[U-Boot] [PATCH] env: Allow accessing non-mtd devices
In certain cases, memory device is present as flat file or block device (via mmc or mtdblock layer). Do not attempt MTD operations against it. --- tools/env/fw_env.c | 21 ++++++++++++++++----- tools/env/fw_env.config | 3 +++ 2 files changed, 19 insertions(+), 5 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 37b60b8..0d8052d 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -838,7 +838,7 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, ioctl (fd, MEMUNLOCK, &erase);
/* Dataflash does not need an explicit erase cycle */ - if (mtd_type != MTD_DATAFLASH) + if (mtd_type && mtd_type != MTD_DATAFLASH) if (ioctl (fd, MEMERASE, &erase) != 0) { fprintf (stderr, "MTD erase error on %s: %s\n", DEVNAME (dev), @@ -949,23 +949,34 @@ static int flash_write (int fd_current, int fd_target, int dev_target) static int flash_read (int fd) { struct mtd_info_user mtdinfo; + struct stat st; int rc;
- rc = ioctl (fd, MEMGETINFO, &mtdinfo); + rc = fstat (fd, &st); if (rc < 0) { - perror ("Cannot get MTD information"); + perror ("Cannot access MTD device"); return -1; }
+ if (S_ISCHR (st.st_mode)) { + rc = ioctl (fd, MEMGETINFO, &mtdinfo); + if (rc < 0) { + perror ("Cannot get MTD information"); + return -1; + } + } else { + memset (&mtdinfo, 0, sizeof (mtdinfo)); + } + if (mtdinfo.type != MTD_NORFLASH && mtdinfo.type != MTD_NANDFLASH && - mtdinfo.type != MTD_DATAFLASH) { + mtdinfo.type != MTD_DATAFLASH && + mtdinfo.type) { fprintf (stderr, "Unsupported flash type %u\n", mtdinfo.type); return -1; }
DEVTYPE(dev_current) = mtdinfo.type; - rc = flash_read_buf(dev_current, fd, environment.image, CUR_ENVSIZE, DEVOFFSET (dev_current), mtdinfo.type);
diff --git a/tools/env/fw_env.config b/tools/env/fw_env.config index 8e21d5a..c086512 100644 --- a/tools/env/fw_env.config +++ b/tools/env/fw_env.config @@ -17,3 +17,6 @@
# NAND example #/dev/mtd0 0x4000 0x4000 0x20000 2 + +# Block device example +#/dev/mmcblk0 0xc0000 0x20000
Dear Lubomir Rintel,
What exactly would be such cases?
This change appears to be redundant. If mtd_type is null, then this is already caught iun te test mtd_type != MTD_DATAFLASH, isn't it?
- rc = fstat (fd, &st); if (rc < 0) {
I don't understand this. You talk about a MTD device here, but expect that MEMGETINFO will not work on it? Please explain in which exact circumstances such a situation wouldhappen.
mtdinfo.type) {
Again, this last line appears to be redundant.
Please don't make such unrelated white space changes in this commit.
I don't see why one would use that. Please elucidate.
Please also make sure to run your patch through checkpatch - it catches a number of "space prohibited between function name and open parenthesis" warnings and tells you that your Signed-off-by: line is missing.
Mine is a Kobo Mini e-book reader, which is basically Freescale MX50 with the only storage there being an MMC/SD card (removable from a slot if disassembled), which contains uboot and its environment as well as partition table, root and storage volume.
Apart from wiring a serial console, running fw_* tools seems to be about the only way to modify kernel command line on that device. Also, I can imagine that it would be useful to prepare a flat file image on a different computer and copy it to the image afterwards.
I tried to stick with the coding style already present in the file. No problem though, I'll follow up with an updated patch later.
Noted, will fix.
Thank you!
Lubo
OK - but you do not comment on my remarks about the actual code?
No. We don't want the erase ioctl to be called for non-MTD devices and files (where mtd_type is null).
The error message (mention of MTD at that point) is incorrect. fstat() is called to determine whether the device is a character device (such as MTD devices -- MEMGETINFO call will follow) or not (it might be a blockdevice or flat file).
mtdinfo.type) {
The same response again -- if the type is nul, then the device is not a flash device at all.
That was a mistake.
Have a nice day! -- Lubo
Signed-off-by: Lubomir Rintel lkundrak@v3.sk --- tools/env/fw_env.c | 20 ++++++++++++++++---- tools/env/fw_env.config | 3 +++ 2 files changed, 19 insertions(+), 4 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 37b60b8..72d77a9 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -838,7 +838,7 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count, ioctl (fd, MEMUNLOCK, &erase);
/* Dataflash does not need an explicit erase cycle */ - if (mtd_type != MTD_DATAFLASH) + if (mtd_type && mtd_type != MTD_DATAFLASH) if (ioctl (fd, MEMERASE, &erase) != 0) { fprintf (stderr, "MTD erase error on %s: %s\n", DEVNAME (dev), @@ -949,17 +949,29 @@ static int flash_write (int fd_current, int fd_target, int dev_target) static int flash_read (int fd) { struct mtd_info_user mtdinfo; + struct stat st; int rc;
- rc = ioctl (fd, MEMGETINFO, &mtdinfo); + rc = fstat(fd, &st); if (rc < 0) { - perror ("Cannot get MTD information"); + perror("Cannot access the device file"); return -1; }
+ if (S_ISCHR(st.st_mode)) { + rc = ioctl(fd, MEMGETINFO, &mtdinfo); + if (rc < 0) { + perror("Cannot get MTD information"); + return -1; + } + } else { + memset(&mtdinfo, 0, sizeof(mtdinfo)); + } + if (mtdinfo.type != MTD_NORFLASH && mtdinfo.type != MTD_NANDFLASH && - mtdinfo.type != MTD_DATAFLASH) { + mtdinfo.type != MTD_DATAFLASH && + mtdinfo.type) { fprintf (stderr, "Unsupported flash type %u\n", mtdinfo.type); return -1; } diff --git a/tools/env/fw_env.config b/tools/env/fw_env.config index 8e21d5a..c086512 100644 --- a/tools/env/fw_env.config +++ b/tools/env/fw_env.config @@ -17,3 +17,6 @@
Arghhh! NAK.
There is no patch version, no history of changes, nothing.
Please read http://www.denx.de/wiki/view/U-Boot/Patches#Sending_updated_patch_versions and follow the rules.
Please also see my previous review comments.
Also:
- rc = fstat(fd, &st); if (rc < 0) {
return -1; }perror("Cannot access the device file");
This error message is still misleading (as you did not use any access(2) system call in your code); also, the use of perror() is - let's say - a bit unusual (not your fault in the first place) and should be fixed; it would be more helpful to print the actual file name here.
Signed-off-by: Lubomir Rintel lkundrak@v3.sk --- Changes for v2: - Coding Style cleanup - Clarified an error message Changes for v3: - Used MTD_ABSENT macro to represent non-MTD devices - Cleaned up places when zero was used instead of MTD_ABSENT Changes for v4: - Further clarification to failed fstat() error message - Improved flash_read() error handling to include file names
tools/env/fw_env.c | 34 +++++++++++++++++++++++----------- tools/env/fw_env.config | 3 +++ 2 files changed, 26 insertions(+), 11 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 0c68e24..bf30234 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -836,9 +836,9 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count,
erase.start = blockstart; ioctl (fd, MEMUNLOCK, &erase); - - /* Dataflash does not need an explicit erase cycle */ - if (mtd_type != MTD_DATAFLASH) + /* These do not need an explicit erase cycle */ + if (mtd_type != MTD_ABSENT && + mtd_type != MTD_DATAFLASH) if (ioctl (fd, MEMERASE, &erase) != 0) { fprintf (stderr, "MTD erase error on %s: %s\n", DEVNAME (dev), @@ -949,21 +949,33 @@ static int flash_write (int fd_current, int fd_target, int dev_target) static int flash_read (int fd) { struct mtd_info_user mtdinfo; + struct stat st; int rc;
- rc = ioctl (fd, MEMGETINFO, &mtdinfo); + rc = fstat(fd, &st); if (rc < 0) { - fprintf(stderr, "Cannot get MTD information for %s\n", + fprintf(stderr, "Cannot stat the file %s\n", DEVNAME(dev_current)); return -1; }
- if (mtdinfo.type != MTD_NORFLASH && - mtdinfo.type != MTD_NANDFLASH && - mtdinfo.type != MTD_DATAFLASH) { - fprintf (stderr, "Unsupported flash type %u on %s\n", - mtdinfo.type, DEVNAME(dev_current)); - return -1; + if (S_ISCHR(st.st_mode)) { + rc = ioctl(fd, MEMGETINFO, &mtdinfo); + if (rc < 0) { + fprintf(stderr, "Cannot get MTD information for %s\n", + DEVNAME(dev_current)); + return -1; + } + if (mtdinfo.type != MTD_NORFLASH && + mtdinfo.type != MTD_NANDFLASH && + mtdinfo.type != MTD_DATAFLASH) { + fprintf (stderr, "Unsupported flash type %u on %s\n", + mtdinfo.type, DEVNAME(dev_current)); + return -1; + } + } else { + memset(&mtdinfo, 0, sizeof(mtdinfo)); + mtdinfo.type = MTD_ABSENT; }
DEVTYPE(dev_current) = mtdinfo.type; diff --git a/tools/env/fw_env.config b/tools/env/fw_env.config index 8e21d5a..c086512 100644 --- a/tools/env/fw_env.config +++ b/tools/env/fw_env.config @@ -17,3 +17,6 @@
I see. But you are misusing mtd_type.
You should define something like MTD_NO_FLASH or so, and use that.
So it needs to be fixed.
mtdinfo.type) {
See above. Please make the code sonsistent and define a proper name for this type.
I found it a bit more abusive to use a MTD_* macro in mtd_type variable for something what is not actually a type of a MTD device, specially when a change in MTD ABI would be needed.
Maybe passing a NULL mtd_info_user pointer to flash_{read,write}_buf() instead of zero type (which happens to be MTD_ABSENT, and, as you pointed out, a misuse) would make more sense for a non-MTD file?
Hopefully fixed in a follow-up patch. I'll follow up with another one (this time with proper changlog and versioning, sorry for that) once an acceptable solution to the issue above is agreed upon.
Thanks, -- Lubo
Dear Lubomir,
But that's exactly what you are doing here, just in a way that it is not even visible. By assigning a mtd_type value of 0, you are setting it to MTD_ABSENT - but you don't write MTD_ABSENT.
This is even more dangerous.
I don't have any real problems with using MTD_ABSENT - it even makes kind of sense.
tools/env/fw_env.c | 32 ++++++++++++++++++++++---------- tools/env/fw_env.config | 3 +++ 2 files changed, 25 insertions(+), 10 deletions(-)
diff --git a/tools/env/fw_env.c b/tools/env/fw_env.c index 37b60b8..94a790d 100644 --- a/tools/env/fw_env.c +++ b/tools/env/fw_env.c @@ -836,9 +836,9 @@ static int flash_write_buf (int dev, int fd, void *buf, size_t count,
erase.start = blockstart; ioctl (fd, MEMUNLOCK, &erase); - - /* Dataflash does not need an explicit erase cycle */ - if (mtd_type != MTD_DATAFLASH) + /* These do not need an explicit erase cycle */ + if (mtd_type != MTD_ABSENT && + mtd_type != MTD_DATAFLASH) if (ioctl (fd, MEMERASE, &erase) != 0) { fprintf (stderr, "MTD erase error on %s: %s\n", DEVNAME (dev), @@ -949,19 +949,31 @@ static int flash_write (int fd_current, int fd_target, int dev_target) static int flash_read (int fd) { struct mtd_info_user mtdinfo; + struct stat st; int rc;
- if (mtdinfo.type != MTD_NORFLASH && - mtdinfo.type != MTD_NANDFLASH && - mtdinfo.type != MTD_DATAFLASH) { - fprintf (stderr, "Unsupported flash type %u\n", mtdinfo.type); - return -1; + if (S_ISCHR(st.st_mode)) { + rc = ioctl(fd, MEMGETINFO, &mtdinfo); + if (rc < 0) { + perror("Cannot get MTD information"); + return -1; + } + if (mtdinfo.type != MTD_NORFLASH && + mtdinfo.type != MTD_NANDFLASH && + mtdinfo.type != MTD_DATAFLASH) { + fprintf(stderr, "Unsupported flash type %u\n", + mtdinfo.type); + return -1; + } + } else { + memset(&mtdinfo, 0, sizeof(mtdinfo)); + mtdinfo.type = MTD_ABSENT; }
Lubomir Rintel
