MHz/800MHz/667MHz - -NAND boot:: - - SW1 [1.1] = 0 - SW2 [1.1] = 1 - SW3 [1:4] = 0001 - -NOR boot:: - - SW1 [1.1] = 1 - SW2 [1.1] = 0 - SW3 [1:4] = 1000 - -B4420QDS Default Settings -------------------------- - -Switch Settings -^^^^^^^^^^^^^^^ - -.. code-block:: none - - SW1 OFF[0] OFF [0] OFF [0] OFF [0] OFF [0] OFF [0] OFF [0] OFF [0] - SW2 ON OFF ON OFF ON ON OFF OFF - SW3 OFF OFF OFF ON OFF OFF ON OFF - SW5 OFF OFF OFF OFF OFF OFF ON ON - -Note: - -- PCIe slots modes: All the PCIe devices work as Root Complex. -- Boot location: NOR flash. - -SysClk/Core(e6500)/CCB/DDR/FMan/DDRCLK/StarCore/CPRI-Maple/eTVPE-Maple/ULB-Maple -66MHz/1.6GHz/667MHz/1.6GHz data rate/667MHz/133MHz/1200MHz/500MHz/800MHz/667MHz - -NAND boot:: - - SW1 [1.1] = 0 - SW2 [1.1] = 1 - SW3 [1:4] = 0001 - -NOR boot:: - - SW1 [1.1] = 1 - SW2 [1.1] = 0 - SW3 [1:4] = 1000 - -Memory map on B4860QDS ----------------------- -The addresses in brackets are physical addresses. - -============= ============= =============== ======= -Start Address End Address Description Size -============= ============= =============== ======= -0xF_FFDF_1000 0xF_FFFF_FFFF Free 2 MB -0xF_FFDF_0000 0xF_FFDF_0FFF IFC - FPGA 4 KB -0xF_FF81_0000 0xF_FFDE_FFFF Free 5 MB -0xF_FF80_0000 0xF_FF80_FFFF IFC NAND Flash 64 KB -0xF_FF00_0000 0xF_FF7F_FFFF Free 8 MB -0xF_FE00_0000 0xF_FEFF_FFFF CCSRBAR 16 MB -0xF_F801_0000 0xF_FDFF_FFFF Free 95 MB -0xF_F800_0000 0xF_F800_FFFF PCIe I/O Space 64 KB -0xF_F600_0000 0xF_F7FF_FFFF QMAN s/w portal 32 MB -0xF_F400_0000 0xF_F5FF_FFFF BMAN s/w portal 32 MB -0xF_F000_0000 0xF_F3FF_FFFF Free 64 MB -0xF_E800_0000 0xF_EFFF_FFFF IFC NOR Flash 128 MB -0xF_E000_0000 0xF_E7FF_FFFF Promjet 128 MB -0xF_A0C0_0000 0xF_DFFF_FFFF Free 1012 MB -0xF_A000_0000 0xF_A0BF_FFFF MAPLE0/1/2 12 MB -0xF_0040_0000 0xF_9FFF_FFFF Free 12 GB -0xF_0000_0000 0xF_01FF_FFFF DCSR 32 MB -0xC_4000_0000 0xE_FFFF_FFFF Free 11 GB -0xC_3000_0000 0xC_3FFF_FFFF sRIO-2 I/O 256 MB -0xC_2000_0000 0xC_2FFF_FFFF sRIO-1 I/O 256 MB -0xC_0000_0000 0xC_1FFF_FFFF PCIe Mem Space 512 MB -0x1_0000_0000 0xB_FFFF_FFFF Free 44 GB -0x0_8000_0000 0x0_FFFF_FFFF DDRC1 2 GB -0x0_0000_0000 0x0_7FFF_FFFF DDRC2 2 GB -============= ============= =============== ======= - -Memory map on B4420QDS ----------------------- -The addresses in brackets are physical addresses. - -============= ============= =============== ======= -Start Address End Address Description Size -============= ============= =============== ======= -0xF_FFDF_1000 0xF_FFFF_FFFF Free 2 MB -0xF_FFDF_0000 0xF_FFDF_0FFF IFC - FPGA 4 KB -0xF_FF81_0000 0xF_FFDE_FFFF Free 5 MB -0xF_FF80_0000 0xF_FF80_FFFF IFC NAND Flash 64 KB -0xF_FF00_0000 0xF_FF7F_FFFF Free 8 MB -0xF_FE00_0000 0xF_FEFF_FFFF CCSRBAR 16 MB -0xF_F801_0000 0xF_FDFF_FFFF Free 95 MB -0xF_F800_0000 0xF_F800_FFFF PCIe I/O Space 64 KB -0xF_F600_0000 0xF_F7FF_FFFF QMAN s/w portal 32 MB -0xF_F400_0000 0xF_F5FF_FFFF BMAN s/w portal 32 MB -0xF_F000_0000 0xF_F3FF_FFFF Free 64 MB -0xF_E800_0000 0xF_EFFF_FFFF IFC NOR Flash 128 MB -0xF_E000_0000 0xF_E7FF_FFFF Promjet 128 MB -0xF_A0C0_0000 0xF_DFFF_FFFF Free 1012 MB -0xF_A000_0000 0xF_A0BF_FFFF MAPLE0/1/2 12 MB -0xF_0040_0000 0xF_9FFF_FFFF Free 12 GB -0xF_0000_0000 0xF_01FF_FFFF DCSR 32 MB -0xC_4000_0000 0xE_FFFF_FFFF Free 11 GB -0xC_3000_0000 0xC_3FFF_FFFF sRIO-2 I/O 256 MB -0xC_2000_0000 0xC_2FFF_FFFF sRIO-1 I/O 256 MB -0xC_0000_0000 0xC_1FFF_FFFF PCIe Mem Space 512 MB -0x1_0000_0000 0xB_FFFF_FFFF Free 44 GB -0x0_0000_0000 0x0_FFFF_FFFF DDRC1 4 GB -============= ============= =============== ======= - -NOR Flash memory Map on B4860 and B4420QDS ------------------------------------------- - -============= ============= ============================== ========= - Start End Definition Size -============= ============= ============================== ========= -0xEFF40000 0xEFFFFFFF U-Boot (current bank) 768KB -0xEFF20000 0xEFF3FFFF U-Boot env (current bank) 128KB -0xEFF00000 0xEFF1FFFF FMAN Ucode (current bank) 128KB -0xEF300000 0xEFEFFFFF rootfs (alternate bank) 12MB -0xEE800000 0xEE8FFFFF device tree (alternate bank) 1MB -0xEE020000 0xEE6FFFFF Linux.uImage (alternate bank) 6MB+896KB -0xEE000000 0xEE01FFFF RCW (alternate bank) 128KB -0xEDF40000 0xEDFFFFFF U-Boot (alternate bank) 768KB -0xEDF20000 0xEDF3FFFF U-Boot env (alternate bank) 128KB -0xEDF00000 0xEDF1FFFF FMAN ucode (alternate bank) 128KB -0xED300000 0xEDEFFFFF rootfs (current bank) 12MB -0xEC800000 0xEC8FFFFF device tree (current bank) 1MB -0xEC020000 0xEC6FFFFF Linux.uImage (current bank) 6MB+896KB -0xEC000000 0xEC01FFFF RCW (current bank) 128KB -============= ============= ============================== ========= - -Various Software configurations/environment variables/commands --------------------------------------------------------------- -The below commands apply to both B4860QDS and B4420QDS. - -U-Boot environment variable hwconfig -^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ - -The default hwconfig is: - -.. code-block:: none - - hwconfig=fsl_ddr:ctlr_intlv=null,bank_intlv=cs0_cs1;usb1:dr_mode=host,phy_type=ulpi - -Note: For USB gadget set "dr_mode=peripheral" - -FMAN Ucode versions -^^^^^^^^^^^^^^^^^^^ - -fsl_fman_ucode_B4860_106_3_6.bin - -Switching to alternate bank -^^^^^^^^^^^^^^^^^^^^^^^^^^^ - -Commands for switching to alternate bank. - -1. To change from vbank0 to vbank2 - -.. code-block:: none - - => qixis_reset altbank (it will boot using vbank2) - -2. To change from vbank2 to vbank0 - -.. code-block:: none - - => qixis reset (it will boot using vbank0) - -To change personality of board -^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ - -For changing personality from B4860 to B4420 - -1. Boot from vbank0 -2. Flash vbank2 with b4420 rcw and U-Boot -3. Give following commands to uboot prompt - -.. code-block:: none - - => mw.b ffdf0040 0x30; - => mw.b ffdf0010 0x00; - => mw.b ffdf0062 0x02; - => mw.b ffdf0050 0x02; - => mw.b ffdf0010 0x30; - => reset - -Note: - -- Power off cycle will lead to default switch settings. -- 0xffdf0000 is the address of the QIXIS FPGA. - -Switching between NOR and NAND boot(RCW src changed from NOR <-> NAND) -^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ - -To change from NOR to NAND boot give following command on uboot prompt - -.. code-block:: none - - => mw.b ffdf0040 0x30 - => mw.b ffdf0010 0x00 - => mw.b 0xffdf0050 0x08 - => mw.b 0xffdf0060 0x82 - => mw.b ffdf0061 0x00 - => mw.b ffdf0010 0x30 - => reset - -To change from NAND to NOR boot give following command on uboot prompt: - -.. code-block:: none - - => mw.b ffdf0040 0x30 - => mw.b ffdf0010 0x00 - => mw.b 0xffdf0050 0x00(for vbank0) or (mw.b 0xffdf0050 0x02 for vbank2) - => mw.b 0xffdf0060 0x12 - => mw.b ffdf0061 0x01 - => mw.b ffdf0010 0x30 - => reset - -Note: - -- Power off cycle will lead to default switch settings. -- 0xffdf0000 is the address of the QIXIS FPGA. - -Ethernet interfaces for B4860QDS -^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ - -Serdes protocosl tested: -* 0x2a, 0x8d (serdes1, serdes2) [DEFAULT] -* 0x2a, 0xb2 (serdes1, serdes2) - -When using [DEFAULT] RCW, which including 2 * 1G SGMII on board and 2 * 1G -SGMII on SGMII riser card. - -Under U-Boot these network interfaces are recognized as:: - - FM1@DTSEC3, FM1@DTSEC4, FM1@DTSEC5 and FM1@DTSEC6. - -On Linux the interfaces are renamed as:: - - eth2 -> fm1-gb2 - eth3 -> fm1-gb3 - eth4 -> fm1-gb4 - eth5 -> fm1-gb5 - -RCW and Ethernet interfaces for B4420QDS -^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ - -Serdes protocosl tested: -* 0x18, 0x9e (serdes1, serdes2) - -Under U-Boot these network interfaces are recognized as:: - - FM1@DTSEC3, FM1@DTSEC4 and e1000#0. - -On Linux the interfaces are renamed as:: - - eth2 -> fm1-gb2 - eth3 -> fm1-gb3 - -NAND boot with 2 Stage boot loader ----------------------------------- -PBL initialise the internal SRAM and copy SPL(160KB) in SRAM. -SPL further initialise DDR using SPD and environment variables and copy -U-Boot(768 KB) from flash to DDR. -Finally SPL transer control to U-Boot for futher booting. - -SPL has following features: - - Executes within 256K - - No relocation required - -Run time view of SPL framework during boot: - -+----------------------------------------------+ -|Area | Address | -+----------------------------------------------+ -|Secure boot | 0xFFFC0000 (32KB) | -|headers | | -+----------------------------------------------+ -|GD, BD | 0xFFFC8000 (4KB) | -+----------------------------------------------+ -|ENV | 0xFFFC9000 (8KB) | -+----------------------------------------------+ -|HEAP | 0xFFFCB000 (30KB) | -+----------------------------------------------+ -|STACK | 0xFFFD8000 (22KB) | -+----------------------------------------------+ -|U-Boot SPL | 0xFFFD8000 (160KB) | -+----------------------------------------------+ - -NAND Flash memory Map on B4860 and B4420QDS -------------------------------------------- - -============= ============= ============================= ===== -Start End Definition Size -============= ============= ============================= ===== -0x000000 0x0FFFFF U-Boot 1MB -0x140000 0x15FFFF U-Boot env 128KB -0x1A0000 0x1BFFFF FMAN Ucode 128KB -============= ============= ============================= ===== diff --git a/doc/board/freescale/index.rst b/doc/board/freescale/index.rst index 313cf409a69..bddc6c6c2c7 100644 --- a/doc/board/freescale/index.rst +++ b/doc/board/freescale/index.rst @@ -6,7 +6,6 @@ Freescale .. toctree:: :maxdepth: 2
- b4860qds imx8mm_evk imx8mn_evk imx8mp_evk diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h deleted file mode 100644 index a5cbb112f38..00000000000 --- a/include/configs/t4qds.h +++ /dev/null @@ -1,240 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2011-2012 Freescale Semiconductor, Inc. - */ - -/* - * Corenet DS style board configuration file - */ -#ifndef __T4QDS_H -#define __T4QDS_H - -/* High Level Configuration Options */ -#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ - -#ifndef CONFIG_RESET_VECTOR_ADDRESS -#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc -#endif - -#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ -#define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_PCIE1 /* PCIE controller 1 */ -#define CONFIG_PCIE2 /* PCIE controller 2 */ -#define CONFIG_PCIE3 /* PCIE controller 3 */ -#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ -#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ - -#define CONFIG_SYS_SRIO -#define CONFIG_SRIO1 /* SRIO port 1 */ -#define CONFIG_SRIO2 /* SRIO port 2 */ - -/* - * These can be toggled for performance analysis, otherwise use default. - */ -#define CONFIG_SYS_CACHE_STASHING -#define CONFIG_BTB /* toggle branch predition */ -#ifdef CONFIG_DDR_ECC -#define CONFIG_ECC_INIT_VIA_DDRCONTROLLER -#define CONFIG_MEM_INIT_VALUE 0xdeadbeef -#endif - -#define CONFIG_ENABLE_36BIT_PHYS - -/* - * Config the L3 Cache as L3 SRAM - */ -#define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 -#define CONFIG_SYS_L3_SIZE (512 << 10) -#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L3_ADDR + 32 * 1024) -#define SPL_ENV_ADDR (CONFIG_SPL_GD_ADDR + 4 * 1024) -#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SPL_GD_ADDR + 12 * 1024) -#define CONFIG_SPL_RELOC_MALLOC_SIZE (50 << 10) -#define CONFIG_SPL_RELOC_STACK (CONFIG_SPL_GD_ADDR + 64 * 1024) - -#define CONFIG_SYS_DCSRBAR 0xf0000000 -#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull - -/* - * DDR Setup - */ -#define CONFIG_VERY_BIG_RAM -#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE - -#define CONFIG_DIMM_SLOTS_PER_CTLR 2 -#define CONFIG_CHIP_SELECTS_PER_CTRL 4 - -#define CONFIG_DDR_SPD - -/* - * IFC Definitions - */ -#define CONFIG_SYS_FLASH_BASE 0xe0000000 -#define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) - -#ifdef CONFIG_SPL_BUILD -#define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE -#else -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ -#endif - -#define CONFIG_HWCONFIG - -/* define to use L1 as initial stack */ -#define CONFIG_L1_INIT_RAM -#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xfdd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW 0xfe03c000 -/* The assembler doesn't like typecast */ -#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ - ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ - CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) -#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 - -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_LEN (768 * 1024) -#define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) - -/* Serial Port - controlled on board with jumper J8 - * open - index 2 - * shorted - index 1 - */ -#define CONFIG_SYS_NS16550_SERIAL -#define CONFIG_SYS_NS16550_REG_SIZE 1 -#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) - -#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} - -#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) -#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) -#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) -#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) - -/* I2C */ -#define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_FSL -#define CONFIG_SYS_FSL_I2C_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C_OFFSET 0x118000 -#define CONFIG_SYS_FSL_I2C2_SLAVE 0x7F -#define CONFIG_SYS_FSL_I2C2_OFFSET 0x118100 - -/* - * RapidIO - */ -#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_SRIO1_MEM_SIZE 0x10000000 /* 256M */ - -#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 -#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull -#define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */ - -/* - * General PCI - * Memory space is mapped 1-1, but I/O space must start from 0. - */ - -/* controller 1, direct to uli, tgtid 3, Base address 20000 */ -#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 -#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull -#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 -#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull -#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ - -/* controller 2, Slot 2, tgtid 2, Base address 201000 */ -#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 -#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull -#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 -#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull -#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ - -/* controller 3, Slot 1, tgtid 1, Base address 202000 */ -#define CONFIG_SYS_PCIE3_MEM_VIRT 0xc0000000 -#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc40000000ull -#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 -#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull -#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ - -/* controller 4, Base address 203000 */ -#define CONFIG_SYS_PCIE4_MEM_BUS 0xe0000000 -#define CONFIG_SYS_PCIE4_MEM_PHYS 0xc60000000ull -#define CONFIG_SYS_PCIE4_MEM_SIZE 0x20000000 /* 512M */ -#define CONFIG_SYS_PCIE4_IO_BUS 0x00000000 -#define CONFIG_SYS_PCIE4_IO_PHYS 0xff8030000ull -#define CONFIG_SYS_PCIE4_IO_SIZE 0x00010000 /* 64k */ - -#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE - -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ -#endif /* CONFIG_PCI */ - -/* SATA */ -#ifdef CONFIG_FSL_SATA_V2 -#define CONFIG_SYS_SATA_MAX_DEVICE 2 -#define CONFIG_SATA1 -#define CONFIG_SYS_SATA1 CONFIG_SYS_MPC85xx_SATA1_ADDR -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA -#define CONFIG_SATA2 -#define CONFIG_SYS_SATA2 CONFIG_SYS_MPC85xx_SATA2_ADDR -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA - -#define CONFIG_LBA48 -#endif - -#ifdef CONFIG_FMAN_ENET -#define CONFIG_ETHPRIME "FM1@DTSEC1" -#endif - -/* - * Environment - */ -#define CONFIG_LOADS_ECHO /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 64 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial map for Linux*/ -#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ - -#ifdef CONFIG_CMD_KGDB -#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ -#endif - -/* - * Environment Configuration - */ -#define CONFIG_ROOTPATH "/opt/nfsroot" -#define CONFIG_BOOTFILE "uImage" -#define CONFIG_UBOOTPATH "u-boot.bin" /* U-Boot image on TFTP server*/ - -/* default location for tftp and bootm */ -#define CONFIG_LOADADDR 1000000 - -#define CONFIG_HVBOOT \ - "setenv bootargs config-addr=0x60000000; " \ - "bootm 0x01000000 - 0x00f00000" - -#endif /* __CONFIG_H */
This does not work with driver model so can be removed.
README | 3 -- drivers/pci/Makefile | 1 - drivers/pci/pci_indirect.c | 71 ----------------------------- include/configs/MPC8349EMDS.h | 4 -- include/configs/MPC8349EMDS_SDRAM.h | 4 -- include/configs/MPC837XERDB.h | 2 - include/configs/MPC8540ADS.h | 1 - include/configs/MPC8560ADS.h | 1 - include/pci.h | 4 -- scripts/config_whitelist.txt | 1 - 10 files changed, 92 deletions(-) delete mode 100644 drivers/pci/pci_indirect.c
diff --git a/README b/README index 1472b40bc45..a84a094a854 100644 --- a/README +++ b/README @@ -2773,9 +2773,6 @@ Low Level (hardware related) configuration options: CONFIG_SYS_OR3_PRELIM, CONFIG_SYS_BR3_PRELIM: Memory Controller Definitions: BR2/3 and OR2/3 (SDRAM)
-- CONFIG_PCI_INDIRECT_BRIDGE: - Enable support for indirect PCI bridges. - - CONFIG_SYS_SRIO: Chip has SRIO or not
diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index bdfdec98a08..4a131bf5ca4 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -14,7 +14,6 @@ obj-$(CONFIG_PCI) += pci_auto_common.o pci_common.o obj-$(CONFIG_PCIE_ECAM_GENERIC) += pcie_ecam_generic.o obj-$(CONFIG_PCIE_ECAM_SYNQUACER) += pcie_ecam_synquacer.o obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o -obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o obj-$(CONFIG_PCI_GT64120) += pci_gt64120.o obj-$(CONFIG_PCI_MPC85XX) += pci_mpc85xx.o obj-$(CONFIG_PCI_MSC01) += pci_msc01.o diff --git a/drivers/pci/pci_indirect.c b/drivers/pci/pci_indirect.c deleted file mode 100644 index 6134c22d1bc..00000000000 --- a/drivers/pci/pci_indirect.c +++ /dev/null @@ -1,71 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Support for indirect PCI bridges. - * - * Copyright (C) 1998 Gabriel Paubert. - */ - -#include <common.h> - -#if !defined(__I386__) && !defined(CONFIG_DM_PCI) - -#include <asm/processor.h> -#include <asm/io.h> -#include <pci.h> - -#define cfg_read(val, addr, type, op) *val = op((type)(addr)) -#define cfg_write(val, addr, type, op) op((type *)(addr), (val)) - -#if defined(CONFIG_E500) || defined(CONFIG_MPC86xx) -#define INDIRECT_PCI_OP(rw, size, type, op, mask) \ -static int \ -indirect_##rw##_config_##size(struct pci_controller *hose, \ - pci_dev_t dev, int offset, type val) \ -{ \ - u32 b, d,f; \ - b = PCI_BUS(dev); d = PCI_DEV(dev); f = PCI_FUNC(dev); \ - b = b - hose->first_busno; \ - dev = PCI_BDF(b, d, f); \ - *(hose->cfg_addr) = dev | (offset & 0xfc) | ((offset & 0xf00) << 16) | 0x80000000; \ - sync(); \ - cfg_##rw(val, hose->cfg_data + (offset & mask), type, op); \ - return 0; \ -} -#else -#define INDIRECT_PCI_OP(rw, size, type, op, mask) \ -static int \ -indirect_##rw##_config_##size(struct pci_controller *hose, \ - pci_dev_t dev, int offset, type val) \ -{ \ - u32 b, d,f; \ - b = PCI_BUS(dev); d = PCI_DEV(dev); f = PCI_FUNC(dev); \ - b = b - hose->first_busno; \ - dev = PCI_BDF(b, d, f); \ - out_le32(hose->cfg_addr, dev | (offset & 0xfc) | 0x80000000); \ - cfg_##rw(val, hose->cfg_data + (offset & mask), type, op); \ - return 0; \ -} -#endif - -INDIRECT_PCI_OP(read, byte, u8 *, in_8, 3) -INDIRECT_PCI_OP(read, word, u16 *, in_le16, 2) -INDIRECT_PCI_OP(read, dword, u32 *, in_le32, 0) -INDIRECT_PCI_OP(write, byte, u8, out_8, 3) -INDIRECT_PCI_OP(write, word, u16, out_le16, 2) -INDIRECT_PCI_OP(write, dword, u32, out_le32, 0) - -void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data) -{ - pci_set_ops(hose, - indirect_read_config_byte, - indirect_read_config_word, - indirect_read_config_dword, - indirect_write_config_byte, - indirect_write_config_word, - indirect_write_config_dword); - - hose->cfg_addr = (unsigned int *) cfg_addr; - hose->cfg_data = (unsigned char *) cfg_data; -} - -#endif /* !__I386__ */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 11959e509a5..42fb165001f 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -303,10 +303,6 @@ #define CONFIG_SYS_SICRH 0 #define CONFIG_SYS_SICRL SICRL_LDP_A
-#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE -#endif - #if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed of kgdb serial port */ #endif diff --git a/include/configs/MPC8349EMDS_SDRAM.h b/include/configs/MPC8349EMDS_SDRAM.h index d424427e0c8..bab9a1ce159 100644 --- a/include/configs/MPC8349EMDS_SDRAM.h +++ b/include/configs/MPC8349EMDS_SDRAM.h @@ -360,10 +360,6 @@ #define CONFIG_SYS_SICRH 0 #define CONFIG_SYS_SICRL SICRL_LDP_A
-#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE -#endif - #if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed of kgdb serial port */ #endif diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index c37cdae07f8..a6b2ebe8c73 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -255,8 +255,6 @@ #define CONFIG_SYS_PCIE2_IO_SIZE 0x00800000
#ifdef CONFIG_PCI -#define CONFIG_PCI_INDIRECT_BRIDGE - #undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index afe972ee105..3842851a120 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -26,7 +26,6 @@ #define CONFIG_HAS_FEC 1 /* 8540 has FEC */ #endif
-#define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */
/* diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index d24b5b5eac3..26f95270d43 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -27,7 +27,6 @@ * assume U-Boot is less than 0.5MB */
-#define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #undef CONFIG_ETHER_ON_FCC /* cpm FCC ethernet support */ #define CONFIG_RESET_PHY_R 1 /* Call reset_phy() */ diff --git a/include/pci.h b/include/pci.h index 2c2930e7a74..0fc22adffd0 100644 --- a/include/pci.h +++ b/include/pci.h @@ -656,10 +656,6 @@ struct pci_controller { struct pci_region *pci_mem, *pci_io, *pci_prefetch; };
-#ifdef CONFIG_PCI_INDIRECT_BRIDGE -extern void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data); -#endif - #if defined(CONFIG_DM_PCI_COMPAT) extern phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, pci_addr_t addr, unsigned long flags); diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index 98a80680f6e..c66b1194f4b 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -1097,7 +1097,6 @@ CONFIG_PCI_EHCI_DEVICE CONFIG_PCI_EHCI_DEVNO CONFIG_PCI_FIXUP_DEV CONFIG_PCI_GT64120 -CONFIG_PCI_INDIRECT_BRIDGE CONFIG_PCI_IO_BUS CONFIG_PCI_IO_PHYS CONFIG_PCI_IO_SIZE
This option has not effect now. Drop it, using PCI instead where needed.
arch/Kconfig | 1 - arch/arm/Kconfig | 2 +- arch/arm/mach-imx/mx6/Kconfig | 2 +- arch/mips/Kconfig | 2 +- board/emulation/qemu-riscv/Kconfig | 1 - board/socionext/developerbox/Kconfig | 1 - common/Kconfig | 1 - drivers/gpio/Kconfig | 2 +- drivers/i2c/Makefile | 2 +- drivers/net/Kconfig | 6 ++--- drivers/net/mscc_eswitch/Kconfig | 2 +- drivers/pci/Kconfig | 40 +++------------------------- drivers/spi/Kconfig | 2 +- drivers/virtio/Kconfig | 2 +- test/dm/Makefile | 2 +- 15 files changed, 14 insertions(+), 54 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 49813a4c9b8..e5df36f9922 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -182,7 +182,6 @@ config X86 select SUPPORT_TPL select CREATE_ARCH_SYMLINK select DM - select DM_PCI select HAVE_ARCH_IOMAP select HAVE_PRIVATE_LIBGCC select OF_CONTROL diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 9de97cc1015..b3123178f79 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1669,7 +1669,7 @@ config TARGET_SL28 select DM_SPI_FLASH select DM_ETH select DM_MDIO - select DM_PCI + select PCI select DM_RNG select DM_RTC select DM_SCSI diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index a03eca81651..f5db7aeddaa 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -237,7 +237,7 @@ config TARGET_KOSAGI_NOVENA select DM_ETH select DM_GPIO select DM_MMC - select DM_PCI + select PCI select DM_SCSI select DM_VIDEO select OF_CONTROL diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 6b1f10d9a0e..a5cec387a04 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -17,7 +17,7 @@ config TARGET_MALTA select BOARD_EARLY_INIT_R select DM select DM_SERIAL - select DM_PCI + select PCI select DM_ETH select DYNAMIC_IO_PORT_BASE select MIPS_CM diff --git a/board/emulation/qemu-riscv/Kconfig b/board/emulation/qemu-riscv/Kconfig index 0818048ba64..46b01c2049a 100644 --- a/board/emulation/qemu-riscv/Kconfig +++ b/board/emulation/qemu-riscv/Kconfig @@ -51,7 +51,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy imply E1000 imply NVME imply PCI - imply DM_PCI imply PCIE_ECAM_GENERIC imply SCSI imply DM_SCSI diff --git a/board/socionext/developerbox/Kconfig b/board/socionext/developerbox/Kconfig index 706b8dc0f1c..c181d26a44a 100644 --- a/board/socionext/developerbox/Kconfig +++ b/board/socionext/developerbox/Kconfig @@ -7,7 +7,6 @@ choice config TARGET_DEVELOPERBOX bool "Socionext DeveloperBox" select PCI - select DM_PCI select PCIE_ECAM_SYNQUACER select SYS_DISABLE_DCACHE_OPS select OF_BOARD_SETUP diff --git a/common/Kconfig b/common/Kconfig index 2ab20a6c85b..ee14d3ad5bf 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -551,7 +551,6 @@ config MISC_INIT_R config PCI_INIT_R bool "Enumerate PCI buses during init" depends on PCI - default y if !DM_PCI help With this option U-Boot will call pci_init() soon after relocation, which will enumerate PCI buses. This is needed, for instance, in the diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 0817b12c5f7..ae373887174 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -348,7 +348,7 @@ config PIC32_GPIO
config OCTEON_GPIO bool "Octeon II/III/TX/TX2 GPIO driver" - depends on DM_GPIO && DM_PCI && (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2) + depends on DM_GPIO && PCI && (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2) default y help Add support for the Marvell Octeon GPIO driver. This is used with diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 06a1150f03d..7c644dcb25f 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -18,7 +18,7 @@ obj-$(CONFIG_SYS_I2C_CADENCE) += i2c-cdns.o obj-$(CONFIG_SYS_I2C_CA) += i2c-cortina.o obj-$(CONFIG_SYS_I2C_DAVINCI) += davinci_i2c.o obj-$(CONFIG_SYS_I2C_DW) += designware_i2c.o -ifdef CONFIG_DM_PCI +ifdef CONFIG_PCI obj-$(CONFIG_SYS_I2C_DW) += designware_i2c_pci.o endif obj-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 130db9fb391..4e9f31deaa4 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -222,7 +222,6 @@ config DWC_ETH_QOS_TEGRA186
config E1000 bool "Intel PRO/1000 Gigabit Ethernet support" - depends on (DM_ETH && DM_PCI) || !DM_ETH help This driver supports Intel(R) PRO/1000 gigabit ethernet family of adapters. For more information on how to identify your adapter, go @@ -506,7 +505,7 @@ config OCTEONTX2_CGX_INTF
config PCH_GBE bool "Intel Platform Controller Hub EG20T GMAC driver" - depends on DM_ETH && DM_PCI + depends on DM_ETH select PHYLIB help This MAC is present in Intel Platform Controller Hub EG20T. It @@ -606,7 +605,6 @@ source "drivers/net/ti/Kconfig"
config TULIP bool "DEC Tulip DC2114x Ethernet support" - depends on (DM_ETH && DM_PCI) || !DM_ETH help This driver supports DEC DC2114x Fast ethernet chips.
@@ -782,7 +780,7 @@ config HIGMACV300_ETH
config FSL_ENETC bool "NXP ENETC Ethernet controller" - depends on DM_PCI && DM_ETH && DM_MDIO + depends on DM_ETH && DM_MDIO help This driver supports the NXP ENETC Ethernet controller found on some of the NXP SoCs. diff --git a/drivers/net/mscc_eswitch/Kconfig b/drivers/net/mscc_eswitch/Kconfig index ccf7822dbe7..930d2ef1130 100644 --- a/drivers/net/mscc_eswitch/Kconfig +++ b/drivers/net/mscc_eswitch/Kconfig @@ -39,7 +39,7 @@ config MSCC_SERVAL_SWITCH
config MSCC_FELIX_SWITCH bool "Felix switch driver" - depends on DM_DSA && DM_PCI + depends on DM_DSA select FSL_ENETC help This driver supports the Ethernet switch integrated in the diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 2ef4d46797e..e4123ba820f 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -2,35 +2,26 @@ menuconfig PCI bool "PCI support" depends on DM default y if PPC - select DM_PCI help Enable support for PCI (Peripheral Interconnect Bus), a type of bus used on some devices to allow the CPU to communicate with its peripherals.
-config DM_PCI - bool - help - Use driver model for PCI. Driver model is the new method for - orgnising devices in U-Boot. For PCI, driver model keeps track of - available PCI devices, allows scanning of PCI buses and provides - device configuration support. + This subsystem requires driver model.
if PCI
config DM_PCI_COMPAT bool "Enable compatible functions for PCI" - depends on DM_PCI help Enable compatibility functions for PCI so that old code can be used - with CONFIG_DM_PCI enabled. This should be used as an interim + with CONFIG_PCI enabled. This should be used as an interim measure when porting a board to use driver model for PCI. Once the board is fully supported, this option should be disabled.
config PCI_AARDVARK bool "Enable Aardvark PCIe driver" default n - depends on DM_PCI depends on DM_GPIO depends on ARMADA_3700 help @@ -40,14 +31,12 @@ config PCI_AARDVARK
config PCI_PNP bool "Enable Plug & Play support for PCI" - depends on PCI || DM_PCI default y help Enable PCI memory and I/O space resource allocation and assignment.
config PCI_REGION_MULTI_ENTRY bool "Enable Multiple entries of region type MEMORY in ranges for PCI" - depends on PCI || DM_PCI default n help Enable PCI memory regions to be of multiple entry. Multiple entry @@ -57,7 +46,6 @@ config PCI_REGION_MULTI_ENTRY
config PCI_MAP_SYSTEM_MEMORY bool "Map local system memory from a virtual base address" - depends on PCI || DM_PCI depends on MIPS default n help @@ -70,7 +58,6 @@ config PCI_MAP_SYSTEM_MEMORY
config PCI_SRIOV bool "Enable Single Root I/O Virtualization support for PCI" - depends on PCI || DM_PCI default n help Say Y here if you want to enable PCI Single Root I/O Virtualization @@ -80,7 +67,6 @@ config PCI_SRIOV
config PCI_ARID bool "Enable Alternate Routing-ID support for PCI" - depends on PCI || DM_PCI default n help Say Y here if you want to enable Alternate Routing-ID capability @@ -90,7 +76,6 @@ config PCI_ARID config PCIE_ECAM_GENERIC bool "Generic ECAM-based PCI host controller support" default n - depends on DM_PCI help Say Y here if you want to enable support for generic ECAM-based PCIe host controllers, such as the one emulated by QEMU. @@ -98,7 +83,6 @@ config PCIE_ECAM_GENERIC config PCIE_ECAM_SYNQUACER bool "SynQuacer ECAM-based PCI host controller support" default n - depends on DM_PCI select PCI_INIT_R select PCI_REGION_MULTI_ENTRY help @@ -109,14 +93,12 @@ config PCIE_ECAM_SYNQUACER
config PCI_PHYTIUM bool "Phytium PCIe support" - depends on DM_PCI help Say Y here if you want to enable PCIe controller support on Phytium SoCs.
config PCIE_DW_MVEBU bool "Enable Armada-8K PCIe driver (DesignWare core)" - depends on DM_PCI depends on ARMADA_8K help Say Y here if you want to enable PCIe controller support on @@ -135,7 +117,6 @@ config PCIE_DW_SIFIVE
config PCIE_FSL bool "FSL PowerPC PCIe support" - depends on DM_PCI help Say Y here if you want to enable PCIe controller support on FSL PowerPC MPC85xx, MPC86xx, B series, P series and T series SoCs. @@ -143,14 +124,12 @@ config PCIE_FSL
config PCI_MPC85XX bool "MPC85XX PowerPC PCI support" - depends on DM_PCI help Say Y here if you want to enable PCI controller support on FSL PowerPC MPC85xx SoC.
config PCI_RCAR_GEN2 bool "Renesas RCar Gen2 PCIe driver" - depends on DM_PCI depends on RCAR_32 help Say Y here if you want to enable PCIe controller support on @@ -159,7 +138,6 @@ config PCI_RCAR_GEN2
config PCI_RCAR_GEN3 bool "Renesas RCar Gen3 PCIe driver" - depends on DM_PCI depends on RCAR_GEN3 help Say Y here if you want to enable PCIe controller support on @@ -167,7 +145,7 @@ config PCI_RCAR_GEN3
config PCI_SANDBOX bool "Sandbox PCI support" - depends on SANDBOX && DM_PCI + depends on SANDBOX help Support PCI on sandbox, as an emulated bus. This permits testing of PCI feature such as bus scanning, device configuration and device @@ -202,7 +180,6 @@ config PCIE_OCTEON
config PCI_XILINX bool "Xilinx AXI Bridge for PCI Express" - depends on DM_PCI help Enable support for the Xilinx AXI bridge for PCI express, an IP block which can be used on some generations of Xilinx FPGAs. @@ -213,7 +190,6 @@ config PCIE_LAYERSCAPE
config PCIE_LAYERSCAPE_RC bool "Layerscape PCIe Root Complex mode support" - depends on DM_PCI select PCIE_LAYERSCAPE help Enable Layerscape PCIe Root Complex mode driver support. The Layerscape @@ -235,7 +211,6 @@ config PCI_IOMMU_EXTRA_MAPPINGS
config PCIE_LAYERSCAPE_EP bool "Layerscape PCIe Endpoint mode support" - depends on DM_PCI select PCIE_LAYERSCAPE select PCI_ENDPOINT help @@ -246,7 +221,6 @@ config PCIE_LAYERSCAPE_EP
config PCIE_LAYERSCAPE_GEN4 bool "Layerscape Gen4 PCIe support" - depends on DM_PCI help Support PCIe Gen4 on NXP Layerscape SoCs, which may have one or several PCIe controllers. The PCIe controller can work in RC or @@ -279,14 +253,12 @@ config FSL_PCIE_EP_COMPAT
config PCIE_INTEL_FPGA bool "Intel FPGA PCIe support" - depends on DM_PCI help Say Y here if you want to enable PCIe controller support on Intel FPGA, example Stratix 10.
config PCIE_IPROC bool "Iproc PCIe support" - depends on DM_PCI help Broadcom iProc PCIe controller driver. Say Y here if you want to enable Broadcom iProc PCIe controller, @@ -294,7 +266,6 @@ config PCIE_IPROC config PCI_MVEBU bool "Enable Armada XP/38x PCIe driver" depends on ARCH_MVEBU - select DM_PCI select MISC help Say Y here if you want to enable PCIe controller support on @@ -302,7 +273,6 @@ config PCI_MVEBU
config PCIE_DW_COMMON bool - select DM_PCI
config PCI_KEYSTONE bool "TI Keystone PCIe controller" @@ -312,7 +282,6 @@ config PCI_KEYSTONE
config PCIE_MEDIATEK bool "MediaTek PCIe Gen2 controller" - depends on DM_PCI depends on ARCH_MEDIATEK help Say Y here if you want to enable Gen2 PCIe controller, @@ -329,7 +298,6 @@ config PCIE_DW_MESON config PCIE_ROCKCHIP bool "Enable Rockchip PCIe driver" depends on ARCH_ROCKCHIP - select DM_PCI select PHY_ROCKCHIP_PCIE default y if ROCKCHIP_RK3399 help @@ -347,7 +315,6 @@ config PCIE_DW_ROCKCHIP
config PCI_BRCMSTB bool "Broadcom STB PCIe controller" - depends on DM_PCI depends on ARCH_BCM283X help Say Y here if you want to enable support for PCIe controller @@ -357,7 +324,6 @@ config PCI_BRCMSTB
config PCIE_UNIPHIER bool "Socionext UniPhier PCIe driver" - depends on DM_PCI depends on ARCH_UNIPHIER select PHY_UNIPHIER_PCIE help diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 5c2a60a2142..db236591f64 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -271,7 +271,7 @@ config NXP_FSPI
config OCTEON_SPI bool "Octeon SPI driver" - depends on DM_PCI && (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2) + depends on ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2 help Enable the Octeon SPI driver. This driver can be used to access the SPI NOR flash on Octeon II/III and OcteonTX/TX2 diff --git a/drivers/virtio/Kconfig b/drivers/virtio/Kconfig index 18356070833..863c3fbe029 100644 --- a/drivers/virtio/Kconfig +++ b/drivers/virtio/Kconfig @@ -31,7 +31,7 @@ config VIRTIO_MMIO
config VIRTIO_PCI bool "PCI driver for virtio devices" - depends on DM_PCI + depends on PCI select VIRTIO help This driver provides support for virtio based paravirtual device diff --git a/test/dm/Makefile b/test/dm/Makefile index d5c42e7643e..958d7df94a4 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -64,7 +64,7 @@ obj-y += of_extra.o obj-$(CONFIG_OSD) += osd.o obj-$(CONFIG_DM_VIDEO) += panel.o obj-$(CONFIG_EFI_PARTITION) += part.o -obj-$(CONFIG_DM_PCI) += pci.o +obj-$(CONFIG_PCI) += pci.o obj-$(CONFIG_P2SB) += p2sb.o obj-$(CONFIG_PCI_ENDPOINT) += pci_ep.o obj-$(CONFIG_PCH) += pch.o
Migration is complete. Drop the message.
doc/develop/driver-model/migration.rst | 9 --------- 1 file changed, 9 deletions(-)
diff --git a/doc/develop/driver-model/migration.rst b/doc/develop/driver-model/migration.rst index 8d0bb7635b5..8bb8601c582 100644 --- a/doc/develop/driver-model/migration.rst +++ b/doc/develop/driver-model/migration.rst @@ -75,15 +75,6 @@ Partially converted:: * Status: In progress * Deadline: 2019.07
-CONFIG_DM_PCI -------------- -Deadline: 2019.07 - -The PCI subsystem has supported driver model since mid 2015. Maintainers should -submit patches switching over to using CONFIG_DM_PCI and other base driver -model options in time for inclusion in the 2019.07 release. - - CONFIG_DM_VIDEO --------------- Deadline: 2019.07
Daniel Schwierzeck
Ramon Fried
