[PATCH 0/6] imx: imx6ul: kontron-sl-mx6ul: Fixes and improvements
This series fixes some issues with the kontron-sl-mx6ul board configuration. It also syncs devicetrees with changes in the Linux kernel.
Notes:
* This series is based on imx/master and fixes the previously merged sync patch from Marcel [1]. * The devicetree changes this is based on are still pending in Linux (see [2]).
[1] https://patchwork.ozlabs.org/project/uboot/patch/20220721132748.1052244-9-ma... [2] https://patchwork.kernel.org/project/linux-arm-kernel/cover/20220815082814.2...
Frieder Schrempf (6): Makefile: Make flash.bin target available for all platforms imx: imx6ul: kontron-sl-mx6ul: Enable migrated Kconfig options imx: imx6ul: kontron-sl-mx6ul: Fix CONFIG_ENV_SPI_BUS imx: imx6ul: kontron-sl-mx6ul: Select correct boot and env device imx: imx6ul: kontron-sl-mx6ul: Migrate to use CONFIG_EXTRA_ENV_TEXT imx: imx6ul: kontron-sl-mx6ul: Sync devicetrees
Makefile | 4 +- arch/arm/dts/Makefile | 4 +- arch/arm/dts/imx6ul-kontron-bl-43.dts | 103 +++++ ...i => imx6ul-kontron-bl-common-u-boot.dtsi} | 0 ...x-s.dtsi => imx6ul-kontron-bl-common.dtsi} | 0 ...oot.dtsi => imx6ul-kontron-bl-u-boot.dtsi} | 2 +- ...tron-n631x-s.dts => imx6ul-kontron-bl.dts} | 9 +- arch/arm/dts/imx6ul-kontron-n6x1x-s.dts | 423 ------------------ ...mon.dtsi => imx6ul-kontron-sl-common.dtsi} | 15 + ...-n631x-som.dtsi => imx6ul-kontron-sl.dtsi} | 6 +- ...ot.dtsi => imx6ull-kontron-bl-u-boot.dtsi} | 2 +- arch/arm/dts/imx6ull-kontron-bl.dts | 15 + arch/arm/dts/imx6ull-kontron-n641x-s.dts | 16 - ...n641x-som.dtsi => imx6ull-kontron-sl.dtsi} | 6 +- board/kontron/sl-mx6ul/MAINTAINERS | 6 +- board/kontron/sl-mx6ul/Makefile | 2 + board/kontron/sl-mx6ul/sl-mx6ul-common.c | 24 + board/kontron/sl-mx6ul/sl-mx6ul-common.h | 11 + board/kontron/sl-mx6ul/sl-mx6ul.c | 15 + board/kontron/sl-mx6ul/sl-mx6ul.env | 4 + board/kontron/sl-mx6ul/spl.c | 39 +- configs/kontron-sl-mx6ul_defconfig | 13 +- include/configs/kontron-sl-mx6ul.h | 10 +- 23 files changed, 242 insertions(+), 487 deletions(-) create mode 100644 arch/arm/dts/imx6ul-kontron-bl-43.dts rename arch/arm/dts/{imx6ul-kontron-n6x1x-s-u-boot.dtsi => imx6ul-kontron-bl-common-u-boot.dtsi} (100%) rename arch/arm/dts/{imx6ul-kontron-n6x1x-s.dtsi => imx6ul-kontron-bl-common.dtsi} (100%) rename arch/arm/dts/{imx6ul-kontron-n631x-s-u-boot.dtsi => imx6ul-kontron-bl-u-boot.dtsi} (75%) rename arch/arm/dts/{imx6ul-kontron-n631x-s.dts => imx6ul-kontron-bl.dts} (52%) delete mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s.dts rename arch/arm/dts/{imx6ul-kontron-n6x1x-som-common.dtsi => imx6ul-kontron-sl-common.dtsi} (90%) rename arch/arm/dts/{imx6ul-kontron-n631x-som.dtsi => imx6ul-kontron-sl.dtsi} (62%) rename arch/arm/dts/{imx6ull-kontron-n641x-s-u-boot.dtsi => imx6ull-kontron-bl-u-boot.dtsi} (75%) create mode 100644 arch/arm/dts/imx6ull-kontron-bl.dts delete mode 100644 arch/arm/dts/imx6ull-kontron-n641x-s.dts rename arch/arm/dts/{imx6ull-kontron-n641x-som.dtsi => imx6ull-kontron-sl.dtsi} (55%) create mode 100644 board/kontron/sl-mx6ul/sl-mx6ul-common.c create mode 100644 board/kontron/sl-mx6ul/sl-mx6ul-common.h create mode 100644 board/kontron/sl-mx6ul/sl-mx6ul.env
There is no reason for restricting the use of the flash.bin target to the i.MX8 platform. Others can benefit from this as well.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- Makefile | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/Makefile b/Makefile index ff25f929748..cb8ccdea783 100644 --- a/Makefile +++ b/Makefile @@ -1546,7 +1546,7 @@ tpl/u-boot-with-tpl.bin: tpl/u-boot-tpl.bin u-boot.bin FORCE SPL: spl/u-boot-spl.bin FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@
-ifeq ($(CONFIG_ARCH_IMX8M)$(CONFIG_ARCH_IMX8), y) +#ifeq ($(CONFIG_ARCH_IMX8M)$(CONFIG_ARCH_IMX8), y) ifeq ($(CONFIG_SPL_LOAD_IMX_CONTAINER), y) u-boot.cnt: u-boot.bin FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ @@ -1562,7 +1562,7 @@ flash.bin: spl/u-boot-spl.bin u-boot.itb FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@ endif endif -endif +#endif
u-boot.uim: u-boot.bin FORCE $(Q)$(MAKE) $(build)=arch/arm/mach-imx $@
From: Frieder Schrempf frieder.schrempf@kontron.de There is no reason for restricting the use of the flash.bin target to the i.MX8 platform. Others can benefit from this as well. Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de
Best regards, Stefano Babic
The board support was merged at the same time as some Kconfig options for SPL were migrated/renamed. As a result some essential features like serial output, MMC support, etc. are currently missing. Fix this by enabling the required options.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- configs/kontron-sl-mx6ul_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/kontron-sl-mx6ul_defconfig b/configs/kontron-sl-mx6ul_defconfig index f9cebf9e9c9..664c55e9eb0 100644 --- a/configs/kontron-sl-mx6ul_defconfig +++ b/configs/kontron-sl-mx6ul_defconfig @@ -14,8 +14,12 @@ CONFIG_TARGET_KONTRON_MX6UL=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="imx6ul-kontron-n631x-s" CONFIG_SPL_TEXT_BASE=0x00908000 +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y CONFIG_BOOTCOUNT_BOOTLIMIT=3 CONFIG_SPL=y +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_DISTRO_DEFAULTS=y @@ -26,11 +30,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_BOARD_TYPES=y CONFIG_BOARD_EARLY_INIT_F=y +CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_LEGACY_IMAGE_FORMAT=y CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK=y CONFIG_SYS_SPL_MALLOC=y +CONFIG_SPL_SPI_LOAD=y +CONFIG_SYS_SPI_U_BOOT_OFFS=0x11400 CONFIG_SPL_USB_HOST=y CONFIG_SPL_USB_GADGET=y +CONFIG_SPL_USB_SDP_SUPPORT=y CONFIG_SPL_WATCHDOG=y CONFIG_SYS_MAXARGS=32 CONFIG_SYS_PBSIZE=532
From: Frieder Schrempf frieder.schrempf@kontron.de The board support was merged at the same time as some Kconfig options for SPL were migrated/renamed. As a result some essential features like serial output, MMC support, etc. are currently missing. Fix this by enabling the required options. Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de
The SPI NOR is on ECSPI1 so CONFIG_ENV_SPI_BUS should be 1 to detect the environment on the SPI NOR.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- configs/kontron-sl-mx6ul_defconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/configs/kontron-sl-mx6ul_defconfig b/configs/kontron-sl-mx6ul_defconfig index 664c55e9eb0..4eb10bec0ee 100644 --- a/configs/kontron-sl-mx6ul_defconfig +++ b/configs/kontron-sl-mx6ul_defconfig @@ -64,7 +64,6 @@ CONFIG_OF_LIST="imx6ul-kontron-n631x-s imx6ull-kontron-n641x-s" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y -CONFIG_ENV_SPI_BUS=2 CONFIG_USE_ETHPRIME=y CONFIG_ETHPRIME="eth0" CONFIG_BOOTCOUNT_LIMIT=y
From: Frieder Schrempf frieder.schrempf@kontron.de The SPI NOR is on ECSPI1 so CONFIG_ENV_SPI_BUS should be 1 to detect the environment on the SPI NOR. Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de
Instead of checking both, SPI NOR and MMC for loading U-Boot proper and the environment, implement a way to detect the actual boot device even if the BootROM doesn't report it and we can't rely solely on the fuse settings, as by default we use MMC as primary boot device and boot from SPI NOR via the secondary fallback device (EEPROM Recovery Mode).
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- board/kontron/sl-mx6ul/Makefile | 2 ++ board/kontron/sl-mx6ul/sl-mx6ul-common.c | 24 ++++++++++++++++++++++++ board/kontron/sl-mx6ul/sl-mx6ul-common.h | 11 +++++++++++ board/kontron/sl-mx6ul/sl-mx6ul.c | 15 +++++++++++++++ board/kontron/sl-mx6ul/spl.c | 23 ++++++++++++++--------- 5 files changed, 66 insertions(+), 9 deletions(-) create mode 100644 board/kontron/sl-mx6ul/sl-mx6ul-common.c create mode 100644 board/kontron/sl-mx6ul/sl-mx6ul-common.h
diff --git a/board/kontron/sl-mx6ul/Makefile b/board/kontron/sl-mx6ul/Makefile index cae273c9309..6af5f65450a 100644 --- a/board/kontron/sl-mx6ul/Makefile +++ b/board/kontron/sl-mx6ul/Makefile @@ -6,3 +6,5 @@ obj-y := spl.o else obj-y := sl-mx6ul.o endif + +obj-y += sl-mx6ul-common.o diff --git a/board/kontron/sl-mx6ul/sl-mx6ul-common.c b/board/kontron/sl-mx6ul/sl-mx6ul-common.c new file mode 100644 index 00000000000..1f24acdfa3d --- /dev/null +++ b/board/kontron/sl-mx6ul/sl-mx6ul-common.c @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#include <asm/types.h> +#include <asm/arch/sys_proto.h> + +#include <sl-mx6ul-common.h> + +bool sl_mx6ul_is_spi_nor_boot(void) +{ + u32 bmode = imx6_src_get_boot_mode(); + + /* + * Check if "EEPROM Recovery" enabled and ECSPI2_CONREG not 0x0. + * If this is the case and U-Boot didn't initialize the SPI bus + * yet, we can safely assume that we are booting from SPI NOR. + */ + if ((bmode & 0x40000000) && readl(0x0200c008)) + return true; + + return false; +} diff --git a/board/kontron/sl-mx6ul/sl-mx6ul-common.h b/board/kontron/sl-mx6ul/sl-mx6ul-common.h new file mode 100644 index 00000000000..58a0e77a8b0 --- /dev/null +++ b/board/kontron/sl-mx6ul/sl-mx6ul-common.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2022 Kontron Electronics GmbH + */ + +#ifndef __SL_MX6UL_COMMON_H +#define __SL_MX6UL_COMMON_H + +bool sl_mx6ul_is_spi_nor_boot(void); + +#endif // __SL_MX6UL_COMMON_H diff --git a/board/kontron/sl-mx6ul/sl-mx6ul.c b/board/kontron/sl-mx6ul/sl-mx6ul.c index 79d4d8753b0..0f45ea84fc7 100644 --- a/board/kontron/sl-mx6ul/sl-mx6ul.c +++ b/board/kontron/sl-mx6ul/sl-mx6ul.c @@ -6,8 +6,10 @@ #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/global_data.h> +#include <env_internal.h> #include <fdt_support.h> #include <phy.h> +#include <sl-mx6ul-common.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -83,3 +85,16 @@ int board_init(void)
return 0; } + +enum env_location env_get_location(enum env_operation op, int prio) +{ + if (prio) + return ENVL_UNKNOWN; + + if (sl_mx6ul_is_spi_nor_boot() && CONFIG_IS_ENABLED(ENV_IS_IN_SPI_FLASH)) + return ENVL_SPI_FLASH; + else if (CONFIG_IS_ENABLED(ENV_IS_IN_MMC)) + return ENVL_MMC; + + return ENVL_NOWHERE; +} diff --git a/board/kontron/sl-mx6ul/spl.c b/board/kontron/sl-mx6ul/spl.c index 12b0352146f..ba6915c898c 100644 --- a/board/kontron/sl-mx6ul/spl.c +++ b/board/kontron/sl-mx6ul/spl.c @@ -17,6 +17,7 @@ #include <linux/sizes.h> #include <linux/errno.h> #include <mmc.h> +#include <sl-mx6ul-common.h>
@@ -339,26 +340,30 @@ void board_boot_order(u32 *spl_boot_list)
/* * The default boot fuse settings use the SD card (MMC1) as primary - * boot device, but allow SPI NOR as a fallback boot device. - * We can't detect the fallback case and spl_boot_device() will return - * BOOT_DEVICE_MMC1 despite the actual boot device being SPI NOR. - * Therefore we try to load U-Boot proper vom SPI NOR after loading - * from MMC has failed. + * boot device, but allow SPI NOR as a fallback boot device. There + * is no proper way to detect if the fallback was used. Therefore + * we read the ECSPI2_CONREG register and see if it differs from the + * reset value 0x0. If that's the case we can assume that the BootROM + * has successfully probed the SPI NOR. */ - spl_boot_list[0] = bootdev; - switch (bootdev) { case BOOT_DEVICE_MMC1: case BOOT_DEVICE_MMC2: - spl_boot_list[1] = BOOT_DEVICE_SPI; + if (sl_mx6ul_is_spi_nor_boot()) { + spl_boot_list[0] = BOOT_DEVICE_SPI; + return; + } break; } + + spl_boot_list[0] = bootdev; }
int board_early_init_f(void) { setup_iomux_uart(); - setup_spi(); + if (sl_mx6ul_is_spi_nor_boot()) + setup_spi();
return 0; }
From: Frieder Schrempf frieder.schrempf@kontron.de Instead of checking both, SPI NOR and MMC for loading U-Boot proper and the environment, implement a way to detect the actual boot device even if the BootROM doesn't report it and we can't rely solely on the fuse settings, as by default we use MMC as primary boot device and boot from SPI NOR via the secondary fallback device (EEPROM Recovery Mode). Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de
Move the environment from the board header to a separate text file and also drop those variables that are already set in env_default.h from the Kconfig options or are not needed anymore.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- board/kontron/sl-mx6ul/sl-mx6ul.env | 4 ++++ include/configs/kontron-sl-mx6ul.h | 10 +--------- 2 files changed, 5 insertions(+), 9 deletions(-) create mode 100644 board/kontron/sl-mx6ul/sl-mx6ul.env
diff --git a/board/kontron/sl-mx6ul/sl-mx6ul.env b/board/kontron/sl-mx6ul/sl-mx6ul.env new file mode 100644 index 00000000000..9484e739dd4 --- /dev/null +++ b/board/kontron/sl-mx6ul/sl-mx6ul.env @@ -0,0 +1,4 @@ +kernel_addr_r=0x82000000 +ramdisk_addr_r=0x88080000 +pxefile_addr_r=0x80100000 +scriptaddr=0x80100000 diff --git a/include/configs/kontron-sl-mx6ul.h b/include/configs/kontron-sl-mx6ul.h index 7aac5d3f5a1..f0586f7f721 100644 --- a/include/configs/kontron-sl-mx6ul.h +++ b/include/configs/kontron-sl-mx6ul.h @@ -49,14 +49,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2 #endif
-#define CONFIG_EXTRA_ENV_SETTINGS \ - "kernel_addr_r=0x82000000\0" \ - "ramdisk_addr_r=0x88080000\0" \ - "pxefile_addr_r=0x80100000\0" \ - "scriptaddr=0x80100000\0" \ - "bootdelay=3\0" \ - "ethact=" CONFIG_ETHPRIME "\0" \ - "hostname=" CONFIG_HOSTNAME "\0" \ - BOOTENV +#define CONFIG_EXTRA_ENV_SETTINGS BOOTENV
#endif /* __KONTRON_MX6UL_CONFIG_H */
From: Frieder Schrempf frieder.schrempf@kontron.de Move the environment from the board header to a separate text file and also drop those variables that are already set in env_default.h from the Kconfig options or are not needed anymore. Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de
Sync the devicetrees with Linux and adjust the board names.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de --- Note:
* The devicetree changes this is based on are still pending in Linux (see https://patchwork.kernel.org/project/linux-arm-kernel/cover/20220815082814.2...). --- arch/arm/dts/Makefile | 4 +- arch/arm/dts/imx6ul-kontron-bl-43.dts | 103 +++++ ...i => imx6ul-kontron-bl-common-u-boot.dtsi} | 0 ...x-s.dtsi => imx6ul-kontron-bl-common.dtsi} | 0 ...oot.dtsi => imx6ul-kontron-bl-u-boot.dtsi} | 2 +- ...tron-n631x-s.dts => imx6ul-kontron-bl.dts} | 9 +- arch/arm/dts/imx6ul-kontron-n6x1x-s.dts | 423 ------------------ ...mon.dtsi => imx6ul-kontron-sl-common.dtsi} | 15 + ...-n631x-som.dtsi => imx6ul-kontron-sl.dtsi} | 6 +- ...ot.dtsi => imx6ull-kontron-bl-u-boot.dtsi} | 2 +- arch/arm/dts/imx6ull-kontron-bl.dts | 15 + arch/arm/dts/imx6ull-kontron-n641x-s.dts | 16 - ...n641x-som.dtsi => imx6ull-kontron-sl.dtsi} | 6 +- board/kontron/sl-mx6ul/MAINTAINERS | 6 +- board/kontron/sl-mx6ul/spl.c | 16 +- configs/kontron-sl-mx6ul_defconfig | 4 +- 16 files changed, 161 insertions(+), 466 deletions(-) create mode 100644 arch/arm/dts/imx6ul-kontron-bl-43.dts rename arch/arm/dts/{imx6ul-kontron-n6x1x-s-u-boot.dtsi => imx6ul-kontron-bl-common-u-boot.dtsi} (100%) rename arch/arm/dts/{imx6ul-kontron-n6x1x-s.dtsi => imx6ul-kontron-bl-common.dtsi} (100%) rename arch/arm/dts/{imx6ul-kontron-n631x-s-u-boot.dtsi => imx6ul-kontron-bl-u-boot.dtsi} (75%) rename arch/arm/dts/{imx6ul-kontron-n631x-s.dts => imx6ul-kontron-bl.dts} (52%) delete mode 100644 arch/arm/dts/imx6ul-kontron-n6x1x-s.dts rename arch/arm/dts/{imx6ul-kontron-n6x1x-som-common.dtsi => imx6ul-kontron-sl-common.dtsi} (90%) rename arch/arm/dts/{imx6ul-kontron-n631x-som.dtsi => imx6ul-kontron-sl.dtsi} (62%) rename arch/arm/dts/{imx6ull-kontron-n641x-s-u-boot.dtsi => imx6ull-kontron-bl-u-boot.dtsi} (75%) create mode 100644 arch/arm/dts/imx6ull-kontron-bl.dts delete mode 100644 arch/arm/dts/imx6ull-kontron-n641x-s.dts rename arch/arm/dts/{imx6ull-kontron-n641x-som.dtsi => imx6ull-kontron-sl.dtsi} (55%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 48cb1f52b7a..d075fcf953c 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -879,8 +879,8 @@ dtb-$(CONFIG_MX6UL) += \ imx6ul-phytec-segin-ff-rdk-nand.dtb \ imx6ul-pico-hobbit.dtb \ imx6ul-pico-pi.dtb \ - imx6ul-kontron-n631x-s.dtb \ - imx6ull-kontron-n641x-s.dtb + imx6ul-kontron-bl.dtb \ + imx6ull-kontron-bl.dtb
dtb-$(CONFIG_MX6ULL) += \ imx6ull-14x14-evk.dtb \ diff --git a/arch/arm/dts/imx6ul-kontron-bl-43.dts b/arch/arm/dts/imx6ul-kontron-bl-43.dts new file mode 100644 index 00000000000..0c643706a15 --- /dev/null +++ b/arch/arm/dts/imx6ul-kontron-bl-43.dts @@ -0,0 +1,103 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2017 exceet electronics GmbH + * Copyright (C) 2018 Kontron Electronics GmbH + * Copyright (c) 2019 Krzysztof Kozlowski krzk@kernel.org + */ + +#include "imx6ul-kontron-bl.dts" + +/ { + model = "Kontron BL i.MX6UL 43 (N631X S 43)"; + compatible = "kontron,bl-imx6ul-43", "kontron,bl-imx6ul", + "kontron,sl-imx6ul", "fsl,imx6ul"; + + backlight { + compatible = "pwm-backlight"; + pwms = <&pwm7 0 5000000>; + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <6>; + status = "okay"; + }; +}; + +&i2c4 { + touchscreen@5d { + compatible = "goodix,gt928"; + reg = <0x5d>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_cap_touch>; + interrupt-parent = <&gpio5>; + interrupts = <6 IRQ_TYPE_LEVEL_LOW>; + reset-gpios = <&gpio5 8 GPIO_ACTIVE_HIGH>; + irq-gpios = <&gpio5 6 GPIO_ACTIVE_HIGH>; + }; +}; + +&lcdif { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_lcdif_dat &pinctrl_lcdif_ctrl>; + /* Leave status disabled because of missing display panel node */ +}; + +&pwm7 { + #pwm-cells = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_pwm7>; + status = "okay"; +}; + +&iomuxc { + pinctrl_cap_touch: captouchgrp { + fsl,pins = < + MX6UL_PAD_SNVS_TAMPER6__GPIO5_IO06 0x1b0b0 /* Touch Interrupt */ + MX6UL_PAD_SNVS_TAMPER7__GPIO5_IO07 0x1b0b0 /* Touch Reset */ + MX6UL_PAD_SNVS_TAMPER8__GPIO5_IO08 0x1b0b0 /* Touch Wake */ + >; + }; + + pinctrl_lcdif_ctrl: lcdifctrlgrp { + fsl,pins = < + MX6UL_PAD_LCD_CLK__LCDIF_CLK 0x79 + MX6UL_PAD_LCD_ENABLE__LCDIF_ENABLE 0x79 + MX6UL_PAD_LCD_HSYNC__LCDIF_HSYNC 0x79 + MX6UL_PAD_LCD_VSYNC__LCDIF_VSYNC 0x79 + MX6UL_PAD_LCD_RESET__LCDIF_RESET 0x79 + >; + }; + + pinctrl_lcdif_dat: lcdifdatgrp { + fsl,pins = < + MX6UL_PAD_LCD_DATA00__LCDIF_DATA00 0x79 + MX6UL_PAD_LCD_DATA01__LCDIF_DATA01 0x79 + MX6UL_PAD_LCD_DATA02__LCDIF_DATA02 0x79 + MX6UL_PAD_LCD_DATA03__LCDIF_DATA03 0x79 + MX6UL_PAD_LCD_DATA04__LCDIF_DATA04 0x79 + MX6UL_PAD_LCD_DATA05__LCDIF_DATA05 0x79 + MX6UL_PAD_LCD_DATA06__LCDIF_DATA06 0x79 + MX6UL_PAD_LCD_DATA07__LCDIF_DATA07 0x79 + MX6UL_PAD_LCD_DATA08__LCDIF_DATA08 0x79 + MX6UL_PAD_LCD_DATA09__LCDIF_DATA09 0x79 + MX6UL_PAD_LCD_DATA10__LCDIF_DATA10 0x79 + MX6UL_PAD_LCD_DATA11__LCDIF_DATA11 0x79 + MX6UL_PAD_LCD_DATA12__LCDIF_DATA12 0x79 + MX6UL_PAD_LCD_DATA13__LCDIF_DATA13 0x79 + MX6UL_PAD_LCD_DATA14__LCDIF_DATA14 0x79 + MX6UL_PAD_LCD_DATA15__LCDIF_DATA15 0x79 + MX6UL_PAD_LCD_DATA16__LCDIF_DATA16 0x79 + MX6UL_PAD_LCD_DATA17__LCDIF_DATA17 0x79 + MX6UL_PAD_LCD_DATA18__LCDIF_DATA18 0x79 + MX6UL_PAD_LCD_DATA19__LCDIF_DATA19 0x79 + MX6UL_PAD_LCD_DATA20__LCDIF_DATA20 0x79 + MX6UL_PAD_LCD_DATA21__LCDIF_DATA21 0x79 + MX6UL_PAD_LCD_DATA22__LCDIF_DATA22 0x79 + MX6UL_PAD_LCD_DATA23__LCDIF_DATA23 0x79 + >; + }; + + pinctrl_pwm7: pwm7grp { + fsl,pins = < + MX6UL_PAD_CSI_VSYNC__PWM7_OUT 0x110b0 + >; + }; +}; diff --git a/arch/arm/dts/imx6ul-kontron-n6x1x-s-u-boot.dtsi b/arch/arm/dts/imx6ul-kontron-bl-common-u-boot.dtsi similarity index 100% rename from arch/arm/dts/imx6ul-kontron-n6x1x-s-u-boot.dtsi rename to arch/arm/dts/imx6ul-kontron-bl-common-u-boot.dtsi diff --git a/arch/arm/dts/imx6ul-kontron-n6x1x-s.dtsi b/arch/arm/dts/imx6ul-kontron-bl-common.dtsi similarity index 100% rename from arch/arm/dts/imx6ul-kontron-n6x1x-s.dtsi rename to arch/arm/dts/imx6ul-kontron-bl-common.dtsi diff --git a/arch/arm/dts/imx6ul-kontron-n631x-s-u-boot.dtsi b/arch/arm/dts/imx6ul-kontron-bl-u-boot.dtsi similarity index 75% rename from arch/arm/dts/imx6ul-kontron-n631x-s-u-boot.dtsi rename to arch/arm/dts/imx6ul-kontron-bl-u-boot.dtsi index d3f013c58cf..daf4175200c 100644 --- a/arch/arm/dts/imx6ul-kontron-n631x-s-u-boot.dtsi +++ b/arch/arm/dts/imx6ul-kontron-bl-u-boot.dtsi @@ -4,4 +4,4 @@ * Copyright (C) 2018 Kontron Electronics GmbH */
-#include "imx6ul-kontron-n6x1x-s-u-boot.dtsi" +#include "imx6ul-kontron-bl-common-u-boot.dtsi" diff --git a/arch/arm/dts/imx6ul-kontron-n631x-s.dts b/arch/arm/dts/imx6ul-kontron-bl.dts similarity index 52% rename from arch/arm/dts/imx6ul-kontron-n631x-s.dts rename to arch/arm/dts/imx6ul-kontron-bl.dts index 407d2b1dab9..dadf6d3d5f5 100644 --- a/arch/arm/dts/imx6ul-kontron-n631x-s.dts +++ b/arch/arm/dts/imx6ul-kontron-bl.dts @@ -7,11 +7,10 @@
/dts-v1/;
-#include "imx6ul-kontron-n631x-som.dtsi" -#include "imx6ul-kontron-n6x1x-s.dtsi" +#include "imx6ul-kontron-sl.dtsi" +#include "imx6ul-kontron-bl-common.dtsi"
/ { - model = "Kontron N631X S"; - compatible = "kontron,imx6ul-n631x-s", "kontron,imx6ul-n631x-som", - "fsl,imx6ul"; + model = "Kontron BL i.MX6UL (N631X S)"; + compatible = "kontron,bl-imx6ul", "kontron,sl-imx6ul", "fsl,imx6ul"; }; diff --git a/arch/arm/dts/imx6ul-kontron-n6x1x-s.dts b/arch/arm/dts/imx6ul-kontron-n6x1x-s.dts deleted file mode 100644 index 84d8a717ab5..00000000000 --- a/arch/arm/dts/imx6ul-kontron-n6x1x-s.dts +++ /dev/null @@ -1,423 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (C) 2017 exceet electronics GmbH - * Copyright (C) 2018 Kontron Electronics GmbH - * Copyright (c) 2019 Krzysztof Kozlowski krzk@kernel.org - */ - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include "imx6ul-kontron-n6x1x-som.dtsi" - -/ { - gpio-leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_gpio_leds>; - - led1 { - label = "debug-led1"; - gpios = <&gpio1 30 GPIO_ACTIVE_LOW>; - default-state = "off"; - linux,default-trigger = "heartbeat"; - }; - - led2 { - label = "debug-led2"; - gpios = <&gpio5 3 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - - led3 { - label = "debug-led3"; - gpios = <&gpio5 2 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - }; - - pwm-beeper { - compatible = "pwm-beeper"; - pwms = <&pwm8 0 5000>; - }; - - reg_3v3: regulator-3v3 { - compatible = "regulator-fixed"; - regulator-name = "3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - reg_5v: regulator-5v { - compatible = "regulator-fixed"; - regulator-name = "5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - reg_usb_otg1_vbus: regulator-usb-otg1-vbus { - compatible = "regulator-fixed"; - regulator-name = "usb_otg1_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio1 4 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - - reg_vref_adc: regulator-vref-adc { - compatible = "regulator-fixed"; - regulator-name = "vref-adc"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; -}; - -&adc1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_adc1>; - num-channels = <3>; - vref-supply = <®_vref_adc>; - status = "okay"; -}; - -&can2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_flexcan2>; - status = "okay"; -}; - -&ecspi1 { - cs-gpios = <&gpio4 26 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_ecspi1>; - status = "okay"; - - eeprom@0 { - compatible = "anvo,anv32e61w", "atmel,at25"; - reg = <0>; - spi-max-frequency = <20000000>; - spi-cpha; - spi-cpol; - pagesize = <1>; - size = <8192>; - address-width = <16>; - }; -}; - -&fec1 { - pinctrl-0 = <&pinctrl_enet1>; - /delete-node/ mdio; -}; - -&fec2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_enet2 &pinctrl_enet2_mdio>; - phy-mode = "rmii"; - phy-handle = <ðphy2>; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy1: ethernet-phy@1 { - reg = <1>; - micrel,led-mode = <0>; - clocks = <&clks IMX6UL_CLK_ENET_REF>; - clock-names = "rmii-ref"; - }; - - ethphy2: ethernet-phy@2 { - reg = <2>; - micrel,led-mode = <0>; - clocks = <&clks IMX6UL_CLK_ENET2_REF>; - clock-names = "rmii-ref"; - }; - }; -}; - -&i2c1 { - clock-frequency = <100000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c1>; - status = "okay"; -}; - -&i2c4 { - clock-frequency = <100000>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_i2c4>; - status = "okay"; - - rtc@32 { - compatible = "epson,rx8900"; - reg = <0x32>; - }; -}; - -&pwm8 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pwm8>; - status = "okay"; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart1>; - status = "okay"; -}; - -&uart2 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart2>; - linux,rs485-enabled-at-boot-time; - rs485-rx-during-tx; - rs485-rts-active-low; - uart-has-rtscts; - status = "okay"; -}; - -&uart3 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart3>; - fsl,uart-has-rtscts; - status = "okay"; -}; - -&uart4 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_uart4>; - status = "okay"; -}; - -&usbotg1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usbotg1>; - dr_mode = "otg"; - srp-disable; - hnp-disable; - adp-disable; - over-current-active-low; - vbus-supply = <®_usb_otg1_vbus>; - status = "okay"; -}; - -&usbotg2 { - dr_mode = "host"; - disable-over-current; - vbus-supply = <®_5v>; - status = "okay"; -}; - -&usdhc1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_usdhc1>; - cd-gpios = <&gpio1 19 GPIO_ACTIVE_LOW>; - keep-power-in-suspend; - wakeup-source; - vmmc-supply = <®_3v3>; - voltage-ranges = <3300 3300>; - bus-width = <4>; - no-1-8-v; - status = "okay"; -}; - -&usdhc2 { - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc2>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>; - non-removable; - keep-power-in-suspend; - wakeup-source; - vmmc-supply = <®_3v3>; - voltage-ranges = <3300 3300>; - bus-width = <4>; - no-1-8-v; - status = "okay"; -}; - -&wdog1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_wdog>; - fsl,ext-reset-output; - status = "okay"; -}; - -&iomuxc { - pinctrl-0 = <&pinctrl_reset_out &pinctrl_gpio>; - - pinctrl_adc1: adc1grp { - fsl,pins = < - MX6UL_PAD_GPIO1_IO02__GPIO1_IO02 0xb0 - MX6UL_PAD_GPIO1_IO03__GPIO1_IO03 0xb0 - MX6UL_PAD_GPIO1_IO08__GPIO1_IO08 0xb0 - >; - }; - - pinctrl_ecspi1: ecspi1grp { - fsl,pins = < - MX6UL_PAD_CSI_DATA07__ECSPI1_MISO 0x100b1 - MX6UL_PAD_CSI_DATA06__ECSPI1_MOSI 0x100b1 - MX6UL_PAD_CSI_DATA04__ECSPI1_SCLK 0x100b1 - MX6UL_PAD_CSI_DATA05__GPIO4_IO26 0x100b1 /* ECSPI1-CS1 */ - >; - }; - - pinctrl_enet2: enet2grp { - fsl,pins = < - MX6UL_PAD_ENET2_RX_EN__ENET2_RX_EN 0x1b0b0 - MX6UL_PAD_ENET2_RX_ER__ENET2_RX_ER 0x1b0b0 - MX6UL_PAD_ENET2_RX_DATA0__ENET2_RDATA00 0x1b0b0 - MX6UL_PAD_ENET2_RX_DATA1__ENET2_RDATA01 0x1b0b0 - MX6UL_PAD_ENET2_TX_EN__ENET2_TX_EN 0x1b0b0 - MX6UL_PAD_ENET2_TX_DATA0__ENET2_TDATA00 0x1b0b0 - MX6UL_PAD_ENET2_TX_DATA1__ENET2_TDATA01 0x1b0b0 - MX6UL_PAD_ENET2_TX_CLK__ENET2_REF_CLK2 0x4001b009 - >; - }; - - pinctrl_enet2_mdio: enet2mdiogrp { - fsl,pins = < - MX6UL_PAD_GPIO1_IO07__ENET2_MDC 0x1b0b0 - MX6UL_PAD_GPIO1_IO06__ENET2_MDIO 0x1b0b0 - >; - }; - - pinctrl_flexcan2: flexcan2grp{ - fsl,pins = < - MX6UL_PAD_UART2_RTS_B__FLEXCAN2_RX 0x1b020 - MX6UL_PAD_UART2_CTS_B__FLEXCAN2_TX 0x1b020 - >; - }; - - pinctrl_gpio: gpiogrp { - fsl,pins = < - MX6UL_PAD_SNVS_TAMPER5__GPIO5_IO05 0x1b0b0 /* DOUT1 */ - MX6UL_PAD_SNVS_TAMPER4__GPIO5_IO04 0x1b0b0 /* DIN1 */ - MX6UL_PAD_SNVS_TAMPER1__GPIO5_IO01 0x1b0b0 /* DOUT2 */ - MX6UL_PAD_SNVS_TAMPER0__GPIO5_IO00 0x1b0b0 /* DIN2 */ - >; - }; - - pinctrl_gpio_leds: gpioledsgrp { - fsl,pins = < - MX6UL_PAD_UART5_TX_DATA__GPIO1_IO30 0x1b0b0 /* LED H14 */ - MX6UL_PAD_SNVS_TAMPER3__GPIO5_IO03 0x1b0b0 /* LED H15 */ - MX6UL_PAD_SNVS_TAMPER2__GPIO5_IO02 0x1b0b0 /* LED H16 */ - >; - }; - - pinctrl_i2c1: i2c1grp { - fsl,pins = < - MX6UL_PAD_CSI_PIXCLK__I2C1_SCL 0x4001b8b0 - MX6UL_PAD_CSI_MCLK__I2C1_SDA 0x4001b8b0 - >; - }; - - pinctrl_i2c4: i2c4grp { - fsl,pins = < - MX6UL_PAD_UART2_TX_DATA__I2C4_SCL 0x4001f8b0 - MX6UL_PAD_UART2_RX_DATA__I2C4_SDA 0x4001f8b0 - >; - }; - - pinctrl_pwm8: pwm8grp { - fsl,pins = < - MX6UL_PAD_CSI_HSYNC__PWM8_OUT 0x110b0 - >; - }; - - pinctrl_uart1: uart1grp { - fsl,pins = < - MX6UL_PAD_UART1_TX_DATA__UART1_DCE_TX 0x1b0b1 - MX6UL_PAD_UART1_RX_DATA__UART1_DCE_RX 0x1b0b1 - >; - }; - - pinctrl_uart2: uart2grp { - fsl,pins = < - MX6UL_PAD_NAND_DATA04__UART2_DCE_TX 0x1b0b1 - MX6UL_PAD_NAND_DATA05__UART2_DCE_RX 0x1b0b1 - MX6UL_PAD_NAND_DATA06__UART2_DCE_CTS 0x1b0b1 - /* - * mux unused RTS to make sure it doesn't cause - * any interrupts when it is undefined - */ - MX6UL_PAD_NAND_DATA07__UART2_DCE_RTS 0x1b0b1 - >; - }; - - pinctrl_uart3: uart3grp { - fsl,pins = < - MX6UL_PAD_UART3_TX_DATA__UART3_DCE_TX 0x1b0b1 - MX6UL_PAD_UART3_RX_DATA__UART3_DCE_RX 0x1b0b1 - MX6UL_PAD_UART3_CTS_B__UART3_DCE_CTS 0x1b0b1 - MX6UL_PAD_UART3_RTS_B__UART3_DCE_RTS 0x1b0b1 - >; - }; - - pinctrl_uart4: uart4grp { - fsl,pins = < - MX6UL_PAD_UART4_TX_DATA__UART4_DCE_TX 0x1b0b1 - MX6UL_PAD_UART4_RX_DATA__UART4_DCE_RX 0x1b0b1 - >; - }; - - pinctrl_usbotg1: usbotg1 { - fsl,pins = < - MX6UL_PAD_GPIO1_IO04__GPIO1_IO04 0x1b0b0 - >; - }; - - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - MX6UL_PAD_SD1_CMD__USDHC1_CMD 0x17059 - MX6UL_PAD_SD1_CLK__USDHC1_CLK 0x10059 - MX6UL_PAD_SD1_DATA0__USDHC1_DATA0 0x17059 - MX6UL_PAD_SD1_DATA1__USDHC1_DATA1 0x17059 - MX6UL_PAD_SD1_DATA2__USDHC1_DATA2 0x17059 - MX6UL_PAD_SD1_DATA3__USDHC1_DATA3 0x17059 - MX6UL_PAD_UART1_RTS_B__GPIO1_IO19 0x100b1 /* SD1_CD */ - >; - }; - - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x10059 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x17059 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x17059 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x17059 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x17059 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x17059 - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2-100mhzgrp { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x100b9 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x170b9 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x170b9 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x170b9 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x170b9 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x170b9 - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2-200mhzgrp { - fsl,pins = < - MX6UL_PAD_NAND_RE_B__USDHC2_CLK 0x100f9 - MX6UL_PAD_NAND_WE_B__USDHC2_CMD 0x170f9 - MX6UL_PAD_NAND_DATA00__USDHC2_DATA0 0x170f9 - MX6UL_PAD_NAND_DATA01__USDHC2_DATA1 0x170f9 - MX6UL_PAD_NAND_DATA02__USDHC2_DATA2 0x170f9 - MX6UL_PAD_NAND_DATA03__USDHC2_DATA3 0x170f9 - >; - }; - - pinctrl_wdog: wdoggrp { - fsl,pins = < - MX6UL_PAD_GPIO1_IO09__WDOG1_WDOG_ANY 0x30b0 - >; - }; -}; diff --git a/arch/arm/dts/imx6ul-kontron-n6x1x-som-common.dtsi b/arch/arm/dts/imx6ul-kontron-sl-common.dtsi similarity index 90% rename from arch/arm/dts/imx6ul-kontron-n6x1x-som-common.dtsi rename to arch/arm/dts/imx6ul-kontron-sl-common.dtsi index 09a83dbdf65..dcf88f61034 100644 --- a/arch/arm/dts/imx6ul-kontron-n6x1x-som-common.dtsi +++ b/arch/arm/dts/imx6ul-kontron-sl-common.dtsi @@ -11,6 +11,11 @@ chosen { stdout-path = &uart4; }; + + memory@80000000 { + reg = <0x80000000 0x10000000>; + device_type = "memory"; + }; };
&ecspi2 { @@ -55,6 +60,16 @@ pinctrl-names = "default"; pinctrl-0 = <&pinctrl_qspi>; status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-nand"; + spi-max-frequency = <104000000>; + spi-tx-bus-width = <4>; + spi-rx-bus-width = <4>; + reg = <0>; + }; };
&wdog1 { diff --git a/arch/arm/dts/imx6ul-kontron-n631x-som.dtsi b/arch/arm/dts/imx6ul-kontron-sl.dtsi similarity index 62% rename from arch/arm/dts/imx6ul-kontron-n631x-som.dtsi rename to arch/arm/dts/imx6ul-kontron-sl.dtsi index 9a1179814b7..0580d043e5a 100644 --- a/arch/arm/dts/imx6ul-kontron-n631x-som.dtsi +++ b/arch/arm/dts/imx6ul-kontron-sl.dtsi @@ -6,9 +6,9 @@ */
#include "imx6ul.dtsi" -#include "imx6ul-kontron-n6x1x-som-common.dtsi" +#include "imx6ul-kontron-sl-common.dtsi"
/ { - model = "Kontron N631X SOM"; - compatible = "kontron,imx6ul-n631x-som", "fsl,imx6ul"; + model = "Kontron SL i.MX6UL (N631X SOM)"; + compatible = "kontron,sl-imx6ul", "fsl,imx6ul"; }; diff --git a/arch/arm/dts/imx6ull-kontron-n641x-s-u-boot.dtsi b/arch/arm/dts/imx6ull-kontron-bl-u-boot.dtsi similarity index 75% rename from arch/arm/dts/imx6ull-kontron-n641x-s-u-boot.dtsi rename to arch/arm/dts/imx6ull-kontron-bl-u-boot.dtsi index d3f013c58cf..daf4175200c 100644 --- a/arch/arm/dts/imx6ull-kontron-n641x-s-u-boot.dtsi +++ b/arch/arm/dts/imx6ull-kontron-bl-u-boot.dtsi @@ -4,4 +4,4 @@ * Copyright (C) 2018 Kontron Electronics GmbH */
-#include "imx6ul-kontron-n6x1x-s-u-boot.dtsi" +#include "imx6ul-kontron-bl-common-u-boot.dtsi" diff --git a/arch/arm/dts/imx6ull-kontron-bl.dts b/arch/arm/dts/imx6ull-kontron-bl.dts new file mode 100644 index 00000000000..fa016465cdb --- /dev/null +++ b/arch/arm/dts/imx6ull-kontron-bl.dts @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2017 exceet electronics GmbH + * Copyright (C) 2019 Kontron Electronics GmbH + */ + +/dts-v1/; + +#include "imx6ull-kontron-sl.dtsi" +#include "imx6ul-kontron-bl-common.dtsi" + +/ { + model = "Kontron BL i.MX6ULL (N641X S)"; + compatible = "kontron,bl-imx6ull", "kontron,sl-imx6ull", "fsl,imx6ull"; +}; diff --git a/arch/arm/dts/imx6ull-kontron-n641x-s.dts b/arch/arm/dts/imx6ull-kontron-n641x-s.dts deleted file mode 100644 index 01aeea40853..00000000000 --- a/arch/arm/dts/imx6ull-kontron-n641x-s.dts +++ /dev/null @@ -1,16 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (C) 2017 exceet electronics GmbH - * Copyright (C) 2019 Kontron Electronics GmbH - */ - -/dts-v1/; - -#include "imx6ull-kontron-n641x-som.dtsi" -#include "imx6ul-kontron-n6x1x-s.dtsi" - -/ { - model = "Kontron N641X S"; - compatible = "kontron,imx6ull-n641x-s", "kontron,imx6ull-n641x-som", - "fsl,imx6ull"; -}; diff --git a/arch/arm/dts/imx6ull-kontron-n641x-som.dtsi b/arch/arm/dts/imx6ull-kontron-sl.dtsi similarity index 55% rename from arch/arm/dts/imx6ull-kontron-n641x-som.dtsi rename to arch/arm/dts/imx6ull-kontron-sl.dtsi index 8a64aa9a275..93f10eb3494 100644 --- a/arch/arm/dts/imx6ull-kontron-n641x-som.dtsi +++ b/arch/arm/dts/imx6ull-kontron-sl.dtsi @@ -5,9 +5,9 @@ */
#include "imx6ull.dtsi" -#include "imx6ul-kontron-n6x1x-som-common.dtsi" +#include "imx6ul-kontron-sl-common.dtsi"
/ { - model = "Kontron N641X SOM"; - compatible = "kontron,imx6ull-n641x-som", "fsl,imx6ull"; + model = "Kontron SL i.MX6ULL (N641X SOM)"; + compatible = "kontron,sl-imx6ull", "fsl,imx6ull"; }; diff --git a/board/kontron/sl-mx6ul/MAINTAINERS b/board/kontron/sl-mx6ul/MAINTAINERS index 0f8b5512d64..9e9dff0361c 100644 --- a/board/kontron/sl-mx6ul/MAINTAINERS +++ b/board/kontron/sl-mx6ul/MAINTAINERS @@ -1,8 +1,10 @@ Kontron SL/BL i.MX6UL/ULL Boards (N63xx/N64xx) M: Frieder Schrempf frieder.schrempf@kontron.de S: Maintained -F: arch/arm/dts/imx6ul-kontron-n6* -F: arch/arm/dts/imx6ull-kontron-n6* +F: arch/arm/dts/imx6ul-kontron-sl* +F: arch/arm/dts/imx6ul-kontron-bl* +F: arch/arm/dts/imx6ull-kontron-sl* +F: arch/arm/dts/imx6ull-kontron-bl* F: board/kontron/sl-mx6ul F: configs/kontron-sl-mx6ul_defconfig F: doc/board/kontron/sl-mx6ul.rst diff --git a/board/kontron/sl-mx6ul/spl.c b/board/kontron/sl-mx6ul/spl.c index ba6915c898c..3ae8bf62094 100644 --- a/board/kontron/sl-mx6ul/spl.c +++ b/board/kontron/sl-mx6ul/spl.c @@ -22,8 +22,8 @@ DECLARE_GLOBAL_DATA_PTR;
enum { - BOARD_TYPE_KTN_N631X = 1, - BOARD_TYPE_KTN_N641X, + BOARD_TYPE_KTN_SL_UL = 1, + BOARD_TYPE_KTN_SL_ULL, BOARD_TYPE_MAX };
@@ -295,9 +295,9 @@ static void spl_dram_init(void) static int do_board_detect(void) { if (is_mx6ul()) - gd->board_type = BOARD_TYPE_KTN_N631X; + gd->board_type = BOARD_TYPE_KTN_SL_UL; else if (is_mx6ull()) - gd->board_type = BOARD_TYPE_KTN_N641X; + gd->board_type = BOARD_TYPE_KTN_SL_ULL;
printf("Kontron SL i.MX6UL%s (N6%s1x) module, %lu MB RAM detected\n", is_mx6ull() ? "L" : "", is_mx6ull() ? "4" : "3", gd->ram_size / SZ_1M); @@ -370,12 +370,12 @@ int board_early_init_f(void)
int board_fit_config_name_match(const char *name) { - if (gd->board_type == BOARD_TYPE_KTN_N631X && is_mx6ul() && - !strcmp(name, "imx6ul-kontron-n631x-s")) + if (gd->board_type == BOARD_TYPE_KTN_SL_UL && is_mx6ul() && + (!strcmp(name, "imx6ul-kontron-n631x-s") || !strcmp(name, "imx6ul-kontron-bl"))) return 0;
- if (gd->board_type == BOARD_TYPE_KTN_N641X && is_mx6ull() && - !strcmp(name, "imx6ull-kontron-n641x-s")) + if (gd->board_type == BOARD_TYPE_KTN_SL_ULL && is_mx6ull() && + (!strcmp(name, "imx6ull-kontron-n641x-s") || !strcmp(name, "imx6ull-kontron-bl"))) return 0;
return -1; diff --git a/configs/kontron-sl-mx6ul_defconfig b/configs/kontron-sl-mx6ul_defconfig index 4eb10bec0ee..9fc93b78ec9 100644 --- a/configs/kontron-sl-mx6ul_defconfig +++ b/configs/kontron-sl-mx6ul_defconfig @@ -12,7 +12,7 @@ CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_MX6UL=y CONFIG_TARGET_KONTRON_MX6UL=y CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="imx6ul-kontron-n631x-s" +CONFIG_DEFAULT_DEVICE_TREE="imx6ul-kontron-bl" CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_MMC=y CONFIG_SPL_SERIAL=y @@ -60,7 +60,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=spi1.0:128k(spl),832k(u-boot),64k(env);spi4.0: CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="imx6ul-kontron-n631x-s imx6ull-kontron-n641x-s" +CONFIG_OF_LIST="imx6ul-kontron-bl imx6ull-kontron-bl" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_MMC=y CONFIG_ENV_IS_IN_SPI_FLASH=y
From: Frieder Schrempf frieder.schrempf@kontron.de Sync the devicetrees with Linux and adjust the board names. Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de
Hi Stefano,
Notes:
- This series is based on imx/master and fixes the previously merged sync patch from Marcel [1].
- The devicetree changes this is based on are still pending in Linux (see [2]).
Can you please merge these patches so they land in v2023.01?
These have been around for two months and contain some important fixes for the kontron-sl-mx6ul board configuration.
Thanks! Frieder
On 24.10.22 09:39, Frieder Schrempf wrote:
Hi Stefano,
Notes:
Ah, I just saw that they are already in imx/master. Sorry for the noise. For some reason I didn't get pull notification e-mails while for my other patches I got them.
Hi Stefano,
Notes:
I have checked this - my script takes the address of the sender (see on ML's archive), notification were sent to frieder@fris.de, while patches are signed with your company's address.
Regards, Stefano
Hi Stefano,
Notes:
(see [2]).
[1] https://eur04.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchwork.... [2] https://eur04.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatchwork....
True, I got all the notifications there. So probably the forwarding rules in my mailbox don't work properly. Thanks for checking!
Frieder Schrempf
Frieder Schrempf
sbabic@denx.de
Stefano Babic
