[PATCH v3 00/10] riscv: Add FPIOA and GPIO support for Kendryte K210
This patch series adds support for pinmuxing, gpios, and leds on the Kendyte K210.
This patch series was previously part of https://patchwork.ozlabs.org/project/uboot/list/?series=161576
This patch series depends on https://patchwork.ozlabs.org/project/uboot/list/?series=178480
Changes in v3: - Add dt-bindings/pinctrl/sandbox-pinmux.h to patch
Changes in v2: - Add test for pinmuxing - Don't clear existing pinctrl settings on probe - Re-order GPIOs to match the defaults more closely - Rebase onto v13 of "riscv: Add Sipeed Maix support" - Rewrite FPIOA driver to use pinmux property - Support muxing the output enable signal for each function in the FPIOA - Support output and input inversion in the pinmux driver - Support pinmux property in pinctrl-generic
Sean Anderson (10): pinctrl: Add pinmux property support to pinctrl-generic test: pinmux: Add test for pin muxing pinctrl: Add support for Kendryte K210 FPIOA gpio: sifive: Use generic reg read function gpio: dw: Fix warnings about casting int to pointer gpio: dw: Add a trailing underscore to generated name gpio: dw: Return output value when direction is out led: gpio: Default to using node name if label is absent riscv: Add pinmux and gpio bindings for Kendryte K210 riscv: Add FPIOA and GPIO support for Kendryte K210
MAINTAINERS | 2 + arch/riscv/dts/k210-maix-bit.dts | 104 +++ arch/riscv/dts/k210.dtsi | 12 + arch/sandbox/dts/test.dts | 45 +- board/sipeed/maix/Kconfig | 9 + doc/board/sipeed/maix.rst | 64 +- .../pinctrl/kendryte,k210-fpioa.txt | 102 +++ .../pinctrl/pinctrl-bindings.txt | 65 +- drivers/gpio/dwapb_gpio.c | 33 +- drivers/gpio/sifive-gpio.c | 2 +- drivers/led/led_gpio.c | 7 +- drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/kendryte/Kconfig | 7 + drivers/pinctrl/kendryte/Makefile | 1 + drivers/pinctrl/kendryte/pinctrl.c | 678 ++++++++++++++++++ drivers/pinctrl/kendryte/pinctrl.h | 70 ++ drivers/pinctrl/pinctrl-generic.c | 125 +++- drivers/pinctrl/pinctrl-sandbox.c | 155 +++- include/dm/pinctrl.h | 21 +- include/dt-bindings/pinctrl/k210-pinctrl.h | 277 +++++++ include/dt-bindings/pinctrl/sandbox-pinmux.h | 19 + test/dm/Makefile | 3 + test/py/tests/test_pinmux.py | 36 +- 24 files changed, 1717 insertions(+), 122 deletions(-) create mode 100644 doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt create mode 100644 drivers/pinctrl/kendryte/Kconfig create mode 100644 drivers/pinctrl/kendryte/Makefile create mode 100644 drivers/pinctrl/kendryte/pinctrl.c create mode 100644 drivers/pinctrl/kendryte/pinctrl.h create mode 100644 include/dt-bindings/pinctrl/k210-pinctrl.h create mode 100644 include/dt-bindings/pinctrl/sandbox-pinmux.h
The pinmux property allows for smaller and more compact device trees, especially when there are many pins which need to be assigned individually. Instead of specifying an array of strings to be parsed as pins and a function property, the pinmux property contains an array of integers representing pinmux groups. A pinmux group consists of the pin identifier and mux settings represented as a single integer or an array of integers. Each individual pin controller driver specifies the exact format of a pinmux group. As specified in the Linux documentation, a pinmux group may be multiple integers long. However, no existing drivers use multi-integer pinmux groups, so I have chosen to omit this feature. This makes the implementation easier, since there is no need to allocate a buffer to do endian conversions.
Support for the pinmux property is done differently than in Linux. As far as I can tell, inversion of control is used when implementing support for the pins and groups properties to avoid allocating. This results in some duplication of effort; every property in a config node is parsed once for each pin in that node. This is not such an overhead with pins and groups properties, since having multiple pins in one config node does not occur especially often. However, the semantics of the pinmux property make such a configuration much more appealing. A future patch could parse all config properties at once and store them in an array. This would make it easier to create drivers which do not function solely as callbacks from pinctrl-generic.
This commit increases the size of the sandbox build by approximately 48 bytes. However, it also decreases the size of the K210 device tree by 2 KiB from the previous version of this series.
The documentation has been updated from the last Linux commit before it was split off into yaml files.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
(no changes since v2)
Changes in v2: - New
.../pinctrl/pinctrl-bindings.txt | 65 ++++++++- drivers/pinctrl/pinctrl-generic.c | 125 ++++++++++++++---- include/dm/pinctrl.h | 21 +-- 3 files changed, 168 insertions(+), 43 deletions(-)
diff --git a/doc/device-tree-bindings/pinctrl/pinctrl-bindings.txt b/doc/device-tree-bindings/pinctrl/pinctrl-bindings.txt index b73c96d24f..603796f169 100644 --- a/doc/device-tree-bindings/pinctrl/pinctrl-bindings.txt +++ b/doc/device-tree-bindings/pinctrl/pinctrl-bindings.txt @@ -119,7 +119,8 @@ For example:
The contents of each of those pin configuration child nodes is defined entirely by the binding for the individual pin controller device. There -exists no common standard for this content. +exists no common standard for this content. The pinctrl framework only +provides generic helper bindings that the pin controller driver can use.
The pin configuration nodes need not be direct children of the pin controller device; they may be grandchildren, for example. Whether this is legal, and @@ -156,6 +157,29 @@ state_2_node_a { pins = "mfio29", "mfio30"; };
+For hardware where pin multiplexing configurations have to be specified for +each single pin the number of required sub-nodes containing "pin" and +"function" properties can quickly escalate and become hard to write and +maintain. + +For cases like this, the pin controller driver may use the pinmux helper +property, where the pin identifier is provided with mux configuration settings +in a pinmux group. A pinmux group consists of the pin identifier and mux +settings represented as a single integer or an array of integers. + +The pinmux property accepts an array of pinmux groups, each of them describing +a single pin multiplexing configuration. + +pincontroller { + state_0_node_a { + pinmux = <PINMUX_GROUP>, <PINMUX_GROUP>, ...; + }; +}; + +Each individual pin controller driver bindings documentation shall specify +how pin IDs and pin multiplexing configuration are defined and assembled +together in a pinmux group. + == Generic pin configuration node content ==
Many data items that are represented in a pin configuration node are common @@ -168,12 +192,15 @@ structure of the DT nodes that contain these properties. Supported generic properties are:
pins - the list of pins that properties in the node - apply to (either this or "group" has to be + apply to (either this, "group" or "pinmux" has to be specified) group - the group to apply the properties to, if the driver supports configuration of whole groups rather than - individual pins (either this or "pins" has to be - specified) + individual pins (either this, "pins" or "pinmux" has + to be specified) +pinmux - the list of numeric pin ids and their mux settings + that properties in the node apply to (either this, + "pins" or "groups" have to be specified) bias-disable - disable any pin bias bias-high-impedance - high impedance mode ("third-state", "floating") bias-bus-hold - latch weakly @@ -184,17 +211,30 @@ drive-push-pull - drive actively high and low drive-open-drain - drive with open drain drive-open-source - drive with open source drive-strength - sink or source at most X mA -input-enable - enable input on pin (no effect on output) -input-disable - disable input on pin (no effect on output) +drive-strength-microamp - sink or source at most X uA +input-enable - enable input on pin (no effect on output, such as + enabling an input buffer) +input-disable - disable input on pin (no effect on output, such as + disabling an input buffer) input-schmitt-enable - enable schmitt-trigger mode input-schmitt-disable - disable schmitt-trigger mode input-debounce - debounce mode with debound time X power-source - select between different power supplies low-power-enable - enable low power mode low-power-disable - disable low power mode +output-disable - disable output on a pin (such as disable an output + buffer) +output-enable - enable output on a pin without actively driving it + (such as enabling an output buffer) output-low - set the pin to output mode with low level output-high - set the pin to output mode with high level +sleep-hardware-state - indicate this is sleep related state which will be programmed + into the registers for the sleep state. slew-rate - set the slew rate +skew-delay - this affects the expected clock skew on input pins + and the delay before latching a value to an output + pin. Typically indicates how many double-inverters are + used to delay the signal.
For example:
@@ -216,6 +256,12 @@ state_2_node_a { bias-pull-up; }; }; +state_3_node_a { + mux { + pinmux = <GPIOx_PINm_MUXn>, <GPIOx_PINj_MUXk)>; + input-enable; + }; +};
Some of the generic properties take arguments. For those that do, the arguments are described below. @@ -224,11 +270,18 @@ arguments are described below. binding for the hardware defines: - Whether the entries are integers or strings, and their meaning.
+- pinmux takes a list of pin IDs and mux settings as required argument. The + specific bindings for the hardware defines: + - How pin IDs and mux settings are defined and assembled together in a single + integer or an array of integers. + - bias-pull-up, -down and -pin-default take as optional argument on hardware supporting it the pull strength in Ohm. bias-disable will disable the pull.
- drive-strength takes as argument the target strength in mA.
+- drive-strength-microamp takes as argument the target strength in uA. + - input-debounce takes the debounce time in usec as argument or 0 to disable debouncing
diff --git a/drivers/pinctrl/pinctrl-generic.c b/drivers/pinctrl/pinctrl-generic.c index 313aeccb1e..3c8e24088c 100644 --- a/drivers/pinctrl/pinctrl-generic.c +++ b/drivers/pinctrl/pinctrl-generic.c @@ -227,6 +227,13 @@ static int pinconf_enable_setting(struct udevice *dev, bool is_group, } #endif
+enum pinmux_subnode_type { + PST_NONE = 0, + PST_PIN, + PST_GROUP, + PST_PINMUX, +}; + /** * pinctrl_generic_set_state_one() - set state for a certain pin/group * Apply all pin multiplexing and pin configurations specified by @config @@ -234,13 +241,15 @@ static int pinconf_enable_setting(struct udevice *dev, bool is_group, * * @dev: pin controller device * @config: pseudo device pointing to config node - * @is_group: target of operation (true: pin group, false: pin) - * @selector: pin selector or group selector, depending on @is_group + * @subnode_type: target of operation (pin, group, or pin specified by a pinmux + * group) + * @selector: pin selector or group selector, depending on @subnode_type * @return: 0 on success, or negative error code on failure */ static int pinctrl_generic_set_state_one(struct udevice *dev, struct udevice *config, - bool is_group, unsigned selector) + enum pinmux_subnode_type subnode_type, + unsigned selector) { const char *propname; const void *value; @@ -248,17 +257,22 @@ static int pinctrl_generic_set_state_one(struct udevice *dev, int len, func_selector, param, ret; u32 arg, default_val;
+ assert(subnode_type != PST_NONE); + dev_for_each_property(property, config) { value = dev_read_prop_by_prop(&property, &propname, &len); if (!value) return -EINVAL;
- if (!strcmp(propname, "function")) { + /* pinmux subnodes already have their muxing set */ + if (subnode_type != PST_PINMUX && + !strcmp(propname, "function")) { func_selector = pinmux_func_name_to_selector(dev, value); if (func_selector < 0) return func_selector; - ret = pinmux_enable_setting(dev, is_group, + ret = pinmux_enable_setting(dev, + subnode_type == PST_GROUP, selector, func_selector); } else { @@ -272,7 +286,8 @@ static int pinctrl_generic_set_state_one(struct udevice *dev, else arg = default_val;
- ret = pinconf_enable_setting(dev, is_group, + ret = pinconf_enable_setting(dev, + subnode_type == PST_GROUP, selector, param, arg); }
@@ -283,6 +298,41 @@ static int pinctrl_generic_set_state_one(struct udevice *dev, return 0; }
+/** + * pinctrl_generic_get_subnode_type() - determine whether there is a valid + * pins, groups, or pinmux property in the config node + * + * @dev: pin controller device + * @config: pseudo device pointing to config node + * @count: number of specifiers contained within the property + * @return: the type of the subnode, or PST_NONE + */ +static enum pinmux_subnode_type pinctrl_generic_get_subnode_type(struct udevice *dev, + struct udevice *config, + int *count) +{ + const struct pinctrl_ops *ops = pinctrl_get_ops(dev); + + *count = dev_read_string_count(config, "pins"); + if (*count >= 0) + return PST_PIN; + + *count = dev_read_string_count(config, "groups"); + if (*count >= 0) + return PST_GROUP; + + if (ops->pinmux_property_set) { + *count = dev_read_size(config, "pinmux"); + if (*count >= 0 && !(*count % sizeof(u32))) { + *count /= sizeof(u32); + return PST_PINMUX; + } + } + + *count = 0; + return PST_NONE; +} + /** * pinctrl_generic_set_state_subnode() - apply all settings in config node * @@ -293,38 +343,55 @@ static int pinctrl_generic_set_state_one(struct udevice *dev, static int pinctrl_generic_set_state_subnode(struct udevice *dev, struct udevice *config) { - const char *subnode_target_type = "pins"; - bool is_group = false; + enum pinmux_subnode_type subnode_type; const char *name; - int strings_count, selector, i, ret; + int count, selector, i, ret, scratch; + const u32 *pinmux_groups = NULL; /* prevent use-uninitialized warning */
- strings_count = dev_read_string_count(config, subnode_target_type); - if (strings_count < 0) { - subnode_target_type = "groups"; - is_group = true; - strings_count = dev_read_string_count(config, - subnode_target_type); - if (strings_count < 0) { + subnode_type = pinctrl_generic_get_subnode_type(dev, config, &count); + + debug("%s(%s, %s): count=%d\n", __func__, dev->name, config->name, + count); + + if (subnode_type == PST_PINMUX) { + pinmux_groups = dev_read_prop(config, "pinmux", &scratch); + if (!pinmux_groups) + return -EINVAL; + } + + for (i = 0; i < count; i++) { + switch (subnode_type) { + case PST_PIN: + ret = dev_read_string_index(config, "pins", i, &name); + if (ret) + return ret; + selector = pinctrl_pin_name_to_selector(dev, name); + break; + case PST_GROUP: + ret = dev_read_string_index(config, "groups", i, &name); + if (ret) + return ret; + selector = pinctrl_group_name_to_selector(dev, name); + break; + case PST_PINMUX: { + const struct pinctrl_ops *ops = pinctrl_get_ops(dev); + u32 pinmux_group = fdt32_to_cpu(pinmux_groups[i]); + + /* Checked for in pinctrl_generic_get_subnode_type */ + selector = ops->pinmux_property_set(dev, pinmux_group); + break; + } + case PST_NONE: + default: /* skip this node; may contain config child nodes */ return 0; } - }
- for (i = 0; i < strings_count; i++) { - ret = dev_read_string_index(config, subnode_target_type, i, - &name); - if (ret) - return ret; - - if (is_group) - selector = pinctrl_group_name_to_selector(dev, name); - else - selector = pinctrl_pin_name_to_selector(dev, name); if (selector < 0) return selector;
- ret = pinctrl_generic_set_state_one(dev, config, - is_group, selector); + ret = pinctrl_generic_set_state_one(dev, config, subnode_type, + selector); if (ret) return ret; } diff --git a/include/dm/pinctrl.h b/include/dm/pinctrl.h index 692e5fc8cb..d50af1ce38 100644 --- a/include/dm/pinctrl.h +++ b/include/dm/pinctrl.h @@ -34,29 +34,33 @@ struct pinconf_param { * depending on your necessity. * * @get_pins_count: return number of selectable named pins available - * in this driver. (necessary to parse "pins" property in DTS) + * in this driver. (necessary to parse "pins" property in DTS) * @get_pin_name: return the pin name of the pin selector, * called by the core to figure out which pin it shall do - * operations to. (necessary to parse "pins" property in DTS) + * operations to. (necessary to parse "pins" property in DTS) * @get_groups_count: return number of selectable named groups available - * in this driver. (necessary to parse "groups" property in DTS) + * in this driver. (necessary to parse "groups" property in DTS) * @get_group_name: return the group name of the group selector, * called by the core to figure out which pin group it shall do - * operations to. (necessary to parse "groups" property in DTS) + * operations to. (necessary to parse "groups" property in DTS) * @get_functions_count: return number of selectable named functions available - * in this driver. (necessary for pin-muxing) + * in this driver. (necessary for pin-muxing) * @get_function_name: return the function name of the muxing selector, * called by the core to figure out which mux setting it shall map a - * certain device to. (necessary for pin-muxing) + * certain device to. (necessary for pin-muxing) * @pinmux_set: enable a certain muxing function with a certain pin. * The @func_selector selects a certain function whereas @pin_selector * selects a certain pin to be used. On simple controllers one of them - * may be ignored. (necessary for pin-muxing against a single pin) + * may be ignored. (necessary for pin-muxing against a single pin) * @pinmux_group_set: enable a certain muxing function with a certain pin - * group. The @func_selector selects a certain function whereas + * group. The @func_selector selects a certain function whereas * @group_selector selects a certain set of pins to be used. On simple * controllers one of them may be ignored. * (necessary for pin-muxing against a pin group) + * @pinmux_property_set: enable a pinmux group. @pinmux_group should specify the + * pin identifier and mux settings. The exact format of a pinmux group is + * left up to the driver. The pin selector for the mux-ed pin should be + * returned on success. (necessary to parse the "pinmux" property in DTS) * @pinconf_num_params: number of driver-specific parameters to be parsed * from device trees (necessary for pin-configuration) * @pinconf_params: list of driver_specific parameters to be parsed from @@ -90,6 +94,7 @@ struct pinctrl_ops { unsigned func_selector); int (*pinmux_group_set)(struct udevice *dev, unsigned group_selector, unsigned func_selector); + int (*pinmux_property_set)(struct udevice *dev, u32 pinmux_group); unsigned int pinconf_num_params; const struct pinconf_param *pinconf_params; int (*pinconf_set)(struct udevice *dev, unsigned pin_selector,
This extends the pinctrl-sandbox driver to support pin muxing, and adds a test for that behaviour. The test is done in C and not python (like the existing tests for the pinctrl uclass) because it needs to call pinctrl_select_state. Another option could be to add a command that invokes pinctrl_select_state and then test everything in test/py/tests/test_pinmux.py.
The pinctrl-sandbox driver now mimics the way that many pinmux devices work. There are two groups of pins which are muxed together, as well as four pins which are muxed individually. I have tried to test all normal paths. However, very few error cases are explicitly checked for.
arch/sandbox/dts/test.dts | 45 +++++- drivers/pinctrl/pinctrl-sandbox.c | 155 ++++++++++++++----- include/dt-bindings/pinctrl/sandbox-pinmux.h | 19 +++ test/dm/Makefile | 3 + test/py/tests/test_pinmux.py | 36 ++--- 5 files changed, 197 insertions(+), 61 deletions(-) create mode 100644 include/dt-bindings/pinctrl/sandbox-pinmux.h
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index f5b685f7fe..36736f374d 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -2,6 +2,7 @@
#include <dt-bindings/gpio/gpio.h> #include <dt-bindings/gpio/sandbox-gpio.h> +#include <dt-bindings/pinctrl/sandbox-pinmux.h>
/ { model = "sandbox"; @@ -967,30 +968,60 @@ pinctrl { compatible = "sandbox,pinctrl";
- pinctrl-names = "default"; - pinctrl-0 = <&gpios>; + pinctrl-names = "default", "alternate"; + pinctrl-0 = <&pinctrl_gpios>, <&pinctrl_i2s>; + pinctrl-1 = <&pinctrl_spi>, <&pinctrl_i2c>;
- gpios: gpios { + pinctrl_gpios: gpios { gpio0 { - pins = "GPIO0"; + pins = "P5"; + function = "GPIO"; bias-pull-up; input-disable; }; gpio1 { - pins = "GPIO1"; + pins = "P6"; + function = "GPIO"; output-high; drive-open-drain; }; gpio2 { - pins = "GPIO2"; + pinmux = <SANDBOX_PINMUX(7, SANDBOX_PINMUX_GPIO)>; bias-pull-down; input-enable; }; gpio3 { - pins = "GPIO3"; + pinmux = <SANDBOX_PINMUX(8, SANDBOX_PINMUX_GPIO)>; bias-disable; }; }; + + pinctrl_i2c: i2c { + groups { + groups = "I2C_UART"; + function = "I2C"; + }; + + pins { + pins = "P0", "P1"; + drive-open-drain; + }; + }; + + pinctrl_i2s: i2s { + groups = "SPI_I2S"; + function = "I2S"; + }; + + pinctrl_spi: spi { + groups = "SPI_I2S"; + function = "SPI"; + + cs { + pinmux = <SANDBOX_PINMUX(5, SANDBOX_PINMUX_CS)>, + <SANDBOX_PINMUX(6, SANDBOX_PINMUX_CS)>; + }; + }; };
hwspinlock@0 { diff --git a/drivers/pinctrl/pinctrl-sandbox.c b/drivers/pinctrl/pinctrl-sandbox.c index ac0119d198..9aa13fbd55 100644 --- a/drivers/pinctrl/pinctrl-sandbox.c +++ b/drivers/pinctrl/pinctrl-sandbox.c @@ -3,55 +3,67 @@ * Copyright (C) 2015 Masahiro Yamada yamada.masahiro@socionext.com */
-/* #define DEBUG */ - #include <common.h> #include <dm.h> -#include <log.h> #include <dm/pinctrl.h> +#include <dt-bindings/pinctrl/sandbox-pinmux.h> +#include <log.h> #include <linux/bitops.h>
+/* + * This driver emulates a pin controller with the following rules: + * - The pinctrl config for each pin must be set individually + * - The first three pins (P0-P2) must be muxed as a group + * - The next two pins (P3-P4) must be muxed as a group + * - The last four pins (P5-P8) must be muxed individually + */ + static const char * const sandbox_pins[] = { - "SCL", - "SDA", - "TX", - "RX", - "W1", - "GPIO0", - "GPIO1", - "GPIO2", - "GPIO3", +#define PIN(x) \ + [x] = "P" #x + PIN(0), + PIN(1), + PIN(2), + PIN(3), + PIN(4), + PIN(5), + PIN(6), + PIN(7), + PIN(8), +#undef PIN };
-static const char * const sandbox_pins_muxing[] = { - "I2C SCL", - "I2C SDA", - "Uart TX", - "Uart RX", - "1-wire gpio", - "gpio", - "gpio", - "gpio", - "gpio", +static const char * const sandbox_pins_muxing[][2] = { + { "UART TX", "I2C SCL" }, + { "UART RX", "I2C SDA" }, + { "SPI SCLK", "I2S SCK" }, + { "SPI MOSI", "I2S SD" }, + { "SPI MISO", "I2S WS" }, + { "GPIO0", "SPI CS0" }, + { "GPIO1", "SPI CS1" }, + { "GPIO2", "PWM0" }, + { "GPIO3", "PWM1" }, };
+#define SANDBOX_GROUP_I2C_UART 0 +#define SANDBOX_GROUP_SPI_I2S 1 + static const char * const sandbox_groups[] = { - "i2c", - "serial_a", - "serial_b", - "spi", - "w1", + [SANDBOX_GROUP_I2C_UART] = "I2C_UART", + [SANDBOX_GROUP_SPI_I2S] = "SPI_I2S", };
static const char * const sandbox_functions[] = { - "i2c", - "serial", - "spi", - "w1", - "gpio", - "gpio", - "gpio", - "gpio", +#define FUNC(id) \ + [SANDBOX_PINMUX_##id] = #id + FUNC(UART), + FUNC(I2C), + FUNC(SPI), + FUNC(I2S), + FUNC(GPIO), + FUNC(CS), + FUNC(PWM), +#undef FUNC };
static const struct pinconf_param sandbox_conf_params[] = { @@ -69,6 +81,7 @@ static const struct pinconf_param sandbox_conf_params[] = { };
/* bitfield used to save param and value of each pin/selector */ +static unsigned int sandbox_mux; static unsigned int sandbox_pins_param[ARRAY_SIZE(sandbox_pins)]; static unsigned int sandbox_pins_value[ARRAY_SIZE(sandbox_pins)];
@@ -89,7 +102,8 @@ static int sandbox_get_pin_muxing(struct udevice *dev, const struct pinconf_param *p; int i;
- snprintf(buf, size, "%s", sandbox_pins_muxing[selector]); + snprintf(buf, size, "%s", + sandbox_pins_muxing[selector][!!(priv->mux & BIT(selector))]);
if (sandbox_pins_param[selector]) { for (i = 0, p = sandbox_conf_params; @@ -133,10 +147,30 @@ static const char *sandbox_get_function_name(struct udevice *dev, static int sandbox_pinmux_set(struct udevice *dev, unsigned pin_selector, unsigned func_selector) { + int mux; + struct sandbox_pinctrl_priv *priv = dev_get_priv(dev); + debug("sandbox pinmux: pin = %d (%s), function = %d (%s)\n", pin_selector, sandbox_get_pin_name(dev, pin_selector), func_selector, sandbox_get_function_name(dev, func_selector));
+ if (pin_selector < 5) + return -EINVAL; + + switch (func_selector) { + case SANDBOX_PINMUX_GPIO: + mux = 0; + break; + case SANDBOX_PINMUX_CS: + case SANDBOX_PINMUX_PWM: + mux = BIT(pin_selector); + break; + default: + return -EINVAL; + } + + sandbox_mux &= ~BIT(pin_selector); + sandbox_mux |= mux; sandbox_pins_param[pin_selector] = 0; sandbox_pins_value[pin_selector] = 0;
@@ -147,13 +181,61 @@ static int sandbox_pinmux_group_set(struct udevice *dev, unsigned group_selector, unsigned func_selector) { + bool mux; + int i, group_start, group_end; + struct sandbox_pinctrl_priv *priv = dev_get_priv(dev); + unsigned int mask; + debug("sandbox pinmux: group = %d (%s), function = %d (%s)\n", group_selector, sandbox_get_group_name(dev, group_selector), func_selector, sandbox_get_function_name(dev, func_selector));
+ if (group_selector == SANDBOX_GROUP_I2C_UART) { + group_start = 0; + group_end = 1; + + if (func_selector == SANDBOX_PINMUX_UART) + mux = false; + else if (func_selector == SANDBOX_PINMUX_I2C) + mux = true; + else + return -EINVAL; + } else if (group_selector == SANDBOX_GROUP_SPI_I2S) { + group_start = 2; + group_end = 4; + + if (func_selector == SANDBOX_PINMUX_SPI) + mux = false; + else if (func_selector == SANDBOX_PINMUX_I2S) + mux = true; + else + return -EINVAL; + } else { + return -EINVAL; + } + + mask = GENMASK(group_end, group_start); + priv->mux &= ~mask; + priv->mux |= mux ? mask : 0; + + for (i = group_start; i < group_end; i++) { + priv->param[i] = 0; + priv->value[i] = 0; + } + return 0; }
+static int sandbox_pinmux_property_set(struct udevice *dev, u32 pinmux_group) +{ + int ret; + unsigned pin_selector = pinmux_group & 0xFFFF; + unsigned func_selector = pinmux_group >> 16; + + ret = sandbox_pinmux_set(dev, pin_selector, func_selector); + return ret ? ret : pin_selector; +} + static int sandbox_pinconf_set(struct udevice *dev, unsigned pin_selector, unsigned param, unsigned argument) { @@ -191,6 +273,7 @@ const struct pinctrl_ops sandbox_pinctrl_ops = { .get_function_name = sandbox_get_function_name, .pinmux_set = sandbox_pinmux_set, .pinmux_group_set = sandbox_pinmux_group_set, + .pinmux_property_set = sandbox_pinmux_property_set, .pinconf_num_params = ARRAY_SIZE(sandbox_conf_params), .pinconf_params = sandbox_conf_params, .pinconf_set = sandbox_pinconf_set, diff --git a/include/dt-bindings/pinctrl/sandbox-pinmux.h b/include/dt-bindings/pinctrl/sandbox-pinmux.h new file mode 100644 index 0000000000..891af072e5 --- /dev/null +++ b/include/dt-bindings/pinctrl/sandbox-pinmux.h @@ -0,0 +1,19 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#ifndef SANDBOX_PINMUX_H +#define SANDBOX_PINMUX_H + +#define SANDBOX_PINMUX_UART 0 +#define SANDBOX_PINMUX_I2C 1 +#define SANDBOX_PINMUX_SPI 2 +#define SANDBOX_PINMUX_I2S 3 +#define SANDBOX_PINMUX_GPIO 4 +#define SANDBOX_PINMUX_CS 5 +#define SANDBOX_PINMUX_PWM 6 + +#define SANDBOX_PINMUX(pin, func) ((func) << 16 | (pin)) + +#endif /* SANDBOX_PINMUX_H */ diff --git a/test/dm/Makefile b/test/dm/Makefile index 0d1c66fa1e..9e273ee02d 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -76,4 +76,7 @@ obj-$(CONFIG_DM_RNG) += rng.o obj-$(CONFIG_CLK_K210_SET_RATE) += k210_pll.o obj-$(CONFIG_SIMPLE_PM_BUS) += simple-pm-bus.o obj-$(CONFIG_RESET_SYSCON) += syscon-reset.o +ifneq ($(CONFIG_PINMUX),) +obj-$(CONFIG_PINCONF) += pinmux.o +endif endif diff --git a/test/py/tests/test_pinmux.py b/test/py/tests/test_pinmux.py index 4e6df992a4..0cbbae000c 100644 --- a/test/py/tests/test_pinmux.py +++ b/test/py/tests/test_pinmux.py @@ -28,15 +28,15 @@ def test_pinmux_status_all(u_boot_console): assert ('a6 : gpio output .' in output)
assert ('pinctrl:' in output) - assert ('SCL : I2C SCL.' in output) - assert ('SDA : I2C SDA.' in output) - assert ('TX : Uart TX.' in output) - assert ('RX : Uart RX.' in output) - assert ('W1 : 1-wire gpio.' in output) - assert ('GPIO0 : gpio bias-pull-up input-disable.' in output) - assert ('GPIO1 : gpio drive-open-drain.' in output) - assert ('GPIO2 : gpio bias-pull-down input-enable.' in output) - assert ('GPIO3 : gpio bias-disable.' in output) + assert ('P0 : UART TX.' in output) + assert ('P1 : UART RX.' in output) + assert ('P2 : I2S SCK.' in output) + assert ('P3 : I2S SD.' in output) + assert ('P4 : I2S WS.' in output) + assert ('P5 : GPIO0 bias-pull-up input-disable.' in output) + assert ('P6 : GPIO1 drive-open-drain.' in output) + assert ('P7 : GPIO2 bias-pull-down input-enable.' in output) + assert ('P8 : GPIO3 bias-disable.' in output)
@pytest.mark.buildconfigspec('cmd_pinmux') @pytest.mark.boardspec('sandbox') @@ -73,12 +73,12 @@ def test_pinmux_status(u_boot_console): assert (not 'pinctrl-gpio:' in output) assert (not 'pinctrl:' in output)
The Fully-Programmable Input/Output Array (FPIOA) device controls pin multiplexing on the K210. The FPIOA can remap any supported function to any multifunctional IO pin. It can also perform basic GPIO functions, such as reading the current value of a pin. However, GPIO functionality remains largely unimplemented (in favor of the dedicated GPIO peripherals).
Signed-off-by: Sean Anderson seanga2@gmail.com --- This patch was previously submitted as part of https://patchwork.ozlabs.org/project/uboot/list/?series=161576
Changes from that version include: - Reformat to reduce errors from checkpatch
Changes in v2: - Don't clear existing pinctrl settings on probe - Rewrite to use pinmux property - Support muxing the output enable signal for each function - Support output and input inversion - Update binding documentation
MAINTAINERS | 2 + .../pinctrl/kendryte,k210-fpioa.txt | 102 +++ drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/kendryte/Kconfig | 7 + drivers/pinctrl/kendryte/Makefile | 1 + drivers/pinctrl/kendryte/pinctrl.c | 678 ++++++++++++++++++ drivers/pinctrl/kendryte/pinctrl.h | 70 ++ include/dt-bindings/pinctrl/k210-pinctrl.h | 277 +++++++ 9 files changed, 1139 insertions(+) create mode 100644 doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt create mode 100644 drivers/pinctrl/kendryte/Kconfig create mode 100644 drivers/pinctrl/kendryte/Makefile create mode 100644 drivers/pinctrl/kendryte/pinctrl.c create mode 100644 drivers/pinctrl/kendryte/pinctrl.h create mode 100644 include/dt-bindings/pinctrl/k210-pinctrl.h
diff --git a/MAINTAINERS b/MAINTAINERS index 2b58cf7d94..e0bae4f199 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -876,7 +876,9 @@ RISC-V KENDRYTE M: Sean Anderson seanga2@gmail.com S: Maintained F: doc/device-tree-bindings/mfd/kendryte,k210-sysctl.txt +F: doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt F: drivers/clk/kendryte/ +F: drivers/pinctrl/kendryte/ F: include/kendryte/
RNG diff --git a/doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt b/doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt new file mode 100644 index 0000000000..06a9cc060f --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/kendryte,k210-fpioa.txt @@ -0,0 +1,102 @@ +Kendryte K210 FPIOA + +This binding describes the Fully-Programmable Input/Output Array (FPIOA) found +in Kendryte K210 SoCs. Any of the 256 functions can be mapped to any of the 48 +pins. + +Required properties: +- compatible: should be "kendryte,k210-fpioa" +- reg: address and length of the FPIOA registers +- kendryte,sysctl: phandle to the "sysctl" register map node +- kendryte,power-offset: offset in the register map of the power bank control + register (in bytes) + +Configuration nodes + +Pin configuration nodes are documented in pinctrl-bindings.txt + +Required properties for pin-configuration nodes or sub-nodes are: +- groups: list of power groups to which the configuration applies. Valid groups + are: + A0, A1, A2, B0, B1, B2, C0, C1 + (either this or "pinmux" must be specified) +- pinmux: integer array representing pin multiplexing configuration. In addition + to the 256 standard functions, each pin can also output the direction + indicator (DO) of any function. This signal is high whenever the function + would normally drive the output. Helper macros to ease assembling the "pinmux" + arguments from the pin and function are provided by the FPIOA header file at: + <dt-bindings/pinctrl/k210-pinctrl.h> + Integer values in the "pinmux" argument list are assembled as: + ((PIN << 16) | (DO << 8) | (FUNC)) + Valid values for PIN are numbers 0 through 47. + Valid values for DO are 0 or 1. + Valid values for FUNC are numbers 0 through 255. For a complete list of + acceptable functions, consult the FPIOA header file. + (either this or "groups" must be specified) + +Optional properties for "pinmux" nodes are: + bias-disable, bias-pull-down, bias-pull-up, drive-strength, + drive-strength-ua, input-enable, input-disable, input-schmitt-enable, + input-schmitt-disable, output-low, output-high, output-enable, + output-disable, slew-rate, output-polarity-invert, input-polarity-invert + +Optional properties for "groups" nodes are: + power-source + +Notes on specific properties include: +- bias-pull-up, -down, and -pin-default: The pull strength cannot be configured. +- drive-strength: There are 8 drive strength settings between 11 and 50 mA. +- input- and output-polarity-invert: Invert the polarity of either the input or + the output, respectively. +- power-source: Controls the output voltage of a bank of pins. Either + K210_PC_POWER_1V8 or K210_PC_POWER_3V3 may be specified. +- slew-rate: Specifying this property reduces the slew rate. + +Example: +fpioa: pinmux@502B0000 { + compatible = "kendryte,k210-fpioa"; + reg = <0x502B0000 0x100>; + kendryte,sysctl = <&sysctl>; + kendryte,power-offset = <K210_SYSCTL_POWER_SEL>; + + /* JTAG running at 3.3V and driven at 11 mA */ + fpioa_jtag: jtag { + voltage { + group = "A0"; + power-source = <K210_PC_POWER_3V3>; + }; + + jtag { + pinmux = <K210_FPIOA(0, K210_PCF_JTAG_TCK)>, + <K210_FPIOA(1, K210_PCF_JTAG_TDI)>, + <K210_FPIOA(2, K210_PCF_JTAG_TMS)>, + <K210_FPIOA(3, K210_PCF_JTAG_TDO)>; + drive-strength = <11>; + } + }; + + /* I2C configured for use with a TCA9800 level shifter */ + fpioa_i2c: i2c { + i2c { + pinmux = <K210_FPIOA(6, K210_PCF_I2C0_SCLK)>, + <K210_FPIOA(7, K210_PCF_I2C0_SDA)>; + }; + + direction { + pinmux = <K210_FPIOA_DO(8, K210_PCF_I2C0_SDA)>; + output-polarity-invert; + }; + }; + + /* UART with an active-high TX status LED */ + fpioa_uart1: uart1 { + uart { + pinmux = <K210_FPIOA(9, K210_PCF_UART1_TX)>, + <K210_FPIOA(10, K210_PCF_UART1_RX)>; + }; + + status { + pinmux = <K210_FPIOA_DO(11, K210_PCF_UART1_TX)>; + }; + }; +}; diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 83e39b9de3..9ec56c7735 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -289,6 +289,7 @@ endif source "drivers/pinctrl/broadcom/Kconfig" source "drivers/pinctrl/exynos/Kconfig" source "drivers/pinctrl/intel/Kconfig" +source "drivers/pinctrl/kendryte/Kconfig" source "drivers/pinctrl/mediatek/Kconfig" source "drivers/pinctrl/meson/Kconfig" source "drivers/pinctrl/mscc/Kconfig" diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 4f662c4f6d..1fe66fed3c 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -17,6 +17,7 @@ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o obj-$(CONFIG_PINCTRL_UNIPHIER) += uniphier/ obj-$(CONFIG_PINCTRL_PIC32) += pinctrl_pic32.o obj-$(CONFIG_PINCTRL_EXYNOS) += exynos/ +obj-$(CONFIG_PINCTRL_K210) += kendryte/ obj-$(CONFIG_PINCTRL_MESON) += meson/ obj-$(CONFIG_PINCTRL_MTK) += mediatek/ obj-$(CONFIG_PINCTRL_MSCC) += mscc/ diff --git a/drivers/pinctrl/kendryte/Kconfig b/drivers/pinctrl/kendryte/Kconfig new file mode 100644 index 0000000000..6fc10e9516 --- /dev/null +++ b/drivers/pinctrl/kendryte/Kconfig @@ -0,0 +1,7 @@ +config PINCTRL_K210 + bool "Kendryte K210 Fully-Programmable Input/Output Array driver" + depends on DM && PINCTRL_GENERIC + help + Support pin multiplexing on the K210. The "FPIOA" can remap any + supported function to any multifunctional IO pin. It can also perform + basic GPIO functions, such as reading the current value of a pin. diff --git a/drivers/pinctrl/kendryte/Makefile b/drivers/pinctrl/kendryte/Makefile new file mode 100644 index 0000000000..1c10d7a929 --- /dev/null +++ b/drivers/pinctrl/kendryte/Makefile @@ -0,0 +1 @@ +obj-y += pinctrl.o diff --git a/drivers/pinctrl/kendryte/pinctrl.c b/drivers/pinctrl/kendryte/pinctrl.c new file mode 100644 index 0000000000..75c1dd3d02 --- /dev/null +++ b/drivers/pinctrl/kendryte/pinctrl.c @@ -0,0 +1,678 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#include <common.h> +#include <clk.h> +#include <dm.h> +#include <dt-bindings/pinctrl/k210-pinctrl.h> +#include <mapmem.h> +#include <regmap.h> +#include <syscon.h> +#include <asm/io.h> +#include <linux/err.h> +#include <linux/bitfield.h> +#include "pinctrl.h" + +struct k210_pc_priv { + struct clk clk; + struct k210_fpioa __iomem *fpioa; /* FPIOA register */ + struct regmap *sysctl; /* Sysctl regmap */ + u32 power_offset; /* Power bank register offset */ +}; + +#ifdef CONFIG_CMD_PINMUX +static const char k210_pc_pin_names[][6] = { +#define PIN(i) \ + [i] = "IO_" #i + PIN(0), + PIN(1), + PIN(2), + PIN(3), + PIN(4), + PIN(5), + PIN(6), + PIN(7), + PIN(8), + PIN(9), + PIN(10), + PIN(11), + PIN(12), + PIN(13), + PIN(14), + PIN(15), + PIN(16), + PIN(17), + PIN(18), + PIN(19), + PIN(20), + PIN(21), + PIN(22), + PIN(23), + PIN(24), + PIN(25), + PIN(26), + PIN(27), + PIN(28), + PIN(29), + PIN(30), + PIN(31), + PIN(32), + PIN(33), + PIN(34), + PIN(35), + PIN(36), + PIN(37), + PIN(38), + PIN(39), + PIN(40), + PIN(41), + PIN(42), + PIN(43), + PIN(44), + PIN(45), + PIN(46), + PIN(47), +#undef PIN +}; + +static int k210_pc_get_pins_count(struct udevice *dev) +{ + return ARRAY_SIZE(k210_pc_pin_names); +}; + +static const char *k210_pc_get_pin_name(struct udevice *dev, unsigned selector) +{ + return k210_pc_pin_names[selector]; +} +#endif /* CONFIG_CMD_PINMUX */ + +/* These are just power domains */ +static const char k210_pc_group_names[][3] = { + [0] = "A0", + [1] = "A1", + [2] = "A2", + [3] = "B0", + [4] = "B1", + [5] = "B2", + [6] = "C0", + [7] = "C1", +}; + +static int k210_pc_get_groups_count(struct udevice *dev) +{ + return ARRAY_SIZE(k210_pc_group_names); +} + +static const char *k210_pc_get_group_name(struct udevice *dev, + unsigned selector) +{ + return k210_pc_group_names[selector]; +} + +enum k210_pc_mode_id { + K210_PC_DEFAULT_DISABLED, + K210_PC_DEFAULT_IN, + K210_PC_DEFAULT_IN_TIE, + K210_PC_DEFAULT_OUT, + K210_PC_DEFAULT_I2C, + K210_PC_DEFAULT_SPI, + K210_PC_DEFAULT_GPIO, + K210_PC_DEFAULT_INT13, +}; + +static const u32 k210_pc_mode_id_to_mode[] = { +#define DEFAULT(mode) \ + [K210_PC_DEFAULT_##mode] = K210_PC_MODE_##mode + [K210_PC_DEFAULT_DISABLED] = 0, + DEFAULT(IN), + [K210_PC_DEFAULT_IN_TIE] = K210_PC_MODE_IN, + DEFAULT(OUT), + DEFAULT(I2C), + DEFAULT(SPI), + DEFAULT(GPIO), + [K210_PC_DEFAULT_INT13] = K210_PC_MODE_IN | K210_PC_PU, +#undef DEFAULT +}; + +/* This saves around 2K vs having a pointer+mode */ +struct k210_pcf_info { +#ifdef CONFIG_CMD_PINMUX + char name[15]; +#endif + u8 mode_id; +}; + +static const struct k210_pcf_info k210_pcf_infos[] = { +#ifdef CONFIG_CMD_PINMUX +#define FUNC(id, mode) \ + [K210_PCF_##id] = { \ + .name = #id, \ + .mode_id = K210_PC_DEFAULT_##mode \ + } +#else +#define FUNC(id, mode) \ + [K210_PCF_##id] = { \ + .mode_id = K210_PC_DEFAULT_##mode \ + } +#endif + FUNC(JTAG_TCLK, IN), + FUNC(JTAG_TDI, IN), + FUNC(JTAG_TMS, IN), + FUNC(JTAG_TDO, OUT), + FUNC(SPI0_D0, SPI), + FUNC(SPI0_D1, SPI), + FUNC(SPI0_D2, SPI), + FUNC(SPI0_D3, SPI), + FUNC(SPI0_D4, SPI), + FUNC(SPI0_D5, SPI), + FUNC(SPI0_D6, SPI), + FUNC(SPI0_D7, SPI), + FUNC(SPI0_SS0, OUT), + FUNC(SPI0_SS1, OUT), + FUNC(SPI0_SS2, OUT), + FUNC(SPI0_SS3, OUT), + FUNC(SPI0_ARB, IN_TIE), + FUNC(SPI0_SCLK, OUT), + FUNC(UARTHS_RX, IN), + FUNC(UARTHS_TX, OUT), + FUNC(RESV6, IN), + FUNC(RESV7, IN), + FUNC(CLK_SPI1, OUT), + FUNC(CLK_I2C1, OUT), + FUNC(GPIOHS0, GPIO), + FUNC(GPIOHS1, GPIO), + FUNC(GPIOHS2, GPIO), + FUNC(GPIOHS3, GPIO), + FUNC(GPIOHS4, GPIO), + FUNC(GPIOHS5, GPIO), + FUNC(GPIOHS6, GPIO), + FUNC(GPIOHS7, GPIO), + FUNC(GPIOHS8, GPIO), + FUNC(GPIOHS9, GPIO), + FUNC(GPIOHS10, GPIO), + FUNC(GPIOHS11, GPIO), + FUNC(GPIOHS12, GPIO), + FUNC(GPIOHS13, GPIO), + FUNC(GPIOHS14, GPIO), + FUNC(GPIOHS15, GPIO), + FUNC(GPIOHS16, GPIO), + FUNC(GPIOHS17, GPIO), + FUNC(GPIOHS18, GPIO), + FUNC(GPIOHS19, GPIO), + FUNC(GPIOHS20, GPIO), + FUNC(GPIOHS21, GPIO), + FUNC(GPIOHS22, GPIO), + FUNC(GPIOHS23, GPIO), + FUNC(GPIOHS24, GPIO), + FUNC(GPIOHS25, GPIO), + FUNC(GPIOHS26, GPIO), + FUNC(GPIOHS27, GPIO), + FUNC(GPIOHS28, GPIO), + FUNC(GPIOHS29, GPIO), + FUNC(GPIOHS30, GPIO), + FUNC(GPIOHS31, GPIO), + FUNC(GPIO0, GPIO), + FUNC(GPIO1, GPIO), + FUNC(GPIO2, GPIO), + FUNC(GPIO3, GPIO), + FUNC(GPIO4, GPIO), + FUNC(GPIO5, GPIO), + FUNC(GPIO6, GPIO), + FUNC(GPIO7, GPIO), + FUNC(UART1_RX, IN), + FUNC(UART1_TX, OUT), + FUNC(UART2_RX, IN), + FUNC(UART2_TX, OUT), + FUNC(UART3_RX, IN), + FUNC(UART3_TX, OUT), + FUNC(SPI1_D0, SPI), + FUNC(SPI1_D1, SPI), + FUNC(SPI1_D2, SPI), + FUNC(SPI1_D3, SPI), + FUNC(SPI1_D4, SPI), + FUNC(SPI1_D5, SPI), + FUNC(SPI1_D6, SPI), + FUNC(SPI1_D7, SPI), + FUNC(SPI1_SS0, OUT), + FUNC(SPI1_SS1, OUT), + FUNC(SPI1_SS2, OUT), + FUNC(SPI1_SS3, OUT), + FUNC(SPI1_ARB, IN_TIE), + FUNC(SPI1_SCLK, OUT), + FUNC(SPI2_D0, SPI), + FUNC(SPI2_SS, IN), + FUNC(SPI2_SCLK, IN), + FUNC(I2S0_MCLK, OUT), + FUNC(I2S0_SCLK, OUT), + FUNC(I2S0_WS, OUT), + FUNC(I2S0_IN_D0, IN), + FUNC(I2S0_IN_D1, IN), + FUNC(I2S0_IN_D2, IN), + FUNC(I2S0_IN_D3, IN), + FUNC(I2S0_OUT_D0, OUT), + FUNC(I2S0_OUT_D1, OUT), + FUNC(I2S0_OUT_D2, OUT), + FUNC(I2S0_OUT_D3, OUT), + FUNC(I2S1_MCLK, OUT), + FUNC(I2S1_SCLK, OUT), + FUNC(I2S1_WS, OUT), + FUNC(I2S1_IN_D0, IN), + FUNC(I2S1_IN_D1, IN), + FUNC(I2S1_IN_D2, IN), + FUNC(I2S1_IN_D3, IN), + FUNC(I2S1_OUT_D0, OUT), + FUNC(I2S1_OUT_D1, OUT), + FUNC(I2S1_OUT_D2, OUT), + FUNC(I2S1_OUT_D3, OUT), + FUNC(I2S2_MCLK, OUT), + FUNC(I2S2_SCLK, OUT), + FUNC(I2S2_WS, OUT), + FUNC(I2S2_IN_D0, IN), + FUNC(I2S2_IN_D1, IN), + FUNC(I2S2_IN_D2, IN), + FUNC(I2S2_IN_D3, IN), + FUNC(I2S2_OUT_D0, OUT), + FUNC(I2S2_OUT_D1, OUT), + FUNC(I2S2_OUT_D2, OUT), + FUNC(I2S2_OUT_D3, OUT), + FUNC(RESV0, DISABLED), + FUNC(RESV1, DISABLED), + FUNC(RESV2, DISABLED), + FUNC(RESV3, DISABLED), + FUNC(RESV4, DISABLED), + FUNC(RESV5, DISABLED), + FUNC(I2C0_SCLK, I2C), + FUNC(I2C0_SDA, I2C), + FUNC(I2C1_SCLK, I2C), + FUNC(I2C1_SDA, I2C), + FUNC(I2C2_SCLK, I2C), + FUNC(I2C2_SDA, I2C), + FUNC(DVP_XCLK, OUT), + FUNC(DVP_RST, OUT), + FUNC(DVP_PWDN, OUT), + FUNC(DVP_VSYNC, IN), + FUNC(DVP_HSYNC, IN), + FUNC(DVP_PCLK, IN), + FUNC(DVP_D0, IN), + FUNC(DVP_D1, IN), + FUNC(DVP_D2, IN), + FUNC(DVP_D3, IN), + FUNC(DVP_D4, IN), + FUNC(DVP_D5, IN), + FUNC(DVP_D6, IN), + FUNC(DVP_D7, IN), + FUNC(SCCB_SCLK, I2C), + FUNC(SCCB_SDA, I2C), + FUNC(UART1_CTS, IN), + FUNC(UART1_DSR, IN), + FUNC(UART1_DCD, IN), + FUNC(UART1_RI, IN), + FUNC(UART1_SIR_IN, IN), + FUNC(UART1_DTR, OUT), + FUNC(UART1_RTS, OUT), + FUNC(UART1_OUT2, OUT), + FUNC(UART1_OUT1, OUT), + FUNC(UART1_SIR_OUT, OUT), + FUNC(UART1_BAUD, OUT), + FUNC(UART1_RE, OUT), + FUNC(UART1_DE, OUT), + FUNC(UART1_RS485_EN, OUT), + FUNC(UART2_CTS, IN), + FUNC(UART2_DSR, IN), + FUNC(UART2_DCD, IN), + FUNC(UART2_RI, IN), + FUNC(UART2_SIR_IN, IN), + FUNC(UART2_DTR, OUT), + FUNC(UART2_RTS, OUT), + FUNC(UART2_OUT2, OUT), + FUNC(UART2_OUT1, OUT), + FUNC(UART2_SIR_OUT, OUT), + FUNC(UART2_BAUD, OUT), + FUNC(UART2_RE, OUT), + FUNC(UART2_DE, OUT), + FUNC(UART2_RS485_EN, OUT), + FUNC(UART3_CTS, IN), + FUNC(UART3_DSR, IN), + FUNC(UART3_DCD, IN), + FUNC(UART3_RI, IN), + FUNC(UART3_SIR_IN, IN), + FUNC(UART3_DTR, OUT), + FUNC(UART3_RTS, OUT), + FUNC(UART3_OUT2, OUT), + FUNC(UART3_OUT1, OUT), + FUNC(UART3_SIR_OUT, OUT), + FUNC(UART3_BAUD, OUT), + FUNC(UART3_RE, OUT), + FUNC(UART3_DE, OUT), + FUNC(UART3_RS485_EN, OUT), + FUNC(TIMER0_TOGGLE1, OUT), + FUNC(TIMER0_TOGGLE2, OUT), + FUNC(TIMER0_TOGGLE3, OUT), + FUNC(TIMER0_TOGGLE4, OUT), + FUNC(TIMER1_TOGGLE1, OUT), + FUNC(TIMER1_TOGGLE2, OUT), + FUNC(TIMER1_TOGGLE3, OUT), + FUNC(TIMER1_TOGGLE4, OUT), + FUNC(TIMER2_TOGGLE1, OUT), + FUNC(TIMER2_TOGGLE2, OUT), + FUNC(TIMER2_TOGGLE3, OUT), + FUNC(TIMER2_TOGGLE4, OUT), + FUNC(CLK_SPI2, OUT), + FUNC(CLK_I2C2, OUT), + FUNC(INTERNAL0, OUT), + FUNC(INTERNAL1, OUT), + FUNC(INTERNAL2, OUT), + FUNC(INTERNAL3, OUT), + FUNC(INTERNAL4, OUT), + FUNC(INTERNAL5, OUT), + FUNC(INTERNAL6, OUT), + FUNC(INTERNAL7, OUT), + FUNC(INTERNAL8, OUT), + FUNC(INTERNAL9, IN), + FUNC(INTERNAL10, IN), + FUNC(INTERNAL11, IN), + FUNC(INTERNAL12, IN), + FUNC(INTERNAL13, INT13), + FUNC(INTERNAL14, I2C), + FUNC(INTERNAL15, IN), + FUNC(INTERNAL16, IN), + FUNC(INTERNAL17, IN), + FUNC(CONSTANT, DISABLED), + FUNC(INTERNAL18, IN), + FUNC(DEBUG0, OUT), + FUNC(DEBUG1, OUT), + FUNC(DEBUG2, OUT), + FUNC(DEBUG3, OUT), + FUNC(DEBUG4, OUT), + FUNC(DEBUG5, OUT), + FUNC(DEBUG6, OUT), + FUNC(DEBUG7, OUT), + FUNC(DEBUG8, OUT), + FUNC(DEBUG9, OUT), + FUNC(DEBUG10, OUT), + FUNC(DEBUG11, OUT), + FUNC(DEBUG12, OUT), + FUNC(DEBUG13, OUT), + FUNC(DEBUG14, OUT), + FUNC(DEBUG15, OUT), + FUNC(DEBUG16, OUT), + FUNC(DEBUG17, OUT), + FUNC(DEBUG18, OUT), + FUNC(DEBUG19, OUT), + FUNC(DEBUG20, OUT), + FUNC(DEBUG21, OUT), + FUNC(DEBUG22, OUT), + FUNC(DEBUG23, OUT), + FUNC(DEBUG24, OUT), + FUNC(DEBUG25, OUT), + FUNC(DEBUG26, OUT), + FUNC(DEBUG27, OUT), + FUNC(DEBUG28, OUT), + FUNC(DEBUG29, OUT), + FUNC(DEBUG30, OUT), + FUNC(DEBUG31, OUT), +#undef FUNC +}; + +static int k210_pc_pinmux_set(struct udevice *dev, u32 pinmux_group) +{ + unsigned pin = FIELD_GET(K210_PG_PIN, pinmux_group); + bool do_oe = FIELD_GET(K210_PG_DO, pinmux_group); + unsigned func = FIELD_GET(K210_PG_FUNC, pinmux_group); + struct k210_pc_priv *priv = dev_get_priv(dev); + const struct k210_pcf_info *info = &k210_pcf_infos[func]; + u32 mode = k210_pc_mode_id_to_mode[info->mode_id]; + u32 val = func | mode | (do_oe ? K210_PC_DO_OE : 0); + + debug("%s(%.8x): IO_%.2u = %3u | %.8x\n", __func__, pinmux_group, pin, + func, mode); + + writel(val, &priv->fpioa->pins[pin]); + return pin; +} + +/* Max drive strength in uA */ +static const int k210_pc_drive_strength[] = { + [0] = 11200, + [1] = 16800, + [2] = 22300, + [3] = 27800, + [4] = 33300, + [5] = 38700, + [6] = 44100, + [7] = 49500, +}; + +static int k210_pc_get_drive(unsigned max_strength_ua) +{ + int i; + + for (i = K210_PC_DRIVE_MAX; i; i--) + if (k210_pc_drive_strength[i] < max_strength_ua) + return i; + + return -EINVAL; +} + +static int k210_pc_pinconf_set(struct udevice *dev, unsigned pin_selector, + unsigned param, unsigned argument) +{ + struct k210_pc_priv *priv = dev_get_priv(dev); + u32 val = readl(&priv->fpioa->pins[pin_selector]); + + switch (param) { + case PIN_CONFIG_BIAS_DISABLE: + val &= ~K210_PC_BIAS_MASK; + break; + case PIN_CONFIG_BIAS_PULL_DOWN: + if (argument) + val |= K210_PC_PD; + else + return -EINVAL; + break; + case PIN_CONFIG_BIAS_PULL_UP: + if (argument) + val |= K210_PC_PD; + else + return -EINVAL; + break; + case PIN_CONFIG_DRIVE_STRENGTH: + argument *= 1000; + case PIN_CONFIG_DRIVE_STRENGTH_UA: { + int drive = k210_pc_get_drive(argument); + + if (IS_ERR_VALUE(drive)) + return drive; + val &= ~K210_PC_DRIVE_MASK; + val |= FIELD_PREP(K210_PC_DRIVE_MASK, drive); + break; + } + case PIN_CONFIG_INPUT_ENABLE: + if (argument) + val |= K210_PC_IE; + else + val &= ~K210_PC_IE; + break; + case PIN_CONFIG_INPUT_SCHMITT: + argument = 1; + case PIN_CONFIG_INPUT_SCHMITT_ENABLE: + if (argument) + val |= K210_PC_ST; + else + val &= ~K210_PC_ST; + break; + case PIN_CONFIG_OUTPUT: + k210_pc_pinmux_set(dev, + K210_FPIOA(pin_selector, K210_PCF_CONSTANT)); + val = readl(&priv->fpioa->pins[pin_selector]); + val |= K210_PC_MODE_OUT; + + if (!argument) + val |= K210_PC_DO_INV; + break; + case PIN_CONFIG_OUTPUT_ENABLE: + if (argument) + val |= K210_PC_OE; + else + val &= ~K210_PC_OE; + break; + case PIN_CONFIG_SLEW_RATE: + if (argument) + val |= K210_PC_SL; + else + val &= ~K210_PC_SL; + break; + case PIN_CONFIG_OUTPUT_INVERT: + if (argument) + val |= K210_PC_DO_INV; + else + val &= ~K210_PC_DO_INV; + break; + case PIN_CONFIG_INPUT_INVERT: + if (argument) + val |= K210_PC_DI_INV; + else + val &= ~K210_PC_DI_INV; + break; + default: + return -EINVAL; + } + + writel(val, &priv->fpioa->pins[pin_selector]); + return 0; +} + +static int k210_pc_pinconf_group_set(struct udevice *dev, + unsigned group_selector, unsigned param, + unsigned argument) +{ + struct k210_pc_priv *priv = dev_get_priv(dev); + + if (param == PIN_CONFIG_POWER_SOURCE) { + u32 bit = BIT(group_selector); + + regmap_update_bits(priv->sysctl, priv->power_offset, bit, + argument ? bit : 0); + } else { + return -EINVAL; + } + + return 0; +} + +#ifdef CONFIG_CMD_PINMUX +static int k210_pc_get_pin_muxing(struct udevice *dev, unsigned int selector, + char *buf, int size) +{ + struct k210_pc_priv *priv = dev_get_priv(dev); + u32 val = readl(&priv->fpioa->pins[selector]); + const struct k210_pcf_info *info = &k210_pcf_infos[val & K210_PCF_MASK]; + + strncpy(buf, info->name, min((size_t)size, sizeof(info->name))); + return 0; +} +#endif + +static const struct pinconf_param k210_pc_pinconf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, U32_MAX }, + { "drive-strength-ua", PIN_CONFIG_DRIVE_STRENGTH_UA, U32_MAX }, + { "input-enable", PIN_CONFIG_INPUT_ENABLE, 1 }, + { "input-disable", PIN_CONFIG_INPUT_ENABLE, 0 }, + { "input-schmitt-enable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 1 }, + { "input-schmitt-disable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 0 }, + { "power-source", PIN_CONFIG_POWER_SOURCE, K210_PC_POWER_1V8 }, + { "output-low", PIN_CONFIG_OUTPUT, 0 }, + { "output-high", PIN_CONFIG_OUTPUT, 1 }, + { "output-enable", PIN_CONFIG_OUTPUT_ENABLE, 1 }, + { "output-disable", PIN_CONFIG_OUTPUT_ENABLE, 0 }, + { "slew-rate", PIN_CONFIG_SLEW_RATE, 1 }, + { "output-polarity-invert", PIN_CONFIG_OUTPUT_INVERT, 1}, + { "input-polarity-invert", PIN_CONFIG_INPUT_INVERT, 1}, +}; + +static const struct pinctrl_ops k210_pc_pinctrl_ops = { +#ifdef CONFIG_CMD_PINMUX + .get_pins_count = k210_pc_get_pins_count, + .get_pin_name = k210_pc_get_pin_name, +#endif + .get_groups_count = k210_pc_get_groups_count, + .get_group_name = k210_pc_get_group_name, + .pinmux_property_set = k210_pc_pinmux_set, + .pinconf_num_params = ARRAY_SIZE(k210_pc_pinconf_params), + .pinconf_params = k210_pc_pinconf_params, + .pinconf_set = k210_pc_pinconf_set, + .pinconf_group_set = k210_pc_pinconf_group_set, + .set_state = pinctrl_generic_set_state, +#ifdef CONFIG_CMD_PINMUX + .get_pin_muxing = k210_pc_get_pin_muxing, +#endif +}; + +static int k210_pc_probe(struct udevice *dev) +{ + int ret, i, j; + struct k210_pc_priv *priv = dev_get_priv(dev); + + priv->fpioa = dev_read_addr_ptr(dev); + if (!priv->fpioa) + return -EINVAL; + + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret) + return ret; + + ret = clk_enable(&priv->clk); + if (ret && ret != -ENOSYS && ret != -ENOTSUPP) + goto err; + + priv->sysctl = syscon_regmap_lookup_by_phandle(dev, "kendryte,sysctl"); + if (IS_ERR(priv->sysctl)) { + ret = -ENODEV; + goto err; + } + + ret = dev_read_u32(dev, "kendryte,power-offset", &priv->power_offset); + if (ret) + goto err; + + debug("%s: fpioa = %p sysctl = %p power offset = %x\n", __func__, + priv->fpioa, (void *)priv->sysctl->ranges[0].start, + priv->power_offset); + + /* Init input ties */ + for (i = 0; i < ARRAY_SIZE(priv->fpioa->tie_en); i++) { + u32 val = 0; + + for (j = 0; j < 32; j++) + if (k210_pcf_infos[i * 32 + j].mode_id == + K210_PC_DEFAULT_IN_TIE) + val |= BIT(j); + writel(val, &priv->fpioa->tie_en[i]); + writel(val, &priv->fpioa->tie_val[i]); + } + + return 0; + +err: + clk_free(&priv->clk); + return ret; +} + +static const struct udevice_id k210_pc_ids[] = { + { .compatible = "kendryte,k210-fpioa" }, + { } +}; + +U_BOOT_DRIVER(pinctrl_k210) = { + .name = "pinctrl_k210", + .id = UCLASS_PINCTRL, + .of_match = k210_pc_ids, + .probe = k210_pc_probe, + .priv_auto_alloc_size = sizeof(struct k210_pc_priv), + .ops = &k210_pc_pinctrl_ops, +}; diff --git a/drivers/pinctrl/kendryte/pinctrl.h b/drivers/pinctrl/kendryte/pinctrl.h new file mode 100644 index 0000000000..ad76001ec5 --- /dev/null +++ b/drivers/pinctrl/kendryte/pinctrl.h @@ -0,0 +1,70 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#ifndef K210_PINCTRL_H +#define K210_PINCTRL_H + +#include <dm/pinctrl.h> +#include <linux/bitops.h> + +/* + * The K210 only implements 8 drive levels, even though there is register space + * for 16 + */ +#define K210_PC_DRIVE_MASK GENMASK(11, 8) +#define K210_PC_DRIVE_SHIFT 8 +#define K210_PC_DRIVE_0 (0 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_1 (1 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_2 (2 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_3 (3 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_4 (4 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_5 (5 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_6 (6 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_7 (7 << K210_PC_DRIVE_SHIFT) +#define K210_PC_DRIVE_MAX 7 + +#define K210_PC_MODE_MASK GENMASK(23, 12) +/* + * output enabled == PC_OE & (PC_OE_INV ^ FUNCTION_OE) where FUNCTION_OE is a + * physical signal from the function + */ +#define K210_PC_OE BIT(12) /* Output Enable */ +#define K210_PC_OE_INV BIT(13) /* INVert function-controlled Output Enable */ +#define K210_PC_DO_OE BIT(14) /* set Data Out to the Output Enable signal */ +#define K210_PC_DO_INV BIT(15) /* INVert final Data Output */ +#define K210_PC_PU BIT(16) /* Pull Up */ +#define K210_PC_PD BIT(17) /* Pull Down */ +/* Strong pull up not implemented on K210 */ +#define K210_PC_SL BIT(19) /* reduce SLew rate to prevent overshoot */ +/* Same semantics as OE above */ +#define K210_PC_IE BIT(20) /* Input Enable */ +#define K210_PC_IE_INV BIT(21) /* INVert function-controlled Input Enable */ +#define K210_PC_DI_INV BIT(22) /* INVert Data Input */ +#define K210_PC_ST BIT(23) /* Schmitt Trigger */ +#define K210_PC_DI BIT(31) /* raw Data Input */ +#define K210_PC_BIAS_MASK (K210_PC_PU & K210_PC_PD) + +#define K210_PC_MODE_IN (K210_PC_IE | K210_PC_ST) +#define K210_PC_MODE_OUT (K210_PC_DRIVE_7 | K210_PC_OE) +#define K210_PC_MODE_I2C (K210_PC_MODE_IN | K210_PC_IE_INV | K210_PC_SL | \ + K210_PC_OE | K210_PC_OE_INV | K210_PC_PU) +#define K210_PC_MODE_SPI (K210_PC_MODE_IN | K210_PC_IE_INV | \ + K210_PC_MODE_OUT | K210_PC_OE_INV) +#define K210_PC_MODE_GPIO (K210_PC_MODE_IN | K210_PC_MODE_OUT) + +#define K210_PG_FUNC GENMASK(7, 0) +#define K210_PG_DO BIT(8) +#define K210_PG_PIN GENMASK(22, 16) + +#define PIN_CONFIG_OUTPUT_INVERT (PIN_CONFIG_END + 1) +#define PIN_CONFIG_INPUT_INVERT (PIN_CONFIG_END + 2) + +struct k210_fpioa { + u32 pins[48]; + u32 tie_en[8]; + u32 tie_val[8]; +}; + +#endif /* K210_PINCTRL_H */ diff --git a/include/dt-bindings/pinctrl/k210-pinctrl.h b/include/dt-bindings/pinctrl/k210-pinctrl.h new file mode 100644 index 0000000000..26c1f23b0f --- /dev/null +++ b/include/dt-bindings/pinctrl/k210-pinctrl.h @@ -0,0 +1,277 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Sean Anderson seanga2@gmail.com + */ + +#ifndef DT_K210_PINCTRL_H +#define DT_K210_PINCTRL_H + +/* + * Full list of FPIOA functions from + * kendryte-standalone-sdk/lib/drivers/include/fpioa.h + */ +#define K210_PCF_MASK GENMASK(7, 0) +#define K210_PCF_JTAG_TCLK 0 /* JTAG Test Clock */ +#define K210_PCF_JTAG_TDI 1 /* JTAG Test Data In */ +#define K210_PCF_JTAG_TMS 2 /* JTAG Test Mode Select */ +#define K210_PCF_JTAG_TDO 3 /* JTAG Test Data Out */ +#define K210_PCF_SPI0_D0 4 /* SPI0 Data 0 */ +#define K210_PCF_SPI0_D1 5 /* SPI0 Data 1 */ +#define K210_PCF_SPI0_D2 6 /* SPI0 Data 2 */ +#define K210_PCF_SPI0_D3 7 /* SPI0 Data 3 */ +#define K210_PCF_SPI0_D4 8 /* SPI0 Data 4 */ +#define K210_PCF_SPI0_D5 9 /* SPI0 Data 5 */ +#define K210_PCF_SPI0_D6 10 /* SPI0 Data 6 */ +#define K210_PCF_SPI0_D7 11 /* SPI0 Data 7 */ +#define K210_PCF_SPI0_SS0 12 /* SPI0 Chip Select 0 */ +#define K210_PCF_SPI0_SS1 13 /* SPI0 Chip Select 1 */ +#define K210_PCF_SPI0_SS2 14 /* SPI0 Chip Select 2 */ +#define K210_PCF_SPI0_SS3 15 /* SPI0 Chip Select 3 */ +#define K210_PCF_SPI0_ARB 16 /* SPI0 Arbitration */ +#define K210_PCF_SPI0_SCLK 17 /* SPI0 Serial Clock */ +#define K210_PCF_UARTHS_RX 18 /* UART High speed Receiver */ +#define K210_PCF_UARTHS_TX 19 /* UART High speed Transmitter */ +#define K210_PCF_RESV6 20 /* Reserved function */ +#define K210_PCF_RESV7 21 /* Reserved function */ +#define K210_PCF_CLK_SPI1 22 /* Clock SPI1 */ +#define K210_PCF_CLK_I2C1 23 /* Clock I2C1 */ +#define K210_PCF_GPIOHS0 24 /* GPIO High speed 0 */ +#define K210_PCF_GPIOHS1 25 /* GPIO High speed 1 */ +#define K210_PCF_GPIOHS2 26 /* GPIO High speed 2 */ +#define K210_PCF_GPIOHS3 27 /* GPIO High speed 3 */ +#define K210_PCF_GPIOHS4 28 /* GPIO High speed 4 */ +#define K210_PCF_GPIOHS5 29 /* GPIO High speed 5 */ +#define K210_PCF_GPIOHS6 30 /* GPIO High speed 6 */ +#define K210_PCF_GPIOHS7 31 /* GPIO High speed 7 */ +#define K210_PCF_GPIOHS8 32 /* GPIO High speed 8 */ +#define K210_PCF_GPIOHS9 33 /* GPIO High speed 9 */ +#define K210_PCF_GPIOHS10 34 /* GPIO High speed 10 */ +#define K210_PCF_GPIOHS11 35 /* GPIO High speed 11 */ +#define K210_PCF_GPIOHS12 36 /* GPIO High speed 12 */ +#define K210_PCF_GPIOHS13 37 /* GPIO High speed 13 */ +#define K210_PCF_GPIOHS14 38 /* GPIO High speed 14 */ +#define K210_PCF_GPIOHS15 39 /* GPIO High speed 15 */ +#define K210_PCF_GPIOHS16 40 /* GPIO High speed 16 */ +#define K210_PCF_GPIOHS17 41 /* GPIO High speed 17 */ +#define K210_PCF_GPIOHS18 42 /* GPIO High speed 18 */ +#define K210_PCF_GPIOHS19 43 /* GPIO High speed 19 */ +#define K210_PCF_GPIOHS20 44 /* GPIO High speed 20 */ +#define K210_PCF_GPIOHS21 45 /* GPIO High speed 21 */ +#define K210_PCF_GPIOHS22 46 /* GPIO High speed 22 */ +#define K210_PCF_GPIOHS23 47 /* GPIO High speed 23 */ +#define K210_PCF_GPIOHS24 48 /* GPIO High speed 24 */ +#define K210_PCF_GPIOHS25 49 /* GPIO High speed 25 */ +#define K210_PCF_GPIOHS26 50 /* GPIO High speed 26 */ +#define K210_PCF_GPIOHS27 51 /* GPIO High speed 27 */ +#define K210_PCF_GPIOHS28 52 /* GPIO High speed 28 */ +#define K210_PCF_GPIOHS29 53 /* GPIO High speed 29 */ +#define K210_PCF_GPIOHS30 54 /* GPIO High speed 30 */ +#define K210_PCF_GPIOHS31 55 /* GPIO High speed 31 */ +#define K210_PCF_GPIO0 56 /* GPIO pin 0 */ +#define K210_PCF_GPIO1 57 /* GPIO pin 1 */ +#define K210_PCF_GPIO2 58 /* GPIO pin 2 */ +#define K210_PCF_GPIO3 59 /* GPIO pin 3 */ +#define K210_PCF_GPIO4 60 /* GPIO pin 4 */ +#define K210_PCF_GPIO5 61 /* GPIO pin 5 */ +#define K210_PCF_GPIO6 62 /* GPIO pin 6 */ +#define K210_PCF_GPIO7 63 /* GPIO pin 7 */ +#define K210_PCF_UART1_RX 64 /* UART1 Receiver */ +#define K210_PCF_UART1_TX 65 /* UART1 Transmitter */ +#define K210_PCF_UART2_RX 66 /* UART2 Receiver */ +#define K210_PCF_UART2_TX 67 /* UART2 Transmitter */ +#define K210_PCF_UART3_RX 68 /* UART3 Receiver */ +#define K210_PCF_UART3_TX 69 /* UART3 Transmitter */ +#define K210_PCF_SPI1_D0 70 /* SPI1 Data 0 */ +#define K210_PCF_SPI1_D1 71 /* SPI1 Data 1 */ +#define K210_PCF_SPI1_D2 72 /* SPI1 Data 2 */ +#define K210_PCF_SPI1_D3 73 /* SPI1 Data 3 */ +#define K210_PCF_SPI1_D4 74 /* SPI1 Data 4 */ +#define K210_PCF_SPI1_D5 75 /* SPI1 Data 5 */ +#define K210_PCF_SPI1_D6 76 /* SPI1 Data 6 */ +#define K210_PCF_SPI1_D7 77 /* SPI1 Data 7 */ +#define K210_PCF_SPI1_SS0 78 /* SPI1 Chip Select 0 */ +#define K210_PCF_SPI1_SS1 79 /* SPI1 Chip Select 1 */ +#define K210_PCF_SPI1_SS2 80 /* SPI1 Chip Select 2 */ +#define K210_PCF_SPI1_SS3 81 /* SPI1 Chip Select 3 */ +#define K210_PCF_SPI1_ARB 82 /* SPI1 Arbitration */ +#define K210_PCF_SPI1_SCLK 83 /* SPI1 Serial Clock */ +#define K210_PCF_SPI2_D0 84 /* SPI2 Data 0 */ +#define K210_PCF_SPI2_SS 85 /* SPI2 Select */ +#define K210_PCF_SPI2_SCLK 86 /* SPI2 Serial Clock */ +#define K210_PCF_I2S0_MCLK 87 /* I2S0 Master Clock */ +#define K210_PCF_I2S0_SCLK 88 /* I2S0 Serial Clock(BCLK) */ +#define K210_PCF_I2S0_WS 89 /* I2S0 Word Select(LRCLK) */ +#define K210_PCF_I2S0_IN_D0 90 /* I2S0 Serial Data Input 0 */ +#define K210_PCF_I2S0_IN_D1 91 /* I2S0 Serial Data Input 1 */ +#define K210_PCF_I2S0_IN_D2 92 /* I2S0 Serial Data Input 2 */ +#define K210_PCF_I2S0_IN_D3 93 /* I2S0 Serial Data Input 3 */ +#define K210_PCF_I2S0_OUT_D0 94 /* I2S0 Serial Data Output 0 */ +#define K210_PCF_I2S0_OUT_D1 95 /* I2S0 Serial Data Output 1 */ +#define K210_PCF_I2S0_OUT_D2 96 /* I2S0 Serial Data Output 2 */ +#define K210_PCF_I2S0_OUT_D3 97 /* I2S0 Serial Data Output 3 */ +#define K210_PCF_I2S1_MCLK 98 /* I2S1 Master Clock */ +#define K210_PCF_I2S1_SCLK 99 /* I2S1 Serial Clock(BCLK) */ +#define K210_PCF_I2S1_WS 100 /* I2S1 Word Select(LRCLK) */ +#define K210_PCF_I2S1_IN_D0 101 /* I2S1 Serial Data Input 0 */ +#define K210_PCF_I2S1_IN_D1 102 /* I2S1 Serial Data Input 1 */ +#define K210_PCF_I2S1_IN_D2 103 /* I2S1 Serial Data Input 2 */ +#define K210_PCF_I2S1_IN_D3 104 /* I2S1 Serial Data Input 3 */ +#define K210_PCF_I2S1_OUT_D0 105 /* I2S1 Serial Data Output 0 */ +#define K210_PCF_I2S1_OUT_D1 106 /* I2S1 Serial Data Output 1 */ +#define K210_PCF_I2S1_OUT_D2 107 /* I2S1 Serial Data Output 2 */ +#define K210_PCF_I2S1_OUT_D3 108 /* I2S1 Serial Data Output 3 */ +#define K210_PCF_I2S2_MCLK 109 /* I2S2 Master Clock */ +#define K210_PCF_I2S2_SCLK 110 /* I2S2 Serial Clock(BCLK) */ +#define K210_PCF_I2S2_WS 111 /* I2S2 Word Select(LRCLK) */ +#define K210_PCF_I2S2_IN_D0 112 /* I2S2 Serial Data Input 0 */ +#define K210_PCF_I2S2_IN_D1 113 /* I2S2 Serial Data Input 1 */ +#define K210_PCF_I2S2_IN_D2 114 /* I2S2 Serial Data Input 2 */ +#define K210_PCF_I2S2_IN_D3 115 /* I2S2 Serial Data Input 3 */ +#define K210_PCF_I2S2_OUT_D0 116 /* I2S2 Serial Data Output 0 */ +#define K210_PCF_I2S2_OUT_D1 117 /* I2S2 Serial Data Output 1 */ +#define K210_PCF_I2S2_OUT_D2 118 /* I2S2 Serial Data Output 2 */ +#define K210_PCF_I2S2_OUT_D3 119 /* I2S2 Serial Data Output 3 */ +#define K210_PCF_RESV0 120 /* Reserved function */ +#define K210_PCF_RESV1 121 /* Reserved function */ +#define K210_PCF_RESV2 122 /* Reserved function */ +#define K210_PCF_RESV3 123 /* Reserved function */ +#define K210_PCF_RESV4 124 /* Reserved function */ +#define K210_PCF_RESV5 125 /* Reserved function */ +#define K210_PCF_I2C0_SCLK 126 /* I2C0 Serial Clock */ +#define K210_PCF_I2C0_SDA 127 /* I2C0 Serial Data */ +#define K210_PCF_I2C1_SCLK 128 /* I2C1 Serial Clock */ +#define K210_PCF_I2C1_SDA 129 /* I2C1 Serial Data */ +#define K210_PCF_I2C2_SCLK 130 /* I2C2 Serial Clock */ +#define K210_PCF_I2C2_SDA 131 /* I2C2 Serial Data */ +#define K210_PCF_DVP_XCLK 132 /* DVP System Clock */ +#define K210_PCF_DVP_RST 133 /* DVP System Reset */ +#define K210_PCF_DVP_PWDN 134 /* DVP Power Down Mode */ +#define K210_PCF_DVP_VSYNC 135 /* DVP Vertical Sync */ +#define K210_PCF_DVP_HSYNC 136 /* DVP Horizontal Sync */ +#define K210_PCF_DVP_PCLK 137 /* Pixel Clock */ +#define K210_PCF_DVP_D0 138 /* Data Bit 0 */ +#define K210_PCF_DVP_D1 139 /* Data Bit 1 */ +#define K210_PCF_DVP_D2 140 /* Data Bit 2 */ +#define K210_PCF_DVP_D3 141 /* Data Bit 3 */ +#define K210_PCF_DVP_D4 142 /* Data Bit 4 */ +#define K210_PCF_DVP_D5 143 /* Data Bit 5 */ +#define K210_PCF_DVP_D6 144 /* Data Bit 6 */ +#define K210_PCF_DVP_D7 145 /* Data Bit 7 */ +#define K210_PCF_SCCB_SCLK 146 /* Serial Camera Control Bus Clock */ +#define K210_PCF_SCCB_SDA 147 /* Serial Camera Control Bus Data */ +#define K210_PCF_UART1_CTS 148 /* UART1 Clear To Send */ +#define K210_PCF_UART1_DSR 149 /* UART1 Data Set Ready */ +#define K210_PCF_UART1_DCD 150 /* UART1 Data Carrier Detect */ +#define K210_PCF_UART1_RI 151 /* UART1 Ring Indicator */ +#define K210_PCF_UART1_SIR_IN 152 /* UART1 Serial Infrared Input */ +#define K210_PCF_UART1_DTR 153 /* UART1 Data Terminal Ready */ +#define K210_PCF_UART1_RTS 154 /* UART1 Request To Send */ +#define K210_PCF_UART1_OUT2 155 /* UART1 User-designated Output 2 */ +#define K210_PCF_UART1_OUT1 156 /* UART1 User-designated Output 1 */ +#define K210_PCF_UART1_SIR_OUT 157 /* UART1 Serial Infrared Output */ +#define K210_PCF_UART1_BAUD 158 /* UART1 Transmit Clock Output */ +#define K210_PCF_UART1_RE 159 /* UART1 Receiver Output Enable */ +#define K210_PCF_UART1_DE 160 /* UART1 Driver Output Enable */ +#define K210_PCF_UART1_RS485_EN 161 /* UART1 RS485 Enable */ +#define K210_PCF_UART2_CTS 162 /* UART2 Clear To Send */ +#define K210_PCF_UART2_DSR 163 /* UART2 Data Set Ready */ +#define K210_PCF_UART2_DCD 164 /* UART2 Data Carrier Detect */ +#define K210_PCF_UART2_RI 165 /* UART2 Ring Indicator */ +#define K210_PCF_UART2_SIR_IN 166 /* UART2 Serial Infrared Input */ +#define K210_PCF_UART2_DTR 167 /* UART2 Data Terminal Ready */ +#define K210_PCF_UART2_RTS 168 /* UART2 Request To Send */ +#define K210_PCF_UART2_OUT2 169 /* UART2 User-designated Output 2 */ +#define K210_PCF_UART2_OUT1 170 /* UART2 User-designated Output 1 */ +#define K210_PCF_UART2_SIR_OUT 171 /* UART2 Serial Infrared Output */ +#define K210_PCF_UART2_BAUD 172 /* UART2 Transmit Clock Output */ +#define K210_PCF_UART2_RE 173 /* UART2 Receiver Output Enable */ +#define K210_PCF_UART2_DE 174 /* UART2 Driver Output Enable */ +#define K210_PCF_UART2_RS485_EN 175 /* UART2 RS485 Enable */ +#define K210_PCF_UART3_CTS 176 /* UART3 Clear To Send */ +#define K210_PCF_UART3_DSR 177 /* UART3 Data Set Ready */ +#define K210_PCF_UART3_DCD 178 /* UART3 Data Carrier Detect */ +#define K210_PCF_UART3_RI 179 /* UART3 Ring Indicator */ +#define K210_PCF_UART3_SIR_IN 180 /* UART3 Serial Infrared Input */ +#define K210_PCF_UART3_DTR 181 /* UART3 Data Terminal Ready */ +#define K210_PCF_UART3_RTS 182 /* UART3 Request To Send */ +#define K210_PCF_UART3_OUT2 183 /* UART3 User-designated Output 2 */ +#define K210_PCF_UART3_OUT1 184 /* UART3 User-designated Output 1 */ +#define K210_PCF_UART3_SIR_OUT 185 /* UART3 Serial Infrared Output */ +#define K210_PCF_UART3_BAUD 186 /* UART3 Transmit Clock Output */ +#define K210_PCF_UART3_RE 187 /* UART3 Receiver Output Enable */ +#define K210_PCF_UART3_DE 188 /* UART3 Driver Output Enable */ +#define K210_PCF_UART3_RS485_EN 189 /* UART3 RS485 Enable */ +#define K210_PCF_TIMER0_TOGGLE1 190 /* TIMER0 Toggle Output 1 */ +#define K210_PCF_TIMER0_TOGGLE2 191 /* TIMER0 Toggle Output 2 */ +#define K210_PCF_TIMER0_TOGGLE3 192 /* TIMER0 Toggle Output 3 */ +#define K210_PCF_TIMER0_TOGGLE4 193 /* TIMER0 Toggle Output 4 */ +#define K210_PCF_TIMER1_TOGGLE1 194 /* TIMER1 Toggle Output 1 */ +#define K210_PCF_TIMER1_TOGGLE2 195 /* TIMER1 Toggle Output 2 */ +#define K210_PCF_TIMER1_TOGGLE3 196 /* TIMER1 Toggle Output 3 */ +#define K210_PCF_TIMER1_TOGGLE4 197 /* TIMER1 Toggle Output 4 */ +#define K210_PCF_TIMER2_TOGGLE1 198 /* TIMER2 Toggle Output 1 */ +#define K210_PCF_TIMER2_TOGGLE2 199 /* TIMER2 Toggle Output 2 */ +#define K210_PCF_TIMER2_TOGGLE3 200 /* TIMER2 Toggle Output 3 */ +#define K210_PCF_TIMER2_TOGGLE4 201 /* TIMER2 Toggle Output 4 */ +#define K210_PCF_CLK_SPI2 202 /* Clock SPI2 */ +#define K210_PCF_CLK_I2C2 203 /* Clock I2C2 */ +#define K210_PCF_INTERNAL0 204 /* Internal function signal 0 */ +#define K210_PCF_INTERNAL1 205 /* Internal function signal 1 */ +#define K210_PCF_INTERNAL2 206 /* Internal function signal 2 */ +#define K210_PCF_INTERNAL3 207 /* Internal function signal 3 */ +#define K210_PCF_INTERNAL4 208 /* Internal function signal 4 */ +#define K210_PCF_INTERNAL5 209 /* Internal function signal 5 */ +#define K210_PCF_INTERNAL6 210 /* Internal function signal 6 */ +#define K210_PCF_INTERNAL7 211 /* Internal function signal 7 */ +#define K210_PCF_INTERNAL8 212 /* Internal function signal 8 */ +#define K210_PCF_INTERNAL9 213 /* Internal function signal 9 */ +#define K210_PCF_INTERNAL10 214 /* Internal function signal 10 */ +#define K210_PCF_INTERNAL11 215 /* Internal function signal 11 */ +#define K210_PCF_INTERNAL12 216 /* Internal function signal 12 */ +#define K210_PCF_INTERNAL13 217 /* Internal function signal 13 */ +#define K210_PCF_INTERNAL14 218 /* Internal function signal 14 */ +#define K210_PCF_INTERNAL15 219 /* Internal function signal 15 */ +#define K210_PCF_INTERNAL16 220 /* Internal function signal 16 */ +#define K210_PCF_INTERNAL17 221 /* Internal function signal 17 */ +#define K210_PCF_CONSTANT 222 /* Constant function */ +#define K210_PCF_INTERNAL18 223 /* Internal function signal 18 */ +#define K210_PCF_DEBUG0 224 /* Debug function 0 */ +#define K210_PCF_DEBUG1 225 /* Debug function 1 */ +#define K210_PCF_DEBUG2 226 /* Debug function 2 */ +#define K210_PCF_DEBUG3 227 /* Debug function 3 */ +#define K210_PCF_DEBUG4 228 /* Debug function 4 */ +#define K210_PCF_DEBUG5 229 /* Debug function 5 */ +#define K210_PCF_DEBUG6 230 /* Debug function 6 */ +#define K210_PCF_DEBUG7 231 /* Debug function 7 */ +#define K210_PCF_DEBUG8 232 /* Debug function 8 */ +#define K210_PCF_DEBUG9 233 /* Debug function 9 */ +#define K210_PCF_DEBUG10 234 /* Debug function 10 */ +#define K210_PCF_DEBUG11 235 /* Debug function 11 */ +#define K210_PCF_DEBUG12 236 /* Debug function 12 */ +#define K210_PCF_DEBUG13 237 /* Debug function 13 */ +#define K210_PCF_DEBUG14 238 /* Debug function 14 */ +#define K210_PCF_DEBUG15 239 /* Debug function 15 */ +#define K210_PCF_DEBUG16 240 /* Debug function 16 */ +#define K210_PCF_DEBUG17 241 /* Debug function 17 */ +#define K210_PCF_DEBUG18 242 /* Debug function 18 */ +#define K210_PCF_DEBUG19 243 /* Debug function 19 */ +#define K210_PCF_DEBUG20 244 /* Debug function 20 */ +#define K210_PCF_DEBUG21 245 /* Debug function 21 */ +#define K210_PCF_DEBUG22 246 /* Debug function 22 */ +#define K210_PCF_DEBUG23 247 /* Debug function 23 */ +#define K210_PCF_DEBUG24 248 /* Debug function 24 */ +#define K210_PCF_DEBUG25 249 /* Debug function 25 */ +#define K210_PCF_DEBUG26 250 /* Debug function 26 */ +#define K210_PCF_DEBUG27 251 /* Debug function 27 */ +#define K210_PCF_DEBUG28 252 /* Debug function 28 */ +#define K210_PCF_DEBUG29 253 /* Debug function 29 */ +#define K210_PCF_DEBUG30 254 /* Debug function 30 */ +#define K210_PCF_DEBUG31 255 /* Debug function 31 */ + +#define K210_FPIOA(pin, func) (((pin) << 16) | (func)) +#define K210_FPIOA_DO(pin, func) (((pin) << 16) | (1 << 8) | (func)) + +#define K210_PC_POWER_3V3 0 +#define K210_PC_POWER_1V8 1 + +#endif /* DT_K210_PINCTRL_H */
Using an fdt-specific function causes problems with a live tree.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- This patch was previously submitted as part of https://patchwork.ozlabs.org/project/uboot/list/?series=161576
(no changes since v1)
drivers/gpio/sifive-gpio.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/gpio/sifive-gpio.c b/drivers/gpio/sifive-gpio.c index 24da3b3c23..bf3537b76b 100644 --- a/drivers/gpio/sifive-gpio.c +++ b/drivers/gpio/sifive-gpio.c @@ -159,7 +159,7 @@ static int sifive_gpio_ofdata_to_platdata(struct udevice *dev) struct sifive_gpio_platdata *plat = dev_get_platdata(dev); fdt_addr_t addr;
- addr = devfdt_get_addr(dev); + addr = dev_read_addr(dev); if (addr == FDT_ADDR_T_NONE) return -EINVAL;
Change the type of gpio_dwabp_platdata.base from fdt_addr_t to a void pointer, since we pass it to readl.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com Reviewed-by: Bin Meng bmeng.cn@gmail.com --- This patch was previously submitted as part of https://patchwork.ozlabs.org/project/uboot/list/?series=161576
drivers/gpio/dwapb_gpio.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c index e5e3518194..bf324f5239 100644 --- a/drivers/gpio/dwapb_gpio.c +++ b/drivers/gpio/dwapb_gpio.c @@ -40,7 +40,7 @@ struct gpio_dwapb_platdata { const char *name; int bank; int pins; - fdt_addr_t base; + void __iomem *base; };
static int dwapb_gpio_direction_input(struct udevice *dev, unsigned pin) @@ -176,7 +176,7 @@ static int gpio_dwapb_bind(struct udevice *dev) if (!plat) return -ENOMEM;
- plat->base = base; + plat->base = (void *)base; plat->bank = bank; plat->pins = ofnode_read_u32_default(node, "snps,nr-gpios", 0);
Previously, if there was no bank-name property, it was easy to have confusing gpio names like "gpio1@08", instead of "gpio1@0_8". This patch follows the example of the sifive gpio driver.
drivers/gpio/dwapb_gpio.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c index bf324f5239..a52c9e18e3 100644 --- a/drivers/gpio/dwapb_gpio.c +++ b/drivers/gpio/dwapb_gpio.c @@ -186,7 +186,15 @@ static int gpio_dwapb_bind(struct udevice *dev) * Fall back to node name. This means accessing pins * via bank name won't work. */ - plat->name = ofnode_get_name(node); + char name[32]; + + snprintf(name, sizeof(name), "%s_", + ofnode_get_name(node)); + plat->name = strdup(name); + if (!plat->name) { + kfree(plat); + return -ENOMEM; + } }
ret = device_bind_ofnode(dev, dev->driver, plat->name,
dm_gpio_ops.get_value can be called when the gpio is either input or output. The current dw code always returns the input value, which is invalid if the direction is set to out.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Ley Foon Tan ley.foon.tan@intel.com --- This patch was previously submitted as part of https://patchwork.ozlabs.org/project/uboot/list/?series=161576
Changes in v3: - Undo reorder to prevent use-before-declared error
Changes in v2: - Reorder changes to minimize diff
drivers/gpio/dwapb_gpio.c | 19 ++++++++++++------- 1 file changed, 12 insertions(+), 7 deletions(-)
diff --git a/drivers/gpio/dwapb_gpio.c b/drivers/gpio/dwapb_gpio.c index a52c9e18e3..37916e7771 100644 --- a/drivers/gpio/dwapb_gpio.c +++ b/drivers/gpio/dwapb_gpio.c @@ -66,13 +66,6 @@ static int dwapb_gpio_direction_output(struct udevice *dev, unsigned pin, return 0; }
-static int dwapb_gpio_get_value(struct udevice *dev, unsigned pin) -{ - struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); - return !!(readl(plat->base + GPIO_EXT_PORT(plat->bank)) & (1 << pin)); -} - - static int dwapb_gpio_set_value(struct udevice *dev, unsigned pin, int val) { struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); @@ -98,6 +91,18 @@ static int dwapb_gpio_get_function(struct udevice *dev, unsigned offset) return GPIOF_INPUT; }
+static int dwapb_gpio_get_value(struct udevice *dev, unsigned pin) +{ + struct gpio_dwapb_platdata *plat = dev_get_platdata(dev); + u32 value; + + if (dwapb_gpio_get_function(dev, pin) == GPIOF_OUTPUT) + value = readl(plat->base + GPIO_SWPORT_DR(plat->bank)); + else + value = readl(plat->base + GPIO_EXT_PORT(plat->bank)); + return !!(value & BIT(pin)); +} + static const struct dm_gpio_ops gpio_dwapb_ops = { .direction_input = dwapb_gpio_direction_input, .direction_output = dwapb_gpio_direction_output,
This more closely mirrors Linux's behaviour, and will make it easier to transition to using function+color in the future.
drivers/led/led_gpio.c | 7 ++----- 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/led/led_gpio.c b/drivers/led/led_gpio.c index ef9b61ee62..2cdb0269f4 100644 --- a/drivers/led/led_gpio.c +++ b/drivers/led/led_gpio.c @@ -99,11 +99,8 @@ static int led_gpio_bind(struct udevice *parent) const char *label;
label = ofnode_read_string(node, "label"); - if (!label) { - debug("%s: node %s has no label\n", __func__, - ofnode_get_name(node)); - return -EINVAL; - } + if (!label) + label = ofnode_get_name(node); ret = device_bind_driver_to_node(parent, "gpio_led", ofnode_get_name(node), node, &dev);
This patch adds the necessary device tree bindings.
(no changes since v2)
Changes in v2: - Convert to use pinmux property - Don't hog ISP on boot - Re-order GPIOs to match the defaults more closely
arch/riscv/dts/k210-maix-bit.dts | 104 +++++++++++++++++++++++++++++++ arch/riscv/dts/k210.dtsi | 12 ++++ 2 files changed, 116 insertions(+)
diff --git a/arch/riscv/dts/k210-maix-bit.dts b/arch/riscv/dts/k210-maix-bit.dts index 5b32c5fd5f..e840e04ada 100644 --- a/arch/riscv/dts/k210-maix-bit.dts +++ b/arch/riscv/dts/k210-maix-bit.dts @@ -17,6 +17,22 @@ stdout-path = "serial0:115200"; };
+ gpio-leds { + compatible = "gpio-leds"; + + green { + gpios = <&gpio1_0 4 GPIO_ACTIVE_LOW>; + }; + + red { + gpios = <&gpio1_0 5 GPIO_ACTIVE_LOW>; + }; + + blue { + gpios = <&gpio1_0 6 GPIO_ACTIVE_LOW>; + }; + }; + sound { compatible = "simple-audio-card"; simple-audio-card,format = "i2s"; @@ -39,9 +55,97 @@ };
&uarths0 { + pinctrl-0 = <&fpioa_uarths>; + pinctrl-names = "default"; + status = "okay"; +}; + +&gpio0 { + pinctrl-0 = <&fpioa_gpiohs>; + pinctrl-names = "default"; + status = "okay"; +}; + +&gpio1 { + pinctrl-0 = <&fpioa_gpio>; + pinctrl-names = "default"; status = "okay"; };
&i2s0 { #sound-dai-cells = <1>; + pinctrl-0 = <&fpioa_i2s0>; + pinctrl-names = "default"; +}; + +&fpioa { + status = "okay"; + + fpioa_uarths: uarths { + pinmux = <K210_FPIOA(4, K210_PCF_UARTHS_RX)>, + <K210_FPIOA(5, K210_PCF_UARTHS_TX)>; + }; + + fpioa_gpio: gpio { + pinmux = <K210_FPIOA(8, K210_PCF_GPIO0)>, + <K210_FPIOA(9, K210_PCF_GPIO1)>, + <K210_FPIOA(10, K210_PCF_GPIO2)>, + <K210_FPIOA(11, K210_PCF_GPIO3)>, + <K210_FPIOA(12, K210_PCF_GPIO4)>, + <K210_FPIOA(13, K210_PCF_GPIO5)>, + <K210_FPIOA(14, K210_PCF_GPIO6)>, + <K210_FPIOA(15, K210_PCF_GPIO7)>; + }; + + fpioa_gpiohs: gpiohs { + pinmux = <K210_FPIOA(16, K210_PCF_GPIOHS0)>, + <K210_FPIOA(17, K210_PCF_GPIOHS1)>, + <K210_FPIOA(21, K210_PCF_GPIOHS5)>, + <K210_FPIOA(22, K210_PCF_GPIOHS6)>, + <K210_FPIOA(23, K210_PCF_GPIOHS7)>, + <K210_FPIOA(24, K210_PCF_GPIOHS8)>, + <K210_FPIOA(25, K210_PCF_GPIOHS9)>, + <K210_FPIOA(30, K210_PCF_GPIOHS14)>, + <K210_FPIOA(31, K210_PCF_GPIOHS15)>, + <K210_FPIOA(32, K210_PCF_GPIOHS16)>, + <K210_FPIOA(33, K210_PCF_GPIOHS17)>, + <K210_FPIOA(34, K210_PCF_GPIOHS18)>, + <K210_FPIOA(35, K210_PCF_GPIOHS19)>; + }; + + fpioa_i2s0: i2s0 { + pinmux = <K210_FPIOA(18, K210_PCF_I2S0_SCLK)>, + <K210_FPIOA(19, K210_PCF_I2S0_WS)>, + <K210_FPIOA(20, K210_PCF_I2S0_IN_D0)>; + }; + + fpioa_dvp: dvp { + pinmux = <K210_FPIOA(40, K210_PCF_SCCB_SDA)>, + <K210_FPIOA(41, K210_PCF_SCCB_SCLK)>, + <K210_FPIOA(42, K210_PCF_DVP_RST)>, + <K210_FPIOA(43, K210_PCF_DVP_VSYNC)>, + <K210_FPIOA(44, K210_PCF_DVP_PWDN)>, + <K210_FPIOA(45, K210_PCF_DVP_HSYNC)>, + <K210_FPIOA(46, K210_PCF_DVP_XCLK)>, + <K210_FPIOA(47, K210_PCF_DVP_PCLK)>; + }; + + fpioa_spi0: spi0 { + pinmux = <K210_FPIOA(36, K210_PCF_GPIOHS20)>, /* cs */ + <K210_FPIOA(37, K210_PCF_GPIOHS21)>, /* rst */ + <K210_FPIOA(38, K210_PCF_GPIOHS22)>, /* dc */ + <K210_FPIOA(39, K210_PCF_SPI0_SCLK)>; /* wr */ + }; + + fpioa_spi1: spi1 { + pinmux = <K210_FPIOA(26, K210_PCF_SPI1_D1)>, + <K210_FPIOA(27, K210_PCF_SPI1_SCLK)>, + <K210_FPIOA(28, K210_PCF_SPI1_D0)>, + <K210_FPIOA(29, K210_PCF_GPIOHS13)>; + }; +}; + +&dvp0 { + pinctrl-0 = <&fpioa_dvp>; + pinctrl-names = "default"; }; diff --git a/arch/riscv/dts/k210.dtsi b/arch/riscv/dts/k210.dtsi index 2546c7d4e0..fc7986b326 100644 --- a/arch/riscv/dts/k210.dtsi +++ b/arch/riscv/dts/k210.dtsi @@ -5,6 +5,7 @@
#include <dt-bindings/clock/k210-sysctl.h> #include <dt-bindings/mfd/k210-sysctl.h> +#include <dt-bindings/pinctrl/k210-pinctrl.h> #include <dt-bindings/reset/k210-sysctl.h>
/ { @@ -367,7 +368,18 @@ reg = <0x502B0000 0x100>; clocks = <&sysclk K210_CLK_FPIOA>; resets = <&sysrst K210_RST_FPIOA>; + kendryte,sysctl = <&sysctl>; + kendryte,power-offset = <K210_SYSCTL_POWER_SEL>; + pinctrl-0 = <&fpioa_jtag>; + pinctrl-names = "default"; status = "disabled"; + + fpioa_jtag: jtag { + pinmux = <K210_FPIOA(0, K210_PCF_JTAG_TCLK)>, + <K210_FPIOA(1, K210_PCF_JTAG_TDI)>, + <K210_FPIOA(2, K210_PCF_JTAG_TMS)>, + <K210_FPIOA(3, K210_PCF_JTAG_TDO)>; + }; };
sha256: sha256@502C0000 {
This patch adds the necessary configs and docs for FPIOA and GPIO support on the K210.
Changes in v3: - Document pins 6 and 7 as not set
Changes in v2: - Remove SPI flash related Kconfig settings
board/sipeed/maix/Kconfig | 9 ++++++ doc/board/sipeed/maix.rst | 64 +++++++++++++++++++++++++++++++++++++-- 2 files changed, 71 insertions(+), 2 deletions(-)
diff --git a/board/sipeed/maix/Kconfig b/board/sipeed/maix/Kconfig index 0cdcd32adc..4c42dd2087 100644 --- a/board/sipeed/maix/Kconfig +++ b/board/sipeed/maix/Kconfig @@ -44,4 +44,13 @@ config BOARD_SPECIFIC_OPTIONS imply RESET_SYSCON imply SYSRESET imply SYSRESET_SYSCON + imply PINCTRL + imply PINCONF + imply PINCTRL_K210 + imply DM_GPIO + imply DWAPB_GPIO + imply SIFIVE_GPIO + imply CMD_GPIO + imply LED + imply LED_GPIO endif diff --git a/doc/board/sipeed/maix.rst b/doc/board/sipeed/maix.rst index 06e0008b9f..1865e2adfb 100644 --- a/doc/board/sipeed/maix.rst +++ b/doc/board/sipeed/maix.rst @@ -132,7 +132,7 @@ To run legacy images, use the ``bootm`` command: Load Address: 80000000 Entry Point: 80000000
- $ picocom -b 115200 /dev/ttyUSB0i + $ picocom -b 115200 /dev/ttyUSB0 => loady ## Ready for binary (ymodem) download to 0x80000000 at 115200 bps... C @@ -163,6 +163,66 @@ To run legacy images, use the ``bootm`` command: argv[0] = "<NULL>" Hit any key to exit ...
+Pin Assignment +-------------- + +The K210 contains a Fully Programmable I/O Array (FPIOA), which can remap any of +its 256 input functions to any any of 48 output pins. The following table has +the default pin assignments for the BitM. + +===== ========== ======= +Pin Function Comment +===== ========== ======= +IO_0 JTAG_TCLK +IO_1 JTAG_TDI +IO_2 JTAG_TMS +IO_3 JTAG_TDO +IO_4 UARTHS_RX +IO_5 UARTHS_TX +IO_6 Not set +IO_7 Not set +IO_8 GPIO_0 +IO_9 GPIO_1 +IO_10 GPIO_2 +IO_11 GPIO_3 +IO_12 GPIO_4 Green LED +IO_13 GPIO_5 Red LED +IO_14 GPIO_6 Blue LED +IO_15 GPIO_7 +IO_16 GPIOHS_0 ISP +IO_17 GPIOHS_1 +IO_18 I2S0_SCLK MIC CLK +IO_19 I2S0_WS MIC WS +IO_20 I2S0_IN_D0 MIC SD +IO_21 GPIOHS_5 +IO_22 GPIOHS_6 +IO_23 GPIOHS_7 +IO_24 GPIOHS_8 +IO_25 GPIOHS_9 +IO_26 SPI1_D1 MMC MISO +IO_27 SPI1_SCLK MMC CLK +IO_28 SPI1_D0 MMC MOSI +IO_29 GPIOHS_13 MMC CS +IO_30 GPIOHS_14 +IO_31 GPIOHS_15 +IO_32 GPIOHS_16 +IO_33 GPIOHS_17 +IO_34 GPIOHS_18 +IO_35 GPIOHS_19 +IO_36 GPIOHS_20 Panel CS +IO_37 GPIOHS_21 Panel RST +IO_38 GPIOHS_22 Panel DC +IO_39 SPI0_SCK Panel WR +IO_40 SCCP_SDA +IO_41 SCCP_SCLK +IO_42 DVP_RST +IO_43 DVP_VSYNC +IO_44 DVP_PWDN +IO_45 DVP_HSYNC +IO_46 DVP_XCLK +IO_47 DVP_PCLK +===== ========== ======= + Over- and Under-clocking ------------------------
@@ -294,5 +354,5 @@ Address Size Description 0x8801C000 0x1000 riscv priv spec 1.9 config 0x8801D000 0x2000 flattened device tree (contains only addresses and interrupts) -0x8801f000 0x1000 credits +0x8801F000 0x1000 credits ========== ========= ===========
Sean Anderson
