[PATCH] arm64: a37xx: pinctrl: probe after binding
Currently, pinctrl drivers are getting probed during post-bind, however that is being reverted, and on A37XX pinctrl driver is the one that registers the GPIO driver during the probe.
So, if the pinctrl driver doesn't get probed GPIO-s won't get registered and thus they cannot be used.
This is a problem on the Methode eDPU as it just uses SB pins as GPIO-s and without them being registered networking won't work as it only has one SFP slot and the TX disable GPIO is on the SB controller.
So, lets just add a flag only to A37XX driver to probe after binding in order for the GPIO driver to always get registered.
Signed-off-by: Robert Marko robert.marko@sartura.hr --- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c index 25fbe39abd1..1be6252227d 100644 --- a/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c +++ b/drivers/pinctrl/mvebu/pinctrl-armada-37xx.c @@ -745,6 +745,19 @@ static int armada_37xx_pinctrl_probe(struct udevice *dev) return 0; }
+static int armada_37xx_pinctrl_bind(struct udevice *dev) +{ + /* + * Make sure that the pinctrl driver gets probed after binding + * as on A37XX the pinctrl driver is the one that is also + * registering the GPIO one during probe, so if its not probed + * GPIO-s are not registered as well. + */ + dev_or_flags(dev, DM_FLAG_PROBE_AFTER_BIND); + + return 0; +} + static const struct udevice_id armada_37xx_pinctrl_of_match[] = { { .compatible = "marvell,armada3710-sb-pinctrl", @@ -762,6 +775,7 @@ U_BOOT_DRIVER(armada_37xx_pinctrl) = { .id = UCLASS_PINCTRL, .of_match = of_match_ptr(armada_37xx_pinctrl_of_match), .probe = armada_37xx_pinctrl_probe, + .bind = armada_37xx_pinctrl_bind, .priv_auto = sizeof(struct armada_37xx_pinctrl), .ops = &armada_37xx_pinctrl_ops, };
Reviewed--by: Stefan Roese sr@denx.de
Thanks, Stefan
- dev_or_flags(dev, DM_FLAG_PROBE_AFTER_BIND);
- static const struct udevice_id armada_37xx_pinctrl_of_match[] = { { .compatible = "marvell,armada3710-sb-pinctrl",
- .bind = armada_37xx_pinctrl_bind, .priv_auto = sizeof(struct armada_37xx_pinctrl), .ops = &armada_37xx_pinctrl_ops, };
Viele Grüße, Stefan Roese
Thanks, Stefan
};.bind = armada_37xx_pinctrl_bind, .priv_auto = sizeof(struct armada_37xx_pinctrl), .ops = &armada_37xx_pinctrl_ops,
This is OK if you really want to do this. Is it not possible to do the bind of the GPIO devices in the pinctrl bind() handler, as is done by other SoCs? Why do we need to probe the pinctrl driver first?
Thanks, Stefan
Because on A37xx the pinctrl driver needs to be probed before the GPIO one can be probed as GPIO driver is using internal data that is filled in by the pinctrl driver.
Regards, Robert
Thanks, Stefan
Applied to u-boot-dm, thanks!
Robert Marko
Stefan Roese
